John Deere 9100 9200 9300 9400 9120 9220 9320 9420 9520 9620 Tractor Repair Manual TM1623
Brand: John Deere
Type of Manual: Repair Manual
Model: John Deere 9100 9200 9300 9400 9120 9220 9320 9420 9520 9620 Tractor
Part Number: TM1623
Publication Date: 2010
Number of Pages: 1813 Pages
FOREWORD
NOTICE TO THE DEALER
DEALER PREDELIVERY INFORMATION FORM
Section 10 - GENERAL INFORMATION
Group 05 - Safety
Recognize Safety Information
Follow Safety Instructions
Practice Safe Maintenance
Protect Against High Pressure Spray
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Avoid High-Pressure Fluids
Park Machine Safely
Support Machine Properly
Wear Protective Clothing
Work in Clean Area
Service Machines Safely
Work In Ventilated Area
Illuminate Work Area Safely
Replace Safety Signs
Use Proper Lifting Equipment
Service Tires Safely
Avoid Harmful Asbestos Dust
Use Proper Tools
Dispose of Waste Properly
Live With Safety
Protect Against Noise
Keep ROPS Installed Properly
Wait Before Opening High-Pressure Fuel System
Group 10 - General Information
General Specifications—9000 Series
General Specifications—9020 Series
General Specifications—9000 and 9020 Series
Identify Zinc-Flake Coated Fasteners
Sealants and Adhesives Cross-Reference Chart
Glossary of Terms
Section 20 - ENGINE
Group 00 - Component Removal and Installation
Essential or Recommended Tools
Specifications
Remove 8.1 L Engine—9000 Series
Remove 8.1 L Engine—9020 Series
Install 8.1 L Engine
Engine Identification—10.5 L and 12.5 L Engines
Remove 10.5 L and 12.5 L Engine—Dual-Rail
Remove 10.5 L and 12.5 L Engine—Single-Rail
Install 10.5 L and 12.5 L Engine
Determine Engine Shim Pack
Group 05 - Engine Repair
Repair Engine—Use CTM
Other Material
Specifications
Remove and Install Oil Pan—8.1 L Engine
Section 30 - FUEL, AIR, AND COOLING SYSTEMS
Group 05 - Diesel Fuel System
Remove and Install Left Fuel Tank
Remove, and Install Right Fuel Tank
Replace Fuel Filter, Fuel Pump, and Bleed Fuel System
Group 10 - Air Intake and Exhaust Systems
Specifications
Install Muffler
Air Intake Pipe Connections
Turbocharger Inlet Hose
Air Intake Pipe Installation
Inspect Air Intake System
Service Air Intake System
Group 15 - Engine Cooling System
Specifications
Test Radiator and Coolant Tank
Test Radiator Cap
Remove and Install Radiator
Remove and Install Aftercooler
Remove and Install Viscous Fan Drive
Inspect Belt Tensioner
Drive Belt Routings
Group 20 - Oil Coolers
Specifications
Remove and Install Oil Cooler—9100, 9200
Remove and Install Axle Oil Cooler—9300, 9400
Remove and Install Hydraulic/Transmission Oil Cooler—9300, 9400
Remove and Install Oil Cooler—9020 Series
Leak Test Oil Coolers
Section 40 - ELECTRICAL
Group 05 - Connectors
Other Material
Use Electrical Insulating Compound
Using High-Pressure Washers
Repair AMP Connector
Remove Connector Body from Blade Terminals
Repair CINCH Connectors
Repair 32 and 48 Way CINCH Connectors
Repair CPC CPC is a trademark of AMP Incorporated Blade Type Connectors
Repair CPC CPC is a trademark of AMP Incorporated , Large MATE-N-LOC MATE-N-LOC is a trademark of AMP Incorporated and METRIMATE METRIMATE is a trademark of AMP Incorporated Pin Type Connectors
Repair DEUTSCH DEUTSCH is a trademark of Deutsch Company Connectors
Repair DEUTSCH™ Implement Connectors
Repair Small MATE-N-LOC MATE-N-LOC is a trademark of AMP Incorporated Socket Connector
Repair Small MATE-N-LOC MATE-N-LOC is a trademark of AMP Incorporated Pin Connector
Repair (Pull Type) METRI-PACK METRI-PACK is a trademark of Delphi Packard Electric Systems Connectors
Repair (Push Type) METRI-PACK METRI-PACK is a trademark of Delphi Packard Electric Systems Connectors
Repair SUMITOMO™ Connectors
Repair Weather Pack Weather Pack is a trademark of Packard Electric Connector
Repair YAZAKI™ Connectors
Group 10 - Wiring Harness Routings
Wire Numbers and Color Codes
Ground Point Locations
Chassis Single Point Grounds
Cab Ground (Roof)
Cab Ground (Floor)
# 4 Cab-To-Chassis Ground Cable
Miscellaneous Grounds
Engine/Chassis Harness Routing and Component Identification—9100 MST
Engine/Chassis Harness Routing and Component Identification—9.0 L
Dual-Rail Engine/Chassis Harness Routing and Component Identification—9200, 9300, and 9400 MST
Single-Rail Engine/Chassis Harness Routing and Component Identification—9200, 9300, and 9400 MST
Engine/Chassis Harness Routing and Component Identification—9220, 9320, 9420, and 9520 MST
Rear Engine/Chassis Harness Routing and Component Identification—MST
Engine/Chassis Harness Routing and Component Identification—9120 PST
Dual-Rail Engine/Chassis Harness Routing and Component Identification—9000 PST
Single-Rail Engine/Chassis Harness Routing and Component Identification—9000 PST
Engine/Chassis Harness Routing and Component Identification—13.5 L (North American)
Rear Engine/Chassis Harness Routing and Component Identification—PST
Engine/Chassis Harness Routing and Component Identification—13.5 L (European)
Rear European Engine/Chassis Harness Routing and Component Identification—PST
Transmission Harness Routing and Component Identification—PST
Transmission Harness Routing and Component Identification—9020 Series w/PST (S.N. —011407)
Cab Harness Routing and Component Identification—9100—9400 (S.N. —30000) MST
Cab Harness Routing and Component Identification—9100—9400 (S.N. 30001— ) MST
Cab Harness Routing and Component Identification—9100—9400 (S.N. —30000) PST
Cab Harness Routing and Component Identification—9100—9400 (S.N. 30001— ) PST
Cab Harness Routing and Component Identification—PST
Cab Harness Routing and Component Identification—European
Roof Harness Routing and Component Identification—North American
Roof Harness Routing and Component Identification—European
ACTIVE SEAT ACTIVE SEAT is a trademark of Deere & Company Harness Routing and Component Identification
Remote Mirror Harness Routing and Component Identification
GREENSTAR GREENSTAR is a trademark of Deere & Company Harness Routing and Component Identification
Group 15 - Charging Circuit
Disconnect Electrical Circuit
Repair Alternator—Use CTM
Exploded View—Alternator
Replace Alternator
Alternator Power Cable Routing
Replace Batteries
Group 20 - Starting Circuit
Specifications
Repair Starter—Use CTM77
Remove and Install Starter
Replace Fusible Link
Remove and Install Start Circuit Relay
Group 25 - Relays, Fuses, Solenoids, and Switches
Specifications
General Repair Procedures—Solenoids
Load Center Fuses—9000 Series
Load Center Fuses—9020 Series (S.N. —009999)
Load Center Fuses
Load Center Relays and Diodes—9000 Series
Load Center Relays and Diodes—9020 Series (S.N. —009999)
Replace Starting Aid Solenoid
Replace Fuel Shut-Off Solenoid
Replace Differential Lock Solenoid
Replace Two-Speed Clutch Hi-Lo Solenoid—MST
Replace Solenoid Valves—PST
Replace Park Brake Valve Solenoids
Replace Park Brake Valve Solenoids—9020 Series w/PST (S.N. —011407)
Replace SCV Solenoids
Replace Hitch Valve Solenoids
Exploded View—Right Console Controls and Switches—9000
Replace Right Console Switches
Replace Engine Oil Pressure Switch
Replace Starting Aid and Ignition Switch
Replace Clutch On/Off Switch
Replace Clutch Up and Down Switch Assembly
Replace Differential Lock Switch
Neutral Start Switch—MST
Replace Neutral Start Switch—PST
Replace Rear PTO Switch
Replace Brake Switch
Replace Dome Light Switch
Replace Cab Door Light Switch
Replace Beacon Light Switch
Replace Seat Raise/Lower Switch
Replace Operator Presence Seat Switch
Replace Hand Brake Switch—9000 PST European
Replace Hand Brake Switch and Potentiometer (European)
Replace Park Brake Valve Pressure Sensor
Replace Park Brake Valve Pressure Switch—9020 Series w/PST (S.N. —011407)
Replace External Hitch Raise/Lower Switch
Replace A/C High- and Low-Pressure Switches
Replace A/C Deicing Switch and Blower Motor Resistor
Group 30 - Monitoring Systems and Sensors
Other Material
Specifications
Replace Instrument Control Unit and SCV Set-up Panel
Replace Bulbs and Gauges in Instrument Control Unit (ICU)
Replace Bulbs SCV Set-Up Panel (SUP)
Replace Corner Post Display and Bulbs
Replace Steering Column Module Bulbs
Replace Control Units—9000 Series
Replace EEPROM EEPROM—Electrically Erasable Programmable Read-Only Memory In Control Units
Remove EEPROM
Replace Power Shift Controller—9000 PST
Replace Engine Cam Speed Sensor
Replace Engine Crank Speed Sensor—9000 Series
Replace Engine Coolant Temperature Sensors
Replace Fuel Level Sensor
Replace Fuel Temperature Sensor
Replace Air Filter Restriction Sensor
Replace Manifold Air Intake Temperature Sensor (MAT)
Remove, Inspect, and Adjust Clutch Position Sensor
Replace Transmission Input and Output Speed Sensor—9000 PST
Replace Transmission Oil Temperature Sensor—9000 PST
Replace Transmission Filter Restriction Sensor—9000 PST
Replace Transmission Lube Oil Pressure Sensor—9000 PST
Replace Transmission Lube Oil Pressure Sensor—MST
Replace Transmission Oil Filter Restriction Sensor—MST
Replace Axle Lube Filter Restriction Sensor—9000 PST
Replace Axle Lube Pressure Sensor—9000 PST
Replace Axle Lube Pressure Sensor—MST
Replace Hydraulic Oil Temperature Sensor
Replace Hydraulic Oil Reservoir Level Sensor
Replace Hydraulic Oil Filter Restriction Sensor
Replace Wheel Speed Sensor—MST
Replace Radar Sensor
Replace Hitch Position Sensor
Remove, Install, and Adjust Draft Sensor
CLIMATRAK CLIMATRAK is a trademark of Deere & Company Wire Harness and Component Identification
Replace Outlet Duct Temperature Sensor
Replace Cab Temperature Sensor
Replace Fresh Air Temperature Sensor
Replace Evaporator Temperature Sensor
Group 35 - Armrest Control
Armrest Test Procedures
Exploded View—Armrest Control—9000 Series
Replace Armrest Control Assembly
Replace Armrest Control Unit (ACU)
Replace Armrest Controls—9000 Series
Exploded View—Engine Speed Control
Exploded View—Transmission Control (PST)
Exploded View—Hi-Lo Clutch Control (MST)
Replace Hitch Control
Exploded View—SCV Control Lever
Group 40 - Implement and Accessory Connectors
Replace Seven-Terminal Outlet Socket
TOUCHSET™ Depth Control Connector
Diagnostic/Program
ECU Diagnostic Connector
Group 45 - Convenience and Accessory Components
Replace Circulation Blower Motor
Replace Pressurizer Blower Motor
Replace Wiper Motors
Replace Windshield Washer Pumps
Remove Radio and Speakers—Style A
Section 50 - 18-SPEED POWER SHIFT TRANSMISSION (9020)
Other Material
Specifications
Remove Power Shift Transmission
Install Transmission to Rollover Stand Bracket
Install Power Shift Transmission
Check Transmission Oil Level
Group 05 - In Tractor Repair
Other Material
Specifications
Remove Filter Relief Valve
Disassemble and Assemble Filter Relief Valve
Remove, Repair, and Install Filter Relief Valve Housing
Remove and Install Input and Output Yokes
Repair Internal Park Brake (S.N. 011408— )
Replace Input and Output Shaft Seals
Group 10 - Transmission Repair
Repair 18-Speed PST
Group 15 - Transmission Cleanup
Perform Transmission Cleanup
Group 20 - Clutch Control
Repair Clutch Pedal Assembly
Section 52 - 12-SPEED POWER SHIFT TRANSMISSION (9000)
Other Material
Specifications
Install Transmission on Engine Rotation Stand
Shim Transmission
Group 05 - Clutch Control
Repair Clutch Pedal
Group 10 - Transmission Oil Filter Relief Valve Housing and Oil Pump
Specifications
Remove and Install Transmission Filter Relief Valve Housing
Disassemble and Assemble Filter Relief Valve Housing
Repair Oil Distribution Manifold
Remove, Inspect, and Install Oil Pump
Group 15 - Transmission Pressure Regulating Valve
Specifications
Remove, Inspect, and Install Pressure Regulating Valve
Group 20 - On-Off and Modulating Shift Solenoids
Specifications
Replace Solenoids
Remove and Replace Modulating Shift Valves
Clean and Inspect Modulating Shift Valves
Remove and Replace On-Off Shift Valve Solenoids
Group 25 - 8-Inch Clutch Assembly
Specifications
Cross-Sectional View—8-Inch Clutch Assembly
Exploded View—8-Inch Clutch Assembly
Disassemble and Inspect 8-Inch Clutch
Assemble 8-Inch Clutch
Group 30 - Lower 7-Inch Clutch Assembly
Specifications
Cross-Sectional View—Lower 7-Inch Clutch Assembly
Exploded View—Lower 7-Inch Clutch Assembly
Disassemble and Inspect Lower 7-Inch Clutch
Assemble Lower 7-Inch Clutch
Group 35 - Upper 7-Inch Clutch Assembly
Specifications
Cross-Sectional View—Upper 7-Inch Clutch Assembly
Exploded View—Upper 7-Inch Clutch Assembly
Disassemble and Inspect Upper 7-Inch Clutch
Assemble Upper 7-Inch Clutch
Group 40 - Compound Shaft Assembly
Cross-Sectional View—Compound Shaft Assembly
Exploded View—Compound Shaft Assembly
Disassemble Compound Shaft
Assemble Compound Shaft
Group 45 - 9-Inch Clutch Assembly
Specifications
Cross-Sectional View—9-Inch Clutch Assembly
Exploded View—9-Inch Clutch Assembly
Disassemble and Inspect 9-Inch Clutch
Assemble 9-Inch Clutch
Group 50 - Front and Rear Housings
Other Material
Specifications
Disassemble Transmission
Remove and Install All Shafts
Remove and Install Upper 7-Inch Clutch Shaft Assembly
Remove and Install Lower 7-Inch Clutch Shaft Assembly
Remove and Install Compound Shaft Assembly
Remove and Install 8-Inch Clutch Shaft Assembly
Remove and Install 9-Inch Clutch Shaft Assembly
Disassemble and Assemble Front and Rear Housings
Assemble Transmission
Adjust Clutch Shaft End Play
Adjust Upper 7-Inch Clutch Shaft End Play
Adjust Lower 7-Inch Clutch Shaft End Play
Adjust Compound Shaft End Play
Adjust 9-Inch Clutch Shaft End Play Adjustment
Adjust 8-Inch Clutch Shaft End Play
Replace Front Output Shaft Oil Seal
Replace Input Shaft Oil Seal
Install Input and Front Output Yokes
Install Rear Output Yoke
Adjust Speed Sensors
Group 55 - Transmission Cleanup
Other Material
Section 55 - MECHANICAL SHIFT TRANSMISSION (MST)
Other Material
Specifications
Remove Mechanical Shift Transmission
Install Mechanical Shift Transmission
Shim Transmission—9000 Series
Transmission/Axle Oil Fill—All MST & 9020 PST
Group 05 - Transmission Oil Filter Relief Valve Housing
Specifications
Remove Filter Relief Valve Housing
Group 10 - Transmission Control Valve Housing
Other Material
Specifications
Repair Clutch Pedal
Remove and Install Clutch Operating Cable
Adjust Clutch Cable
Remove Transmission Control Valve Housing
Cross-Sectional View—Transmission Control Valve
Exploded View—Transmission Control Valve
Disassemble, Inspect, and Assemble Transmission Control Valve Housing
Install Transmission Control Valve
Group 15 - Transmission Pump
Specifications
Remove Transmission Pump
Cross-Sectional View—Transmission Pump and Bearing Quill (12-Speed)
Exploded View—Transmission Pump and Bearing Quill (12-Speed)
Cross-Sectional View—Transmission Pump and Bearing Quill (24-Speed)
Disassemble, Inspect, and Assemble Transmission Pump
Install Transmission Pump
Group 20 - Transmission Front Cover
Other Material
Specifications
Remove Transmission Front Cover
Remove, Inspect, and Install Front Cover Parts
Install Transmission Front Cover
Group 25 - Hi-Lo Clutch and Brake (24-Speed)
Other Material
Specifications
Cross-Sectional View—Hi-Lo Clutch and Brake
Exploded View—Hi-Lo Clutch and Brake
Remove Clutch and Brake Pack
Disassemble, Inspect, and Assemble Hi-Lo Clutch and Brake Assembly
Install Hi-Lo Clutch and Brake Assembly
Group 30 - Hi-Lo Planetary (24-Speed)
Specifications
Cross-Sectional View—Hi-Lo Planetary
Exploded View—Hi-Lo Planetary
Remove Hi-Lo Planetary Assembly
Disassemble, Inspect, and Assemble Hi-Lo Planetary
Install Hi-Lo Planetary Assembly
Group 35 - Spacer Housing (24-Speed)
Other Material
Remove, Inspect, and Install Spacer Housing and Parts
Group 40 - Traction Clutch
Other Material
Specifications
Remove Traction Clutch Assembly
Cross-Sectional View—Traction Clutch
Exploded View—Traction Clutch
Disassemble, Inspect, and Assemble Traction Clutch
Remove and Inspect Traction Clutch Manifold
Install Traction Clutch Manifold
Install Traction Clutch Assembly
Group 45 - Transmission Gear Drives
Other Material
Specifications
Cross-Sectional View—Transmission Gear Drives
Remove Transmission Top Shaft, Upper Countershaft, Lower Countershaft, and Output Shaft
Cross-Sectional and Exploded Views—Top Shaft
Cross-Sectional and Exploded Views—Upper Countershaft
Cross-Sectional and Exploded Views—Lower Countershaft
Cross-Sectional and Exploded Views—Output Shaft
Disassemble and Inspect Shafts
Disassemble, Inspect, and Assemble Drive/Shift Collar (12-Speed)
Disassemble and Inspect Synchronizer
Assemble Synchronizer
Assemble Lower Countershaft
Assemble Upper Countershaft
Disassemble and Assemble Park Pawl Assembly
Cross-Sectional and Exploded Views—Shifter Cams
Remove and Install Shifter Cams
Adjust Neutral Start and Reverse Switches
Disassemble and Assemble Shifter Fork
Remove and Install Front Case Parts
Remove and Install Reverse Idler Gear
Install Transmission Shafts
Install Rear Case
Adjust Shaft End Play
Install Yoke Seals and Yokes
Group 50 - Transmission Cleanup
Other Material
Group 55 - Shift Levers and Linkage
Specifications
Remove and Install Shift Lever Control Assembly
Exploded View—Shifter Lever Control Assembly Components
Disassemble, Inspect, and Assemble Shift Lever Control Assembly
Remove, Disassemble, Assemble, and Install Upper Shift Rods
Remove, Disassemble, and Assemble Shifter Bell Crank Components
Install Bell Crank Assembly
Remove, Disassemble, Assemble, and Install Lower Shift Rods
Adjust Lower Shift Rods
Adjust Neutral Lockout Plate
Section 56 - DRIVE SYSTEMS
Specifications
Remove and Install PTO Clutch
PTO-to-Transmission Alignment
Remove and Install PTO Drop Box Assembly
Group 05 - Engine Coupler
Other Material
Specifications
Replace Engine Coupler
Group 10 - Drive Shafts
Specifications
Inspect and Replace Universal Joints
Group 15 - PTO Clutch
Other Material
Specifications
Cross-Sectional View—PTO Clutch Assembly
Exploded View—PTO Rear Cover and Brake Assembly
Exploded View—PTO Clutch Housing and Shaft
Exploded View—PTO Clutch Assembly
Disassemble, Inspect, and Assemble PTO Clutch
Group 20 - PTO Clutch Valve and Linkage
Other Material
Specifications
Remove and Install PTO Clutch Valve
Disassemble, Inspect, and Assemble PTO Clutch Valve
Remove and Install PTO Clutch Lever
Replace PTO Clutch Operating Cable
Adjust PTO Clutch Operating Cable
Group 25 - PTO Drop Box
Other Material
Specifications
Cross-Sectional View—PTO Housing Assembly
Disassemble, Inspect, and Assemble PTO Drop Box
Section 57 - AXLES
Essential, Recommended and Fabricated Tools
Specifications
Remove and Install Front Axle Assembly
Remove and Install Rear Axle Assembly
Check Axle Oil Level—9000 PST
Group 02 - Park Brake
Specifications
Inspect Park Brake Disk
Group 03 - Repair Preparation
Essential Tools
Remove and Install Park Brake Components—9000 PST and European MST
Remove and Install Park Brake Components——9020 Series w/PST (S.N. —011407)
Install and Remove Axle Assembly in Repair Stand
Group 05 - Input Housing
Other Material
Specifications
Replace Vent Tube
Remove Input Housing/Cover
Cross-Sectional View—Input Housing/Cover
Disassemble Input Housing/Cover
Assemble Input Housing/Cover
Determine Spiral Bevel Pinion Shaft Cone Point Shim Pack
Continue Assembly of Input Housing Cover
Adjust Differential Drive Shaft
Install Input Housing/Cover
Group 10 - Differential
Other Material
Specifications
Remove Differential
Cross-Sectional View—Differential with Differential Lock
Cross-Sectional View—Standard Differential
Disassemble, Inspect, and Assemble Differential
Install Differential
Adjust Differential Preload
Adjust Differential Backlash
Group 15 - Final Drives
Other Material
Specifications
Remove Final Drive Assemblies
Cross-Sectional View—Final Drive
Disassemble Final Drive
Disassemble, Inspect, and Assemble Planet Pinion Carrier
Remove Axle Housing
Disassemble and Assemble Axle Housing
Disassemble, Inspect, and Assemble Axle Shaft
Install Axle Housing
Adjust Axle Bearings
Install Final Drive Assemblies
Group 20 - Brakes
Specifications
Replace Brakes
Section 60 - STEERING AND BRAKES
Group 05 - Steering Column
Specifications
Repair Steering Column
Group 10 - Steering Control Valve
Specifications
Remove and Install Steering Valve
Exploded View—Steering Control Valve
Disassemble, Inspect, and Assemble Steering Valve
Group 15 - Steering Cylinders
Other Material
Service Parts Kits
Specifications
Remove and Install Steering Cylinders
Disassemble and Assemble Steering Cylinder
Group 20 - Brake Valve
Service Parts Kits
Specifications
General Repair Procedures—Brake Valve
Remove and Install Brake Valve
Disassemble, Inspect, and Assemble Brake Valve
Adjust Brake Pedal
Bleed Brakes
Check Manual Brakes
Group 25 - Park Brake
Specifications
Manual Park Brake Release——9020 Series w/PST (S.N. —011407)
Manual Park Brake Release—9020 Series w/PST (S.N. 011408— )
Exploded View—Park Brake Caliper—9020 Series w/PST (S.N. —011407)
Exploded View—Park Brake Valve 9020 Series w/PST (S.N. —002423)
Exploded View—Park Brake Valve 9020 Series w/PST (S.N. 002424—011407)
Park Brake Valve Hose Connections—Park Brake Caliper—9020 Series w/PST (S.N. —011407)
Inspect Park Brake Disk (If Equipped)
Remove and Install Park Brake Caliper (If Equipped)
Adjusting Park Brake—9000 Series w/PST (S.N. 030001—040000)
Park Brake Adjustment—9020 Series w/PST (S.N. —011407)
Secondary Brake Adjustment—9020 Series w/PST (S.N. 011408— )
Section 70 - HYDRAULICS
Other Material
Specifications
Remove and Install Hydraulic Oil Reservoir
Remove and Install Hydraulic Pump—9000 MST and 9020 Series
Remove and Install Hydraulic Pump—9000 PST
Remove and Install High-Flow Hydraulic Pumps
Fill Hydraulic Pump Crankcase
Group 05 - Hydraulic System Repair
Specifications
Disconnect Battery Ground Cable
Use Special Wrench
Install Hydraulic Fittings
Drain and Fill Hydraulic Reservoir
Group 10 - Hydraulic Pump
Service Parts Kits
Other Material
Specifications
Pump Identification—9000 Series
Pump Identification—High-Flow Hydraulic
Remove and Install Hydraulic Pump Controller—Vickers
Exploded View—Hydraulic Pump Controller—Vickers
Disassemble, Inspect, and Assemble Hydraulic Pump Controller—Vickers
Exploded View—Hydraulic Pump—Vickers
Disassemble and Inspect Hydraulic Pump—Vickers
Remove and Install Pump Shaft Seal—Vickers
Assemble Hydraulic Pump—Vickers
Exploded View—Hydraulic Pump—Sauer
Service Hydraulic Pump Control—Sauer
Disassemble and Inspect Hydraulic Pump—Sauer
Replace Hydraulic Pump Shaft Seal—Sauer
Assemble Hydraulic Pump—Sauer
Replace Shaft Seal—45 cm3 Pump
Service Hydraulic Pump Control—45 cm3 Pump
Repair Hydraulic Pump—45 cm3 Pump
Group 15 - Axle Lubrication and Charge Pumps
Other Material
Service Parts Kits
Specifications
Remove and Install Axle Lubrication Pump—9000 MST and 9020 Series
Exploded View—Axle Lubrication Pump—9000 MST and 9020 Series
Disassemble, Inspect, and Assemble Axle Lubrication Pump—9000 MST and 9020 Series
Remove and Install Axle Lubrication Pump—9000 PST
Exploded View—Axle Lubrication Pump—9000 PST
Disassemble, Inspect, and Assemble Axle Lubrication Pump—9000 PST
Remove and Install Charge Pump—9000 PST
Exploded View—Charge Pump—9000 PST
Disassemble, Inspect, and Assemble Charge Pump—9000 PST
Group 20 - Filter Housings and Control Valves
Service Parts Kits
Specifications
Remove, Inspect, and Install Hydraulic Filter Housing
Remove, Inspect, and Install Axle Filter Housing—9000 PST
Repair Sequence Valve—9000 PST
Disassemble and Assemble Return Oil Manifold—9000 PST
Reference—Priority Valve
Remove and Install Priority Valve
Disassemble, Inspect, and Assemble Priority Valve
Remove and Install Differential Lock Valve
Exploded View—Differential Lock Valve
Inspect Differential Lock Valve
Remove, Inspect, and Install Cooler Bypass Valve—9000 Series and 9020 MST
Group 25 - Hitch Valve, Selective Control Valves, and Couplers—9000 Series
Service Parts Kits
Specifications
Remove and Install Hitch-SCV Valve Stack
Disassemble and Assemble Hitch-SCV Valve Stack
Disassemble, Inspect, and Assemble Hitch Manifold
Remove, Inspect, and Install Hitch and SCV Solenoids
Disassemble, Inspect, and Assemble Hitch Valve
Test Surge Relief Valve
Disassemble, Inspect, and Assemble Selective Control Valve
Exploded View—Coupler
Repair SCV Couplers
Group 30 - Hitch Valve, Selective Control Valves, and Couplers—9020 Series
Specifications
Top Cover Identification
Exploded View—Standard End Cover
Exploded View—Deluxe End Cover
Disassemble and Assemble High Flow SCV Valve Stack
Test High Pressure Relief Valve
Repair SCV Couplers
Group 35 - High-Flow Selective Control Valve—Scraper
Specifications
Remove and Install High-Flow SCV Stack
Repair High-Flow SCV Stack
Group 40 - Hitch
Other Material
Specifications
Remove and Install Lift Cylinder
Cross-Sectional and Exploded View—90 mm Lift Cylinder
Cross-Sectional and Exploded View—100 mm Lift Cylinder
Disassemble, Inspect, and Assemble Lift Cylinder
Repair Hitch Lift Arm Assembly
Section 80 - MISCELLANEOUS
Group 05 - Hood and Side Panels
Remove and Install Hood
Releasing Broken Hood Latch
Adjust Hood
Adjust Side Panel
Group 10 - Heavy-Duty Wheels—9020 Tractors
Specifications
Service Heavy-Duty Wheel Clamps
Section 90 - OPERATOR STATION
Other Material
Specifications
Remove Cab
Exploded View—Cab Mounts
Install Cab
Repair Cab
Group 05 - Heating, Ventilating, and Air Conditioning (HVAC)
Specifications
Heater Line Routing
Remove HVAC Module
Install HVAC Module
Remove and Install Temperature Control Cable
Adjust Heating/Cooling Controls
Remove and Install Heater Core
Leak Test Heater Core
Remove, Test, and Install Heater Control Valve—Without CLIMATRAK CLIMATRAK is a trademark of Deere & Company
Remove, Test, and Install Heater Control Valve—With CLIMATRAK CLIMATRAK is a trademark of Deere & Company (S.N. —010001):
Remove and Install Heater Control Valve With CLIMATRAK CLIMATRAK is a trademark of Deere & Company ( S.N 010001- )
Group 10 - Air Conditioning System
Other Material
Service Parts Kits
Specifications
Hose and Tubing O-Ring Connection Torques
Diagram—Air Conditioning System
Reference Chart—Air Conditioning System Fittings
Leak Test With Dye
Discharge Air Conditioning System
Flushing, Purging, and Evacuating Information
Flush Air Conditioning System
Purge Air Conditioning System
Evacuate Air Conditioning System
Charge Air Conditioning System
Refrigerant Oil Information
Check Compressor Oil Charge
Determine Correct Refrigerant Oil Charge
Add Refrigerant Oil to System
Add Refrigerant to Pressurized System
Remove and Install Compressor
Test Volumetric Efficiency
Test Shaft Seal Leakage
Disassemble and Assemble Compressor Clutch
Check Clutch Hub Clearance
Inspect Compressor Manifold
Inspect Compressor Thermal Bypass Valve
Disassemble, Inspect, and Assemble Compressor
Remove and Install Compressor Relief Valve
Replace Receiver-Dryer
Leak Test Condenser
Remove Air Conditioning Condenser
Leak Test Evaporator
Remove and Install Evaporator
Remove and InstallExpansion Valve
Group 15 - Air Suspension Seat (S.N. —030000)
Other Material
Remove Seat and Swivel Plate From Suspension
Disassemble, Inspect, and Assemble Air Suspension Assembly
Group 20 - Air Suspension Seat (S.N. 030001— ) and 9020 Series
Other Material
Specifications
Remove and Install Seat
Repair Air System
Remove and Install Ride Zone Protector (RZP)—9000 Series
Repair Suspension
Repair Seat Back
Repair Control Knobs
Group 25 - ACTIVE SEAT™
Other Material
Specifications
Purging Air from ACTIVE SEAT ACTIVE SEAT is a trademark of Deere & Company System
Remove and Install ACTIVE SEAT ACTIVE SEAT is a trademark of Deere & Company
Remove and Install ACTIVE SEAT ACTIVE SEAT is a trademark of Deere & Company Actuator
Remove and Install Actuator Hoses
Remove and Install Seat Control Valve Assembly
Exploded View—ACTIVE SEAT™ Hydraulic Control Valve Block
Replace Seat Control Valve Assembly O-Rings
Remove and Install Accumulator
Checking and Charging Replacement Accumulators
Repair Active Seat Air System
Repair Active Seat Suspension
Repair Seat Back
Group 30 - Armrest
Remove and Install Armrest Control
Disassemble and Assemble Armrest Adjustment Assembly—Style A
Disassemble and Assemble Adjustable Armrest Support—Style B
Group 35 - Cab Door and Windshield
Door Latch Identification—Version "A" and Version "B"
Repair Cab Door Latch
Cab Door Adjustment
Replace Windshield Glass or Seal
Section 95 - HINGE AND GUDGEON
Group 05 - Hinge
Other Material
Specifications
Replace Hinge Pins and Bushings
Group 10 - Gudgeon
Other Material
Specifications
Remove Gudgeon Drive Shaft
Inspect Universal Joint and Drive Shaft
Install Gudgeon Drive Shaft
Replace Gudgeon Journal Bearings, Thrust Bearings, and Wear Plates—Standard Duty Gudgeon
Replace Gudgeon Journal Bearings, Thrust Bearings, and Wear Plates—Severe Duty Gudgeon
Replace Gudgeon Spindle
Section 99 - DEALER FABRICATED TOOLS
Group 05 - Fabricated Tools
Fabricated Tools
DF1057—Axle Adjusting Tool
DFRW7—Differential Lifting Tool
DFRW13—PST Clutch Clip
DFRW20—Compressor Holding Fixture
DFRW30A—Axle Jacking Tool
DRFW60 - DFRW61 - DFRW62—Extension Harnesses
DFRW63 - DFRW64 - DFRW65 - DFRW66 - DFRW81—Tap-Out Harnesses
DFRW72—Gudgeon Spindle Cooling Box
DFRW92—Mounting Guide Pins
DFRW94—Rear Axle Support Stand
DFRW103—Yoke Holding Tool Tool may be purchased. Order JDG924
DFRW113—Hood Supports Tool may be purchased. Order JDG1007
DFRW116—Hydraulic Reservoir Siphon Tube
DFRW117—Transmission-Hydraulic Flusher
DFRW139—Thermal Expansion Valve Replacement Tool
DFRW147—Screw Jack
DFRW148—ACTIVE SEAT ACTIVE SEAT is a trademark of Deere & Company Control Valve Holding Tool
DFRW150—SCV-Hitch Valve Stack Lifting Bracket
DFRW155—Jumper Leads
DFRW165—PST Park Brake Pump Off Hose Adapter
DFRW169—Gudgeon Oscillation Stop This tool may be purchased. Order JDG660B.
DFRW198—Accumulator Service Tool
Brand: John Deere
Part Number: TM1623
FOREWORD
Group 05 - Safety
Prevent Acid Burns
Park Machine Safely
Work in Clean Area
Use Proper Tools
Live With Safety
Glossary of Terms
Section 20 - ENGINE
Specifications
Other Material
Specifications
Specifications
Install Muffler
Specifications
Test Radiator Cap
Drive Belt Routings
Specifications
Other Material
Cab Ground (Roof)
Cab Ground (Floor)
Replace Alternator
Replace Batteries
Specifications
Specifications
Load Center Fuses
Other Material
Specifications
Remove EEPROM
Diagnostic/Program
Other Material
Specifications
Other Material
Specifications
Repair 18-Speed PST
Other Material
Specifications
Shim Transmission
Repair Clutch Pedal
Specifications
Specifications
Specifications
Replace Solenoids
Specifications
Specifications
Specifications
Specifications
Other Material
Specifications
Other Material
Other Material
Specifications
Specifications
Other Material
Specifications
Repair Clutch Pedal
Adjust Clutch Cable
Specifications
Other Material
Specifications
Other Material
Specifications
Specifications
Other Material
Other Material
Specifications
Other Material
Specifications
Install Rear Case
Other Material
Specifications
Specifications
Other Material
Specifications
Specifications
Other Material
Specifications
Other Material
Specifications
Other Material
Specifications
Section 57 - AXLES
Specifications
Specifications
Essential Tools
Other Material
Specifications
Replace Vent Tube
Other Material
Specifications
Remove Differential
Other Material
Specifications
Remove Axle Housing
Group 20 - Brakes
Specifications
Replace Brakes
Specifications
Specifications
Other Material
Service Parts Kits
Specifications
Service Parts Kits
Specifications
Adjust Brake Pedal
Bleed Brakes
Check Manual Brakes
Specifications
Other Material
Specifications
Specifications
Use Special Wrench
Service Parts Kits
Other Material
Specifications
Other Material
Service Parts Kits
Specifications
Service Parts Kits
Specifications
Service Parts Kits
Specifications
Repair SCV Couplers
Specifications
Repair SCV Couplers
Specifications
Group 40 - Hitch
Other Material
Specifications
Adjust Hood
Adjust Side Panel
Specifications
Other Material
Specifications
Remove Cab
Install Cab
Repair Cab
Specifications
Heater Line Routing
Remove HVAC Module
Install HVAC Module
Other Material
Service Parts Kits
Specifications
Leak Test With Dye
Leak Test Condenser
Other Material
Other Material
Specifications
Repair Air System
Repair Suspension
Repair Seat Back
Other Material
Specifications
Repair Seat Back
Group 30 - Armrest
Cab Door Adjustment
Group 05 - Hinge
Other Material
Specifications
Group 10 - Gudgeon
Other Material
Specifications
Fabricated Tools
DFRW147—Screw Jack
- JOHN DEERE CODE DTC LIST
