John Deere 724 732 740 724i 732i 740i Trailed Crop Sprayers Diagnostic and Repair Manual TM402919
Brand: John Deere
Type of Machine: Trailed Crop Sprayers
Type of Manual: Diagnostic and Repair Manual
Model: 724, 732, 740, 724i, 732i, and 740i Trailed Crop Sprayers with ELC-1/EHC-2 Control Unit/with EL-4 Control Unit
Part Number: TM402919
Publication Date: 2012
Number of Pages: 857 Pages
FOREWORD
Section 05 - SAFETY
Group 05 - Safety Information
Admissible Use
Recognize Safety Information
Understand Signal Words
Keep Riders Off Machine
Prepare for Emergencies
Use Safety Lights and Devices
Work in Clean Area
Chemical Safety
Handle Agricultural Chemicals Safely
Service and Operate Chemical Sprayers Safely
Danger Symbols
Mechanical Safety
Non-Permissible Use
Operators
Working Area
Wear Protective Clothing
Illuminate Work Area Safely
Respiratory Protection
Skin Protection
Maintenance of Means of Personal Protection
Tractor Cab
Use Proper Lifting Equipment
Safety During Maintenance Work
Avoid High-Pressure Fluids
Service Accumulator Systems Safely
Service Tires Safely
Avoid Heating Near Pressurized Fluid Lines
Use Proper Tools
Construct Dealer-Made Tools Safely
Service Machines Safely
Remove Paint Before Welding or Heating
Servicing Electronic Control Units
Welding Near Electronic Control Units
Keep Electronic Control Unit Connectors Clean
General Machine Operation Safety
Transport in the Field and on the Road
Operate Safely
Live With Safety
Section 10 - GENERAL INFORMATION
Group 05 - Description of the Machine
Identification Views
Machine Composition
Group 10 - Torques for Hardware
Unified Inch Bolt and Screw Torque Values
Metric Bolt and Screw Torque Values
Metric Stainless Steel Bolt and Screw Torque Values
Group 15 - Specifications
Capacities
Dimensions and Weights
Sound Level
Electrical Connection Requirements
Products to be Processed
Materials Used
Physical Operating Conditions
Lubricant Storage
Section 40 - ELECTRICAL SYSTEM
Group 05 - Connector Repair
Essential or Recommended Tools
Electrical Connector Handling
Disconnecting Electrical Circuit
Connector Information
Repair Procedure R-A
Repair Procedure R-B
Repair Procedure R-C
Repair Procedure R-E
Repair Procedure R-F
Repair Procedure R-I
Repair Procedure R-AA
Repair Procedure R-AE
Repair Procedure R-AM
Repair Procedure R-AN
Repair Procedure R-AO
Repair Procedure R-AP
Repair Procedure R-AQ
Group 10 - Sensors
Specifications
Remove and Install Automatic Tracking System Sensor (Steering Drawbar)
Remove and Install Center Position Sensors (Steering Drawbar)
Remove and Install Flow Sensor
Remove and Install Digital Level Indicator Sensor
Remove and Install Digital Level Indicator Alarm
Remove and Install Solution Pressure Sensor
Remove and Install Wheel Speed Sensor
Remove and Install Spray Boom Transport Lock Switch
Remove and Install Spray Boom Position Switch
Remove and Install Spray Boom Suspension Sensor
Section 60 - BRAKE SYSTEM
Group 05 - Hydraulic Brake System
Hydraulic Brake System (Not for Germany)
Remove and Install Parking Brake Operating Assembly
Remove and Install Tension Cable Disk
Adjust Parking Brake
Group 10 - Pneumatic Brake System
Public Roads
Replace Coupling
Clean/Replace Line Filter Strainer
Replace Release Valve
Replace Brake Power Regulator
Replace Brake Valve
Replace Quick Release Valve or Switch Valve
Replace Shut-Off Valve
Replace Compressed Air Storage Tank
Replace Brake Cylinder
Section 70 - HYDRAULIC SYSTEM
Group 05 - Hydraulic Functions
General Information
Group 10 - Hydraulic Cylinders
Other Material
Specifications
Remove and Install Hydraulic Brake Cylinder
Disassemble and Assemble Hydraulic Brake Cylinder
Remove and Install Secondary Fold Cylinder
Disassemble and Assemble Secondary Fold Cylinder
Remove and Install Height Adjustment Cylinders
Remove and Install Pendulum Lock Cylinder
Disassemble and Assemble Pendulum Lock Cylinder
Remove and Install Boom Fold Cylinder
Remove and Install Spray Boom Tilt Cylinder
Remove and Install Drawbar Steering Cylinder
Disassemble and Assemble Boom Fold, Boom Tilt, and Drawbar Steering Cylinders
Remove and Install Variable Geometry Cylinder
Disassemble and Assemble Variable Geometry Cylinder
Disassemble and Assemble Hydraulic Fluid Pressure Restrictor Assembly
Group 15 - Control Valves
Specifications
General Repair Information
Disassemble and Assemble Load Sensing Flow Control Valve
Disassemble and Assemble Hydraulic Valve Stack (Double Folding Boom)
Disassemble and Assemble Hydraulic Valve Stack (Triple Folding Boom)
Group 20 - Accumulator
Other Material
Specifications
Remove and Install Hydraulic Distributor with Accumulator
Disassemble and Assemble Hydraulic Distributor with Accumulator
Section 80 - FRAME AND SPRAY BOOM
Group 05 - Welding and Repair
Unauthorized Modifications
Frame Repair
Welding
Emergency Crack Repair
Emergency ”T” Joint Repair
Skip Welding
Stress Relief (Normalizing)
Group 10 - Spray Boom
Prepare Sprayer for Service of Spray Boom
Remove and Install Breakaway Section
Remove and Install Breakaway Section Tension Spring
Remove and Install Outer Spray Boom Section
Remove and Install Inner Spray Boom Section or Complete Spray Boom (On One Side)
Remove and Install Center Spray Boom Frame
Remove and Install Spray Boom Hinge
Remove and Install Spindle
Remove and Install Pressure Roll for Breakaway Section
Remove and Install Spray Boom Transport Support and Roll
Remove and Install Spray Boom Transport Bracket
Group 15 - Center Frame
Remove and Install Center Attaching Frame
Remove and Install Protection Plates
Remove and Install Shock Absorber (Center Attaching Frame)
Remove and Install Shock Absorber (Anti-Yaw)
Remove and Install Anti-Yaw Shock Absorber Arm
Remove and Install Anti-Yaw Dampener
Remove and Install Center Frame Roll (Front)
Remove and Install Center Frame Roll (Rear)
Remove and Install Spray Boom Suspension Springs
Group 20 - Axle
Other Material
Specifications
Remove and Install Axle Assembly (Adjustable)
Remove and Install Adjustable Axle
Remove and Install Extension Spring
Remove and Install Brake Shoes and Camshaft (Adjustable Axle)
Remove and Install Camshaft Support (Adjustable Axle)
Remove and Install Roller Bearings (Wheel Hub)
Remove and Install Brake Drum or Back-Up Ring
Amount of Grease For Each Wheel Hub
Inspect Brake Drum, Brake Shoes, and Brake Linings
Group 25 - Drawbar
Other Material
Specifications
Remove and Install Steering Drawbar
Remove and Install Tow Eye
Remove and Install Connecting Bracket (Steering Drawbar)
Group 30 - Parallelogram
Other Material
Remove and Install Parallelogram Arm (Top)
Remove and Install Parallelogram Arm (Bottom)
Remove and Install Parallelogram Vertical Lift Arm
Remove and Install Parallelogram Lift Arm
Remove and Install Isolators
Group 35 - Adjustments
Specifications
Adjust Automatic Tracking System With Steering Drawbar
Adjust Steering Cylinder Speed
Adjust Spray Boom Transport Position
Adjust Spray Boom Alignment
Balance Spray Boom
Track Width Adjustment With Sliding Axle
Adjust Anti-Yaw System
Adjust Spray Boom Suspension
Adjust Center Position of Steering Drawbar
Section 100 - TANKS AND ACCESSORIES
Group 05 - Solution Tank
Cleaning the Machine
Processing Residual Liquids with EL-4
Processing Residual Liquids with Ring Line Circulation and EL-4
Processing Residual Liquids with EHC-2
Processing Residual Liquids with Ring Line Circulation and EHC-2
Processing Residual Liquids with MFC
Processing Residual Liquids with Ring Line Circulation and MFC
Remove and Install Solution Tank
Remove and Install Solution Tank Lid
Disassemble and Assemble Solution Tank Lid
Remove and Install Solution Tank Breather Valve
Remove and Install Solution Tank Lid Adapter
Remove and Install Drain Valve
Disassemble and Assemble Drain Valve
Remove and Install Solution Tank Level Indicator
Remove and Install Solution Tank Rinsing Nozzle
Remove and Install Injectors for Agitation
Group 10 - Rinse Tank
Remove and Install Rinse Tank
Remove and Install Rinse Tank Breather Vent
Remove and Install Rinse Tank Quick Coupler Assembly
Group 15 - Hand Wash Tank
Remove and Install Hand Wash Tank
Remove and Install Hand Wash Tank Bleed Valve
Group 20 - Polyethylene Tank Repair
Repair Polyethylene Plastic
Install RIVNUT RIVNUT is a registered trademark of RIVNUT Engineered Products Inc. Threaded Inserts
Section 110 - PUMP
Group 05 - Pump
Other Material
Specifications
Remove and Install Pump
Disassemble and Assemble Pump
Remove and Install Pump Oil Seal
Disassemble and Assemble Pump Accumulator
Section 120 - LINES AND VALVES
Group 05 - Spray Line
Remove and Install Spray Line Valve
Disassemble and Assemble Spray Line Valve
Section 130 - ACTIVATION SYSTEMS
Group 05 - Flow Meter
Remove and Install Flow Meter
Disassemble and Assemble Flow Meter
Group 10 - Ball Valves
Remove and Install Protective Cap on Left-Hand Side
Remove and Install External Pump Filling Control Valve
Disassemble and Assemble External Pump Filling Control Valve
Remove and Install Pressure Selection Valve
Disassemble and Assemble Pressure Selection Valve
Remove and Install Suction Valve
Disassemble and Assemble Suction Valve
Remove and Install Injector Shut-Off Valve
Disassemble and Assemble Injector Shut-Off Valve
Remove and Install Ring Line Circulation Valve
Disassemble and Assemble Ring Line Circulation Valve
Group 15 - Regulating Unit
Remove and Install Primary Pressure Regulator
Disassemble and Assemble Primary Pressure Regulator
Remove and Install Pressure Regulator
Disassemble and Assemble Pressure Regulator
Remove and Install Suction Filter
Remove and Install Pressure Filter
Remove and Install Circulation Valve
Disassemble and Assemble Circulation Valve
Section 140 - SPRAY NOZZLES
Group 05 - Spray Nozzles
Remove and Install Nozzle Holder (5-Way)
Disassemble and Assemble Nozzle Holder (5-Way)
Remove and Install Nozzle Holder (Single)
Disassemble and Assemble Nozzle Holder (Single)
Remove and Install Spray Nozzle Solenoid
Section 211 - DIAGNOSTIC TROUBLE CODES WITH GREENSTAR SPRAYER CONTROL
Group 01 - SPC Codes
SPC 002128.09 - Connection To Virtual Terminal Lost
SPC 002160.09 - Connection To EPM1 Lost
SPC 002161.09 - Connection To EPM2 Lost
SPC 002162.09 - Connection To EPM3 Lost
SPC 002163.09 - Connection To EPM4 Lost
SPC 002205.09 - Connection To BoomTrac Lost
SPC 002394.05 - Working Light Open Load
SPC 002394.06 - Working Light Short To Ground
SPC 520195.05 - Master Water Valve Open Load
SPC 520195.06 - Master Water Valve Short To Ground
SPC 520197.02 - Controller ID Failure
SPC 520300.02 - Left BoomTrac Sensor Out of Range
SPC 520301.02 - Right BoomTrac Sensor Out of Range
SPC 520401.05 - OC Solenoid Open Load
SPC 520401.06 - OC Solenoid Short To Ground
SPC 520402.05 - Pendulum Lock On Open Load
SPC 520402.06 - Pendulum Lock On Short To Ground
SPC 520403.05 - Pendulum Lock Off Open Load
SPC 520403.06 - Pendulum Lock Off Short To Ground
SPC 520503.05 - Right Outer Nozzle Open Load
SPC 520503.06 - Right Outer Nozzle Short To Ground
SPC 520504.05 - Left Outer Nozzle Open Load
SPC 520504.06 - Left Outer Nozzle Short To Ground
SPC 520601.05 - Free Function Open Load
SPC 520601.06 - Free Function Short To Ground
SPC 520704.00 - Pump 1 Oil Level High
SPC 520704.01 - Pump 1 Oil Level Low
SPC 521101.05 - High Side 6 EPM1 Open Load
SPC 521101.06 - High Side 6 EPM1 Short To Ground
SPC 521200.05 - High Side 3 EPM opt Open Load
SPC 521200.06 - High Side 3 EPM opt Short To Ground
SPC 521201.05 - High Side 4 EPM opt Open Load
SPC 521201.06 - High Side 4 EPM opt Short To Ground
SPC 521202.05 - High Side 6 EPM opt Open Load
SPC 521202.06 - High Side 6 EPM opt Short To Ground
SPC 523382.05 - Agitation Open Load
SPC 523382.06 - Agitation Short To Ground
SPC 523409.05 - Drawbar Right Open Load
SPC 523409.06 - Drawbar Right Short To Ground
SPC 523410.05 - Drawbar Left Open Load
SPC 523410.06 - Drawbar Left Short To Ground
SPC 523411.05 - Height Adjustment UP Open Load
SPC 523411.06 - Height Adjustment UP Short To Ground
SPC 523412.05 - Boom Tilt Left Open Load
SPC 523412.06 - Boom Tilt Left Short To Ground
SPC 523413.05 - Boom Tilt Right Open Load
SPC 523413.06 - Boom Tilt Right Short To Ground
SPC 523414.05 - Height Adjustment Down Open Load
SPC 523414.06 - Height Adjustment Down Short To Ground
SPC 523417.05 - LS Solenoid Open Load
SPC 523417.06 - LS Solenoid Short To Ground
SPC 523418.05 - Horn Open Load
SPC 523418.06 - Horn Short To Ground
SPC 523422.05 - Center Section Valve Open Load
SPC 523422.06 - Center Section Valve Short To Ground
SPC 523423.05 - Right Fence-Edge Spray Nozzle Open Load
SPC 523423.06 - Right Fence-Edge Spray Nozzle Short To Ground
SPC 523432.05 - Section Water Valve R4 Open Load
SPC 523432.06 - Section Water Valve R4 Short To Ground
SPC 523434.05 - Section Water Valve R3 Open Load
SPC 523434.06 - Section Water Valve R3 Short To Ground
SPC 523435.05 - Section Water Valve R2 Open Load
SPC 523435.06 - Section Water Valve R2 Short To Ground
SPC 523439.05 - Section Water Valve R1 Open Load
SPC 523439.06 - Section Water Valve R1 Short To Ground
SPC 523443.05 - Left Fence-Edge Spray Nozzle Open Load
SPC 523443.06 - Left Fence-Edge Spray Nozzle Short To Ground
SPC 523450.05 - Section Water Valve L4 Open Load
SPC 523450.06 - Section Water Valve L4 Short To Ground
SPC 523452.05 - Section Water Valve L3 Open
SPC 523452.06 - Section Water Valve L3 Short To Ground
SPC 523453.05 - Section Water Valve L2 Open Load
SPC 523453.06 - Section Water Valve L2 Short To Ground
SPC 523454.05 - Section Water Valve L1 Open Load
SPC 523454.06 - Section Water Valve L1 Short To Ground
SPC 523465.05 - Boom Fold Tip Left Out Open Load
SPC 523465.06 - Boom Fold Tip Left Out Short To Ground
SPC 523466.05 - Boom Fold Tip Left In Open Load
SPC 523466.06 - Boom Fold Tip Left In Short To Ground
SPC 523467.05 - Boom Fold Left In Open Load
SPC 523467.06 - Boom Fold Left In Short To Ground
SPC 523468.05 - Boom Fold Left Out Open Load
SPC 523468.06 - Boom Fold Left Out Short To Ground
SPC 523469.05 - Boom Fold Right Out Open Load
SPC 523469.06 - Boom Fold Right Out Short To Ground
SPC 523470.05 - Boom Fold Right In Open Load
SPC 523470.06 - Boom Fold Right In Short To Ground
SPC 523471.05 - Boom Fold Tip Right In Open Load
SPC 523471.06 - Boom Fold Tip Right In Short To Ground
SPC 523472.05 - Boom Fold Tip Right Out Open Load
SPC 523472.06 - Boom Fold Tip Right Out Short To Ground
SPC 523479.05 - Variable Geometry Left Down Open Load
SPC 523479.06 - Variable Geometry Left Down Short To Ground
SPC 523480.05 - Variable Geometry Right Down Open Load
SPC 523480.06 - Variable Geometry Right Down Short To Ground
SPC 523481.05 - Variable Geometry Left Up Open Load
SPC 523481.06 - Variable Geometry Left Up Short To Ground
SPC 523482.05 - Variable Geometry Right Up Open Load
SPC 523482.06 - Variable Geometry Right Up Short To Ground
Section 212 - OBSERVABLE SYMPTOMS
Group 01 - Electrical Symptoms
Agitation
Boom Fold
Boom Raise and Lower
Boom Tilt
BoomTrac
Boom Variable Geometry
CAN Bus
Control Unit Power — EPM
Control Unit Power — SPC
Hydraulic System Type
Lights — Work
Multifunction Control Lever
Power Distribution
Ring Line System
Solution Pressure
Solution Pump Oil Level
Solution System Auto-Dilute
Spray Rate Control
Spray Valve Control
Tank Water Level
Wheel Speed
Group 02 - Brake Symptoms
Hydraulic Brake Diagnostics
Pneumatic Brakes Diagnostics
Group 03 - Hydraulic Symptoms
Overall Hydraulics
Auto-Dilute Hydraulic System
Boom Fold Hydraulic System
Boom Pendulum Lock Hydraulic System
Boom Raise Hydraulic System
Boom Tilt Hydraulic System
Boom Variable Geometry Hydraulic System
Drawbar Steering Hydraulic System
Group 04 - Solution System Symptoms
Solution System Diagnostics
Section 240 - ELECTRICAL DIAGNOSIS AND TESTS
Group 05A - General Information
How to Use the Electrical Diagnostic Section
Electrical Schematic Symbols
Intermittent Fault Diagnostics
Programming Procedure
Obtain Software Payload
Program Control Unit
Group 05B - Component Identification
Electrical Component Identification Legend
Fuses
Group 10A - Accessing Diagnostic Codes and Addresses
Accessing GREENSTAR 2 Diagnostic Trouble Codes
Accessing GREENSTAR 2 Diagnostic Addresses
Technician Mode Procedure
GreenStar Display Screen Capture and Debug Files
Group 10B - Diagnostic Trouble Codes
SPC Codes
Group 10C - Diagnostic Addresses
SPC Addresses
Group 10D - System Overview Schematics
System Overview ISOBUS 700i Schematic
Group 15A - Agitation
Agitation Theory of Operation 700i Series
Agitation Schematic 700i Series
Group 15B - Boom Fold
Boom Fold Theory of Operation 700i Series
Boom Fold Schematic 700i Series
Group 15C - Boom Raise and Lower
Boom Raise and Lower Theory of Operation 700i Series
Boom Raise and Lower Schematic 700i Series
Group 15D - Boom Tilt
Boom Tilt Theory of Operation 700i Series
Boom Tilt Schematic 700i Series
Group 15E - BoomTrac
BoomTrac Theory of Operation
BoomTrac Schematic
Group 15F - Boom Variable Geometry
Boom Variable Geometry Theory of Operation 700i Series
Boom Variable Geometry Schematic 700i Series
Group 15G - CAN Bus
CAN Bus Theory of Operation
CAN Bus Schematic
Group 15H - Control Unit Power — EPM
EPM Power Theory of Operation
EPM and BoomTrac Control Unit Power Schematic
Group 15I - Control Unit Power — SPC
SPC Power Theory of Operation
SPC Power Schematic
Group 15J - Drawbar Steering
Drawbar Steering Theory of Operation 700i Series
Drawbar Steering Schematic 700i Series
Group 15K - Hydraulic System Type
Hydraulic System Type Electrical Theory of Operation 700i Series
Hydraulic System Type Electrical Schematic 700i Series
Group 15L - Lights — Public Road Travel
Public Road Travel Lights Theory of Operation
Public Road Travel Lights Schematic
Public Road Travel Lights Schematic — Denmark
Public Road Travel Lights Schematic — France
Group 15M - Lights — Work 700i Series
Work Lights Theory of Operation
Work Lights Schematic
Group 15N - Multi-Function Control Lever
Multi-Function Control Lever Theory of Operation
Multi-Function Control Lever Schematic
Group 15O - Power Distribution 700i Series
Power Distribution Theory of Operation
Power Distribution Schematic
Group 15P - Solution Pressure 700i Series
Solution Pressure Theory of Operation
Solution Pressure Schematic
Group 15Q - Solution Pump Oil Level 700i Series
Solution Pump Oil Level Theory of Operation
Solution Pump Oil Level Schematic
Group 15R - Solution System AutoDilute 700i Series
AutoDilute Theory of Operation
AutoDilute Schematic
Group 15S - Spray Rate Control 700i Series
Spray Rate Control Theory of Operation
Spray Rate Control Schematic
Group 15T - Spray Valve Control 700i Series
Spray Valve Control Theory of Operation
Spray Valve Control Schematic
Group 15U - Tank Water Level 700i Series
Water Level Theory of Operation
Water Level Schematic
Group 15V - Wheel Speed 700i Series
Wheel Speed Theory of Operation
Wheel Speed Schematic
Group 15W - Power Supply 3 Pole Cobo Connector Schematic
Group 15X - EL-4 Connection 700 V3 Schematic
Group 15Y - EL-4 + Tankmatic Connection Schematic
Group 15Z - EL-4 + Tankmatic Connection V2 Schematic
Group 15AA - EHS-1 for 3 Part Folding Boom Connection Schematic
Group 15AB - EL-4 + Off Center Nozzle Valves Connection Schematic 700
Group 15AC - Update to B-Motor Schematic
Group 15AD - EL-4 + Independent Yaw Suspension Connection Schematic 700
Group 15AE - EHB-1 700 Hydac Wiring Harness
Group 15AF - EHB-1 700 TFI Wiring Harness
Group 15AG - EHB-2 700 TFI Wiring Harness
Group 15AH - EHB-2 700 with Variable Geometry Hydac Wiring Harness
Group 15AI - EHB-2 700 without Variable Geometry Hydac Wiring Harness
Group 15AJ - EHS-1 700 Wiring Harness
Group 15AK - EHS-1 700 TFI Wiring Harness
Group 15AL - EL-4 and Digital Tank Display Setup
Group 15AM - Cable/Wire List for 700 with EL-4 Wiring Harness
Group 15AN - EL-4 Main Board
EL-4 Main Board
Group 15AO - EHB2 / EHB1 Hydraulics Auxiliary Connector
Group 15AP - EHS1 Auxiliary Connector
Group 20 - Connector Information
X001F - Connector Switchbox
X002F - Connector Switchbox
X101M - ISOBUS Connector
X102F - Sensor Drawbar Rear
X103F - Sensor Drawbar Front
X104F - Oil Level Sensor
X106F - Open Center or Load Sense Hydraulic Solenoid
X107F - Tank Filling Horn
X108F - Master Water Valve - Standard
X109F - Pressure Regulator (Water)
X111F - Master Water Valve - Ringline
X112F - Tank Level Pressure Sensor
X113F - Agitation Valve
X114F - Sensor Drawbar Right
X115F - Sensor Drawbar Left
X116F - Wheel Speed Sensor
X118F - Boom In Sensor
X119F - Boom Tilt Sensor
X120F-1 SPC Connector A
X120F-2 SPC Connector B
X120F-3 SPC Connector C
X121F-1 EPM1 Base
X121F-2 EPM Base
X121F-3 - EPM Base
X123F - Edge Nozzle Left
X124F - Outer Nozzle Left
X126F - Edge Nozzle Right
X127F - Outer Nozzle Right
X131F - Section R4
X132F - Section R3
X133F - Section R2
X134F - Section R1
X135F - Section C
X136F - Section L1
X137F - Section L2
X138F - Section L3
X139F - Section L4
X144F - Water Pressure Sensor
X145F - Flow Sensor
X146F - Free Function
X147F - Working Light
X149F - Terminator Harness
X151F - CAN Bus
X153F - Fuse Box
X154F - CAN Bus EPM4 Harness
X155F - BoomTrac GND
X156F - Boom On Transport
X157F - Pressure Switch
X158F - Lock Valve
X160F-1 EPM Hydraulics 1
X160F-2 EPM Hydraulics 1
X160F-3 EPM Hydraulics 1
X161F-1 EPM Hydraulics 2
X161F-2 EPM Hydraulics 2
X161F-3 EPM Hydraulics 2
X162M - CAN Bus
X163 - Fuse Box
X164F - Drawbar Left
X165F - VG Left Up
X166F - VG Right Up
X167F - Fold Boom In 2
X168F - Fold Tip Left In
X169F - Fold Tip Right In
X170F - Fold Boom In 1
X171F - Lock On
X172F - Boom Tilt Right
X173F - Boom Up
X175F - Drawbar Right
X176F - VG Left Down
X177F - VG Right Down
X178F - Fold Boom Out
X179F - Fold Tip Left Out
X180F - Fold Tip Right Out
X181F - Fold Boom Out 1
X182F - Lock Off
X183F - Boom Tilt Left
X184F - Boom Down
X185M - BoomTrac Boom Tilt GND
X200F-1 EPM4 Option
X200F-2 EPM4 Option
X200F-3 EPM4 Option
X201M - CAN Bus
X202 - Fuse Box
X203 - Left Hand Work Light
X204 - Right Hand Work Light
X208 - Dilution Pump
X240 - Terminator Harness
X241F - Passive Terminator
X250M - CAN Bus In
X251F - CAN Bus Out
X252 - Fuse Box
X253 - Hydraulic Function BoomTrac
X254F - Sensor Left
X255F - Sensor Right
X256F-3 - BoomTrac Control Unit
X257F - Boom Tilt
X300 - Fuse Box
X501 - Fuse Box
X502 - Ground Block
X503 - Ground Block
X525 - Tractor Implement 7- Pin Connector
X526 - Left Tail and Stop Light
X527 - Right Tail and Stop Light
X528 - Left Front Marker Harness
X529 - Right Front Marker Harness
X530 - Left Front Marker
X531 - Right Front Marker
X532 - Left Tail Light Extension Harness
X533 - Right Tail Light Extension Harness
X534 - Left Side Marker Harness
X535 - Right Side Marker Harness
X536 - Left Side Marker Light 1
X537 - Left Side Marker Light 2
X538 - Left Side Marker Light 3
X539 - Left Side Marker Light 4
X540 - Right Side Marker Light 1
X541 - Right Side Marker Light 2
X542 - Right Side Marker Light 3
X543 - Right Side Marker Light 4
X544 - Left Rear Marker Light
X545 - Right Rear Marker Light
X546 - Left Rear Marker Harness
X547 - Right Rear Marker Harness
X900 - Tractor - Implement Connector
X901 - Tractor Cab Harness
X903 - Cab Harness to Display Harness
X910 - Greenstar 2 Display
X911 - Tractor Ground Point - Pin 1
X912 - Tractor Ground Point - Pin 2
X913 - Tractor Switched Power - Pin 3
X914 - Tractor Switched Power - Pin 4
X915 - CAN Bus Power
X916 - CAN Bus Ground
X917 - Ground Point to Multi-function Control Lever
X918 - Switched Power to Multi-function Control Lever
X919 - Unswitched Power to Multi-function Control Lever
X920 - Tractor 7 - Pin Connector
Section 260 - BRAKE SYSTEM DIAGNOSTICS
Group 05 - General Information
Brake System Component Identification
Group 15A - Hydraulic Brake System
Hydraulic Braking System Theory of Operation
Hydraulic Braking System Schematic
Group 15B - Pneumatic Braking System
Pneumatic Braking System Theory of Operation
Pneumatic Braking System Schematic
Group 15C - Hydraulic Brakes 700 Schematic
Hydraulic brakes 700 Schematic
Section 270 - HYDRAULIC DIAGNOSIS AND TESTS
Hydraulic System Component Identification
Group 15A - Overall Hydraulic System
Overall Hydraulic System Theory of Operation
Overall Hydraulic System Schematic
Group 15B - AutoDilute Hydraulic System
AutoDilute Hydraulic Theory of Operation
AutoDilute Hydraulic Schematic
Group 15C - Boom Fold Hydraulic System
Boom Fold Hydraulic Theory of Operation
Boom Fold Hydraulic Schematic
Group 15D - Boom Pendulum Lock Hydraulic System
Boom Pendulum Lock Hydraulic Theory of Operation
Boom Pendulum Lock Schematic
Group 15E - Boom Raise Hydraulic System
Boom Raise Hydraulic Theory of Operation
Boom Raise Hydraulic Schematic
Group 15F - Boom Tilt Hydraulic System
Boom Tilt Hydraulic Theory of Operation
Boom Tilt Hydraulic Schematic
Group 15G - Boom Variable Geometry Hydraulic System
Boom Variable Geometry Hydraulic Theory of Operation
Boom Variable Geometry Hydraulic Schematic
Group 15H - Drawbar Steering Hydraulic System
Drawbar Steering Hydraulic Theory of Operation
Drawbar Steering Hydraulic Schematic
Group 15I - Hydraulic System Type
Hydraulic System Type Theory of Operation
Hydraulic System Type Schematic
Group 15J - EL-4 Hydac Hydraulics V3 700 Schematic
Group 15K - EHB-1/EHB-2 700 Schematic
Group 15L - EHB-1/EHB-2/ISOBUS - Hydraulic Connections 700 Schematic
Group 15M - Folding/Unfolding SCV 2 Part Folding Boom Schematic
Group 15N - EHS-1 2 Part Folding Boom Schematic
Group 15O - EHS-1 3 Part Folding Boom
EHS-1 3 Part Folding Boom Schematic
Group 15P - EHB-2 3 Part Folding Boom Schematic
Group 15Q - Independent Yaw Suspension 700 Schematic
Group 15R - EHB-1/EHB-2 2 Part Folding Boom 700 Hydac Hydraulic Schematic
Group 15S - EHB-2 3 Part Folding Boom 700 Hydac Hydraulic Schematic
Group 20 - Component Location
A01 — Boom Raise Accumulator
C01 — Left Lift Cylinder
C02 — Right Lift Cylinder
C03 — Drawbar Steering Cylinder (Single)
C04 — Left Drawbar Steering Cylinder
C05 — Right Drawbar Steering Cylinder
C06 — Boom Tilt Cylinder
C07 — Pendulum Lock Cylinder
C08 — Left Inner Boom Cylinder
C09 — Right Inner Boom Cylinder
C10 — Left Middle Boom Cylinder (3-Part Boom)
C11 — Right Middle Boom Cylinder (3-Part Boom)
C12 — Left Boom Tip Cylinder
C13 — Right Boom Tip Cylinder
C14 — Left Variable Geometry Boom Cylinder
C15 — Right Variable Geometry Boom Cylinder
D02, D04, D06, D08, D10, D14, D16, D18, D20, D22 — ”A” Port Check Valves
D07, D09, D13, D15, D17, D19, D21 — ”B′ Port Check Valves
D01, D03, D05, D07 — ”B” Port Check Valves
D26 — Hydraulic System Pressure Coupler
D27 — Hydraulic System Return Coupler
D28 — Hydraulic System Load Sense Coupler
F01 — Filter
G01 — Flow Divider Valve Block
G03 — Drawbar Steering Variable Restrictor (Optional)
G04 — Drawbar Steering Variable Restrictor (Optional)
G05 — Left Wing Variable Geometry Flow Restrictor
G06 — Left Wing Variable Geometry Flow Restrictor
G07 — Right Wing Variable Geometry Flow Restrictor
G08 — Right Wing Variable Geometry Flow Restrictor
G10 — Boom Control Valve Assembly
M01 — AutoDilute Motor
O1 — Hydraulic System Orifice
O2 — Lift Orifice
O3, O4 — Drawbar Steering Orifices (Single Cylinder)
O5, O6 — Drawbar Steering Orifices (Dual Cylinder)
O7 — Boom Tilt Orifice
O8 — Boom Tilt Orifice
O9 — Pendulum Lock Orifice
O10 — Pendulum Lock Orifice
O11 — Inner Boom Fold 1 Orifice
O12 — Inner Boom Fold 1 Orifice
O13 — Inner Boom Fold 1 Orifice
O14 — Inner Boom Fold 1 Orifice
O15 — Inner Boom Fold 2 Orifice (3-Part Boom)
O16 — Inner Boom Fold 2 Orifice (3-Part Boom)
O17 — Inner Boom Fold 2 Orifice (3-Part Boom)
O18 — Inner Boom Fold 2 Orifice (3-Part Boom)
O19 — Left Tip Fold Orifice
O20 — Left Tip Fold Orifice
O21 — Right Tip Fold Orifice
O22 — Right Tip Fold Orifice
O23 — Load Sense Orifice
V01 — Pressure Relief Valve
V02 — Load Sense Bleed Valve
V03 — AutoDilute Flow Control Valve
Y01 — Hydraulic Type Solenoid Valve
Y06, Y08, Y10, Y11, Y14, Y16, Y18, Y20, Y22, Y24 — Solenoid Valves
Y26 — AutoDilute Pump Valve
Y27 — Boom Height Lock Solenoid Valve
Section 280 - SOLUTION SYSTEM
Group 15A - Solution System without Ring Line
Solution System (without Ring Line) Theory of Operation
Function Diagram — Sprayer with Single Pump
Group 15B - Solution System with Ring Line
Solution System (with Ring Line) Theory of Operation
Function Diagram — Sprayer with Single Pump and Ring Line Circulation System
Group 15C - AutoDilute System
Brand: John Deere
FOREWORD
Section 05 - SAFETY
Admissible Use
Work in Clean Area
Chemical Safety
Danger Symbols
Mechanical Safety
Non-Permissible Use
Operators
Working Area
Skin Protection
Tractor Cab
Use Proper Tools
Operate Safely
Live With Safety
Machine Composition
Capacities
Sound Level
Materials Used
Lubricant Storage
Group 10 - Sensors
Specifications
Public Roads
Replace Coupling
Replace Brake Valve
General Information
Other Material
Specifications
Specifications
Other Material
Specifications
Frame Repair
Welding
Skip Welding
Group 20 - Axle
Other Material
Specifications
Group 25 - Drawbar
Other Material
Specifications
Other Material
Specifications
Balance Spray Boom
Section 110 - PUMP
Group 05 - Pump
Other Material
Specifications
Agitation
Boom Fold
Boom Tilt
BoomTrac
CAN Bus
Lights — Work
Power Distribution
Ring Line System
Solution Pressure
Spray Rate Control
Spray Valve Control
Tank Water Level
Wheel Speed
Overall Hydraulics
Fuses
SPC Codes
SPC Addresses
BoomTrac Schematic
Group 15G - CAN Bus
CAN Bus Schematic
SPC Power Schematic
EL-4 Main Board
X121F-1 EPM1 Base
X121F-2 EPM Base
X121F-3 - EPM Base
X131F - Section R4
X132F - Section R3
X133F - Section R2
X134F - Section R1
X135F - Section C
X136F - Section L1
X137F - Section L2
X138F - Section L3
X139F - Section L4
X145F - Flow Sensor
X151F - CAN Bus
X153F - Fuse Box
X158F - Lock Valve
X162M - CAN Bus
X163 - Fuse Box
X165F - VG Left Up
X166F - VG Right Up
X171F - Lock On
X173F - Boom Up
X182F - Lock Off
X184F - Boom Down
X200F-1 EPM4 Option
X200F-2 EPM4 Option
X200F-3 EPM4 Option
X201M - CAN Bus
X202 - Fuse Box
X250M - CAN Bus In
X251F - CAN Bus Out
X252 - Fuse Box
X254F - Sensor Left
X257F - Boom Tilt
X300 - Fuse Box
X501 - Fuse Box
X502 - Ground Block
X503 - Ground Block
F01 — Filter
O2 — Lift Orifice
- JOHN DEERE JD-410 Technical Manual
- Funk Power DF Series 150 & 250 Transmission Service Manual
- John Deere Service ADVISOR 4.0 CF+JDIN+History Data (11.2013)
- John Deere Parts Manager Pro 6.5.5 (CF) Construction & Foresty [03.2016]
- John Deere Service Advisor 4.1.011 + 4 dvd data RU (01.2013)
- John Deere 750C,850C Crawler Dozer Technical Manual
- John Deere Service Advisor 4.01.11
- John Deere 750J,850J Crawler Dozer Parts Catalog
- John Deere 6020 Series Repair Manuals (6020 to 6920S)
- John Deere Service Advisor 4.1.007 Torrent 28.11.2013
- Jonh Dree 690E LC Excavator Techical Manual
- John Deere 700J Crawler Dozer Parts Catalog
- John Deere 850J Crawler Dozer Tier 3 Parts Catalog
- John Deere LTR155, LTR166 and LTR180 Lawn Tractors Technical manual
- JOHN DEERE CODE DTC LIST
