John Deere 6510 6610 6810 6910 Tractors Operators Manual OMAL116300
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 6510 6610 6810 6910 Tractors
Serial Number: 266766
Part Number: OMAL116300
Number of Pages: 266 Pages
Identification Views
Safety
Safety Decals
Controls and Instruments
Vehicle controls
PTO and creeper controls
Attachment controls
Heater and air-conditioning controls
Operating the digital display
Indicator lights
Fuel gauge
Coolant temperature gauge
Digital display
Travel speed
Engine speed
PTO speed
Time of day (clock)
Operating hours
Gear
Performance monitor
Data entry
Operating
Calibration
Wheel slip
Vehicle speed
Service
Backlight brightness
Lights
H4 farm headlights
Light switch
Hazard warning lights
Turn signals and horn
Work lights
Trailer socket
Page
Operator’s Station and Cab
Roll-over protective structure
Seat belt
Operator’s seat
Windshield wiper
Blower and air louvers
Heater
Air-conditioning system
Cooling cans of drink
Storage rack
Dome and console lights
Adjusting the steering wheel
Beacon light
Adjusting the access step
Cool box
Monitor installation
Cigarette lighter and ashtray
Roof hatch
Break-In Period
After the first 4 and 8 hours of operation
Within the first 100 hours of operation
After the first 100 hours of operation
Prestarting Checks
Operating the Engine
Starting the engine
Electrical starting aid
Coolant heater
Booster battery
Fuel preheater
Towing the tractor
Parking the tractor
Battery cut-off switch
Stopping the engine
Chock block
Operating the Tractor
Reduce fuel consumption
Correct ground travel speed
Travel speeds, 6510 and 6610
Travel speeds, 6810 and 6910
Shifting PowrQuad transmission
Shift positions, PowrQuad transmission
Shifting PowrQuad Plus transmission
Shifting AutoQuad transmission
Shifting AutoQuad II transmission
Travel speeds with Powr Shift
transmission
Shifting Powr Shift transmission
Engaging creeper transmission
Engaging front-wheel drive
Differential lock
Foot brakes
Hydraulic trailer brake
Air brake on trailer
Rockshaft and Three-Point Hitch
Operating the rockshaft
With Headland Management System
(HMS)
Remote control
Height adjustment
Transporting mounted implements
Adjusting rate of implement drop
Depth adjustment
Load/depth adjustment
Depth control
Mixed control
Load control
Float position
Direct actuation
Three-point hitch
Draft links
Attaching implements
Center link
Lift links
Sway blocks
Stabilizer chain
Stabilizer bar
Stabilizing system
Adjusting spreading dimension
Power Take-Off
PTO guard
PTO options
PTO speeds
Page
Operating the PTOs
By remote control
Reversing rear PTO shafts
Changing speed of shiftable rear PTO
Attaching PTO-driven equipment
Ballast
Ballast
Ballasting rear wheels
Measuring rear wheel slip
Rear wheel weights
Filling tires with liquid ballast
Pre-assembling the pick-up weight
Attaching to three-point hitch (rear-end
attachment)
Attaching to basic weight
Attaching to three-point hitch (front-end
attachment)
Front weights
Additional 180 kg (400 lb) weight
package
Wheel Tread, Tires
Front-wheel tread adjustment
Limiting the steering angle
Tightening front-wheel attaching nuts
Checking front-wheel toe-in
Adjusting
Adjusting the fenders
Rear wheel tread adjustment
Tread widths
Tires
Tire combinations
Additional Equipment
Selective control valves
Pressure adjustment, 300 Series
Control lever
Multi-function lever
Couplers
Maximum permissible oil withdrawal
Oil withdrawal with hydraulic motor
Power Beyond couplers, 6510 and 6610
Pressure-free return circuit, 6510 and
6610
Additional oil reservoir, 6510 and 6610
Power Beyond application valve
Remote hydraulic cylinder
Swinging drawbar
Lengthwise adjustment
Tool bar for three-point hitch
Front jaw hitch
Height-adjustable trailer hitch
Pick-up hitch
Lockable tank filler cap
Transport
Fuel, Lubricants, Hydraulic Oil and Coolant
Fuel
Engine break-in oil
Engine oil
Transmission/hydraulic oil
FWD axle oil
Grease
Coolant
Lubrication and Periodic Service
Service intervals
Opening hood
Removing grille screens
Removing fan guard
Access to battery
Access to fuses
Service chart
Service intervals - daily or every 10 hours
Every 250 hours
Every 500 hours
Every 750 hours
Once every year
Every 1500 hours or every 2 years
Every 3000 hours or every 3 years
As required
Service / Daily or Every 10 Hours
Engine crankcase oil level
Fuel filter
Compressed air trailer brake system
Checking the lights
Other service jobs
Service / Every 250 Hours
Changing engine oil
Changing engine crankcase filter element
Checking transmission oil level
Battery service
Lubricating front axle
Checking oil level in FWD axle
Page
Checking oil level in FWD final drives
Checking brake operation
Three-point hitch
Pick-up hitch
Checking neutral start circuit
Tightening wheel retaining bolts
Service / Every 500 Hours
Changing the fuel filter
Lubricating rear axle
Lubricating draft link support
Air intake hoses
Service / Every 750 Hours
Checking engine speeds
Changing transmission oil filters
Changing filter on front PTO
Service / Once Every Year
Checking seat belt
Service / Every 1500 Hours or 2 Years
Changing oil in FWD axle
Service / Every 3000 Hours or 3 Years
Changing coolant
Service / As Required
Cleaning cab air filter
Engine air cleaner
Secondary (safety) element
Cab air filters
Radiator screen
Service - air-conditioning system
Adjusting the handbrake
Bleeding foot brakes, 6510 and 6610
Bleeding foot brakes, 6810 and 6910
Fuel filter
Bleeding the fuel system
Operator’s seat
Checking specific gravity of battery
Starter motor
Fuses
Replacing drive belt
Troubleshooting
Hydraulic system
Electrical system
Diagnostic Codes
Storage
Storage for a lengthy period
Taking tractor out of storage
Specifications
PTO power output
Hydraulic system
Axle loads and weights
Electrical system
Capacities
Sound level
Tire loading limits
Safety note regarding electrical
appliances
Serial Numbers
Index
Brand: John Deere
Safety
Safety Decals
Vehicle controls
Attachment controls
Indicator lights
Fuel gauge
Digital display
Travel speed
Engine speed
PTO speed
Time of day (clock)
Operating hours
Gear
Performance monitor
Data entry
Operating
Calibration
Wheel slip
Vehicle speed
Service
Lights
H4 farm headlights
Light switch
Work lights
Trailer socket
Page
Seat belt
Operator’s seat
Windshield wiper
Heater
Storage rack
Beacon light
Cool box
Roof hatch
Break-In Period
Prestarting Checks
Starting the engine
Coolant heater
Booster battery
Fuel preheater
Towing the tractor
Parking the tractor
Stopping the engine
Chock block
transmission
Differential lock
Foot brakes
(HMS)
Remote control
Height adjustment
Depth adjustment
Depth control
Mixed control
Load control
Float position
Direct actuation
Three-point hitch
Draft links
Center link
Lift links
Sway blocks
Stabilizer chain
Stabilizer bar
Stabilizing system
Power Take-Off
PTO guard
PTO options
PTO speeds
Page
Operating the PTOs
By remote control
Ballast
Ballast
Rear wheel weights
attachment)
attachment)
Front weights
package
Wheel Tread, Tires
Adjusting
Tread widths
Tires
Tire combinations
Control lever
Couplers
6610
Swinging drawbar
Front jaw hitch
Pick-up hitch
Transport
Fuel
Engine break-in oil
Engine oil
FWD axle oil
Grease
Coolant
Service intervals
Opening hood
Removing fan guard
Access to battery
Access to fuses
Service chart
Every 250 hours
Every 500 hours
Every 750 hours
Once every year
As required
Fuel filter
Checking the lights
Other service jobs
Changing engine oil
Battery service
Page
Three-point hitch
Pick-up hitch
Air intake hoses
Checking seat belt
Changing coolant
Engine air cleaner
Cab air filters
Radiator screen
Fuel filter
Operator’s seat
Starter motor
Fuses
Troubleshooting
Hydraulic system
Electrical system
Diagnostic Codes
Storage
Specifications
PTO power output
Hydraulic system
Electrical system
Capacities
Sound level
Tire loading limits
appliances
Serial Numbers
Index
- JOHN DEERE CODE DTC LIST
