John Deere 925 935 Rotary Impeller-Mower Conditioners Operators Manual OME92549
- Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Rotary Impeller-Mower Conditioners
Model: John Deere 925 935 Rotary Impeller-Mower Conditioners
Serial Number: 925 (Serial No. 124001-), 935 (Serial No. 125001-)
Part Number: OME92549
Number of Pages: 134 Pages
Safety
Safety Signs
Preparing the Tractor
Positioning Tractor Drawbar
Attaching Drawbar Extension to Tractor
Drawbar (Ball-Joint Hitch)
Checking Ballast, Wheel Spacing and
Tire Inflation
Selecting Tractor PTO Speed
Using Drawbar Shield
Making Drawbar Shield
Preparing the Mower-Conditioner
Adjusting Mower-Conditioner Hitch
Determining Need for Turn Limiters
Installing Turn Limiters (If Required)
Narrow
Wide
Installing Tongue Positioner
Mechanical Pull-Rope
Hydraulic Cylinder
Checking Tire Inflation
Checking Wheel Nut Torque
Attaching and Detaching
Attaching to Tractor Drawbar
PTO Driveline
Assembling
Attaching
Installing Safety Chain
Connecting Warning Light Harness (If
Equipped)
Attaching to Tractor Hydraulic System
Attaching Tongue Positioner Pull-rope
Detaching Mower-Conditioner from
Tractor
Transporting
Page
Operating the Mower-Conditioner
Prestarting Checks
Breaking-In Mower-Conditioner
Keep Riders Off Machine
Follow Safe Operating Procedures
Positioning Tongue for Field Operation
Operating Tips for Making Right-Hand
Turn
Operating Tips for Making 180 Degree
Turn
Settings for Various Crop Conditions
Raising and Lowering Curtain
Adjusting
Windrow Width
Gauge Shoes
Carrier Frame Height
Adusting Cut Height
Turnbuckle Top Link
Hydraulic Tilt Control
Adjusting
Platform Float
Conditioner Roll Pressure
Roll Spacing
Shearing Disk Driver When Operating in
the Field
Lubrication and Maintenance
Lubricating and Maintaining Machine
Safely
Grease
Cutterbar and Gear Case Oil
Mixing of Lubricants
Lubricant Storage
Observe Lubrication Symbols
Perform Lubrication and Maintenance
Every 10 Hours
Every 50 Hours
Every 100 Hours
Every 200 Hours
Each Season
Troubleshooting
Service
Practice Safe Service Procedures
Keep Service Area Clean
Service Tires Safely
Bleeding Platform Lift Circuit
Unplugging Machine
Adjusting Wheel Bearing
Slip Clutch
Adjusting
Slipping
Replacing Lining
Adjusting Cutterbar Drive Belt Tension
Replacing Cutterbar Drive Belt
Disks
Removing
Installing and Synchronizing
Knives
Removing
Installing
Checking
Checking Knife Wear
Checking Knife Mounting
Knife Bolts
Checking
Replacing
Checking Knife Nuts
Direction of Knife Rotation
Direction of Disk Rotation
Changing Direction of Disk Rotation
Replacing Wear Shield on Knife Bolt
Clean Disk Area When Replacing Disk
Driver
Replacing Disk Driver
Replacing Left-Hand End Converging
Disk Driver
Replacing Right-Hand End Converging
Disk Driver
Optional Gauge Shoes
Installing
Removing
Changing Tire
Page
Storage
Specifications
Machine Specifications
925 Mower-Conditioner
935 Mower-Conditioner
Record Product Identification Number
Bolt and Cap Screw Torque Value Charts
Metric
Inch
Crime Prevention Tips
Index
Brand: John Deere
Safety
Safety Signs
Tire Inflation
Narrow
Wide
Hydraulic Cylinder
PTO Driveline
Assembling
Attaching
Equipped)
Tractor
Transporting
Page
Prestarting Checks
Turn
Turn
Adjusting
Windrow Width
Gauge Shoes
Adusting Cut Height
Turnbuckle Top Link
Adjusting
Platform Float
Roll Spacing
the Field
Safely
Grease
Lubricant Storage
Every 10 Hours
Every 50 Hours
Every 100 Hours
Every 200 Hours
Each Season
Troubleshooting
Service
Unplugging Machine
Slip Clutch
Adjusting
Slipping
Replacing Lining
Disks
Removing
Knives
Removing
Installing
Checking
Checking Knife Wear
Knife Bolts
Checking
Replacing
Checking Knife Nuts
Driver
Disk Driver
Disk Driver
Installing
Removing
Changing Tire
Page
Storage
Specifications
Metric
Inch
Index
- JOHN DEERE CODE DTC LIST
