John Deere 770A 770AH 772A 772AH Motor Graders Technical Manual TM1361
- Download this document, you need 350 Gallons
Brand: John Deere
Type of Machine: Motor Graders
Type of Manual: Technical Manual
Model: John Deere 770A 770AH 772A 772AH Motor Graders
Part Number: TM1361
Number of Pages: 216 Pages
SECTION I - GENERAL INFORMATION
Group I - Contents and Index
Group II - Introduction and Safety Information
Group III - General Specifications
Group IV - Predelivery, Delivery and After-Sales Services
Group V - Lubrication
SECTION 1 - WHEELS
Group 0110 - Powered Wheels and Fastenings
Group 0120 - Non-Powered Wheels and Fastenings
Group 0199 - Specifications and Special Tools
SECTION 2 - AXLES AND SUSPENSION SYSTEMS
Group 0201 - Drive Axle Housing and Support
Group 0210 - Differential or Bevel Drive
Group 0250 - Axle Shafts, Bearing and Reduction Gears
Group 0260 - Hydraulic System
Group 0999 - Specifications and Special Tools
SECTION 3 - TRANSMISSION
Group 0315 - Controls
Group 0350 - Gears, Shafts, Bearings and Power Shift Clutch
Group 0360 - Hydraulic System
Group 0370 - Clutch Disconnect and Controls
Group 0399 - Specifications and Special Tools
SECTION 4 - ENGINE
Group 0400 - Engine, Removal and Installation
Group 0401 - Crankshaft and Main Bearings
Group 0402 - Camshaft and Valve Actuating Means
Group 0403 - Connecting Rods and Pistons
Group 0404 - Cylinder Block
Group 0407 - Colling System
Group 0408 — Ventilating System
Group 0409 - Cylinder Head and Valves
Group 0410 - Exhaust Manifold
Group 0413 - Fuel Injection System
Group 0414 - Intake Manifold
Group 0416 - Turbocharger
Group 0417 - Water Pump
Group 0418 - Thermostats, Housings, and Water Piping
Group 0419 - Oil Cooler
Group 0420 - Fuel Filter
Group 0421 - Fuel Transfer Pump
Group 0422 - Starting Motor and Fastenings
Group 0433 - Flywheel, Housing and Fastenings
Group 0499 - Specifications and Special Tools
SECTION 5 - ENGINE AUXILIARY SYSTEMS
Group 0505 - Cold Weather Starting Aids
Group 0510 - Cooling Systems
Group 0515 - Speed Controls
Group 0520 - Intake System
Group 0540 - Mounting Frame
Group 0560 - External Fuel Supply Systems
Group 0599 - Specifications and Special Tools
SECTION 8 - TRANSFER DRIVE
Group 0841 - Housings and Covers
Group 0851 - Gears, Shafts, Bearings
Group 0899 - Specifications and Special Tools
SECTION 9 - STEERING SYSTEM
Group 0920 - Power Steering
Group 0960 - Hydraulic System
SECTION 10 - SERVICE BRAKES
Group 1011 - Active Elements
Group 1015 - Controls Linkage
Group 1060 - Hydraulic System
Group 1099 - Specifications and Special Tools
SECTION 11 - PARKING-EMERGENCY BRAKES
Group 1111 - Active Elements
Group 1115 - Controls Linkage
Group 1199 - Specifications and Special Tools
SECTION 15 - EQUIPMENT ATTACHING
Group 1511 - Drawbar
SECTION 16 - ELECTRICAL SYSTEMS
Group 1671 - Batteries, Support and Cables
Group 1672 - Alternator, Regulator and Charging System Wiring
Group 1673 - Lighting System
Group 1674 — Wiring Harness and Switches
Group 1675 - System Controls
Group 1676 - Instruments and Indicators
Group 1699 - Specifications and Special Tools
SECTION 17 - FRAME, CHASSIS OR SUPPORTING STRUCTURE
Group 1740 - Frame Installation
Group 1746 - Frame Bottom Guards
Group 1747 - Bumpers, Vehicle
Group 1799 - Specifications and Special Tools
SECTION 18 - OPERATOR'S STATION
Group 1810 - Operator Enclosure
Group 1821 - Seat and Seat Belt
Group 1822 - Steps and Hendholda
Group 1830 - Healing and Air Conditioning
Group 1899 — Specifications and Special Tools
SECTION 19 - SHEET METAL AND STYLING
Group 1910 - Hood or Engine Enclosure
Group 1913 - Miscellaneous Shields
Group 1921 - Grille and Grille Housing
SECTION 20 - SAFETY, CONVENIENCE AND MISCELLANEOUS
Group 2002 - Mirror
Group 2003 - Fire Extinguisher
Group 2004 - Horn
Group 2006 - Cigar Lighter
SECTION 21 - MAIN HYDRAULIC SYSTEM
Group 2160 - Hydraulic System
Group 2199 - Specifications and Special Tools
SECTION 34 - GRADING DEVICE
Group 3401 - Blade
Group 3415 — Controls Linkage
Group 3440 - Frames
Group 3450 - Circle Gear Box
Group 3460 - Hydraulic System
Group 3499 - Specifications and Special Tools
SECTION 42 - GROUND CONDITIONING TOOL
Group 4201 - Blades, Teeth, Shanks, Etc
Group 4240 - Frames
Group 4260 - Hydraulic System
Group 4299 - Specifications and Special Tools
SECTION 46 - AUTOMATIC CONTROL
Group 4615 - Linkages
Group 4640 - Frames and Housings
Group 4660 - Hydraulic System
Group 4670 — Electrical System
Group 4099 - Specifications and Special Tools
SECTION 90 - SYSTEM TESTING
Group 9005 - General Information
Group 9010 — Engine
Group 9015 - Electrical System
Group 9016 - Hydraulic Front Wheel Drive
Group 9020 — Power Train
Group 9025 — Hydraulic System
Group 9030 — Miscellaneous Components
Group 9031 — Heating and Air Conditioning
Group 9032 — Automatic Blade Control
Group 9035 — Specifications and Special Tools
Brand: John Deere
Part Number: TM1361
SECTION 1 - WHEELS
SECTION 4 - ENGINE
Group 2002 - Mirror
Group 2004 - Horn
Group 3401 - Blade
Group 3440 - Frames
Group 4240 - Frames
Group 9010 — Engine
