John Deere 620F 622F 625F 630F 635F Cutting Platforms Operators Manual OMHXE147135
- Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Cutting Platforms
Model: John Deere 620F 622F 625F 630F 635F Cutting Platforms
Serial Number: 810001-
Part Number: OMHXE147135
Number of Pages: 76 Pages
Introduction
Foreword
A Message to Our Customers
Identification View
Safety Features
Header Safety Features
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
French and Spanish Safety Signs and Operators's Manual
Ballasting for Safe Ground Contact
Parking and Leaving the Machine
Prepare for Emergencies
Wear Protective Clothing
Stay Clear of Harvesting Units
Keep Hands Away From Knives
Use Safety Lights and Devices
Transport Combine With Header Safely
Road Transport Disconnect Switch
Practice Safe Maintenance
Avoid Contact With Moving Parts
Stay Clear of Cutterbar When Rotating Auger
Stay Clear of Rotating Drivelines
Guards and Shields
Avoid High-Pressure Fluids
Service Machines Safely
Service Drive Belts Safely
Protect Against High Pressure Spray
Support Machine Properly
Store Attachments Safely
Safety Signs
Rear View Decals
Rear View Decals Continued
Side View Decals
Replace Safety Signs
Transporting
Transporting on Trailer
Transporting on Combine
Attaching and Detaching
Rear Auger Stripper Extension Location
Attaching Header to Feeder House
Detaching Header from Feeder House
Calibration and Settings
When to Calibrate
Calibration Error Codes
Calibration Procedures
Adjusting Feeder House Drop Rate and Sensitivity
Operating the Platform
Cutting Platform Operation
Setting Backshaft Speed
Armrest Functions
Active Header Control Display—Features
Description of Automatic Header Height Control Systems
Operating HydraFlex™ Pressure—Flex Platforms
Header Height Sensing – HYDRAFLEX Heads with Auxiliary Sensors
Operating Flex Platform in Rigid Mode
Auxiliary Sensor Arm Operating Positions
HydraFlex™ Pressure Manual Adjust Switch
Position Warning Lights for Field Operation
Harvesting Soybeans—Flex Platforms
Harvesting Sorghum and Sunflowers in Dry Ground Conditions
Harvesting Oats, Sorghum and Wheat in Damp or in Wet/Weedy Conditions (All Platforms)
Attachments and Options
Auger Flight Extensions (Attachment)
Auger Speed Increase or Decrease (Attachment)
Stubble Lights (Attachment)
Spare Knife Storage (Optional)
Fine Serrated Knife (Optional)
Knife Assemblies with Long-Short Sections (Optional)
Knife Drive Sheaves (Attachment)
Reel Position Resume (Attachment)
Short Dividers (Attachment)
Low Stone Dam (Attachment or Option)
High Stone Dam (Attachment or Option)
Raised Height Skid Shoes (Optional)
Adjustments — Flex Platform
Bleeding HydraFlex™ System
Standard Perma-Glide Divider and Divider Point
Height Adjustment of Perma-Glide Divider Assembly
Side-to-Side Adjustment of Perma-Glide Divider Assembly
Adjustments — Auger and Stripper
Remove Knife Drive Belt From Drive Sheave
Adjusting Auger Position
Adjusting Auger Height
Adjusting Auger Fore/Aft
Adjusting Center Auger Finger Timing
Adjusting Rear Stripper
Adjusting Floor Stripper
Adjusting Auger Chain
Adjustments — Reel
Adjust Reel Fingers
Adjusting Minimum Reel Height and Leveling Reel
Adjusting Reel Fore/Aft and Lift Cylinders
Rephasing Reel Fore/Aft Cylinders
Rephasing Reel Lift Cylinders
Bleeding the Reel Lift Cylinder System
Adjusting Dial-A-Speed™ Reel Speed Ratio
Adjusting Reel Speed Ratio Sensor
Adjusting Reel Drive Gear
Lubrication
Grease
Lubricant Storage
Mixing of Lubricants
Lubrication and Maintenance
Care and Maintenance of Belts
Lubrication Interval Chart
Every 50 Hours of Operation
Every 200 Hours of Operation
Every 400 Hours of Operation
Service
Hydraulic Cylinder Safety Stop
Safe Cutting Platform Operation
Reel Safety Stops
Opening and Closing Right and Left-Hand Shields
Remove and Install Knife Drive Belt
Adjusting Knife Drive Belt Tension
Replacing Cutterbar Knife
Knife and Knife Drive Alignment
Knife Hold-Down Clearance
Replacing Knife Sections
Replacing Auger Fingers and Retainers
Stubble Light Bulb Replacement
Header Warning Light Bulb Replacement
Troubleshooting
Cutting Platform
Storage
End of Season Service
Beginning of Season Service
Specifications
Specifications
Dimensions/Weights
Keep Machines Secure
Header Identification Number
Keep Proof of Ownership
John Deere Service Literature Available
Technical Information
John Deere Service Keeps You On The Job
John Deere Is At Your Service
Brand: John Deere
Introduction
Foreword
Identification View
Safety Features
Safety
Guards and Shields
Safety Signs
Rear View Decals
Side View Decals
Transporting
When to Calibrate
Armrest Functions
Adjustments — Reel
Adjust Reel Fingers
Lubrication
Grease
Lubricant Storage
Service
Reel Safety Stops
Troubleshooting
Cutting Platform
Storage
Specifications
Specifications
Dimensions/Weights
- JOHN DEERE CODE DTC LIST
