John Deere 6100 6200 6300 6400 Tractors Operators Manual OMAL76458
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 6100 6200 6300 6400 Tractors
Part Number: OMAL76458
Number of Pages: 200 Pages
Identification Views
Safety
Safety Decals
Controls and Instruments
Vehicle controls
PTO and creeper control
Attachment controls
Heater and air conditioning controls
Operating the digital display
Indicator lights
Digital display
Lights
Operator’s Platform and Cab
Roll-over protective structure
Seat belt
Operator’s seat
Windshield wipers
Blower
Heater
Air conditioning system
Steering wheel adjustment
Door retainer
Roof hatch
Break-In Period
After the first 4 and 8 hours of operation
Within the first 100 hours of operation
After the first 100 hours of operation
Prestarting Checks
Operating the Engine
Starting the engine
Electrical starting aid
Page
Coolant heater
Booster battery
Fuel preheater
Towing the tractor
Parking the tractor
Stopping the engine
Operating the Tractor
Reduce fuel consumption
Correct ground travel speed
Travel speeds, SyncroPlus transmission
Shifting SyncroPlus transmission
Travel speeds, PowrQuad transmission
Shifting PowrQuad transmission
Engaging creeper transmission
Front wheel drive
Differential lock
Foot brakes
Rockshaft and Three-Point Hitch
Operating the rockshaft
Three-point hitch
Draft links
Attaching implements
Center link
Lift links
Sway blocks
Power Take-Off
PTO guard
Operating the PTOs
Attaching PTO-driven equipment
Ballast
Ballast
Measuring rear wheel slip
Rear wheel weights
Filling tires with liquid ballast
Front weights
Wheel Tread, Tires
Front wheel tread adjustment
Rear wheel tread adjustment
Tires
Tire combinations with front wheel drive
Additional Equipment
Selective control valves
Couplers
Maximum permissible oil withdrawal
Remote hydraulic cylinder
Swinging drawbar
Trailer hitches
Transport
Fuel, Lubricants, Hydraulic Oil and Coolant
Fuel
Engine oil
Transmission/hydraulic oil
FWD axle oil
Grease
Engine coolant
Lubrication and Periodic Service
Opening hood
Removing grille screens
Access to battery
Service intervals
Service / Daily or Every 10 Hours
Engine crankcase oil level
Checking lights
Other service jobs
Service / Every 250 Hours
Changing engine oil
Changing engine crankcase filter element
Checking transmission oil level
Battery service
Lubricating front axle
Checking oil level in FWD axle
Three-point hitch
Trailer hitch
Checking neutral start switch
Service / Every 500 Hours
Changing fuel filter
Page
Lubricating rear axle
Tightening air intake hose clamps
Service / Every 750 Hours
Checking engine speed
Changing transmission oil filters
Service / Every 1500 Hours or 2 Years
Changing coolant
Changing oil in FWD axle
Service / As Required
Air cleaner
Secondary (safety) filter
Cab air filters
Service - air conditioning system
Adjusting handbrake
Bleeding foot brakes
Fuel filter
Bleeding fuel system
Operator’s seat
Starting motor
Fuses
Troubleshooting
Hydraulic system
Electrical system
Storage
Storage for a lengthy period
Removing tractor from storage
Specifications
PTO power output
Axle loads and weights
Electrical system
Capacities
Sound level
Tire loading limits
Serial numbers
Lubrication and Maintenance Records
Index
Brand: John Deere
Safety
Safety Decals
Vehicle controls
Attachment controls
Indicator lights
Digital display
Lights
Seat belt
Operator’s seat
Windshield wipers
Blower
Heater
Door retainer
Roof hatch
Break-In Period
Prestarting Checks
Starting the engine
Page
Coolant heater
Booster battery
Fuel preheater
Towing the tractor
Parking the tractor
Stopping the engine
Front wheel drive
Differential lock
Foot brakes
Three-point hitch
Draft links
Center link
Lift links
Sway blocks
Power Take-Off
PTO guard
Operating the PTOs
Ballast
Ballast
Rear wheel weights
Front weights
Wheel Tread, Tires
Tires
Couplers
Swinging drawbar
Trailer hitches
Transport
Fuel
Engine oil
FWD axle oil
Grease
Engine coolant
Opening hood
Access to battery
Service intervals
Checking lights
Other service jobs
Changing engine oil
Battery service
Three-point hitch
Trailer hitch
Page
Changing coolant
Air cleaner
Cab air filters
Adjusting handbrake
Fuel filter
Operator’s seat
Starting motor
Fuses
Troubleshooting
Hydraulic system
Electrical system
Storage
Specifications
PTO power output
Electrical system
Capacities
Sound level
Tire loading limits
Serial numbers
Index
- JOHN DEERE CODE DTC LIST
