John Deere 904 1054 1204 And 1354 Tractors Operators Manual OMSJ16423
Format: HTML
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 904 1054 1204 And 1354 Tractors
Parts Number: OMSJ16423
Foreword
Identification Views
Look for Supplemental Information
Section 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Handle Starting Fluid Safely
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operator Manuals for ISOBUS Implements
Use Seat Belt Properly
Operating the Tractor Safely
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Use a Safety Chain
Transport Towed Equipment at Safe Speeds
Use Caution On Slopes and Uneven Terrain
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Dispose of Waste Properly
Section 10 - Safety Signs
Replace Damaged or Missing Safety Signs
Section 15 - Controls and Instruments
Tractor Controls
Instrument Panel
Section 20 - Lights
Light Switch Positions
Use Headlights and Floodlights
High Beam Indicator
Use Tail Lights and Warning Lights
Use Turn Signals
Use Cab Light
Section 25 - Operator Station
Seat Adjustments
Use Seat Belt
Open Windows
Open Door
RH Emergency Exit
Sun Visor
Operate Wipers
Section 30 - Break-In Period
Observe Engine Operation Closely
Break-In Service
Section 35 - Prestarting Checks
Service Daily Before Start-Up
Section 40 - Operating the Engine
Before Starting the Engine
Key Switch Positions
Start the Engine
Check Instruments After Starting
Engine Oil Pressure Indicator
Charging System Indicator
Air Restriction Indicator
Coolant Temperature Gauge
Watch Fuel Level
Change Engine Speeds
Warm Up the Engine
Restart Stalled Engine
Avoid Idling the Engine
Observe Engine Work and Idle Speeds
Use Tachometer/Hour Meter
Stop the Engine
Use Booster Battery
Section 45 - Driving the Tractor
Operator Training Required
Driving on Public Roads
Operate Transmission
Shifting Transmission
Select a Gear
Use Brakes
Use Differential Lock
Operate Mechanical Front-Wheel Drive
Stopping Tractor
Section 50 - Rockshaft and 3-Point Hitch
Match Tractor Power to Implement
3-Point Hitch Components
Rockshaft Control Levers
Use Rockshaft Position Control
Set Position Control Lever Stop
Use Rockshaft Draft Control
Adjust Rockshaft Rate-of-Drop
Prepare Implement
Attach Implements to 3-Point Hitch
Adjust Sway Chains
Leveling Hitch
Adjust Implement Float
Section 55 - Hydraulics and Selective Control Valves
Open Center Hydraulic System
Warm Hydraulic System Oil
Use Correct Hose Tips
SCV Control Levers and Couplers
Connect Cylinder Hoses
Disconnect Cylinder Hoses
Reconnect Hoses Under Pressure
Neutral Lever Position
Extend Cylinder
Retract Cylinder
Cylinder Float Position
Cylinder Regenerate Position
SCV Selection Table
Section 60 - Drawbar and PTO
Observe Drawbar Load Limitations
Adjust Drawbar Length
Use Swinging Drawbar
Proper Use of Drawbar
Reversible PTO Stub Shaft
Attach PTO-Driven Implement
Operate Tractor PTO
Adjust PTO Clutch Operating Rod
Section 65 - Ballast
Plan for Maximum Productivity
Select Ballast Carefully
Match Ballast to Work Load
Check for Correct Ballast
Measure Rear Wheel Slip—Manually
Ballast Limitations
Ballast Front End for Transport
Add Ballast on Tractor
Determine Maximum Rear Ballast
Determine Maximum Front Ballast
Use Cast Iron Weights
Install Rear Cast Iron Weights
Use Liquid Weight
Section 70 - Wheels, Tires and Treads
Check Implement-to-Tire Clearance
Check Tire Inflation Pressure
Tire Inflation Pressure Chart
Tire Combinations—MFWD
Tighten Wheel/Axle Hardware Correctly
Tighten Bolts—MFWD Axle
Tighten Bolts—Rear Axle
Tread Settings—MFWD Axle
Tread Settings—Multi-Position Rear Wheels
Adjust Steering Stop
Check Toe-In
Adjust Toe-In
Section 75 - Transporting
Use a Safety Chain
Driving Tractor on Roads
Tow Tractor
Section 80 - Fuels, Lubricants and Coolant
Cold Weather Operation
Hot Weather Operation
Diesel Fuel
Lubricity of Diesel Fuel
Testing Diesel Fuel
Fill Fuel Tank
Lubricant Storage
Diesel Engine Oil
Oil Filters
Heavy Duty Diesel Engine Coolant
Transmission and Hydraulic Oil
Use Correct Transmission/Hydraulic Filter Element
MFWD Front Axle Housing Oil
MFWD Wheel Hub Oil
Grease
Section 85 - Maintenance and Service Intervals
Additional Service Information
Service Tractor Safely
Service Interval Chart - Daily or 10 Hours - 50 Hours - 150 Hours - 250 Hours
Service Interval Chart - 500 Hours - 1000 Hours - Annually - 2 Years or 2000 Hours
Service after First 100 Hours
Observe Service Intervals
Use Correct Lubricant
Section 90 - General Maintenance and Inspection
Service Air Cleaner
Inspect Air Cleaner Elements
Replace Primary and Secondary Elements (904, 1054 Model)
Replace Primary and Secondary Elements (1204, 1354 Models)
Store Air Cleaner Elements
Check Air Intake System
Adjust Brake Pedal Free Play
Adjust Clutch Pedal Free Play
Clean Engine Crankcase Vent Tube
Check Engine Idle Speed
Adjust Engine Valve Clearance
Remove and Install Hood
Check Hoses and Hose Clamps for Tightness
Loose Hardware Inspection
Check Neutral Start System
Check Seat Belt
Remove Side Screen
Adjust Hand Throttle Friction
Inspect Tires
Section 95 - Lubrication
Use Lubricant Correctly
Check Engine Oil Level
Change Engine Oil and Filter
Check Transmission/Hydraulic System Oil Level
Service Transmission/Hydraulic Oil Filter
Lubricate Steering Spindles
Lubricate MFWD Front Axle
Lubricate MFWD Front Axle Pivot Pins
Lubricate MFWD Drive Shaft
Lubricate 3-Point Hitch Links
Check MFWD Axle Housing Oil Level
Check MFWD Wheel Hub Oil Level
Lubricate Rear Axle Bearings
Change Transmission/Hydraulic System Oil
Change MFWD Front Axle Housing Oil
Change MFWD Wheel Hub Oil
Section 100 - Maintenance—Cooling System
Engine Cooling System Components
Front Grille, Side Screens, Radiator and Oil Cooler Cleaning
Check Coolant Level
Check Cooling System for Leaks
Flush Cooling System
Section 105 - Maintenance—Fuel System
Bleed Fuel System
Drain Water and Sediment from Fuel Tank
Replace Primary/Secondary Fuel Filters
Do Not Modify Fuel System
Section 110 - Maintenance—Electrical System
Observe Electrical Service Precautions
Alternator/Fan Belt Adjustment
Alternator/Fan Belt Replacement
Battery Access
Charge Battery
Clean Battery
Check Battery Condition
Remove Battery
Battery Replacement Specifications
Service Battery
Adjust Headlights
Aiming Headlights
Replace Headlight Bulbs
Replace Flood Light Bulb
Replace Front Turn Signal Bulb
Replace Tail Light/Rear Turn Signal/Brake Light Bulbs
Starter Wiring Connections
Locate Fuses
Fuse Size and Function
Section 115 - Troubleshooting
Engine Troubleshooting
Transmission Troubleshooting
Hydraulic System Troubleshooting
Brakes Troubleshooting
Rockshaft and 3-Point Hitch Troubleshooting
Hydraulic Cylinders Troubleshooting
Electrical System Troubleshooting
Section 120 - Storage
Tractor Storage
Remove Tractor From Storage
Section 125 - Specifications
Machine Specifications
Machine Dimensions and Weights
Ground Speeds
Section 130 - Identification Numbers
Identification Plates
Record Tractor Serial Number
Record MFWD Front Axle Serial Number
Record Engine Serial Number
Record Transmission Serial Number
Section 135 - Lubrication and Maintenance Record Charts
50, 250, 500 Hour Service Chart
1000 Hour Service Chart
Annual Service Chart
2000 Hour Service Chart
As Required Service Chart
Section JDSLA - John Deere Service Literature Available
Technical Information
Section IBC - John Deere Service Keeps You On The Job
John Deere Parts
The Right Tools
Well-Trained Technicians
John Deere Is At Your Service
Format: HTML
Brand: John Deere
Foreword
Section 05 - Safety
Instructional Seat
Use a Safety Chain
Avoid Hot Exhaust
Park Machine Safely
Tractor Controls
Instrument Panel
Section 20 - Lights
High Beam Indicator
Use Turn Signals
Use Cab Light
Seat Adjustments
Use Seat Belt
Open Windows
Open Door
RH Emergency Exit
Sun Visor
Operate Wipers
Break-In Service
Start the Engine
Watch Fuel Level
Warm Up the Engine
Stop the Engine
Use Booster Battery
Select a Gear
Use Brakes
Stopping Tractor
Prepare Implement
Adjust Sway Chains
Leveling Hitch
Extend Cylinder
Retract Cylinder
SCV Selection Table
Operate Tractor PTO
Ballast Limitations
Use Liquid Weight
Check Toe-In
Adjust Toe-In
Use a Safety Chain
Tow Tractor
Diesel Fuel
Testing Diesel Fuel
Fill Fuel Tank
Lubricant Storage
Diesel Engine Oil
Oil Filters
MFWD Wheel Hub Oil
Grease
Service Air Cleaner
Check Seat Belt
Remove Side Screen
Inspect Tires
Check Coolant Level
Bleed Fuel System
Battery Access
Charge Battery
Clean Battery
Remove Battery
Service Battery
Adjust Headlights
Aiming Headlights
Locate Fuses
Tractor Storage
Ground Speeds
John Deere Parts
The Right Tools
- JOHN DEERE CODE DTC LIST
