Martin Welker
104
230,310
John Deere 870 970 1070 Tractors Operators Manual OMM79639 B9
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 870 970 1070 Tractors
Part Number: OMM79639 B9
Number of Pages: 127 Pages
Safety
Controls
Tractor Controls
Instruments
Operating the Engine
Before Starting Engine
Starting Engine
Cold Weather Starting Using
Thermo-Start System
Cold Weather Starting Aids
Observing Engine Work and Idle Speeds
Determining Correct PTO Speeds
Changing Engine Speeds
Warming Up the Engine
Idling the Engine
Restart Stalled Engine
Stopping the Engine
Driving the Machine
Operator Training Required
Operating on Slopes and Rough Terrain
Adjust Seat
Using Seat Belt
Selecting Light Switch Positions
Using Park Brake
Operating Transmission
Selecting A Gear
Determining Tractor Travel Speed
Using Differential Lock
Operating Optional Front-Wheel Drive
Using Power-Take-Off (PTO)
Warming Hydraulic System Oil
Using Optional (SCV) Selective Control
Valve
Connecting Attachment Hydraulic Cylinder
Hoses
Using Drawbar Hitch
Using -Point Hitch
Adjusting Sway Links
Using Speed of Drop/Lock Valve
Determining Maximum Rear Ballast
Using Optional Rear Cast Iron Wheel
Weights
Using Optional Rear Ballast Box
Using Liquid Weight in Rear Tires
Selecting Front Ballast
Determining Maximum Front Ballast
Using Front Weights (Optional)
Selecting Front Tire Rolling Direction
Changing Rear Tread
Transporting
Fuels and Lubricants
Troubleshooting
Periodic Service
Service Intervals
Break-In
Torque Chart for Standard Hardware
Torque Chart for Metric Hardware
Engine Break-In
Hour Meter/Tachometer
Opening and Closing Hood
Removing and Installing Engine Shields
Tractor Break-In
Hours
Checking Engine Oil Level
Checking Hydraulic Oil Level
Checking Coolant Level
Cleaning Grille and Radiator Screen
Hours
Check Tire Inflation
