Martin Welker
104
230,310
John Deere 7610 7710 7810 Tractor Repair Manual TM1651
Brand: John Deere
Type of Manual: Repair Manual
Model: John Deere 7610 7710 7810 Tractor
Serial Number: 000001-030000, 030001-030000, 030001-, 030001-090000, 090001-, 070001-
Part Number: TM1651
Publication Date: 2010
Number of Pages: 1576 Pages
FOREWORD
NOTICE TO THE DEALER
DEALER PREDELIVERY INFORMATION FORM
QUICK REFERENCE SPECIFICATIONS
Section 10 - GENERAL INFORMATION
Group 05 - Safety
Recognize Safety Information
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Avoid High-Pressure Fluids
Park Machine Safely
Support Machine Properly
Wear Protective Clothing
Work in Clean Area
Service Machines Safely
Work In Ventilated Area
Illuminate Work Area Safely
Replace Safety Signs
Use Proper Lifting Equipment
Service Tires Safely
Avoid Harmful Asbestos Dust
Use Proper Tools
Dispose of Waste Properly
Live With Safety
Group 10 - General Information
General Specifications
Sealants and Adhesives Cross-Reference Chart
Metric Bolt and Cap Screw Torque Values
Unified Inch Bolt and Cap Screw Torque Values
Glossary of Terms
Section 20 - ENGINE
Group 00 - Component Removal and Installation
Essential or Recommended Tools
Specifications
Remove Engine—7610
Remove Engine—7710 And 7810 (S.N. -90000)
Remove Engine—7710 And 7810 (S.N. 90001- )
Install Engine in Repair Stand
Install Engine
Group 05 - Engine Repair
Specifications
Repair Engine—Use CTM
Access to Front Crankshaft Seal
Access to Rear Crankshaft Seal
Access to Camshaft
Access to Timing Gear Cover
Remove and Install Engine Valve Cover (S.N. -90000)
Remove and Install Engine Valve Cover (S.N. 90000- )
Remove Suspended MFWD Engine Oil Pan
Section 30 - FUEL AND COOLING SYSTEMS
Group 05 - Controls
Adjust Hand-Foot Throttle Linkage—7610
Adjust Hand-Foot Throttle Linkage—7710-7810
Group 10 - Diesel Fuel System
Specifications
Remove And Install Fuel Tanks
Replace Fuel Filter, Fuel Pump, And Bleed Fuel System
Group 15 - Air Intake System
Specifications
Inspect And Service Air Intake System
Group 20 - Engine Cooling System
Specifications
Test Radiator And Coolant Tank Cap
Remove and Install Front Cooling Assembly—7610, 7710 And 7810 (S.N. -90000)
Remove and Install Radiator —7710 And 7810 (S.N. 90001- )
Remove And install Thermostat Valve—7710 And 7810 (S.N. 90001- )
Fill Cooling System With Coolant—7710 And 7810 (S.N. 90001- )
Remove And Install Viscous/Vistronic Fan Drive
Inspect Belt Tensioner
Replace Belt Tension Mechanism
Fan Belt Routing—7610
Fan Belt Routing—7710 and 7810
Group 25 - Air Conditioning Condenser and Coolers—7610, 7710 and 7810 (S.N. -90000)
Specifications
Remove Fuel-Hydraulic Oil Cooler/Condenser
Leak Test Fuel-Hydraulic Oil Cooler
Install Fuel-Hydraulic Oil Cooler/Condenser
Group 30 - Air Conditioning Condenser and Coolers—7710 and 7810 (S.N. 90001- )
Specifications
Remove And Install Hydraulic Oil Coolers And Leak Test
Remove And Install Fuel Cooler And Leak Test
Remove And Install Condenser
Section 40 - ELECTRICAL
Group 05 - Connectors
Essential Or Recommended Tools
Other Material
Use Electrical Insulating Compound
Using High-Pressure Washers
Repair AMP Connector
Remove Connector Body From Blade Terminals
Repair CINCH Connectors
Repair CPC™ Blade Type Connectors
Repair CPC™ Large MATE-N-LOC ™ And METRIMATE™ Pin Type Connectors
Repair DEUTSCH™ Connectors
Repair Small MATE-N-LOC™ Socket Connector
Repair Small MATE-N-LOC™ Pin Connector
Repair (Pull Type) METRI-PACK™ Connectors
Repair (Push Type) METRI-PACK™ Connectors
Repair SUMITOMO™ Connectors
Repair Weather Pack™ Connectors
Repair YAZAKI™ Connectors
Group 10 - Wiring Harness Routings
Ground Point Locations
Cab Harness Routing—Common Components—PQT And IVT Transmissions
Cab Harness Routing—POWRQUAD Transmission Without LH Reverser
Cab Harness Routing—POWRQUAD Transmission With LH Reverser
Cab Harness Routing—AutoPowr/IVT Transmission
Open-Station Harness Routing And Component Identification
Transmission Harness Routing And Component Identification (PQT)
Transmission Harness Routing And Component Identification—AutoPowr/IVT—Left-Hand Side
Transmission Harness Routing And Component Identification—AutoPowr/IVT—Right-Hand Side
AutoPowr/IVT Control Lever Harness Routing And Component Identification
(7710—7810)—AutoPowr/IVT Engine/Chassis Harness Routing And Component Identification
Harness Routing And Component Identification—Suspended MFWD Axle
Row Guidance Harness Routing And Component Identification
Wire Number And Color Codes
Load Center Fuses, Relays, And Diodes—Open-Station
Load Center Fuses, Relays, And Diodes—Cab (North American)
Load Center Fuses, Relays, And Diodes—Cab (European)
Load Center Fuses, Relays, And Diodes—Cab (AutoPowr/IVT)
Replace Load Center Fuses And Relays
Group 15 - Charging Circuit
Repair Alternator—Use CTM
Exploded View—Alternator
Remove And Install Alternator
Group 20 - Starting Circuit
Specifications
Repair Starter—Use CTM
Remove And Install Starter Motor
Replace Starter Circuit Relay
Replace Fusible Link
Replace Neutral Start Switch—POWRQUAD Transmission
Replace Gear Encoder
Replace Switch Module
Group 25 - Solenoids And Switches
Specifications
Replace Ether Starting Aid Solenoid And Switch—7710 And 7810
Replace Brake Switch—Non-AutoPowr/IVT
Replace MFWD Switch
Replace Field Cruise Switch
Replace Fuel Shut-Off Solenoid
Replace MFWD Solenoid
Replace Differential Lock And Rear PTO Solenoids
Replace Hitch Return And Hitch Pressure Solenoids
Replace Air Conditioning Relays And Switches
Replace Air Conditioning High- And Low-Pressure Switches
Replace Hitch Position Potentiometer Assembly
Replace Hitch Control Potentiometer And Switch
Replace Park Enable Switch (Tractors With Left-Hand Reverser)
Remove Electrical Switches And Sensors—POWRQUAD Transmission
Electrical Controls And Switches—AutoPowr/IVT Transmission
Replace AutoPowr/IVT Hydro Control Solenoid
Replace AutoPowr/IVT Fixed Unit Speed Sensor
Replace AutoPowr/IVT Carrier Speed Sensor
Replace AutoPowr/IVT Clutch Pedal Position Sensor
Replace AutoPowr/IVT Clutch Pedal Position Sensor Linkage
Replace AutoPowr/IVT Brake Switch
Replace AutoPowr/IVT Hand Throttle/Speed Selector Assembly
Replace AutoPowr/IVT Set-Speed Switch
Replace AutoPowr/IVT Selector Switch
Group 30 - Monitoring System
Other Material
Replace Engine Oil Pressure Sensor
Replace Engine Speed Sensor
Replace Engine Coolant Temperature Sensor
Replace Air Filter Restriction Indicator Sensor
Replace Fuel Level Sensor
Replace Hydraulic Oil Filter Restriction Sensor
Hitch-Position Feedback Sensor Location
Remove And Install Draft Link Sensor
Adjust Draft Link Sensor
Replace Rear PTO Speed Sensor
Replace Wheel Speed Sensor—Non-AutoPowr/IVT
Replace Radar Speed Sensor
Replace MFWD Speed Sensor—AutoPowr/IVT
Replace AutoPowr/IVT Primary Wheel Speed Sensor
Replace AutoPowr/IVT Backup Wheel Speed Sensor
Replace AutoPowr/IVT Transmission Oil Temperature Sensor
Replace AutoPowr/IVT Transmission Pressure Sensor
Replace PST Central Control Unit—(CCU/PCU)
Replace Hitch Control Unit—(HCU) And/Or Central Control Unit
Replace Reverser Control Unit—(RCU)
Remove And Install Display Module
Replace Display Module Bulbs
Replace Light Switch, Hazard Light Switch, And Audible Warning Alarm
Replace Multifunction And Washer Wiper Switch
Replace FNR Direction Switch
Replace Multifunction Switch Wiring Harness
Group 40 - Auxiliary Lighting And Electrical Components
Replace Seven-Terminal Outlet Socket—North American
Replace Seven-Terminal Outlet Socket—European
Group 45 - Convenience And Accessory Components
Replace Pressurizer Blower Motor
Replace Circulation Blower Motors
Replace Wiper Motor
Test Ground-Fault Circuit Interrupter
Replace Transmission Cover Heater
Replace Hydraulic Charge Pump Heater
Remove and Install Electro-Hydraulic Control Valve Switch
Section 50 - POWER SHIFT TRANSMISSION
Other Material
Specifications
Sealing Instructions—Drive Train
Remove Drive Train
Install Drive Train
Remove Power Shift Transmission
Install Power Shift Transmission
Remove Reduction Gearbox
Install Reduction Gearbox
Group 05 - Controls
Shift Console Access
Transmission Shift Control and Park Linkage
Park Linkage Adjustments
Remove and Install Shift Control Assembly
Disassemble and Assemble Shift Control Assembly
Replace Encoder
Replace Power Shift Control Unit—(PCU)
Replace Relays
Recondition Park Lock Linkage
Adjust or Replace Clutch Cable (Non-Isolated)
Adjust or Replace Clutch Cable (Isolated)
Recondition Tow Disconnect
Electrical Controls and Sensors—Front Valve Housing
Electrical Controls and Sensors—Front Cover and Transmission
Wheel Speed Sensor
Remove and Install Thermal Bypass Valve
Group 10 - Transmission
Other Material
Specifications
General Repair Procedures—Power Shift Transmission
Transmission Components
Prepare Transmission for Repair
Remove Transmission Front Cover/Front Valve Housing
Remove Front Valve Housing
Front Valve Housing Valves
Transmission Front Cover Valves
Repair Clutch Valve
Replace Clutch Valve Shifter Lever Shaft Seal
Cross-Sectional View—Transmission Pump
Repair Transmission Pump
Install Front Valve Housing
Install Transmission Front Cover/Valve Housing Assembly
Remove and Install Electro-Hydraulic Valves
Remove Clutch Pack Assembly
Cross-Sectional View—Clutch Pack Assembly (Early Design)
Cross-Sectional View—Clutch Pack Assembly (Later Design)
Disassemble Clutch Pack Assembly
Assemble Clutch Pack Assembly
Install Clutch Pack Assembly
Remove and Disassemble C-LO—B-HI Pack
Assemble and Install C-LO — B-HI Pack
Remove and Disassemble Input Planetary Carrier Assembly
Assemble and Install Input Planetary Carrier Assembly
Disassemble Output Housing Module and Remove Output Planetary Carrier
Cross-Sectional View—Output Planetary Carrier Assembly
Exploded View—Output Planetary Carrier Assembly
Disassemble Output Planetary Carrier Assembly
Assemble Output Planetary Carrier Assembly
B3 Gear Identification — Version ‘A” and Version ‘B”
Remove and Disassemble B-5 Pack
Assemble and Install B-5 Pack
Install Output Planetary Carrier and Assemble Output Housing Module
Group 15 - Reduction Gearbox
Other Material
Specifications
General Repair Procedures—Reduction Gearbox
Remove Differential Drive Shaft
Cross-Sectional View—Differential Drive Shaft
Determine Cone Point Shim Pack and Install Differential Drive Shaft
Cross-Sectional View—Reduction Gear Shaft
Remove and Install Reduction Gear Shaft
Repair Lube Manifold (Differential S.N. -026096)
Repair Lube Manifold (Differential S.N. 026097- )
Remove and Install Tow Disconnect
Replace Transmission Lock Return Spring
Remove and Install Transmission Lock
Section 51 - AUTOPOWR/IVT TRANSMISSION
Essential Tools
Specifications
Other Material
Drive Train Removal
Group 05 - Controls
Specifications
Brake Pedal Switch Adjustment
Using Hydraulic Hand Pump To Release Park Brake
Cross-Sectional View—Park Brake Release (Early Production)
Replace Park Brake Release Cable
Adjust Service Disconnect
Group 10 - Front Pump/Control Valve Assembly
Essential Tools
Specifications
General Repair Procedures—Front Control Valve/Transmission Control Pump Assembly
Remove And Install Front Control Valve Assembly
Hydrostatic Module Control Valve Assembly—Exploded View
Repair Hydrostatic Module Control Valve Assembly
Group 15 - Transmission Front Housing
Essential Tools
Specifications
Other Material
General Repair Procedures—Transmission
Hydrostatic Module Replacement
Repair Sequence For Hydrostatic Module Service ONLY
Remove Hydrostatic Module
Install Hydrostatic Module
Group 20 - Hydrostatic Module
Essential Tools
Specifications
Exploded View—Hydrostatic Gear Train
Disassemble Hydrostatic Module Gear Train
Repair Hydrostatic Module Gear Train
Assemble Hydrostatic Module Gear Train
Replace Hydrostatic Module
Test Multi-Function Valves
Group 25 - Shift Valve Assembly
Essential Tools
Specifications
General Repair Procedures—Shift Control Valve Assembly
Remove And Install Shift Valve Housing
Exploded View—Shift Valve Housing
Repair Shift Valve Assembly
Service Hi-Lo-Reverse Shift Valves
Group 30 - Transmission Rear Housing
Essential Tools
Specifications
Cross-Sectional View—Park Brake Assembly
Repair Park Brake
Remove And Install Clutch/Planetary Assembly
Shift Accumulator
Park Brake Release Check Valve
Cross Sectional View—Clutch Assembly
Cross Sectional View—Clutch/Planetary Assembly
Exploded View—Planetary Assembly
Repair Clutch/Planetary Assembly
Repair Reverse Brake
Replace Clutch/Planetary Carrier Bearing Cups
Group 35 - Differential Input Assembly
Essential Tools
Specifications
General Repair Procedures—Differential Input Quill
Cross-Sectional View—Differential Input Quill
Disassemble Differential Input Quill
Assemble Differential Input Quill
Section 55 - POWRQUADPOWRQUAD IS A TRADEMARK OF DEERE & COMPANY TRANSMISSION
Group 00 - Component Removal And Installation
Other Material
Specifications
Remove Drive Train
Install Drive Train
Remove Transmission
Remove Creeper Transmission
Install Creeper Transmission
Remove Range Box
Install Range Box
Group 05 - Control Linkages
Specifications
POWRQUAD™ Controls Introduction
Access Shift Console
Shift And Park Linkage Assembly
Shift And Park Linkage Symptom/Cause Chart—Two-Lever Shift
Shift And Park Linkage Adjustment
Preliminary Checks—All
Check Shifter Lever Tang And Fork Slot—Two-Lever Shifter
Check Shift Lever Pivot—Two-Lever Shifter, Three-Lever Shifter With Right-Hand Reverser
Inspect Shifter Cams—Two-Lever Shifter
Check And Adjust Cam Neutral Alignment—Two-Lever Shifter
Check And Adjust Park Disengaged Stop (After Cam Adjustment)
Inspect And Adjust FNR Lower Rod—Two-Lever Shifter And Three-Lever Shifter With Right-Hand Reverser
Inspect And Adjust FNR Linkage (Upper And Lower)—Two-Lever Shifter
Adjust FNR Upper linkage—Three-Lever Shifter With Right-Hand Reverser
Inspect And Adjust Lower Speed Linkage—Two-Lever Shifter And Three-Lever Shifter With Right-Hand Reverser
Inspect And Adjust Upper Speed Linkage—Two-Lever Shifter
Inspect And Adjust Upper Speed Linkage—Three-Lever Shifter
Inspect Lower Park Rod—All
Inspect Upper Park Rod And Check Park Adjustment—All
Adjust Park Rod—All
Adjust Park Rod With Turnbuckle—All
Adjust Park Rod With Balljoint—All
Check Park Rod For Excessive Flexing—All
Check Park Disengaged Stop—Two-Lever Shifter
Lubricate Park Arm, Shifter Fork Slots And Shift Lever Tang—All
Inspect And Adjust Range Shift Linkage—All
Drive And Final Checks—Shifting And Park Performance
Other Symptoms And Solutions—Two-Lever Shifter And Three-Lever Shifter With Right-Hand Reverser
Remove Shift Control Assembly—Three-Lever Shifter
Exploded View—Three-Lever Shifter with Right-Hand Reverser
Disassemble Three-Lever Shifter Assembly With Right-Hand Reverser
Assemble Three-Lever Shifter With Right-Hand Reverser
Exploded View—Three-Lever Shifter With Left-Hand Reverser
Disassemble Three-Lever Shifter With Left-Hand Reverser
Assemble Three-Lever Shifter With Left-Hand Reverser
Exploded View—Two-Lever Shifter
Disassemble Two-Lever Shifter
Assemble Two-Lever Shifter
Bench Test Stepper Motor
Install Stepper Motor
Adjust Stepper Motor
Adjust Or Replace Clutch Cable (Non-Isolated)
Adjust Or Replace Clutch Cable (Isolated)
Other Material
Specifications
General Repair Procedures—POWRQUAD Transmissions
Internal Components—POWRQUAD
Install Transmission In Repair Stand
Repair Clutch Valve
Replace Clutch Valve Shifter Lever/Shaft Seal
Replace Clutch Valve Inner Arm/Shaft
Cross-Sectional View—Transmission Pump and Air Pump
Repair Transmission Pump and Air Pump
Install Transmission Front Cover/Front Valve Housing
Remove Shift Control Valve Housing
Replace Forward-Reverse/Speed Selector Shifter Levers/Shaft Seals
Replace Forward-Reverse/Speed Selector Shifter Shafts/Shifter Arms
Shift Control Valve Housing Valves
Cross-Sectional View—Modulator Valve
Planetary Housing Valves
Cross-Sectional View—Forward/Neutral/Reverse Control Valve
Cross-Sectional View—Forward/Reverse Control Valve
Cross-Sectional View—Speed Selector Valve
Assemble and Install Shift Valve Housing
Disassemble Planetary Assembly
Recondition Input Planetary Carrier
Disassemble Input Planetary Assembly
Disassemble Reverse Brake Housing Components
Cross-Sectional View—Forward Clutch Assembly
Recondition Forward Clutch Assembly
Disassemble Planetary Housing Components
Cross-Sectional View—Direct Drive Clutch Assembly
Recondition Direct Drive Clutch Assembly
Assemble Planetary Housing Components
Assemble Reverse Brake Housing Components
Assemble Input Planetary Assembly
Assemble Planetary/Reverse Brake Housing Assembly
Group 15 - Creeper Transmission
Other Material
Specifications
General Repair Procedures—Creeper Transmission
Recondition Creeper Transmission
Cross-Sectional View—Shifter Components
Remove And Install Shifter Components
Cross-Sectional View—Creeper Transmission
Remove Input/Output Drive Shaft Assembly
Disassemble And Assemble Drive Shaft/Snubber Brake
Remove And Install Countershaft
Install Input/Output Drive Shaft Assembly
Group 20 - Range Box
Other Material
Specifications
Remove And Install Park Pawl And Operating Cam (In Tractor)
30K, 40K, and 50K Range Box
General Repair Procedures—Range Box
Recondition Neutral Centering System Not Used on Tractors with Left-Hand Reverser
Remove And Disassemble Shifter Cover
Reverse Lockout Components
Cross-Sectional View—Shifter Rails
Remove Shifter Rails And Forks
Install And Adjust Shifter Forks And Rails
Assemble And Install Shifter Cover
Determine Cone Point Shim Pack And Install Differential Drive Shaft
Cross-Sectional View—Input Shaft (30K)
Cross-Sectional View—Input Shaft (40K and 50K)
Remove And Disassemble Input Shaft
Assemble And Install Input Shaft
Adjust Input Shaft End Play
Section 56 - DRIVE SYSTEMS
Other Material
Specifications
MFWD Axle Identification—Version "A" and Version "B"
Remove MFWD Clutch
Install MFWD Clutch
Remove Non-Suspended MFWD Axle
Install Non-Suspended MFWD Axle
Remove Suspended MFWD Axle
Install Suspended Axle
Remove Final Drive
Install Final Drive
Remove Rear PTO Assembly
Install Rear PTO Assembly
Remove Front PTO Assembly
Install Front PTO Assembly
Group 05 - Controls
Specifications
PTO Switch
MFWD Switch
MFWD Solenoid
Differential Lock Switch
Differential Lock Solenoid
PTO Shift Lever
Group 10 - MFWD Clutch
Other Material
Specifications
General Repair Procedures—MFWD Clutch
Cross-Sectional View—PQT And PST MFWD Clutch Without Secondary Brake—(Transmission S.N. -013050)
Cross-Sectional View—PQT, PST And 40K AQT MFWD Clutch Without Secondary Brake— (Transmission S.N. 013051- )
Cross-Sectional View—PQT And PST MFWD Clutch With Secondary Brake— (Transmission S.N. -013050)
Cross-Sectional View—PQT, PST And 40K AQT MFWD Clutch With Secondary Brake— (Transmission S.N. 013051- )
Cross-Sectional View—50K AQT MFWD Clutch With Secondary Brake
Cross-Sectional View—40K AutoPowr/IVT MFWD Clutch Without Secondary Brake
Cross-Sectional View—40K AutoPowr/IVT MFWD Clutch With Secondary Brake
Cross-Sectional View—50K AutoPowr/IVT MFWD Clutch With Secondary Brake
Disassemble MFWD Clutch
Disassemble MFWD Clutch Pack
Assemble MFWD Clutch Pack
Group 15 - MFWD Axle
Other Material
Specifications
Version ‘B” Steering Cylinder Identification
Cross-Sectional View—Planetary Carrier and Wheel Hub
Remove, Recondition, And Install Planetary Carrier And Wheel Hub
Assemble And Install Planetary Carrier And Wheel Hub
Cross-Sectional View—Knuckle Spindle Assembly
Disassemble, Inspect, and Assemble Knuckle Spindle Assembly
Install MFWD Axle Into Repair Stand
Install Suspended MFWD Axle Into Repair Stand
Cross-Sectional View—Planetary Carrier-Wheel Hub-Knuckle Spindle-U-Joint/Axle Shaft Assembly
Remove And Install Planetary Carrier-Wheel Hub-Knuckle Spindle-U-Joint/Axle Shaft Assembly
Determine Kingpin Shim Pack
Remove Differential Housing
Cross-Sectional View—Differential Housing
Cross-Sectional View—Differential Housing—European and Suspended
Repair Differential Housing
Cross-Sectional View—Differential Drive Shaft and Input Quill
Cross-Sectional View—Differential Drive Shaft And Input Quill—Suspended MFWD Axle
Remove And Disassemble Differential Drive Shaft
Determine Differential Drive Shaft Cone Point Shim Pack
Assemble And Install Differential Drive Shaft
Check Ring Gear Backlash And Determine Differential Case Bearing Cup Shim Pack
Adjust Ring Gear Backlash
Backlash Shim Pack Example and Worksheet
Install Differential Case Bearing Cup and Differential Housing
Disassemble And Assemble Axle Housing
Determine And Install Axle Housing Bearing Cup Shim Pack
Bearing Cup Shim Pack Procedure
Preload Shim Pack Example And Worksheet
Cross-Sectional View—Steering Cylinder Housing Assembly—Non-Suspended MFWD Axle (Early Design)
Cross-Sectional View—Steering Cylinder Housing Assembly—Non-Suspended MFWD Axle (Late Design)
Cross-Sectional View—Steering Cylinder Housing Assembly—Suspended MFWD Axle
Remove And Disassemble Steering Cylinder
Assemble And Install Steering Cylinder
Replace MFWD Pivot Bushing
Group 16 - Suspended MFWD Axle Components
Other Material
Specifications
Replace Suspended MFWD Axle Position Sensor
Replace Suspended MFWD Axle Controller
Replace Load-Sense Shuttle Valve—Suspended MFWD Axle
Relieve Pressure From Suspended MFWD Axle Hydraulic System
Remove And Install Suspended MFWD Axle Hydraulic Control Valve
Recondition Suspended MFWD Axle Pressure Control, Pressure Relief, And Solenoid Valves
Recondition Suspended MFWD Axle Hydraulic Control Valve Assembly
Exploded View—Suspended MFWD Axle Hydraulic Control Valve
Remove And Install Suspended MFWD Axle Accumulators
Check And Charge Accumulators
Replace Suspended MFWD Axle Cylinder Hydraulic Lines
Remove Suspended MFWD Axle Cylinder
Install Suspended MFWD Axle Cylinder
Repair Suspended MFWD Axle Cylinder
Cross-Sectional View—Suspended MFWD Axle Cylinder
Recondition Piston Rod
Cross-Sectional View—Suspended MFWD Axle Cylinder Piston Seals
Assemble Piston Rod
Replace Oscillation Limiter Chain
Replace Panhard Link
Group 20 - Rear Differential
Specifications
General Repair Procedures—Rear Differential
Remove Differential
Adjust Differential Preload
Adjust Differential Backlash
Group 25 - Final Drive
Other Material
Specifications
General Repair Procedures—Final Drive
Remove Planet Pinion Carrier
Cross-Sectional View—Planet Pinion Carrier
Disassemble Planet Pinion Carrier
Exploded View—Planet Pinion Carrier
Assemble Planet Pinion Carrier
Cross-Sectional View—Rear Axle Housing And Shaft
Remove Axle Housing
Disassemble And Assemble Axle Shaft
Install Planet Pinion Carrier And Check Rolling Drag Torque (Non-Shimmed Axles)
Install Planet Pinion Carrier And Check Rolling Drag Torque (Shimmed Axles)
Group 30 - Rear PTO
Essential Tools
Specifications
General Repair Procedures—PTO
Repair PTO Clutch
Cross-Sectional View—PTO Clutch
Remove And Disassemble PTO Clutch
Assemble And Install PTO Clutch
Remove And Disassemble Countershaft
Cross-Sectional View—Two-Speed And Two-Speed Shiftable PTO Countershaft
Cross-Sectional View—Three-Speed Shiftable PTO Countershaft
Assemble And Install Countershaft
Cross-Sectional View—Two-Speed PTO Output Shaft
Cross-Sectional View—Two-Speed Shiftable PTO Output Shaft
Cross-Sectional View—Three-Speed Shiftable PTO Output Shaft
Remove And Disassemble Output Shaft
Assemble And Install PTO Output Shaft
Exploded View—Shiftable PTO Shifter
Remove PTO Shifter
Install PTO Shifter
Replace PTO Output Shaft Oil Seal
Remove Valve Housing
Disassemble And Assemble Valve Housing
Install Valve Housing
Group 35 - Drivelines
Specifications
Engine Coupler Shaft Assembly
Exploded View—Non-Suspended MFWD Axle Drive Shaft
Remove Suspended MFWD Axle Rear Driveline
Repair Suspended MFWD Axle Rear Driveline
Install Suspended MFWD Axle Rear Driveline
Remove And Install Suspended MFWD Axle Driveline Housing
Cross-Sectional View—Suspended MFWD Axle Driveline Support
Replace Suspended MFWD Axle Drive Shaft Rear Bearing
Replace Suspended MFWD Axle Spherical Bearing
Group 40 - Hydraulic Pump Drive
Specifications
General Repair Procedures—Pump Drive
Cross-Sectional View—Hydraulic Pump Drive
Remove And Disassemble Pump Drive Pinion
Remove And Disassemble Pump Drive Gear
Assemble And Install Pump Drive Gear
Assemble And Install Pump Drive Pinion
Check And Adjust Pump Drive Gear Backlash
Group 45 - Front PTO
Other Material
Specifications
Remove PTO Clutch And Pump
Disassemble Pump
Replace PTO Brake
Remove PTO Output Gear
Replace Idler Gear
Remove Modulating Valve
Install Modulating Valve
Install PTO Output Gear
Assemble PTO Clutch
Assemble Pump
Install PTO Clutch and Pump
Cross-Sectional View—Front PTO Driveline
Repair Front PTO Driveline
Repair Pressure And Lube Regulating Valves
Section 60 - STEERING AND BRAKES
Group 05 - Steering Column
Specifications
Repair Steering Column
Repair Steering Housing Assembly
Group 10 - Hydrostatic Steering
Specifications
Remove And Install Steering Valve
Exploded View—Steering Valve — 7710, 7810
Exploded View—Steering Valve With Dual Gerotor—7710, 7810
Disassemble, Inspect, And Assemble Steering Valve
Remove And Install Ground-Driven Steering Pump
Disassemble, Inspect, And Assemble Ground-Driven Steering Pump
Group 15 - Steering Cylinders
Specifications
Other Material
Service Parts Kits
MFWD Axle Identification—Version ‘A”and Version ‘B”
Remove And Install Steering Cylinder
Cross-Sectional And Exploded View—Steering Cylinder—Two-Wheel Drive
Cross-Sectional And Exploded View—Steering Cylinder—Version ‘A” MFWD Axle
Group 20 - Brake Valve
Service Parts Kits
Specifications
General Repair Procedures—Brake Valve
Remove And Install Brake Valve
Disassemble, Inspect, And Assemble Brake Valve
Bleed Brakes
Check Manual Brakes
Group 25 - Brake Components
Specifications
Remove, Inspect, And Install Brake Pistons, Plates, And Disks
Inspect And Adjust Secondary Brake
Group 30 - Trailer Brakes
Specifications
Remove And Install Hydraulic Trailer Brake Valve
Repair Hydraulic Trailer Brakes
Section 70 - HYDRAULICS
Specifications
Remove And Install Hitch-SCV Assembly
Remove And Install Main Hydraulic Pump
Remove And Install Charge Pump
Group 05 - Hydraulic System Repair
Specifications
General Repair Procedures—Hydraulic System
Use Special Wrench
Install Hydraulic Fittings
Drain Hydraulic System
Fill Hydraulic System
Group 10 - Hydraulic Pump And Charge Pump
Other Material
Service Parts Kits
Specifications
General Repair Procedures—Hydraulic Pumps
Remove And Install Hydraulic Pump Controller
Exploded View—Hydraulic Pump Controller
Disassemble, Inspect, And Assemble Pump Controller
Disassemble, Inspect, And Assemble Hydraulic Pump
Adjust Yoke Bearing Preload
Adjust Shaft Bearing Preload
Inspect Hydraulic Charge Pump
Group 15 - Hydraulic System Valves
Service Parts Kits
Specifications
General Repair Procedures—Hitch, Inlet-Priority, And Filter Bypass Valves
Remove, Inspect, And Install Hydraulic Filter Bypass
Disassemble, Inspect, And Assemble Inlet-Priority Valve
Remove And Install Hitch Valve
Identify Hitch Valve
Exploded View—Hitch Valve (Version ‘A”)
Exploded View—Hitch Valve (Version ‘B”)
Disassemble, Inspect, And Assemble Hitch Valve
Test Surge Relief Valve
Adjust Hitch Valve
Remove And Install Electro-Hydraulic Control Valve
Disassemble And Assemble Electro-Hydraulic Control Valve
Group 20 - Selective Control Valves And Couplers
Other Material
Service Parts Kits
Specifications
General Repair Procedures—Selective Control Valves And Couplers
Remove, Install, And Adjust SCV Linkage
Single Lever Loader Control Repair
SCV Identification
Remove, Inspect, And Install Selective Control Valves
Selective Control Valve—Exploded View—Three-Position
Selective Control Valve—Exploded View—Two-Position
Exploded View—Manual Selective Control Valve (Single-Position)
Replace Control Knobs
Inspect Poppet Load-Check Valves
Inspect Pressure Compensator Valve—Three-Position SCV
Inspect Metering Valve—Three-Position SCV
Inspect Metering Valve—Two-Position SCV
Disassemble, Inspect, And Assemble Control Valve—Three-Position SCV
Disassemble, Inspect, And Assemble Control Valve—Two-Position SCV
Disassemble, Inspect, And Assemble Control Valve (Manual SCV-Single Position)
Disassemble, Inspect, And Assemble Couplers
Group 25 - Hitch
Other Material
Specifications
Remove And Install Lift Cylinders
Cross-Sectional And Exploded View—Lift Cylinder
Disassemble, Inspect, And Assemble Lift Cylinder
Replace Rockshaft Housing Bushings
Repair Draft Link
Group 30 - Bleed Hydraulic System
Section 80 - MISCELLANEOUS
Specifications
Remove Front Axle
Install Front Axle
Group 05 - Front Axle
Other Material
Specifications
Replace Knee Bushings
Group 10 - Hood
Specifications
Remove, Install, And Adjust Hood
Group 15 - Wagon And Pick-Up Hitch
Specifications
Repair Wagon Hitch
Adjust Wagon Hitch Release
Repair Pick-Up Hitch
Adjust Pick-Up Hitch
Section 90 - OPERATOR STATION
Specifications
Remove Cab
Install Cab
Remove And Install Open-Station ROPS
Group 05 - HVAC
Remove Evaporator-Heater Core
Install Evaporator-Heater Core
Remove, Install, And Adjust Temperature Control Cable
Remove Heater Control Valve
Leak Test Heater Control Valve
Install Heater Control Valve
Remove, Install, And Adjust Air Flow Control Cable
Remove And Install Air Plenum
Remove and Install Air Manifold
Group 10 - Air Conditioning System
Other Material
Service Parts Kits
Specifications
Hose and Tubing O-Ring Connection Torques
Air Conditioning System—Diagram
Air Conditioning System Fitting—Reference Chart
Leak Test With Dye
Discharge Air Conditioning System
Remove And Install Compressor
Test Volumetric Efficiency
Test Shaft Seal Leakage
Disassemble And Assemble Compressor Clutch
Check Clutch Hub Clearance
Inspect Compressor Manifold
Inspect Compressor Thermal Bypass Valve
Disassemble, Inspect, And Assemble Compressor
Remove And Install Compressor Relief Valve
Replace Receiver-Dryer
Leak Test Condenser
Leak Test Evaporator
Remove And Install Expansion Valve
System Information
Flush Air Conditioning System
Purge Air Conditioning System
Evacuate Air Conditioning System
Refrigerant Oil Information
Check Compressor Oil Charge
Determine Correct Refrigerant Oil Charge
Add Refrigerant Oil to System
Add Refrigerant Oil to Pressurized System
Charge Air Conditioning System
Group 20 - Seat
Other Material
Remove Seat And Mechanical Suspension
Disassemble, Inspect, And Assemble Mechanical Suspension Assembly
Install Mechanical Suspension Assembly
Remove Seat And Air Suspension
Remove Seat From Suspension
Remove Swivel Plate
Disassemble, Inspect, and Assemble Air Suspension Assembly
Install Seat and Air Suspension
Group 25 - ROPS and Cab
Check ROPS
Repair Cab Door Latch
Cab Door Adjustment—Step 1
Cab Door Adjustment—Step 2
Cab Door Adjustment—Step 3
Cab Door Adjustment—Step 4
Cab Door Adjustment—Step 5
Section 99 - DEALER FABRICATED TOOLS
Group 05 - Fabricated Tools
DFRW4—Axle Wheel Hub Tool
DFRW20—Compressor Holding Fixture
DFRW29—Final Drive Housing Adapter
DFRW30—Axle Jacking Tool
DRFW60 - DFRW61 - DFRW62—Extension Harnesses
DFRW63 - DFRW64 - DFRW65 - DFRW66 - DFRW81—Tap-Out Harnesses
DFRW70—Holding Tool
DFRW77—Rear Tractor Access Platform
DFRW78—Seat Support Tray
DFRW79—Piston Holding Tool
DFRW80—Front PTO Lifting Brackets And Spacers
DFRW87—Pick-Up Hitch Adapter Plate
DFRW108—Park Rod Adjusting Nut Tool
DFRW117—Transmission-Hydraulic Flusher
DFRW131—Cone Stand Adapter
DFRW132—Differential Side Bevel Gear End Play Tool
DFRW135—Suspended MFWD Axle Housing Bracket
DFRW138—Open-Station Platform Support
DFRW139—Evaporator Flushing Block
DFRW141 Stepper Motor Adjustment Harness
DFRW149—Tractor Side Frame Lifting Bracket
DFRW151—Radiator Cap Adapter
