Martin Welker
104
230,310
John Deere 8235R 8260R 8285R 8310R 8335R And 8360R Tractors Operators Manual OMRE317037
Format: HTML
Brand: John Deere
Type of Machine: Tractors
Model: John John Deere 8235R 8260R 8285R 8310R 8335R And 8360R Tractors
Serial Number: 041001-
Parts Number: OMRE317037
Foreword
Look For Supplemental Information
Trademarks
Section 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Fire Prevention
Handle Starting Fluid Safely
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operator Manuals for ISOBUS Implements
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Use a Safety Chain
Transport Towed Equipment at Safe Speeds
Use Caution On Slopes and Uneven Terrain
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Clean Exhaust Filter Safely
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Dispose of Waste Properly
Section 10 - Safety Signs
Replace Damaged or Missing Safety Signs
Left Front Cab Corner Posts Safety Labels
Cab Entrance—Caution
Safety Signs — Starter
Independent Link Suspension Accumulators (ILS™) (If Equipped)
Primary Brake Valve Accumulator
Quick Coupler (If Equipped)
Tractor Rear—PTO Shield
Engine Block Heater (If Equipped)
Implement Detected
Auxiliary Control
Section 15 - Controls and Instruments
Front Console
Corner Post Display
Information Indicators
Digital Indicators—Tachometer, Ground Speed and Transmission
Gauges—Coolant Temperature, Engine Oil Pressure and Fuel Level
CommandARM™
CommandARM™ Controls
Foot Operated Throttle Control (If Equipped)
External Hitch Raise/Lower Switches
Section 16 - CommandCenter
Navigating The CommandCenter™—Read Me First
Activating The System
CommandCenter™ Menu
Shortcut Buttons
Page Structure
CommandCenter™ Left Region
CommandCenter™ Right Region Softkeys
CommandCenter™ Input Fields
Navigating To Specific Page
Display Control Test
Access Manager
Selecting Highlight Color
Setting Country, Language, And Units
Setting System Time
Viewing Basic Diagnostic Readings
Message Center
Configuring Home Page
Setting Cab Lighting
Setting Service Interval
Setting Distance Counter
Setting Performance Monitor Access
Using Performance Monitor
Setting Implement Width and Control Modes
Setting Alarm Volume
Accessing Video Capability
Connecting ISO Implements and Multiple ISO Displays
Auxiliary Controls
CommandCenter™ Software Version
Service ADVISOR Remote (SAR) — If Equipped
Calibrating Dual Beam Radar
Manual Vehicle Speed Calibration
Section 20 - Lights
Light Identification
Programmable Lights
Using Delayed Egress Lighting (If Equipped)
Operating Turn Signals and High/Low Beam
Operating Hazard Lights and Extremity Transport Lights
Operating Rotary Beacon Light (If Equipped)
Using Seven-Terminal Outlet
Section 25 - Operator Station
Adjusting Air Suspension Seat
Adjusting ActiveSeat™(If Equipped)
Using Instructional Seat
Heated Leather Seat (If Equipped)
Adjusting CommandARM™ Position
Operating Cab Heat, Defrost and Air Conditioning—Standard Equipment
Operating Automatic Temperature Control (ClimaTrak™ ATC)
Adjusting Steering Wheel and Column
Operating Horn
Operating Front Wiper and Washer
Operating Rear Wiper and Washer (If Equipped)
Operating Deluxe Radio
Setting Clock and Alarm—Deluxe Radio
Changing World Tuner Settings—Deluxe Radio
Operating Premium Radio with Compact Disc (CD) Player
Setting Clock—Premium Radio
Setting the Alarm—Premium Radio
Compact Disc (CD) Mode—Premium Radio
Using iPod® — Premium Radio
Satellite Service For Premium Radio- US and Canada Only
Using Weather Band
Changing World Tuner Setting—Premium Radio
Setting up Hands Free (Bluetooth®) Mode – Premium Radio
USB Mode – Premium Radio
Operating Premium Radio Through CommandARM™ Controls
Installing Business Band Radio and Antenna
Using Auxiliary Power Strip And Electrical Outlets (If Equipped)
Connecting Compatible Electronic Equipment
Configuring Tractor For GPS/Radar
Mounting StarFire™ Receiver
Installing GreenStar™ System Components
Connecting AutoTrac™ Assisted Steering System (If Equipped)
Monitor Bracket Mounts
Using Electric Mirror (If Equipped)
Using Telescoping Heated Electric Mirror (If Equipped)
Using Storage Compartment
Positioning Steps and Handrails
Section 30 - Break-In Period
Break-In Checks
Section 35 - Operating the Engine
Exhaust Filter System Overview
AUTO Exhaust Filter Cleaning Mode
Parked Exhaust Filter Cleaning
Starting the Engine
Stopping the Engine
Engine Fuel System and Power Rating
Cold Weather Starting—Without Optional Starting Aid
Changing Starting Fluid Can (If Equipped)
Using Auxiliary Heaters
Using a Battery Booster or Charger
Section 40 - Operating the Tractor
Avoid Contact with Pesticides
Clean Vehicle of Hazardous Pesticides
Using Seat Belts
Using Emergency Exit
Transmission-Hydraulic System Warm-Up
Operating Tractor with Independent Link Suspension
Using FieldCruise™
Intelligent Power Management (If Equipped)
Using The Brakes
Using Mechanical Front-Wheel Drive
Using Differential Lock
Using Hydraulic Trailer Brakes (If Equipped)
Using Trailer Air Brakes (If Equipped)
Come Home Mode
Section 41 - Operating PowerShift Transmission
Operating the Transmission
Shifting the Transmission
Setting Startup Gear And RPM Droop
Operating Automatic PowerShift (APS)
Section 42 - Operating IVT/AutoPowr Transmission
Controls Identification
Left-Hand and Right-Hand Reverser Shift Patterns
Operating The Transmission
Adjusting Set Speeds
Set Speeds—Guidelines And Examples
IVT™/AutoPowr™ Modes And Setting Maximum Speed
Custom IVT™/AutoPowr™ Settings
Adjusting Reverse-Forward Set Speed Ratio
Adjusting AutoClutch Sensitivity and Acceleration Aggressiveness
Adjusting Set Speeds To Match Varying Load Conditions
Putting Tractor In Motion
Tractor Speed Displays On Corner Post Display And CommandCenter™
Using Creeper Mode
Using Individual Brake Pedals
Stopping And Parking The Tractor
Downhill Operation In Slippery Conditions
Section 45 - Intelligent Total Equipment Control (iTEC)
Operator Station Description And Functions
CommandCenter™ Pages Description And Functions
Inhibit, Abort, Cancel or Interrupt Conditions
Entering Or Editing Equipment Name
Manually Programming A Sequence While Stationary
Recording A Sequence While Driving
Learn Distance Only
Executing Programmed Sequence
Aborting and/or Clearing iTEC Sequence
iTEC Functions—IVT™/AutoPowr™ Transmission
Section 50 - Hitch
Hitch Set-up and Use (Quick Reference)
Using Hitch Command Lever
Adjusting Load/Depth Control (Draft Response)
Using Position Control
Using Draft Control
Adjusting Hitch Upper Limit
Adjusting Hitch Drop Rate
Adjusting Hitch Raise Rate
Setting Hitch Slip Response
Using Float Operation
Hitch Components
Using External Raise and Lower Switches
Using Hitch Manual Lowering Feature
Using Correct Center Link Position
Using Sway Blocks
Attaching Implement to Quick Coupler
Adjusting Implement Level
Changing Lateral Float
Detaching Implement from Quick Coupler
Hitch Conversion—Convertible Quick Coupler
Converting Category 4 Convertible Quick Coupler Lower Hooks
Converting Category 3/4 Convertible Quick Coupler Upper Hook
Using Front Hitch (If Equipped)
Section 52 - Tractor Implement Automation
Tractor-Implement Automation (TIA)
Activating Tractor-Implement Automation Equipment
Requirements for PTO
Requirements for E-SCVs
Requirements for IVT™/AutoPowr™
Requirements For Guidance
Requirements For Rear Hitch
Requirements For Drive Strategy
Operating Tractor Implement Automation
Section 55 - TouchSet Depth Control
Using TouchSet™ Depth Controls
Attaching Implement and Control System
TouchSet™Scraper Control—for Scrapers Equipped with Scraper Control Unit
Section 60 - Hydraulics and Selective Control Valves
Configuring Selective Control Valves On CommandCenter™
Connecting Hydraulic Hoses
Disconnecting Hydraulic Hoses
Determining Total Flow Demand
Using Six Position SCV Control Levers
SCV Lever—Neutral Position
SCV Lever—Extend and Extend Detent Position
SCV Lever—Retract and Retract Detent Position
SCV Lever—Float Position
Operator Presence Sensor
Section 65 - Remote Hydraulic Connections
Hydraulic Component Identification
Using Load-Sensing Hydraulic System—Power-Beyond
Examples Using Load-Sensing Hydraulic System—Power-Beyond
Using Hydraulic Spray Pumps
Implement Connection, Example 1—Pressure Control Valve Applications (Grain Drills or Air Seeders with Constant Down-Pressure System)
Implement Connection, Example 2—Motor Application Using Motor Case Drain
Implement Connection, Example 3—Closed Center Valve with Pump at High Pressure
Implement Connection, Example 4—Planter with Vacuum Motor and Return Line to SCV Using Motor Return Tip
Implement Connection, Example 5—Planter with Vacuum Motor, Return Line to Motor Return and Lift Assist
Implement Connection, Example 6—Planter with Vacuum Motor and Return Line to Motor Return
Using Hydraulic Motor Return
Using Hydraulic Motor Case Drain (Sump)
Using Implement Requiring Large Volumes of Oil
Section 70 - Drawbar and PTO
Observing Drawbar Load Limitations
Adjusting Drawbar Length, Height and Side-to-Side
Installing and Using Clevis Assembly
Attaching PTO-Driven Implement
Using PTO Shield
Using Correct Engine Speed
Operating Rear PTO
Setting Rear PTO Engagement Rate
Using Correct PTO Shaft
Changing PTO Stub Shaft
Section 75 - Performance Ballasting
General Ballasting Information
General Guidelines for Tractor Weight Based on PTO Power Rating
General Weight Split Guidelines
Ballast Types
Ballasting Suggestions for Specific Types of Implements
Determining Ballasted Tractor Weight, Weight Split, Axle Loads and Required Tire Inflation Pressures
Unballasted Tractor Weight Chart for 8235R 2WD
Unballasted Tractor Weight Chart for 8235R-8310R 1300 MFWD
Unballasted Tractor Weight Chart for 8235R-8360R 1500 MFWD
Unballasted Tractor Weight Chart for 8235R-8360R Independent Link Suspension
Maximum Load Per Wheel
Worksheet to Calculate Ballast Changes
Controlling Power Hop—MFWD Tractors
Using QUIK-TATCH Weights
Using Rear Wheel Weights
Using Liquid Ballast
Implement Codes
Weight Added to Rear Axle with Hitch Mounted Implements
Measuring Wheel Slip—Manually
Section 80 - Front Wheels, Tires and Treads
Tire Combinations
Tire Combinations Tables
Wheel tightening Stand—DFR219 or JDG10741
Tire Inflation Pressure Guidelines
Recommended Pressures—Bias Single Front Tires
Recommended Pressures—Group 42
Recommended Pressures—Group 42 — Continued
Recommended Pressures—Group 43
Recommended Pressures—Group 43 — Continued
Recommended Pressures—Group 43 IF Tires
Recommended Pressures—Group 44
Two-Wheel Drive Front Axle Adjustment
Two-Wheel Drive Front Axle and Wheel Bolt Tightening
Two-Wheel Drive Front Axle Toe-In Check
Two-Wheel Drive Front Axle Toe-In Adjustment
Two-Wheel Drive Front Axle Tread Setting
MFWD and Independent Link Suspension Front Wheel Bolts Tightening
Independent Link Suspension/ 1500 MFWD Front Dual Installation
MFWD and Independent Link Suspension Toe-In Check
1300 MFWD Axle Toe-In Adjustment
1500 MFWD Axle Toe-In Adjustment
Independent Link Suspension Toe-In Adjustment
MFWD Steering Stop Settings
Independent Link Suspension Steering Stop Settings
1300 MFWD Axle Fender Settings
1500 MFWD and Independent Link Suspension Fender Settings
Determining Rim Type—Front Tires
Eight Position Wheel Settings
Sixteen Position Front Wheel Settings
Front Tire, Fender and Steering Stop Settings Table Explanation
1300 MFWD Axle Front Tire, Fender and Steering Stop Settings
1500 MFWD Front Axle, Tire, Fender and Steering Stop Settings
Independent Link Suspension Front Tire, Fender and Steering Stop Settings
Independent Link Suspension Front Tire, Fender and Steering Stop Settings—Continued
1500 MFWD Dual Front Tire, Fender and Steering Stop Settings
Independent Link Suspension Dual Front Tire, Fender and Steering Stop Settings
Section 81 - Rear Wheels, Tires and Treads
Recommended Pressures—Group 47
Recommended Pressures—Group 47—Continued
Recommended Pressures—Group 48
Recommended Pressures—Group 48 — Continued
Recommended Pressures—Group 47/ 48 — IF Tires
Rear Wheel, Tire, and Tread Guidelines
Dual Wheel to Hub Installation
Rear Drive Wheel with Standard Hubs— Adjusting and Tightening
Rear Dual Wheels with Standard Hubs— Adjusting and Tightening
Rear Drive and Dual Wheels With Heavy Duty Hubs—Adjusting and Tightening
Sixteen Position Rear Dual Wheel Settings
Rear Drive Wheel Tread Settings for Single Wheels
Rear Dual Wheel Tread Settings—320 and 380 Tire
Rear Dual Wheel tread Settings—420 and 480 Tires
Rear Dual Wheel Tread Settings—520 and 620Tires
Rear Dual Wheel Tread Settings—650 Tires
Rear Dual Wheel Tread Settings—710 and 800 Tires
Rear Triple Wheel Tread Settings—320 Tires
Rear Triple Wheel Tread Settings—380 Tires
Rear Triple Wheel Tread Settings—420 Tires
480 and 520 mm Triple Rear Wheel Tread Settings
Rear Dual Wheel Row Crop Settings
Rear Triple Wheel Row Crop Settings
Section 85 - Transport
Driving Tractor on Roads
Transporting with Ballast
Towing Loads
Using a Safety Chain
Tow Mode
Towing Tractor
Transporting on Flat-Bed Carrier
Section 90 - Fuels, Lubricants, and Coolant
Diesel Fuel
Lubricity of Diesel Fuel
Fill Fuel Tank
John Deere Break-In™ Plus Engine Oil
Biodiesel Fuel
Testing Diesel Fuel
Minimizing the Effect of Cold Weather on Diesel Engines
Diesel Engine Oil
Engine Oil and Filter Service Intervals—Interim Tier 4 and Stage III B Engines
Heavy Duty Diesel Engine Coolant
Drain Intervals for Diesel Engine Coolant
John Deere COOL-GARD™ II Coolant Extender
Supplemental Coolant Additives
Operating in Warm Temperature Climates
Additional Information About Diesel Engine Coolants and John Deere COOL-GARD™ II COOLANT EXTENDER
Testing Diesel Engine Coolant
Transmission and Hydraulic Oil
Gear Oil
Grease
Powershift Transmission Recalibration
Independent Link Suspension Differential Case Oil
Oil Filters
Lubricant Storage
Mixing of Lubricants
Transmission, Steering, Brake, Hydraulic, and Gear Case Oil
Section 95 - Maintenance and Service Intervals
Observe Service Intervals
Service Interval Chart—Daily or 10 Hours—Annual—50 Hours—250 Hours And 500 Hours
Service Interval Chart—1000—1500 — 3000—5000 and 6000 Hours
Section 100 - Daily or 10 Hour Service
Checking Engine Oil
Draining Water Separator
Checking Transmission/Hydraulic Oil Level
Draining Air Brake Tank
Section 101 - Annual Service
Servicing Batteries And Connections
Checking Seat Belts
Checking Independent Link Suspension Upper and Lower Rod and Head End Accumulator Charge Pressure
Inspecting Primary And Secondary Engine Air Filter
Section 102 - 50 Hour Service
Perform Service And All Subordinate Services
Checking Tires
Lubricating Rear Hitch Components
Section 103 - 250 Hour Service
Checking Neutral Start System—IVT™/AutoPowr™ Transmission
Checking Neutral Start System—PowerShift Transmission
Checking Transmission PARK Position
Lubricating MFWD King Pins, Tie Rod Ends, Axle Pivot Fittings And U-Joints
Lubricating Independent Link Suspension King Pins, Tie Rod Ends, Axle Pivot Fittings And U-Joints (If Equipped)
Lubricating ActiveCommand Steering Arm
Checking MFWD or Independent Link Suspension Wheel Hub Oil Level
Lubricating Two Wheel Drive Front Axle—If Equipped
Lubricating Two Wheel Drive Front Wheel Bearings—If Equipped
Lubricating Front Hitch (If Equipped)
Draining Fuel Tank Sump
Section 104 - 500 Hour Service
Changing Engine Oil and Filter
Checking Wheel and Wheel Weight Bolts
Checking Dual Beam Radar Sensor
Replacing Fuel Filters
Checking Air Intake System
Cleaning Optional Fuel Water Separator Filter Element—If Equipped
Section 105 - 1000 Hour Service
Cleaning Fuel Tank Vent Filter
Replacing Cab Recirculation Filters
Replacing Cab Air Filters
Cleaning MFWD Axle Breather
Replacing Primary And Secondary Engine Air Filters
Testing Coolant
Section 106 - 1500 Hour Service
Performing 1500 Hour Service
Draining Differential And Clean Oil Reservoir
Draining PowerShift (PST) Transmission and Cleaning Filter
Draining IVT™/AutoPowr™ Transmission And Cleaning Transmission Filter
Draining Independent Link Suspension (If Equipped)
Cleaning Hydraulic Oil Suction Screen
Replacing Transmission/Hydraulic Filters And Refill Transmission/Hydraulic Oil.
Changing MFWD Or Independent Link Suspension Wheel Hub Oil
Changing MFWD Differential Case Oil
Lubricating Independent Link Suspension Axle—Tie Rod Internal Ball Joints
Lubricating Draft Link Support Shaft Bushing
Inspecting Auxiliary Drive Belt
Clean And Repack Front Wheel Bearings—Two Wheel Drive
Section 107 - 3000 Hour Service
Check Engine Valve Clearance
Section 108 - 5000 Hour Service
Replace Engine Torsional Crankshaft Damper
Replace Transmission Torsional Damper
Section 109 - 6000 Hour Service
Draining, Flushing and Refilling Cooling System
Checking De-aeration Cap And De-aeration Tank
Section 115 - General Services
Servicing and Connecting Snap to Connect STC® Fittings
Welding Near Electronic Control Units
Keep Electronic Control Unit Connectors Clean
Diesel Particulate Filter Maintenance and Service
Exhaust Filter / Diesel Particulate Filter Ash Handling and Disposal
Exhaust Filter Disposal
Cleaning Radiator, Coolers and Air Conditioning Condenser
Remove and Install VARI-COOL Fan Belt
Checking Air Conditioning System
Replacing Auxiliary Drive Belt
Checking Weep Hole
Back Flushing the Optional Fuel Water Separator—If Equipped
Maintaining Optional Fuel Water Separator Filter Element—If Equipped
Section 120 - Electrical Services
Introduction to Electrical System Section
Load Center Fuses
Power Module
Implement Power Relay Module
Handling Halogen Light Bulbs Safely
Replacing Front Grille Flood Light Bulb—Standard Lighting
Handling HID Light Bulbs Safely
HID Bulbs
Adjusting Front Grille Lights
Aiming Headlights
Replacing Front, Side And Rear Cab Roof Light Bulbs
Replacing Brake or Turn Signal Light Bulb
Replacing Dome Light Bulb
Replacing Courtesy Light Bulb
Replacing Map Light bulb
Replacing Extremity Warning Light Bulb (if Equipped)
Section 125 - Troubleshooting
Engine Troubleshooting
Transmission Troubleshooting
Hydraulic System Troubleshooting
Hitch Troubleshooting
Selective Control Valve Troubleshooting
TouchSet Depth Control Troubleshooting
Electrical System Troubleshooting
Operator Enclosure Troubleshooting
Tractor Operation Troubleshooting
Independent Link Suspension Troubleshooting
Premium Radio Troubleshooting
Section 130 - Diagnostic Trouble Codes
STOP, Service Alert and Information Indicators
Accessing Diagnostic Trouble Codes
Armrest Control Unit (ACU) Diagnostic Trouble Codes
ActiveSeat Control Unit (ASU) Diagnostic Trouble Codes
Automatic Temperature Control Unit (ATC) Diagnostic Trouble Codes
Brake Control Unit (BRC) Diagnostic Trouble Codes
Cab Control Unit (CAB) Diagnostic Trouble Codes
Chassis Control Unit (CCU) Diagnostic Trouble Codes
Cab Load Center Diagnostic Trouble Codes
Cab Switch Module (CSM) Diagnostic Trouble Codes
Engine Control Unit (ECU) Diagnostic Trouble Codes
Hitch Control Center (HCC) Diagnostic Trouble Codes
Hitch Valve (HV1) Diagnostic Trouble Codes
JDLink™ Control Unit (JDL) Diagnostic Trouble Codes
PDU Diagnostic Trouble Codes
PowerShift Control Unit (PTP) Diagnostic Trouble Codes
IVT™/AutoPowr Control Unit (PTI) Diagnostic Trouble Codes
Suspended Front Axle (SFA) Diagnostic Trouble Codes
SCV Control Unit (SCC) Diagnostic Trouble Codes
Steering System Control Unit (SSU) Diagnostic Trouble Codes
Selective Control Valve Units 1 - 7 (SV1 - 7) Diagnostic Trouble Codes
Tractor Equipment Control Unit (TEC) Diagnostic Trouble Codes
Vehicle Load Center (VLC) Diagnostic Trouble Codes
Section 135 - Storage
Placing Tractor in Storage
Removing Tractor from Storage
Paint Finish Care
Section 140 - Specifications
Power, Engine, Transmission And Electrical Specifications
Power Train, Steering, Hydraulics, Hitch And Drawbar Specifications
Capacities, Weights And Requirements
Ground Speeds With PST
Ground Speeds—IVT™/AutoPowr™
Identify Zinc-Flake Coated Fasteners
Limited Battery Warranty
Section 145 - Identification Numbers
Identification Plates
Record Product Identification Number
Record Engine Serial Number
Record Cab Serial Number
Record PST Transmission Serial Number
Record IVT™/AutoPowr™ Transmission Serial Number
Record 1300 MFWD Axle Serial Number
Record 1500 MFWD Axle Serial Number
Record Independent Link Suspension Axle Serial Number
Keep Proof of Ownership
Keep Machines Secure
Section 150 - Lubrication and Maintenance Records
Daily Service Records
Annual Service Records
50 Hour Service Records
250 Hour Service Records
500 Hour Service Records
1000 Hour Service Records
1500 Hour Service Records
3000 Hour Service Records
5000 Hour Service Records
6000 Hour Service Records
Section 155 - Glossary
Glossary of Terms
Section SLIT - John Deere Service Literature Available
Technical Information
Section IBC - John Deere Service Keeps You on the Job
John Deere Is At Your Service
