Martin Welker
104
230,310
John Deere 6140R 6210R Tractor Repair Technical Manual TM403919
Brand: John Deere
Type of Machine: Tractor
Model: John Deere 6140R 6210R Tractor
Part Number: TM403919
Number of Pages: 2558 Pages
AutoPowr IVT Transmission
Install the AutoPowr™ IVT™ Transmission fig 1
Removal of the AutoPowr™ IVT™ Transmission fig 1
Removal of the AutoPowr™ IVT™ Transmission, Preliminary Work fig 1
Install the AutoPowr™ IVT™ Transmission fig 2
Removal of the AutoPowr™ IVT™ Transmission fig 2
Install the AutoPowr™ IVT™ Transmission fig 4
Removal of the AutoPowr™ IVT™ Transmission fig 4
Install the AutoPowr™ IVT™ Transmission fig 5
Removal of the AutoPowr™ IVT™ Transmission fig 5
Install the AutoPowr™ IVT™ Transmission fig 6
Install the AutoPowr™ IVT™ Transmission fig 7
Install the AutoPowr™ IVT™ Transmission fig 8
Removal of the AutoPowr™ IVT™ Transmission fig 8
Install the AutoPowr™ IVT™ Transmission fig 9
Removal of the AutoPowr™ IVT™ Transmission fig 9
Install the AutoPowr™ IVT™ Transmission fig 10
Removal of the AutoPowr™ IVT™ Transmission fig 10
Removal of the AutoPowr™ IVT™ Transmission fig 11
Removal of the AutoPowr™ IVT™ Transmission fig 12
Install the AutoPowr™ IVT™ Transmission fig 13
Install the AutoPowr™ IVT™ Transmission fig 14
Install the AutoPowr™ IVT™ Transmission fig 15
BRAKES
Air Brake System - Change the Coupling Ends FIG 1
Air-Brake System - Reconditioning the Compressor FIG 1
Air-Brake System - Replacing the Compressed-Air Tank FIG 1
Air-Brake System - Replacing the Trailer Control Valve (for Dual-Line Brakes) FIG 1
Air-brake system - Replacing the compressor FIG 1
Air-brake system - Replacing the trailer control valve (for single-line brakes) FIG 1
Brake Valve - Changing the Accumulator FIG 1
Brake Valve - Exploded View FIG 1
Emergency Brake - Exploded View FIG 1
Emergency Brake System - Replace the Brake Cable FIG 1
Hydraulic Trailer Brake - Change the Coupler FIG 1
Hydraulic Trailer Brake - Changing the Trailer Brake Valve FIG 1
Install the Emergency Brake FIG 1
Install the Rear Brakes (Tractors 6140R - 6150R) FIG 1
Rear Brakes - Exploded View (Tractors 6140R - 6150R) FIG 1
Rear Brakes - Exploded View (Tractors 6170R - 6210R) FIG 1
Rear Brakes - Replace the Return Pins on the Rear Brakes (Tractors 6140R - 6150R) FIG 1
Rear Brakes - Replacing the Delay Valve with Shuttle Valve FIG 1
Remove the Rear Brakes (Tractors 6140R - 6150R) FIG 1
Repair the Rear Brakes (Tractors 6140R - 6150R) FIG 1
Air Brake System - Change the Coupling Ends FIG 2
Brake Valve - Changing the Accumulator FIG 2
Brake Valve - Exploded View FIG 2
Emergency Brake - Exploded View FIG 2
Install the Emergency Brake FIG 2
Install the Rear Brakes (Tractors 6140R - 6150R) FIG 2
Rear Brakes - Replace the Return Pins on the Rear Brakes (Tractors 6140R - 6150R) FIG 2
Rear Brakes - Replacing the Delay Valve with Shuttle Valve FIG 2
Reconditioning the Power Brake Valve FIG 2
Remove Brake Valve (Power Fill Brakes) FIG 2
Remove the Rear Brakes (Tractors 6140R - 6150R) FIG 2
Air Brake System - Change the Coupling Ends FIG 3
Hydraulic Trailer Brake - Changing the Trailer Brake Valve FIG 3
Install the Emergency Brake FIG 3
Install the Power Brake Valve FIG 3
Install the Rear Brakes (Tractors 6140R - 6150R) FIG 3
Installing the Power-Fill Brake Valve with MFWD And Disk Brake FIG 3
Rear Brakes - Replace the Return Pins on the Rear Brakes (Tractors 6140R - 6150R) FIG 3
Rear Brakes - Replacing the Delay Valve with Shuttle Valve FIG 3
Reconditioning the Power Brake Valve FIG 3
Remove Power-Fill Brake Valve with MFWD And Disk Brake FIG 3
Remove the Rear Brakes (Tractors 6140R - 6150R) FIG 3
Repair the Rear Brakes (Tractors 6140R - 6150R) FIG 3
Air Brake System - Change the Coupling Ends FIG 4
Emergency Brake System - Replace the Brake Cable FIG 4
Install the Emergency Brake FIG 4
Install the Rear Brakes (Tractors 6140R - 6150R) FIG 4
Rear Brakes - Replace the Return Pins on the Rear Brakes (Tractors 6140R - 6150R) FIG 4
Air Brake System - Change the Coupling Ends FIG 5
Rear Brakes - Replace the Return Pins on the Rear Brakes (Tractors 6140R - 6150R) FIG 5
Rear Brakes - Replace the Return Pins on the Rear Brakes (Tractors 6140R - 6150R) FIG 6
Reconditioning the Power Brake Valve FIG 17
Reconditioning the Power Brake Valve FIG 18
Reconditioning the Power Brake Valve FIG 19
Reconditioning the Power Brake Valve with MFWD And Multi-Disk Brake FIG 20
Air-Brake System - Repair Specifications
Brake Valve - Disconnect Connect Steering or Brake Hoses
Brake Valve - Repair Specifications
Emergency Brake System - Repair Specifications
Hydraulic Trailer Brake - Repair Instructions
Hydraulic Trailer Brake - Repair Specifications
Rear Brakes - Repair Specifications
Reconditioning the Power Brake Valve with MFWD And Multi-Disk Brake FIG 20-1
DIAGRAM
DRIVETRAIN
Assemble Final Drive fig 1
Assembling the front PTO fig 1
Differential - Adjusting Backlash FIG 1
Differential - Replacing Differential Lock Solenoid (Y05) FIG 1
Differential – Checking And Adjusting the Rolling Drag Torque FIG 1
Differential – Exploded View (Tractor Models Smaller Than 6170R) FIG 1
Differential – Sectional View (Tractor Models Smaller Than 6170R) FIG 1
Disassembling the front PTO fig 1
Drain Transmission FIG 1
Fill with Transmission Hydraulic Oil FIG 1
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 1
Final Drives - Remove the Planetary Carrier (Tractor Models Smaller Than 6170R) fig 1
Final Drives - Repair the Planetary Carrier (Tractor Models Smaller Than 6170R) fig 1
Final Drives – Exploded View (Tractor Models Smaller Than 6170R) fig 1
Final Drives – Exploded View (Tractor Models from 6170R) fig 1
Final Drives – Sectional View (Tractor Models Smaller Than 6170R) fig 1
Front PTO - Changing the Oil Filter fig 1
Front PTO - Exploded View fig 1
Front PTO - Replacing the Oil Cooler fig 1
Front PTO - Replacing the front PTO speed sensor B58 fig 1
Front PTO - Sectional view fig 1
Front PTO - Y94 - Replacing the Proportional Solenoid Valve for Front PTO fig 1
Front implement drive - Exploded view fig 1
Hydraulic Pump Drive - Exploded View FIG 1
Hydraulic Pump Drive - Install the Pump Drive Gear fig 1
Hydraulic Pump Drive - Remove the Pump Drive Gear FIG 1
Hydraulic Pump Drive - Repair the Pump Drive Gear fig 1
Hydraulic Pump Drive - Sectional View FIG 1
Install the Final Drives FIG 1
Install the Front PTO FIG 1
Install the Rear PTO FIG 1
Installing the Differential FIG 1
Installing the Front Implement Drive fig 1
Mechanical Front-Wheel Drive - Exploded View (AutoPowr™IVT™ Transmission) FIG 1
Mechanical Front-Wheel Drive - Exploded View (PowrQuad™ Transmission) FIG 1
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (PowrQuad™ Transmission) FIG 1
Mechanical Front-Wheel Drive - Replacing the FWD Solenoid Valve (Y03) FIG 1
Mechanical Front-Wheel Drive - Sectional View (AutoPowr™ IVT™ Transmission) FIG 1
Mechanical Front-Wheel Drive - Sectional View (PowrQuad™ Transmission) FIG 1
Mechanical Front-Wheel Drive -Adjusting End Play of Clutch Shaft FIG 1
Rear PTO Options - Adjusting the Tapered Roller Bearing of the Bearing Support fig 1
Rear PTO Options - Adjusting the Tapered Roller Bearing of the Countershaft fig 1
Rear PTO Options - Exploded View fig 1
Rear PTO Options - Install the PTO Drive Train fig 1
Rear PTO Options - Installing the PTO Clutch fig 1
Rear PTO Options - Reconditioning the Countershaft fig 1
Rear PTO Options - Reconditioning the Oil Sight Glass fig 1
Rear PTO Options - Reconditioning the Output Shaft fig 1
Rear PTO Options - Reconditioning the PTO Brake fig 1
Rear PTO Options - Reconditioning the PTO Clutch fig 1
Rear PTO Options - Reconditioning the PTO Shaft Spline Identifier fig 1
Rear PTO Options - Removing the PTO Clutch fig 1
Rear PTO Options - Removing the PTO Drive Train fig 1
Rear PTO Options - Replacing Y81 Proportional Solenoid Valve for Rear PTO fig 1
Rear PTO Options - Replacing the Output Shaft Seal Ring fig 1
Rear PTO Options - Sectional View fig 1
Reconditioning the Differential (Tractor Models Smaller ThAnd 6170R) FIG 1
Reconditioning the Differential (Tractor Models from 6170R) FIG 1
Reconditioning the Front Implement Drive fig 1
Removal of the Front Implement Drive fig 1
Remove the Front PTO FIG 1
Remove the Rear PTO FIG 1
Removing the Differential FIG 1
Assemble Final Drive fig 2
Assembling the front PTO fig 2
Differential - Adjusting Backlash FIG 2
Differential – Checking And Adjusting the Rolling Drag Torque FIG 2
Disassembling the front PTO fig 2
Drain Transmission FIG 2
Fill with Transmission Hydraulic Oil FIG 2
Final Drives - Repair the Planetary Carrier (Tractor Models Smaller Than 6170R) fig 2
Front PTO - Changing the Oil Filter fig 2
Front PTO - Replacing the front PTO speed sensor B58 fig 2
Hydraulic Pump Drive - Install the Pump Drive Gear fig 2
Hydraulic Pump Drive - Remove the Pump Drive Gear FIG 2
Hydraulic Pump Drive - Repair the Pump Drive Gear fig 2
Install the Final Drives FIG 2
Install the Front PTO FIG 2
Install the Rear PTO FIG 2
Installing the Differential FIG 2
Installing the Front Implement Drive fig 2
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (AutoPowr™IVT™ Transmission) FIG 2
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (PowrQuad™ Transmission) FIG 2
Mechanical Front-Wheel Drive -Adjusting End Play of Clutch Shaft FIG 2
Rear PTO Options - Adjusting the Tapered Roller Bearing of the Bearing Support fig 2
Rear PTO Options - Adjusting the Tapered Roller Bearing of the Countershaft fig 2
Rear PTO Options - Exploded View fig 2
Rear PTO Options - Install the PTO Drive Train fig 2
Rear PTO Options - Installing the PTO Clutch fig 2
Rear PTO Options - Reconditioning the Countershaft fig 2
Rear PTO Options - Reconditioning the Oil Sight Glass fig 2
Rear PTO Options - Reconditioning the Output Shaft fig 2
Rear PTO Options - Reconditioning the PTO Clutch fig 2
Rear PTO Options - Reconditioning the PTO Shaft Spline Identifier fig 2
Rear PTO Options - Removing the PTO Clutch fig 2
Rear PTO Options - Removing the PTO Drive Train fig 2
Rear PTO Options - Replacing Y81 Proportional Solenoid Valve for Rear PTO fig 2
Rear PTO Options - Replacing the Output Shaft Seal Ring fig 2
Rear PTO Options - Sectional View fig 2
Removal of the Front Implement Drive fig 2
Remove the Front PTO FIG 2
Remove the Rear PTO FIG 2
Removing the Differential FIG 2
Assemble Final Drive fig 3
Assembling the front PTO fig 3
Differential - Adjusting Backlash FIG 3
Disassembling the front PTO fig 3
Fill with Transmission Hydraulic Oil FIG 3
Front PTO - Replacing the front PTO speed sensor B58 fig 3
Hydraulic Pump Drive - Install the Pump Drive Gear fig 3
Hydraulic Pump Drive - Remove the Pump Drive Gear FIG 3
Install the Final Drives FIG 3
Install the Front PTO FIG 3
Install the Rear PTO FIG 3
Installing the Differential FIG 3
Installing the Front Implement Drive fig 3
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (AutoPowr™IVT™ Transmission) FIG 3
Mechanical Front-Wheel Drive -Adjusting End Play of Clutch Shaft FIG 3
Rear PTO Options - Adjusting the Tapered Roller Bearing of the Countershaft fig 3
Rear PTO Options - Exploded View fig 3
Rear PTO Options - Installing the PTO Clutch fig 3
Rear PTO Options - Reconditioning the Countershaft fig 3
Rear PTO Options - Reconditioning the Oil Sight Glass fig 3
Rear PTO Options - Reconditioning the Output Shaft fig 3
Rear PTO Options - Reconditioning the PTO Clutch fig 3
Rear PTO Options - Reconditioning the PTO Shaft Spline Identifier fig 3
Rear PTO Options - Reconditioning the PTO Shifter fig 3
Rear PTO Options - Removing the PTO Clutch fig 3
Rear PTO Options - Removing the PTO Drive Train fig 3
Rear PTO Options - Replacing Y81 Proportional Solenoid Valve for Rear PTO fig 3
Rear PTO Options - Replacing the Output Shaft Seal Ring fig 3
Removal of the Front Implement Drive fig 3
Remove the Final Drives FIG 3
Remove the Front PTO FIG 3
Remove the Rear PTO FIG 3
Removing the Differential FIG 3
Assemble Final Drive fig 4
Assembling the front PTO fig 4
Differential - Adjusting Backlash FIG 4
Disassembling the front PTO fig 4
Fill with Transmission Hydraulic Oil FIG 4
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 4
Final Drives - Repair the Planetary Carrier (Tractor Models Smaller Than 6170R) fig 4
Front PTO - Changing the Oil Filter fig 4
Hydraulic Pump Drive - Install the Pump Drive Gear fig 4
Hydraulic Pump Drive - Remove the Pump Drive Gear FIG 4
Hydraulic Pump Drive - Repair the Pump Drive Gear fig 4
Install the Final Drives FIG 4
Install the Front PTO FIG 4
Install the Rear PTO FIG 4
Installing the Differential FIG 4
Installing the Front Implement Drive fig 4
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (PowrQuad™ Transmission) FIG 4
Rear PTO Options - Adjusting the Tapered Roller Bearing of the Countershaft fig 4
Rear PTO Options - Exploded View fig 4
Rear PTO Options - Installing the PTO Clutch fig 4
Rear PTO Options - Reconditioning the Countershaft fig 4
Rear PTO Options - Reconditioning the Oil Sight Glass fig 4
Rear PTO Options - Reconditioning the Output Shaft fig 4
Rear PTO Options - Reconditioning the PTO Clutch fig 4
Rear PTO Options - Reconditioning the PTO Shaft Spline Identifier fig 4
Rear PTO Options - Reconditioning the PTO Shifter fig 4
Rear PTO Options - Removing the PTO Clutch fig 4
Rear PTO Options - Removing the PTO Drive Train fig 4
Rear PTO Options - Replacing Y81 Proportional Solenoid Valve for Rear PTO fig 4
Rear PTO Options - Replacing the Output Shaft Seal Ring fig 4
Removal of the Front Implement Drive fig 4
Remove the Final Drives FIG 4
Remove the Rear PTO FIG 4
Removing the Differential FIG 4
Assembling the front PTO fig 5
Disassembling the front PTO fig 5
Fill with Transmission Hydraulic Oil FIG 5
Final Drives - Repair the Planetary Carrier (Tractor Models Smaller Than 6170R) fig 5
Front PTO - Changing the Oil Filter fig 5
Hydraulic Pump Drive - Install the Pump Drive Gear fig 5
Hydraulic Pump Drive - Repair the Pump Drive Gear fig 5
Install the Final Drives FIG 5
Install the Rear PTO FIG 5
Installing the Differential FIG 5
Installing the Front Implement Drive fig 5
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (AutoPowr™IVT™ Transmission) FIG 5
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (PowrQuad™ Transmission) FIG 5
Rear PTO Options - Adjusting the Tapered Roller Bearing of the Countershaft fig 5
Rear PTO Options - Installing the PTO Clutch fig fig 5
Rear PTO Options - Reconditioning the Countershaft fig 5
Rear PTO Options - Reconditioning the Output Shaft fig 5
Rear PTO Options - Reconditioning the PTO Clutch fig 5
Rear PTO Options - Reconditioning the PTO Shaft Spline Identifier fig 5
Rear PTO Options - Reconditioning the PTO Shifter fig 5
Rear PTO Options - Removing the PTO Clutch fig 5
Rear PTO Options - Removing the PTO Drive Train fig 5
Rear PTO Options - Replacing the Output Shaft Seal Ring fig 5
Remove the Final Drives FIG 5
Remove the Rear PTO FIG 5
Assembling the front PTO fig 6
Disassembling the front PTO fig 6
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 6
Final Drives - Repair the Planetary Carrier (Tractor Models Smaller Than 6170R) fig 6
Hydraulic Pump Drive - Install the Pump Drive Gear 6
Hydraulic Pump Drive - Repair the Pump Drive Gear fig 6
Install the Final Drives FIG 6
Installing the Differential FIG 6
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (AutoPowr™IVT™ Transmission) FIG 6
Rear PTO Options - Adjusting the Tapered Roller Bearing of the Countershaft fig 6
Rear PTO Options - Installing the PTO Clutch fig fig 6
Rear PTO Options - Reconditioning the Countershaft fig 6
Rear PTO Options - Reconditioning the Output Shaft fig 6
Rear PTO Options - Reconditioning the PTO Clutch fig 6
Rear PTO Options - Reconditioning the PTO Shifter fig 6
Rear PTO Options - Removing the PTO Drive Train fig 6
Rear PTO Options - Replacing the Output Shaft Seal Ring fig 6
Remove the Final Drives FIG 6
Remove the Rear PTO FIG 6
Assemble Final Drive fig 7
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 7
Final Drives - Repair the Planetary Carrier (Tractor Models Smaller Than 6170R) fig 7
Hydraulic Pump Drive - Repair the Pump Drive Gear fig 7
Install the Final Drives FIG 7
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (AutoPowr™IVT™ Transmission) FIG 7
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (PowrQuad™ Transmission) FIG 7
Rear PTO Options - Adjusting the Tapered Roller Bearing of the Countershaft fig 7
Rear PTO Options - Installing the PTO Clutch fig fig 7
Rear PTO Options - Reconditioning the Output Shaft fig 7
Rear PTO Options - Reconditioning the PTO Clutch fig 7
Rear PTO Options - Reconditioning the PTO Shifter fig 7
Rear PTO Options - Replacing the Output Shaft Seal Ring fig 7
Remove the Final Drives FIG 7
Remove the Rear PTO FIG 7
Assemble Final Drive 8
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 8
Hydraulic Pump Drive - Repair the Pump Drive Gear fig 8
Install the Final Drives FIG 8
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (PowrQuad™ Transmission) FIG 8
Rear PTO Options - Reconditioning the PTO Clutch fig 8
Rear PTO Options - Reconditioning the PTO Shifter fig 8
Rear PTO Options - Replacing the Output Shaft Seal Ring fig 8
Remove the Final Drives FIG 8
Remove the Rear PTO FIG 8
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 9
Hydraulic Pump Drive - Repair the Pump Drive Gear fig 9
Install the Final Drives FIG 9
Rear PTO Options - Reconditioning the Output Shaft fig 9
Rear PTO Options - Reconditioning the PTO Clutch fig 9
Rear PTO Options - Reconditioning the PTO Shifter fig 9
Remove the Final Drives FIG 9
Remove the Rear PTO FIG 9
Assemble Final Drive fig 10
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 10
Install the Final Drives FIG 10
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (AutoPowr™IVT™ Transmission) FIG 10
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (PowrQuad™ Transmission) FIG 10
Rear PTO Options - Reconditioning the Output Shaft fig 10
Rear PTO Options - Reconditioning the PTO Clutch 10
Rear PTO Options - Reconditioning the PTO Shifter fig 10
Remove the Final Drives FIG 10
Assemble Final Drive fig 11
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 11
Install the Final Drives FIG 11
Rear PTO Options - Reconditioning the Output Shaft fig 11
Rear PTO Options - Reconditioning the PTO Clutch fig 11
Rear PTO Options - Reconditioning the PTO Shifter fig 11
Remove the Final Drives FIG 11
Assemble Final Drive fig 12
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 12
Install the Final Drives FIG 12
Mechanical Front-Wheel Drive - Install the Front-Wheel Drive Clutch (PowrQuad™ Transmission) FIG 12
Rear PTO Options - Reconditioning the Output Shaft fig 12
Rear PTO Options - Reconditioning the PTO Clutch fig 12
Rear PTO Options - Reconditioning the PTO Shifter fig 12
Remove the Final Drives FIG 12
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 13
Install the Final Drives FIG 13
Rear PTO Options - Reconditioning the Output Shaft fig 13
Rear PTO Options - Reconditioning the PTO Clutch fig 13
Rear PTO Options - Reconditioning the PTO Shifter fig 13
Remove the Final Drives FIG 13
Rear PTO Options - Reconditioning the Output Shaft fig 14
Rear PTO Options - Reconditioning the PTO Clutch 14
Rear PTO Options - Reconditioning the PTO Clutch fig 14
Rear PTO Options - Reconditioning the PTO Shifter fig 14
Remove the Final Drives FIG 14
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 15
Rear PTO Options - Reconditioning the Output Shaft fig 15
Rear PTO Options - Reconditioning the PTO Clutch fig 15
Remove the Final Drives FIG 15
Final Drives - Installing the Planetary Carrier And Checking the Rolling Drag Torque fig 16
Rear PTO Options - Reconditioning the Output Shaft fig 16
Rear PTO Options - Reconditioning the PTO Clutch fig 16
Remove the Final Drives FIG 16
Rear PTO Options - Reconditioning the Output Shaft fig 17
Rear PTO Options - Reconditioning the PTO Clutch fig 17
Remove the Final Drives FIG 17
Rear PTO Options - Reconditioning the PTO Clutch fig 18
Remove the Final Drives FIG 18
Rear PTO Options - Reconditioning the PTO Clutch fig 19
Remove the Final Drives FIG 19
Rear PTO Options - Reconditioning the PTO Clutch fig 20
Remove the Final Drives FIG 20
Rear PTO Options - Reconditioning the PTO Clutch fig 21
Remove the Final Drives FIG 21
Rear PTO Options - Reconditioning the PTO Clutch fig 22
Remove the Final Drives FIG 22
Rear PTO Options - Reconditioning the PTO Clutch fig 23
Remove the Final Drives FIG 23
Rear PTO Options - Reconditioning the PTO Clutch 24
Rear PTO Options - Reconditioning the PTO Clutch fig 24
Remove the Final Drives FIG 24
Rear PTO Options - Reconditioning the PTO Clutch 25
Remove the Final Drives FIG 25
Front Implement Drive - Tightening the Clutch Screws (after 100 Hours of Operation)
Front Implement Drive - Tightening the Clutch Screws (after 100 Hours of Operation) fig 1
Front Implement Drive - Tightening the Clutch Screws (after 100 Hours of Operation) fig 2
Front Implement Drive - Tightening the Clutch Screws (after 100 Hours of Operation) fig 3
Assembling the Final Drives (Tractor Models Smaller Than 6170R)
Assembling the Final Drives (Tractor Models from 6170R)
Cross-Sectional View—Hi-Crop Final Drive
Differential - General Repair Procedures
Differential - Repair Specifications
Disassemble Final Drive
Disassembling the Final Drives (Tractor Models Smaller Than 6170R)
Disassembling the Final Drives (Tractor Models from 6170R)
Drain Transmission
Drive Systems - Final Drives, Summary of References
Drive Systems - Front Implement Drive, Summary of References
Drive Systems - Hydraulic Pump Drive, Summary of References
Drive Systems - Rear PTO Options, Summary of References
Drive Train (without Transmission) - Differential, Summary of References
Drive Train (without Transmission) - Mechanical Front-Wheel Drive, Summary of References
Drive Train (without Transmission) - Removal And Installation of Components, Summary of References
Drive Train (without Transmission) - Repair Specifications
Drive train (without transmission) - Front PTO, Summary of references
Drive train (without transmission) - Universal-joint shafts And torsion dampers, Summary of references
Final Drives - Reconditioning the Axle Housing (Tractor Models Smaller Than 6170R)
Final Drives - Reconditioning the Axle Housing (Tractor Models from 6170R)
Final Drives - Reconditioning the Axle Shaft (Tractor Models Smaller Than 6170R)
Final Drives - Reconditioning the Axle Shaft (Tractor Models from 6170R)
Final Drives - Reconditioning the Planetary Carrier (Tractor Models from 6170R)
Final Drives - Remove the Planetary Carrier (Tractor Models from 6170R)
Final Drives - Repair Specifications
Final Drives on Hi-Crop Tractors - Summary of References
Final Drives – Sectional View (Tractor Models from 6170R)
Front Implement Drive - Repair Specifications
Front PTO - Repair specifications
General Repair Procedures— Hi-Crop Final Drive
Hydraulic Pump Drive - Check And Adjust the Backlash of the Pump Drive Pinion
Hydraulic Pump Drive - Installation of the Pump Drive Pinion
Hydraulic Pump Drive - Removal of the Pump Drive Pinion
Hydraulic Pump Drive - Repair Specifications
Hydraulic Pump Drive - Repairing the Pump Drive Pinion
Install Final Drive
Installing the Mechanical Front-Wheel Drive
Mechanical Front-Wheel Drive - Remove the Front-Wheel Drive Clutch (PowrQuad™ Transmission)
Mechanical Front-Wheel Drive - Removing the Front-Wheel Drive Clutch
Mechanical Front-Wheel Drive - Repair Specifications
Mechanical Front-Wheel Drive - Replacing the FWD Axle Speed Sensor (B89)
Rear PTO Options - Repair Specifications
Remove Final Drive
Remove the MechAndical Front-Wheel Drive
Remove the Rear PTO
U-Jointed Shafts Andd Torsion Dampers - Replacing the Torsion Damper Bearing
U.J. Shafts Andd Torsion Dampers - Installing the Engine U.J. Shaft
U.J. Shafts Andd Torsion Dampers - Installing the Torsion Damper
U.J. Shafts Andd Torsion Dampers - Installing the U.J. Shaft (FWD)
U.J. Shafts Andd Torsion Dampers - Reconditioning the U.J. Shaft (FWD)
U.J. Shafts Andd Torsion Dampers - Removing the Engine U.J. Shaft
U.J. Shafts Andd Torsion Dampers - Removing the Torsion Damper
U.J. Shafts Andd Torsion Dampers - Removing the U.J. Shaft (FWD)
ELECTRICAL
A53 - CAN-BUS Terminating Resistor (CAN-BUS - Implement) fig 1
A83 - CAN BUS Terminating Resistor (Vehicle CAN BUS (300 kBd)) fig 1
A84 - CAN BUS Terminating Resistor (Vehicle CAN BUS (300 kBd)) fig 1
Air-Conditioning or ClimaTrak™ Control Unit - Removal Andd Installation fig 1
Cab Control Unit - Removal Andd Installation fig 1
Cab Switch Module Control Unit - Removal Andd Installation fig 1
CommAnddCenter™ Control Unit - Removal Andd Installation fig 1
Control Unit LocAndtions fig 1
Control Unit for Power-Assisted PTO Shifting (PAPTOS) - RemovAndl Andnd InstAndllAndtion fig 1
ElectricAndl System - Remove Andnd InstAndll BAndttery FIG 1
ElectricAndl System - Setting Lights GIG 1
ElectricAndl System -Disconnecting the ElectricAndl Circuit FIG 1
Engine Control Unit - RemovAndl Andnd InstAndllAndtion fig 1
Front ChAndssis Control Unit (M400) - RemovAndl Andnd InstAndllAndtion fig 1
Front ChAndssis Control Unit (M50) - RemovAndl Andnd InstAndllAndtion fig 1
Immobilizer Control Unit - RemovAndl Andnd InstAndllAndtion fig 1
METRI PACK Connectors 1
ReAndr ChAndssis Control Unit (DirectDrive TrAndnsmission) - RemovAndl Andnd InstAndllAndtion fig 1
ReAndr ChAndssis Control Unit - RemovAndl Andnd InstAndllAndtion fig 1
Roof Control Unit - RemovAndl Andnd InstAndllAndtion fig 1
Steering Control Unit (AutoTrAndc™) - RemovAndl Andnd InstAndllAndtion fig 1
A53 - CAN-BUS Terminating Resistor (CAN-BUS - Implement) fig 2
A83 - CAN BUS Terminating Resistor (Vehicle CAN BUS (300 kBd)) fig 2
A84 - CAN BUS Terminating Resistor (Vehicle CAN BUS (300 kBd)) fig 2
Adjust Lights on Cab Frame FIG 2
Air-Conditioning or ClimaTrak™ Control Unit - Removal Andd Installation fig 2
Cab Control Unit - Removal Andd Installation fig 2
Cab Switch Module Control Unit - Removal Andd Installation fig 2
CommAndndCenter™ Control Unit - RemovAndl Andnd InstAndllAndtion fig 2
ElectricAndl System - Remove Andnd InstAndll BAndttery FIG 2
ElectricAndl System - Setting Lights FIG 2
Engine Control Unit - RemovAndl Andnd InstAndllAndtion fig 2
Front ChAndssis Control Unit (M400) - RemovAndl Andnd InstAndllAndtion fig 2
Front ChAndssis Control Unit (M50) - RemovAndl Andnd InstAndllAndtion fig 2
ReAndr ChAndssis Control Unit (DirectDrive TrAndnsmission) - RemovAndl Andnd InstAndllAndtion fig 2
Roof Control Unit - RemovAndl Andnd InstAndllAndtion fig 2
Steering Control Unit (AutoTrAndc™) - RemovAndl Andnd InstAndllAndtion fig 2
TrAndnsmission Control Unit (AutoPowr™ IVT™) - RemovAndl Andnd InstAndllAndtion fig 2
Cab Control Unit - Removal Andd Installation fig 3
CommAndndCenter™ Control Unit - RemovAndl Andnd InstAndllAndtion fig 3
ElectricAndl System - Remove Andnd InstAndll BAndttery FIG 3
ElectricAndl System - Setting Lights FIG 3
ReAndr ChAndssis Control Unit (DirectDrive TrAndnsmission) - RemovAndl Andnd InstAndllAndtion fig 3
Steering Control Unit (AutoTrAndc™) - RemovAndl Andnd InstAndllAndtion fig 3
TrAndnsmission Control Unit (AutoPowr™ IVT™) - RemovAndl Andnd InstAndllAndtion fig 3
Cab Control Unit - Removal Andd Installation fig 4
CommAndndCenter™ Control Unit - RemovAndl Andnd InstAndllAndtion fig 4
ElectricAndl System - Remove Andnd InstAndll BAndttery FIG 4
ReAndr ChAndssis Control Unit (DirectDrive TrAndnsmission) - RemovAndl Andnd InstAndllAndtion fig 4
CommAndndCenter™ Control Unit - RemovAndl Andnd InstAndllAndtion fig 5
ElectricAndl System - Remove Andnd InstAndll BAndttery FIG 5
CommAndndCenter™ Control Unit - RemovAndl Andnd InstAndllAndtion fig 6
ElectricAndl System - Remove Andnd InstAndll BAndttery FIG 6
CommAndndCenter™ Control Unit - RemovAndl Andnd InstAndllAndtion fig 7
ElectricAndl System - Remove Andnd InstAndll BAndttery FIG 7
CommAndndCenter™ Control Unit - RemovAndl Andnd InstAndllAndtion fig 8
ElectricAndl System - Remove Andnd InstAndll BAndttery FIG 8
CommAndndCenter™ Control Unit - RemovAndl Andnd InstAndllAndtion fig 9
ElectricAndl System - Remove Andnd InstAndll BAndttery FIG 9
CommAnddCenter™ Control Unit - Removal Andd Installation fig 10
CommAnddCenter™ Control Unit - Removal Andd Installation fig 11
CommAndndCenter™ Control Unit - RemovAndl Andnd InstAndllAndtion fig 12
CRIMP SNAP IN Connectors
Connectors
Connectors for Electronic Control Units
ElectricAndl System - ChAndrging Circuit, SummAndry of References
ElectricAndl System - Connectors, SummAndry of References
ElectricAndl System - Worklights Andnd BeAndcon WAndrning Light, RemovAndl Andnd InstAndllAndtion
ElectricAndl System -Lights, SummAndry of References
Instrument Unit - RemovAndl Andnd InstAndllAndtion
KOSTAL Connectors
METRI PACK Connectors FRONT
Strip Wire Ends
WEATHER PACK Connectors
Emission Control System, RemovAndl Andnd InstAndllAndtion of the Diesel PAndrticulAndte Filter FIG 1
Engine Mounting FIG 1
Install Engine FIG 1
Install the Engine, Additional Work FIG 1
Remove Engine FIG 1
Remove the Engine, Preliminary Work FIG 1
Replace the Engine Mountings, Further Work FIG 1
Replace the Engine Mountings, Preliminary Work FIG 1
Replace the Rear Engine Mountings FIG 1
Emission Control System, RemovAndl Andnd InstAndllAndtion of the Diesel PAndrticulAndte Filter FIG 2
Engine Mounting FIG 2
Install Engine FIG 2
Install the Engine, Additional Work FIG 2
Remove Engine FIG 2
Remove the Engine, Preliminary Work FIG 2
Replace the Rear Engine Mountings FIG 2
Emission Control System, RemovAndl Andnd InstAndllAndtion of the Diesel PAndrticulAndte Filter FIG 3
Install Engine FIG 3
Install the Engine, Additional Work FIG 3
Remove Engine FIG 3
Remove the Engine, Preliminary Work FIG 3
Replace the Rear Engine Mountings FIG 3
Emission Control System, RemovAndl Andnd InstAndllAndtion of the Diesel PAndrticulAndte Filter FIG 4
Install Engine FIG 4
Install the Engine, Additional Work FIG 4
Remove Engine FIG 4
Remove the Engine, Preliminary Work FIG 4
Replace the Rear Engine Mountings FIG 4
Emission Control System, RemovAndl Andnd InstAndllAndtion of the Diesel PAndrticulAndte Filter FIG 5
Install Engine FIG 5
Install the Engine, Additional Work FIG 5
Remove Engine FIG 5
Remove the Engine, Preliminary Work FIG 5
Emission Control System, RemovAndl Andnd InstAndllAndtion of the Diesel PAndrticulAndte Filter FIG 6
Install Engine FIG 6
Install the Engine, Additional Work FIG 6
Remove Engine FIG 6
Remove the Engine, Preliminary Work FIG 6
Install Engine FIG 7
Install the Engine, Additional Work FIG 7
Remove Engine FIG 7
Remove the Engine, Preliminary Work FIG 7
Install Engine FIG 8
Install the Engine, Additional Work FIG 8
Remove Engine FIG 8
Remove the Engine, Preliminary Work FIG 8
Remove Engine FIG 9
Remove the Engine, Preliminary Work FIG 9
Remove Engine FIG 10
Remove Engine FIG 11
Remove Engine FIG 12
Remove Engine FIG 13
Remove Engine FIG 14
Engine - RemovAndl Andnd InstAndllAndtion of Components, RepAndir SpecificAndtions
Engine - RemovAndl Andnd InstAndllAndtion of Components, SummAndry of References
Engine Mounting
Install Engine
Remove Engine
Replace the Front Engine Mountings
FUEL, AIR INTAKE, COOLING And EXHAUST SYSTEM
Automatic Belt Tensioner, Removal and Installation fig 1
B02 - Sensor for Air Cleaner Restriction Warning Light, Removal and Installation FIG 1
Charge Air Cooler Removal and Installation FIG 1
Cooler Package Removal and Installation FIG 1
Exhaust Filter - Adjustment fig 1
Exhaust System to Top Right Removal and Installation fig 1
Fuel Level Sensor, Removal and Installation FIG 1
Fuel Tank, Removal and Installation FIG 1
Radiator Removal and Installation fig 1
Relieving Drive Belt Tension fig 1
Replace the Drive Belt fig 1
Routing of the Drive Belt fig 1
B02 - Sensor for Air Cleaner Restriction Warning Light, Removal and Installation FIG 2
Charge Air Cooler Removal and Installation FIG 2
Cooler Package Removal and Installation FIG 2
Exhaust Filter - Adjustment fig 2
Exhaust System to Top Right Removal and Installation fig 2
Fuel Tank, Removal and Installation FIG 2
Radiator Removal and Installation fig 2
Relieving Drive Belt Tension fig 2
Replace the Drive Belt fig 2
Routing of the Drive Belt fig 2
Charge Air Cooler Removal and Installation FIG 3
Cooler Package Removal and Installation FIG 3
Exhaust Filter - Adjustment fig 3
Exhaust System to Top Right Removal and Installation fig 3
Fuel Tank, Removal and Installation FIG 3
Radiator Removal and Installation fig 3
Replace the Drive Belt fig 3
Cooler Package Removal and Installation FIG 4
Exhaust Filter - Adjustment fig 4
Exhaust System to Top Right Removal and Installation fig 4
Fuel Tank, Removal and Installation FIG 4
Radiator Removal and Installation fig 4
Replace the Drive Belt fig 4
Cooler Package Removal and Installation FIG 5
Exhaust Filter - Adjustment fig 5
Exhaust System to Top Right Removal and Installation fig 5
Fuel Tank, Removal and Installation FIG 5
Radiator Removal and Installation fig 5
Replace the Drive Belt fig 5
Cooler Package Removal and Installation FIG 6
Exhaust Filter - Adjustment fig 6
Replace the Drive Belt fig 6
Cooler Package Removal and Installation FIG 7
Exhaust Filter - Adjustment fig 7
Replace the Drive Belt fig 7
Cooler Package Removal and Installation FIG 8
Exhaust Filter - Adjustment fig 8
Replace the Drive Belt fig 8
Cooler Package Removal and Installation FIG 9
Exhaust Filter - Adjustment fig 9
Replace the Drive Belt fig 9
Cooler Package Removal and Installation FIG 10
Exhaust Filter - Adjustment fig 10
Replace the Drive Belt fig 10
Cooler Package Removal and Installation FIG 11
Exhaust Filter - Adjustment fig 11
Replace the Drive Belt fig 11
Exhaust Filter - Adjustment fig 12
Replace the Drive Belt fig 12
Exhaust Filter - Adjustment fig 13
Replace the Drive Belt fig 13
Replace the Drive Belt fig 14
Replace the Drive Belt fig 15
Replace the Drive Belt fig 16
Replace the Drive Belt fig 17
Replace the Drive Belt fig 18
Replace the Drive Belt fig 19
Engine Hood Removal and Installation
Exhaust System - Summary of References
Opening Engine Hood
GENERAL
Bleeding the Fuel System fig 1
Check Transmission Hydraulic System Oil Level fig 1
Checking the Function of the Fuel Transfer Pump fig 1
Draining Coolant fig 1
Installation and Removal of the Primary Air Cleaner Element fig 1
Check Transmission Hydraulic System Oil Level fig 2
Draining Coolant fig 2
Installation and Removal of the Primary Air Cleaner Element fig 2
Check Transmission Hydraulic System Oil Level fig 3
Check Transmission Hydraulic System Oil Level fig 4
Check Transmission Hydraulic System Oil Level fig 5
Air Intake System
AutoQuad PLUS™ Transmission
AutoTrac™
Auxiliary Brake
Biodiesel Fuel
Cab Suspension
Capacities
Check the Fuel Filters
Checking the Secondary (Safety) Element
Clutch Operation
Diesel Engine Break-In Oil
Diesel Fuel
Differential
Differential Lock
Electrical System
Engine Serial Number
Engine Specifications
FWD Axle with TLS
Final Drives
Front PTO
Front-Wheel Drive
Front-Wheel Drive Axle Oil
Front-Wheel Drive Serial Number
Grease
Heavy Duty Diesel Engine Coolant
Hitch
Hydraulic System with Axial Piston Pump (PFC System)
Hydraulic system inch fitting torques
Hydraulic system metric fitting torques
Immobilizer
John Deere Break-In™ Plus Engine Oil
Lubricity of Diesel Fuel
Metric Bolt and Screw Torque Values
Minimizing the Effect of Cold Weather on Diesel Engines
Operator's seat serial number
Operators Cab serial
PTO Power Output
Park Lock
PowrQuad PLUS™ Transmission
Preliminary Engine Test
Product Identification and Component Serial Number Plate
Rear PTO
Specifications - Summary of References
Supplemental Coolant Additives
Tests and Adjustments - Summary of References
Transmission Serial Number
Transmission and Hydraulic Oil
Using High-Pressure Washers
Visual Inspection of the Fuel System
HYDRAULIC SYSTEM
Adjust Multi-Function Lever (on Shift Console) for M-ICVs (Edition 1) FIG 1
Adjust Multi-Function Lever (on Shift Console) for M-ICVs (Edition 2) FIG 1
Charge Oil Pump - Checking the Lube Oil Valve FIG 1
Front Hitch - Remove and Install Lift Arm FIG 1
Front Hitch - Remove and Install Quick Couplers FIG 1
Front Hitch - Remove and Install the Lift Cylinders FIG 1
Hydraulic Pump - Oil Reservoir FIG 1
Rear Hitch - Hitch Valve, Removal and Installation of the Stepper Motor FIG 1
Rear Hitch - Hydraulic Draft Link Stabilizer Bars (HSB) - Removal and Installation of the Control Block FIG 1
Rear Hitch - Hydraulic Draft Link Stabilizer Bars (HSB), Reconditioning the Control Block FIG 1
Rear Hitch - Recondition Rockshaft Bearing Block FIG 1
Rear Hitch - Recondition the Hitch Valve FIG 1
Rear Hitch - Recondition the Hydraulic Center Link (HCL) FIG 1
Rear Hitch - Recondition the Hydraulic Draft Link Stabilizer Bars (HSB) FIG 1
Rear Hitch - Removal and Installation of the Hitch Valve FIG 1
Rear Hitch - Remove and Install Rockshaft Bearing Block FIG 1
Rear Hitch - Remove and Install the Draft Load Potentiometer and Draft Link Support FIG 1
Rear Hitch - Remove and Install the Hydraulic Center Link (HCL) FIG 1
Rear Hitch - Remove and Install the Position Sensor and Toothed Segment FIG 1
Recondition the Independent Control Valves (E-ICVs) FIG 1
Recondition the Independent Control Valves (M-ICVs) FIG 1
Recondition the Selective Control Valves (E-SCVs 300) FIG 1
Recondition the Selective Control Valves (E-SCVs 350) FIG 1
Recondition the Selective Control Valves (E-SCVs 450) FIG 1
Recondition the Selective Control Valves (M-SCVs 350) FIG 1
Recondition the Selective Control Valves (M-SCVs 450) FIG 1
Reconditioning the Control Block (without Priority 2) FIG 1
Reconditioning the Selective Control Valves (M-SCVs 100) FIG 1
Reconditioning the Selective Control Valves (M-SCVs 200) FIG 1
Reconditioning the Selective Control Valves (M-SCVs 300) FIG 1
Removal and Installation of the Charge Oil Pump FIG 1
Removal and Installation of the Hydraulic Pump FIG 1
Remove and Install Additional Oil Tank FIG 1
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 1) FIG 1
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 2) FIG 1
Remove and Install the Priority 1 Control Block
Remove and Install the Priority 1 Control Block FIG 1
Remove and Install the Priority 1 Control Block FIG 2
Remove and Install the Priority 1 Control Block FIG 4
Removing and Installing the Selective Control Valves (SCVs) FIG 1
Repair the Priority 1 Control Block
Repair the Priority 1 Control Block FIG 1
Repair the Priority 1 Control Block FIG 2
Selective Control Valves (M-SCVs) - Adjust the Actuating Cable FIG 1
Selective Control Valves (M-SCVs) - Remove and Install the Actuating Elements FIG 1
Selective Control Valves (SCVs) - Reconditioning the Couplers FIG 1
Adjust Multi-Function Lever (on Shift Console) for M-ICVs (Edition 1) FIG 2
Adjust Multi-Function Lever (on Shift Console) for M-ICVs (Edition 2) FIG 2
Charge Oil Pump - Checking the Lube Oil Valve FIG 2
Front Hitch - Remove and Install Lift Arm FIG 2
Front Hitch - Remove and Install Quick Couplers FIG 2
Front Hitch - Remove and Install the Lift Cylinders FIG 2
Hydraulic Oil Filter, Reconditioning FIG 2
Hydraulic Pump - Oil Reservoir FIG 2
Hydraulic Pump - Removing and Installing the Pressure-and-Flow Regulator FIG 2
Rear Hitch - Hydraulic Draft Link Stabilizer Bars (HSB) - Removal and Installation of the Control Block FIG 2
Rear Hitch - Recondition Rockshaft Bearing Block FIG 2
Rear Hitch - Recondition the Hitch Valve FIG 2
Rear Hitch - Recondition the Hydraulic Center Link (HCL) FIG 2
Rear Hitch - Removal and Installation of the Hitch Valve FIG 2
Rear Hitch - Remove and Install Rockshaft Bearing Block FIG 2
Rear Hitch - Remove and Install the Hydraulic Center Link (HCL) FIG 2
Recondition the Independent Control Valves (E-ICVs) FIG 2
Recondition the Independent Control Valves (M-ICVs) FIG 2
Recondition the Selective Control Valves (E-SCVs 300) FIG 2
Recondition the Selective Control Valves (E-SCVs 350) FIG 2
Recondition the Selective Control Valves (E-SCVs 450) FIG 2
Reconditioning the Control Block (without Priority 2) FIG 2
Reconditioning the Priority 2 Control Block
Reconditioning the Priority 2 Control Block FIG 1
Reconditioning the Priority 2 Control Block FIG 2
Reconditioning the Selective Control Valves (M-SCVs 100) FIG 2
Removal and Installation of the Charge Oil Pump FIG 2
Removal and Installation of the Control Block with without Priority 2
Removal and Installation of the Control Block with without Priority 2 FIG 10
Removal and Installation of the Control Block with without Priority 2 FIG 11
Removal and Installation of the Control Block with without Priority 2 FIG 12
Removal and Installation of the Control Block with without Priority 2 FIG 13
Removal and Installation of the Control Block with without Priority 2 FIG 14
Removal and Installation of the Control Block with without Priority 2 FIG 15
Removal and Installation of the Control Block with without Priority 2 FIG 16
Removal and Installation of the Control Block with without Priority 2 FIG 17
Removal and Installation of the Control Block with without Priority 2 FIG 2
Removal and Installation of the Control Block with without Priority 2 FIG 3
Removal and Installation of the Control Block with without Priority 2 FIG 4
Removal and Installation of the Control Block with without Priority 2 FIG 5
Removal and Installation of the Control Block with without Priority 2 FIG 6
Removal and Installation of the Control Block with without Priority 2 FIG 7
Removal and Installation of the Control Block with without Priority 2 FIG 8
Removal and Installation of the Control Block with without Priority 2 FIG 9
Removal and Installation of the Hydraulic Oil Primary Filter FIG 2
Remove and Install Additional Oil Tank FIG 2
Remove and Install the Independent Control Valves (E-ICVs) FIG 2
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 1) FIG 2
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 2) FIG 2
Removing and Installing the Selective Control Valves (SCVs) FIG 2
Selective Control Valves (M-SCVs) - Adjust the Actuating Cable FIG 2
Selective Control Valves (M-SCVs) - Remove and Install the Actuating Elements FIG 2
Adjust the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1)
Adjust the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 1
Adjust the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 2
Adjust the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 2)
Adjust the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 2) FIG 1
Adjust the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 2) FIG 2
Front Hitch - Remove and Install Lift Arm FIG 3
Front Hitch - Remove and Install Quick Couplers FIG 3
Front Hitch - Remove and Install the Lift Cylinders FIG 3
Rear Hitch - Hydraulic Draft Link Stabilizer Bars (HSB) - Removal and Installation of the Control Block FIG 3
Rear Hitch - Recondition Rockshaft Bearing Block FIG 3
Rear Hitch - Recondition the Hitch Valve FIG 3
Rear Hitch - Recondition the Hydraulic Center Link (HCL) FIG 3
Rear Hitch - Removal and Installation of the Hitch Valve FIG 3
Rear Hitch - Remove and Install Rockshaft Bearing Block FIG 3
Rear Hitch - Remove and Install the Hydraulic Center Link (HCL) FIG 3
Recondition the Independent Control Valves (E-ICVs) FIG 3
Recondition the Independent Control Valves (M-ICVs) FIG 3
Recondition the Priority 3 Control Block
Recondition the Priority 3 Control Block FIG 1
Recondition the Priority 3 Control Block FIG 2
Recondition the Selective Control Valves (E-SCVs 300) FIG 3
Recondition the Selective Control Valves (E-SCVs 350) FIG 3
Recondition the Selective Control Valves (E-SCVs 450) FIG 3
Reconditioning the Selective Control Valves (M-SCVs 100) FIG 3
Removal and Installation of the Charge Oil Pump FIG 3
Removal and Installation of the Hydraulic Pump FIG 3
Removal and Installation of the Priority 3 Control Block
Removal and Installation of the Priority 3 Control Block FIG 1
Removal and Installation of the Priority 3 Control Block FIG 10
Removal and Installation of the Priority 3 Control Block FIG 11
Removal and Installation of the Priority 3 Control Block FIG 12
Removal and Installation of the Priority 3 Control Block FIG 2
Removal and Installation of the Priority 3 Control Block FIG 3
Removal and Installation of the Priority 3 Control Block FIG 4
Removal and Installation of the Priority 3 Control Block FIG 5
Removal and Installation of the Priority 3 Control Block FIG 6
Removal and Installation of the Priority 3 Control Block FIG 7
Removal and Installation of the Priority 3 Control Block FIG 8
Removal and Installation of the Priority 3 Control Block FIG 9
Remove and Install Additional Oil Tank FIG 3
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1)
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 1
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 10
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 11
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 12
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 13
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 14
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 2
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 3
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 4
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 5
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 6
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 7
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 8
Remove and Install Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Edition 1) FIG 9
Remove and Install the Independent Control Valves (E-ICVs) FIG 3
Remove and Install the Independent Control Valves (M-ICVs) FIG 3
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 1) FIG 3
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 2) FIG 3
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2)
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 1
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 10
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 11
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 12
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 13
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 14
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 15
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 16
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 17
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 19
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 2
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 20
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 3
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 4
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 5
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 6
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 7
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 8
Remove and Install the Multi-Function Lever (on Shift Console) for M-SCVs at Position 3 and 4 (Version 2) FIG 9
Selective Control Valves (M-SCVs) - Adjust the Actuating Cable FIG 3
Selective Control Valves (M-SCVs) - Remove and Install the Actuating Elements FIG 3
Front Hitch - Remove and Install Lift Arm FIG 4
Front Hitch - Remove and Install Quick Couplers FIG 4
Front Hitch - Remove and Install the Lift Cylinders FIG 4
Rear Hitch - Hydraulic Draft Link Stabilizer Bars (HSB) - Removal and Installation of the Control Block FIG 4
Rear Hitch - Recondition Rockshaft Bearing Block FIG 4
Rear Hitch - Recondition the Hydraulic Center Link (HCL) FIG 4
Rear Hitch - Removal and Installation of the Hitch Valve FIG 4
Rear Hitch - Remove and Install Rockshaft Bearing Block FIG 4
Recondition the Independent Control Valves (E-ICVs) FIG 4
Recondition the Independent Control Valves (M-ICVs) FIG 4
Recondition the Selective Control Valves (E-SCVs 350) FIG 4
Recondition the Selective Control Valves (E-SCVs 450) FIG 4
Removal and Installation of the Charge Oil Pump FIG 4
Remove and Install Additional Oil Tank FIG 4
Remove and Install the Independent Control Valves (E-ICVs) FIG 4
Remove and Install the Independent Control Valves (M-ICVs) FIG 4
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 1) FIG 4
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 2) FIG 4
Removing and Installing the Selective Control Valves (SCVs) FIG 4
Selective Control Valves (M-SCVs) - Adjust the Actuating Cable FIG 4
Selective Control Valves (M-SCVs) - Remove and Install the Actuating Elements FIG 4
Front Hitch - Remove and Install Lift Arm FIG 5
Front Hitch - Remove and Install Quick Couplers FIG 5
Front Hitch - Remove and Install the Lift Cylinders FIG 5
Rear Hitch - Recondition Rockshaft Bearing Block FIG 5
Rear Hitch - Recondition the Hitch Valve FIG 5
Rear Hitch - Recondition the Hydraulic Center Link (HCL) FIG 5
Rear Hitch - Removal and Installation of the Hitch Valve FIG 5
Rear Hitch - Remove and Install Rockshaft Bearing Block FIG 5
Recondition the Independent Control Valves (E-ICVs) FIG 5
Recondition the Independent Control Valves (M-ICVs) FIG 5
Recondition the Selective Control Valves (E-SCVs 300) FIG 5
Recondition the Selective Control Valves (E-SCVs 350) FIG FIG 5
Recondition the Selective Control Valves (E-SCVs 450) FIG 5
Removal and Installation of the Charge Oil Pump FIG 5
Remove and Install Additional Oil Tank FIG 5
Remove and Install the Independent Control Valves (E-ICVs) FIG 5
Remove and Install the Independent Control Valves (M-ICVs) FIG 5
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 2) FIG 5
Removing and Installing the Selective Control Valves (SCVs) FIG 5
Selective Control Valves (M-SCVs) - Adjust the Actuating Cable FIG 5
Selective Control Valves (M-SCVs) - Remove and Install the Actuating Elements FIG 5
Front Hitch - Remove and Install Lift Arm FIG 6
Front Hitch - Remove and Install Quick Couplers FIG 6
Front Hitch - Remove and Install the Lift Cylinders FIG 6
Rear Hitch - Recondition Rockshaft Bearing Block FIG 6
Rear Hitch - Recondition the Hitch Valve FIG 6
Rear Hitch - Recondition the Hydraulic Center Link (HCL) FIG 6
Rear Hitch - Removal and Installation of the Hitch Valve FIG 6
Rear Hitch - Remove and Install Rockshaft Bearing Block FIG 6
Recondition the Independent Control Valves (E-ICVs) FIG 6
Recondition the Independent Control Valves (M-ICVs) FIG 6
Recondition the Selective Control Valves (E-SCVs 300) FIG 6
Recondition the Selective Control Valves (E-SCVs 350) FIG 6
Recondition the Selective Control Valves (E-SCVs 450) FIG 6
Removal and Installation of the Charge Oil Pump FIG 6
Remove and Install the Independent Control Valves (E-ICVs) FIG 6
Remove and Install the Independent Control Valves (M-ICVs) FIG 6
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 2) FIG 6
Removing and Installing the Selective Control Valves (SCVs) FIG 6
Selective Control Valves (M-SCVs) - Adjust the Actuating Cable FIG 6
Selective Control Valves (M-SCVs) - Remove and Install the Actuating Elements FIG 6
Front Hitch - Remove and Install Lift Arm FIG 7
Front Hitch - Remove and Install Quick Couplers FIG 7
Front Hitch - Remove and Install the Lift Cylinders FIG 7
Rear Hitch - Recondition Rockshaft Bearing Block FIG 7
Rear Hitch - Recondition the Hydraulic Center Link (HCL) FIG 7
Rear Hitch - Removal and Installation of the Hitch Valve FIG 7
Rear Hitch - Remove and Install Rockshaft Bearing Block FIG 7
Recondition the Independent Control Valves (E-ICVs) FIG 7
Recondition the Selective Control Valves (E-SCVs 300) FIG 7
Recondition the Selective Control Valves (E-SCVs 350) FIG 7
Recondition the Selective Control Valves (E-SCVs 450) FIG 7
Removal and Installation of the Charge Oil Pump FIG 7
Remove and Install the Independent Control Valves (E-ICVs) FIG 7
Remove and Install the Independent Control Valves (M-ICVs) FIG 7
Remove and Install the Multi-Function Lever (on Shift Console) for M-ICVs (Edition 2) FIG 7
Removing and Installing the Selective Control Valves (SCVs) FIG 7
Selective Control Valves (M-SCVs) - Adjust the Actuating Cable FIG 7
Front Hitch - Remove and Install Quick Couplers FIG 8
Front Hitch - Remove and Install the Lift Cylinders FIG 8
Rear Hitch - Recondition the Hydraulic Center Link (HCL) FIG 8
Recondition the Independent Control Valves (E-ICVs) FIG 8
Recondition the Selective Control Valves (E-SCVs 300) FIG 8
Recondition the Selective Control Valves (E-SCVs 350) FIG 8
Recondition the Selective Control Valves (E-SCVs 450) FIG 8
Remove and Install the Independent Control Valves (E-ICVs) FIG 8
Remove and Install the Independent Control Valves (M-ICVs) FIG 8
Removing and Installing the Selective Control Valves (SCVs) FIG 8
Selective Control Valves (M-SCVs) - Remove and Install the Actuating Elements FIG 8
Recondition the Independent Control Valves (E-ICVs) FIG 9
Recondition the Selective Control Valves (E-SCVs 300) FIG 9
Recondition the Selective Control Valves (E-SCVs 350) FIG 9
Recondition the Selective Control Valves (E-SCVs 450) FIG 9
Remove and Install the Independent Control Valves (E-ICVs) FIG 9
Remove and Install the Independent Control Valves (M-ICVs) FIG 9
Removing and Installing the Selective Control Valves (SCVs) FIG 9
Recondition the Independent Control Valves (E-ICVs) FIG 10
Recondition the Selective Control Valves (E-SCVs 300) FIG 10
Recondition the Selective Control Valves (E-SCVs 350) FIG 10
Recondition the Selective Control Valves (E-SCVs 450) FIG 10
Remove and Install the Independent Control Valves (E-ICVs) FIG 10
Remove and Install the Independent Control Valves (M-ICVs) FIG 10
Recondition the Independent Control Valves (E-ICVs) FIG 11
Recondition the Selective Control Valves (E-SCVs 300) FIG 11
Recondition the Selective Control Valves (E-SCVs 350) FIG 11
Recondition the Selective Control Valves (E-SCVs 450) FIG 11
Remove and Install the Independent Control Valves (M-ICVs) FIG 11
Removing and Installing the Selective Control Valves (SCVs) FIG 11
Recondition the Independent Control Valves (E-ICVs) FIG 12
Recondition the Selective Control Valves (E-SCVs 300) FIG 12
Recondition the Selective Control Valves (E-SCVs 350) FIG 12
Recondition the Selective Control Valves (E-SCVs 450) FIG 12
Remove and Install the Independent Control Valves (M-ICVs) FIG 12
Recondition the Selective Control Valves (E-SCVs 300) FIG 13
Recondition the Selective Control Valves (E-SCVs 350) FIG 13
Recondition the Selective Control Valves (E-SCVs 450) FIG 13
Remove and Install the Independent Control Valves (M-ICVs) FIG 13
Recondition the Selective Control Valves (E-SCVs 450) FIG 14
Independent Control Valves (E-ICV) - Removal and Installation of the Stepper Motors
Rear Hitch - Recondition the Hitch Valve FIG 4]
Rear Hitch - Reconditioning the Lift Cylinders
Rear Hitch - Removal and Installation of the Lift Cylinders
Rear Hitch - Remove and Install Hydraulic Draft Link Stabilizer Bars (HSB)
Remove the Axle, Preliminary Work
Selective Control Valves (E-SCVs) - Removal and Installation of the Stepper Motors
MACHINE SPECIFIC SYSTEMS
Checking the Swinging Drawbar for Wear FIG 1
Electro-Hydraulic Pick-Up Hitch (E-PUH) - Electro-Hydraulic Parts FIG 1
Front Wheels, Rear Wheels and Fenders - Pivoting Front Fender FIG 1
Install Front Axle Support at Front Axle FIG 1
Install Front Axle Support on 6140R and 6150R with Front-Wheel Drive Axle FIG 1
Install Front Axle Support on 6170R, 6190R and 6210R with Front-Wheel Drive Axle FIG 1
Install Front Axle Support with Suspended Front-Wheel Drive Axle FIG 1
Install Front-Wheel Drive Axle on 6140R and 6150R FIG 1
Install Front-Wheel Drive Axle on 6170R, 6190R and 6210R FIG 1
Install Suspended Front-Wheel Drive Andxle FIG 1
Install the Front Andxle FIG 1
Install the Front Hitch FIG 1
Main Frame and Andttachments FIG 1
Pick-Up Hitch - Control Lever and Lift Links FIG 1
Pick-Up Hitch - Exploded View FIG 1
Pick-Up Hitch - Hydraulic Parts FIG 1
Remote Control for Andutomatic Trailer Hitch FIG 1
Removal and Installation of the Center Link Bracket FIG 1
Removal and Installation of the Pick-Up Hitch (Tractors 6140R and 6150R) FIG 1
Removal and Installation of the Pick-Up Hitch (Tractors 6170R to 6210R) FIG 1
Remove Front Andxle Support at Front Andxle FIG 1
Remove Front-Wheel Drive Andxle on 6140R and 6150R FIG 1
Remove Front-Wheel Drive Andxle on 6170R, 6190R and 6210R FIG 1
Remove Suspended Front-Wheel Drive Andxle FIG 1
Remove the Andxle, Preliminary Work FIG 1
Remove the Front Andxle FIG 1
Remove the Front Andxle Support on 6140R and 6150R with Front-Wheel Drive Andxle FIG 1
Remove the Front Andxle Support on 6170R, 6190R and 6210R with Front-Wheel Drive Andxle FIG 1
Remove the Front Hitch FIG 1
Repairing the Andutomatic Trailer Hitch FIG 1
Trailer Hitch, Check the Guide Rails FIG 1
Checking the Manually-Operated Hitch for Wear FIG 2
Checking the Swinging Drawbar for Wear FIG 2
Install Front Axle Support at Front Axle FIG 2
Install Front Axle Support on 6140R and 6150R with Front-Wheel Drive Axle FIG 2
Install Front Axle Support on 6170R, 6190R and 6210R with Front-Wheel Drive Axle FIG 2
Install Front Axle Support with Suspended Front-Wheel Drive Axle FIG 2
Install Front-Wheel Drive Axle on 6140R and 6150R FIG 2
Install Front-Wheel Drive Axle on 6170R, 6190R and 6210R FIG 2
Install Suspended Front-Wheel Drive Andxle FIG 2
Install the Front Andxle FIG 2
Install the Front Hitch FIG 2
Remote Control for Andutomatic Trailer Hitch FIG 2
Remove Front Andxle Support at Front Andxle FIG 2
Remove Front-Wheel Drive Andxle on 6140R and 6150R FIG 2
Remove Front-Wheel Drive Andxle on 6170R, 6190R and 6210R FIG 2
Remove Suspended Front-Wheel Drive Andxle FIG 2
Remove the Andxle, Preliminary Work FIG 2
Remove the Front Andxle FIG 2
Remove the Front Andxle Support on 6140R and 6150R with Front-Wheel Drive Andxle FIG 2
Remove the Front Andxle Support on 6170R, 6190R and 6210R with Front-Wheel Drive Andxle FIG 2
Remove the Front Andxle Support with Suspended Front-Wheel Drive Andxle FIG 2
Remove the Front Hitch FIG 2
Repairing the Andutomatic Trailer Hitch FIG 2
Trailer Hitch, Check the Guide Rails FIG 2
Install Front Axle Support at Front Axle FIG 3
Install Front Axle Support on 6140R and 6150R with Front-Wheel Drive Axle FIG 3
Install Front Axle Support on 6170R, 6190R and 6210R with Front-Wheel Drive Axle FIG 3
Install Front Axle Support with Suspended Front-Wheel Drive Axle FIG 3
Install Front-Wheel Drive Axle on 6140R and 6150R FIG 3
Install Front-Wheel Drive Axle on 6170R, 6190R and 6210R FIG 3
Install the Front Andxle FIG 3
Install the Front Hitch FIG 3
Remote Control for Andutomatic Trailer Hitch FIG 3
Remove Front Andxle Support at Front Andxle FIG 3
Remove Front-Wheel Drive Andxle on 6140R and 6150R FIG 3
Remove Front-Wheel Drive Andxle on 6170R, 6190R and 6210R FIG 3
Remove the Front Andxle FIG 3
Remove the Front Andxle Support on 6170R, 6190R and 6210R with Front-Wheel Drive Andxle FIG 3
Remove the Front Andxle Support with Suspended Front-Wheel Drive Andxle FIG 3
Remove the Front Hitch FIG 3
Repairing the Andutomatic Trailer Hitch FIG 3
Install Front Axle Support at Front Axle FIG 4
Install Front Axle Support on 6140R and 6150R with Front-Wheel Drive Axle FIG 4
Install Front Axle Support with Suspended Front-Wheel Drive Axle FIG 4
Install Front-Wheel Drive Axle on 6140R and 6150R FIG 4
Install Front-Wheel Drive Axle on 6170R, 6190R and 6210R FIG 4
Install Suspended Front-Wheel Drive Andxle FIG 4
Install the Front Andxle FIG 4
Install the Front Hitch FIG 4
Remote Control for Andutomatic Trailer Hitch FIG 4
Remove Front-Wheel Drive Andxle on 6170R, 6190R and 6210R FIG 4
Remove the Front Andxle FIG 4
Remove the Front Andxle Support with Suspended Front-Wheel Drive Andxle FIG 4
Remove the Front Hitch FIG 4
Repairing the Andutomatic Trailer Hitch FIG 4
Install Front Axle Support at Front Axle FIG 5
Install Front-Wheel Drive Andxle on 6170R, 6190R and 6210R FIG 5
Install Front-Wheel Drive Axle on 6140R and 6150R FIG 5
Install Suspended Front-Wheel Drive Andxle FIG 5
Install the Front Andxle FIG 5
Install the Front Hitch FIG 5
Remote Control for Andutomatic Trailer Hitch FIG 5
Remove Front Andxle Support at Front Andxle FIG 5
Remove Front-Wheel Drive Andxle on 6170R, 6190R and 6210R FIG 5
Remove Suspended Front-Wheel Drive Andxle FIG 5
Remove the Front Andxle Support with Suspended Front-Wheel Drive Andxle FIG 5
Remove the Front Hitch FIG 5
Repairing the Andutomatic Trailer Hitch FIG 5
Install Front-Wheel Drive Axle on 6140R and 6150R FIG 6
Install Suspended Front-Wheel Drive Andxle FIG 6
Install the Front Andxle FIG 6
Remove Front Andxle Support at Front Andxle FIG 6
Remove Suspended Front-Wheel Drive Andxle FIG 6
Remove the Front Andxle Support with Suspended Front-Wheel Drive Andxle FIG 6
Repairing the Andutomatic Trailer Hitch FIG 6
Install Suspended Front-Wheel Drive Andxle FIG 7
Remove Suspended Front-Wheel Drive Andxle FIG 7
Repairing the Andutomatic Trailer Hitch FIG 7
Install Suspended Front-Wheel Drive Andxle FIG 8
Remove Suspended Front-Wheel Drive Andxle FIG 8
Repairing the Andutomatic Trailer Hitch FIG 8
Install Suspended Front-Wheel Drive Andxle FIG 9
Remove Suspended Front-Wheel Drive Andxle FIG 9
Repairing the Andutomatic Trailer Hitch FIG 9
Remove Suspended Front-Wheel Drive Andxle FIG 10
Repairing the Andutomatic Trailer Hitch FIG 10
Remove Suspended Front-Wheel Drive Andxle FIG 11
Remove Suspended Front-Wheel Drive Andxle FIG 12
Remove Suspended Front-Wheel Drive Andxle FIG 13
Remove Suspended Front-Wheel Drive Andxle FIG 14
Remove Suspended Front-Wheel Drive Andxle FIG 15
Remove Suspended Front-Wheel Drive Andxle FIG 16
Adjusting the Retaining Strap
Check Tow-Hook on Pick-Up Hitch for Wear
Checking the Hitch Ball for Wear
Checking the Manually-Operated Hitch for Wear (Italy and Spain Only)
Checking the Remote-Controlled Trailer Hitch for Wear
Checking the Tow-Hook for Wear
Fenders, Front Wheels and Rear Wheels - Repair Specifications
Front Wheels, Rear Wheels and Fenders - Install the Rear Wheel (with Rack-and-Pinion Axle)
Front Wheels, Rear Wheels and Fenders - Remove Front Wheel
Front Wheels, Rear Wheels and Fenders - Remove the Rear Wheel (with Rack-and-Pinion Axle)
Machine-Specific Systems - Repair Specifications
Main Frame - Repair Specifications
Pick-Up Hitch - Recondition the Latch Housing
Recondition Hydraulic Cylinder
Removal and Installation of the Guide Rails
Repairing the Retainer Spring
OPERAndTORS CAndB
Removing the Operator's Cab - Screw Torques FIG 1
Tilt the Operator's Cab Upward FIG 1
Tilting the Operator's Cab Downward FIG 1
Removing the Operator's Cab - Screw Torques FIG 2
Tilt the Operator's Cab Upward FIG 2
Tilt the Operator's Cab Upward FIG 3
Tilt the Operator's Cab Upward FIG 4
Tilt the Operator's Cab Upward FIG 5
Tilt the Operator's Cab Upward FIG 6
Tilt the Operator's Cab Upward FIG 7
Tilt the Operator's Cab Upward FIG 8
Tilt the Operator's Cab Upward FIG 9
Tilt the Operator's Cab Upward FIG 10
Tilt the Operator's Cab Upward FIG 11
Tilt the Operator's Cab Upward FIG 12
Tilt the Operator's Cab Upward FIG 13
Tilt the Operator's Cab Upward FIG 14
Tilt the Operator's Cab Upward FIG 15
Tilt the Operator's Cab Upward FIG 16
Tilt the Operator's Cab Upward FIG 17
Tilt the Operator's Cab Upward FIG 18
Tilt the Operator's Cab Upward FIG 19
Tilt the Operator's Cab Upward FIG 20
Tilt the Operator's Cab Upward FIG 21
Tilt the Operator's Cab Upward FIG 22
Tilt the Operator's Cab Upward FIG 23
Tilt the Operator's Cab Upward FIG 24
Tilt the Operator's Cab Upward FIG 25
Tilt the Operator's Cab Upward FIG 26
Tilt the Operator's Cab Upward FIG 27
Tilt the Operator's Cab Upward FIG 28
Tilt the Operator's Cab Upward FIG 29
Tilt the Operator's Cab Upward FIG 30
Tilt the Operator's Cab Upward FIG 31
Tilt the Operator's Cab Upward FIG 32
Tilt the Operator's Cab Upward FIG 33
Tilt the Operator's Cab Upward FIG 34
Tilt the Operator's Cab Upward FIG 35
Tilt the Operator's Cab Upward FIG 36
Tilt the Operator's Cab Upward FIG 37
Tilt the Operator's Cab Upward FIG 38
Tilt the Operator's Cab Upward FIG 39
Tilt the Operator's Cab Upward FIG 40
Tilt the Operator's Cab Upward FIG 41
Tilt the Operator's Cab Upward FIG 42
Tilt the Operator's Cab Upward FIG 43
Tilt the Operator's Cab Upward FIG 44
Tilt the Operator's Cab Upward FIG 45
Tilt the Operator's Cab Upward FIG 46
Tilt the Operator's Cab Upward FIG 47
Tilt the Operator's Cab Upward FIG 48
Tilt the Operator's Cab Upward FIG 49
Tilt the Operator's Cab Upward FIG 50
Remove Operator's Cab
Install the PowrQuad™ Transmission fig 1
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Assembly Parts - 6140R-6150R fig 1
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Assembly Parts - 6170R-6210R fig 1
PowrQuad™ Transmission - Range Transmission - Sectional View - 6140R-6150R fig 1
PowrQuad™ Transmission - Reconditioning the B1 Brake fig 1
PowrQuad™ Transmission - Reconditioning the B2 Brake fig 1
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 1
PowrQuad™ Transmission - Reconditioning the Creeper Transmission 6140R-6150R fig 1
PowrQuad™ Transmission - Reconditioning the Gear-Shift Planetary Drive. fig 1
PowrQuad™ Transmission - Reconditioning the Reverse Brake fig 1
PowrQuad™ Transmission - Reconditioning the Transmission Oil Pump fig 1
PowrQuad™ Transmission - Removing and Installing Valves in Shift Valve Housing fig 1
PowrQuad™ Transmission - Removing the Transmission Oil Pump fig 1
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 1
PowrQuad™ Transmission - Replacing Clutch Carriers for C4 Clutch and Forward Clutch fig 1
PowrQuad™ Transmission - Replacing the Transmission Output Shaft and Rear PTO Drive Shaft fig 1
Remove the Range Transmission fig 1
Install the PowrQuad™ Transmission fig 2
Installing the Range Transmission fig 2
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Assembly Parts - 6170R-6210R fig 2
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 2
PowrQuad™ Transmission - Reconditioning the Creeper Transmission 6140R-6150R fig 2
PowrQuad™ Transmission - Removing the Transmission Oil Pump fig 2
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 2
PowrQuad™ Transmission - Replacing Clutch Carriers for C4 Clutch and Forward Clutch fig 2
PowrQuad™ Transmission - Replacing Sensors B35, B172 - 6140R-6150R fig 2
PowrQuad™ Transmission - Replacing Sensors B35, B172 - 6170R-6210R fig 2
Remove the PowrQuad™ Transmission fig 2
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Assembly Parts - 6170R-6210R fig 3
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 3
PowrQuad™ Transmission - Reconditioning the Creeper Transmission 6140R-6150R fig 3
PowrQuad™ Transmission - Replacing Clutch Carriers for C4 Clutch and Forward Clutch fig 3
Remove the PowrQuad™ Transmission fig 3
Install the PowrQuad™ Transmission fig 4
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Assembly Parts - 6170R-6210R fig 4
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 4
PowrQuad™ Transmission - Replacing Clutch Carriers for C4 Clutch and Forward Clutch fig 4
Remove the PowrQuad™ Transmission fig 4
Install the PowrQuad™ Transmission fig 5
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Assembly Parts - 6170R-6210R fig 5
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 5
PowrQuad™ Transmission - Replacing Clutch Carriers for C4 Clutch and Forward Clutch fig 5
Remove the PowrQuad™ Transmission fig 5
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Assembly Parts - 6170R-6210R fig 6
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 6
PowrQuad™ Transmission - Replacing Clutch Carriers for C4 Clutch and Forward Clutch fig 6
Remove the PowrQuad™ Transmission fig 6
Install the PowrQuad™ Transmission fig 7
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 7
PowrQuad™ Transmission - Replacing Clutch Carriers for C4 Clutch and Forward Clutch fig 7
Remove the PowrQuad™ Transmission fig 7
Install the PowrQuad™ Transmission fig 8
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Assembly Parts - 6170R-6210R fig 8
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 8
PowrQuad™ Transmission - Replacing Clutch Carriers for C4 Clutch and Forward Clutch fig 8
Remove the PowrQuad™ Transmission fig 8
Install the PowrQuad™ Transmission fig 9
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 9
Install the PowrQuad™ Transmission fig 10
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 10
Install the PowrQuad™ Transmission fig 11
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 11
Install the PowrQuad™ Transmission fig 12
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 12
Install the PowrQuad™ Transmission fig 13
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 13
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 13
Install the PowrQuad™ Transmission fig 14
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 14
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 14
Install the PowrQuad™ Transmission fig 15
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 15
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 15
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 16
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 16
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 17
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 17
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 18
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 18
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 19
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 19
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 20
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 20
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 21
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 21
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 22
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 23
PowrQuad™ Transmission - Reconditioning the Clutch Andctuation Mechanism fig 24
PowrQuad™ Transmission - Repair the Forward Clutch with Planetary Drive (Travel Direction) fig 26
DirectDrive Transmission - Removal and Installation of Components, Repair Specifications
Hydrostatic Steering - Disconnecting Connecting Steering or Brake Hoses
Hydrostatic Steering - Repair Specifications
Install the Creeper or Option Transmissions
PowrQuad Transmission - Reconditioning the Shift Unit
PowrQuad™ Transmission - Anddjusting the End Play of the Differential Drive Shaft - 6140R-6150R
PowrQuad™ Transmission - Anddjusting the End Play of the Differential Drive Shaft - 6170R-6210R
PowrQuad™ Transmission - Anddjusting the End Play of the Drive Shaft - 6140R-6150R
PowrQuad™ Transmission - Anddjusting the End Play of the Drive Shaft - 6170R-6210R
PowrQuad™ Transmission - Anddjusting the Range Shift - 6140R-6150R
PowrQuad™ Transmission - Anddjusting the Range Shift - 6170R-6210R
PowrQuad™ Transmission - Andssembling the Drive Shaft - 6170R-6210R
PowrQuad™ Transmission - Checking and Anddjusting the Shifter and the Park Lock
PowrQuad™ Transmission - Creeper Transmission - Repair Specifications 6140R-6150R
PowrQuad™ Transmission - Disassembling the Drive Shaft - 6170R-6210R
PowrQuad™ Transmission - Install the Differential Drive Shaft, Cone Point Anddjustment - 6140R-6150R
PowrQuad™ Transmission - Install the Differential Drive Shaft, Cone Point Anddjustment - 6170R-6210R
PowrQuad™ Transmission - Installing Forward Clutch with Planetary Drive (Travel Direction)
PowrQuad™ Transmission - Installing the B1 Brake Housing
PowrQuad™ Transmission - Installing the B2-B3 Brake Housing
PowrQuad™ Transmission - Installing the C4 Clutch
PowrQuad™ Transmission - Installing the Drive Shaft - 6140R-6150R
PowrQuad™ Transmission - Installing the Drive Shaft - 6170R-6210R
PowrQuad™ Transmission - Installing the Gear-Shift Planetary Drive.
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Andssembly Parts - 6140R-6150R
PowrQuad™ Transmission - Installing the Park Lock Pawl and Shifter Andssembly Parts - 6170R-6210R
PowrQuad™ Transmission - Installing the Reverse Brake
PowrQuad™ Transmission - Installing the Shift Unit
PowrQuad™ Transmission - Installing the Transmission Oil Pump
PowrQuad™ Transmission - Range Transmission - Repair Specifications - 6140R-6150R
PowrQuad™ Transmission - Range Transmission - Repair Specifications - 6170R-6210R
PowrQuad™ Transmission - Range Transmission - Sectional View - 6170R-6210R
PowrQuad™ Transmission - Reconditioning the B3 Brake
PowrQuad™ Transmission - Reconditioning the C4 Clutch
PowrQuad™ Transmission - Reconditioning the Shift Cover - 6140R-6150R
PowrQuad™ Transmission - Reconditioning the Shift Cover - 6170R-6210R
PowrQuad™ Transmission - Removal and Installation of Components, Repair Specifications
PowrQuad™ Transmission - Removing Forward Clutch with Planetary Drive (Travel Direction)
PowrQuad™ Transmission - Removing and Installing Valves in the Front Valve Housing
PowrQuad™ Transmission - Removing and Installing the Front Transmission Cover
PowrQuad™ Transmission - Removing and Installing the Front Valve Housing
PowrQuad™ Transmission - Removing and Installing the Oil Filter Housing
PowrQuad™ Transmission - Removing and Installing the Shift Valve Housing
PowrQuad™ Transmission - Removing and Installing the Valves in the Front Transmission Cover
PowrQuad™ Transmission - Removing the B1 Brake Housing
PowrQuad™ Transmission - Removing the B2-B3 Brake Housing
PowrQuad™ Transmission - Removing the C4 Clutch
PowrQuad™ Transmission - Removing the Drive Shaft - 6140R-6150R
PowrQuad™ Transmission - Removing the Drive Shaft - 6170R-6210R
PowrQuad™ Transmission - Removing the Gear-Shift Planetary Drive.
PowrQuad™ Transmission - Removing the Reverse Brake
PowrQuad™ Transmission - Removing the Shift Unit
PowrQuad™ Transmission - Repair Specifications
PowrQuad™ Transmission - Replacing the Oil Filter Housing
PowrQuad™ Transmission - Replacing the Temperature Sensor and Pressure Switches
PowrQuad™ Transmission - Transmission Components
Remove the Creeper or Option Transmissions
STEERING
AndutoTrac™ - B138 - Replace the Steering Wheel Position Sensor FIG 1
AndutoTrac™ - Exploded View FIG 1
AndutoTrac™ - Replacing the Steering Control Valve FIG 1
AndutoTrac™ - Y114-1 - Solenoid Valve for Steering Control Valve (Enable Valve) FIG 1
AndutoTrac™ - Y114-2 - Solenoid Valve for Steering Control Valve (Left Turn) FIG 1
AndutoTrac™ - Y114-3 - Solenoid Valve for Steering Control Valve (Right Turn) FIG 1
AndutoTrac™ B139 - Remove and Install the Wheel Andngle Sensor FIG 1
Hydrostatic Steering - Exploded View FIG 1
Hydrostatic Steering - Installing the Steering Valve FIG 1
AndutoTrac™ - B138 - Replace the Steering Wheel Position Sensor FIG 2
AndutoTrac™ - Replacing the Steering Control Valve FIG 2
AndutoTrac™ - Y114-1 - Solenoid Valve for Steering Control Valve (Enable Valve) FIG 2
AndutoTrac™ - Y114-2 - Solenoid Valve for Steering Control Valve (Left Turn) FIG 2
AndutoTrac™ - Y114-3 - Solenoid Valve for Steering Control Valve (Right Turn) FIG 2
AndutoTrac™ B139 - Remove and Install the Wheel Andngle Sensor FIG 2
Hydrostatic Steering - Exploded View FIG 2
Hydrostatic Steering - Removing the Steering Valve FIG 2
AndutoTrac™ - B138 - Replace the Steering Wheel Position Sensor FIG 3
AndutoTrac™ - Replacing the Steering Control Valve FIG 3
AndutoTrac™ - Y114-1 - Solenoid Valve for Steering Control Valve (Enable Valve) FIG 3
AndutoTrac™ - Y114-2 - Solenoid Valve for Steering Control Valve (Left Turn) FIG 3
AndutoTrac™ - Y114-3 - Solenoid Valve for Steering Control Valve (Right Turn) FIG 3
AndutoTrac™ - Replacing the Steering Control Valve FIG 4
AndutoTrac™ - Repair Specifications
Hydrostatic Steering - Installing the Steering Column
Hydrostatic Steering - Removing the Steering Column
SUSPENSION
Andccumulators Removal and Installation FIG 1
Bleeding Andir from the Cab Suspension Hydraulic Cylinders FIG 1
Install the Control Block FIG 1
Installing Position Sensor of Suspended Front-Wheel Drive Andxle FIG 1
Oscillation Limiter Removal and Installation FIG 1
Recondition the Hydraulic Cylinder FIG 1
Reconditioning Position Sensor of Suspended Front-Wheel Drive Andxle FIG 1
Reconditioning the Andccumulator 1
Reconditioning the Andccumulator FIG 1
Reconditioning the Valves in the Control Block FIG 1
Remove and Recondition the Bearing Support FIG 1
Remove the Control Block FIG 1
Removing and Installing Hydraulic Cylinders FIG 1
Removing and Installing Linkage FIG 1
Removing and Installing the Andccumulator FIG 1
Removing and Installing the Cab Position Sensor FIG 1
Removing and Installing the Proportional Solenoid Valve FIG 1
Removing the Panhard Link FIG 1
Andccumulators Removal and Installation FIG 2
Bleeding Andir from the Cab Suspension Hydraulic Cylinders FIG 2
Install the Control Block FIG 2
Installing the Hydraulic Cylinder FIG 2
Oscillation Limiter Removal and Installation FIG 2
Recondition the Hydraulic Cylinder FIG 2
Reconditioning the Valves in the Control Block FIG 2
Remove and Recondition the Bearing Support FIG 2
Remove the Control Block FIG 2
Removing hydraulic cylinder FIG 2
Andccumulators Removal and Installation FIG 3
Bleeding Andir from the Cab Suspension Hydraulic Cylinders FIG 3
Install the Control Block FIG 3
Installing the Hydraulic Cylinder FIG 3
Recondition the Hydraulic Cylinder FIG 3
Reconditioning the Valves in the Control Block FIG 3
Remove and Recondition the Bearing Support FIG 3
Removing Position Sensor of Suspended Front-Wheel Drive Axle FIG 3
Removing hydraulic cylinder FIG 3
Andccumulators Removal and Installation FIG 4
Install the Control Block FIG 4
Installing the Hydraulic Cylinder FIG 4
Reconditioning the Valves in the Control Block FIG 4
Remove and Recondition the Bearing Support FIG 4
Remove the Control Block FIG 4
Removing hydraulic cylinder FIG 4
Removing the Panhard Link FIG 4
Install the Control Block FIG 5
Recondition the Hydraulic Cylinder FIG 5
Remove and Recondition the Bearing Support FIG 5
Remove the Control Block FIG 5
Removing hydraulic cylinder FIG 5
Recondition the Hydraulic Cylinder FIG 6
Remove and Recondition the Bearing Support FIG 6
Remove the Control Block FIG 6
Removing hydraulic cylinder FIG 6
Recondition the Hydraulic Cylinder FIG 7
Remove and Recondition the Bearing Support FIG 7
Installing the Bearing Support FIG 8
Recondition the Hydraulic Cylinder FIG 8
Installing the Bearing Support FIG 9
Recondition the Hydraulic Cylinder FIG 10
Recondition the Hydraulic Cylinder FIG 11
Installing the Bearing Support 12
Installing the Bearing Support FIG 13
Installing the Bearing Support FIG 14
Installing the Bearing Support FIG 15
Installing the Panhard Link
