John Deere 8560 8760 8960 Tractors Operators Manual OMAR110222
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 8560 8760 8960 Tractors
Serial Number: 002331-, 004322-, 002939-
Part Number: OMAR110222
Number of Pages: 263 Pages
Safety
Safety Signs
Controls and Instruments
Control Location
Instrument Identification
Gauges and Indicators Description
Tachometer
Performance Monitor
Radar Sensor
Lighting and Signals
Switch
Lamps and Signals
Electrical Outlets
Load Center
Operator’s Station
SOUND-GARD® Body Temperature
Controls
Window Wipers
Windows
Radio
Steering Wheel
Engine Break-in
Prestarting Checks
Operating the Engine
Start-up Procedures
Cold Weather Starting
Starting Aids
Warm-up and Operation
Stopping the Engine
Operating the Tractor
Brakes
Differential Lock
Page
12-Speed Syncro and 24-Speed
POWRSYNC® Transmission
Power Shift Transmission
Three-Point Hitch
Component Identification
Hitch Control Lever
Sway Blocks
Attaching Implement Hitch
Adjusting Implement Level
Removing Implement
Remote Hydraulic Cylinders
Hose Tips
Identifying SCV
Connecting Cylinder Hoses
Operating SCV
Setting Remote Cylinder Stroke
Disconnecting Cylinder Hoses
Drawbar and PTO
Drawbar Adjustments
Power Take-Off (PTO)
Ballast
Importance of Ballast
Measuring Wheel Slip
Determining Ballast
Wheels, Tires, and Treads
Wheel Tightening
Tread Width Limitations
Adjusting Tread Width (Steel)
Adjusting Tread Width (Cast)
Steering Stops
Inflation Pressure
Transporting
Driving
Carrier
Towing
Fuels, Lubricants, and Coolant
Fuel
Engine Oil
Coolant
Transmission/Hydraulic Oil
Lubricants
Lubricant Storage
Lubrication and Maintenance/10 Hour
Lubrication and Maintenance/After 100
Hours
Lubrication and Maintenance/250 Hours
Lubrication and Maintenance/500 Hours
Lubrication and Maintenance/750 Hours
Lubrication and Maintenance/1500 Hour
Lubrication and Maintenance/Annually
Lubrication and Maintenance/2 Year
Lubrication and Maintenance/As
Required
Troubleshooting
Drive Line
Brakes
3-Point Hitch and Quick-Coupler
Electrical
SOUND-GARD® Body
Service
Access
Air Cleaner
Fuel System
Belts
Electrical
Fuses
Lighting
Page
Brakes
Heating
Air Conditioner
Rollover Protective Structure
Storage
Placing Tractor in Storage
Removing Tractor From Storage
Crime Prevention Tips
Specifications
General
Ground Speeds
Identification Numbers
Identification Plates
Daily Maintenance
Lubrication and Maintenance Records
Index
Brand: John Deere
Safety
Safety Signs
Control Location
Tachometer
Performance Monitor
Radar Sensor
Switch
Lamps and Signals
Electrical Outlets
Load Center
Operator’s Station
Controls
Window Wipers
Windows
Radio
Steering Wheel
Engine Break-in
Prestarting Checks
Start-up Procedures
Starting Aids
Stopping the Engine
Brakes
Differential Lock
Page
Three-Point Hitch
Hitch Control Lever
Sway Blocks
Removing Implement
Hose Tips
Identifying SCV
Operating SCV
Drawbar and PTO
Drawbar Adjustments
Ballast
Determining Ballast
Wheel Tightening
Steering Stops
Inflation Pressure
Transporting
Driving
Carrier
Towing
Fuel
Engine Oil
Coolant
Lubricants
Lubricant Storage
Hours
Required
Troubleshooting
Drive Line
Brakes
Electrical
SOUND-GARD® Body
Service
Access
Air Cleaner
Fuel System
Belts
Electrical
Fuses
Lighting
Page
Brakes
Heating
Air Conditioner
Storage
Specifications
General
Ground Speeds
Daily Maintenance
Index
- JOHN DEERE CODE DTC LIST
