John Deere 6620 Sidehill 6620 7720 8820 Combines Technical Manual TM1202
Brand: John Deere
Type of Machine: Combines
Type of Manual: Technical Manual
Model: John Deere 6620 Sidehill 6620 7720 8820 Combines
Part Number: TM1202
Number of Pages: 1922 Pages
SECTION 10 - GENERAL
Group 00 - General Specifications
Group 05 - Diagnosing and Testing Procedures
Group 10 - Tune-Up and Adjustment
SECTION 20 - ENGINE REPAIR
Group 00 - Specifications and Special Tools
Group 05 - Cylinder Head, Valves and Camshaft
Group 10 - Block, Liners, Pistons, and Rods
Group 15 - Crankshaft and Main Bearings
Group 20 - Lubrication System
Group 25 - Cooling System
SECTION 30 - FUEL AND AIR REPAIR
Group 05 - Air Intake System
Group 10 - Diesel Fuel System
Group 15 - Control Linkage
SECTION 40 - ELECTRICAL REPAIR
Group 05 - Harness Replacement
Group 10 - Charging Circuit Repair
Group 15 - Starting Circuit Repair
Group 20 - Lights, Instruments. and Accessories
SECTION 50 - POWER TRAIN REPAIR
Group 05 - Clutch
Group 10 - Transmission
Group 15 - Differential
Group 20 - Final Drive
Group 25 - Sundstrand Hydrostatic Drive
Group 26 - Eaton Hydrostatic Drive
Group 30 - 4-Wheel Drive (Planetary Gearing)
Group 31 - 4-Wheel Drive (Cam Lobe)
Group 35 - Posi-Torq Ground Drive
Group 40 - Tires and Wheels
SECTION 60 - STEERING/BRAKES REPAIR
Group 05 - Power Steering
Group 10 - Brakes
SECTION 70 - HYDRAULIC REPAIR
Group 05 - Reservoir
Group 10 - Hydraulic Pump
Group 15 - Hydraulic Valves
Group 20 - Hydraulic Cylinders
Group 25 - Hydraulic Motors
Group 30 - Accumulator
SECTION 80 - SEPARATOR SHELL REPAIR
Group 05 - Rear Hood
Group 10 - Cylinder Rear Cover
Group 15 - Separator Uprights
SECTION 90 - OPERATOR STATION REPAIR
Group 05 - Air Conditioning System
Group 10 - Air Intake (Pressurizer) System
Group 15 - Heating System
Group 20 - Personal Posture Seat
Group 25 - Miscellaneous Components
SECTION 100 - HEADER REPAIR
Group 05 - 200 and 900 Series Cutting Platforms
Group 10 - 40 Series Corn Heads
Group 15 - 50, 50A Series Row-Crop Heads
SECTION 110 - FEEDER HOUSE REPAIR
Group 05 - Feeder Conveyor Chain
Group 10 - Feeder Conveyor Drum
Group 15 - Feeder House Drives and Reverser Gear Case
Group 20 - Feeder House Drives (SideHill 6620 Combines)( -610300)
Group 25 - Feeder House Paddles, Stripper and Front Closure Sheets (SideHill 6620 Combines [ -403300])
Group 30 - Feeder Conveyor Chain, Upper Shaft, Paddle and Shaft, Conveyor Drum and Front Closure Sheets (SideHill 6620 Combines {403301- J)
SECTION 120 - SEPARATOR REPAIR
Group 05 - Cylinder, Concave, and Beater
Group 10 - POSI-TORQ" Cylinder Drive
Group 12 - Dual-Range Cylinder Drive
Group 15 - Straw Walkers and Crankshafts
Group 20 - Straw Chopper and Straw Spreader
Group 25 - Shoe Augers, Fan, and Shoe Frame
Group 30 - Tailings Elevator and Augers
Group 35 - LowerAuger, Clean Grain Elevator, and Grain Tank Loading Auger
SECTION 130 - GRAIN TANK UNLOADING SYSTEM
Group 05 - Grain Tank Cross Augers
Group 10 - Vertical Auger and Bevel Gears
Group 15 - Horizontal Auger and Gearcase
SECTION-140 - MAJOR DRIVES REPAIR
Group 05 - Engine Powershaft
Group 10 - Primary Countershaft
Group 15 - Secondary Countershaft
SECTION 150 - SIDEHILL LEVELING SYSTEM REPAIR
Group 05 - Electrical Components
Group 10 - Hydraulic Components
SECTION 160 - AUTOMATIC HEADER HEIGHT CONTROL REPAIR
Group 05 - Repair of Components
SECTION 220 - ENGINE OPERATION AND TESTS
Group 05 - System Operation
Group 10 - System Tests and Diagnosis
SECTION 230 - FUEL/AIR OPERATION AND TESTS
SECTION 240 - ELECTRICAL OPERATION AND TESTS
Group 05 - General Information and Diagnosis
Group 06 - Electrical System Diagnosis
Group 20 - Lights, Instruments and Accessory Circuits
SECTION 250 - POWER TRAIN OPERATION AND TESTS
Group 05 - Clutch Diagnosis
Group 10 - Transmission Diagnosis
Group 15 - Final Drive Diagnosis
Group 20 - Hydrostatic Drive Tests and Diagnosis
Group 25 - 4-Wheel Drive Diagnosis (Planetary Gearing)
Group 26 - 4-Wheel Drive (Cam Lobe)
Group 30 - PosiTorq Ground Drive Diagnosis
SECTION 260 - STEERING/BRAKES OPERATION AND TESTS
Group 10 - Brakes
SECTION 270 - HYDRAULIC OPERATION AND TESTS
Group 01 - Hydraulic System Operation
Group 05 - Hydraulic System Tests
Group 10 - Reservoir
Group 15 - Hydraulic Pumps
Group 20 - Hydraulic Valves
Group 25 - Hydraulic Cylinders
Group 30 - Hydraulic Motors
Group 35 - Accumulator
SECTION 290 - OPERATOR STATION OPERATION AND TESTS
Group 10 - Heating System
SECTION 350 - SIDEHILL LEVELING SYSTEM OPERATION AND TESTS
Group 05 - General Information, Diagnosis, and Tests
Group 10 - Electrical System
Group 15 - Hydraulic System
SECTION 360 - AUTOMATIC HEADER HEIGHT CONTROL OPERATION AND TESTS
Group 10 - Mechanical System
Group 15 - Electrical System
Group 20 - Hydraulic System -
Group 25 - General Information, Diagnosis, and Tests - DIAL-A-MATIC
Group 30 - Mechanical System - DIAL-A-MATIC
Group 35 - Electrical System - DIAL-A-MATIC
Group 40 - Hydraulic System - DIAL-A-MATIC
Brand: John Deere
Part Number: TM1202
Group 05 - Clutch
Group 10 - Brakes
Group 10 - Brakes
- JOHN DEERE CODE DTC LIST
