John Deere 6155M 6175M And 6195M Tractors Operators Manual OMAL219652
Format: HTML
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 6155M 6175M And 6195M Tractors
Parts Number: OMAL219652
Foreword
Emissions Performance and Tampering
Section 00 - Identification Views
Trademarks
Section 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Handle Starting Fluid Safely
Fire Prevention
In Case of Fire
Avoid Static Electricity Risk When Refueling
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operator’s Manuals for ISOBUS Controllers
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Use a Safety Chain
Transport Towed Equipment at Safe Speeds
Use Caution on Slopes, Uneven Terrain, and Rough Ground
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Section 10 - Safety Decals
Use the Seat Belt
Operate the Tractor Safely
Do Not Modify ROPS
Use of Instructional Seat (If Equipped)
Tow Trailer Safely (not on Tractors up to 30 km/h)
Caution When Operating Front Loader (on Tractors with Mechanical Selective Control Valves)
Caution When Operating Front PTO
Caution When Operating Rear PTO
Accumulators (Suspended Front-Wheel Drive Axle, if Equipped)
Pressure Accumulator (Brake System)
Starter Motor
Electrical Coolant Heater of Engine (if Equipped)
Do Not Modify ROPS
Never Carry Riders
Regular ROPS Position
Section 15 - Controls and Instruments
Vehicle Controls with PowrQuad™ Transmission
Vehicle Controls with PowrQuad™ PLUS and AutoQuad™ PLUS Transmissions
Vehicle Controls with CommandQuad™ PLUS Transmission
Key Switch
Come-Home Mode
Immobilizer
Front-Wheel Drive - Controls
Differential Lock - Controls
Creeper - Controls
PTO - Controls
Mechanical Selective Control Valves (SCV) - Controls
Mechanical Multi-Function Lever with Dampening
Front Hitch (Economy) - Controls
Rear Hitch - Controls
iTEC™ Basic — Intelligent Total Equipment Control - Controls
AutoTrac™ Controls (Optional Equipment)
Heating and Air Conditioning System - Controls
Instrument Panel and Indicator Lights — PowrQuad™ PLUS and AutoQuad™ PLUS Transmissions
Instrument Panel and Indicator Lights — CommandQuad™ PLUS Transmission
Level Indicator — Fuel Tank and DEF Tank
Coolant Temperature Gauge
Aftertreatment Indicators Overview
Digital Display - User Interface
Digital Display - Display Properties (Basic Settings)
Digital Display - Information Menu
Digital Display - More Settings
Software Update
Section 20 - Lights
Overview of the Lights
Lighting System - Overview of the Lights (Tractors with Open Operator's Station)
Switches for Turn Signal and Horn (Tractors with Cab)
Lighting System – Switch for the Turn Signal and Horn (Tractors with Open Operator's Station)
Lighting System - Light Switch (Tractors with Cab)
Lighting System – Light Switch (Tractors with Open Operator's Station)
Additional Headlights (Optional Equipment)
Lighting System - Worklight Switches (Tractors with Cab)
Lighting System – Worklight Switch (Tractors with Open Operator's Station)
Lighting System - Front Loader Worklights (If Equipped)
Lighting System - Worklights of ISOBUS Implement
Lighting System - Switch on Hazard Warning Lights
Beacon Light (Option)
Seven-Pin Trailer Connector
Section 25 - Open Operator's Station and Cab
Clean Vehicle of Hazardous Pesticides
Emergency Exits
Roll Over Protection System (ROPS)
Operate the Foldable ROPS
Use the Seat Belt
Comfort Seat MSG83
Comfort Seat MSG85
Air Comfort Seat — MSG95GL
Air Comfort Seat MSG95AL
Instructional Seat for Training Purposes
Wiper and Washer System
Fan and Air Louvers
Heating System
Air-Conditioning System
Tips On Using the Air-Conditioning System
Storage Tray
Dome Lights
Reverse Travel Alarm (Optional Equipment)
Controls for Hydraulic Quick Release and Worklights on Front Loader (if Equipped)
Adjust the Steering Wheel
Beacon Light
Install Monitor
Socket for GreenStar™ Display
ISOBUS socket in cab
12-V Power Outlet Socket / Cigarette Lighter
3-Terminal Power Outlet Socket and Multiple Power Outlet Socket Strip (12V, SAE)
Signal Socket According to ISO Standard 11786
Service Socket (CAN BUS)
ISOBUS Socket (ISB)
Opening Windows
Routing Cables through the Window
Roof Hatch
Section 30 - Break-In Period
After the First 4 and 8 Hours of Operation
Within the First 100 Hours of Operation
After the First 100 Operating Hours
Section 35 - Prestarting Checks
Prestarting Checks
Comply with Operator's Manuals of Implement Manufacturers
Section 40 - Operate the Engine
US EPA Qualified Emergency Use — SCR Derate Override Option
Important Engine Information
Engines with Turbocharger
Engine Protection
Required Machine Stop Warning
Cold Start Aids
Coolant Heater
Ground Fault Circuit Interrupter (GFCI)
Starting the Engine
Engine Start with a Slave Battery
Battery — Disconnect the Electrical Circuit
Stopping the Engine
Battery Disconnect System (If Equipped)
Parking the Tractor
Tow the Tractor
Fill the Fuel Tank
Filling the DEF Tank
Section 42 - Exhaust Cleaning System
Exhaust Filter Cleaning, General Information
Access the Engine Menu on the Digital Display
Passive Exhaust Filter Cleaning
Automatic Exhaust Filter Cleaning
Exhaust Filter Cleaning with Tractor Parked
Exhaust Filter, Service Cleaning
Exhaust Cleaning System, Information for Operator
DEF (Diesel Exhaust Fluid) Level Gauge
Selective Catalytic Reduction (SCR) System Overview
Section 45 - Operate the Tractor — General
Reduce Fuel Consumption
Select Correct Ground Speed
Notes on Changing to a Different Size of Tire
Ground Speed Tables and SRI Values
Travel Speeds, PowrQuad™ and PowrQuad™ PLUS Transmissions for 30 km/h (16/16), on 6155M Tractors - Tires with SRI 825 and 875
Travel Speeds, PowrQuad™ and PowrQuad™ PLUS Transmissions for 30 km/h (16/16), on 6155M Tractors - Tires with SRI 925
Travel Speeds, PowrQuad™ and PowrQuad™ PLUS Transmissions for 30 km/h (16/16), on 6175M and 6195M Tractors - Tires with SRI 925 and 975
Travel Speeds, PowrQuad™ PLUS and AutoQuad™ PLUS Transmissions for 40 km/h (20/20), for 6155M Tractor - With Tires SRI 825 and 875
Travel Speeds, PowrQuad™ PLUS and AutoQuad™ PLUS Transmissions for 40 km/h (20/20), on 6155M Tractors - With Tires SRI 925
Travel Speeds, PowrQuad™ PLUS and AutoQuad™ PLUS Transmissions for 40 km/h (20/20), on 6175M and 6195M Tractors - With Tires SRI 875, 925 and 975
Travel Speeds, CommandQuad™ PLUS Transmission for 40 km/h (20/20), on 6155M Tractors - With Tires SRI 825, 875 and 925
Travel Speeds, CommandQuad™ PLUS Transmission for 40 km/h (20/20), on 6175M and 6195M Tractors - With Tires SRI 875, 925 and 975
Engage Front-Wheel Drive
Engage Differential Lock
Engage Creeper Transmission
Tractor Equipped With Front Suspension Option
Hydraulic Foot Brakes
Single-Line Hydraulic Trailer Brake (If Equipped)
Parking the Tractor
Section 47 - Operating the Tractor — PowrQuad™ and PowrQuad™ PLUS
Shift the PowrQuad™ Transmission
Shift the PowrQuad™ PLUS Transmission
PowrQuad™ PLUS Transmission — Settings
Section 48 - Operate the Tractor — AutoQuad™ PLUS
Shift the AutoQuad™ PLUS Transmission
AutoQuad Plus Transmission — Settings
Section 49 - Operate the Tractor — CommandQuad™ PLUS
CommandQuad™ PLUS — Controls
CommandQuad™ PLUS — Special Features when Maneuvering the Tractor
CommandQuad™ PLUS – Set Maximum Travel Speed
CommandQuad™ PLUS - Set Maximum Engine Speed
CommandQuad™ PLUS — Set Operating Mode
CommandQuad™ PLUS – Set Engine Speed Reduction (Custom Setting)
CommandQuad™ PLUS — Set Engine Droop (Custom Setting)
CommandQuad™ PLUS — SoftShift when Changing Gears
CommandQuad™ PLUS — Set the Reverse/Forward Speed Ratio
CommandQuad™ PLUS – Adjust AutoClutch Sensitivity
CommandQuad™ PLUS — Set the Start Gear
CommandQuad™ PLUS — Customizing Vehicle Behavior
CommandQuad™ PLUS — Operating with Trailer on Hillsides in Slippery Conditions
CommandQuad™ PLUS — Stopping and Parking the Tractor
CommandQuad™ PLUS — Come-Home Mode
CommandQuad™ PLUS — Towing the Tractor
Section 50 - Hitches
Hitch - Maximum Lifting Force
Rear Hitch - Operation
Rear Hitch - Remote Control
Rear Hitch - Raise Height Limit
Rear Hitch - Driving under Load with Mounted Implement
Rear Hitch - Hitch Damping
Rear Hitch - Adjust the Rate of Drop
Rear Hitch - Adjust the Raise Rate
Rear Hitch - Set the Depth Control Stop
Rear Hitch - Draft/Depth Control Adjustment
Rear Hitch - Use Draft Control
Rear Hitch - Float Position
Rear Hitch - Direct Actuation
Economy Front Hitch - Controls
Economy Front Hitch
Front Hitch - Center Link
Front Hitch - Center Link Positions
Front Hitch - Hook-Type Center Link
Three-point hitch
Flat Steel Draft Links
Telescopic Draft Links
Attach Three-Point Hitch Mounted and Drawn Implements
Leveling the Implement
Center Link
Adjust Lift Links
Lift Links - Adjust for Vertical Float
Sway Blocks (If Equipped)
Stabilizer (If Equipped)
Stabilizing System (If Equipped)
Draft Links — Adjust Spreading Dimension
Section 51 - iTEC™ Basic — Intelligent Total Equipment Control
iTEC™ Basic - Operating the Intelligent Total Equipment Control
Section 55 - Power Take-Offs
Front PTO — PTO Shield
Rear PTO — PTO Shield
Operating instructions
PTO Speeds
PTO Options
Front PTO
Switching the Front PTO
Engaging Rear PTO
Rear PTO — Select Standard Speed (Shiftable PTO)
Rear PTO — Remote Control and Function
Rear PTO — Change the PTO Stub Shaft
Rear PTO — Connect an Implement
Section 60 - Ballast
Ballasting Information and Guidelines for Tractors with Single Tires
General Guidelines for Tractor Weight Based on Engine Horsepower (according to EC Directive 97/68, using PS as Unit of Measurement)
Selection of Weights
Load on Rear Wheels
Measure Rear Wheel Slip
Fill Tires with Water
Draining Tires
Wheel Weights
Change Wheel Weights Safely
Install Front Weights
Section 65 - Wheels, Tires
General Wheel, Tire, and Tread Guidelines
Preventing Front Wheel or Fender Contact with Tractor Components
Changing to a Different Tire Size
Use of Dual Wheels (Easy-to-Attach)
Change Tires Safely
Wheel Exchange with Wheel Weights
Front Tires
Check and Adjust Toe-In
Adjustable Front Axle - Check Toe-in
Adjustable Front Axle Typ B - Adjust Toe-in
Adjustable Front Axle Type B - Tightening Axle Bolts and Wheels Bolts
Adjustable Front Axle Typ B - Adjusting the Wheel Treads
Adjustable Front Axle Typ B - Wheel Treads
Front-Wheel Drive Axle — Check Toe-In
Front-Wheel Drive Axle — Adjust Toe-In
Instructions for Front Wheel Tread Adjustment with Rims for 2, 8, and 16 Positions
Three-Piece Front Axle (Version 1) — Tread Widths for Front Wheels with Rims for 2 Positions - 6155M
Three-Piece Front Axle (Version 1) — Tread Widths for Front Wheels with Rims for 2 Positions - 6175M
Three-Piece Front Axle (Version 1) — Tread Widths for Front Wheels with Rims for 2 Positions - 6195M
Three-Piece Front Axle (Version 1) — Tread Widths for Front Wheels with Rims for 8 Positions - 6155M
Three-Piece Front Axle (Version 1) — Tread Widths for Front Wheels with Rims for 8 Positions - 6175M
Three-Piece Front Axle (Version 1) — Tread Widths for Front Wheels with Rims for 8 Positions - 6195M
Three-Piece Front Axle (Version 1) — Tread Widths for Front Wheels with Rims for 16 Positions - 6155M
Three-Piece Front Axle (Version 1) — Tread Widths for Front Wheels with Rims for 16 Positions - 6175M
Three-Piece Front Axle (Version 1) — Overview of Axle Category and Axle Type
Three-Piece Front Axle (Version 1) — Adjust the Fenders
Three-Piece Front Axle (Version 1) — Notes on Adjusting the Fenders
Three-Piece Front Axle (Version 1) — Notes on Adjusting the Steering Stop
Three-Piece Front Axle (Version 1) — Adjust the Fixed Fenders and Steering Stop - 750 (M50LD, M50 und M50HD)
Three-Piece Front Axle (Version 1) — Adjust the Fixed Fenders and Steering Stop - 750 (M60LD) and 755HD (M60)
Three-Piece Front Axle (Version 1) — Adjust the Pivoting Fenders and Steering Stop - 750 (M50LD, M50 and M50HD)
Three-Piece Front Axle (Version 1) — Adjust the Pivoting Fenders and Steering Stop - 750 (M60LD) und 755HD (M60)
Three-Piece Front Axle (Version 2) — Tread Widths for Front Wheels with Rims for 2 Positions - 6155M
Three-Piece Front Axle (Version 2) — Tread Widths for Front Wheels with Rims for 2 Positions - 6175M
Three-Piece Front Axle (Version 2) — Tread Widths for Front Wheels with Rims for 2 Positions - 6195M
Three-Piece Front Axle (Version 2) — Tread Widths for Front Wheels with Rims for 8 Positions - 6155M
Three-Piece Front Axle (Version 2) — Tread Widths for Front Wheels with Rims for 8 Positions - 6175M
Three-Piece Front Axle (Version 2) — Tread Widths for Front Wheels with Rims for 8 Positions - 6195M
Three-Piece Front Axle (Version 2) — Tread Widths for Front Wheels with Rims for 16 Positions - 6155M
Three-Piece Front Axle (Version 2) — Tread Widths for Front Wheels with Rims for 16 Positions - 6175M
Three-Piece Front Axle (Version 2) — Overview of Axle Category and Axle Type
Three-Piece Front Axle (Version 2) — Adjust the Fenders
Three-Piece Front Axle (Version 2) — Notes on Adjusting the Fenders
Three-Piece Front Axle (Version 2) — Notes on Adjusting the Steering Stop
Three-Piece Front Axle (Version 2) — Adjust the Fixed Fenders and Steering Stop - 750 (M50LD, M50 und M50HD)
Three-Piece Front Axle (Version 2) — Adjust the Fixed Fenders and Steering Stop - 755 (M60LD and M60)
Three-Piece Front Axle (Version 2) — Adjust the Pivoting Fenders and Steering Stop - 750 (M50LD, M50 and M50HD)
Three-Piece Front Axle (Version 2) — Adjust the Pivoting Fenders and Steering Stop - 755 (M60LD and M60)
Instructions for Rear Wheel Tread Adjustment with Rims for 2, 8 and 16 Positions - Flanged Axle
Tread Widths for Rear Wheels with Rims for 2 Positions - Flanged Axle (6155M)
Tread Widths for Rear Wheels with Rims for 2 Positions - Flanged Axle (6175M)
Tread Widths for Rear Wheels with Rims for 2 Positions - Flanged Axle (6195M)
Tread Widths for Rear Wheels with Rims for 2 Positions (Heavy-Duty Type) - Flanged Axle (6155M)
Tread Widths for Rear Wheels with Rims for 2 Positions (Heavy-Duty Type) - Flanged Axle (6175M)
Tread Widths for Rear Wheels with Rims for 2 Positions (Heavy-Duty Type) - Flanged Axle (6195M)
Tread Widths for Rear Wheels with Rims for 8 Positions - Flanged Axle (6155M)
Tread Widths for Rear Wheels with Rims for 8 Positions - Flanged Axle (6175M)
Tread Widths for Rear Wheels with Rims for 8 Positions - Flanged Axle (6195M)
Tread Widths for Rear Wheels with Rims for 16 Positions / Positions 1 to 8 - Flanged Axle (6155M)
Tread Widths for Rear Wheels with Rims for 16 Positions / Positions 9 to 16 - Flanged Axle (6155M)
Tread Widths for Rear Wheels with Rims for 16 Positions / Positions 1 to 8 - Flanged Axle (6175M)
Tread Widths for Rear Wheels with Rims for 16 Positions / Positions 9 to 16 - Flanged Axle (6175M)
Tread Widths for Rear Wheels with Rims for 16 Positions / Positions 1 to 8 / Flanged Axle (6195M)
Tread Widths for Rear Wheels with Rims for 16 Positions / Positions 9 to 16 - Flanged Axle (6195M)
Tread Widths for Rear Wheels with Rims for 16 Positions (Heavy-Duty Type) / Positions 1 to 8 - Flanged Axle (6175R)
read Widths for Rear Wheels with Rims for 16 Positions (Heavy-Duty Type) / Positions 9 to 16 - Flanged Axle (6175M)
Tread Widths for Rear Wheels with Rims for 16 Positions (Heavy-Duty Type) / Positions 1 to 8 - Flanged Axle (6195M)
read Widths for Rear Wheels with Rims for 16 Positions (Heavy-Duty Type) / Positions 9 to 16 - Flanged Axle (6195M)
Notes on Rear Wheels at Rack-and-Pinion Axles
Rack-and-Pinion Axles - Adjust Tread Widths for Cast Rear Wheels
Rack-and-Pinion Axles - Adjust Tread Widths for Steel Rear Wheels (with Adjusting Pinion)
Rack-and-Pinion Axles - Adjust Tread Widths for Steel Rear Wheels (without Adjusting Pinion)
Tread Widths on Rear Wheels - Rack-and-Pinion Axle (6155M)
Tread Widths on Rear Wheels - Rack-and-Pinion Axle (6175M)
Tread Widths on Rear Wheels - Rack-and-Pinion Axle (6195M)
Tire Combinations - 6155M
Tire Combinations - 6175M
Tire Combinations - 6195M
Calculate Tire Combinations (Graphic)
Calculate Tire Combination, Three-Piece Front Axle - 6155M
Calculate Tire Combination, Three-Piece Front Axle - 6175M and 6195M
Tire Labeling, Ascertain the Load Capacity of Tires
Tire Pressures
Tire Inflation Pressure Guidelines
Select Tire Inflation Pressure
Section 70 - Additional Equipment — Hydraulic System
Selective Control Valves, Mechanical - Control Levers
Mechanical Selective Control Valves - Transport Lock
Selective Control Valves, Mechanical - Raise Rate
Selective Control Valves, Mechanical - Set Feature Mode
Selective Control Valves, Mechanical - Pressure Settings for Series 450
Operator Presence Sensor — For North America, Australia, and New Zealand Only
Selective Control Valves - Hose Unions
Selective Control Valves - Connect Hydraulic Hoses
Selective Control Valves - Disconnect Hydraulic Hoses
Selective Control Valves - Connect or Disconnect Hydraulic Hoses at Front Hitch (If Equipped)
Hydraulic Connections for Implements and Hydraulic Motors
Connect Implements to Selective Control Valves
Selective Control Valves - Maximum Permissible Oil Withdrawal
Selective Control Valves - Oil Withdrawal with Hydrostatic Drive (with PC Hydraulic System)
Selective Control Valves - Oil Withdrawal with Hydrostatic Drive (with PFC Hydraulic System)
Mechanical Multi-Function Lever with Front-Loader Dampening
Section 71 - Additional Equipment — Other
CAT II Drawbar
Proper Use of Drawbar
Locking the Hitch Pins
Latch for telescopic draft links
Front Loader - Hydraulic Quick Release (If Equipped)
Front Loader Mounting Frames for Loaders 640R/643R, 660R/663R and 680R/683R
Front Jaw Hitch
Lockable Tank Filler Cap
Section 75 - Transport
Transporting tractor
Lashing the tractor to transport trailers
Wash Machine After Unloading
Drive on Public Roads
Towing Loads and Transporting with Ballast
Use Safety Chain
Tow the Tractor
Section 80 - Fuel, Lubricants, Hydraulic Oil and Coolant
John Deere Break-In Plus™ Engine Oil — Interim Tier 4, Final Tier 4, Stage IIIB, Stage IV, and Stage V
Diesel Engine Oil — Interim Tier 4, Final Tier 4, Stage IIIB, Stage IV, and Stage V
Engine Oil and Filter Service Intervals — Interim Tier 4, Final Tier 4, Stage IIIB, Stage IV, and Stage V Engines
Transmission and Hydraulic Oil
Oil for Front-Wheel Drive Axle
Multipurpose Extreme Pressure (EP) Grease
Grease for Automated Lubrication Systems
Multipurpose Grease
Mixing of Lubricants
Lubricant Storage
Diesel Engine Coolant (engine with wet sleeve cylinder liners)
Operating in Warm Temperature Climates
John Deere COOL-GARD™ II Coolant Extender
Water Quality for Mixing with Coolant Concentrate
Testing Coolant Freeze Point
Diesel Fuel
Lubricity of Diesel Fuel
Testing Diesel Fuel
Biodiesel Fuel
Minimizing the Effect of Cold Weather on Diesel Engines
Supplemental Diesel Fuel Additives
Oilscan™ and CoolScan™
Diesel Exhaust Fluid (DEF) — Use in Selective Catalytic Reduction (SCR) Equipped Engines
Refilling Diesel Exhaust Fluid (DEF) Tank
Storing Diesel Exhaust Fluid (DEF)
Testing Diesel Exhaust Fluid (DEF)
Disposal of Diesel Exhaust Fluid (DEF)
Section 85 - Lubrication and Periodic Service
Required Emission-Related Information
Scope of This Manual
Safe Maintenance and Cleaning
Using High Pressure Washers
Lubricate All Lubricating Points
Observe Service Intervals
Service Intervals
General Instructions Regarding the Condition of the Tractor
Open the Hood
Opening Service Doors
Access to the Battery
Access to Fuses
Jack Up the Tractor - Lifting Points
Greasing - General information
Lubricate Tractor - Lubrication Points
Important Instructions Regarding Alternator
Service After the First 100 Hours
Service As Required
Inspect/Replace Hydraulic Hoses
Other Service Jobs
Note Regarding the Service Interval for Engine Coolant
Instructions for Starting up the Air-Conditioning System
Periodic Service
All Service Tasks
Service (As Required, Annually, Every 2 and 3 Years)
Section 90 - Service / Daily or Every 10 Hours
Clean the Radiator, Condenser and Area Surrounding the Engine - 6-Cylinder Engines
Check Coolant Level - 6-Cylinder Engines
Check Fuel Filters - 6-Cylinder Engines
Check Engine Oil Level - 6-Cylinder Engines
Transmission/Hydraulic System - Check Oil Level (6155M)
Transmission/Hydraulic System - Check Oil Level (6175M and 6195M)
Leak-Off Oil Container (if Equipped)
Check Brakes
Check the Lights
Lubricate the Lubrication Points of the Tractor
Section 95 - Service / After the First 100 Hours
Change Engine Oil Filter
Change the Engine Oil - 6-Cylinder Engines
Front-Wheel Drive Axle - Instructions on Changing Oil (Axle Housing and Final Drives)
Front-Wheel Drive Axle - Final Drives with Brake, Oil Change
Front-Wheel Drive Axle - Final Drives without Brake, Oil Change
Front-Wheel Drive Axle - Axle Housing, Oil Change
Transmission/Hydraulic Oil Filters, Replace
Check Air Intake Hoses - on 6-Cylinder Engines
Front Hitch - Check Hardware Torque
John Deere™ Front Loader - Mounting Frame - Maintenance
Open Operator's Station - Check Torques of Attaching Screws
CAT II Drawbar - Tighten the Screws
Section 105 - Service / After the First 750 Hours and Then Every 750 Hours
Check the Movement Inhibitor – PowrQuad™Transmission
Check the Movement Inhibitor — PowrQuad™ PLUS Transmission and AutoQuad™ PLUS Transmission
Check the Movement Inhibitor – CommandQuad™ Transmission
PTO Actuation - Check Safety Circuit
Cab — Check Closing Mechanisms and Rubber Seals of the Doors, Windows, and Roof Hatches
Cab — Change Activated Carbon Filter (If Equipped)
Engine - Check Drive Belt for Wear
Check Engine Ground Connection - 6-Cylinder Engines
Bleed and Check the Brake System
Service the Fuel Tank
Change the Fuel Filters - 6-Cylinder Engines
Front-Wheel Drive Axle - Axle Housing, Check Oil Level
Front-Wheel Drive Axle - Final Drives without Brakes, Check Oil Level
Front PTO - Change Oil Filter (If Equipped)
Tighten Axle Bolts - Adjustable Front Axle, Type B
Tighten the wheel bolts of the front wheels, with adjustable front axle type B
Tighten Front-Wheel Bolts, on Vehicles with Front-Wheel Drive Axles
Tighten Wheel Bolts of the Rear Wheels, with Flanged Axles
Tighten Wheel Bolts of the Rear Wheels, with Rack-and-Pinion Axles
Wheel Weights - Tighten Screws
Rear PTO - Lubricate PTO Stub Shaft Support
Lubricate Rear Axle Bearings
Adjustable Front Axle Type B - Lubricate the Grease Fittings
Check the Drawbar for Wear
Section 110 - Service / Once a Year
Inspect Seat Belt
Use coolant test strips to check engine coolant - with 6-cylinder engines
Inspect Hydraulic Hoses
Other Annual Service Jobs
Section 115 - Service / Every 1500 Hours or 2 Years
Change Cab Air Filters
Change the Engine Air Cleaner
Engine - Change Filter of Oil Separator in Crankcase Vent (If Equipped)
Change Transmission/Hydraulic Oil and Clean Intake Screen
Front PTO - Change Oil (If Equipped)
Front-Axle Suspension - Accumulator Check
Section 117 - Service / Every 4500 Hours
Engine Air Cleaner - Change Secondary Element
Clean DEF Tank
Change Filter of DEF Dosing Unit
Replace Suction Screen on DEF Tank Header (Only for Tractors without In-Line DEF Filter)
Section 120 - Service / Every 6000 Hours
Change the Coolant - 6-Cylinder Engines
Change In-Line DEF Filter (If Equipped)
Section 125 - Service / As Required
Clean Cab Air Filters
Bleed Air from Fuel System - 6-Cylinder Engines
Front Loader Mounting Frame - Maintenance
Cooling System - Viscous Fan, Cleaning the Bimetallic Spring
Cooling System - Check the Viscous Fan
Check the Mechanical Cab Suspension
Starter Motor
DEF Tank Vent - Check Filter
Change Diesel Particulate Filter (DPF)
Fuse and Relay of Electrical Starting Aid - Only on Tractors with Aftertreatment (Final Tier 4 / Stage IV)
Fuses and Relays under the Right Access Step
Fuses and Relays (LCS) and (FRM), General Information - Tractors with Operator's Cab
Fuses and Relays (LCS) and (FRM) - Tractors with Operator's Cab
Fuses and Relays (LCS) and (FRM), General Information - Tractors with Open Operator's Station
Fuses and Relays (LCS) and (FRM) - Tractors with Open Operator's Station
Handling Halogen Lamps Safely
Headlight in the Engine Hood, Low-Beam Headlight - Exchange Lamps
Headlight in the Engine Hood, High-Beam Headlight - Exchange Lamps
Worklight in the Engine Hood - Exchange Lamps
Worklights on Cab Frame, Cab Roof, or Rear Fender - Exchange Lamps
Turn-Signal on Cab Roof, Change lamps
Headlights on Cab Frame - Change Lamp
Tail Brake Light/Turn Signal on Fender - Change Lamp
Replace Bulb on Beacon Light
Cab Lighting - Replace Bulb
Lighting of the Transmission Shift Unit - Replace Bulb
Section 126 - Maintenance Records
Information on Engine Oil Change — Tractors with 6-Cylinder Engine
Engine Oil and Filter Change
Engine Air Cleaner and Cab Air Filters, Service
Cooling System, Service
Service the DEF System
Yearly
Yearly
100 Hours Service
750 Hour Service
1500 Hour Service
2250 Hour Service
3000 Hour Service
3750 Hour Service
4500 Hours Service
5250 Hour Service
6000 Hour Service
6750 Hour Service
7500 Hour Service
8250 Hour Service
9000 Hour Service
9750 Hour Service
10000 Hour Service
Information About Further Services
Record For Further Services
Section 130 - Troubleshooting
Selective Control Valves (SCVs)
Operator's Cab
Section 135 - Diagnostic Trouble Codes and Settings
STOP, Service Alert, and Information Indicators
Operation and Entering the Diagnostic Addresses with Digital Display (Customer Level)
Section 140 - Storage
Storage for a Long Period
Removing Tractor from Storage
Section 145 - Technical specifications
Dimensions - 6155M with Open Operator's Station, without Front-Wheel Drive Axle
Dimensions - 6155M with Open Operator's Station and Front-Wheel Drive Axle
Dimensions - 6155M with Operator's Cab, without Front-Wheel Drive Axle
Dimensions - 6155M with Operator's Cab and Front-Wheel Drive Axle
Dimensions - 6175M with Operator's Cab and Front-Wheel Drive Axle
Dimensions - 6195M with Operator's Cab and Front-Wheel Drive Axle
Engine - 6155M
Engine - 6175M
Engine - 6195M
PTO Power Output - 6155M
PTO Power Output - 6175M
PTO Power Output - 6195M
Transmission - 6155M
Transmission - 6175M and 6195M
Hitch - 6155M
Hitch - 6175M and 6195M
Hydraulic System - 6155M
Hydraulic System - 6175M and 6195M
Capacities - 6155M
Capacities - 6175M and 6195M
Oil Quantity that Can be Removed
Loads and Weights - 6155M
Loads and Weights - 6175M and 6195M
Vibration
Sound level
Permissible Front Axle Load in Relation to Tires (Normal Operation) - 6155M
Permissible Front Axle Load in Relation to Tires (Front Loader Operation) - 6155M
Permissible Front Axle Load in Relation to Tires (Normal Operation) - 6175M
Permissible Front Axle Load in Relation to Tires (Front Loader Operation) - 6175M
Permissible Front Axle Load in Relation to Tires (Normal Operation) - 6195M
Permissible Front Axle Load in Relation to Tires (Front Loader Operation) - 6195M
Permissible Rear Axle Load in Relation to Tires - 6155M
Permissible Rear Axle Load in Relation to Tires - 6175M
Permissible Rear Axle Load in Relation to Tires - 6195M
Identification of Air-Conditioning Systems
Safety Note Regarding the Subsequent Installation of Electrical and Electronic Appliances and/or Components
Carbon Dioxide Emissions (CO₂)
Limited Battery Warranty
Warranty on Tires
Emissions Control System Certification Label
EPA Non-road Emissions Control Warranty Statement—Compression Ignition
CARB Non-road Emissions Control Warranty Statement—Compression Ignition
Section 150 - Serial Numbers
Type Plates
Plate for Product Identification and Serial Numbers of Components
Plate for Product Identification Number
Engine Serial Number
Transmission Serial Number
Front-Wheel Drive Axle Serial Number
Open Operator's Station Serial Number
Operator’s Cab Serial Number
Serial Number of Operator's Seat
Sub-Assembly Serial Numbers
Section 155 - Glossary
Glossary
Section 160 - Change of Ownership
Record of Changes of Ownership
Section 165 - Pre-delivery Inspection
Service Procedure
Copy for owner
Copy for dealer
Section IBC - John Deere Service Keeps You On the Job
John Deere Parts
The Right Tools
Well-Trained Technicians
Prompt Service
Format: HTML
Brand: John Deere
Foreword
Trademarks
Section 05 - Safety
Fire Prevention
In Case of Fire
Instructional Seat
Use a Safety Chain
Avoid Hot Exhaust
Park Machine Safely
Use the Seat Belt
Do Not Modify ROPS
Starter Motor
Do Not Modify ROPS
Never Carry Riders
Key Switch
Come-Home Mode
Immobilizer
Creeper - Controls
PTO - Controls
Software Update
Section 20 - Lights
Emergency Exits
Use the Seat Belt
Comfort Seat MSG83
Comfort Seat MSG85
Fan and Air Louvers
Heating System
Storage Tray
Dome Lights
Beacon Light
Install Monitor
ISOBUS Socket (ISB)
Opening Windows
Roof Hatch
Prestarting Checks
Engine Protection
Cold Start Aids
Coolant Heater
Starting the Engine
Stopping the Engine
Parking the Tractor
Tow the Tractor
Fill the Fuel Tank
Parking the Tractor
Economy Front Hitch
Three-point hitch
Center Link
Adjust Lift Links
PTO Speeds
PTO Options
Front PTO
Engaging Rear PTO
Load on Rear Wheels
Draining Tires
Wheel Weights
Change Tires Safely
Front Tires
Tire Pressures
CAT II Drawbar
Front Jaw Hitch
Use Safety Chain
Tow the Tractor
Multipurpose Grease
Lubricant Storage
Diesel Fuel
Testing Diesel Fuel
Biodiesel Fuel
Service Intervals
Open the Hood
Access to Fuses
Service As Required
Other Service Jobs
Periodic Service
All Service Tasks
Check Brakes
Check the Lights
Inspect Seat Belt
Clean DEF Tank
Starter Motor
Yearly
Yearly
100 Hours Service
750 Hour Service
1500 Hour Service
2250 Hour Service
3000 Hour Service
3750 Hour Service
4500 Hours Service
5250 Hour Service
6000 Hour Service
6750 Hour Service
7500 Hour Service
8250 Hour Service
9000 Hour Service
9750 Hour Service
10000 Hour Service
Operator's Cab
Engine - 6155M
Engine - 6175M
Engine - 6195M
Hitch - 6155M
Capacities - 6155M
Vibration
Sound level
Warranty on Tires
Type Plates
Glossary
Service Procedure
Copy for owner
Copy for dealer
John Deere Parts
The Right Tools
Prompt Service
- JOHN DEERE CODE DTC LIST
