John Deere 6120 6120L 6220 6220L 6320 6320L 6420 6420L 6520L Tractors Operators Manual OMAL162071
Format: HTML
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 6120 6120L 6220 6220L 6320 6320L 6420 6420L 6520L Tractors
Parts Number: OMAL162071
Foreword
Section : 00 - Identification Views
Section : 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Stay Clear of Moving Tractor
Prevent Machine Runaway
Use Seat Belt Properly (If Equipped)
Operating the Tractor Safely
Shift to Low Gear on Hills
Use Caution on Hillsides
Parking and Leaving the Tractor
Keep Riders Off Machine
Instructional Seat
Handle Fuel Safely-Avoid Fires
Prepare for Emergencies
Wear Protective Clothing
Avoid Contact with Pesticides
Stay Clear of Rotating Drivelines
Use Safety Lights and Devices
Use a Safety Chain
Safely Transporting the Tractor
Transport Towed Equipment at Safe Speeds
Freeing a Mired Machine
Keep ROPS Installed Properly
Practice Safe Maintenance
Avoid High-Pressure Fluids
Service Cooling System Safely
Store Attachments Safely
Dispose of Waste Properly
Special Features on Tractors with JD IVT
JD IVT- Operating on Hillsides in Slippy Conditions
Section : 10 - Safety Decals
Use Seat Belt
Operate Tractor Safely
Do Not Modify ROPS
Tow Loads Safely
Use of Instructional Seat
Avoid Explosive Gases
Stay Clear of PTO
Suspension System
Section : 15 - Controls and Instruments
Vehicle Controls
Differences of Vehicle Controls on Tractors Without Cab
PTO and Creeper Controls
Attachment Controls
Heater and Air-Conditioning Controls (Tractors without ClimaTrak System)
Heater and Air-Conditioning Controls (Tractors with ClimaTrak System)
Operating the Digital Display
Indicator Lights and Displays on Tractors without Cab
Indicator Lights and Displays on Tractors with Cab
Operation of Additional Components
Performance Monitor
Data Entry Mode
Operating Touch Pad Switches
Operation and Calibration
Wheel Slip (3)
Vehicle Speed (6)
Service (8)
Backlight Brightness-Cab Displays
Adjusting Backlight-Performance Monitor
Section : 20 - Lights
Light Switches (Tractors with Cab)
Work Light Switches (Tractors with Cab)
Xenon Worklights
Beacon Light (Option)
Light Switches (Tractors Without Cab)
Work Light Switches (Tractors without Cab)
Lights
Operating the Hazard Warning Light Switch
Switch for Turn Signal Lights and Horn (Tractors with Cab)
Switch for Turn Signal Lights (Tractors without Cab)
Switch for Horn (Tractors without Cab)
Seven-Terminal Outlet
Section : 25 - Operator's Platform and Cab
Roll-Over Protective Structure
Operating Foldable ROPS
Seat Belt
Clean Vehicle of Hazardous Pesticides
Comfort Seat
Super Comfort Seat
Air Comfort Seat
Operating the Instructional Seat
Opening Windows
Windshield Wiper and Washer System
Fan and Air Louvers (Tractors without ClimaTrak System)
Heater (Tractors without ClimaTrak System)
Air-Conditioning System (Tractors without ClimaTrak System)
Tips On Using the Air-Conditioning System
Using the ClimaTrak System (ATC)
Changing the ClimaTrak Display (ATC)
Cooling A Drink Can
Field Office (Option)
Dome and Console Lights
Adjusting Steering Wheel
Back-up Alarm (Option)
Step Adjustment
Multiple Power-Outlet Socket Strip (Option)
Cigarette Lighter and Ashtray
Installing the Monitor
Power Outlet Sockets (Option)
Service ADVISOR™ - Socket
Roof Hatch
Section : 30 - Break-In Period
After First 4 and 8 Hours of Operation
Within the First 100 Hours of Operation
After First 100 Hours of Operation
Section : 35 - Prestarting Checks
Prestarting Check
Section : 40 - Operating the Engine
Positions of Main Switch
Starting the Engine
Cold Weather Starting Aids
Using Auxiliary Heaters
Engine Warm-Up Period
Engines with Turbocharger
Engine Protection
Towing the Tractor
Parking the Tractor (Tractors without IVT)
Parking the Tractor (Tractors with IVT)
Stopping the Engine
Section : 45 - Operating the Tractor
Reduce Fuel Consumption
Select Correct Ground Travel Speed
Travel Speeds, SyncroPlus Transmission (12/4)
Travel Speeds, SyncroPlus Transmission with Power Reverser (16/16)
Shifting SyncroPlus Transmission/Power Reverser
Shift Lever Positions
Travel Speeds, PowrQuad Transmission/PowrQuad Plus Transmission (16/16)
Travel Speeds, PowrQuad Plus and AutoQuad Plus Transmissions (24/24)
Shifting the PowrQuad Transmission
Shift Lever Positions, PowrQuad Transmission
Shifting the PowrQuad Plus Transmission
Shift Lever Positions, PowrQuad Plus Transmission
Shifting the AutoQuad Plus Transmission
Shift Lever Positions, AutoQuad Plus Transmission
JD IVT -Starting in Cold Weather
JD IVT Operation
JD IVT Transmission Enabling Mode
Towing a Tractor equipped with JD IVT
Engaging Creeper Transmission
Engaging Front Wheel Drive
Tractors With TLS MFWD Axle
Engaging Differential Lock
Hydraulic Foot Brakes
Section : 50 - Rockshaft and Three-Point Hitch
Rockshaft Control
Headland Management System HMS II (If Equipped) - Basic Principles
Headland Management System (HMS) II - Details
Rockshaft Remote Control
Height Adjustment
Transporting Mounted Implements
Hitch Dampening
Adjusting Rate of Implement Drop
Depth Adjustment
Load/Depth Adjustment
1 Depth Control
2-4 Mixed Control
5 Load Control
Float Position
Direct Actuation
Telescopic Draft Links
Coupler Hook › Draft Links
Attaching Three-Point Hitch and Drawn Implements
Leveling the Implement
Center Link Adjustment
Coupler Hook › Center Link
Lift Links
Adjusting for Vertical Float
Sway Blocks (If Equipped)
Stabilizing System (If Equipped)
Adjusting Spreading Dimension
Section : 55 - Power Take-Off
PTO Guard
Operating Instructions
PTO Options
PTO Speeds
Operating Power Take-Offs
Reversing Rear PTO Shafts
Attaching PTO-Driven Equipment
Section : 60 - Ballast
Selecting Ballast
Ballasting Rear Wheels
Measuring Rear Wheel Slip
Installing Weights on Flanged Axle
Installing Weights on Rack-and-Pinion Axle
Filling Tires With Liquid Ballast
Draining the Tires
Installing Front Weights
Using Implement Codes
Section : 65 - Wheel Treads, Tires
Adjustable Front Axle (Tractors Without Front Wheel Drive)
Adjusting Front Wheel Tread
Checking Front Wheel Toe-In
Adjusting Front Wheel Toe-In
Changing Wheels Safely
Front Wheel Tread Adjustment (Tractors With Front Wheel Drive)
Adjusting Front Wheel Tread With Reversible Rims
Adjusting Front Wheel Tread With Adjustable Rims
Tighten Front Wheel Attaching Nuts
Check Front Wheel Toe-In
Adjust Fenders
Rear Wheel Tread Adjustment With Flanged Axle
Positions of Rims and Wheel Disks
Tread Widths
Adjusting Wheel Tread With Rack-and-Pinion Axle
Positions of Rims and Wheel Disks With Rack-and-Pinion Axle
Tread Widths With Standard Rack-and-Pinion Axle
Tire Pressures
Service Tires Safely
Tire Combinations, Tractors With Front Wheel Drive
Section : 70 - Additional Equipment
Selective Control Valves
Adjusting the Kickout Relief Valve Detent - 300 Series SCV
Control Lever for Selective Control Valves
Multi-Function Lever (Mechanical)
Multi-Function Lever (Electrical)
Rate of Cylinder Operation
Couplers
Hose Unions
Maximum Permissible Oil Withdrawal
Oil Withdrawal With Hydraulic Motor
Using Pressure Free Return Circuit
Swinging Drawbar
Lengthwise Adjustment of Drawbar
High Clearance Drawbar
Use a Safety Chain
Vandal Protection
Adjust Exhaust
Section : 75 - Transport
Towing the Tractor
Manual Park Lock Release (Tractors with JD IVT)
Driving on Public Roads
Section : 80 - Fuel, Lubricants, Hydraulic Oil and Coolant
Diesel Fuel
Lubricity of Diesel Fuel
Bio-Diesel Fuel
Diesel Engine Break-In Oil
Diesel Engine Oil
Oil Filters
Diesel Engine Coolant
Operating in Warm Temperature Climates
Drain Intervals for Diesel Engine Coolant
Transmission and Hydraulic Oil
Front-Wheel Drive Axle Oil
Grease
Mixing of Lubricants
Lubricant Storage
Section : 85 - Lubrication and Periodic Service
Using High Pressure Washers
Opening the Hood
Access to Battery
Access to Fuses
Important Instructions Regarding Alternator
Daily or Every 10 Hours
After the First 100 Hours
Every 250 Hours
Every 500 Hours
Every 750 Hours
Once Every Year
Every 1500 Hours Or Every Two Years
Every 2000 Hours
Every 3000 Hours Or Every Three Years
As Required
Section : 90 - Service / Daily Or Every 10 Hours
Checking Engine Crankcase Oil Level
Checking the Fuel Filter
Checking On Lights
Other Service Jobs
Section : 95 - Service / Every 250 Hours
Servicing Fuel Tank
Checking Transmission/Hydraulic System Oil Level
Handling Batteries Safely
Prevent Battery Explosions
Checking Electrolyte Level of Batteries
Lubricating Front Axle and Front Wheels
Lubricating Front Axle and Drive Shaft
Checking Oil Level in MFWD Axle Housing
Checking Oil Level in MFWD Final Drives
Checking Brake Operation
Lubricating Three-Point Hitch
Neutral Start Circuit
Checking Transmission PARK Position
Wheel Retaining Bolts/Nuts
Section : 100 - Service / Every 500 Hours
Changing Engine Oil
Changing Engine Oil Filter Element
Changing the Fuel Filter
Lubricating Rear Axle Bearings
Air Intake Hoses
Checking Engine Ground Connection
Section : 105 - Service / Every 750 Hours
Checking Engine Speeds
Replacing Transmission/Hydraulic System Filter Elements
Replace Front PTO Filter (If Equipped)
Section : 110 - Service / Once Every Year
Checking Seat Belt
Section : 115 - Service / Every 1500 Hours or 2 Years
Changing Oil in Front-Wheel Drive Axle and Final Drives
Changing Oil in MFWD Axle Housing
Changing Oil in MFWD Final Drives
Changing Transmission/Hydraulic Oil (Tractors NOT Equipped with IVT)
Changing Transmission/Hydraulic Oil (Tractors with IVT)
Changing the Oil at the Front PTO (If Equipped)
Section : 120 - Service / Every 3000 Hours or 3 Years
Changing Coolant
Section : 125 - Service / As Required
Air Cleaner
Cleaning Primary Filter Element
Cleaning Dusty Element
Secondary (Safety) Element
Installation
Cleaning the Cab Air Filters
Keep Radiator Screen Clean (If Equipped)
Bleeding the Fuel System (Tractors Equipped with DE10 Injection Pump)
Bleeding the Fuel System (Tractors Equipped with HPCR System)
Lubricate All Lubricating Points
Operator's Seat
Batteries-Checking Specific Gravity
Starting Motor
Replacing the Main Fuses
Replacing Fuse of Electrical Starting Aid (Tractors equipped with DE10 Injection Pump)
Replacing Fuses of Electrical Starting Aid (Tractors equipped with IVT Transmission)
Replacing the LTC coolant pump fuse (Tractors equipped with IVT transmission)
Fuse and Relay Box on Tractors with Open Operator's Station
Fuse and Relay Boxes on Tractors with Operator's Cab (w/o IVT Transmission)
Fuse and Relay Boxes on Tractors with Operator's Cab (with IVT Transmission)
Replacing the Drive Belt
Section : 130 - Diagnostic Trouble Codes
What the Diagnostic Trouble Codes Mean
Customization
General Operating Instructions and Entering Program Mode
Calling up Addresses and Diagnostic Trouble Codes
Diagnostic Trouble Codes on ClimaTrak Controller (ATC)
Diagnostic Trouble Codes on Basic Control Unit / Hitch Control Unit (BCU)
Diagnostic Trouble Codes on Basic Informator (BIF)
Diagnostic Trouble Codes on Engine Control Unit (ECU)
Diagnostic Trouble Codes on Electronic PowrQuad Controller (EPC)
Diagnostic Trouble Codes on JDLink Controller (JDL)
Diagnostic Trouble Codes on Park Lock Controller (PLC)
Diagnostic Trouble Codes on Performance Monitor (PrF)
Diagnostic Trouble Codes on Control Unit for Suspended Front Axle with TLS (SFA)
Diagnostic Trouble Codes on E-ICV Controller (SIC)
Diagnostic Trouble Codes on Transmission Control Unit (TCU)
Diagnostic Trouble Codes on User Interface Controller (UIC)
Section : 135 - Troubleshooting
Section : 140 - Storage
Storage for Long Period
Removing Tractor from Storage
Section : 145 - Specifications
Weights and Loads
Towable Loads
Capacities
Load Capacity of Tires (Front)
Load Capacity of Tires (Rear)
Load Capacity of Tires With Front Loader
Limited Battery Warranty
Emission Control System Certification Label
U.S. Emission Control Warranty
Section : 150 - Serial Numbers
Type Plates
Product Identification Number
Engine Identification Number
Transmission Serial Number
Serial Number of Front Wheel Drive Axle
Section : 155 - Lubrication and Maintenance Records
250 Hour Service
500 Hour Service
750 Hour Service
1000 Hour Service
1500 Hour Service
3000 Hour Service
Section : 160 - Crime Prevention Tips
Help Prevent Crime
Record Ag Identification Numbers
Keep Proof of Ownership
Park Indoors Out of Sight
When Parking Outdoors
Reduce Vandalism
Report Thefts Immediately
Section : SLIT - John Deere Service Literature Available
Technical Information
Section : IBC - John Deere Service Keeps You On The Job
John Deere Is At Your Service
Format: HTML
Brand: John Deere
Foreword
Instructional Seat
Use a Safety Chain
Use Seat Belt
Do Not Modify ROPS
Tow Loads Safely
Stay Clear of PTO
Suspension System
Vehicle Controls
Attachment Controls
Performance Monitor
Data Entry Mode
Wheel Slip (3)
Vehicle Speed (6)
Service (8)
Xenon Worklights
Lights
Seat Belt
Comfort Seat
Super Comfort Seat
Air Comfort Seat
Opening Windows
Cooling A Drink Can
Step Adjustment
Roof Hatch
Prestarting Check
Starting the Engine
Engine Protection
Towing the Tractor
Stopping the Engine
JD IVT Operation
Rockshaft Control
Height Adjustment
Hitch Dampening
Depth Adjustment
1 Depth Control
2-4 Mixed Control
5 Load Control
Float Position
Direct Actuation
Lift Links
PTO Guard
PTO Options
PTO Speeds
Selecting Ballast
Draining the Tires
Adjust Fenders
Tread Widths
Tire Pressures
Couplers
Hose Unions
Swinging Drawbar
Use a Safety Chain
Vandal Protection
Adjust Exhaust
Towing the Tractor
Diesel Fuel
Bio-Diesel Fuel
Diesel Engine Oil
Oil Filters
Grease
Lubricant Storage
Opening the Hood
Access to Battery
Access to Fuses
Every 250 Hours
Every 500 Hours
Every 750 Hours
Once Every Year
Every 2000 Hours
As Required
Checking On Lights
Other Service Jobs
Servicing Fuel Tank
Changing Engine Oil
Air Intake Hoses
Checking Seat Belt
Changing Coolant
Air Cleaner
Installation
Operator's Seat
Starting Motor
Customization
Weights and Loads
Towable Loads
Capacities
Type Plates
250 Hour Service
500 Hour Service
750 Hour Service
1000 Hour Service
1500 Hour Service
3000 Hour Service
Help Prevent Crime
Reduce Vandalism
- JOHN DEERE CODE DTC LIST
