Martin Welker
104
230,310
John Deere 6100 6200 6300 6400 Tractors Operators Manual OMAL110985
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 6100 6200 6300 6400 Tractors
Serial Number: 140 000
Part Number: OMAL110985
Number of Pages: 236 Pages
Identification Views
Safety
Safety Decals
Controls and Instruments
Vehicle controls
PTO and creeper controls
Attachment controls
Heater and air conditioning controls
Operating the digital display
Indicator lights
Digital display
Performance monitor
Lights
Operator’s Platform and Cab
Roll-over protective structure
Seat belt
Operator’s seat
Windshield wiper
Blower
Heater
Air conditioning system
Adjusting the steering wheel
Door retainer
Monitor installation
Roof hatch
Break-In Period
After the first 4 and 8 hours of operation
Within the first 100 hours of operation
After the first 100 hours of operation
Prestarting Checks
Page
Operating the Engine
Starting the engine
Electrical starting aid
Coolant heater
Booster battery
Fuel preheater
Towing the tractor
Parking the tractor
Stopping the engine
Operating the Tractor
Reduce fuel consumption
Select ground travel speeds
Travel speeds, SyncroPlus transmission
Shifting SyncroPlus transmission
Travel speeds, PowrQuad transmission
Shifting PowrQuad transmission
Engaging creeper transmission
Front wheel drive
Differential lock
Foot brakes
Rockshaft and Three-Point Hitch
Operating the rockshaft
Three-point hitch
Draft links
Attaching implements
Center link
Lift links
Sway blocks
Power Take-Off
PTO guard
Operating PTO
Attaching PTO-driven equipment
Ballast
Ballast
Measuring rear wheel slip
Rear wheel weights
Filling tires with liquid ballast
Pre-assembling the pick-up weight
Pick-up weight to three-point hitch
Pick-up weight to basic weight
Pick-up weight to front three-point hitch
Front weights
Wheel Tread and Tires
Front wheel tread adjustment
Rear wheel tread adjustment
Tires
Tire combinations with front wheel drive
Additional Equipment
Selective control valves
Couplers
Maximum permissible oil withdrawal
Additional oil reservoir
Power Beyond application valve
Remote hydraulic cylinder
Swinging drawbar
Trailer hitches
Transport
Fuel, Lubricants, Hydraulic Oil and Coolant
Fuel
Engine oil
Transmission and hydraulic oil
Front wheel drive axle oil
Grease
Coolant
Lubrication and Periodic Service
Opening the hood
Remove grille screens
Access to battery
Service intervals
Service / Daily or Every 10 Hours
Check engine crankcase oil level
Checking lights
Other service jobs
Service / Every 250 Hours
Changing engine oil
Page
Change engine crankcase filter element
Checking transmission oil level
Battery service
Lubricating the front axle
Checking oil level in FWD axle
Three-point hitch
Trailer hitch
Checking neutral start circuit
Service / Every 500 Hours
Changing fuel filter
Lubricating rear axle
Air intake hoses
Service / Every 750 Hours
Checking engine speed
Changing transmission oil filter
Service / Every 1500 Hours or 2 Years
Replacing coolant
Changing oil in FWD axle
Service / As Required
Air cleaner
Secondary (safety) filter
Cab air filters
Service - air conditioning system
Adjusting the handbrake
Bleeding the brakes
Fuel filter
Bleeding the fuel system
Operator’s seat
Starting motor
Fuses
Troubleshooting
Hydraulic system
Electrical system
Storage
Storage for a lengthy period
Removing tractor from storage
Specifications
PTO power output
Axle loads and weights
Electrical system
Capacities
Sound level
Tire loading limits
Serial Numbers
Lubrication and Maintenance Records
Index
