Martin Welker
104
230,310
John Deere 7630 7730 7830 7930 Tractor Operation and Test Manual TM2234
Brand: John Deere
Type of Manual: Operation and Test Manual Manual
Model: John Deere 7630 7730 7830 7930 Tractor
Part Number: TM2234
Publication Date: 2009
Number of Pages: 5247 Pages
GENERAL
Safety
Recognize Safety Information
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Avoid High-Pressure Fluids
Park Machine Safely
Support Machine Properly
Wear Protective Clothing
Work in Clean Area
Service Machines Safely
Work In Ventilated Area
Illuminate Work Area Safely
Replace Safety Signs
Use Proper Lifting Equipment
Wait Before Opening High-Pressure Fuel System
Keep ROPS Installed Properly
Service Tires Safely
Avoid Harmful Asbestos Dust
Practice Safe Maintenance
Use Proper Tools
Dispose of Waste Properly
Prevent Machine Runaway
Handle Starting Fluid Safely
Service Cooling System Safely
Stay Clear of Rotating Drivelines
Protect Against High Pressure Spray
Clean Vehicle of Hazardous Pesticides
Live With Safety
General References
General Reference List
Bolt and Cap Screw Torque Values
Glossary of Terms
JIC Hydraulic Symbols
Trademarks
Wiring Diagram and Schematic Information
Electrical Schematic Symbols
Reading Wiring Schematics and Diagrams
Visually Inspect Electrical System
Seven Step Electrical Test ProcedureWith probe light or multimet
Using a Probe Light
Circuit Types
Circuit Malfunctions
Troubleshooting Circuit Malfunctions
Understanding Electrical vs. Electronic Circuits
Intermittent Electronic Problems
Relay Circuit Types
Using a Digital Multimeter
Troubleshooting Unresolved Electrical/Electronic Problems
DIAGNOSTIC TROUBLE CODES
ACU Code Diagnostics
ACU 000158.04 — ACU Switched Supply Voltage Low
ACU 000177.17 — Engine Speed Limited Due to Cold Oil
ACU 000237.02 — VIN Security Data Conflict
ACU 000237.14 — VIN Security Not Enabled
ACU 000237.31 — VIN Security Messages Missing
ACU 000581.07 — Transmission Not Responding to Command
ACU 000628.02 — ACU EOL Data Fault
ACU 000628.12 — ACU Programming
ACU 000629.11 — ACU Control Unit Fault
ACU 000629.12 — ACU Control Unit Fault
ACU 000630.02 — ACU Calibration Fault/Data Invalid
ACU 000630.13 — ACU Calibration Fault/Not Calibrated
ACU 000974.02 — Hand Throttle Sensor Circuit Voltage Conflict
ACU 000974.03 — Hand Throttle Sensor Circuit Voltage High
ACU 000974.04 — Hand Throttle Sensor Circuit Voltage Low
ACU 001079.03 — ACU Sensor Supply 1 Voltage High
ACU 001079.04 — ACU Sensor Supply 1 Voltage Low
ACU 001080.03 — ACU Sensor Supply 2 Voltage High
ACU 001080.04 — ACU Sensor Supply 2 Voltage Low
ACU 002000.09 — ECU Message Missing
ACU 002003.09 — PTI or PTQ Message Missing
ACU 002020.09 — SFA Message Missing
ACU 002049.09 — CAB Message Missing
ACU 523664.02 — Speed Band 1 and 2 Switches Conflict
ACU 523775.02 — Single Lever Control Hand Presence Switch Fault
ACU 523775.09 — Single Lever Control Hand Presence Switch Fault
ACU 523776.02 — Single Lever Control Transport Lock Switch Circu
ACU 523801.02 — Single Lever Control Auxiliary Switch Fault
ACU 523804.02 — Single Control Lever Lateral Detent Switch Circu
ACU 523804.03 — Single Lever Control Lateral Sensor Circuit Volt
ACU 523804.04 — Single Lever Control Lateral Sensor Circuit Volt
ACU 523805.02 — Single Lever Control Fore-Aft Detent Switch Circ
ACU 523805.03 — Single Lever Control Fore-Aft Sensor Circuit Vol
ACU 523805.04 — Single Lever Control Fore-Aft Sensor Circuit Vol
ACU 523923.02 — SCV I Control Lever Switch/Sensor Conflict
ACU 523923.03 — SCV I Control Lever Sensor Circuit Voltage High
ACU 523923.04 — SCV I Control Lever Sensor Circuit Voltage Low
ACU 523953.02 — Speed Control Lever Sensor Circuit Conflict
ACU 523953.03 — Speed Control Lever Sensor Voltage High
ACU 523953.04 — Speed Control Lever Sensor Voltage Low
ACU 523954.07 — Speed Band 1 Adjustment Fault
ACU 523954.11 — Set Speed Adjuster Conflict
ACU 523955.31 — Engine Overload In Manual Mode
ACU 523958.31 — Reversing Ratio Fault
ACU 523960.17 — Operator Not Present At Low Speeds
ACU 523960.31 — Operator Not Seated During Reverser Command
ACU 523961.02 — Park Engaged While in Gear
ACU 523961.07 — Park Lock Engagement Fault
ACU 523962.31 — MFWD Speed Incorrect
ACU 523963.02 — Speed Band 1 Switch/Voltage Conflict
ACU 523966.31 — Transmission Come Home Mode
ACU 523967.02 — Speed Band 2 Switch/Voltage Conflict
ACU 523968.02 — IMS Switch Circuits Conflict
ACU 523968.03 — IMS Switch Circuits Voltage High
ACU 523968.04 — IMS Switch Circuits Voltage Low
ACU 523969.11 — Upshift/Downshift Switch Conflict
ACU 524017.31 — Right Hand Reverser Power Circuit Fault
ACU 524018.31 — Right Hand Reverser Neutral/Park Transition Faul
ACU 524019.31 — Right Hand Reverser Neutral/Not-Neutral Transiti
ACU 524020.31 — Transmission in Gear at Power Up
ACU 524021.31 — Multiple Reverser Switches Conflict
ACU 524101.02 — SCV VI Control Lever Switch/Sensor Circuit Confl
ACU 524101.03 — SCV VI Control Lever Sensor Circuit Voltage High
ACU 524101.04 — SCV VI Control Lever Sensor Circuit Voltage Low
ACU 524102.02 — SCV V Control Lever Switch/Sensor Circuit Confli
ACU 524102.03 — SCV V Control Lever Sensor Circuit Voltage High
ACU 524102.04 — SCV V Control Lever Sensor Circuit Voltage Low
ACU 524103.02 — SCV IV Control Lever Switch/Sensor Circuit Confl
ACU 524103.03 — SCV IV Control Lever Sensor Circuit Voltage High
ACU 524103.04 — SCV IV Control Lever Sensor Circuit Voltage Low
ACU 524104.02 — SCV III Control Lever Switch/Sensor Circuit Conf
ACU 524104.03 — SCV III Control Lever Sensor Circuit Voltage Hig
ACU 524104.04 — SCV III Control Lever Sensor Circuit Voltage Low
ACU 524105.02 — SCV II Control Lever Switch/Sensor Circuit Confl
ACU 524105.03 — SCV II Control Lever Sensor Circuit Voltage High
ACU 524105.04 — SCV II Control Lever Sensor Circuit Voltage Low
ACU 524212.02 — Rear Hitch Control Lever Switch/Sensor Circuit C
ACU 524212.03 — Rear Hitch Control Lever Sensor Circuit Voltage
ACU 524212.04 — Rear Hitch Control Lever Sensor Circuit Voltage
ACU 524222.02 — Resume Switch Circuit Conflict
ACU 524224.02 — Rear PTO Switch Circuit Conflict
ACU 524254.31 — Transmission Enable Circuit Fault
ASU Code Diagnostics
ASU 000629.12 — ASU Control Unit Fault
ASU 524002.31 — Active Seat Pressure Control Solenoid Fault
ASU 524003.02 — Active Seat Firmness Control Switch Circuit Faul
ASU 524004.02 — Active Seat Height Control Switch Circuit Fault
ASU 524006.30 — Active Seat Vent ON Too Long
ASU 524007.30 — Active Seat Compressor Assembly ON Too Long
ASU 524008.13 — ASU Not Calibrated
ASU 524010.31 — Active Seat Raise/Lower Solenoid Circuit Fault
ASU 524011.03 — Active Seat Accelerometer Circuit Voltage High
ASU 524011.04 — Active Seat Accelerometer Circuit Voltage Low
ASU 524011.08 — Active Seat Accelerometer Circuit Fault
ASU 524012.03 — Active Seat Position Sensor Circuit Voltage Hig
ASU 524012.04 — Active Seat Position Sensor Circuit Voltage Low
ATC Code Diagnostics
ATC 000170.03 — Cab Temperature Sensor Circuit Voltage High
ATC 000170.04 — Cab Temperature Sensor Circuit Voltage Low
ATC 000171.03 — Ambient Temperature Sensor Circuit Voltage High
ATC 000171.04 — Ambient Temperature Sensor Circuit Voltage Low
ATC 000628.12 — ATC Programming
ATC 000630.02 — ATC Calibration Fault/Data Invalid
ATC 000639.14 — ATC CAN Error Exceeded
ATC 000871.03 — Refrigerant Pressure Sensor Circuit Voltage High
ATC 000871.04 — Refrigerant Pressure Sensor Circuit Voltage Low
ATC 000876.10 — Excessive A/C Clutch Cycling
ATC 000876.14 — Compressor Shutoff Due to Engine Overheat
ATC 000923.03 — Circulation Blower Motor Circuit Voltage High
ATC 000923.04 — Circulation Blower Motor Circuit Voltage Low
ATC 000923.12 — Circulation Blower Motor Driver Circuit Fault
ATC 001079.03 — ATC Sensor Supply Voltage High
ATC 001079.04 — ATC Sensor Supply Voltage Low
ATC 001546.03 — Water Valve Position Sensor Circuit Voltage High
ATC 001546.04 — Water Valve Position Sensor Circuit Voltage Low
ATC 001547.03 — Evaporator Temperature Sensor Circuit Voltage Hi
ATC 001547.04 — Evaporator Temperature Sensor Circuit Voltage Lo
ATC 001548.03 — Outlet Air Temperature Sensor Circuit Voltage Hi
ATC 001548.04 — Outlet Air Temperature Sensor Circuit Voltage Lo
ATC 001549.03 — Water Valve Motor Circuit Voltage High
ATC 001549.04 — Water Valve Motor Circuit Voltage Low
ATC 001549.07 — Water Valve Motor Mechanical Fault
ATC 001549.13 — Water Valve Motor Not Calibrated
ATC 001551.03 — Pressurizer Blower Motor Circuit Voltage High
ATC 001551.04 — Pressurizer Blower Motor Circuit Voltage Low
ATC 001552.03 — Cab Temperature Control Circuit Voltage High
ATC 001552.04 — Cab Temperature Control Circuit Voltage Low
ATC 001553.03 — Blower Control Circuit Voltage High
ATC 001553.04 — Blower Control Circuit Voltage Low
ATC 002000.09 — ECU Message Missing
ATC 523848.03 — Air Flow Mode Motor Circuit Voltage High
ATC 523848.04 — Air Flow Mode Motor Circuit Voltage Low
ATC 523848.05 — Air Flow Mode Motor Circuit Current Low
ATC 523848.06 — Air Flow Mode Motor Circuit Current High
ATC 523848.07 — Air Flow Mode Motor Mechanical Fault
ATC 523848.13 — Air Flow Mode Motor Not Calibrated
BRC Code Diagnostics
BRC 000154.04 — BRC Switched Supply Voltage Low
BRC 000168.04 — BRC Unswitched Supply Voltage Low
BRC 000629.12 — BRC Control Unit Fault
BRC 000630.13 — BRC Calibration Fault/Not Calibrated
BRC 001079.03 — BRC Sensor Supply Voltage High
BRC 001079.04 — BRC Sensor Supply Voltage Low
BRC 002049.09 — CAB Message Missing
BRC 522279.05 — Secondary Handbrake Control Valve Current Low
BRC 522279.06 — Secondary Handbrake Control Valve Current High
BRC 522279.13 — Secondary Handbrake Control Valve Not Calibrated
BRC 522280.00 — Secondary Handbrake Pressure Sensor Voltage Very
BRC 522280.01 — Secondary Handbrake Sensor Voltage Very Low
BRC 522280.03 — Secondary Handbrake Sensor Voltage High
BRC 522280.04 — Secondary Handbrake Pressure Sensor Voltage Low
BRC 522280.13 — Secondary Handbrake Pressure Not Calibrated
BRC 523652.02 — Wire Connector Fault
BRC 523837.00 — Rear Brake Pressure High/Right Brake Pedal Confl
BRC 523837.03 — Rear Brake Pressure Sensor Circuit Voltage High
BRC 523837.04 — Rear Brake Pressure Sensor Circuit Voltage Low
BRC 523837.13 — Brake Pressure Sensor Not Calibrated
BRC 523840.00 — Front Brake Pressure High
BRC 523840.01 — Front Brake Pressure Low
BRC 523840.03 — Front Brake Pressure Sensor Circuit Voltage High
BRC 523840.04 — Front Brake Pressure Sensor Circuit Voltage Low
BRC 523840.13 — BRC Calibration Fault/Front Brake Pressure Senso
BRC 523841.19 — Secondary Handbrake Position Fault Message Recei
BRC 523841.31 — Secondary Handbrake Position Message Missing
BRC 523844.05 — Front Brake Solenoid Circuit Current Low
BRC 523844.06 — Front Brake Solenoid Circuit Current High
BRC 523844.13 — BRC Calibration Fault/Front Brake Valve
BRC 523910.02 — BRC Control Unit Fault
BRC 524016.04 — Brake Solenoid Supply Voltage Low
BRC 524157.09 — Right Brake Pedal Switch Fault Message Received
BRC 524162.19 — Left Brake Pedal Switch Fault Message Received
CAB Code Diagnostics
CAB 000091.02 — Foot Throttle Sensor Circuit Voltage Conflict
CAB 000091.03 — Foot Throttle Sensor Circuit Voltage High
CAB 000091.04 — Foot Throttle Sensor Circuit Voltage Low
CAB 000158.03 — CAB Control Unit Switched Supply Voltage High
CAB 000158.04 — CAB Control Unit Switched Supply Voltage Low
CAB 000628.02 — CAB Control Unit EOL Data Fault
CAB 000628.12 — CAB Control Unit Programming
CAB 000629.11 — CAB Control Unit Fault
CAB 000629.12 — CAB Control Unit Fault
CAB 001079.02 — CAB Control Unit Sensor Supply Voltage Fault
CAB 001079.03 — CAB Control Unit Sensor Supply Voltage High
CAB 001079.04 — CAB Control Unit Sensor Supply Voltage Low
CAB 001504.30 — Seat Switch Circuit Fault
CAB 002876.02 — Turn Signal Switch Conflict
CAB 523839.02 — Secondary Brake Switch Conflict
CAB 523839.13 — Secondary Brake Not Calibrated
CAB 523841.03 — Secondary Brake Sensor Voltage High
CAB 523841.04 — Secondary Brake Sensor Voltage Low
CAB 523908.02 — Rear PTO Remote (External) Switch Conflict
CAB 523922.31 — Secondary Hand Brake ON While Moving
CAB 524016.04 — CAB Control Unit Switched Supply Voltage Low
CAB 524017.13 — Left Hand Reverser Lever Type Not Selected
CAB 524017.31 — Left Hand Reverser Lever Power Circuit Fault
CAB 524020.31 — Left Hand Reverser Lever in Gear at Power Up
CAB 524021.31 — Left Hand Reverser Lever Multiple Switch Circuit
CAB 524166.02 — Right Brake Pedal Switch-Sensor Circuit Conflict
CAB 524166.03 — Right Brake Pedal Sensor Circuit Voltage High
CAB 524166.04 — Right Brake Pedal Sensor Circuit Voltage Low
CAB 524166.13 — Right Brake Pedal Sensor Not Calibrated
CAB 524166.30 — Right Brake Pedal Sensor Adjustment Fault
CAB 524169.02 — Left Brake Pedal Switch-Sensor Circuit Conflict
CAB 524169.03 — Left Brake Pedal Sensor Circuit Voltage High
CAB 524169.04 — Left Brake Pedal Sensor Circuit Voltage Low
CAB 524169.13 — Left Brake Pedal Sensor Not Calibrated
CAB 524169.30 — Left Brake Pedal Sensor Adjustment Fault
CAB 524173.02 — Clutch Pedal Sensor Voltage Conflict
CAB 524173.03 — Clutch Pedal Sensor Circuit Voltage High
CAB 524173.04 — Clutch Pedal Sensor Circuit Voltage Low
CCU Code Diagnostics
CCU 000090.03 — Rear PTO Oil Temperature Sensor Circuit Voltage
CCU 000090.04 — Rear PTO Oil Temperature Sensor Circuit Voltage
CCU 000096.03 — Fuel Level Sensor Circuit Voltage High
CCU 000096.17 — Fuel Level Low
CCU 000107.00 — Engine Air Filter Restriction/Engine Limited to
CCU 000107.03 — Engine Air Filter Restriction Sensor Voltage Hig
CCU 000107.04 — Engine Air Filter Restriction Sensor Voltage Low
CCU 000107.15 — Engine Air Filter Becoming Restricted
CCU 000107.16 — Engine Air Filter Restricted/Engine De-rated
CCU 000237.02 — VIN Security Data Conflict
CCU 000237.14 — VIN Security Not Enabled
CCU 000237.31 — VIN Security Messages Missing
CCU 000569.05 — Rear Differential Lock Solenoid Circuit Fault
CCU 000630.14 — Rear PTO Configuration Invalid
CCU 000976.04 — Rear PTO Shaft Type Sensor Circuit Voltage Low
CCU 001079.03 — Chassis Control Unit (CCU) Sensor Supply Voltage
CCU 001079.04 — Chassis Control Unit (CCU) Sensor Supply Voltage
CCU 001086.18 — Air Brake Pressure Low
CCU 001638.00 — Hydraulic Oil Temperature Very Hot
CCU 001638.04 — Hydraulic Oil Temperature Sensor Circuit Voltage
CCU 001638.03 — Hydraulic Oil Temperature Sensor Circuit Voltage
CCU 001638.16 — Hydraulic Oil Temperature High
CCU 001713.00 — Hydraulic Oil Filter Restricted
CCU 001883.00 — Rear PTO Over-Speed
CCU 001883.01 — Rear PTO Under-Speed
CCU 001883.13 — Rear PTO Not Calibrated
CCU 002392.05 — Back Up Alarm Circuit Fault
CCU 523698.09 — GreenStar™ Display Messages Not Available
CCU 523749.16 — PTO Clutch Slipping Too Long
CCU 523851.02 — IMS Disabled Due to HCU/SCU/SCO/TEC
CCU 524016.04 — Chassis Control Unit (CCU) Switched Supply Volta
CCU 524223.03 — Differential Lock Switch Circuit Voltage High
CCU 524224.02 — Rear PTO Switch Voltage Mismatch
CCU 524224.14 — Rear PTO Disabled
CCU 524235.05 — MFWD Solenoid Circuit Fault
CCU 524236.31 — MFWD Switch / IMS Conflict
CCU 524251.31 — Operator Not Present With Rear PTO On
CCU 524252.05 — Rear PTO Solenoid Circuit Fault
CCU 524255.31 — Rear PTO Remote Enabled
CLC Code Diagnostics
CLC 000158.00 — Cab Load Center (CLC) Switched Supply Voltage Hi
CLC 000158.01 — Cab Load Center (CLC) Switched Supply Voltage Lo
CLC 000158.17 — Cab Load Center (CLC) Switched Supply Voltage Lo
CLC 000158.18 — Cab Load Center (CLC) Switched Supply Voltage Lo
CLC 000628.02 — Cab Load Center (CLC) End Of Line (EOL) Data Fau
CLC 000628.12 — Cab Load Cab (CLC) Control Unit Programming
CLC 000629.11 — Cab Load Center (CLC) Control Unit Fault
CLC 000629.12 — Cab Load Center (CLC) Control Unit Fault
CLC 001079.03 — Cab Load Center (CLC) Control Unit Sensor Supply
CLC 001079.04 — Cab Load Center (CLC) Control Unit Sensor Supply
CLC 002050.06 — Cab Load Center (CLC) Control Unit Current High
CLC 002360.05 — Rear Fender Flood Lights Circuit Current Low
CLC 002360.06 — Rear Fender Flood Lights Circuit Current High
CLC 002362.05 — Rear Roof Flood Lights Circuit Current Low
CLC 002362.06 — Rear Roof Flood Lights Circuit Current High
CLC 002364.05 — Mid-Body Flood Lights Circuit Current Low
CLC 002364.06 — Mid-Body Flood Lights Circuit Current High
CLC 002366.05 — Side Roof Flood Lights Circuit Current Low
CLC 002366.06 — Side Roof Flood Lights Circuit Current High
CLC 002368.05 — Left Turn Signal / Brake Lights Circuit Current
CLC 002368.06 — Left Turn Signal / Brake Lights Circuit Current
CLC 002370.05 — Right Turn Signal Lights Circuit Current Low
CLC 002370.06 — Right Turn Signal Lights Circuit Current High
CLC 002372.05 — Brake Lights Circuit Current Low
CLC 002372.06 — Brake Lights Circuit Current High
CLC 002378.05 — Tail Lights Circuit Current Low
CLC 002378.06 — Tail Lights Circuit Current High
CLC 002394.05 — Trailer Flood Light Circuit Current Low
CLC 002394.06 — Trailer Flood Light Circuit Current High
CLC 002863.02 — Front Wiper Switch Circuit Fault
CLC 002865.02 — Rear Wiper Switch Circuit Fault
CLC 002872.02 — Road Light Switch Circuit Fault
CLC 522310.05 — Cab Load Center (CLC) Control Unit ELX Output 1
CLC 522310.06 — Cab Load Center (CLC) Control Unit ELX Output 1
CLC 522433.05 — Rear Wiper Motor Circuit Current Low
CLC 522433.06 — Rear Wiper Motor Circuit Current High
CLC 522434.05 — Front Wiper Motor Low Speed Circuit Current Low
CLC 522434.06 — Front Wiper Motor Low Speed Circuit Current High
CLC 522435.05 — Front Wiper Motor High Speed Circuit Current Low
CLC 522435.06 — Front Wiper Motor High Speed Circuit Current Hig
CLC 523677.02 — Hand Clutch Switch Circuit Fault
CLC 523677.03 — Hand Clutch Switch Voltage High
CLC 523677.04 — Hand Clutch Switch Voltage Low
CLC 523907.02 — Rear PTO Preselector Switch Conflict
CLC 524016.05 — Cab Load Center (CLC) Control Unit Wake-Up Circu
CLC 524016.06 — Cab Load Center (CLC) Control Unit Wake-Up Circu
CLC 524035.02 — IVT Selector Circuit Fault
CLC 524037.02 — MFWD Auto Mode & Brake Assist Mode High
CLC 524259.00 — CLC Temperature Above 115 Degrees Celsius
CLC 524259.15 — CLC Temperature Above 100 Degrees Celsius
CLC 524259.16 — CLC Temperature Above 85 Degrees Celsius
ECU Code Diagnostics
ECU 000097.03 — Water In Fuel Signal Out of Range High
ECU 000097.04 — Water In Fuel Signal Out of Range Low
ECU 000097.16 — Water In Fuel Detected
ECU 000100.01 — Engine Oil Pressure Signal Extremely Low
ECU 000100.04 — Engine Oil Pressure Signal Out of Range Low
ECU 000100.18 — Engine Oil Pressure Signal Moderately Low
ECU 000100.31 — Engine Oil Pressure Invalid
ECU 000102.02 — Intake Manifold Pressure Signal Invalid
ECU 000102.03 — Intake Manifold Pressure Signal Out of Range Hig
ECU 000102.04 — Intake Manifold Pressure Signal Out of Range Low
ECU 000103.00 — Turbo Speed Signal Extremely High
ECU 000103.05 — Turbo Speed Sensor Circuit Has High Resistance
ECU 000103.06 — Turbo Speed Sensor Circuit has Low Resistance
ECU 000103.08 — Turbocharger Speed Missing
ECU 000103.31 — Turbocharger Speed Signal Missing
ECU 000105.00 — Intake Manifold Air Temperature Signal Extremely
ECU 000105.03 — Intake Manifold Air Temperature Signal Out of Ra
ECU 000105.04 — Intake Manifold Air Temperature Signal Out of Ra
ECU 000105.15 — Intake Manifold Air Temperature Signal Slightly
ECU 000105.16 — Intake Manifold Air Temperature Signal Moderatel
ECU 000108.02 — Barometric Pressure Signal Invalid
ECU 000110.00 — Engine Coolant Temperature Signal Extremely High
ECU 000110.03 — Engine Coolant Temperature Signal Out of Range H
ECU 000110.04 — Engine Coolant Temperature Signal Out of Range L
ECU 000110.15 — Engine Coolant Temperature Signal Slightly High
ECU 000110.16 — Engine Coolant Temperature Signal Moderately Hig
ECU 000110.17 — Engine Coolant Temperature Signal Slightly Low
ECU 000157.03 — Fuel Rail Pressure Signal Out of Range High
ECU 000157.04 — Fuel Rail Pressure Signal Out of Range Low
ECU 000157.10 — Fuel Rail Pressure Rate of Change Abnormal
ECU 000157.17 — Fuel Rail Pressure Not Developed
ECU 000158.17 — ECU Power Down Error
ECU 000174.00 — Fuel Temperature Signal Extremely High
ECU 000174.03 — Fuel Temperature Signal Out of Range High
ECU 000174.04 — Fuel Temperature Signal Out of Range Low
ECU 000174.16 — Fuel Temperature Signal Moderately High
ECU 000189.00 — Engine Speed Derate Condition Exists
ECU 000190.00 — Engine Speed Extremely High
ECU 000237.02 — VIN Security Data Invalid
ECU 000237.13 — VIN Option Code Security Data Conflict
ECU 000237.31 — VIN Security Data Missing
ECU 000412.00 — EGR Temperature Signal Extremely High
ECU 000412.03 — EGR Temperature Signal Out of Range High
ECU 000412.04 — EGR Temperature Signal Out of Range Low
ECU 000412.16 — EGR Temperature Signal Moderately High
ECU 000611.03 — Injector Shorted to Power
ECU 000611.04 — Injector Shorted to Ground
ECU 000629.13 — ECU Programming Error
ECU 000636.02 — Engine Position Sensor Signal Invalid
ECU 000636.05 — Engine Position Sensor Circuit Has High Resistan
ECU 000636.06 — Engine Position Sensor Circuit Has Low Resistanc
ECU 000636.08 — Engine Position Sensor Signal Missing
ECU 000636.10 — Engine Position Signal Rate of Change Abnormal
ECU 000637.02 — Engine Timing Sensor Signal Invalid
ECU 000637.05 — Engine Position Sensor Circuit Has High Resistan
ECU 000637.06 — Engine Position Sensor Circuit Has Low Resistanc
ECU 000637.07 — Engine Timing and Position Signals Out of Sync
ECU 000637.08 — Engine Timing Sensor Signal Missing
ECU 000637.10 — Engine Timing Signal Rate of Change Abnormal
ECU 000641.04 — VGT Actuator Supply Voltage Out of Range Low
ECU 000641.12 — VGT Actuator Communication Error
ECU 000641.13 — VGT Actuator Learn Error
ECU 000641.16 — Turbo Actuator Temperature Moderately High
ECU 000647.05 — Engine Fan Drive Circuit Has High Resistance
ECU 000651.02 — Injector Number 1 Part Number Data Invalid
ECU 000651.05 — Injector Number 1 Circuit Has High Resistance
ECU 000651.06 — Injector Number 1 Circuit Has Low Resistance
ECU 000651.07 — Injector Number 1 Not Responding
ECU 000651.13 — Injector Number 1 Calibration Fault
ECU 000652.02 — Injector Number 2 Part Number Data Invalid
ECU 000652.05 — Injector Number 2 Circuit Has High Resistance
ECU 000652.06 — Injector Number 2 Circuit Has Low Resistance
ECU 000652.07 — Injector Number 2 Not Responding
ECU 000652.13 — Injector Number 2 Calibration Fault
ECU 000653.02 — Injector Number 3 Part Number Data Invalid
ECU 000653.05 — Injector Number 3 Circuit Has High Resistance
ECU 000653.06 — Injector Number 3 Circuit Has Low Resistance
ECU 000653.07 — Injector Number 3 Not Responding
ECU 000653.13 — Injector Number 3 Calibration Fault
ECU 000654.02 — Injector Number 4 Part Number Data Invalid
ECU 000654.05 — Injector Number 4 Circuit Has High Resistance
ECU 000654.06 — Injector Number 4 Circuit Has Low Resistance
ECU 000654.07 — Injector Number 4 Not Responding
ECU 000654.13 — Injector Number 4 Calibration Fault
ECU 000655.02 — Injector Number 5 Part Number Data Invalid
ECU 000655.05 — Injector Number 5 Circuit Has High Resistance
ECU 000655.06 — Injector Number 5 Circuit Has Low Resistance
ECU 000655.07 — Injector Number 5 Not Responding
ECU 000655.13 — Injector Number 5 Calibration Fault
ECU 000656.02 — Injector Number 6 Part Number Data Invalid
ECU 000656.05 — Injector Number 6 Circuit Has High Resistance
ECU 000656.06 — Injector Number 6 Circuit Has Low Resistance
ECU 000656.07 — Injector Number 6 Not Responding
ECU 000656.13 — Injector Number 6 Calibration Fault
ECU 001075.05 — Low Pressure Fuel Pump Circuit Has High Resistan
ECU 001110.31 — Engine Protection Shutdown
ECU 001136.00 — ECU Temperature Signal Extremely High
ECU 001136.16 — ECU Temperature Signal Moderately High
ECU 001172.03 — Compressor Inlet Temperature Signal Out of Range
ECU 001172.04 — Compressor Inlet Temperature Signal Out of Range
ECU 001180.00 — Compressor Inlet Temperature Signal Extremely Hi
ECU 001180.16 — Compressor Inlet Temperature Signal Moderately H
ECU 001347.03 — High Pressure Fuel Pump Control Valve Signal Out
ECU 001347.05 — High Pressure Fuel Pump Solenoid Number 1 Circui
ECU 001347.07 — High Pressure Fuel Pump Not Able to Meet Require
ECU 001569.31 — Engine in Derate Condition
ECU 001639.01 — Fan Speed Signal Extremely Low
ECU 001639.16 — Fan Speed Signal Moderately High
ECU 001639.18 — Fan Speed Moderately Low
ECU 002005.09 — ACU Message Missing
ECU 002005.14 — Communication Error
ECU 002030.09 — VLC Message Missing
ECU 002071.09 — CCU Message Missing
ECU 002630.00 — Charge Air Cooler Outlet Temperature Signal Extr
ECU 002630.03 — Charge Air Cooler Outlet Temperature Signal Out
ECU 002630.04 — Charge Air Cooler Outlet Temperature Signal Out
ECU 002630.15 — Charge Air Cooler Outlet Temperature Signal Slig
ECU 002005.19 — Communication Error
ECU 002630.16 — Charge Air Cooler Outlet Temperature Signal Mode
ECU 002659.02 — EGR Mass Flow Rate Data Invalid
ECU 002659.15 — EGR Mass Flow Rate Data Slightly High
ECU 002659.17 — EGR Mass Flow Rate Data Slightly Low
ECU 002790.16 — Calculated Turbine Outlet Temperature Moderately
ECU 002791.02 — EGR Valve Position Signal Invalid
ECU 002791.03 — EGR Valve Position Signal Out of Range High
ECU 002791.04 — EGR Valve Position Signal Out of Range Low
ECU 002791.07 — EGR Valve Not Reaching Expected Position
ECU 002791.13 — EGR Valve Calibration Change Error
ECU 002791.31 — EGR Valve Calibration Change Over A Long Time
ECU 002795.07 — VGT Actuator Not Reaching Expected Position
ECU 003509.03 — Sensor Supply Number 1 Voltage Out of Range High
ECU 003509.04 — Sensor Supply Number 1 Voltage Out of Range Low
ECU 003510.03 — Sensor Supply Number 2 Voltage Out of Range High
ECU 003510.04 — Sensor Supply Number 2 Voltage Out of Range Low
ECU 003511.03 — Sensor Supply Number 3 Voltage Out of Range High
ECU 003511.04 — Sensor Supply Number 3 Voltage Out of Range Low
ECU 003513.03 — Sensor Supply Number 5 Voltage Out of Range High
ECU 003513.04 — Sensor Supply Number 5 Voltage Out of Range Low
HCU Code Diagnostics
HCU 000158.04 — HCU Switched Supply Voltage Low
HCU 000168.04 — HCU Unswitched Supply Voltage Low
HCU 000190.02 — Rear Hitch Calibration Fault/Engine Speed Low
HCU 000629.12 — HCU Control Unit Fault
HCU 000630.13 — HCU Calibration Fault/Not Calibrated
HCU 000639.12 — HCU CAN Message Overflow
HCU 000639.14 — HCU CAN Error Limit Exceeded
HCU 001079.03 — HCU Sensor Supply Voltage High
HCU 001079.04 — HCU Sensor Supply Voltage Low
HCU 001638.02 — HCU Calibration Fault/Hydraulic Oil Temperature
HCU 001873.02 — Rear Hitch Position Sensor Voltage Fault
HCU 001873.03 — Rear Hitch Position Sensor Circuit Voltage High
HCU 001873.04 — Rear Hitch Position Sensor Circuit Voltage Low
HCU 001873.11 — Rear Hitch Position Sensor Fault
HCU 001873.13 — HCU Calibration Fault/Rear Hitch Position Sensor
HCU 001881.03 — Rear Hitch Draft Sensor Circuit Voltage High
HCU 001881.04 — Rear Hitch Draft Sensor Circuit Voltage Low
HCU 001881.13 — HCU Calibration Fault/Rear Hitch Draft Sensor Ci
HCU 002005.09 — ACU Message Missing
HCU 002071.09 — CCU Message Missing
HCU 002602.18 — Hydraulic Oil Level Low
HCU 521000.02 — Rear Hitch External Switch Circuit Fault
HCU 521000.31 — Rear Hitch External Switch Circuit Fault
HCU 521001.02 — HCU Calibration Fault/Rear Hitch Pressure Valve
HCU 521001.05 — Rear Hitch Pressure Solenoid Current Low
HCU 521001.06 — Rear Hitch Pressure Solenoid Current High
HCU 521001.07 — HCU Calibration Fault/Rear Hitch Pressure Valve
HCU 521001.11 — HCU Calibration Fault/Rear Hitch Pressure Valve
HCU 521001.13 — HCU Calibration Fault/Rear Hitch Pressure Valve
HCU 521002.05 — Rear Hitch Return Solenoid Current Low
HCU 521002.06 — Rear Hitch Return Solenoid Current High
HCU 521002.07 — HCU Calibration Fault/Rear Hitch Return Valve
HCU 521002.11 — HCU Calibration Fault/Rear Hitch Return Valve
HCU 521002.13 — HCU Calibration Fault/Rear Hitch Return Valve
HCU 523652.02 — Wire Connector Fault
HCU 523788.02 — Hydraulic Option Configuration Changed Since Pow
HCU 523788.14 — Hydraulic Option Configuration Change Not Allowe
HCU 523910.02 — HCU Control Unit Fault
HCU 523950.13 — Hitch Calibration Purge Counting Fault
HCU 523952.31 — Rear Hitch Disabled/HCU Configuration
HCU 524016.04 — HCU Switched Supply Voltage Low/Rear Hitch Solen
HCU 524212.19 — Rear Hitch Control Lever Fault Message Received
HCU 524212.31 — Rear Hitch Lever Command Missing
ICU Code Diagnostics
ICU 000237.02 — VIN Security Data Conflict
ICU 000237.14 — VIN Security Not Enabled
ICU 000237.31 — VIN Security Messages Missing
ICU 000251.12 — ICU Clock Fault
ICU 000628.12 — ICU Programming
ICU 000629.09 — Cornerpost Display Message Missing
ICU 000629.12 — ICU Control Unit Fault
ICU 000630.02 — ICU Calibration Fault/Data Invalid
ICU 002000.09 — ECU Message Missing
ICU 002003.09 — PTI or PTQ Message Missing
ICU 002005.09 — ACU Message Missing
ICU 002011.09 — BRC Message Missing
ICU 002019.09 — SSU Message Missing
ICU 002020.09 — SFA Message Missing
ICU 002025.09 — ATC Message Missing
ICU 002030.09 — VLC Message Missing
ICU 002034.09 — SCU Message Missing
ICU 002035.09 — HCU Message Missing
ICU 002049.09 — CAB Message Missing
ICU 002050.09 — CLC Message Missing
ICU 002054.09 — ASU Message Missing
ICU 002071.09 — CCU Message Missing
ICU 002129.09 — ICU Message Missing
ICU 002213.09 — SCO Message Missing
ICU 002227.09 — SUP Message Missing
ICU 002240.09 — TEC Message Missing
ICU 002255.09 — CAN Bus Fault
ICU 523791.14 — ICU Engine Starting Aid Countdown
ICU 524013.03 — ICU Switch Fault
PTF Code Diagnostics
PTF 000168.04 — PTF Unswitched Supply Voltage Low
PTF 000628.02 — PTF EOL Data Fault
PTF 000628.12 — PTF Programming
PTF 000629.12 — PTF Control Unit Fault
PTF 000630.14 — Front PTO Configuration Invalid
PTF 001882.00 — Front PTO Overspeed
PTF 001882.01 — Front PTO Underspeed
PTF 001882.13 — Front PTO Not Calibrated
PTF 523904.31 — Operator Not Seated With Front PTO On
PTF 523905.02 — Front PTO Solenoid Circuit Fault
PTF 523906.03 — Front PTO Oil Temperature Sensor Circuit Voltage
PTF 523906.04 — Front PTO Oil Temperature Sensor Circuit Voltage
PTF 524216.02 — Front PTO Switch Circuit Conflict
PTF 524216.31 — Front PTO Disabled
PTI Code Diagnostics
PTI 000126.15 — Transmission Oil Filter Restricted/Park Engaged
PTI 000126.16 — Transmission Oil Filter Restricted/Park Not Enga
PTI 000127.01 — Transmission Enable Pressure Very Low
PTI 000127.02 — Transmission Pump Pressure/Park and Enable Press
PTI 000127.04 — Transmission Pump Pressure Sensor Circuit Voltag
PTI 000127.18 — Transmission Pump Pressure Low
PTI 000158.01 — PTI Switched Supply Voltage Low
PTI 000168.01 — PTI Unswitched Supply Voltage Low
PTI 000190.00 — Engine Overspeed
PTI 000190.02 — Speed Mismatch
PTI 000191.00 — Transmission Overspeed
PTI 000191.02 — Transmission Output Speed Mismatch
PTI 000619.05 — Park Brake Solenoid Circuit Fault
PTI 000628.02 — PTI EOL Data Fault
PTI 000629.12 — PTI Control Unit Fault
PTI 000630.13 — PTI Hydro Calibration Fault
PTI 000630.14 — PTI Clutch Calibration Fault
PTI 000639.12 — PTI CAN Message Overflow
PTI 000639.14 — PTI CAN Error Limit Exceeded
PTI 000734.05 — Low Clutch Solenoid Circuit Fault
PTI 000735.05 — High Clutch Solenoid Circuit Fault
PTI 000736.05 — Reverse Brake Solenoid Circuit Fault
PTI 000754.18 — Clutch Enable Pressure Low/LC Engaged
PTI 000755.18 — Clutch Enable Pressure Low/HC Engaged
PTI 000756.18 — Clutch Enable Pressure Low/RB Engaged
PTI 001079.04 — PTI Sensor Supply Voltage Low
PTI 002000.09 — ECU Message Missing
PTI 002005.09 — ACU Message Missing
PTI 524042.00 — Transmission Oil Filter Bypassed < 1300/Park eng
PTI 524042.16 — Transmission Oil Filter Bypassed > 1300/Park Eng
PTI 524226.08 — Direction Sensing Incorrect
PTI 524227.00 — Transmission Oil Filter Bypassed < 1300/Park Not
PTI 524227.16 — Transmission Oil Filter Bypassed > 1300/Park Not
PTI 524228.05 — Park Sump Block Solenoid Circuit Fault
PTI 524228.11 — Park Sump Block Valve Fault
PTI 524229.05 — Hydro Control Valve Circuit Fault
PTI 524230.05 — Clutch Enable Solenoid Circuit Fault
PTI 524232.01 — Park Brake Pressure Low/Gear Commanded
PTI 524232.02 — Park Brake Pressure Incorrect
PTI 524232.04 — Park Brake Pressure Sensor Circuit Voltage Low
PTI 524232.14 — Park Brake Pressure Low in Come Home Mode
PTI 524232.16 — Park Brake Pressure High/Park Commanded
PTI 524232.17 — Park Brake Pressure Low/Park Not Commanded
PTI 524232.18 — Park Brake Pressure Low
PTI 524233.00 — Hydro Fixed Unit Overspeed
PTI 524233.02 — Hydro Fixed Unit Speed Incorrect
PTI 524233.07 — Hydro Speed Incorrect/PowerZero
PTI 524233.15 — Hydro Speed Incorrect/Park Engaged
PTI 524233.16 — Hydro Speed Incorrect/Park Not Engaged
PTI 524234.02 — Clutch Enable Pressure Incorrect
PTI 524234.04 — Clutch Enable Pressure Sensor Circuit Voltage Lo
PTI 524237.31 — Reverser Park and Neutral Switches Both On
PTI 524238.31 — Reverser Park And Neutral Switches Off At Power
PTI 524239.31 — No Motion/Engine Running
PTI 524240.14 — No Motion/Come Home Mode
PTI 524241.02 — Carrier or Fixed Unit Speed Incorrect
PTI 524242.00 — Transmission Pressures High
PTI 524243.31 — PTI Park/ACU Gear Command Conflict
PTI 524244.31 — PTI Park/ACU Neutral Command Conflict
PTI 524245.31 — PTI Neutral/ACU Gear Command Conflict
PTI 524246.17 — Hydro Fixed Unit Speed Low At Start-up
PTI 524247.02 — Carrier Speed Incorrect
PTI 524247.17 — Carrier Speed Low at Start up
PTI 524248.31 — Vehicle Motion With Park Brake Engaged
PTI 524249.31 — Operator Not Seated With Transmission In Neutral
PTI 524250.31 — Park Brake Previously Failed/May Not Hold
PTI 524253.02 — ACU Not Commanding Park At Power Up
PTI 524254.03 — Transmission Enable Circuit Voltage High
PTI 524254.04 — Transmission Enable Circuit Voltage Low
PTQ Code Diagnostics
PTQ 000084.07 — Vehicle Motion During Calibration
PTQ 000084.14 — Wheel Speed Signal Missing
PTQ 000126.16 — Transmission Oil Filter Restricted
PTQ 000127.01 — Transmission Oil Pressure Low
PTQ 000158.04 — PTQ Switched Supply Voltage Low
PTQ 000190.18 — Engine Speed Low
PTQ 000191.00 — Transmission Overspeed During Calibration
PTQ 000191.17 — Transmission Underspeed
PTQ 000628.02 — PTQ EOL Data Fault
PTQ 000628.12 — PTQ Programming
PTQ 000629.12 — PTQ Control Unit Fault
PTQ 000630.14 — PTQ Not Calibrated
PTQ 000734.05 — Forward Solenoid Circuit Fault
PTQ 000735.05 — Reverse Solenoid Circuit Fault
PTQ 000736.05 — Four-Speed Solenoid 1 Circuit Fault
PTQ 000737.05 — Four-Speed Solenoid 2 Circuit Fault
PTQ 002000.09 — ECU Message Missing
PTQ 002005.09 — ACU Message Missing
PTQ 002049.09 — CAB Control Unit Message Missing
PTQ 002050.09 — CLC Message Missing
PTQ 002129.09 — ICU Message Missing
PTQ 523677.07 — Hand Clutch Switch Active at Powerup
PTQ 523677.14 — Hand Clutch Disabled by Operator
PTQ 523677.31 — Hand Clutch Disabled
PTQ 523953.02 — Speed Control Lever Sensor Circuit Conflict
PTQ 523960.31 — Operator Not Seated During Reverser Command
PTQ 523961.07 — Range Lever Park/Reverser Lever Gear Conflict
PTQ 523966.31 — Transmission Come Home Mode
PTQ 524191.05 — Trailer Air Brake Valve Driver Fault
PTQ 524230.03 — Clutch Enable Pressure Fault/Unexpected Pressure
PTQ 524230.04 — Clutch Enable Pressure Fault/Unexpected Pressure
PTQ 524230.05 — Clutch Enable Solenoid Circuit Fault
PTQ 524234.03 — Clutch Enable Pressure Sensor Circuit Voltage Hi
PTQ 524234.04 — Clutch Enable Pressure Sensor Circuit Voltage Lo
PTQ 524254.04 — Transmission Enable Circuit Voltage Low
PTQ 524267.16 — Forward Clutch Slipping Too Long
SCo Code Diagnostics
SCO 000158.04 — SCO Switched Supply Voltage Low
SCO 000168.04 — SCO Unswitched Supply Voltage Low
SCO 000628.12 — SCO Programming
SCO 000629.12 — SCO Control Unit Fault
SCO 000630.02 — SCO Calibration Fault/Data Invalid
SCO 000630.13 — SCO Calibration Fault/Not Calibrated
SCO 000639.12 — SCO CAN Message Overflow
SCO 000639.14 — SCO CAN Error Limit Exceeded
SCO 001638.02 — SCO Calibration Fault/Hydraulic Oil Temperature
SCO 001961.13 — SCO Calibration Fault/SCV V Directional Control
SCO 001962.13 — SCO Calibration Fault/SCV V Flow Control Not Cal
SCO 001963.05 — SCV V Flow Control Solenoid Current Low for Floa
SCO 001973.13 — SCO Calibration Fault/SCV VI Directional Control
SCO 001974.13 — SCO Calibration Fault/SCV VI Flow Control Not Ca
SCO 001975.05 — SCV VI Flow Control Solenoid Current Low for Flo
SCO 002005.09 — ACU Message Missing
SCO 002071.09 — CCU Message Missing
SCO 521000.02 — Front Hitch External Switch Circuit Fault
SCO 523652.02 — Wire Connector Fault
SCO 523662.05 — Auxiliary Valve Solenoid 2 Current Low
SCO 523662.06 — Auxiliary Valve Solenoid 2 Current High
SCO 523663.05 — Auxiliary Valve Solenoid 1 Current Low
SCO 523663.06 — Auxiliary Valve Solenoid 1 Current High
SCO 523695.02 — Missing External Control Message for 10 Seconds
SCO 523695.09 — SCV V External Control Lever Message Rate Fault
SCO 523695.19 — SCV V External Control Lever Fault Message Recei
SCO 523696.02 — Missing SCV VI External Control Message for 10 S
SCO 523696.09 — SCV VI External Control Lever Message Rate Fault
SCO 523696.19 — SCV VI External Control Lever Fault Message Rece
SCO 523775.19 — Single Lever Control Hand Presence Switch Fault
SCO 523776.19 — Single Lever Control Transport Lock Switch Fault
SCO 523787.03 — SCO Switched Supply Voltage High/Auxiliary Valve
SCO 523787.04 — SCO Switched Supply Voltage Low/Auxiliary Valve
SCO 523801.19 — Single Lever Control Auxiliary Switch Fault Mess
SCO 523804.19 — Single Lever Control Lateral Sensor Fault Messag
SCO 523805.19 — Single Lever Control Fore-Aft Sensor Fault Mess
SCO 523910.02 — SCO Control Unit Fault
SCO 523930.05 — SCV VI Directional Control Solenoid Circuit Curr
SCO 523930.06 — SCV VI Directional Control Solenoid Circuit Curr
SCO 523931.05 — SCV V Directional Control Solenoid Circuit Curre
SCO 523931.06 — SCV V Directional Control Solenoid Circuit Curre
SCO 523936.05 — SCV VI Flow Control Solenoid Circuit Current Low
SCO 523936.06 — SCV VI Retract Solenoid Circuit Current High
SCO 523937.05 — SCV V Flow Control Solenoid Circuit Current Low
SCO 523937.06 — SCV V Flow Control Solenoid Circuit Current High
SCO 523942.31 — Operator Out Of Seat With SCV VI On
SCO 523943.31 — Operator Out Of Seat With SCV V On
SCO 524016.03 — SCO Switched Supply Voltage High/SCV V and SCV V
SCO 524016.04 — SCO Switched Supply Voltage Low/SCV V and SCV VI
SCU Code Diagnostics
SCU 000158.04 — SCU Switched Supply 1 Voltage Low
SCU 000168.04 — SCU Unswitched Supply Voltage Low
SCU 000628.12 — SCU Programming
SCU 000629.12 — SCU Control Unit Fault
SCU 000630.02 — SCU Calibration Fault/Data Invalid
SCU 000630.13 — SCU Calibration Fault/Not Calibrated
SCU 000639.12 — SCU CAN Message Overflow
SCU 000639.14 — SCU CAN Error Limit Exceeded
SCU 001079.03 — SCU Sensor Supply Voltage High
SCU 001079.04 — SCU Sensor Supply Voltage Low
SCU 001638.02 — SCU Calibration Fault/Hydraulic Oil Temperature
SCU 001913.13 — SCU Calibration Fault/SCV I Directional Control
SCU 001914.13 — SCU Calibration Fault/SCV I Flow Control Not Cal
SCU 001915.05 — SCV I Flow Control Solenoid Current Low for Floa
SCU 001925.13 — SCU Calibration Fault/SCV II Directional Control
SCU 001926.13 — SCU Calibration Fault/SCV II Flow Control Not Ca
SCU 001927.05 — SCV II Flow Control Solenoid Current Low for Flo
SCU 001937.13 — SCU Calibration Fault/SCV III Directional Contro
SCU 001938.13 — SCU Calibration Fault/SCV III Flow Control Not C
SCU 001939.05 — SCV III Flow Control Solenoid Current Low for Fl
SCU 001949.13 — SCU Calibration Fault/SCV IV Directional Control
SCU 001950.13 — SCU Calibration Fault/SCV IV Flow Control Not Ca
SCU 001951.05 — SCV IV Flow Control Solenoid Current Low for Flo
SCU 002005.09 — ACU Message Missing
SCU 002049.09 — CAB Message Missing
SCU 002071.09 — CCU Message Missing
SCU 523652.02 — Wire Connector Fault
SCU 523693.02 — Missing SCV I External Control Message for 10 Se
SCU 523693.09 — Missing SCV I External Control Message for 1 Sec
SCU 523693.19 — SCV I External Control Fault Message Received
SCU 523694.02 — Missing SCV II External Control Message for 10 S
SCU 523694.09 — Missing SCV II External Control Message for 1 Se
SCU 523694.19 — SCV II External Control Fault Message Received
SCU 523775.19 — Single Lever Control Hand Presence Switch Fault
SCU 523776.19 — Single Lever Control Transport Lock Switch Fault
SCU 523786.03 — SCVs I - IV Remote Position Sensor 1 Circuit Vol
SCU 523786.04 — SCVs I - IV Remote Position Sensor 1 Circuit Vol
SCU 523786.07 — SCVs I - IV Remote Position Sensor 1 Fault/Unexp
SCU 523787.03 — SCU Switched Supply Voltage High/SCVs III and IV
SCU 523787.04 — SCU Switched Supply Voltage Low/SCVs III and IV
SCU 523788.02 — Hydraulic Option Configuration Changed Since Pow
SCU 523788.14 — Hydraulic Option Configuration Changed Without D
SCU 523788.31 — Hydraulic Option Configuration Invalid
SCU 523804.19 — Single Lever Control Lateral Sensor Fault Messag
SCU 523805.19 — Single Lever Control Fore-Aft Sensor Fault Messa
SCU 523910.02 — SCU Control Unit Fault
SCU 523923.19 — SCV I Control Lever Fault Message Received
SCU 523923.31 — SCV I Control Lever Command Missing
SCU 523932.05 — SCV IV Directional Control Solenoid Circuit Curr
SCU 523932.06 — SCV IV Directional Control Solenoid Circuit Curr
SCU 523933.05 — SCV III Directional Control Solenoid Circuit Cur
SCU 523933.06 — SCV III Directional Control Solenoid Circuit Cur
SCU 523934.05 — SCV II Directional Control Solenoid Circuit Curr
SCU 523934.06 — SCV II Directional Control Solenoid Circuit Curr
SCU 523935.05 — SCV I Directional Control Solenoid Circuit Curre
SCU 523935.06 — SCV I Directional Control Solenoid Circuit Curre
SCU 523938.05 — SCV IV Flow Control Solenoid Circuit Current Low
SCU 523938.06 — SCV IV Flow Control Solenoid Circuit Current Hig
SCU 523939.05 — SCV III Flow Control Solenoid Circuit Current Lo
SCU 523939.06 — SCV III Flow Control Solenoid Circuit Current Hi
SCU 523940.05 — SCV II Flow Control Solenoid Circuit Current Low
SCU 523940.06 — SCV II Flow Control Solenoid Circuit Current Hig
SCU 523941.05 — SCV I Flow Control Solenoid Circuit Current Low
SCU 523941.06 — SCV I Flow Control Solenoid Circuit Current High
SCU 523944.31 — Operator Out Of Seat With SCV IV On
SCU 523945.31 — Operator Out Of Seat With SCV III On
SCU 523946.31 — Operator Out Of Seat With SCV II On
SCU 523947.31 — Operator Out Of Seat With SCV I On
SCU 524015.02 — Missing SCV III External Control Message for 10
SCU 524015.09 — Missing SCV III External Control Message for 1 S
SCU 524015.19 — SCV III External Control Fault Message Received
SCU 524016.03 — SCU Switched Supply Voltage High/SCVs I and II S
SCU 524016.04 — SCU Switched Supply Voltage Low/SCV I and II Sol
SCU 524038.02 — Missing SCV IV External Control Message for 10 S
SCU 524038.09 — Missing SCV IV External Control Message for 1 Se
SCU 524038.19 — SCV IV External Control Lever Fault Message Rece
SCU 524103.19 — SCV IV Control Lever Fault Message Received
SCU 524103.31 — SCV IV Control Lever Command Missing
SCU 524104.19 — SCV III Control Lever Fault Message Received
SCU 524104.31 — SCV III Control Lever Command Missing
SCU 524105.19 — SCV II Control Lever Fault Message Received
SCU 524105.31 — SCV II Control Lever Command Missing
SFA Code Diagnostics
SFA 000158.04 — SFA Switched Supply Voltage Low
SFA 000168.04 — SFA Unswitched Supply Voltage Low
SFA 000629.12 — SFA Control Unit Fault
SFA 000630.02 — Front Axle Calibration Fault/Data Invalid
SFA 000630.13 — Front Axle Calibration Fault/Not Calibrated
SFA 000639.12 — SFA CAN Message Overflow
SFA 000639.14 — SFA CAN Error Limit Exceeded
SFA 001079.03 — SFA Sensor Supply Voltage High
SFA 001079.04 — SFA Sensor Supply Voltage Low
SFA 002003.09 — PTI or PTQ Message Missing
SFA 002005.09 — ACU Message Missing
SFA 002049.09 — CAB Control Unit Message Missing
SFA 523652.02 — Wire Connector Fault
SFA 523902.07 — Front Axle Not Responding To Raise Command
SFA 523903.07 — Front Axle Not Responding To Lower Command
SFA 523910.02 — SFA Control Unit Fault
SFA 523948.05 — Front Axle Raise Solenoid Circuit Current Low
SFA 523948.06 — Front Axle Raise Solenoid Circuit Current High
SFA 523949.05 — Front Axle Raise-Lower Solenoid Circuit Low
SFA 523949.06 — Front Axle Raise-Lower Control Solenoid Circuit
SFA 523950.02 — Front Axle Position Sensor Calibration Fault
SFA 523950.03 — Front Axle Position Sensor Circuit Voltage High
SFA 523950.04 — Front Axle Position Sensor Circuit Voltage Low
SFA 523950.13 — Front Axle Calibration Fault/Front Axle Position
SFA 524016.04 — SFA Switched Supply Voltage Low/Front Axle Direc
SSU Code Diagnostics
SSU 000084.09 — Wheel Speed Message Missing
SSU 000168.03 — Steering System Control Unit (SSU) Unswitched Su
SSU 000168.04 — Steering System Control Unit (SSU) Unswitched Su
SSU 000177.09 — Hydraulic Oil Temperature Message Missing
SSU 000237.31 — Vehicle Identification Number (VIN) Security Mes
SSU 000517.09 — GPS Speed Message Missing
SSU 000524.02 — Selected Gear Data Invalid
SSU 000524.09 — Selected Gear Message Missing
SSU 000628.02 — Steering System Control Unit (SSU) End Of Line (
SSU 000628.12 — Steering System Control Unit (SSU) Programming
SSU 000629.12 — Steering System Control Unit (SSU) Fault
SSU 000630.13 — Steering System Control Unit (SSU) Calibration F
SSU 001079.03 — Steering System Control Unit (SSU) Sensor Supply
SSU 001079.04 — Steering System Control Unit (SSU) Sensor Supply
SSU 001504.09 — Operator Presence Message Missing
SSU 001504.14 — Operator Not Seated While AutoTrac Active
SSU 001807.02 — Steering Wheel Position Sensors Conflict
SSU 001807.03 — Steering Wheel Position Sensor 1 Supply Voltage
SSU 001807.04 — Steering Wheel Position Sensor 1 Supply Voltage
SSU 001807.05 — Steering Wheel Position Sensor 1 Circuit Current
SSU 001807.06 — Steering Wheel Position Sensor 1 Circuit Current
SSU 001807.10 — Steering Wheel Position Sensor 1 Signal Mismatch
SSU 001807.14 — Steering Wheel Position Sensor 1 Signal Fault
SSU 001865.09 — ELX Message Missing
SSU 522273.00 — Electro-Hydraulic Steering Valve Control Circuit
SSU 522273.01 — Electro-Hydraulic Steering Valve Control Circuit
SSU 522387.07 — Wheel Angle Sensor Or Electro-Hydraulic Steering
SSU 522394.09 — Terrain Compensation Module (TCM) Message Missin
SSU 522451.00 — Wheel Angle Sensor-Axle (Secondary) Signal High
SSU 522451.01 — Wheel Angle Sensor-Axle (Secondary) Signal Low
SSU 522451.14 — Wheel Angle Sensor-Axle (Secondary) Voltage Faul
SSU 523651.02 — Steering System Control Unit (SSU) Fault
SSU 523698.09 — GreenStar Display Message Missing
SSU 523767.02 — Resume Switch Circuits Conflict
SSU 523767.09 — Resume Switch Message Missing
SSU 523795.02 — Electro-Hydraulic Steering Valve Work Port Conne
SSU 523795.11 — Electro-Hydraulic Steering Valve Deadband Incons
SSU 523795.12 — Electro-Hydraulic Steering Valve Fault
SSU 523795.13 — Steering System Control Unit (SSU) Calibration F
SSU 523810.00 — Electro-Hydraulic Steering Valve Supply Voltage
SSU 523810.01 — Electro-Hydraulic Steering Valve Supply Voltage
SSU 523821.02 — Vehicle Mismatch
SSU 523824.03 — Steering Wheel Position Sensor 2 Supply Voltage
SSU 523824.04 — Steering Wheel Position Sensor 2 Supply Voltage
SSU 523824.05 — Steering Wheel Position Sensor 2 Circuit Current
SSU 523824.06 — Steering Wheel Position Sensor 2 Circuit Current
SSU 523824.10 — Steering Wheel Position Sensor 2 Signal Mismatch
SSU 523824.14 — Steering Wheel Position Sensor 2 Signal Fault
SSU 523826.00 — Wheel Angle Sensor-Axle (Primary) Signal High
SSU 523826.01 — Wheel Angle Sensor-Axle (Primary) Signal Low
SSU 523826.02 — SSU Calibration Fault / Wheel Angle Sensor-Axle
SSU 523826.07 — Wheel Angle Sensor-Axle (Primary) Fault / No Ste
SSU 523826.10 — WAS-Axle (Primary) Fault / Steered Motion Detect
SSU 523826.12 — Wheel Angle Sensor-Axle Voltage Oscillation
SSU 523826.13 — Wheel Angle Sensor-Axle Not Calibrated
SSU 523826.14 — WAS-Axle (Primary) Fault / Steering Wheel Motion
SSU 524221.09 — Vehicle Yaw Rate Message Missing
SUP Code Diagnostics
SUP 000628.12 — SUP Programming
SUP 000629.12 — SUP Control Unit Fault
SUP 524013.03 — SUP Switch Fault
TEC Code Diagnostics
TEC 000628.12 — Tractor Equipment Control Unit (TEC) Programming
TEC 000629.12 — Tractor Equipment Control Unit (TEC) Fault
TEC 000630.02 — Tractor Equipment Control Unit (TEC) Calibration
TEC 522550.14 — ISO Compliant and Non-ISO Compliant Devices on I
VLC Code Diagnostics
VLC 000628.02 — Vehicle Load Center (VLC) End Of Line Data Fault
VLC 000628.12 — Vehicle Load Center (VLC) Programming
VLC 000629.11 — Vehicle Load Center (VLC) Control Unit Fault
VLC 000629.12 — Vehicle Load Center (VLC) Control Unit Fault
VLC 001542.04 — Vehicle Load Center (VLC) Control Unit Wake-Up S
VLC 001550.05 — A/C Compressor Clutch Circuit Current Low
VLC 001550.06 — A/C Compressor Clutch Circuit Current High
VLC 002030.06 — Vehicle Load Center (VLC) Circuit Current High
VLC 002050.09 — Cab Load Center (CLC) Control Unit Message Missi
VLC 002348.05 — High Beam Lights Circuit Current Low
VLC 002348.06 — High Beam Lights Circuit Current High
VLC 002350.05 — Low Beam Lights Circuit Current Low
VLC 002350.06 — Low Beam Lights Circuit Current High
VLC 002354.05 — Front Outer Flood Lights Circuit Current Low
VLC 002354.06 — Front Outer Flood Lights Circuit Current High
VLC 002356.05 — Front Inner Flood Lights Circuit Current Low
VLC 002356.06 — Front Inner Flood Lights Circuit Current High
VLC 522310.06 — ELX Output 2 Circuit Current High
VLC 522311.05 — Rear Washer Pump Circuit Current Low
VLC 522311.06 — Rear Washer Pump Circuit Current High
VLC 522312.05 — Front Washer Pump Circuit Current Low
VLC 522312.06 — Front Washer Pump Circuit Current High
VLC 522620.05 — Horn Circuit Current Low
VLC 522620.06 — Horn Circuit Current High
OBSERVABLE SYMPTOMS
ACU
ACU System - Armrest Control Unit (ACU) System Power and Ground
ACU System - Transmission Enable Circuit Diagnostics
ACU System - Hand Throttle Position Sensor Diagnostics
ACU System - IMS Sequence Switch Diagnostics
ACU System - Rear Hitch Control Lever Sensor Diagnostics
ACU System - Rear PTO Switch Diagnostics
ACU System - SCV I Control Lever Sensor Diagnostics
ACU System - SCV II Control Lever Sensor Diagnostics
ACU System - SCV III Control Lever Sensor Diagnostics
ACU System - SCV IV Control Lever Sensor Diagnostics
ACU System - Set Speed Position Sensor Assembly Diagnostics
ACU System - Speed Control Lever Sensor Diagnostics
ACU System - Resume Switch Circuit Diagnostics
ACU System - AutoPowr™/IVT™ Right Hand Reverser Switch Assembly
ACU System - Operator Hand Presence Switch Circuit Diagnostics
ACU System - Transport Lock Switch Circuit Diagnostics
ACU System - Auxiliary Switches Circuit Diagnostics
ACU System - Left/Right Single Lever Control Sensor Circuit Diag
ACU System - Fore/Aft Single Lever Control Sensor Circuit Diagno
ACU System - AutoPowr™/IVT™ Speed Band Sensor Assembly Circuit D
ACU System - Range Lever Park Switch Diagnostics
ACU System - ACU-Up/Down Shift Switch Diagnostics
ACU System - ACU-Up/Down Auto Resume Lever Diagnostics
ASU
ASU System - Accelerometer Sensor Diagnostics
ASU System - Active Seat Unit (ASU) System Power and Ground Diag
ASU System - Air Compressor Assembly Diagnostics
ASU System - Bleed (Vent) Valve Solenoid Diagnostics
ASU System - Firmness Adjustment Switch Diagnostics
ASU System - Height Control Switch Diagnostics
ASU System - Operator's Presence (Seat) Switch Diagnostics
ASU System - Position Sensor Diagnostics
ASU System - Pressure Reducing Valve Solenoid Diagnostics
ASU System - Raise/Lower Valve Solenoid Diagnostics
ATC
ATC System - Air Flow Mode Motor Diagnostics
ATC System - Ambient Temperature Sensor Diagnostics
ATC System - Circulation Blower Motor Diagnostics
ATC System - Automatic Temperature Control Unit (ATC) System Pow
ATC System - Blower Motor Driver Diagnostics
ATC System - Cab Temperature Sensor Diagnostics
ATC System - Evaporator Temperature Sensor Diagnostics
ATC System - Outlet Air Temperature Sensor Diagnostics
ATC System - Pressurizer Blower Motor Diagnostics
ATC System - Refrigerant Pressure Sensor Diagnostics
ATC System - Water Valve Motor Diagnostics
BRC
BRC System - Brake Control Unit (BRC) System Power and Ground Ci
BRC System - Brake Control Unit (BRC) Sensor Supply Power and Gr
BRC System - Front Brake Pressure Sensor Diagnostics
BRC System - Rear Brake Pressure Sensor Diagnostics
BRC System - Secondary Brake Pressure Sensor Diagnostics
BRC System - Secondary Brake Control Valve Circuit Diagnostic
CAB
CAB System - A/C Switch Diagnostics
CAB System - Brake Pedal Sensor Module Circuit Diagnostics
CAB System - CAB Control Unit System Power and Ground Circuit Di
CAB System - Clutch Pedal Position Sensor Circuit Diagnostics
CAB System - Foot Throttle Position Sensor Circuit Diagnostics
CAB System - Implement Switch Circuit Diagnostics
CAB System - Left Hand Reverser Switch Circuit Diagnostics
CAB System - Operator Presence Switch Circuit Diagnostics
CAB System - Rear Differential Lock Switch Circuit Diagnostics
CAB System - Rear PTO External (Fender) Switch Circuit Diagnosti
CAB System - Secondary Hand Brake Sensor & Switch Circuit Diagno
CCU
CCU System - Air Brake Pressure Switch Diagnostics
CCU System - Air Filter Restriction Sensor Diagnostics
CCU System - Back Up Alarm Diagnostics
CCU System - Chassis Control Unit (CCU) System Power and Ground
CCU System - Fuel Level Sensor Diagnostics
CCU System - Hydraulic Oil Temperature Sensor Diagnostics
CCU System - Hydraulic Pump Filter Restriction Switch Diagnostic
CCU System - MFWD Solenoid Diagnostics
CCU System - Radar Sensor Diagnostics
CCU System - Rear Differential Lock Solenoid Diagnostics
CCU System - Rear PTO Oil Temperature Sensor Diagnostics
CCU System - Rear PTO Shaft Selector Switch Diagnostics
CCU System - Rear PTO Solenoid Diagnostics
CCU System - Rear PTO Speed Sensor Diagnostics
CCU System - Rear PTO Switch On Signal Diagnostics
CCU System - Transmission Pump Pressure Sensor Diagnostics
CLC
CLC System - AutoPowr™/IVT™ Transmission Mode Select Switch Diag
CLC System - Brake Light Diagnostics
CLC System - Cab Load Center (CLC) Current Diagnostics
CLC System - Cab Load Center (CLC) ELX Output 1 Diagnostics
CLC System - Cab Load Center (CLC) ELX Wake Up Output Diagnostic
CLC System - Cab Load Center (CLC) Sensor Supply Voltage Diagnos
CLC System - Cab Load Center (CLC) System Power and Ground Diagn
CLC System - Field Light Switch Diagnostics
CLC System - Front Cab Roof Inner Flood Light Diagnostics
CLC System - Front Cab Roof Outer Flood Light Diagnostics
CLC System - Front Wiper Motor Diagnostics
CLC System - Front Wiper Switch Diagnostics
CLC System - Hazard Light Switch Diagnostics
CLC System - Left Extremity & Clearance Light Diagnostics
CLC System - Left Fender Turn Signal Light Diagnostics
CLC System - Left Roof Warning Light Diagnostics
CLC System - Left Tail Light Diagnostics
CLC System - Left/Right Mid Body Flood Light Diagnostics
CLC System - Left/Right Rear Fender Flood Light Diagnostics
CLC System - Left/Right Rear Roof Flood Light Diagnostics
CLC System - Left/Right Side Roof Flood Light Diagnostics
CLC System - MFWD Selection Switch Diagnostics
CLC System - Rear License Plate Flood Light Diagnostics
CLC System - Rear PTO Remote Enable (Preselector) Switch Diagnos
CLC System - Rear Wiper Motor Diagnostics
CLC System - Rear Wiper Switch Diagnostics
CLC System - Right Extremity & Clearance Light Diagnostics
CLC System - Right Fender Turn Signal Light Diagnostics
CLC System - Right Roof Warning Light Diagnostics
CLC System - Right Tail Light Diagnostics
CLC System - Road Light Switch Diagnostics
CLC System - Trailer Flood Light Diagnostics
ECU
ECU System — Electronically Controlled Viscous Clutch Drive Oper
ECU System — Electronically Controlled Viscous Clutch Drive, Spe
ECU System — Engine Control Unit System Power and Ground Diagnos
HCU
HCU System - Hitch Control Unit (HCU) System Power and Ground Ci
HCU System - Option Configuration Connector
HCU System - Rear Hitch Control Lever Sensor Diagnostics
HCU System - Rear Hitch Draft Sensor Diagnostics
HCU System - Rear Hitch Left External Switch Diagnostics
HCU System - Rear Hitch Lower Solenoid Diagnostics
HCU System - Rear Hitch Position Sensor Diagnostics
HCU System - Rear Hitch Raise Solenoid Diagnostics
HCU System - Rear Hitch Right External Switch Diagnostics
ICU
ICU System - Codes After Adding/Removing Control Units
ICU System - CommandCenter™ (ICU) Display Unreadable
ICU System - CommandCenter™ (ICU) Power and Ground Circuit Diagn
PTF
PTF System - Front PTO Control Unit (PTF) System Power and Groun
PTF System - Front PTO Oil Temperature Sensor Diagnostics
PTF System - Front PTO Solenoid Diagnostics
PTF System - Front PTO Speed Sensor Diagnostics
PTF System - Front PTO Switch Diagnostics (AutoPowr™/IVT™)
PTF System - Front PTO Switch Diagnostics (PowrQuad PLUS™/AutoQu
PTI
PTI System - Power Train Control Unit (PTI) System Power and Gro
PTI System - Trailer Air Brake Solenoid Diagnostics
PTI System - Carrier Speed Sensor Diagnostics
PTI System - Clutch Enable Pressure Sensor Diagnostics
PTI System - Clutch Enable Solenoid Diagnostics
PTI System - Diagnostic (Hydraulic) Pressure Sensor Diagnostics
PTI System - High Clutch Solenoid Diagnostics
PTI System - Hydro Fixed Unit Speed Sensor Diagnostics
PTI System - Hydro Control Diagnostics
PTI System - Hydro Control Solenoid Diagnostics
PTI System - Low Clutch Solenoid Diagnostics
PTI System - MFWD Speed Sensor Diagnostics
PTI System - Park Brake Pressure Sensor Diagnostics
PTI System - Park Brake Supply Solenoid Diagnostics
PTI System - Park Sump Block Solenoid Diagnostics
PTI System - Primary Transmission Speed Sensor Diagnostics
PTI System - Reverse Brake Solenoid Diagnostics
PTI System - Secondary Transmission Speed Sensor Diagnostics
PTI System - Transmission Enable Circuit Diagnostics
PTI System - Transmission Pump Pressure Sensor Diagnostics
PTQ
PTQ System - Power Train Control Unit (PTQ) System Power and Gro
PTQ System - Trailer Air Brake Solenoid Diagnostics
PTQ System - Clutch Enable Pressure Sensor Diagnostics
PTQ System - Clutch Enable Solenoid Diagnostics
PTQ System - Forward Solenoid Diagnostics
PTQ System - Four-Speed Solenoid 1 Diagnostics
PTQ System - Four-Speed Solenoid 2 Diagnostics
PTQ System - Reverse Solenoid Diagnostics
PTQ System - Top Shaft Speed Sensor Diagnostics
PTQ System - Transmission Enable Circuit Diagnostics
PTQ System - Transmission Filter Restriction Switch Diagnostics
PTQ System - Transmission Pump Pressure Sensor Diagnostics
PTQ System - Wheel Speed Sensor Diagnostics
SCO
SCO System - Auxiliary Extend Solenoid Diagnostics
SCO System - Auxiliary Retract Solenoid Diagnostics
SCO System - Front Hitch External Switch Diagnostics
SCO System - SCO System Power and Ground Circuit Diagnostics
SCO System - SCV V Directional Control Solenoid Circuit Diagnost
SCO System - SCV V Flow Control Solenoid Circuit Diagnostics
SCO System - SCV VI Directional Solenoid Circuit Diagnostics
SCO System - SCV VI Flow Control Solenoid Circuit Diagnostics
SCU
SCU System - Option Connector Diagnostics
SCU System - SCU System Power and Ground Diagnostics
SCU System - SCU Sensor Power and Ground Diagnostics
SCU System - SCV I Directional Solenoid Diagnostics
SCU System - SCV I Flow Solenoid Diagnostics
SCU System - SCV II Directional Solenoid Diagnostics
SCU System -SCV II Flow Control Solenoid Circuit Diagnostics
SCU System - SCV III Directional Solenoid Circuit Diagnostics
SCU System -SCV III Flow Control Solenoid Diagnostics
SCU System - SCV IV Directional Solenoid Diagnostics
SCU System - SCV IV Flow Control Solenoid Diagnostics
SFA
SFA System - Front Axle Raise Solenoid Diagnostics
SFA System - Front Axle Raise/Lower Solenoid Diagnostics
SFA System - Front Axle Position Sensor Circuit Diagnostics
SFA System - Suspension and Front Axle Control Unit (SFA) Sensor
SUP
SUP System - Set-Up Panel Control Unit (SUP) System Power and Gr
SSU
SSU System - Electro-Hydraulic Steering Valve Diagnostics
SSU System - Steering System Unit (SSU) System Power and Ground
SSU System - Steering Wheel Position Sensor 1 Diagnostics
SSU System - Steering Wheel Position Sensor 2 Diagnostics
SSU System - Wheel Angle Sensor Diagnostics
SSU System - Vehicle Weaves Back & Forth Across AutoTrac™ A/B Li
TEC
TEC System - Tractor Equipment Control (TEC) Unit Power Relay Ou
TEC System - Tractor Equipment Control Unit (TEC) System Power a
VLC
VLC System - Air Conditioner Compressor Clutch Diagnostics
VLC System - Front Washer Pump Diagnostics
VLC System - Horn Diagnostics
VLC System - Left High/Low Beam Head Light Diagnostics
VLC System - Left Front Inner Flood Light Diagnostics
VLC System - Left Front Outer Flood Light Diagnostics
VLC System - Rear Washer Pump Diagnostics
VLC System - Right High/Low Beam Head Light Diagnostics
VLC System - Right Front Inner Flood Light Diagnostics
VLC System - Right Front Outer Flood Light Diagnostics
VLC System - Vehicle Load Center (VLC) ELX Output 2 Diagnostics
VLC System - Vehicle Load Center (VLC) System Power and Ground D
Auxiliary Power Strip Circuit Diagnostics
Battery Inspection Diagnostics
Business Band-CB Radio Circuit Diagnostics
Charging System Diagnostics
Controller Area Network (CAN) Diagnostics
Control Unit System Diagnostics
Convenience Outlet #1 Circuit Diagnostics
Convenience Outlet #2 Circuit Diagnostics
Dome Light Switch Circuit Diagnostics
Electronic and Control Unit Diagnostics
Heated Seat System Diagnostics
High-Low Beam Head Light Switch Circuit Diagnostics
Horn Switch Circuit Diagnostics
Left Door Switch Circuit Diagnostics
Left Junction Block Circuit Diagnostics
Lighter Circuit Diagnostics
Lighting System Diagnostics
Manual HVAC Circulation Blower Motor Circuit Diagnostics
Manual HVAC Pressurized Blower Motor Circuit Diagnostics
Manual Seat Compressor Assembly Circuit Diagnostics
Manual Seat Diode Circuit Diagnostics
Manual Seat Height Control Switch Circuit Diagnostics
Manual Seat Operator's Presence (Seat) Switch Circuit Diagnostic
Programming Control Units Failed Diagnostics
Programming Multiple Control Units Diagnostics
Radar Speed Sensor Circuit Diagnostics
Remote Mirror Adjustment Motor Circuit Diagnostics
Remote Mirror Adjustment Switch Circuit Diagnostics
Right Door Switch Circuit Diagnostics
Right Hand Console Inverter and Panel Backlighting Diagnostics
Right Hand Console Switch Backlighting Diagnostics
Right Junction Block Circuit Diagnostics
Rotary Beacon Light Circuit Diagnostics
Starting System Diagnostics
Steering Column Module Diagnostics
Turn Signal Switch Circuit Diagnostics
AutoPowr™ / IVT™ Transmissions
AutoPowr™ / IVT™ Park Brake Pump-Off Problem
Hydraulic Oil Gets Hot
Engine Stalls When Going Into Gear
Vehicle Does Not Move
Vehicle Moves With MFWD Engaged Only
PowrQuad PLUS™ and AutoQuad PLUS™ Transmissions
Operator Shift Controls Do Not Respond
Missing Speeds Or Ranges
Poor Or No Modulation
Hard Range Lever Shifting
Clutch Problems
Drive Systems
Differential Lock, MFWD and Rear PTO Problems
Front PTO Not Operational
Front PTO Disengages Unexpectedly at Start-Up
Rear PTO Disengages Unexpectedly at Start-Up
Suspended Front Axle Floats or Hunts for Center
Steering and Brakes
AutoTrac System Accuracy Unacceptable
Loss of Power Steering and Brakes
Steering Capacity Low or Stalls Under Load
Front Wheels Wander Or Drift
Intermittent Drag When Turning Steering Wheel
Steering Is Slow, Sluggish, Or Hard To Turn With Vehicle Moving
Hydraulics
Selective Control Valve - Auxiliary Valve Problem
Selective Control Valve - EH SCV's Not Functioning or Erratic
Selective Control Valve - Loader Hoses Come Out of Mid Mount SCV
Operator Station
A/C - Not Cooling Adequately
A/C - Dust In Cab
A/C - Heating Inadequate
A/C - Low or No Airflow From Air Ducts
SYSTEM DIAGNOSIS
Electrical System Diagnosis
Control Unit System Diagnosis
European Lighting System Diagnosis
North American Lighting System Diagnosis
Radar System Diagnosis
Starting and Charging System Diagnosis
CAN System Diagnosis
AutoPowr / IVTIVT is a trademark of Deere & Company™ TRANSMISSIO
AutoPowr™ / IVT™ Transmission Diagnosis
PowrQuad PLUS™ and AutoQuad PLUS™ Transmission System Diagnosis
Drive Systems
Differential Lock System Diagnosis
MFWD System Diagnosis
Front PTO System Diagnosis
Rear PTO System Diagnosis
Suspended Front Axle System Diagnosis
Steering and Brakes
Brakes - Trailer Air Brake System Diagnosis European
Brakes - Trailer Air Brake System Diagnosis North American
Brakes - Front Brake System Diagnosis
Brakes - Hydraulic Trailer Brake System Diagnosis
Brakes - Rear Brake System Diagnosis
Steering - AutoTrac™ System Diagnosis
Steering - Steering System Diagnosis
Hydraulic System Diagnosis
Mid-Stack Mechanical SCV System Diagnosis
Operator Station
A/C - ATC System Diagnosis
A/C - Manual HVAC System Diagnosis
Seat - ActiveSeat™ System Diagnosis
Seat - Heated Seat System Diagnosis
Seat - Manual Seat System Diagnosis
ENGINES
Engine Performance
Performance Testing
Performance Variables
Torque and Power Curve Explanation and Interpretation
Engine Cooling System
Electronically Controlled Viscous Clutch Drive Theory Of Operati
Engine Cooling System Theory
FUEL AND AIR INTAKE SYSTEMS
Engine Fuel System
Engine Fuel System Theory of Operation
Engine Air Intake and Exhaust System
Engine Air Intake and Exhaust System Theory of Operation
ELECTRICAL
Load Center Fuses, Relays & Ground Points
Load Center Panel—Fuses
Load Center Panel—Relays
Ground Point Locations
Operational Checks
Programmable Lighting Operational Check
Tests and Adjustments
Mechanical Mid-stack Grapple Circuit Test
Functional Schematics and Components Reference List
Functional Schematics Reference List
Electrical/Electronic Component Identification List
Connector Information
X009—Battery Power Junction Block (W006, W007, W012, W300, W501,
X010—ServiceAdvisor™ Connector (SE8) (W900)
X010R—Circuit 010 Splice Connector 2 (W300, W501, W502, W503)
X011—ServiceAdvisor™ Interconnect (SE8) (W300, W501, W502, W503,
X050A—Circuit 050 Splice Connector 1 (W300, W501, W502, W503)
X050B—Circuit 050 Splice Connector 3 (W300, W501, W502, W503)
X050C—Circuit 050 Splice Connector (W305, W306, W307, W308)
X100—Rear Cab Interconnect (W305, W306, W307, W308, W300, W501,
X101—Cab to Steering Column Module Harness Interconnect (SE5) (W
X104—Chassis to Hood Flood Light Harness Interconnect (W100, W15
X105—Chassis to Hood Hi/Lo Light Harness Interconnect (W100, W15
X106—Right Cab to Tail Light Harness (W102, W501, W503) (Eur Onl
X107—Left Cab to RII Tail Light Harness (W102, W501, W503) (Eur
X110—Cab-to-Outer-Roof Interconnect (W300, W501, W502, W503, W92
X111—Cab-to-License Plate Harness (W160, W501, W503) (Eur Only)
X113—Hood to Hi/Lo Grille Lights Harness Interconnect (W103, W15
X132—Left Extremity Light Interconnect (SE6B) (W300, W502)
X133—Right Extremity Light Interconnect (SE6B) (W300, W502)
X134—Left Extremity Light Interconnect (SE6C) (W501, W503) (Eur
X135—Right Extremity Light Interconnect (SE6C) (W501, W503) (Eur
X170—Cab to Front Roof Inner & Outer Flood Light Harness Interco
X171—Cab to Beacon Light Harness Interconnect (SE4) (W104, W300,
X171A—Cab to Dual Power Mirror Harness Interconnect (SE4) (W106,
X171B—Dual Power Mirror to Beacon Light Harness Interconnect (SE
X172—Circuit 172 Splice Connector 4 (W300, W501, W502, W503)
X173—Beacon Light Harness to Beacon Light Interconnect (SE4) (W1
X186—Panel Backlighting Inverter Harness Connector (W186, W900)
X187—Switch Back Lighting Interconnect (W300, W501, W502, W503,
X201—Chassis to Radar Harness Connector (SE11A) (W200, W305, W30
X210—Cab to A/C Interconnect (SE3) (W220, W210, W300, W501, W502
X220—Cab to ATC Interconnect (SE3) (W220, W300, W501, W502, W503
X221—Cab to ATC CAN Interconnect (SE3) (W220, W900)
X244—Cab to Convenience Outlet Interconnect (SE7) (W005, W014, W
X249—Cab to Convenience Outlet Interconnect (W008, W009, W015)
X301—Cab to RHR Neutral Start Switch Interconnect (SE1) (W502, W
X302—Chassis to Electronically Controlled Viscous Clutch Harness
X402—Chassis to Engine Injector Harness Interconnect (SE16) (W30
X501— Chassis Harness to Transmission Harness (SE11) (W305, W306
X502—Chassis Harness to Transmission Harness (SE11) (W305, W306,
X503—Chassis to Air Brake Pressure Harness Interconnect (SE11A)
X505—Transmission to Back-Up Alarm Harness Interconnect (SE11A)
X570—Cab to Main Armrest Control Unit Harness Interconnect (SE13
X601—Cab to Operator Control Harness Interconnect (SE10) (W300,
X701—Cab to PTF - Front PTO/Front Hitch Harness Interconnect (SE
X702—Cab Harness to Front PTO Switch Harness Interconnect (SE19)
X703—Cab Harness to Front PTO Switch Harness Interconnect (SE19)
X704—Chassis to Rear Brake Pressure Harness Interconnect (SE14D)
X721—Chassis to Draft Sensor Interconnect (SE14A) (W721, W722)
X770—Chassis to SCO - Mid Stack Harness Interconnect (SE15) (W30
X772—Cab to Single Lever Control Interconnect (SE10C, SE13) (W50
X801—Front External Hitch Switch Extension Harness Interconnect
X807—Chassis Harness to Hitch Switch Jumper Harness (W300, W501,
X808—Chassis Harness to SCV II & SCV III (SE14A, SE14B) (W307, W
X809—Chassis Harness to Hitch & SCV I (SE14B) (W307, W308, W875)
X810—Chassis Harness to SCV IV (SE14B) (W307, W308, W873)
X812—Cab to Hitch with Manual SCVs Harness (W300, W501, W722)
X813—Chassis to Draft/Hitch Position Sensor Harness (SE14A) (W30
X830—Cab to Dual Hitch Switch Harness Interconnect (SE14A) (W300
X870—SCO - Mid Stack to SCV V/SCV VI Harness Interconnect (SE15)
X871—SCO - Mid Stack to Grapple Valve Harness Interconnect (SE15
X900—Cab to Driver Information 1 Interconnect (W300, W501, W502,
X901—Cab to Driver Information 2 Interconnect (W300, W501, W502,
X902—Chassis to SSU (AutoTrac™) Harness (SE20) (W305, W306, W307
X907—Cab to Display Interconnect (SE18) (W300, W501, W502, W503)
X908-1—Outer Roof to GPS Receiver Interconnect (SE18) (W920)
X911A—CAN Tractor Active Terminator Connector (SE8) (W900)
X911B—CAN Active Terminator Interconnect (SE8) (W900, W901)
X912A—CAN Tractor Passive Terminator Connector (SE8) (W573, W574
X912B—CAN Tractor Passive Terminator Interconnect (SE8) (W573, W
X913—CAN Implement Active Terminator Connector (SE18) (W300, W50
X914—CAN Implement Passive Terminator Connector (SE18) (W920)
X915A—Cab Implement Connector (2 pin) (SE18) (W300, W501, W502 ,
X915B—Cab Implement Connector (2 pin) (SE18) (W300, W501, W502 ,
X916A—Cab Implement Connector (4 pin) (SE18) (W300, W501, W502 ,
X916B—Cab Implement Connector (4 pin) (SE18) (W300, W501, W502 ,
X918—Cab to Outer Roof Harness Interconnect (Implement CAN) (SE1
X920—Wheel Speed Signal Connector (SE11A) (W300, W501, W502, W50
X920A—Wheel Speed Signal Connector (SE11A) (W300, W501, W502, W5
X920B—Wheel Speed Signal Connector (SE11A) (W300, W501, W502, W5
X922—ISO Interconnect (SE18) (W300, W501, W502, W503)
X925—JDLink™ Interconnect (SE17)
X930—Seat to Cab Interconnect (SE2) (W300, W501, W502, W503, W93
X930A—Cab to Heated Seat Power Harness Interconnect (SE10E) (W50
X930B—Heated Seat Power to Active Seat Upper Harness Interconnec
X940—4- Way Lower Active Seat to Cab Interconnect (SE10E) (W300,
X941—8-Way Upper Active Seat to Cab Interconnect (SE10E) (W300,
X942—6-Way Upper Active Seat to Cab Interconnect (SE10E) (W300,
X943—Heated Seat Control Unit to Switch Harness Interconnect (SE
X944—Heated Seat Power to Controller Harness Interconnect (SE10E
X951—Circuit 951 Splice Connector 6 (W300, W501, W502, W503)
X953—Circuit 953 Splice Connector 5 (W300, W501, W502, W503)
X981—SSU (AutoTrac™) to Wheel Angle Sensor Harness Interconnect
X982—Chassis Harness to Steering Wheel Position Sensor Harness (
Harness Information
W1—Single Point Ground (W011, W013, W305, W306, W307, W308)
W2—Chassis Ground (W013 W305, W306, W307, W308)
W3—A/C compressor Clutch Ground (W305, W306, W307, W308)
W5—Cab Floor Ground (W210, W220, W300, W501, W502, W503)
W6—Vehicle Chassis Ground
W7—Cab Roof Ground
W005—Right Convenience Outlet Harness (NA only)
W006—VLC Power Cable
W007—CLC Power Cable
W008—Left Convenience Outlet Harness (NA only)
W009—Left Convenience Outlet Harness (Eur only)
W010—Positive Battery Cable
W011—Negative Battery Cable
W012—Cab Power Cable
W013—Cab Ground Cable
W014—Right Convenience Outlet Harness (Eur only)
W015—Field Office Harness
W016—Auxiliary Power Strip
W100—Hood Lights Harness (NA Only)
W102—Tail Lights Harness (Eur Only)
W103—Driving Light Extension Harness (Eur and HID/Xenon)
W104—Beacon Light Harness
W105—Beacon Light Extension Harness
W106—Dual Power Mirror Harness
W107—Extremity Light Harness (NA Only)
W108—Extremity Light Harness (Eur Only)
W110—Steering Column Module Harness
W158—Hood Light Harness (HID/Xenon)
W159—Hood Light Harness (Eur Only)
W160—License Plate Light Harness (Eur Only)
W170—Front Roof Inner & Outer Flood Light Harness
W186—Panel Backlighting Inverter Harness
W200—Radar Extension Harness
W201—Back-Up Alarm Harness
W210—Manual HVAC Harness
W220—ATC HVAC Harness
W305—Chassis Harness with Manual SCVs
W306—Chassis Harness with Manual SCVs, Front Brake, and ILS
W307—Chassis Harness with EH SCVs
W308—Chassis Harness with EH SCVs, Front Brake, and ILS
W401—Electronically Controlled Viscous Clutch Harness
W402—Engine Injector Harness
W403—Glow Plug Harness
W300—Cab Harness (PowrQuad PLUS™/AutoQuad PLUS™) (NA Only)
W501—Cab Harness (PowrQuad PLUS™/AutoQuad PLUS™) (Eur Only)
W502—Cab Harness (AutoPowr™/IVT™) (NA Only)
W503—Cab Harness (AutoPowr™/IVT™) (Eur Only)
W504— Air Brake Pressure Switch Harness
W570—Main Armrest Control Unit Harness (14 Pin)
W571—Standard Armrest Control Unit Harness (20 Pin)
W572—Single Lever Control Assembly Harness (22 Pin)
W573—Transmission Harness (PowrQuad PLUS™/AutoQuad PLUS™)
W574—Transmission Harness (AutoPowr™/IVT™)
W575—Right Hand Reverser Armrest Control Unit Harness (22 Pin) (
W577—Left Hand Reverser Armrest Control Unit Harness (22 Pin) (A
W602—Operator Control Harness with Manual SCVs (PowrQuad PLUS™/A
W603—Operator Controls Harness with EH SCVs (PowrQuad PLUS™/Auto
W700—SSU Harness (AutoTrac™)
W702—Front PTO Switch Harness (AutoPowr™/IVT™ Only)
W703—Rear Brake Pressure Switch Harness
W704—Rear Brake Pressure/Secondary Brake Harness (Eur Only)
W721—Draft Sensor Extension Harness
W722—Hitch with Manual SCVs Harness
W723—Draft/Hitch Position Sensor Harness
W801—SCO - Mid Stack Harness
W805—Dual Hitch Switch Harness
W870—Front Hitch Switch Extension Harness
W871—PTF - Front PTO/Front Hitch Harness
W872—Auxiliary Solenoid Harness
W873—SCV IV Solenoid Harness
W874—SCV II/SCV III Solenoid Harness
W875—Hitch/SCV I Solenoid Harness
W876—SCV V/SCV VI Solenoid Harness
W900—Right Hand Console Harness
W901—JDLink™ Cab Harness
W902—JDLink™ Control Unit Harness
W920—Outer Roof Harness
W922—ISO Cornerpost Harness
W930—Air Seat Harness
W940—Active Seat Upper Harness
W941—Heated Seat Control Unit Harness
W942—Active Seat Lower Harness
W943—Heated Seat Switch Harness
W944—Heated Seat Power Harness
W945—Heated Seat Power Harness (XXXXX - )
W946—Heated Seat Switch Harness (XXXXX - )
W947—Heated Seat Heater Element Harness (XXXXX - )
W992—Steering Wheel Position Sensor Harness (AutoTrac™)
W993—Wheel Angle Sensor Harness (AutoTrac™)
SE01 — Power Supply, Starting, & Charging
Power Supply, Starting and Charging Reference List
Power Supply, Starting and Charging Schematic and Circuit Diagra
Battery Inspection Test
Charging System Circuit Test
Starting System Circuit Test
F001—Master Fuse (SE1) (W012, W305, W306, W307)
G001—Battery (SE1) (W010, W011)
G002—Battery (SE1) (W010, W011)
G301—Alternator (SE1) (W012, W305, W306, W307, W308)
K301—Starter Relay (SE1) (W305, W306, W307, W308)
M301—Starter Motor (SE1)
S001—Key Switch (SE1) (W305, W306, W307, W308)
S301—Neutral Start Switch (SE1) (W570, W575)
V1—Alternator Diode (SE1) (W305, W306, W307, W308)
SE02 — Manual Seat
Standard Seat Reference List
Standard Seat Schematic and Circuit Diagram
Standard Seat Height Control Switch Circuit Test
Standard Seat Compressor Assembly Circuit Test
Standard Seat Diode Circuit Test
Heated Seat Supply Voltage and Ground Circuit Test
Heated Seat Switch Circuit Test
Heated Seat Switch Circuit Test (XXXXX-)
Heated Seat Heating Element Circuit Test
Heated Seat Heating Element Circuit Test (XXXXX-)
A942—Heated Seat Control Unit (SE2) (W941)
A943X1—Heated Seat Heating Elements Connector (SE2) (W947)
A943X4—Heated Seat Power Connector (SE2) (W945)
A943X5—Heated Seat Switch Connector (SE2) (W946)
E946—Seat Heating Element (SE2) (W941)
E947—Backrest Heating Element (SE2) (W941) (W947)
M092—Air Seat Compressor Motor (SE2) (W930)
S930—Operator Presence Switch (SE2) (SE10) (W930, W940)
S931—Standard Seat Switch (SE2) (W930)
S943—Heated Seat Switch (SE2) (W943)
S944—Heated Seat Switch (XXXXX-) (SE2) (W946)
V3—Standard Seat Diode (SE2) (W930)
SE03 — Manual AC & Automatic Temperature Control (ATC)
Manual AC and Automatic Temperature Control Unit (ATC) Reference
Manual AC and Automatic Temperature Control Unit (ATC) Schematic
ATC-Automatic Temperature Control Unit (ATC) System Power and Gr
ATC-Air Flow Mode Motor Circuit Test
ATC-Ambient Temperature Sensor Circuit Test
ATC-Blower Motor Driver Circuit Test
ATC-Cab Temperature Sensor Circuit Test
ATC-Circulation Blower Motor Circuit Test
ATC-Evaporator Temperature Sensor Circuit Test
ATC-Outlet Air Temperature Sensor Circuit Test
ATC-Pressurizer Blower Motor Circuit Test
ATC-Refrigerant Pressure Sensor Circuit Test
ATC-Water Valve Motor Circuit Test
Manual-HVAC Circulation Blower Motor Circuit Test
Manual-HVAC Pressurizer Blower Motor Circuit Test
A220—Automatic Temperature Control Unit (ATC) (SE3) (W220)
A220X1—Automatic Temperature Control Unit (ATC) Connector (SE03)
A221—Blower Motor Driver (SE3) (W220)
B220—Cab Temperature Sensor (SE3) (W220)
B221—Evaporator Temperature Sensor (SE3) (W220)
B222—Ambient Temperature Sensor (SE3) (W920)
B223—Outlet Air Temperature Sensor (SE3) (W220)
B224—Refrigerant Pressure Sensor (SE3) (W220)
KA1—Manual HVAC Circulation Blower Motor Relay (SE3) (W210)
M210—Manual HVAC Circulation Blower Motor (SE3) (W210)
M211—Pressurizer Blower Motor (SE3) (W300, W501, W502, W503)
M220—ATC Circulation Blower Motor (SE3) (W220)
R210—Blower Motor Resistor (SE3) (W210)
S210—Blower Motor Switch (SE3) (W210)
Y220—Air Flow Mode Motor (SE3) (W300, W501, W502, W503)
Y221—Water Valve Motor (SE3) (W220)
SE04 — Remote Mirror Option
Remote Mirror Option—Beacon Light Reference List
Remote Mirror Option—Beacon Light Schematic and Circuit Diagram
Remote Mirror Adjustment Motor Circuit Test
Remote Mirror Adjustment Switch Circuit Test
Beacon Light Circuit Test
E105—Beacon Light (SE4) (W105)
H110—Roof Beacon Indicator (SE4) (W104)
M950—Right Mirror Adjustment Motor (SE4) (W106)
M951—Left Mirror Adjustment Motor (SE4) (W106)
S106—Beacon Light Switch (SE4) (W104)
S951—Mirror Adjustment Switch (SE4) (W106)
SE05 — Radio, Dome Lamp, & Steering Column Module
Radio, Dome Lamp and Multi-Function Switch Reference List
Radio, Dome Lamp and Multi-Function Switch Schematic and Circuit
Steering Column Module Circuit Test
Steering Column Module-Turn Signal Switch Circuit Test
Steering Column Module-High / Low Beam Light Switch Circuit Test
Steering Column Module-Horn Switch Circuit Test
Dome Lamp Circuit Test
Dome Lamp Switch Circuit Test
Left Hand Door Switch Circuit Test
Right Hand Door Switch Circuit Test
Radio Circuit Test
A100 — Steering Column Indicator Lights (SE5) (W110)
A101 — Steering Column Turn/Horn/HiLo Switches (SE5) (W110)
A240 — Radio / Clock (SE5) (W300, W501, W502, W503)
B240 — Right Front Speaker (SE5) (W920)
B241 — Left Front Speaker (SE5) (W920)
B242 — Right Rear Speaker (SE5) (W920)
B243 — Left Rear Speaker (SE5) (W920)
C240 — Radio Antenna (SE5)
E100 — Dome Lamp (SE5) (W300, W501, W502, W503)
E101 — RH Console Lamp (SE5) (W300, W501, W502, W503)
E102 — Left Entry Light (W920)
H100 — Right Turn Indicator (SE5) (W110)
H101 — Left Turn Indicator (SE5) (W110)
H102 — Hazard Lights Indicator (SE5) (W110)
H103 — Tractor Indicator (SE5) (W110)
H104 — Trailer 1 Indicator (SE5) (W110)
H105 — Trailer 2 Indicator (SE5) (W110)
H107 — High Beam Indicator (SE5) (W110)
S103 — Right Hand Door Switch (SE5) (W300, W501, W502, W503)
S104 — Dome Lamp Switch (SE5) (W300, W501, W502, W503)
S105 — LH Door Switch (SE5) (W300, W502, W503)
SE06 - Implement Gateway Control Unit (CLC and TEC)
Implement Gateway Control Unit (CLC, TEC and Lighting) Reference
Implement Gateway Control Unit (CLC, TEC and Lighting) Schematic
A922—Implement Gateway Control Unit (CLC, TEC) (SE6) (W300, W501
A922-1—Cab Load Center Control Unit (CLC) and Tractor Equipment
A922-2—CLC-North American Lighting (SE6A) (W300, W502)
A922-3—CLC-European Lighting (SE6B) (W501, W503)
A922X1—CLC, TEC, TEI Connector (SE6) (W300, W501, W502, W503)
A922X2—CLC, TEC, TEI Connector (SE6) (W300, W501, W502, W503)
A922X3—CLC, TEC, TEI Connector (SE6) (W300, W502, W503)
A922X4—CLC, TEC, TEI Connector (SE6) (W007)
E103—Right Fender Turn Signal Light (SE6B) (W300, W502)
E104—Left Fender Turn Signal Light (SE6B) (W300, W502)
E130—Right Tail/Brake Light (SE6B) (W300, W502)
E131—Left Tail/Brake Light (SE6B) (W300, W502)
E132—Left Front Roof Warning Light (SE6B, SE6C) (W920)
E133—Right Rear Roof Warning Light (SE6B) (W920)
E134—Left Rear Roof Warning Light (SE6B) (W920)
E135—Right Front Roof Warning Light (SE6B, SE6C) (W920)
E136—Left Extremity Transport Light (SE6B, SE6C) (W107, W108)
E137—Right Extremity Transport Light (SE6B, SE6C) (W107, W108)
E160—Right Front Clearance Light (SE6C) (W501, W503)
E161—Left Front Clearance Light (SE6C) (W501, W503)
E162—Right Extremity Clearance Light (SE6C) (W108)
E163—Left Extremity Clearance Light (SE6C) (W108)
E164—Rear License Plate Light (SE6C) (W160)
E165—Right Tail/Brake Light (SE6C) (W102)
E166—Left Tail/Brake Light (SE6C) (W102)
E167—Left Rear Fender Warning Light (SE6C) (W102)
E168—Right Rear Fender Warning Light (SE6C) (W102)
E170—Front Roof Right Outer Flood Light (SE6C) (W170)
E171—Front Roof Right Inner Flood Light (SE6A) (W170)
E172—Front Roof Left Inner Flood Light (SE6A) (W170)
E173—Front Roof Left Outer Flood Light (SE6C) (W170)
E174—Right Loader Flood Light (SE6A) (W170)
E175—Left Loader Flood Light (SE6A) (W170)
E180—Left Rear Roof Flood Light (SE6A) (W920)
E181—Left Side Roof Flood Light (SE6A) (W920)
E182—Left Mid Body Flood Light (SE6A) (W300, W501, W502, W503)
E183—Left Rear Fender Flood Light (SE6A) (W300, W501, W502, W503
E184—Right Rear Roof Flood Light (SE6A) (W920)
E185—Right Mid Body Flood Light (SE6A) (W300, W501, W502, W503)
E186—Right Rear Fender Flood Light (SE6A) (W300, W501, W502, W50
E187—Right Side Roof Flood Light (SE6A) (W920)
KR1—Loader Light Relay (SE6A) (W170)
KR2—High/Low Head Light Relay (SE6A) (W170)
KR3—Front Cab Roof Inner Flood Light Relay (SE6A) (W170)
KR4—Front Cab Roof Outer Flood Light Relay (SE6C) (W170)
M240—Front Wiper Motor (SE6A) (W920)
M241—Rear Wiper Motor (SE6A) (W920)
S100—Road Light Switch (SE6A) (W900)
S101—Hazard Light Switch (SE6A) (W900)
S121—Field Light Switch (SE6C) (W900) (Eur Only)
S241—Front Wiper Switch (SE6A) (W900)
S242—Rear Wiper Switch (SE6A) (W900)
S271—Rear PTO Preselect Switch (SE6A) (W900)
S571—AutoPowr/IVT Selector Switch (SE6A) (W502, W503)
S573—MFWD Assist (SE6A) (W900)
X130—Trailer Lighting and Accessory Connector (SE6B) (W300,W502)
X160—Trailer Lighting and Accessory Connector (SE6C) (W501, W503
X161—Trailer Flood Light Connector (SE6C) (W503) (Eur Only)
SE06A — CLC Control Unit and TEC Control Unit
Cab Load Center (CLC) / Tractor Equipment Control Unit (TEC) Sch
Cab Load Center (CLC) Control Unit, Current Circuit Test
Cab Load Center (CLC) Control Unit, ELX Output 1 Circuit Test
Cab Load Center (CLC) Control Unit, ELX Wake Up Output Circuit T
Cab Load Center (CLC) Control Unit, Sensor Supply Voltage Circui
Cab Load Center (CLC) Control Unit, System Power and Ground Circ
CLC-Field Light Switch Circuit Test
CLC-Front Roof Inner Flood Light Circuit Test
CLC-Front Roof Outer Flood Light Circuit Test
CLC-Front Wiper Motor Circuit Test
CLC-Front Wiper Switch Circuit Test
CLC-Hazard Light Switch Circuit Test
CLC - AutoPowr™/IVT™ Selector Switch Circuit Test
CLC-Left/Right Mid-Body Flood Light Circuit Test
CLC-Left/Right Rear Fender Flood Light Circuit Test
CLC-Left/Right Rear Roof Flood Light Circuit Test
CLC-Left/Right Side Roof Flood Light Circuit Test
CLC-Loader Flood Light Circuit Test
CLC-MFWD Selection Switch Circuit Test
CLC-Rear PTO Preselector Switch Circuit Test
CLC-Rear Wiper Motor Circuit Test
CLC-Rear Wiper Switch Circuit Test
CLC-Right Hand Console Switch Backlighting Circuit Test
CLC-Road Light Switch Circuit Test
CLC-Trailer Brake Circuit Test
CLC-Trailer Flood Light Circuit Test
CLC-Hand Clutch Circuit Test
Tractor Equipment Control Unit (TEC) System Power and Ground Cir
Tractor Equipment Control Unit (TEC) Implement Connector Power R
SE06B — CLC - North American Lighting
CLC / North American Lighting Schematic and Diagram
CLC-Brake Light Circuit Test (NA Only)
CLC-Left Extremity Light Circuit Test (NA Only)
CLC-Left Fender Turn Signal Circuit Test (NA Only)
CLC-Left Roof Warning Light Circuit Test (NA Only)
CLC-Left Tail Light Circuit Test (NA Only)
CLC-Right Extremity Light Circuit Test (NA Only)
CLC-Right Fender Turn Signal Circuit Test (NA Only)
CLC-Right Roof Warning Light Circuit Test (NA Only)
CLC-Right Tail Light Circuit Test (NA Only)
SE06C — CLC - European Lighting
CLC / European Lighting Schematic and Diagram
CLC-Brake Light Circuit Test (EUR Only)
CLC-Left Extremity Light Circuit Test (EUR Only)
CLC-Left Front Warning Light Circuit Test (EUR Only)
CLC-Left Rear Fender Turn Signal Light Circuit Test (EUR Only)
CLC-Left Tail Light Circuit Test (EUR Only)
CLC-Rear License Plate Light Circuit Test (EUR Only)
CLC-Right Extremity Light Circuit Test (EUR Only)
CLC-Right Front Warning Light Circuit Test (EUR Only)
CLC-Right Rear Fender Turn Signal Light Circuit Test (EUR Only)
CLC-Right Tail Light Circuit Test (EUR Only)
SE07 — Accessory Connectors
Accessory Connectors Reference List
Accessory Connectors Schematic and Circuit Diagram
Left Junction Block Circuit Test
Right Junction Block Circuit Test
Auxiliary Power Strip Circuit Test
Lighter Circuit Test
Convenience Outlet #1 Circuit Test
Convenience Outlet #2 Circuit Test
Business Band/CB Radio Prewire
X240—Left Junction Block (SE7) (W015, W300, W501, W502, W503)
X241—Right Junction Block (SE7) (W248, W300, W501, W502, W503, W
X242—Convenience Outlet #1 (SE7) (W005) (NA Only)
X243—Convenience Outlet #2 (SE7) (W008) (NA Only)
X245—Lighter #1 (SE7) (W900)
X246—Lighter #2 (SE7) (W015)
X247—Lighter #3 (SE7) (W015)
X248—Auxiliary Power Strip (SE7) (W016)
X250—Convenience Outlet #2 (SE7) (W009) (Eur Only)
X251—Convenience Outlet #1 (SE7) (W014) (Eur Only)
X910—Business Band / CB Connector (SE7)
SE08 — Controller Area Network (CAN) Termination
CAN Termination Reference List
CAN Termination Schematic and Circuit Diagram
CAN Communication System Diagnostic Wiring Diagrams
CAN System Diagnostic Wiring Diagram - Cab Harnesses
CAN System Diagnostic Wiring Diagram - Engine and Chassis Harnes
CAN Circuit Interconnections and Splice Locations
CAN Communication Fault Checks
CAN Communication System Theory Of Operation
CAN Network Voltage Checks
A911—CAN Active Terminator (SE8) (W900)
A912—CAN Tractor Passive Terminator (SE8) (W573, W574, W700, W80
SE09 — Corner Post Display, ICU, SUP
Corner Post Display, ICU - Information Display, and SCV - Setup
ICU-CommandCenter™ System Power and Ground Circuit Test
Right Hand Console Inverter And Panel Backlighting Circuit Test
SUP-Setup Panel Control Unit Power and Ground Circuit Test
A186—Inverter Backlighting (SE9) (W900)
A901—Information Center Control Unit (ICU) (CommandCenter™) (SE9
A901X1—ICU Connector (SE9) (W900)
A902—SCV Setup Panel Control Unit (SUP) (SE9) (W900)
A902X1—SUP Connector (SE9) (W900)
A903—Corner Post Display (SE9) (W300, W501, W502, W503)
E190—IVT Selector Switch Backlighting Panel (SE09) (W186)
E191—Manual A/C Temperature and Fan Speed Switch Backlighting Pa
E192—Road Light Switch and Front Wiper Switch Backlighting Panel
H200—Warning Horn (SE9) (W900)
SE10 — Cab Controller (CAB, ASU, & ACU/HCU [AQ+/PQ+ Only])
CAB Control Unit (CAB, ASU, & ACU/HCU [AutoQuad PLUS™/PowrQuad P
CAB Control Unit (CAB, ASU, & ACU/HCU for AutoQuad PLUS™/PowrQua
A110 — Cab Controller (CAB & ASU, AutoQuad PLUS™/PowrQuad PLUS™
A110-1 — CAB Control Unit (CAB) (SE10A)
A110-2 — AutoPowr™/IVT™ & PowrQuad PLUS™/AutoQuad PLUS™ Function
A110-3 — Armrest Control Unit (ACU) Functions (PowrQuad PLUS™/Au
A110-4 — Hitch Control Unit (HCU) & SCV Control Unit (SCU) Funct
A110-5 — Active Seat Control Unit (ASU) (SE10E)
A110X1 — CAB, ASU Connector (SE10) (W300, W501, W502, W503)
A110X2 — CAB, ASU Connector (SE10) (W300, W501, W502, W503)
A110X3 — CAB, ASU Connector (SE10) (W300, W501, W502, W503)
A574 — Left Hand Reverser (SE10B) (W300, W501, W502, W503)
A577 — Foot Throttle Sensor (SE10B) (W300, W501, W502, W503)
A601 — Up/Down Auto Resume Lever (SE10C) (W602, W603) (PowrQuad
A602 — Hand Clutch Switch (SE10C) (W602, W603) (PowrQuad PLUS™/A
A773 — Single Lever Control Assembly (SE10C, SE13) (W572)
A921 — Brake Pedal Sensor Module (SE10B) (W300, W501, W502, W503
A940 — Active Seat Compressor Assembly (SE10E) (W940)
B301 — Hand Throttle Position Sensor (SE10C) (W602, W603) (PowrQ
B513 — Clutch Pedal Position Sensor (SE10A) (W300, W501, W502, W
B715 — Secondary Brake Switch (Eur Only) (SE10A) (W900)
B940 — Seat Accelerometer Sensor (SE10E) (W940)
B941 — Seat Position Sensor (SE10E) (W940)
E946 — Heated Seat Elements (W941)
K940 — Active Seat Compressor Relay (SE10E) (W940)
R705 — SCV I Control Lever Sensor (SE10D) (W602, W603) (PowrQuad
R706 — SCV II Control Lever Sensor (SE10D) (W602, W603) (PowrQua
R707 — SCV III Control Lever Sensor (SE10D) (W602, W603) (PowrQu
R708 — SCV IV Control Lever Sensor (SE10D) (W602, W603) (PowrQua
R802 — Rear Hitch Control Lever Sensor (SE10D) (W602, W603) (Pow
S211 — A/C On / Off Switch (SE10A) (W210)
S212 — A/C De-icing Switch (SE10A) (W210)
S213 — A/C Dual Pressure Switch (SE10A) (W210)
S215 — A/C De-icing Switch (SE10A) (W210)
S240 — Implement Switch (SE10A) (W300, W501, W502, W503)
S502 — Rear PTO Switch (SE10C) (W602, W603) (PowrQuad PLUS™/Auto
S503 — Differential Lock Switch (SE10A) (W300, W501, W502, W503)
S508 — IMS Sequence Switch (SE10C) (W602, W603) (PowrQuad PLUS™/
S511 — AutoShift Resume Switch (SE10C) (W300, W501) (PowrQuad PL
S512 — Up/Down Shift Switch (SE10C) (W602, W603) (PowrQuad PLUS™
S513 — Range Lever Park Switch (SE10C) (W602, W603) (PowrQuad PL
S515 — Transport Lock Switch (SE10C, SE13) (W572)
S574 — Rear PTO External Switch (Eur Only) (SE10A) (W501, W503)
S930 — Operator Presence Switch (SE2, SE10E) (W930, W940)
S941 — Active Seat Height Control Switch (SE10E) (W940)
S942 — Active Seat Firmness Control Switch (SE10E) (W940)
S943 — Heated Seat Switch (SE10E) (W943)
X270—Option Configuration Connector (SE10D, SE14) (W307, W308, W
Y941 — Active Seat Raise / Lower Solenoid (SE10E) (W942)
Y942 — Active Seat Flow Control Solenoid (SE10E) (W942)
SE10A — CAB Control Unit Common Functions
CAB Control Unit Common Functions Schematic & Diagram
CAB Control Unit Sensor Supply Voltage Circuit Test
CAB Control Unit System Power and Ground Circuit Test
CAB-A/C Switch Circuit Test
CAB-Clutch Pedal Position Sensor Circuit Test
CAB-Differential Lock Switch Circuit Test
CAB-Implement Switch Circuit Test
CAB-Operator Presence Switch Circuit Test
CAB-Rear PTO External Switch Circuit Test
CAB-Secondary Brake Sensor & Switch Circuit Test
SE10B — CAB - AutoPowr™/IVT™ and PowrQuad PLUS™/AutoQuad PLUS™ F
CAB - AutoPowr™/IVT™ and PowrQuad PLUS™/AutoQuad PLUS™ Functions
CAB-Brake Pedal Sensor Module Circuit Test
CAB-Foot Throttle Position Sensor Circuit Test
CAB-Left Hand Reverser Circuit Test
SE10C — CAB - Functions of ACU (AQ+/PQ+ Only)
Armrest Control Unit (ACU ) Reference List
Armrest Control Unit (ACU) Functions Schematic and Diagram (Auto
ACU- Auxiliary Switches Circuit Test (AutoQuad PLUS™/PowrQuad PL
ACU-Fore/Aft Single Lever Control Sensor Circuit Test (PowrQuad
ACU-Hand Throttle Position Sensor Circuit Test (PowrQuad PLUS™/A
ACU-IMS Sequence Switch Circuit Test (PowrQuad PLUS™/AutoQuad PL
ACU-Left/Right Single Lever Control Sensor Circuit Test (PowrQua
ACU-Operator Hand Presence Switch Circuit Test (PowrQuad PLUS™/A
ACU-Range Lever Park Switch Circuit Test (PowrQuad PLUS™/AutoQua
ACU-Rear Hitch Control Lever Sensor Circuit Test (PowrQuad PLUS™
ACU-Rear PTO Switch Circuit Test (PowrQuad PLUS™/AutoQuad PLUS™)
ACU-Resume Switch Circuit Test (PowrQuad PLUS™/AutoQuad PLUS™)
ACU-SCV I Control Lever Sensor Circuit Test (PowrQuad PLUS™/Auto
ACU-SCV II Control Lever Sensor Circuit Test (PowrQuad PLUS™/Aut
ACU-SCV III Control Lever Sensor Circuit Test (PowrQuad PLUS™/Au
ACU-SCV IV Control Lever Sensor Circuit Test (PowrQuad PLUS™/Aut
ACU-Transport Lock Switch Circuit Test (PowrQuad PLUS™/AutoQuad
ACU-Up/Down Shift Switch Circuit Test (PowrQuad PLUS™/AutoQuad P
ACU-Up/Down Auto Resume Lever Circuit Test (AutoQuad PLUS™)
ACU-Hand Clutch Switch (PowrQuad PLUS™/AutoQuad PLUS™)
SE10D — CAB - Rear Hitch Control Unit (HCU) Functions (PowrQuad
Hitch Control Unit (HCU) References
Hitch Control Unit Schematic and Circuit Diagram (HCU) (PowrQuad
HCU-Hitch Control Unit System Power and Ground Circuit Test (Pow
HCU-Hitch Control Unit Sensor Power and Ground Circuit Test (Pow
HCU-Rear Hitch Left or Frame Mounted External Switch Circuit Tes
HCU-Rear Hitch Right External Switch Circuit Test (PowrQuad PLUS
HCU-Rear Hitch Position Sensor Circuit Test (PowrQuad PLUS/AutoQ
HCU-Rear Hitch Draft Sensor Circuit Test (PowrQuad PLUS/AutoQuad
HCU-Rear Hitch Raise Solenoid Circuit Test (PowrQuad PLUS/AutoQu
HCU-Rear Hitch Lower Solenoid Circuit Test (PowrQuad PLUS/AutoQu
HCU-Option Configuration Connector Test (PowrQuad PLUS/AutoQuad
SE10E — CAB - ActiveSeat™ Control Unit (ASU) Functions
ActiveSeat™ Control Unit (ASU), Functional Schematics & Diagrams
ASU-ActiveSeat™ Unit (ASU), Supply Voltage and Ground Circuit Te
ASU-Pressure Reducing Valve Solenoid Circuit Test
ASU-Raise / Lower Valve Solenoid Circuit Test
ASU-Bleed (Vent) Valve Solenoid Circuit Test
ASU-Accelerometer Sensor Circuit Test
ASU-Position Sensor Circuit Test
ASU-Firmness Adjustment Switch Circuit Test
ASU-Height Control Switch Circuit Test
ASU-Air Compressor Assembly Circuit Test
SE 11 - Vehicle Control Unit (CCU, VLC, PTI/PTQ)
Vehicle Control Unit (CCU, VLC, & PTI or PTQ) Reference List
Vehicle Control Unit (CCU, VLC, PTI or PTQ) Schematics and Diagr
A210—A/C Compressor Clutch (SE11) (W305, W306, W307, W308)
A570—Vehicle Controller (SE11) (CCU, VLC, PTI/PTQ) (W573, W574)
A570-1—Chassis Control Unit (CCU) (SE11A) (W573, W574)
A570-2—Vehicle Load Center Control Unit (VLC) (SE11B) (W573, W57
A570-3—AutoPowr™/IVT™ Transmission Control Unit (PTI) (SE11C) (W
A570-4—PowrQuad PLUS™/AutoQuad PLUS™ Transmission Control Unit (
A570X1—VLC, CCU, PTI or PTQ Connector (SE11) (W573, W574)
A570X2—VLC, CCU, PTI or PTQ Connector (SE11) (W573, W574)
A570X3—VLC, CCU, PTI or PTQ Connector (SE11) (W573, W574)
A570X4—VLC, CCU, PTI or PTQ Connector (SE11) (W006)
B303—Fuel Level Sensor (SE11A) (W305, W306, W307, W308)
B300—Wheel Speed Sensor (2 Connector) (SE11D) (W573) (PowrQuad P
B501— Rear PTO Speed Sensor (SE11A) (W573, W574)
B510—Transmission Pump Pressure Sensor (SE11C, SE11D) (W573, W57
B511—Park Brake Pressure Sensor (SE11C) (W574)
B526—Diagnostic Pressure Sensor (SE11C) (W574)
B570—MFWD Speed Sensor (SE11C) (W574)
B571—Carrier Speed Sensor (SE11C) (W574) (AutoPowr™/IVT™ Only)
B572—Hydro Fixed Unit Speed Sensor (SE11C) (W574) (AutoPowr™/IVT
B573—Rear PTO Oil Temperature Sensor (SE11A) (W573, W574)
B574—Secondary Transmission Speed Sensor (SE11C) (W574) (AutoPow
B575—Primary Transmission Speed Sensor (SE11C) (W574) (AutoPowr™
B576—Top Shaft Speed Sensor (SE11D) (W573) (PowrQuad PLUS™/AutoQ
B670—Clutch Enable Pressure Sensor (SE11C) (W574) (AutoPowr™/IVT
B671—Enable Pressure Sensor (SE11D) (W573) (PowrQuad PLUS™/AutoQ
B700—Hydraulic Oil Temperature Sensor (SE11A) (W573, W574)
B920—Horn (SE11B) (W100, W158, W159)
E140—Left Hi/Lo Light (SE11B) (W100) (NA Only)
E141—Right Hi/Lo Light (SE11B) (W100) (NA Only)
E142—Left Outer Hood Flood Light (SE11B) (W100, W159)
E143—Right Outer Hood Flood Light (SE11B) (W100, W159)
E144—Left Inner Hood Flood Light (SE11B) (W159) (Eur Only)
E145—Right Inner Hood Flood Light (SE11B) (W159) (Eur Only)
E146—Left Outer Hood HID/Xenon Light (SE11B) (W158)
E147—Right Inner Hood HID/Xenon Light (SE11B) (W158)
E148—Left Inner Hood HID/Xenon Light (SE11B) (W158)
E149—Right Outer Hood HID/Xenon Light (SE11B) (W158)
E150—Left Hi/Lo Grille Light (SE11B) (W103)
E151—Right Hi/Lo Grille Light (SE11B) (W103)
H201—Backup Alarm (SE11A) (W201)
M242—Rear Washer Pump (SE11B) (W305, W306, W307, W308
M243—Front Washer Pump (SE11B) (W305, W306, W307, W308)
S510—Transmission Filter Restriction Switch (SE11D) (W573) (Powr
S570—Rear PTO Shaft Select Switch (SE11A) (W573, W574)
S710—Hydraulic Pump Filter Restriction Switch (SE11A) (W573, W57
S922—Air Brake Pressure Switch (SE11A) (W504)
V2—A/C Compressor Clutch Diode (SE11B) (W300, W301, W303)
Y300—Rear PTO Solenoid (SE11C, SE11D) (W573, W574)
Y501—MFWD Solenoid (SE11C, SE11D) (W573, W574)
Y502—Rear Differential Lock Solenoid (SE11C, SE11D) (W573, W574)
Y503—Enable Solenoid (SE11C) (W574) (AutoPowr™/IVT™ Only)
Y515—Air Trailer Brake Solenoid (SE11C, SE11D) (W573, W574)
Y571—Hydro Control Solenoid (SE11C) (W574) (AutoPowr™/IVT™ Only)
Y572—High Clutch Solenoid (SE11C) (W574) (AutoPowr™/IVT™ Only)
Y573— Low Clutch Solenoid (SE11C) (W574) (AutoPowr™/IVT™ Only)
Y574—Reverse Brake Solenoid (SE11C) (W574) (AutoPowr™/IVT™ Only)
Y575—Park Brake Supply Solenoid (SE11C) (W574) (AutoPowr™/IVT™ O
Y576—Park Sump Block Solenoid (SE11C) (W574) (AutoPowr™/IVT™ Onl
Y670—Enable Solenoid (SE11D) (W573) (PowrQuad PLUS™/AutoQuad PLU
Y671—Forward Solenoid (SE11D) (W573) (PowrQuad PLUS™/AutoQuad PL
Y672—Reverse Solenoid (SE11D) (W573) (PowrQuad PLUS™/AutoQuad PL
Y673—Four-Speed Solenoid 1 (SE11D) (W573) (PowrQuad PLUS™/AutoQu
Y674—Four-Speed Solenoid 2 (SE11D) (W573) (PowrQuad PLUS™/AutoQu
SE11A — PTI/PTQ - Chassis Control Unit (CCU) Functions
Chassis Control Unit (CCU), Functional Schematics & Diagrams
Chassis Control Unit (CCU), Sensor Supply Voltage Circuit Test
Chassis Control Unit (CCU) System Power and Ground Circuit Test
CCU-Air Brake Pressure Switch Circuit Test
CCU-Air Filter Restriction Sensor Circuit Test
CCU-Backup Alarm Circuit Test
CCU-Fuel Level Sensor Circuit Test
CCU-Hydraulic Oil Temperature Sensor Circuit Test
CCU-Hydraulic Pump Filter Restriction Sensor Circuit Test
CCU-MFWD Solenoid Circuit Test
CCU-Rear Differential Lock Solenoid Circuit Test
CCU-Rear PTO Oil Temperature Sensor Circuit Test
CCU-Rear PTO Shaft Selector Switch Circuit Test
CCU-Rear PTO Solenoid Circuit Test
CCU-Rear PTO Speed Sensor Circuit Test
CCU-Transmission Pump Pressure Sensor Circuit Test
SE11B — PTI/PTQ - Vehicle Load Center (VLC) Control Unit Functio
Vehicle Load Center (VLC) Control Unit, Schematics & Diagrams
Vehicle Load Center (VLC) Control Unit System Power and Ground T
VLC-Air Conditioner Compressor Clutch Circuit Test
VLC-ELX Output 2 Circuit Test
VLC-Front Washer Pump Circuit Test
VLC-Rear Washer Pump Circuit Test
VLC-Horn Circuit Test
VLC-Left Front Inner Flood Light Circuit Test
VLC-Right Front Inner Flood Light Circuit Test
VLC-Left Front Outer Flood Light Circuit Test
VLC-Right Front Outer Flood Light Circuit Test
VLC-Left High/Low Beam Head Lights Circuit Test
VLC-Right High/Low Beam Head Lights Circuit Test
SE11C — PTI
Power Train Control Unit (PTI) Schematics & Diagrams
Power Train Control Unit (PTI) System Power and Ground Circuit T
PTI-Air Trailer Brake Solenoid Circuit Test
PTI-Carrier Speed Sensor Circuit Test
PTI-Clutch Enable Pressure Sensor Circuit Test
PTI-Clutch Enable Solenoid Circuit Test
PTI-Diagnostic (Hydraulic) Pressure Sensor Circuit Test
PTI-High Clutch Solenoid Circuit Test
PTI-Hydro Fixed Unit Speed Sensor Circuit Test
PTI-Hydro Control Solenoid Circuit Test
PTI-Low Clutch Solenoid Circuit Test
PTI-MFWD Speed Sensor Circuit Test
PTI-Park Brake Pressure Sensor Circuit Test
PTI-Park Brake Supply Solenoid Circuit Test
PTI-Park Sump Block Solenoid Circuit Test
PTI-Primary Transmission Speed Sensor Circuit Test
PTI-Reverse Brake Solenoid Circuit Test
PTI-Secondary Transmission Speed Sensor Circuit Test
PTI-Transmission Enable Circuit Test
PTI-Transmission Pump Pressure Sensor Circuit Test
PTI-Hydro Control Test
SE11D — Power Train AutoQuad PLUS™/PowrQuad PLUS™ Control Unit (
Power Train Control Unit (PTQ) Schematics and Diagrams
Power Train Control Unit (PTQ) System Power and Ground Circuit T
PTQ-Trailer Air Brake Solenoid Circuit Test
PTQ-Clutch Enable Pressure Sensor Circuit Test
PTQ-Clutch Enable Solenoid Circuit Test
PTQ-Forward Solenoid Circuit Test
PTQ-Four-Speed Solenoid 1 Circuit Test
PTQ-Four-Speed Solenoid 2 Circuit Test
PTQ-Reverse Solenoid Circuit Test
PTQ-Top Shaft Speed Sensor Circuit Test
PTQ-Transmission Enable Circuit Test
PTQ-Transmission Filter Restriction Switch Circuit Test
PTQ-Transmission Pump Pressure Sensor Circuit Test
PTQ-Wheel Speed Sensor Circuit Test
SE13 — ACU
Armrest Control Unit (ACU) Schematic and Circuit Diagram
ACU-Armrest Control Unit System Power and Ground Circuit Test
ACU-Armrest Control Unit Sensor Power 1 Circuit Test
ACU-Armrest Control Unit Sensor Power 2 Circuit Test
ACU-Auxiliary Switches Circuit Test (AutoPowr™/IVT™)
ACU-Fore/Aft Single Lever Control Sensor Circuit Test (AutoPowr™
ACU-Hand Throttle Position Sensor Circuit Test (AutoPowr™/IVT™)
ACU-IMS Sequence Switch Circuit Test (AutoPowr™/IVT™)
ACU-Left/Right Single Lever Control Sensor Circuit Test (AutoPow
ACU-Operator Hand Presence Switch Circuit Test (AutoPowr™/IVT™)
ACU-Rear Hitch Control Lever Sensor Circuit Test (AutoPowr™/IVT™
ACU-Rear PTO Switch Circuit Test (AutoPowr™/IVT™)
ACU-Resume Switch Circuit Test (AutoPowr™/IVT™)
ACU-Right Hand Reverser Switch Assembly Circuit Test (AutoPowr™/
ACU-SCV I Control Lever Sensor Circuit Test (AutoPowr™/IVT™)
ACU-SCV II Control Lever Sensor Circuit Test (AutoPowr™/IVT™)
ACU-SCV III Control Lever Sensor Circuit Test (AutoPowr™/IVT™)
ACU-SCV IV Control Lever Sensor Circuit Test (AutoPowr™/IVT™)
ACU-Set Speed Slot Sensor Assembly Test (Left Hand Reverser) (Au
ACU-Set Speed Position Sensor Assembly Circuit Test (AutoPowr™/I
ACU-Speed Control Lever Sensor Circuit Test (AutoPowr™/IVT™)
ACU-Transmission Enable Circuit Test (AutoPowr™/IVT™)
ACU-Transport Lock Switch Circuit Test (AutoPowr™/IVT™)
A572 — Speed Control Lever Sensor (SE13) (W575, W577) (AutoPowr™
A573 — Set Speed Position Sensor (SE13) (W575, W577) (AutoPowr™/
A575 — Hand Throttle Position Sensor (SE13) (W571) (AutoPowr™/IV
A923 — Armrest Control Unit (ACU) (SE13) (W300, W502, W503, W570
A923X1 — ACU Connector (14 Pin) (SE13) (W570)
A923X2 — ACU Connector (20 Pin) (SE13) (W571)
A923X3 — ACU Connector (22 Pin) (SE13) (W575, W577)
A923X4 — ACU Connector (18 Pin) (SE13) (W572)
R700 — SCV I Control Lever Sensor (SE13) (W571) (AutoPowr™/IVT™
R701 — SCV II Control Lever Sensor (SE13) (W571) (AutoPowr™/IVT™
R702 — SCV III Control Lever Sensor (SE13) (W571) (AutoPowr™/IVT
R703 — SCV IV Control Lever Sensor (SE13) (W571) (AutoPowr™/IVT™
R800 — Rear Hitch Control Lever Sensor (SE13) (W571) (AutoPowr™/
S501 — Rear PTO Switch (SE13) (W571) (AutoPowr™/IVT™)
S509 — IMS Sequence Switch (SE13) (W571) (AutoPowr™/IVT™ Only)
S514 — Auto Resume Switch (SE13) (W575, W577)
SE14 - Deluxe Hydraulic Control Unit (HCU, SCU, SFA, BRC)
Deluxe Hydraulic Control Unit Reference List
Deluxe Hydraulic Control Unit Schematic and Circuit Diagram (HCU
A770—Deluxe Hydraulic Control Unit (HCU, SCU, SFA, BRC) (SE14) (
A770-1—Hitch Control Unit (HCU) (SE14A) (W306, W307, W308)
A770-2—Deluxe Hydraulic Control Unit (SCUB) (SE14) (W306, W307,
A770-3—Suspension and Front Axle Control Unit (SFA) (SE14C) (W30
A770-4—Brake Control Unit (BRC) (SE14D) (W306, W307, W308)
A770X1—HCU, SCU, SFA, BRC Connector (SE14) (W306, W307, W308)
A770X2—HCU, SCU, SFA, BRC Connector (SE14) (W306, W307, W308)
A770X3—HCU, SCU, SFA, BRC Connector (SE14) (W306, W307, W308)
B701—Front Axle Position Sensor (SE14C) (W306, W308)
B702—Front Brake Pressure Sensor (SE14D) (W308)
B703—Rear Brake Pressure Sensor (SE14D) (W703, W704)
B706—Secondary Brake Pressure Sensor (SE14D) (W704) (Eur Only)
B870—Rear Hitch Position Sensor (SE14A) (W722, W723)
B871—Rear Hitch Draft Sensor (SE14A) (W721, W723)
S830—Rear Hitch Left External Switch (SE14A) (W300, W501, W502,
S831—Rear Hitch Right External Switch (SE14A) (W501, W503, W805)
Y701—Secondary Brake Valve (SE14D) (W704) (Eur Only)
Y771—Front Brake Solenoid (SE14D) (W306, W308)
Y830—Rear Hitch Raise Solenoid (SE14A) (W722, W875)
Y831—Rear Hitch Lower Solenoid (SE14A) (W722, W875)
Y832—SCV I Directional Solenoid (SE14B) (W875)
Y833—SCV I Flow Control Solenoid (SE14B) (W875)
Y834—SCV II Directional Solenoid (SE14B) (W874)
Y835—SCV II Flow Control Solenoid (SE14B) (W874)
Y836—SCV III Directional Solenoid (SE14B) (W874)
Y837—SCV III Flow Control Solenoid (SE14B) (W874)
Y838—SCV IV Directional Solenoid (SE14B) (W873)
Y839—SCV IV Flow Control Solenoid (SE14B) (W873)
Y842—Front Axle Raise Solenoid (SE14C) (W306, W308)
Y843—Front Axle Lower Solenoid (SE14C) (W306, W308)
SE14A — HCU
Hitch Control Unit Schematic and Circuit Diagram (HCU) (AutoPowr
HCU-Hitch Control Unit System Power and Ground Circuit Test (Aut
HCU-Hitch Control Unit Sensor Power and Ground Circuit Test (Aut
HCU-Rear Hitch Right External Switch Circuit Test (AutoPowr™/IVT
HCU-Rear Hitch Position Sensor Circuit Test (AutoPowr™/IVT™)
HCU-Rear Hitch Draft Sensor Circuit Test (AutoPowr™/IVT™)
HCU-Rear Hitch Raise Solenoid Circuit Test (AutoPowr™/IVT™)
HCU-Rear Hitch Lower Solenoid Circuit Test (AutoPowr™/IVT™)
SE14B — SCU
Selective Control Unit Schematic and Circuit Diagram (SCU)
SCU-Selective Control Unit System Power and Ground Circuit Test
SCU-Selective Control Unit Sensor Power and Ground Circuit Test
SCU-SCV I Directional Control Solenoid Circuit Test
SCU-SCV I Flow Control Solenoid Circuit Test
SCU-SCV II Directional Control Solenoid Circuit Test
SCU-SCV II Flow Control Solenoid Circuit Test
SCU-SCV III Directional Control Solenoid Circuit Test
SCU-SCV III Flow Control Solenoid Circuit Test
SCU-SCV IV Directional Control Solenoid Circuit Test
SCU-SCV IV Flow Control Solenoid Circuit Test
SCU-Option Configuration Connector Test
SE14C — SFA
Suspension and Front Axle Schematic and Circuit Diagram (SFA)
SFA-Suspension and Front Axle Control Unit Power and Ground Circ
SFA-Suspension and Front Axle Control Unit Sensor Power and Gro
SFA-Front Axle Position Sensor Circuit Test
SFA-Front Axle Raise Solenoid Circuit Test
SFA-Front Axle Raise-Lower Solenoid Circuit Test
SE14D — Brake System Control Unit (BRC)
Brake System Control Unit Schematic and Circuit Diagram (BRC)
BRC - Brake Control Unit System Power and Ground Circuit Test
BRC - Brake Control Unit Sensor Supply Power and Ground Circuit
BRC - Front Brake Solenoid Circuit Test
BRC - Rear Brake Pressure Sensor Circuit Test
BRC - Secondary Handbrake Control Valve Circuit Test
BRC - Secondary Handbrake Pressure Sensor Circuit Test
SE15 — SCO
Secondary Hydraulic Control Unit (SCO) Reference List
Secondary Hydraulic Control Unit (SCO) Schematic and Circuit Dia
SCO-Secondary Hydraulic Control Unit System Power and Ground Cir
SCO-SCV V Directional Control Solenoid Circuit Test
SCO-SCV V Flow Control Solenoid Circuit Test
SCO-SCV VI Directional Control Solenoid Circuit Test
SCO-SCV VI Flow Control Solenoid Circuit Test
SCO-Front Hitch External Switch Circuit Test
SCO-Auxiliary Valve Extend Solenoid Circuit Test
SCO-Auxiliary Valve Retract Solenoid Circuit Test
A772—Secondary Hydraulic Control Unit (SCO) (SE15) (W801)
A772X1—Sco Connector (SE15) (W801)
A772X2—Sco Connector (SE15) (W801)
A772X3—Sco Connector (SE15) (W801)
S870—Front Hitch External Raise/Lower Switch (SE15) (W870, W871)
Y840—SCV V Directional Solenoid (SE15) (W876)
Y841—SCV V Flow Control Solenoid (SE15) (W876)
Y870—SCV VI Directional Solenoid (SE15) (W876)
Y871—SCV VI Flow Control Solenoid (SE15) (W876)
Y872—Auxiliary Extend Solenoid (SE15) (W872)
Y873—Auxiliary Retract Solenoid (SE15) (W872)
SE16 — Engine Control Unit (ECU) Level 14
ECU Engine Control Unit Reference List
ECU Engine Control Unit Schematic and Circuit Diagram
ECU-Engine Control Unit System Power and Ground Circuit Test
Electronically Controlled Viscous Clutch Drive Operational Check
Electronically Controlled Viscous Clutch Drive Speed Control Sol
Electronically Controlled Viscous Clutch Drive Speed Sensor Test
A400 — Engine Control Unit (ECU) (SE16) (W305, W306, W307, W308)
A400X1 — ECU Connector (SE16) (W305, W306, W307, W308)
A400X2 — ECU Connector (SE16) (W305, W306, W307, W308)
A400X3 — ECU Connector (SE16) (W305, W306, W307, W308)
A401 — Electronically Controlled Viscous Clutch Drive Connector
A431 — Turbo Actuator (SE16) (W305, W306, W307, W308)
B307 — Air Filter Restriction Sensor (SE11) (W305, W306, W307, W
B400 — Fuel Temperature Sensor (SE16) (W305, W306, W307, W308)
B401 — Engine Coolant Temperature Sensor (SE16) (W305, W306, W30
B402 — Water-In-Fuel Sensor (SE16) (W305, W306, W307, W308)
B404 — Fuel Rail Pressure Sensor (SE16) (W305, W306, W307, W308)
B405 — Cam Position Sensor (SE16) (W305, W306, W307, W308)
B406 — Crank Position Sensor (SE16) (W305, W306, W307, W308)
B407 — Engine Oil Pressure Sensor (SE16) (W305, W306, W307, W308
B410 — Manifold Air Pressure Sensor (SE16) (W305, W306, W307, W3
B430 — Turbo Speed Sensor (SE16) (W305, W306, W307, W308)
B432 — Exhaust Temperature Sensor (SE16) (W305, W306, W307, W308
B433 — Fresh Air Temperature Sensor (SE16) (W305, W306, W307, W3
B434 — Manifold Air Temperature Sensor (SE16) (W305, W306, W307,
B435 — EGR Valve Position Sensor (SE16) (W305, W306, W307, W308)
B436 — Compressor Inlet Temperature Sensor (SE16) (W305, W306, W
B437 — Exhaust Pressure Sensor (SE16) (W305, W306, W307, W308)
K300 — Glow Plug Relay (SE16) (W305, W306, W307, W308)
K401 — Fuel Lift Pump Relay (SE16) (W305, W306, W307, W308)
K402 — Glow Plug Solenoid Relay (SE16) (W305, W306, W307, W308)
M430 — EGR Actuator (SE16) (W305, W306, W307, W308)
M431 — Fuel Transfer Pump (SE16) (W305, W306, W307, W308)
R400 — Cylinder #1 Glow Plug (SE16) (W403)
R401 — Cylinder #2 Glow Plug (SE16) (W403)
R402 — Cylinder #3 Glow Plug (SE16) (W403)
R403 — Cylinder #4 Glow Plug (SE16) (W403)
R404 — Cylinder #5 Glow Plug (SE16) (W403)
R405 — Cylinder #6 Glow Plug (SE16) (W403)
Y420 — Cylinder #1 Electronic Injector (SE16) (W402)
Y421 — Cylinder #2 Electronic Injector (SE16) (W402)
Y422 — Cylinder #3 Electronic Injector (SE16) (W402)
Y423 — Cylinder #4 Electronic Injector (SE16) (W402)
Y424 — Cylinder #5 Electronic Injector (SE16) (W402)
Y425 — Cylinder #6 Electronic Injector (SE16) (W402)
SE17 — JDLink™
JDLink™ Reference List
JDLink™ Schematic and Circuit Diagram
A904—JDLink™ Control Unit (SE17) (W901)
C910—GPS Antenna (SE17)
C910X1—JDLink™ GPS Antenna Connector (SE17)
C911—Cellular Antenna (SE17)
C911X1—JDLink™ Cellular Antenna Connector (SE17)
F69—JDLink™ Switched Power (SE17) (W901))
F70—JDLink™ Unswitched Power (SE17) (W901)
SE18 — GreenStar™ Display, Receiver, & Processor
Greenstar™ Display Reference List
Greenstar™ Display Schematic and Circuit Diagram
CCU-Radar Sensor Circuit Test
CCU-Wheel Speed Buffer Circuit Test
A906—Reconfigurable Display (SE18)
A907—GreenStar™ Display (SE18)
A908—GreenStar™ GPS Receiver (SE18) (W920)
A908X1—StarFire™ Receiver Connector (SE18) (W920)
A909—Mobile Processor (SE18) (W300, W501, W502, W503)
A909X1—Mobile Processor Connector (SE18)
A910—User Interface Module (SE18) (W300, W501, W502, W503)
A913—CAN Implement Active Terminator (SE18) (W300, W501, W502, W
A914—CAN Implement Passive Terminator (SE18) (W920)
A924—Terrain Compensation Module (TCM)
A924X1—TCM Connector
A925—Real Time Kinematic (RTK) Radio
A925X1—RTK Connector
B921—Radar Sensor (SE18) (W200)
X921—Implement Connector (SE18) (W300, W501, W502, W503)
X923—ISO Connector (W922)
SE19 — Power Take-Off Front Control Unit (PTF)
Front PTO Control Unit (PTF) Reference List
Front PTO Control Unit (PTF) Schematic and Circuit Diagram
PTF-Front PTO Control Unit System Power and Ground Circuit Test
PTF-Front PTO Oil Temperature Sensor Circuit Test
PTF-Front PTO Solenoid Circuit Test
PTF-Front PTO Speed Sensor Circuit Test
PTF-Front PTO Switch Circuit Test (AutoPowr™/IVT™)
PTF-Front PTO Switch Circuit Test (PowrQuad PLUS / AutoQuad PLUS
A571—Front PTO Control Unit (PTF) (SE19) (W871)
A571X1—PTF Connector (SE19) (W871)
A571X2—PTF Connector (SE19) (W871)
B770—Front PTO Speed Sensor (SE19) (W871)
B771—Front PTO Oil Temperature Sensor (SE19) (W871)
S572—Front PTO Switch (SE19) (W602, W603) (PowrQuad-Plus™/AutoQu
S575—Front PTO Switch (SE19) (W702) (AUTOPOWR™/IVT™ Only)
Y770—Front PTO Solenoid (SE19) (W871)
SE20 — SSU
Steering System Control Unit (SSU) Reference List
Steering System Control Unit (SSU) Schematic and Circuit Diagram
Steering System Control Unit (SSU) System Power and Ground Circu
SSU-Electro-Hydraulic Steering Valve Manual / Circuit Test
SSU-Steering Wheel Position Sensor 1 Circuit Test
SSU-Steering Wheel Position Sensor 1 Current Test
SSU-Steering Wheel Position Sensor 2 Circuit Test
SSU-Steering Wheel Position Sensor 2 Current Test
SSU-Wheel Angle Sensor Circuit Test
A980— Steering System Control Unit (SSU) (AutoTrac™) (SE20) (W70
A980X1—SSU Connector (SE20) (W700)
A980X2—SSU Connector (SE20) (W700)
A980X3—SSU Connector (SE20) (W700)
A982—Steering Input Device (SE20) (W992)
B957—Steering Wheel Position Sensor 1 (AutoTrac™) (SE20) (W992)
B958—Steering Wheel Position Sensor 2 (AutoTrac™) (W992)
B959—Wheel Angle Sensor (AutoTrac™) (SE20) (W993)
Y952—EH Steering Valve (AutoTrac™) (SE20) (W700)
CONTROL UNITS
General References
Access Control Unit Addresses
Control Unit Locations and Identification
Recall, Record, and Clear Codes
VIN Security Fault Diagnosis
ACU
Armrest Control Unit (ACU) Calibration
Armrest Control Unit (ACU) ”Beep” Mode Test
ACU Code List
ACU Address List
Armrest Control Unit Test
ASU
ActiveSeat™ Unit (ASU) Calibration
ActiveSeat™ Control Unit ”Beep” Mode Test
ASU Code List
ASU Address List
ActiveSeat™ Unit (ASU) Special Adjustment Addresses
ATC
Automatic Temperature Control Unit (ATC) Calibration
Automatic Temperature Control Unit (ATC) ”Beep” Mode Test
Automatic Temperature Control Unit (ATC) Code List
Automatic Temperature Control Unit (ATC) Address List
Automatic Temperature Control Unit Test
BRC
Brake Control Unit (BRC) Calibration
Brake Control Unit (BRC) ”Beep” Mode Test
Brake Control Unit (BRC) Code List
Brake Control Unit (BRC) Address List
Brake Control Unit (BRC) Special Adjustment Addresses
CAB
CAB Control Unit Address List
CAB Control Unit ”Beep” Mode Test
CAB Control Unit Calibration
CAB Control Unit Diagnostic Trouble Code List
CAB Control Unit (CAB, ASU, ACU—AutoQuad PLUS™/PowrQuad PLUS™, a
CCU
Chassis Control Unit (CCU) Address List
Chassis Control Unit (CCU) ”Beep” Mode Test With Speed Sensors
Chassis Control Unit (CCU), Calibration
Chassis Control Unit (CCU) Diagnostic Trouble Code List
Chassis Control Unit (CCU) Special Adjustment Addresses
CLC
Cab Load Center (CLC) Control Unit Address List
Cab Load Center (CLC) Control Unit ”Beep” Mode Test
Cab Load Center (CLC) Control Unit Calibration
Cab Load Center (CLC) Control Unit Diagnostic Trouble Code List
Cab Load Center Control Unit (CLC & TEC) Test
ECU
ECU Diagnostic Trouble Code (DTC) List
ECU Diagnostic Address List
Engine Control Unit (ECU) Test
HCU
Hitch Control Unit (HCU) Calibration
Hitch Control Unit (HCU) ”Beep” Mode Test
Hitch Control Unit (HCU) Code List
Hitch Control Unit (HCU) Address List
Hitch Control Unit (HCU) Special Adjustment Addresses
ICU
Instrument Control Unit (ICU) Calibration
Instrument Control Unit (ICU) “Beep” Mode Test
ICU Code List
ICU Address List
CommandCenter™ Control Unit (ICU) Test
PTF
Front PTO Control Unit Calibration
PTF Control Unit ”Beep” Mode Test
Front PTO Control Unit Code List
Front PTO Control Unit Address List
Front PTO Special Adjustment Addresses
Front PTO Control Unit Test
PTI
Power Train Control Unit (PTI) Calibration
Power Train Control Unit (PTI) ”Beep” Mode Test
Power Train Control Unit (PTI) Special Adjustment Addresses
PTI Code List
PTI Address List
AutoPowr™/IVT™ Transmission Control Unit (PTI, CCU, VLC) Test
PTQ
Power Train Control Unit (PTQ) Calibration
Power Train Control Unit (PTQ) ”Beep” Mode Test
Power Train Control Unit (PTQ) Special Adjustment Addresses
PTQ Code List
PTQ Address List
AutoQuad PLUS™ / PowrQuad PLUS™ Transmission Control Unit Test (
SCO
Secondary Hydraulic Control Unit (SCO) Calibration
Secondary Hydraulic Control Unit (SCO) ”Beep” Mode Test
Secondary Hydraulic Control Unit (SCO) Code List
Secondary Hydraulic Control Unit (SCO) Address List
Secondary Hydraulic Control Unit (SCO) Special Adjustment Addres
Secondary Hydraulic Control Unit Test (SCO)
SCU
Selective Control Unit (SCU) Calibration
Selective Control Unit (SCU) ”Beep” Mode Test
Selective Control Unit (SCU) Code List
Selective Control Unit (SCU) Address List
Selective Control Unit (SCU) Special Adjustment Addresses
Deluxe Hydraulic Control Unit Test (SCU, SFA, BRC, HCU)
SFA
Suspension and Front Axle Control Unit (SFA) Calibration
Suspension and Front Axle Control Unit (SFA) ”Beep” Mode Test
Suspension and Front Axle Control Unit (SFA) Code List
Suspension and Front Axle Control Unit (SFA) Address List
Suspension and Front Axle Control Unit (SFA) Special Adjustment
SSU
Steering System Control Unit (SSU) Address List
Steering System Control Unit (SSU) ”Beep” Mode Test
Steering System Control Unit (SSU) Calibration
Steering System Control Unit (SSU) Diagnostic Trouble Code List
Steering System Control Unit (SSU) Test
SUP
Set-Up Panel Control Unit (SUP) Calibration
SUP Code List
SUP Address List
SCV Set-Up Panel Control Unit Test
TEC
Tractor Equipment Control Unit (TEC) Address List
Tractor Equipment Control Unit (TEC) ”Beep” Mode Test
Tractor Equipment Control Unit (TEC) Calibration
Tractor Equipment Control Unit (TEC), Diagnostic Trouble Code Li
VLC
Vehicle Load Center (VLC) Control Unit Address List
Vehicle Load Center (VLC) Control Unit ”Beep” Mode Test
Vehicle Load Center (VLC) Control Unit Calibration
Vehicle Load Center (VLC) Control Unit Diagnostic Trouble Code L
AutoPowr™ / IVT™ TRANSMISSION
AutoPowr™ / IVT™ Reference List
AutoPowr™ / IVT™ Preliminary Checks
AutoPowr™ / IVT™ Operational Checks
AutoPowr™ / IVT™ Air Pump Test
AutoPowr™ / IVT™ Cold Start Valve Test
AutoPowr™ / IVT™ Differential Lock Leak Test
AutoPowr™ / IVT™ Element Circuit Leak Test
AutoPowr™ / IVT™ Enable Circuit Leak Test
AutoPowr™ / IVT™ Hydrostatic Control Pressure Test
AutoPowr™ / IVT™ Hydrostatic Loop Flush Valve Operation Check
AutoPowr™ / IVT™ Hydrostatic Unit Efficiency Test
AutoPowr™ / IVT™ Hydrostatic Yoke Centering Test
AutoPowr™ / IVT™ Install Test Equipment
AutoPowr™ / IVT™ Lube Pressure And Transmission Oil Pump Flow Te
AutoPowr™ / IVT™ MFWD Leak Test
AutoPowr™ / IVT™ Oil Cooler Inlet Pressure Test
AutoPowr™ / IVT™ Park Brake Leak Test
AutoPowr™ / IVT™ Park Brake Release Procedure
AutoPowr™ / IVT™ PTO Leak Test
AutoPowr™ / IVT™ System 1 Pressure Test
AutoPowr™ / IVT™ Record Sheet
AutoPowr™ / IVT™ Theory Of Operation
AutoPowr™ / IVT™ Theory Of Operation Transmission Air Pump
AutoPowr™ / IVT™ Theory Of Operation Hydraulic Circuit
AutoPowr™ / IVT™ Theory Of Operation Transmission Cycle
AutoPowr™ / IVT™ Transmission Front Cover Component And Valve Lo
AutoPowr™ / IVT™ Cross Section View
AutoPowr™ / IVT™ Hydraulic Schematic
AutoPowr™ / IVT™ Left Side View Component Locations
AutoPowr™ / IVT™ Power Flow Drawing
AutoPowr™ / IVT™ Right Side View Component Locations
PowrQuad PLUS™ AND AutoQuad PLUS™ TRANSMISSION
PowrQuad PLUS™ and AutoQuad PLUS™ - Reference List
PowrQuad PLUS™ and AutoQuad PLUS™ - Preliminary Checks
PowrQuad PLUS™ and AutoQuad PLUS™ - Operational Checks
PowrQuad PLUS™ and AutoQuad PLUS™ - Air Pump Vacuum Test
PowrQuad PLUS™ and AutoQuad PLUS™ - Clutch and Brake Element Ai
PowrQuad PLUS™ and AutoQuad PLUS™ - Clutch Cooling Circuit Test
PowrQuad PLUS™ and AutoQuad PLUS™ - Clutch Enable Pressure Test
PowrQuad PLUS™ and AutoQuad PLUS™ - Differential Lock Circuit L
PowrQuad PLUS™ and AutoQuad PLUS™ - Driving And Preliminary Pre
PowrQuad PLUS™ and AutoQuad PLUS™ - Element Leak Test
PowrQuad PLUS™ and AutoQuad PLUS™ - Install Test Equipment
PowrQuad PLUS™ and AutoQuad PLUS™ - Lube Pressure Test
PowrQuad PLUS™ and AutoQuad PLUS™ - MFWD Leak Test
PowrQuad PLUS™ and AutoQuad PLUS™ - Pump Air Leak Test
PowrQuad PLUS™ and AutoQuad PLUS™ - Rear PTO Leak Test
PowrQuad PLUS™ and AutoQuad PLUS™ - System Pressure Test
PowrQuad PLUS™ and AutoQuad PLUS™ - Transmission Pump / Cooler
PowrQuad PLUS™ and AutoQuad PLUS™ - Theory Of Operation
PowrQuad PLUS™ and AutoQuad PLUS™ - Planetary Theory Of Operati
PowrQuad PLUS™ and AutoQuad PLUS™ - Pumps And Oil Circuits Theo
PowrQuad PLUS™ and AutoQuad PLUS™ - Range Box Theory Of Operati
PowrQuad PLUS™ and AutoQuad PLUS™ - Reservoir And Valves Pressu
PowrQuad PLUS™ and AutoQuad PLUS™ - Shifting Theory Of Operatio
PowrQuad PLUS™ and AutoQuad PLUS™ - Bottom View Test Port and C
PowrQuad PLUS™ and AutoQuad PLUS™ - Front View Test Port and Co
PowrQuad PLUS™ and AutoQuad PLUS™ - Right View Test Port and Co
PowrQuad PLUS™ and AutoQuad PLUS™ - System Schematic
Drive Systems
Axles and Differential Lock
Axle and Diff Lock - Reference List
Diff Lock - Preliminary Checks
Diff Lock - Operational Checks
Axles - Front Axle Theory of Operation
Axles - Rear Axle Theory of Operation
Diff Lock - Theory Of Operation
Diff Lock - Schematic
Diff Lock - Component Location Diagram
MFWD
MFWD - Reference List
MFWD - Preliminary Checks
MFWD - Operational Checks
MFWD - Clutch Slippage Test
MFWD - Clutch Test
MFWD - Theory of Operation
MFWD - Schematic
MFWD - Component Location Diagram
PTO
PTO - Reference List
PTO - Preliminary Checks
PTO - Operational Checks
PTO - Front PTO Leak Test
PTO - Front PTO Modulating Valve Test
PTO - Rear PTO Modulating Valve Test
PTO - Front PTO Theory of Operation
PTO - Rear PTO Theory Of Operation
PTO - Front PTO Schematic
PTO - Rear PTO Schematic
PTO - Front PTO Component Location Diagram
PTO - Rear PTO Component Location Diagram
SFA - Reference List
SFA - Preliminary Checks
SFA - Operational Checks
SFA - Accumulator Pressure Test
SFA - Cylinder Leakage Test
SFA - Load Sense Signal Test
SFA - Theory of Operation
SFA - Schematic
SFA - Component Location Diagram
STEERING AND BRAKES
Brakes
Brake - Reference List
Brake - Front Brakes Preliminary Check
Brake - Rear Brakes Preliminary Check
Brake - Front Brake Operational Test
Brake - Rear Brake Operational Test
Brake - European Air Brake Pressure Test
Brake - Front Brake Leak Test
Brake - Front Brake Pressure Sensor Signal Test
Brake - Hydraulic Trailer Brake Adjustment
Brake - Hydraulic Trailer Brake Pressure Test
Brake - North American Air Brake Pressure Test
Brake - Rear Brake Leak Test
Brake - Rear Brake Pressure Sensor Signal Test
Brake - Rear Brake Pressure Test
Brake - Secondary Brake Pressure Sensor Signal Test
Brake - Trailer Air Brake Theory Of Operation
Brake - Brake Pistons, Plates and Disks Theory of Operation
Brake - Brake Valve Theory of Operation
Brake - Front Brake Theory of Operation
Brake - Hydraulic Trailer Brake Theory Of Operation
Brake - Secondary Brake Theory of Operation (EUR Only)
Brake - System Schematic and Component Diagrams
Steering
Steering - Reference List
Steering - AutoTrac Preliminary Check
Steering - Preliminary Check
Steering - AutoTrac Operational Check
Steering - Operational Check
Steering - AutoTrac Accuracy Factors
Steering - AutoTrac Steering Accuracy Check
Steering - AutoTrac Electro-Hydraulic Steering Valve Hydraulic T
Steering - Leak Test
Steering - Cylinder Theory of Operation
Steering - Gerotor Theory of Operation
Steering - Valve Theory of Operation
Steering - AutoTrac Schematic
Steering - Schematic
Steering - AutoTrac Component Location Diagram
Steering - Component Location Diagram
HYDRAULICS
Main Hydraulics
Hydraulic System Checks, Tests, Theory and Schematic Listing
Hydraulic System Preliminary Checks
Hydraulic System Operational Check
Rear Hitch Operational Checks
Front Hitch Operational Checks
Hydraulics - Bleeding Load Sense and Hydraulic Pressure Circuits
Hydraulics - Charge Pump Suction Air Leak Test
Hydraulics - Hydraulic System Leakage Test
Hydraulics - Load Sense Valve Test
Hydraulics - Main Pump Flow Test
Hydraulics - Main Pump Inlet Pressure Test
Hydraulics - Main Pump Inlet Pressure Test At Full Flow
Hydraulics - Main Pump Stall Pressure Test
Hydraulics - Main Pump Standby Pressure Test
Hydraulics - Mechanical Mid-Stack Pressure Test
Hydraulics - Mid Stack SCV Pilot Pressure Test
Hydraulics - Mid Stack Shuttle Check Valve Verification
Hydraulics - Preliminary Main Pump Pressure Test
Hydraulics - Primary Circuit Pressure Test
Hydraulics - Priority Valve Differential Pressure Test
Hydraulics - Priority Valve Operational Pressure Test
Hydraulics - Pump Load Sense Circuit Pressure Test Using Steerin
Hydraulics - Pump Load Sense Differential Pressure Test
Hydraulics - Pump Load Sense Preliminary Pressure Test
Hydraulics - Pump Pressure Above Standby Or Near Stall
Hydraulics - Rear SCV Pilot Pressure Test
Hydraulics - SCV Leak Down Test
Hydraulics - Steering Stall Pressure Verification Test
Hydraulics - System Response to A Missing Shuttle Check Valve
Heating Hydraulic Oil
Hydraulic System Diagnosis Record Sheet
Hydraulic System Theory Of Operation
Manual Selective Control Valves (SCVs)
Electrohydraulic Selective Control Valves (SCVs)
Manual Mid Mount Selective Control Valve Stack
Mechanical Mid-Stack Theory of Operation
Mechanical Mid-Stack Grapple Valve Theory of Operation
Priority Valve Theory of Operation
Rear Hitch Theory of Operation
Front Hitch Theory of Operation
Tractor Hydraulic Schematic - North American and Manual Valves
Tractor Hydraulic Schematic - European, EH Valves and Options
Tractor Hydraulic Schematic - European, EH SCVs, w/o AutoTrac, a
Hydraulic Schematic - SCV Rear Stack, Manual Valves
Hydraulic Schematic - SCV Rear Stack, Manual Valves with High Pr
Hydraulic Schematic - SCV Mid Stack, Manual Valves
Hydraulic Schematic - SCV Rear Stack, EH Valves
Hydraulic Schematic - SCV Mid Stack, EH Valves
OPERATOR STATION
Air Conditioning
A/C - Reference List
A/C - Preliminary Checks
A/C - ATC Operational Check
A/C - Manual A/C Operational Check
A/C - Install Test Equipment
A/C - System Static Pressure Test
A/C - System Pressure Test
A/C - Temperature Drop Test
A/C - ATC Theory of Operation
A/C - Manual Air Conditioning Theory of Operation
A/C - ATC and Manual A/C Schematic
A/C - ATC and Manual A/C Component Location Diagram
Seat - Reference List
Seat - ActiveSeat™ Operational Check
Seat - Manual Seat Operational Check
Seat - ActiveSeat™ Actuator Check
Seat - ActiveSeat™ Pressure and Accumulator Check
Seat - ActiveSeat™ Theory of Operation
Seat - Manual Seat Theory Of Operation
Seat - ActiveSeat™ and Manual Seat Schematic
Seat - ActiveSeat™ and Manual Seat Component Location Diagram
SERVICE TOOLS
Dealer Fabricated Tools
DFRW2 — Needle Valve Test Hose Assembly
DFRW51 — Electronic Circuit Load Tester
DFRW60 - DFRW61 - DFRW62 — Extension Harnesses
DFRW88 — Clutch Torque Tool
DFRW126 — Modified Tap Out Harness
DFRW130 — Relay Circuit Test Lead
DFRW153 — Water Manometer
DFRW167 — Water Valve Test Harness
DFRW168 — Park Solenoid Jumper Harness
DFRW176 — AutoTrac Steering Valve Test Harness
DFRW177 — Element Test Plate
DFRW178 — Front Brake Bleed Wrench
DFRW180 — Fan Drive Tap Out Harness
DFRW191 — Red Glad Hand Assembly
DFRW192 — Blue Glad Hand Assembly
DFRW213 — Hydraulic Trailer Brake Test / Bleed Assembly
DFRW227 — Hose Assembly, 3048 mm (120 in.) Long
Service Tools and Kits
15H199 — Street Elbow (3/8 NPT)
15H586 — Bushing (1/2 (m) NPT x 3/8 (f) NPT)
15H625 — Bushing (1/2 (m) NPT x 1/4 (f) NPT)
29H659 — Nipple (3/8 (m) NPT x 6.4 cm (2-1/2 in.))
29H668 — Nipple (3/8 (m) NPT x 15 cm (6 in.)
38H1030 — Tee (-6 ORFS)
38H1033 — Tee (-12 ORFS)
38H1146 — Plug (-6 ORFS)
38H1147 — Plug (-8 ORFS)
38H1272 — Union (-12 ORFS)
38H1278 — Union (-6 ORFS)
38H1279 — Union (-8 ORFS)
38H1281 — Union (-16 ORFS)
38H1415 — Cap (-6 ORFS)
38H1416 — Cap (-8 ORFS)
38H1419 — Cap (-16 ORFS)
38H3003 — Straight Fitting (-8 (m) ORFS x M18 x 1.5 (m))
AA20991 — 10 ft. Hydraulic Hose, Straight w/End Fittings
AR52361 — Quick Connect Coupler
AR93820 — ISO Hose Fitting
AR94522 — ISO SCV Coupler
D01074AA — 75 GPM In-Line, Dual Scale Hydraulic Tester
D01169AA — Hydraulic Tester
D05330ST — Supplemental Accessory Kit
D05361ST — Rubber Stopper/Leak Detector Kit
D15032NU — Vacuum Pump Kit
FKM10002 — Pressure Gauge Set
FKM10207 — Pressure Gauge
FKM10209 — Test Hose
FKM10302 — Connector
FKM10303 — Connector
FKM10305 — Connector
JDG774 — Solenoid Test Harness
JDG774A — Solenoid Test Harness
JDG10466 — Flex Probe Kit
JDG1424 — Support Block
JDG1478 — Digital Multimeter
JDG1499 — IVT Housing Pressure Adapter
JDG1504 — Installer Kit, Shift Valve
JDG1505 — Test Block, High Pressure Transmission Valve
JDG1666 — Park Brake Release Hand Pump Kit
JDG1735 — Active Seat™ Accumulator Test Fitting
JDG1753 — Service Jumper Harness Kit
JDG7X10iVT — 7000 TEN SERIES Tool Kit - North American Version
JDH43A(85) — Rockshaft Thermal Relief Valve Test Kit
JT01765 — Lawn and Grounds Care Products Hydraulic Fitting Kit
JT01767 — Supplemental Lawn and Grounds Care Products Hydraulic
JT02051 — Manifold With Vibration Free Gauges
JT02063 — Electronic Leak Detector
JT02095 — R134a Start-Up Kit
JT02098 — Air Conditioning Flushing Kit
JT02178 — A/C Leak Detection Kit
JT02180 — A/C Leak Detector Kit
JT02219 — Fitting Straight, 1/8 NPTF x 1/2-16 ACME
JT03023 — Cap Nut (9/16-18 (f) JIC)
JT03036 — Pipe (9/16-18 (m) JIC x 9/16-18 (m) JIC)
JT03041 — Straight Fitting (1/2 (m) NPT x 3/4-16 (f) ORB)
JT03059 — 90° Elbow, 1 1/16-12 M 37° x 1 1/16-12 F 37° Sw
JT03218 — Straight Fitting (3/8 (f) NPT x 9/16-18 (f) JIC Sw)
JT03232 — Connector 1/4 M NPT X 1/8 F NPT
JT03261 — Coupler (1/4 (m) NPT)
JT03265 — Straight Fitting (7/16 (f) Quick Coupler x 1/4 (m) NPT
JT03341 — 90° Elbow (9/16-18 (m) JIC x 9/16-18 (f) JIC Sw)
JT03348 — Tee Fitting (1/2 (f) NPT x 1/2 (f) NPT x 1/2 (f) NPT)
JT03402 — Shut Off Valve
JT03412 — Supplemental Pressure Test Kit
JT03413 — Supplemental Flow Test Kit
JT03419 — ORFS Fitting Kit
JT03421 — Straight Fitting (9/16-18 (m) JIC x 11/16-16 (f) ORFS)
JT03437 — Plug x Socket - 90° Coupler
JT03445 — Straight Fitting, (9/16-18 (m) JIC or M14 X 1.5M ORB)
JT03473 — Male-to-Female Quick Coupler
JT03474 — Male-to-Male Quick Coupler
JT03475 — Tee Fitting (1/4 (m) NPT x 1/4 (f) NPT x 1/4 (f) NPT)
JT03478 — Male Quick Coupler x 11/16-16 (f) ORFS
JT03485 — Special Male Quick Coupler (1/8 Male QC x 1 3/16 - 12
JT03512 — Hydraulic Fitting Kit
JT03512-1 — 90° Elbow (1 1/16-12 (m) JIC x -12 (f) ORFS)
JT03513C — Fuel Supply System Test Kit
JT03515 — Nitrogen Accumulator Service Kit
JT03515-1 — Accumulator Pressure Check & Gauge
JT03515-2 — Accumulator Adapter
JT05406 — Master Hydraulic Fitting Flow Test Kit
JT05412 — Industrial Universal Pressure Test Kit
JT05416 — Consumer Products Hydraulic Flow Test Kit
JT05418 — Industrial Flow Test Kit
JT05470 — Universal Pressure Test Kit
JT05471 — Gauge w/Quick Coupler, 7000 kPa (70 bar) (1000 psi)
JT05472 — Gauge w/Quick Coupler, 400 kPa (4 bar) (60 psi)
JT05473 — Gauge w/Quick Coupler, 35,000 kPa (350 bar) (5,000 psi
JT05474 — Gauge w/Quick Coupler 2,000 kPa (20 bar) (300 psi)
JT05475 — Gauge w/Needle Valve, 400 kPa (4 bar) (60 psi)
JT05476 — 90° Elbow Assembly (1/2 (m) Quick Coupler x 7/16-20 (f
JT05478A — 90° Elbow (14 mm (m) x 14 mm (f))
JT05480 — Diagnostic Receptacle (M14 x 1.5M ORB x 1/2 Quick Coup
JT05487 — Connector (1/8 (m) NPT x 7/16-20 (m) JIC)
JT05494 — Hydraulic Fitting 7/16-20 M 37° x 3/4-16 M ORB
JT05497 — Hose Assembly, 3048 mm (120 in.) Long
JT05685 — Battery Load Tester
JT05690 — Straight Fitting (1 1/16-12 (m) JIC x 1 3/16-12 (f) OR
JT05697A — U-Tube Manometer Kit
JT05791 — Digital Multimeter
JT05832 — Battery Load Tester
JT05833 — Battery Service Kit
JT05843 — Hydrometer
JT07030 — (100)/0/200 kPa ((1)/0/2 bar) (30 Hg./0/30 psi) Vacuum
JT07041 — 0-2800 kPa (0-28 bar) (0-400 psi) Hydraulic Pressure G
JT07045 — 0-20,000 kPa (0-200 bar) (0-3000 psi) Hydraulic Pressu
JT07115 — Master Hydraulic Test Kit
JT07115 SUP — Supplemental Master Hydraulic Test Kit
JT07117 — Three-Gauge Manifold
JT07118 — Two-Valve Manifold
JT07119 — 5 ft. Test Hose
JT07120 — Load Valve Assembly
JT07134 — Bleed Pipe
JT07135 — Bleed Pipe
JT07196 — Technicians A/C R134a Service Kit
JT07207 — 300 kPa (5 bar) (200 psi) Gauge
JT07208 — Hydraulic Fitting Kit
JT07209 — Hydraulic Test Kit
JT07212 — Diagnostic Fitting Kit
JT07260 — ORFS Adapter Hydraulic Test Kit
JT07328 — Terminal Test Kit
JT07328-1 — Grey Male Test Terminal
JT07328-2 — Grey Female Test Terminal
JT07328-3 — Violet Male Test Terminal
JT07328-4 — Violet Female Test Terminal
JT07328-5 — Brown Male Test Terminal
JT07328-6 — Brown Female Test Terminal
JT07328-7 — Orange Male Test Terminal
JT07328-8 — Orange Female Test Terminal
JT07328-9 — Dark Blue Male Test Terminal
JT07328-10 — Dark Blue Female Test Terminal
JT07328-11 — Red Male Test Terminal
JT07328-12 — Red Female Test Terminal
JT07328-13 — Yellow Male Test Terminal
JT07328-14 — Yellow Female Test Terminal
JT07328-15 — Green Male Test Terminal
JT07328-16 — Green Female Test Terminal
JT07328-17 — Black Male Test Terminal
JT07328-18 — Black Female Test Terminal
JT07328-19 — Patch Cords
KJD10128 — Adaptor Fitting
KJD10194 — Hydraulic Test Kit
KJD10194-1 — Pressure Gauge
KJD10194-2 — Hose
KJD10194-4 — Coupler (yellow)
KJD10194-5 — Coupler (red)
KJD10194-7 — Test Connector
R36659 — Hydraulic Jumper Hose (3 ft)
R77464 — Pin Terminal
RE12187 — Diagnostic Receptacle (14 mm)
RE154966—Oil Pressure Sensor - 2000 kPa (20 bar) (290 psi)
RE167207 — Oil Pressure Sensor, 700 kPa (7 bar) (100 psi)
RE179984 — Oil Pressure Sensor, 6900 kPa (69 bar) (1000 psi)
RE190805 — Diagnostic Receptacle (14 mm)
RE204264—Oil Pressure Sensor - 27600 kPa (276 bar) (4000 psi)
RE217077 — Oil Pressure Sensor, 2700 kPa (27 bar) (390 psi)
RE43774 — Diagnostic Receptacle (13/16-16 (f) ORFS)
RE60701 — Diagnostic Receptacle (-6 ORFS)
T57553 — Special Nut
Page Number
