Martin Welker
104
230,792
John Deere 6405 6605 Tractor Repair Technical Manual TM4866
Brand: John Deere
Model: John Deere 6405 6605 Tractor
Part Number: TM4866
Publication Date: 2002
Number of Pages: 644 Pages
SECTION 05—Safety
Group 00—Norms of Safety
SECTION 50—SyncroPlus Transmission
Group 00—Separating and Installing Transmission Components
Group 05—Transmission Activation
Group 10—Clutch, Oil Pump and Valves
Group 15—Transmission box
Group 20—Slow-speed Transmission
Group SOA—Group Box — Series to
Group SUB—Group Box — Series 20
SECTION 55—Powr0uad Transmission
Group 05—Separating and Installing the PowrQuad Module
Group 10—Powr0uad Box
SECTION 56—Power Transmission
Group 00—Separating and Installing Components
Group 05—Transmission Shaft and Torsion Damper
Group 05—MFWD clutch from series 161067
Group 16—Differential
Group 20—Hydraulic Pump Transmission
Group 25—Final reductions
Group 30—Power Take-Off
SECTION 60—Steering and Brakes
Group 05—Hydrostatic Steering
Group 15—Brake Valve
Group 20—Brakes
SECTION 70—Hydraulic system
Group 05—RCV Controls
Group 10—Hydraulic Pump and Charge Pump
Group 11—Gear pump — (Eaton)
Group 13—Gear Pump — (Albarus)
Group 15—Hydraulic Control Valves
Group 20—Hydraulic Lift and Lift Cylinder
Group 22—Traction/Sensitivity Sensor
Group 25—Remote Control Connections and Valves
SECTION 80—Front axle
Group 00—Special Tools
Group 05—Technical Data and Adjustment Values
Group 10—Disassembly
Group 15—Assembling the differential
Group 20—Pinion depth
Group 25—Adjusting the play between the teeth
Group 30—Assembling the Bridges
Group 35—Assembling the Universal Joint
Group 40—PTO
Group 45—Assembling the Hydraulic Cylinder
Group 50—Convergence Regulation
Group 55—Separating and Installing the Front Shaft/Components
Group 60—Front Axle Support
Group 65—Front Axle 4 x 2
Group 66—Steering Cylinder — 4x2 shaft
Group 70—Front and Rear Wheels
Group 75—Main Chassis
Group 80—Traction bar
SECTION 90—Operator Platform and Cab
Group 00—Removing and Installing the Operator Platform
Group 15—Air-conditioning System
Group 20—Healing System
Group 25—Cab
Group 30—Various
SECTION 99—Special Tools Made By the Dealer
Group 05—Custom-made Tools
