John Deere 6600 Tractor Operators Manual OMAL81271
- Download this document, you need 200 Gallons
Brand: John Deere
Model: John Deere 6600 Tractor
Part Number: OMAL81271
Number of Pages: 165 Pages
Identification View
Safety
Safety Decals
Controls and Instruments
Vehicle controls
Attachment controls
Cab controls
Indicator lights
Digital display
Performance monitor
Lights
Operator’s Platform and Cab
Roll-over protective structure
Seat belt
Operator’s seat
Windshield wiper
Fan
Heater
Air conditioning system
Steering wheel adjustment
Break-In Period
After the first 4 and 8 hours of operation
Within the first 100 hours of operation
After the first 100 hours of operation
Prestarting Checks
Operating the Engine
Starting the engine
Fuel preheater
Parking the tractor
Stopping the engine
Page
Operating the Tractor
Reducing fuel consumption
Correct ground travel speed
Shifting the PowrQuad transmission
Engaging creeper transmission
Front wheel drive
Differential lock
Brakes
Rockshaft and Three-Point Hitch
Operating the rockshaft
Three-point hitch
Draft links
Center link
Lift links
Attaching implements
Sway blocks
Power Take-Off
PTO guard
Operating the PTOs
Attaching PTO-driven equipment
Ballast
Ballast
Measuring rear wheel slip
Rear wheel weights
Filling tires with liquid ballast
Front weights
Wheel Treads, Tires
Front wheel tread adjustment
Rear wheel tread adjustment
Tires
Tire combinations with front wheel drive
Additional Equipment
Selective control valves
Quick couplers
Maximum permissible oil withdrawal
Remote hydraulic cylinder
Swinging drawbar
Trailer hitches
Transport
Fuel, Lubricants, Hydraulic Oil and Coolant
Fuel
Engine oil
Transmission and hydraulic oil
FWD axle oil
Grease
Engine coolant
Lubrication and Periodic Service
Opening hood
Removing grille screens
Access to battery
Service intervals
Service / Daily or Every 10 Hours
Engine crankcase oil level
Fuel filter
Checking lights
Other service jobs
Service / Every 250 Hours
Changing engine oil
Changing engine crankcase filter element
Checking transmission oil level
Battery service
Lubricating front axle
Checking oil level in MFWD axle
Three-point hitch
Hitches
Checking start safety circuit
Service / Every 500 Hours
Changing fuel filter
Lubricating rear axle bearings
Air intake hoses
Service / Every 750 Hours
Checking engine speeds
Changing transmission oil filters
Service / Every 1500 Hours or 2 Years
Changing coolant
Changing oil in MFWD axle
Changing transmission/hydraulic oil
Service / As Required
Air cleaner
Secondary (safety) filter
Cab air filters
Servicing the air conditioning system
Adjusting the handbrake
Bleeding the brakes
Fuel filter
Bleeding air from fuel system
Operator’s seat
Starting motor
Fuses
Troubleshooting
Hydraulic system
Electrical system
Storage
Storage for long period
Removing tractor from storage
Specifications
PTO power output
Hydraulic system
Axle loads and weights
Electrical system
Capacities
Sound level
Load capacities of tires
Serial Numbers
Lubrication and Maintenance Charts
Index
Brand: John Deere
Identification View
Safety
Safety Decals
Vehicle controls
Attachment controls
Cab controls
Indicator lights
Digital display
Performance monitor
Lights
Seat belt
Operator’s seat
Windshield wiper
Fan
Heater
Break-In Period
Prestarting Checks
Starting the engine
Fuel preheater
Parking the tractor
Stopping the engine
Page
Front wheel drive
Differential lock
Brakes
Three-point hitch
Draft links
Center link
Lift links
Sway blocks
Power Take-Off
PTO guard
Operating the PTOs
Ballast
Ballast
Rear wheel weights
Front weights
Wheel Treads, Tires
Tires
Quick couplers
Swinging drawbar
Trailer hitches
Transport
Fuel
Engine oil
FWD axle oil
Grease
Engine coolant
Opening hood
Access to battery
Service intervals
Fuel filter
Checking lights
Other service jobs
Changing engine oil
Battery service
Three-point hitch
Hitches
Air intake hoses
Changing coolant
Air cleaner
Cab air filters
Bleeding the brakes
Fuel filter
Operator’s seat
Starting motor
Fuses
Troubleshooting
Hydraulic system
Electrical system
Storage
Specifications
PTO power output
Hydraulic system
Electrical system
Capacities
Sound level
Serial Numbers
Index
- JOHN DEERE CODE DTC LIST
