Martin Welker
104
230,310
John Deere 730 And 735 Mower Conditioners Operators Manual OMCC59358
Format: HTML
Brand: John Deere
Type of Machine: Mower Conditioners
Model: John Deere 730 And 735 Mower Conditioners
Parts Number: OMCC59358
Foreword
Predelivery Inspection
Section 00 - Identification Views
Identification View
Section 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Maintain a Safety Area Around the Machine
Operate Safely
Keep Riders Off Machine
Observe Road Traffic Regulations
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Service Machines Safely
Check Machine Safety
Stay Clear of Rotating Drivelines
Avoid Injury from Thrown Objects
Use Safety Lights and Devices
Service Tires Safely
Tow Loads Safely
Use a Safety Chain
Practice Safe Maintenance
Secure Raised Mowing Unit
Electrical Circuit and Control Power Supply Requirement
Support Machine Properly
Avoid High-Pressure Fluids
Avoid High-Pressure Jet on Safety Decals
Avoid High-Pressure Jet on Cylinders
Dispose of Waste Properly
Section 10 - Safety Signs
Pictorial Safety Signs
Operator's Manual
Repair and Maintenance
Mower-Conditioner Driveline
Noise Protection
Drive Belt Guard
Roll Conditioner Drivelines Guard
Rotor
Cutterbar
Cutterbar Curtains
Mowing Unit
Raised Grouper
Grouper Safety Lock
Grouper
Section 15 - Preparing the Tractor
Selecting Tractor PTO Speed
Adjusting Sway Blocks
Checking Ballast, Wheel Spacing and Tire Inflation
Setting Selective Control Valves
Section 20 - Preparing the Mower-Conditioner
Checking Tire Inflation
Checking Wheel Hardware Torque
Adjusting Telescoping Hook-Up
Section 25 - Attaching and Detaching
Attach Swivel Hitch to the Tractor
Attach Resume Chain to the Tractor
Secure the Jackstand in Transport Position
Attach PTO Driveline
Connecting Mower-Conditioner to Tractor Hydraulic System
Connecting Road Light Wiring Harness to Tractor
Connecting Wiring Harness for Grouper/Hydraulically Controlled Windrow Forming Shields (if Equipped)
Setting Tongue Swing Time
Detach Swivel Hitch from Tractor
Section 30 - Transporting
Prepare Mower-Conditioner for Transport
Towing Mower-Conditioner on Public Roads
Section 40 - Break-In Period
Breaking-in Mower-Conditioner
Section 45 - Operating the Mower-Conditioner
Follow Safe Operating Procedures
Daily Checks
Prepare Mower-Conditioner for Field Operation
Raising Curtains
Lowering Curtains
Adjusting Cutting Height - Manual Control
Adjusting Cutting Height - Hydraulic Control
Adjusting Gauge Shoes
Installing Gauge Shoe Spacers (If Equipped)
Adjusting Platform Float
Adjust Lift Cylinder Position
Opening a New Field
Turn in Field
Making a Half-turn in Field
Adjusting Windrow Width (Without Wide Spread Deflector)
Adjust Windrow Width (With Wide Spread Deflectors)
Adjusting Windrow Width (With Hydraulically Controlled Windrow Forming Shields)
Operating the Hydraulically Controlled Windrow Forming Shields
Adjust Windrow Form
Check Conditioning Effect (Impeller Mower-Conditioner)
Adjust Conditioning Intensity with Impeller
Changing Impeller Rotor Speed
Check Conditioning Effect (Roll Conditioner)
Adjust Conditioning Intensity (Roll Mower-Conditioner up to S.N. 89999)
Adjust Conditioning Intensity (Roll Mower-Conditioner from S.N. 90000)
Adjust Roll Spacing
Section 46 - Operating the Grouper
Raising or Lowering the Grouper
Grouper Locking Device
Adjust Rear Deflector
Adjusting Windrow Forming Shields
Adjusting Grouper Canvas Speed
Adjusting Grouper Canvas Height
Adjusting Grouper Arm Extension (If equipped)
Recommendations
Mowing Back and Forth
Mowing Around
Mowing with a Front Mower-Conditioner
Section 50 - Attachments
1000 RPM Rotor Speed
Gauge Shoe Spacers
Wrench (E83373)
Tongue Height Resume Chain
Hydraulic Cutting-Height Control
Grouper
Long Windrow Forming Shield
Section 55 - Lubrication and Maintenance
Lubricating and Maintaining Machine Safely
Observe Service Intervals
Grease
Cutterbar Oil
Gear Case Oil
Transmission and Hydraulic Oil
Mixing of Lubricants
Lubricant Storage
Perform Lubrication and Maintenance
As Required - Float Spring Cranks
Every 10 Hours - Primary Driveline
Every 10 Hours - Overrunning Coupler
Every 10 Hours - Tongue Rear Joint Cross
Every 10 Hours - Tongue Pivot Driveline
Every 10 Hours - Platform Driveline (1000 rpm Driveline)
Every 10 Hours - Platform Driveline (540 rpm Driveline)
Every 10 Hours - Cutterbar
Every 10 Hours - Cutterbar Driveline
Every 10 Hours - Wheelarm Pivots (Left-Hand and Right-Hand Side)
Every 10 Hours - Left-Hand Cutterbar Link Pivots
Every 10 Hours - Grouper Frame Pivot Points
Every 10 Hours - Roll Pivots (Roll Conditioner) (up to S.N. 89999)
Every 10 Hours - Roll Pivots (Roll Conditioner) (from S.N. 90000)
Every 10 Hours - Roll Driveline
After the First 50 Hours - Swivel Hitch Gear Cases
After the First 50 Hours - Cutterbar Input Drive Gear Case
After the first 50 Hours - Conditioner Roll Drive Gear Case
Every 50 Hours - Checking Cutterbar Oil Level
Every 50 Hours - Belt Idler Tensioning Spring
Every 50 Hours - Grouper Canvas Tension
Every 50 Hours - Hydraulic Hoses
Every 100 Hours - Cutterbar Input Drive Gear Case Oil Level
Every 250 Hours or Yearly - Draining and Refilling Cutterbar
Every 250 Hours or Yearly - Drain and Refill Swivel Hitch Gear Cases
Every 250 Hours or Yearly - Swivel Hitch Gear Case Pivot
Every 250 Hours or Yearly - Cutterbar Driveline
Every 250 Hours or Yearly - Drain and Refill Conditioner Roll Drive Gear Case
Every 500 Hours or Yearly - Drain and Refill Grouper Oil Reservoir
Every 500 Hours or Yearly - Changing Grouper Oil Filter
Every 1000 Hours or Yearly - Draining and Refilling Cutterbar Input Drive Gear Case
Each Season - Phasing Cylinders
Every 6 Years - Hydraulic Hoses
Section 60 - Troubleshooting
Mower-Conditioner Operation
Telescoping Hook-Up Locking System
End Yokes
Inboard Yokes
Profile Tubes
Telescoping Hook-Up Guards
Grouper Electrical System
Grouper Canvas Operation
Grouper Canvas Drive
Electrical System of Hydraulically Controlled Windrow Forming Shields
Section 65 - Service
Practice Safe Service Procedures
Use Genuine John Deere Parts
Draining Oil from Mowing Unit Lift Circuit
Replacing Main Drive Belt
Adjust Main Drive Belt Tension
Replacing Impeller Drive Belt
Adjusting Impeller Drive Belt Tension
Replacing Roll Conditioner Drive Belt
Adjusting Roll Conditioner Drive Belt Tension
Synchronize Rolls
Removing Disks
Installing and Synchronizing Disks
Removing Knives
Understand Direction of Knife Rotation
Installing Knives
Checking Knives
Checking Knife Wear
Checking Knife Fitting Hole
Checking Knife Hardware
Checking Knife Bolt Wear
Checking Knife Lock Nut Wear
Replacing Wear Shield on Knife Bolt
Replacing Disk Driver
Replace Left-Hand End Converging Disk Driver
Replace Right-Hand End Converging Disk Driver
Replace Rotor Tines
Changing wheel
Adjusting Grouper Canvas Tension
Adjusting Grouper Roll Parallelism
Adjusting Grouper Position Switch (up to S.N. 79999)
Adjusting Grouper Position Switch (from S.N. 80000)
Replacing Grouper Rubber Seal
Replacing Grouper Canvas
Section 70 - Storage
Storing Mower-Conditioner (End of Season)
Removing Mower-Conditioner from Storage (Beginning of Season)
Section 75 - Specifications
730 Mower-Conditioner
735 Mower-Conditioner
Grouper
EC Declaration of Conformity
Section 80 - Serial Numbers
Serial Number Plate
Serial Number Plate Description
Mower-Conditioner Serial Number Record
Grouper Serial Number Record
Keep Proof of Ownership
Keep Machines Secure
Section IBC - John Deere Service Keeps You On The Job
John Deere Parts
The Right Tools
Well-Trained Technicians
Prompt Service
