Martin Welker
104
230,310
John Deere 670 770 790 870 970 1070 Compact Utility Tractor Technical Manual TM1470
Brand: John Deere
Type of Machine: Compact Utility Tractor
Type of Manual: Technical Manual
Model: John Deere 670 770 790 870 970 1070 Compact Utility Tractor
Part Number: TM1470
Number of Pages: 1020 Pages
SECTION 10—GENERAL INFORMATION
Group 05—Safety
Group 10—General Specifications
Group 15—Repair Specifications
Group 20—Fuel and Lubricants
Group 25—Serial Number Locations
SECTION 20—ENGINE REPAIR
Group 05—670/770
Group 06—870/970/1070
Group 07—790
Group 10—Cooling System
Group 15—Throttle and Governor Control Linkage
Group 20—Fuel System
SECTION 40—ELECTRICAL SYSTEM
Group 05—Alternator
Group 10—Starter
Group 15—Sender, Switches and Gauges
SECTION 50—POWER TRAIN REPAIR—670/770/790
Group 05—Clutch Housing
Group 06—Single Stage Clutch
Group 07—Dual Stage Clutch
Group 10—Transmission
Group 15—Rear PTO Drive Shaft
Group 20—Differential
Group 25—Final Drive
Group 30—Mechanical Front Wheel Drive
Group 35—Throttle and Governor Control Linkage
Section 55—POWER TRAIN REPAIR—870/970/1070
Group 06—Dual Stage Clutch
Group 30—Mechanical Front Wheel Drive—870
Group 35—Mechanical Front Wheel Drive—970/1070
Group 40—Mid Mount PTO
SECTION 60—STEERING AND BRAKE REPAIR
Group 05—Manual Steering
Group 10—Power Steering
Group 15—Brake Repair—670/770/790
Group 20—Brake Repair—870/970/1070
SECTION 70—HYDRAULIC REPAIR
Group 05—Hydraulic Pump and Filter
Group 10—Rockshaft—670/770/790
Group 11—Rockshaft—870/970/1070
Group 15—Selective Control Valve
Group 20—Rear Auxiliary Hydraulic Lines
SECTION 80—MISCELLANEOUS REPAIR
Group 05—Wheels
Group 10—Front Axle
Group 15—Hood
Group 20—3-Point Hitch
Group 25—Seat and Support
Group 30—Roll-Gard
Group 35—Mower Spindles
Group 40—Mower Gearbox
SECTION 210—OPERATIONAL CHECKOUT
PROCEDURE AND SPECIFICATIONS
Group 05—Test and Adjustment Specifications
Group 10—Operational Checkout Procedures
SECTION 220—ENGINE OPERATION, TESTS, AND ADJUSTMENTS
Group 05—Component Locations
Group 10—Theory of Operation
Group 15—Engine System Diagnosis
SECTION 240—ELECTRICAL SYSTEM OPERATION AND TESTS
Group 15—Diagnosis and Test
Group 20—Schematic
SECTION 250—POWER TRAIN—670/770/790
SECTION 255—POWER TRAIN—870/970/1070
SECTION 260—STEERING AND BRAKES
SECTION 270—HYDRAULIC SYSTEM
Group 20—Schematic
