John Deere 670G 670GP 672G 672GP Motor Grader Repair Technical Manual TM11205
Brand: John Deere
Type of Machine: Motor Grader
Model: John Deere 670G 670GP 672G 672GP Motor Grader
Serial Number: -634753
Part Number: TM11205
Publication Date: 2015
Number of Pages: 586 Pages
FOREWORD
Section 00 - GENERAL INFORMATION
Group 001 - Safety
Recognize Safety Information
Follow Safety Instructions
Operate Only If Qualified
Wear Protective Equipment
Avoid Unauthorized Machine Modifications
Inspect Machine
Stay Clear of Moving Parts
Avoid High-Pressure Oils
Beware of Exhaust Fumes
Prevent Fires
Prevent Battery Explosions
Dispose of Waste Properly
Prepare for Emergencies
Start Only From Operator′s Seat
Use and Maintain Seat Belt
Prevent Unintended Machine Movement
Avoid Work Site Hazards
Keep Riders Off Machine
Avoid Back over Accidents
Avoid Machine Tip Over
Operating Or Traveling On Public Roads
Inspect and Maintain ROPS
Add and Operate Attachments Safely
Park And Prepare For Service Safely
Service Cooling System Safely
Make Welding Repairs Safely
Drive Metal Pins Safely
Group 0003 - Torque Values
Metric Bolt and Cap Screw Torque Values
Additional Metric Cap Screw Torque Values
Unified Inch Bolt and Cap Screw Torque Values
Service Recommendations for 37° Flare and 30° Cone Seat Connectors
Service Recommendations for O-Ring Boss Fittings
Service Recommendations For Flared Connections—Straight or Tapered Threads
Service Recommendations For Flat Face O-Ring Seal Fittings
O-Ring Face Seal Fittings With SAE Inch Hex Nut And Stud End For High Pressure Service Recommendations
O-Ring Face Seal Fittings With Metric Hex Nut And Stud End For Standard Pressure Service Recommendations
O-Ring Face Seal Fittings With Metric Hex Nut And Stud End For High Pressure Service Recommendations
Service Recommendations for Metric Series Four Bolt Flange Fitting
Service Recommendations For Inch Series Four Bolt Flange Fittings
Inch Series Four Bolt Flange Fitting For High Pressure Service Recommendations
Service Recommendations For Non-Restricted Banjo (Adjustable) Fittings
Service Recommendations For O-Ring Boss Fittings With Shoulder
Metric 24° O-Ring Seal DIN 20078 Service Recommendations
Section 01 - WHEELS
Group 0110 - Powered Wheels and Fasteners
Wheel Remove and Install
Tire Remove and Install
Section 02 - AXLES AND SUSPENSION SYSTEMS
Group 0225 - Input Drive Shafts and U-Joints
Transmission-to-Rear Axle Drive Shaft Remove and Install
Transmission-to-Rear Axle Drive Shaft Disassemble and Assemble
Group 0230 - Non-Powered Wheel Axles
Front Wheel Hub and Spindle Remove and Install—Non 6WD
Front Wheel Hub and Spindle Disassemble and Assemble—Non 6WD
Front Axle Remove and Install—Non 6WD
Group 0240 - Powered Wheel Axles
Front Wheel Hub and Spindle Remove and Install—6WD
Front Wheel Hub and Spindle Disassemble and Assemble—6WD
Front Wheel Hub and Spindle Disassemble and Assemble with Steering Angle Sensor—6WD
6WD Drive Hub Disassemble and Assemble
Planetary Drive Disassemble and Assemble
Planetary Brake Disassemble and Assemble
6WD Bearings Remove and Install
6WD O-Ring Metal Face Seal Remove and Install
Front Axle Remove and Install—6WD
Group 0250 - Axle Shafts, Bearings, and Reduction Gears
TEAMMATE™ II 1400 Series Inboard Planetary Axle—Use CTM43
Rear Axle Remove and Install
Tandem and Wheel Axle Assembly Remove and Install
Tandem Wheel Axle Assembly Remove and Install
Tandem Wheel Axle Assembly Disassemble and Assemble
Tandem Pivot Disassemble and Assemble
Final Drive Axle Remove and Install
Tandem Drive Shaft Remove and Install
Drive Chain Remove and Install
Group 0260 - Hydraulic System
6WD Pump Remove and Install
6WD Pump Disassemble
6WD Pump Assemble
6WD Charge Pump Remove and Install
6WD Engagement Manifold Remove and Install
Differential Lock Pump Remove and Install
6WD Motor Remove and Install
6WD Motor Disassemble and Assemble
Section 03 - TRANSMISSION
Group 0300 - Removal and Installation
DF180 Transmission
Transmission Remove and Install
Group 0360 - Hydraulic System
Transmission Charge Pump Remove and Install
Section 04 - ENGINE
Group 0400 - Removal and Installation
PowerTech™ Plus 4.5L & 6.8L (4045 & 6068) John Deere Engines—6.8L Tier 2/Stage II
PowerTech Plus™ 9.0L (6090) John Deere Engine—9.0L Tier 3/Stage IIIA
Engine Remove and Install—6.8L Tier 2/Stage II
Engine Remove and Install—9.0L Tier 3/Stage IIIA
Section 05 - ENGINE AUXILIARY SYSTEM
Group 0510 - Cooling System
Fan Blade Remove and Install
Radiator Remove and Install
Hydraulic and Differential Oil Cooler Remove and Install
Transmission Oil Cooler Remove and Install
Fuel Cooler Remove and Install—9.0L
Charge Air Cooler Remove and Install
Group 0560 - External Fuel Supply Systems
Fuel Tank Remove and Install
Fast Fill Fuel System Disassemble and Assemble—If Equipped
Section 07 - TORSIONAL ISOLATOR
Group 0752 - Elements
Torsional Isolator Remove and Install
Section 09 - STEERING SYSTEM
Group 0920 - Power Steering
Toe-In Check and Adjustment
Group 0960 - Hydraulic System
Steering Wheel, Column, and Valve Remove and Install—Standard Controls
Steering Wheel, Column, and Valve Remove and Install—EH Controls
EH Controls Steering Canceling Valve Remove and Install
Steering Cylinder Remove and Install
Hydraulic Cylinder Disassemble and Assemble
Wheel Lean Cylinder Remove and Install
Secondary Steering Accumulator Remove and Install—If Equipped
Section 10 - SERVICE BRAKES
Group 1011 - Active Elements
Service Brake Repair
Group 1060 - Hydraulic System
Service Brake Valve Remove and Install
Service Brake Bleeding
Brake Accumulator Remove and Install
Section 11 - PARK BRAKE
Group 1111 - Active Elements
Park Brake Repair
Section 17 - FRAME, CHASSIS OR SUPPORTING STRUCTURE
Group 1740 - Frame Installation
Welding On Machine
Welding Repair of Major Structure
Separate Frames at Articulation Joint
Articulation Bearing Replacement
Rear Platform Remove and Install
Section 18 - OPERATOR’S STATION
Group 1800 - Removal and Installation
Cab Remove and Install
Cab Remove and Install—GP Machine Only
Group 1810 - Operator Enclosure
Windowpanes Remove and Install
Cab Door Handle Remove and Install
Cab Door Latch Remove and Install
Rivet Nut Installation
Group 1815 - Pedal Assembly
Inching Pedal Remove and Install
Group 1816 - Steering Tilt Console
Steering Support Console Remove and Install—Standard Controls
Steering Support Console Remove and Install—EH Controls
Console Tilt Remove and Install
Steering Tilt Assembly Remove and Install
Group 1821 - Seat and Seat Belt
Seat Remove and Install
Seat Belt Remove and Install
Armrest Remove and Install
Armrest Remove and Install—EH Controls
Armrest Disassemble and Assemble—EH Controls
Standard Seat Disassemble and Assemble
Deluxe Seat Disassemble and Assemble
Air Suspension Disassemble and Assemble
Group 1830 - Heating and Air Conditioning
Refrigerant Cautions and Proper Handling
Flush and Purge Air Conditioner System
R134a Refrigerant Oil Information
R134a Refrigerant Recovery/Recycling and Charging Station Installation Procedure
R134a System Recover
R134a System Evacuate
R134a System Charge
Expansion Valve Remove and Install
Freeze Control Switch Remove and Install
Air Conditioning High-Low Pressure Switch Remove and Install
Heater Control Valve Remove and Install
Heater Control Valve Leak Check
Blower Motor Assembly Remove and Install
Compressor Remove and Install—6.8L
Condenser Remove and Install
Heater and Air Conditioner Remove and Install
Receiver-Dryer Remove and Install
Compressor Clutch Disassemble and Assemble
Compressor Manifold Inspect
Compressor Relief Valve Remove and Install
Section 19 - SHEET METAL AND STYLING
Group 1921 - Grille and Grille Housing
Grille Housing Remove and Install
Section 21 - MAIN HYDRAULIC SYSTEM
Group 2160 - Hydraulic System
Vacuum Pump Installation
Hydraulic Pump Remove and Install
Hydraulic Pump Disassemble and Assemble
Hydraulic System Manifold Remove and Install
Hydraulic System Manifold Disassemble and Assemble
Soft Start Valve Remove and Install
Soft Start Valve Disassemble and Assemble
Hydraulic Fan Pump Remove and Install
Hydraulic Fan Motor Remove and Install
Hydraulic Fan Motor Disassemble and Assemble
Hydraulic Fan Valve Remove and Install
General Oil Cleanup Procedure
Hydraulic/Hydrostatic Component Failure Cleanup Procedure
Section 34 - GRADING DEVICE
Group 3415 - Controls Linkage
Control Linkage Remove and Install
Group 3440 - Frames
NeverGrease™ Pin Joints
Lift Arms Remove and Install
Saddle Locking Cylinder Remove and Install
Saddle Lock Cylinder Disassemble and Assemble
Saddle Frame Remove and Install
Blade Pitch Frame Remove and Install
Draft and Circle Frame Remove and Install
Circle Adjustment
Blade Side Shift Wear Inserts Remove and Install
Group 3450 - Circle Gearbox
Circle Drive Gearbox Remove and Install
Circle Drive Gearbox Disassemble and Assemble
Circle Drive Gearbox (With Slip Clutch) Disassemble and Assemble
Circle Rotate Motor Disassemble and Assemble
Circle Rotate Sensor Remove and Install
Group 3460 - Hydraulic System
Grader Control Valve Remove and Install
Draft Frame Mount Grader Control Valve Remove and Install—EH Controls
Cab Mount Grader Control Valve Remove and Install—EH Controls
Grader Control Valve Disassemble and Assemble
Midmount Scarifier Valve Section Disassemble and Assemble
Midmount Scarifier Valve Section Disassemble and Assemble—EH Controls
Blade Lift Valve Section Disassemble and Assemble
Blade Lift Valve Section Disassemble and Assemble—EH Controls
Auxiliary (With Float) Valve Section Disassemble and Assemble
Auxiliary (Without Float) Valve Section Disassemble and Assemble
Auxiliary Valve Section Disassemble and Assemble—EH Controls
Wheel Lean, Articulation, Circle Side Shift, Blade Pitch, and Blade Side Shift Valve Section Disassemble and Assemble
Wheel Lean, Articulation, Circle Side Shift, Blade Pitch, Blade Side Shift, and Steering Valve Section Disassemble and Assemble—EH Controls
Circle Rotate Valve Section Disassemble and Assemble
Circle Rotate Valve Section Disassemble and Assemble—EH Controls
Return Check Poppets Disassemble and Assemble
Rotary Manifold Remove and Install
Rotary Manifold Disassemble and Assemble
Blade Lift, Blade Pitch, and Circle Side Shift Cylinders Remove and Install
Blade Side Shift Cylinder Remove and Install
Articulation Cylinders Remove and Install
Section 42 - GROUND CONDITIONING TOOL
Group 4240 - Frames
Scarifier/Blade Remove and Install
Mid mount Scarifier Remove and Install
Mid mount Scarifier Cylinder Remove and Install
Ripper Remove and Install
Ripper Cylinders Remove and Install
Balder son™ Style Front Lift Group Remove and Install
Section 99 - DEALER FABRICATED TOOLS
Group 9900 - Dealer Fabricated Tools
DF1017—Axle Lift Eye
DF1057—Axle Adjusting Tool
DFRW20 Compressor Holding Fixture
DFRW103—Yoke Holding Tool Tool may be purchased. Order JDG924.
DFT1101 Cab and ROPS Lift Bracket
DFT1151—Outboard Bearing Driver
DFT1152—Inboard Bearing Driver
DFT1153—Oil Seal Driver
DFT1225—Rolling Torque Measurement Tool
DFT1250 Lifting Bracket
DFT1282—King Pin Torque Adapter
DFT1308 Transmission Support Bracket
DFT1310—Cab Mount Control Valve Support Bracket
DFT1311—Extension for DFT1250
Brand: John Deere
FOREWORD
Group 001 - Safety
Inspect Machine
Prevent Fires
Section 01 - WHEELS
6WD Pump Assemble
DF180 Transmission
Section 04 - ENGINE
Park Brake Repair
Welding On Machine
R134a System Charge
Group 3440 - Frames
Circle Adjustment
Group 4240 - Frames
