Martin Welker
104
230,310
John Deere 6600 6800 6506 6900 Tractors Operators Manual OMAL110182
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 6600 6800 6506 6900 Tractors
Serial Number: 140 000
Part Number: OMAL110182
Number of Pages: 236 Pages
Identification Views
Safety
Safety Decals
Controls and Instruments
Vehicle controls
PTO and creeper controls
Attachment controls
Heater and air conditioning controls
Operating the digital display
Indictator lights
Fuel gauge
Coolant temperature gauge
Hour meter
Digital display
Travel speed
Engine speed
PTO speed
Operating hours
Service interval
Performance monitor
Data entry
Operating
Calibration
Wheel slip
Vehicle speed
Service
Backlight brightness
Lights
H4 farm headlights
Light switch
Hazard warning lights
Turn signals and horn
Work lights
Trailer socket
Page
Operator’s Platform and Cab
Roll-over protective structure
Seat belt
Operator’s seat
Windshield wiper
Blower and air louvers
Heater
Air-conditioning system
Cooling cans of drink
Storage space
Dome and console lights
Digital clock
Adjusting the steering wheel
Door retainer
Beacon light
Adjusting the access step
Cool box
Monitor installation
Cigarette lighter and ashtray
Roof hatch
Break-In Period
After the first 4 and 8 hours of operation
Within the first 100 hours of operation
After the first 100 hours of operation
Prestarting Checks
Operating the Engine
Starting the engine
Electrical starting aid
Coolant heater
Booster battery
Fuel preheater
Towing the tractor
Parking the tractor
Battery cut-off switch
Stopping the engine
Chock block
Operating the Tractor
Reduce fuel consumption
Correct ground travel speed
Travel speeds, 6506 and 6600 tractors
Travel speeds, 6800 and 6900 tractors
Shifting PowrQuad transmission
Shift positions, PowrQuad transmission
Engaging creeper transmission
Engaging front-wheel drive
Differential lock
Foot brakes
Hydraulic trailer brake
Air brake on trailer
Rockshaft and Three-Point Hitch
Operating the rockshaft
With Headland Management System
(HMS)
Remote control
Height adjustment
Transporting mounted implements
Adjusting rate of implement drop
Depth adjustment
Load/depth adjustment
Depth control
Mixed control
Load control
Float position
Direct actuation
Three-point hitch
Draft links
Attaching implements
Center link
Lift links
Sway blocks
Stabilizing chain
Stabilizing system
Adjusting spreading dimension
Power Take-Off
PTO guard
PTO options
PTO speeds
Operating the PTOs
By remote control
Reversing rear PTO shafts
Changing speed of shiftable rear PTO
Attaching PTO-driven equipment
Page
Ballast
Ballast
Ballasting rear wheels
Measuring rear wheel slip
Rear wheel weights
Filling tires with liquid ballast
Pre-assembling the pick-up weight
Attaching to three-point hitch (rear-end
attachment)
Attaching to basic weight
Attaching to three-point hitch (front-end
attachment)
Front weights
Additional 180 kg (400 lb) weight
package
Wheel Tread, Tires
Front wheel tread adjustment
Limiting the steering angle
Tightening front wheel attaching nuts
Checking front wheel toe-in
Adjusting
Adjusting the fenders
Rear wheel tread adjustment
Tread widths
Tires
Tire combinations
Additional Equipment
Selective control valves
Pressure adjustment, 300 series
Control levers
Multi-function lever
Couplers
Maximum permissible oil withdrawal
Oil withdrawal with hydraulic motor
Power Beyond couplers, 6506 and 6600
Pressure-free return circuit, 6506 and
6600
Additional oil reservoir, 6506 and 6600
Power Beyond application valve
Remote hydraulic cylinder
Swinging drawbar
Lengthwise adjustment
Drawbar for three-point hitch
Front jaw hitch
Height-adjustable trailer hitch
Pick-up hitch
Lockable tank filler cap
Transport
Fuel, Lubricants, Hydraulic Oil and Coolant
Fuel
Engine oil
Transmission/hydraulic oil
FWD axle oil
Grease
Coolant
Lubrication and Periodic Service
Service intervals
Opening hood
Removing grille screens
Removing fan guard
Access to battery
Access to fuses
Service chart
Service intervals - daily or every 10 hours
Every 250 hours
Every 500 hours
Every 750 hours
Every 1500 hours or every 2 years
As required
Service / Daily or Every 10 Hours
Engine crankcase oil level
Compressed air trailer brake system
Checking the lights
Other service jobs
Service / Every 250 Hours
Changing engine oil
Changing engine crankcase filter element
Checking transmission oil level
Battery service
Lubricating front axle
Checking oil level in FWD axle
Checking oil level in MFWD final drives
Checking brakes, 6800 and 6900
Three-point hitch
Trailer hitch
Checking neutral start circuit
Service / Every 500 Hours
Changing the fuel filter
Lubricating rear axle
Lubricating draft link support
Page
Air intake hoses
Service / Every 750 Hours
Checking engine speeds
Changing transmission oil filters
Service / Every 1500 Hours or 2 Years
Changing coolant
Changing oil in FWD axle
Service / As Required
Cleaning cab air filters
Engine air cleaner
Secondary (safety) element
Cab air filters
Radiator screen
Service - air conditioning system
Adjusting the handbrake
Bleeding the brakes, 6506 and 6600
Bleeding the brakes, 6800 and 6900
Checking the brakes, 6800 and 6900
Fuel filter
Bleeding the fuel system
Operator’s seat
Checking specific gravity of battery
Starting motor
Fuses
Replacing drive belt
Troubleshooting
Hydraulic system
Electrical system
Storage
Storage for a lengthy period
Taking tractor out of storage
Specifications
PTO power output
Hydraulic system
Axle loads and weights
Electrical system
Capacities
Sound level
Tire loading limits
Safety note regarding electrical appliances
Serial Numbers
Lubrication and Maintenance Records
Index
