John Deere 6020 to 6920S and SE Tractor Repair Technical Manual TM4750
Brand: John Deere
Model: John Deere 6020, 6120, 6220, 6320, 6420, 6420S, 6520, 6620
6020SE, 6120SE, 6220SE, 6320SE, 6420SE 6520SE Tractor
Part Number: TM4750
Publication Date: 2002
Number of Pages: 1948 Pages
SAFETY
Safety Measures
Recognize Safety Information
"Important" - Information
"Note" - Information
Prevent Machine Runaway
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Avoid High-Pressure Fluids
Service Cooling System Safely
Work In Ventilated Area
Wear Protective Clothing
Practice Safe Maintenance
Park Machine Safely
Use Proper Lifting Equipment
Support Machine Properly
Work in Clean Area
Illuminate Work Area Safely
Service Machines Safely
Use Proper Tools
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Safety Information - Air Brake System
Avoid Eye Contact With Radar
Keep ROPS Installed Properly
Replace Safety Signs
Dispose of Waste Properly
Live With Safety
Safety Measures on Electronic Control Units
GENERAL INFORMATION
Specifications
References, Specifications
Injection pump (Lucas)
Injection pump (Bosch VP44)
Air Intake System
Hydrostatic Steering System
Clutch
AutoPowr/IVT transmission
PowrQuad and PowrQuad Plus Transmissions
AutoQuad Transmission
Power Reverser
SyncroPlus Transmission
Creeper transmission
Rear PTO
Front PTO
Differential assembly
Differential lock
Final drives
Front-Wheel Drive
FWD axle with TLS
Hydraulic Brakes
Handbrake
Parking Lock
Hydraulic System with Axial Piston Pump
Hydraulic System with Gear-Driven Pump
Rockshaft
Front Hitch
Ground Speeds
Front and Rear Wheels
Dimensions and Weights
Capacities
Diesel Fuel
Lubricity of Diesel Fuel
Diesel Engine Break-In Oil
Diesel Engine Oil
Transmission and Hydraulic Oil
Front Wheel Drive Axle Oil
Diesel Engine Coolant
Supplemental Coolant Additives
Grease
Oil Filters
Mixing of Lubricants
Lubricant Storage
Operating in Warm Temperature Climates
Unified Inch Bolt and Cap Screw Torque Values
Metric Bolt and Cap Screw Torque Values
Hydraulic system inch fitting torques
Hydraulic system metric fitting torques
Product Identification and Sub-Assembly Serial Numbers
Engine serial number
Transmission serial number
Front wheel drive axle serial number
Operator's cab serial number
Sub-assembly serial numbers
Tune-Up
General References, Tune-Up
Specifications
Using High-Pressure Washers
Preliminary engine test
Tractor Tune-Up
Removing and Cleaning the Primary Air Cleaner Element
Checking the Air Cleaner Safety Element
Installing the Primary Filter Element
Checking the Air Intake System Connections for Leaks
Checking the Crankcase Vent Hose for Clogging
Cleaning the Radiator Grille Screen
Keeping the Radiator Screen Clean
Checking the Caps on the Expansion Tank
Checking the Radiator for Leaks
Checking the Engine Thermostat
Check Operation of Fuel Transfer Pump
Checking the Fuel Filter
Bleeding the Fuel System (Tractors NOT Equipped with Bosch VP44 Injection Pump)
Bleeding the Fuel System (Tractors Equipped with Bosch VP44 Injection Pump)
Checking the fuel filter (with Bosch VP44 injection pump)
Checking the Fuel Filter (With Denso/Stanadyne Injection Pump; Stage II Engines according to 97/68/EC)
Clean the water trap
Run the Engine until it is Warm, and Check Engine Speeds
Check Setting of Fuel Injection Pump
Check setting of speed control linkage
Cleaning the Battery, Cables and Battery Box with a Clean Cloth
Checking the Neutral Start Circuit
Check operation of starting motor
Checking the lighting circuit
Final Engine Check
Tractor Operation Check
Predelivery Inspection
ENGINE
Engine Removal and Installation
Special or Essential Tools
Specifications
Removing the Engine
Installing the Engine
FUEL, AIR INTAKE, COOLING AND EXHAUST SYSTEMS
Speed Control Linkage
Speed Control Linkage (Summary of References)
Specifications
Adjusting the Hand Throttle Lever and Accelerator Pedal
Adjusting the Speed Control Linkage
Hand Throttle Lever—Exploded View
Accelerator Pedal On Tractors With Low Platform
Accelerator Pedal, with Mechanical Speed Control
Accelerator Pedal, With Electronic Speed Control ("Cruise Control")
Adjusting the Accelerator Pedal (6420S and 6920S)
Changing the Accelerator Pedal's Potentiometer
Replacing the Accelerator Pedal Assembly (AutoPowr/IVT)
Removing the Accelerator Pedal's Potentiometer
Removing the Hand Throttle's Potentiometer
Fuel System
Fuel System (Summary of References)
Special Tool (Dealer-Fabricated)
Removing the Fuel Tank
Installing the Fuel Tank
Replacing the Fuel Gauge Sending Unit
Changing the Fuel Transfer Pump
Changing the Fuel Filter
Bleeding Air from the Fuel System (with Bosch VP44 Injection Pump and Denso/Stanadyne)
Installing Check Valve in Fuel System
Air Intake System
Air filter - Exploded view
Replacing the Sending Unit for Air Cleaner Restriction (B02)
Cooling System (Summary of References)
Specifications
Removing the Radiator
Changing the Fan or the Viscous Fan Drive
Removing and Installing the Expansion Tank
Removing and Installing the Thermostat Valve
Installing the Radiator
Filling the Cooling System with Coolant
Relieving Tension on the Drive Belt
Replacing the Drive Belt
Replacing the Drive Belt Tensioner
Repairing the Fan Console
Cold-Weather Starting Aids
Fuel Preheater
Electrical Starting Aid
Coolant Heater
Exhaust System
Exhaust System (Summary of References)
Specifications
Exhaust to Top Right
Exhaust to Bottom Right
ELECTRICAL SYSTEM
Connectors
Special Tools
General
Using high-pressure washers
Disconnecting electrical circuits
Stripping Wire Ends
Installing a terminal
WEATHER PACK Connectors
METRI PACK connector with terminal lock at the rear
METRI PACK connector with terminal lock at the front
Connector at CAN bus terminating resistor
Connectors for Electronic Control Units
Connectors
CRIMP SNAP IN connectors
KOSTAL connectors
DEUTSCH Connectors
Changing terminals
Connector for Bosch VP44 Injection Pump
Fuse and relay boxes on tractors with operator's cab
Fuse and Relay Box on Tractors with Open Operator's Station and SE-Tractors
Wiring Harnesses
Wiring Harnesses for 6120, 6220, 6320, 6420 and 6520 Tractors with PowrQuad Plus Transmission and Stage I Engine to 97/68/EC — Summary of References
Wiring Harnesses for 6320, 6420 and 6520 Tractors with AutoQuad Transmission and Stage I Engine to 97/68/EC — Summary of References
Wiring Harnesses for 6420S and 6620 Tractors with PowrQuad Plus or AutoQuad Transmissions and Stage I Engine to 97/68/EC — Summary of References
Wiring Harnesses for Tractors with PowrQuad Plus or AutoQuad Transmissions and Stage II Engine to 97/68/EC — Summary of References
Wiring Harnesses for Tractors with AutoPowr/IVT Transmission and Stage I Engine to 97/68/EC — Summary of References
Wiring Harnesses for Tractors with AutoPowr/IVT Transmission and Stage II Engine to 97/68/EC — Summary of References
Wiring Harnesses for Tractors with Open Operator's Station and Stage I Engine to 97/68/EC — Summary of References
Wiring Harnesses for Tractors with Open Operator's Station and Stage II Engine to 97/68/EC — Summary of References
Wiring Harnesses for SE-Tractors with Stage I Engine to 97/68/EC — Summary of References
Wiring Harnesses for SE-Tractors with Stage II Engine to 97/68/EC — Summary of References
Ground Point Locations
Removing and Installing Harness W01 — Power Supply
Removing and Installing Harness W01 — Power Supply (Open Operator's Station)
Removing and Installing Harness W01 — Power Supply (SE-Tractors)
Removing and Installing Harness W02 — Engine Wiring Harness for Stage I Engine to 97/68/EC (without Engine Control or with Level 1 ECU)
Removing and Installing Harness W02 — Engine Wiring Harness for Stage I Engine to 97/68/EC (ECU Level 4)
Removing and Installing Harness W02 — Engine Wiring Harness for Stage II Engine to 97/68/EC (ECU Level 11)
Removing and Installing Harness W02 — Engine Wiring Harness for Stage I Engine to 97/68/EC (Open Operator's Station)
Removing and Installing Harness W02 — Engine Wiring Harness for Stage II Engine to 97/68/EC (ECU Level 12) (Open Operator's Station)
Removing and Installing Harness W02 — Engine Wiring Harness for Stage I Engine to 97/68/EC (SE-Tractors)
Removing and Installing Harness W02 — Engine Wiring Harness for Stage II Engine to 97/68/EC (ECU Level 12) (SE-Tractors)
Removing and Installing Harness W03 — Wiring Harness - Starting Aid for Stage I and II Engines to 97/68/EC (without Engine Control or with Level 1 or 12 ECUs)
Removing and Installing Harness W03 - Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs)
Removing and Installing Harness W03 - Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs) (AutoPowr/IVT Transmission)
Removing and Installing Harness W04 — Headlights
Removing and Installing Harness W06 — Front-Wheel Drive Axle with TLS
Removing and Installing Harness W07 — Front PTO
Removing and Installing Harness W08 — Cab, with Stage I Engine to 97/68/EC
Removing and Installing Harness W08 — Cab, with Stage II Engine to 97/68/EC
Removing and Installing Harness W08 — Cab, with Stage I Engine to 97/68/EC (AutoPowr/IVT Transmission)
Removing and Installing Harness W08 — Cab, with Stage II Engine to 97/68/EC (AutoPowr/IVT Transmission)
Removing and Installing Harness W08 — Open Operator's Station, with Stage I Engine to 97/68/EC
Removing and Installing Harness W08 — Open Operator's Station, with Stage II Engine to 97/68/EC
Removing and Installing Harness W08 — Cab, with Stage I Engine to 97/68/EC (SE-Tractors)
Removing and Installing Harness W08 — Cab, with Stage II Engine to 97/68/EC (SE-Tractors)
Removing and Installing Harness W09 — Cowl, with Stage I Engine to 97/68/EC
Removing and Installing Harness W09 — Cowl, with Stage I Engine to 97/68/EC (AutoPowr/IVT Transmission)
Removing and Installing Harness W09 — Cowl, with Stage II Engine to 97/68/EC (AutoPowr/IVT Transmission)
Removing and Installing Harness W09 — Cowl, with Stage I Engine to 97/68/EC (Open Operator's Station)
Removing and Installing Harness W09 — Cowl, with Stage II Engine to 97/68/EC (Open Operator's Station)
Removing and Installing Harness W09 — Cowl, with Stage I Engine to 97/68/EC (SE-Tractors)
Removing and Installing Harness W08 — Cowl, with Stage II Engine to 97/68/EC (SE-Tractors)
Removing and Installing Harness W10 — Shift Console
Removing and Installing Harness W11 — Transmission Shift and Hand Throttle
Removing and Installing Harness W11 — Speed Control Lever and Hand Throttle (AutoPowr/IVT Transmission)
Removing and Installing Harness W12 — Command Arm (AutoPowr/IVT Transmission)
Removing and Installing Harness W13 — Clutch Sender
Removing and Installing Harness W14 — 3-Terminal Power Outlet Socket
Removing and Installing Harness W14 - 3-Terminal Power Outlet Socket (Open Operator's Station and SE Tractors)
Removing and Installing Harness W15 — ECU for Stage I Engines to 97/68/EC (without Engine Control)
Removing and Installing Harness W15 — ECU for Stage I Engines to 97/68/EC (ECU Level 1)
Removing and Installing Harness W15 — ECU for Stage I Engines to 97/68/EC (ECU Level 4)
Removing and Installing Harness W15 — ECU for Stage II Engines to 97/68/EC (ECU Level 11)
Removing and Installing Harness W16 — SIC with Stage I Engine to 97/68/EC
Removing and Installing Harness W17 — Multifunction Unit
Removing and Installing Harness W18 — Windshield Wiper Switch (Without Intermittent Wipe)
Removing and Installing Harness W18 — Windshield Wiper Switch (With Intermittent Wipe)
Removing and Installing Harness W19 — Cab Roof, with Stage I Engine to 97/68/EC
Removing and Installing Harness W19 — Cab Roof, with Stage II Engine to 97/68/EC
Removing and Installing Harness W19 — Cab Roof (SE-Tractors)
Removing and Installing Harness W20 — Turn Signal and Clearance Lights
Removing and Installing Harness W21 — Worklights on Front of Cab Roof
Removing and Installing Harness W22 — Worklights on Rear of Cab Roof
Removing and Installing Harness W22 — Xenon Worklights on Rear of Cab Roof
Removing and Installing Harness W23 — Windshield Wiper Switch (Without Switch for Windshield)
Removing and Installing Harness W23 — Windshield Wiper (With Switch for Windshield)
Removing and Installing Harness W24 — Rear Window Wiper
Removing and Installing Harness W25 — Rear Window Wiper Switch
Removing and Installing Harness W26 — Fan and Air Conditioner
Removing and Installing Harness W26 — Fan and Air Conditioner (SE-Tractors)
Removing and Installing Harness W28 — Front End of Transmission
Removing and Installing Harness W28 — Front End of Transmission (AutoPowr/IVT Transmission)
Removing and Installing Harness W28 — Front End of Transmission (Open Operator's Station)
Removing and Installing Harness W28 — Front End of Transmission (SE-Tractors)
Removing and Installing Harness W29 — Valve Block (AutoPowr/IVT Transmission)
Removing and Installing Harness W30 — Rear End of Transmission
Removing and Installing Harness W30 — Rear End of Transmission (Open Operator's Station)
Removing and Installing Harness W30 — Rear End of Transmission (SE-Tractors)
Removing and Installing Harness W31 — 7-Terminal Power Outlet Socket
Removing and Installing Harness W32 — Stepper Motors, with Stage I Engine to 97/68/EC
Removing and Installing Harness W32 — Stepper Motors, with Stage II Engine to 97/68/EC
Removing and Installing Harness W33 — Service
Removing and Installing Harness W34 — Electric Rear-View Mirrors
Removing and Installing Harness W35 — Access Step Lighting and Battery Cut-off Switch
Removing and Installing Harness W36 — 60-amp GreenStar Power Outlet Socket
Removing and Installing Harness W37 — GreenStar Port
Removing and Installing Harness W39 — GreenStar (Cab)
Removing and Installing Harness W39 — GreenStar with TEC (Tractor Equipment Interface Controller) (Cab)
Removing and Installing Harness W40 — GreenStar (Cab Roof)
Removing and Installing Harness W41 — JDLink
Removing and Installing Harness W42 — Battery Cut-off Switch
Charging Circuit
Special Tools
Specifications
Repairing the Alternator
Disconnecting Electrical Circuits
Relieve Drive Belt Tension
Remove/Install the Alternator
Pulley Removal and Installation
Starter Motor Circuit
Specifications
Repairing the Starting Motor
Removing and Installing the Starter Motor
Fuses, Relays and Switches
Note
Special Tools
Specifications
Fuses, Relays and Switches — Reconditioning (Summary of References)
Remove Trim Panels from Cowl
Fuse and Relay Boxes on Tractors with Operator's Cab
Fuse and Relay Boxes on Tractors with Operator's Cab and AutoPowr/IVT Transmission
Fuse and Relay Boxes on SE-Tractors
Replacing the Main Fuses
Replacing Fuses of Electric Starting Aid for Stage I and II Engines to 97/68/EC (without Engine Control or with Level 1 or 12 ECUs)
Replacing Fuse of Electric Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs)
Replacing Fuses of Electric Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs) (AutoPowr/IVT Transmission)
Replacing Fuse for Fuel Injection Pump (with Stage I Engines to 97/68/EC (Level 4 ECU)
Replacing Fuse for Fuel Injection Pump (with Stage I Engines to 97/68/EC (Level 4 ECU) (AutoPowr/IVT Transmission)
Replacing the LTC Coolant Pump Fuse (AutoPowr/IVT Transmission)
Replacing Fuses of 60-amp GreenStar Power Outlet Socket
Replacing Starting Motor Relay for Stage I and II Engines to 97/68/EC (without Engine Control or with Level 1 or 12 ECUs)
Replacing Starting Motor Relay for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs)
Replacing Starting Motor Relay for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs) (AutoPowr/IVT Transmission)
Replacing Relay of Electric Starting Aid for Stage I and II Engines to 97/68/EC (without Engine Control or with Level 1 or 12 ECUs)
Replacing Relay of Electric Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs)
Replacing Relay of Electric Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs) (AutoPowr/IVT Transmission)
Replacing Relay for Fuel Injection Pump (with Stage I Engines to 97/68/EC only (Level 4 ECU)
Replacing Relays of 60-amp GreenStar Power Outlet Socket
Replacing Battery Cut-off Relay
Replacing Battery Cut-off Switch Relay
Replacing Main Switch
Replacing the Brake Switches
Replacing the Light Switch
Replacing Full/Dipped-Beam Switch
Replacing the Worklight Switches
Replacing the Switch for Lights on Cab Frame
Replacing the Beacon Light Switch
Replacing the Hazard Warning Light Switch
Replacing the Turn Signal Switch
Replacing the Horn Switch
Replacing Switches on Multi-Function Unit
Replacing the Windshield Wiper and Washer Switch
Replacing the Rear Window Wiper and Washer Switch
Replacing the Windshield/Rear Window Switches
Replacing the Dome Light Door Switch
Replacing the Handbrake Switch
Replacing the front-wheel drive switch
Replacing the Headland Management (HMS) Switch
Replacing the Record/Save Switch
Replacing the Program Switch
Replacing the rear PTO preselector switch
Replacing the Switch for AutoQuad Transmission
Replacing the Gear Selector Switch on Tractors with PowrQuad Plus or AutoQuad Transmissions
Replacing the Park Lock Switch on Tractors with PowrQuad Plus or AutoQuad Transmissions
Replacing the Fan Switch
Replacing the Switch of the Air-Conditioning System Compressor
Replacing the Differential Lock Switch
Replacing the PTO Switches
Replacing the External Control Switch for the Rear PTO
Replacing the Rockshaft Remote Control Switch
Replacing the Switches for the Electrical Rear-View Mirrors
Replacing the Switch for the Heated Rear-View Mirrors
Replacing the Switch for the Heated Rear Window
Replacing Switch of Battery Cut-off Switch
Replacing the Cruise Control Potentiometer on Tractors with AutoQuad Transmission
Replacing the Cruise Control Potentiometer on Tractors with AutoPowr/IVT Transmission
Rockshaft control
Electrical Activators for Selective Control Valves (E-SCV)
Electrical Activators for Independent Control Valves (E-ICV)
Monitoring Systems
Note
Note
Note
Note
Monitoring Systems — Repair (Summary of References)
Replacing the Engine Speed Sending Unit (B01)
Replacing the engine oil pressure sending unit (B04)
Replacing the Sending Unit for the Coolant Temperature Gauge (B08)
Replacing the Acoustic Alarm
Replacing the Acoustic Alarm (Park Lock) on Tractors with AutoPowr/IVT Transmission
Electrical Components
Note
Special Tools
Specifications
Electrical Components — Reconditioning (Summary of References)
Replacing the 7-Terminal Power Outlet Socket
Replacing the 3-Terminal Power Outlet Socket
Replacing the Multiple Power-Outlet Socket Strip
Replacing the Service Socket
Removing the Wiper Motor
Adjusting the Headlights
Adjusting the Lights on the Cab Frame
Lights with Halogen Bulbs
Worklights with Xenon Bulbs
SYNCROPLUS TRANSMISSION
Removal and Installation of Transmission Components
Dealer-Manufactured Special Tools
Specifications
Removing the Clutch Housing
Installing the Clutch Housing
Removing the Gear Transmission
Installing the Gear Transmission
Transmission Shift Controls
Specifications
SyncroPlus Transmission Shift Units—Reconditioning (Summary of References)
Reconditioning the Gear Shift Mechanism
Reconditioning the Range Shift Mechanism
Checking and Adjusting the Shift Units
Adjusting the Clutch Pedal
Perma Clutch II Module
Specifications
SyncroPlus Transmission, Perma Clutch II Module—Reconditioning (Summary of References)
Removing the Clutch
Reconditioning the Clutch
Removing the Transmission Oil Pump
Reconditioning the Transmission Oil Pump
Installing the Transmission Oil Pump
Valves and Other Hydraulic Components
Reconditioning the Engagement Override Valve
Reconditioning the Clutch Cooling Valve
Reconditioning the Cooling Pilot Valve
Reconditioning the Filter Relief Valve
Reconditioning the Pressure-Regulating Valve
Reconditioning the Lube Relief Valve
Reconditioning the Cooler Relief Valve
Reconditioning the Clutch Pedal Valve
Replacing the Temperature and Pressure Sending Units
Gear Transmission
Specifications
SyncroPlus Transmission, Gear Transmission—Reconditioning (Summary of References)
Gear Transmission—Sectional View
Disassembling the Gear Transmission
Reconditioning the Gear Transmission
Preparation for Installing the Gear Transmission
Reconditioning the Shift Cover
Adjusting the Gear Transmission Shift Mechanism
Adjusting the Neutral Start Switch
POWER REVERSER TRANSMISSION
Removal and Installation of Power Reverser Module
Specifications
Removing the Power Reverser Module
Installing the Power Reverser Module
Removing and Installing the Gear Transmission
Specifications
Power Reverser Shift Units—Reconditioning (Summary of References)
Reconditioning the Forward/Reverse Control
Adjusting the Reverse Drive Lever
Adjusting the Reverse Drive Linkage
Specifications
Power Reverser, Power Reverser Module—Reconditioning (Summary of References)
Power Reverser Module—Sectional View
Components of Power Train
Removing the Disk Brake
Reconditioning the Disk Brake
Installing the Disk Brake
Removing the Clutch and Planetary Carrier
Reconditioning the Clutch and Planetary Carrier
Installing the Clutch and Planetary Carrier
Reconditioning the Sump Valve
Reconditioning the Accumulator Piston
Reconditioning the Forward/Reverse Valve
Reconditioning the Fwd/Rev Cooling Control Valve
Reconditioning the Modulator Valve
Reconditioning the Connecting Valve
Replacing the Oil Filter
Replacing the Neutral Start Switch
Gear Transmission
Specifications
Power Reverser, Gear Transmission—Reconditioning (Summary of References)
Adjusting the Shift Mechanism on the Gear Transmission
AUTOPOWR/IVT TRANSMISSION
Removing and Installing the AutoPowr/IVT Transmission
Specifications
Removing the AutoPowr/IVT Transmission
AutoPowr/IVT Transmission Shift Units—Reconditioning (Summary of References)
Reconditioning the Speed Control Lever
Reconditioning the Reverser Control
Reconditioning the Clutch Actuation Mechanism
Reconditioning the Manual Park Lock Release Mechanism
Releasing the Park Lock Manually
Input Housing
AutoPowr/IVT Transmission, Input Housing — Reconditioning (Summary of References)
Specifications
Replace Hydrostatic Unit Speed Sending Unit (B62) (Repair Level 1 and 2)
Replacing Pressure Sending Unit B87, S73, S74 (Repair Level 1 and 2)
Replacing Thermostat Valve (Repair Level 1 and 2)
Replacing Filter By-Pass Valve (Cold-Weather Starting) (Repair Level 1 and 2)
Replacing the Oil Filter (Repair Level 1 and 2)
Removing the System Pressure Control Block (Repair Level 1 and 2)
Installing System Pressure Control Block (Repair Level 1 and 2)
Removing the Transmission Oil Pump (Repair Level 1 and 2)
Reconditioning the Transmission Oil Pump (Repair Level 1 and 2)
Installing the Transmission Oil Pump (Repair Level 1 and 2)
Removing the Vibration Damper (Repair Level 1 and 2)
Reconditioning the Vibration Damper (Repair Level 1 and 2)
Installing the Vibration Damper (Repair Level 1 and 2)
Removing the Front Plate (Repair Level 1 and 2)
Installing the Front Plate (Repair Level 1 and 2)
Removing Clutch Control Block (Repair Level 1 and 2)
Reconditioning Clutch Control Block (Repair Level 1 and 2)
Installing the Clutch Control Block (Repair Level 1 and 2)
Separating the Input and Output Housings (Repair Level 2)
Joining the Input and Output Housings (Repair Level 2)
Removing BG Disk Brake (Repair Level 2)
Installing BG Disk Brake (Repair Level 2)
Removing Shift Turret (Repair Level 2)
Reconditioning the Shift Turret (Repair Level 2)
Installing the Shift Turret (Repair Level 2)
Removing the Hydrostatic Unit (Repair Level 2)
Installing the Hydrostatic Unit (Repair Level 2)
Reconditioning the Hydrostatic Unit Output Shaft (Repair Level 2)
Measuring the Gaps Between Transmission Shafts (Repair Level 2)
Replacing the Wiring Harness / Replacing the Fittings on the Housing (Repair Level 2)
Output Housing
AutoPowr/IVT Transmission, Output Housing — Reconditioning (Summary of References)
Specifications
Replacing Transmission Input Speed Sending Unit (B61) (Repair Level 1 and 2)
Replacing Transmission Output Speed Sending Unit (B63) (Repair Level 1 and 2)
Replacing the Bleed Valve (Repair Level 2)
Removing the Park Lock Control Block (Repair Level 1 and 2)
Reconditioning the Park Lock Control Block (Repair Level 1 and 2)
Reconditioning the Park Lock Cam (Repair Level 1 and 2)
Installing the Park Lock Control Block (Repair Level 1 and 2)
Removing the Pneumatic Pump (Repair Level 1 and 2)
Removing the Direction Turret and Reverse Intermediate Shaft (Repair Level 2)
Installing Direction Turret and Reverse Intermediate Shaft (Repair Level 2)
Removing the Drive Shaft for the Hydrostatic Unit (Repair Level 2)
Removing the Through-Drive Shaft (Repair Level 2)
Installing the Through-Drive Shaft (Repair Level 2)
Removing the Drive Gear for the Hydrostatic Unit (Repair Level 2)
Removing the Idler Gear with Pneumatic Pump Drive (Repair Level 2)
Installing the Idler Gear with Pneumatic Pump Drive (Repair Level 2)
Replacing the Screw Plugs (Repair Level 1 and 2)
Assembling the Differential Drive Shaft
AutoPowr/IVT Transmission, Differential Drive Shaft — Reconditioning (Summary of References)
Specifications
Differential Drive Shaft — Sectional View
Disassembling the Differential Drive Shaft (without Bearings)
Reconditioning the Cover with the Park Lock Pawl
Assembling the Differential Drive Shaft (without Bearings)
Replacing the Differential Drive Shaft / Reconditioning the Bearings
POWRQUAD, POWRQUAD PLUS AND AUTOQUAD TRANSMISSIONS
Removal and Installation of Components
Specifications
PowrQuad Plus Transmission, Removal and Installation
AutoQuad Transmission, Removal and Installation
Removing the PowrQuad Transmission
Installing the PowrQuad Transmission
Removing Creeper or Option Transmissions
Installing Creeper or Option Transmissions
Removing the Range Transmission
Installing the Range Transmission
Specifications
PowrQuad Transmission Shift Units—Reconditioning (Summary of References)
Reconditioning the Gear Shift Linkage (Reverser Control on Steering Column)
Reconditioning the Range Shift Linkage (Reverser Control on Steering Column)
Reconditioning the Reverser Control (on Steering Column)
Adjusting the Reverse Drive Lever (Reverser Control on Steering Column)
Checking and Adjusting the Shift Mechanisms/Linkages (Reverser Control on Steering Column)
Reconditioning the Range Shift Linkage (PowrQuad Plus and AutoQuad Transmissions)
Checking and Adjusting the Shift Mechanisms/Linkages (PowrQuad Plus & AutoQuad Transm.)
Adjusting the Clutch Pedal (PowrQuad Transmission)
Reconditioning the Clutch Actuation (PowrQuad Plus & AutoQuad Transm.)
PowrQuad Module
Specifications
PowrQuad, PowrQuad Plus and AutoQuad Transmissions—Summary of References
Replacing the Neutral Start Circuit (with Mech. Actuated PowrQuad Module)
Replacing the Temperature Sensor and Pressure Switches
Removing and Installing the Oil Filter Housing
Removing and Installing the Front Valve Housing
Removing and Installing the Valves in the Front Valve Housing
Removing and Installing the Valves in the Front Valve Housing (with Mech. Actuated PowrQuad Module)
Removing and Installing the Front Transmission Cover
Removing and Installing the Valves in the Front Transmission Cover
Removing and Installing the Valves in the Front Transmission Cover (with Mech. Actuated PowrQuad Module)
Replacing the Clutch Pedal Valve (with Mech. Actuated PowrQuad Module)
Removing and Installing the Shift Valve Housing
Removing and Installing the Valves in the Shift Valve Housing
Removing and Installing the Shift Valve Housing (with Mech. Actuated PowrQuad Module)
Removing and Installing the Valves in the Shift Valve Housing (with Mech. Actuated PowrQuad Module)
Removing the Planetary Drive (Gear-Shift)
Reconditioning the Planetary Drive (Gear-Shift)
Installing the Gear-Shift Planetary Drive
Removing the B1 Brake Housing
Reconditioning the B1 Brake
Installing the B1 Brake Housing
Removing the B2-B3 Brake Housing
Reconditioning the B2 Brake
Reconditioning the B3 Brake
Installing the B2-B3 Brake Housing
Removing the C4 Clutch
Reconditioning the C4 Clutch
Installing the C4 Clutch
Removing the Reverse Brake
Reconditioning the Reverse Brake
Installing the Reverse Brake
Removing the Forward Clutch with Planetary Drive (Forward/Reverse)
Reconditioning the Forward Clutch with Planetary Drive (Forward/Reverse)
Installing the Forward Clutch with Planetary Drive (Forward/Reverse)
Replacing the Output Shaft
Creeper Transmission
Specifications
Creeper Transmission—Reconditioning (Summary of References)
Removing the Creeper Transmission
Reconditioning the Creeper Transmission
Installing the Creeper Transmission
Option Transmission
Specifications
Option Transmission—Reconditioning (Summary of References)
Removing the Option Transmission
Reconditioning the Option Transmission
Installing the Option Transmission
Range Transmission
Specifications
Range Transmission—Reconditioning (Summary of References)
Range Transmission—Sectional View
Reconditioning the Range Transmission
Replacing the Speed Sending Unit
DRIVE SYSTEMS
Dealer-Fabricated Special Tools
Specifications
Removing the FWD Clutch
Installing the FWD Clutch
Removing the Differential Housing
Installing the Differential Housing
Removing the Final Drives
Installing the Final Drives
Removing the Rear PTO
Installing the Rear PTO
Removing the Front PTO
Installing the Front PTO
U-Jointed Shafts and Torsion Damper
Summary of References (U-Jointed Shafts and Torsion Damper)
Specifications
Removing the U.j. Shaft (FWD)
Reconditioning the U.j. Shaft (FWD)
Installing the U.j. Shaft (FWD)
Removing the U.j. Shaft (Engine)
Removing and Installing the Ring-Shaped Cooler
Removing the Torsion Damper
Changing the Torsion Damper Bearings
Installing the Torsion Damper
Installing the U.j. Shaft (Engine)
Front-Wheel Drive Clutch
Front-Wheel Drive Clutch — Reconditioning (Summary of References)
Other Material
Specifications
Replacing the FWD Axle Speed Sending Unit
Disassembling the Front Wheel Drive Clutch
Front-Wheel Drive Clutch — Exploded View
Assembling the Front-Wheel Drive Clutch
Differential — Reconditioning (Summary of References)
Specifications
Replacing the Sending Unit (B09 or B35 or B84)
Differential — Exploded View
Hydraulic Pump Drive
Specifications
Reconditioning the Hydraulic Pump Drive
Adjusting the Hydraulic Pump Drive
Final Drives
Specifications
Reconditioning the Final Drives
Rear PTO Options
Rear PTO Options — Summary of References
Other Material
Specifications
Replacing the Output Shaft Seal Ring
Changing the O-Ring on Reversible PTO
Removing the PTO Clutch
Reconditioning the PTO Clutch
Installing the PTO Clutch
Reconditioning the PTO Brake
Disassembling the PTO Drive Train
Reconditioning the Output Shaft (540/1000 rpm Reversible and Shiftable)
Assembling the Output Shaft (540/1000 rpm and 540/540E/1000 rpm Shiftable)
Reconditioning the Countershaft (540/1000 rpm and 540/540E/1000 rpm)
Assembling the PTO Shifter (540/1000 rpm Shiftable and 540/540E/1000 rpm)
Assembling PTO Drive Train
Adjusting Taper Roller Bearing at Output Shaft
Adjusting Taper Roller Bearing of Countershaft
Installing the Support and Adjusting the Taper Roller Bearings
Installing the PTO Housing
Removing the PTO Modulating Valve
Reconditioning the PTO Modulating Valve
Installing the PTO Modulating Valve
Repairing the Solenoid Valve
Replacing the PTO Speed Sending Unit
Changing and Adjusting the Bowden Cable
Front PTO
Front PTO — Reconditioning (Summary of References)
Other Material
Specifications
General Repair Procedures
Replacing the Solenoid Valve
Replacing the Front PTO Speed Sending Unit (B58)
Cleaning and Replacing the Filter
Checking the Cooler Relief and Filter By-Pass Valves
Removing and Installing the Valve Plate
Front PTO — Sectional View
Disassembling the Front PTO
Reconditioning the Oil Pump
Reconditioning the Intermediate Gear Shaft (PTO Rotating Counterclockwise)
Reconditioning the Drive Shaft
Assembling the Front PTO
Front Implement Drive
Front Implement Drive (Summary of References)
Specifications
Summary of Torques
Preliminary Work
Removing/Installing the Drive Shaft Adapter
Installing and Removing the Drive Shaft
STEERING AND BRAKES
Hydrostatic Steering (Summary of References)
Special Tools
Specifications
Preliminary Work
Disconnecting/Connecting Steering or Brake Hoses
Steering Valve - Removal (Tractors with Cab)
Steering Valve - Removal (Tractors without Cab)
Disassembling the Steering Valve
Exploded View of Steering Valve
Assembling the Steering Valve
Adjusting the Shock Valves
Steering Wheel and Steering Column (With Cab)
Steering Wheel and Column (Tractors without Cab)
Reconditioning the Steering Column
Steering Valve - Installation (Tractors with Cab)
Steering Valve - Installation (Tractors without Cab)
Steering Cylinder(s)
Specifications
Removing the Steering Cylinder
Disassembling the Steering Cylinder
Assembling the Steering Cylinder
Installing the Steering Cylinder
Brake Valve
Summary of References (Brake Valve)
Special Tools
Specifications
Brake Valve (Without Power Fill)
Brake Valve (With Power Fill)
Power-Fill Brake Valve with MFWD and Disk Brake
Rear Brakes
Summary of References (Rear Brakes)
Specifications
Removing the Rear Brakes
Installing the Rear Brake
Checking Brake Pistons for Return Movement and Leakage
Final assembly
Bleeding the Brakes (Brake Valve without Power-Fill)
Bleeding the Brakes (Power-Fill Brake Valve with MFWD and Disk Brake)
Handbrake
Specifications
Preliminary Work
Removing the Handbrake
Handbrake - Exploded View
Installing the Handbrake
Final Assembly
Handbrake Components
Replacing the Handbrake Cable
Handbrake Test
Adjusting the Handbrake
Hydraulic Trailer Brake
Special Tools
Specifications
Repair Instructions
Changing the Trailer Brake Valve
Cleaning the Trailer Brake Valve
Cleaning the Screen
Replacing the Check Valve
Bleeding the Trailer Brake Valve
Checking the Trailer Brake Valve
Adjusting the Trailer Brake Valve
Air Brakes
Summary of References (Air Brakes)
Specifications
Screw Union Installation
Changing the Compressor
Gaskets for the Compressor
Changing the Compressed Air Tank
Changing the Pressure Control Valve
Changing the Preload Valve
Changing the Trailer Control Valve
Exploded View of Trailer Control Valve
Changing the Coupling Ends
Changing the Pressure Gauge
Test sequence
Checking the System for Leaks
Checking the "Supply" Coupling End
Checking the Dual-Line Brakes
Checking the Single-Line Brakes
Adjusting the Handbrake (With Air Brake System)
HYDRAULIC SYSTEM
Controls
Hydraulic System — Controls (Summary of References)
Specifications
Selective Control Valves — Removing and Installing the Actuating Elements
Selective Control Valves — Adjusting the Bowden Cable
Removing and Installing the Multifunction Lever
Adjusting the Multifunction Lever
Hydraulic Pump and Charge Pump (PFC Hydraulic System)
Other Material
Specifications
Removing and Installing the Charge Pump
Reconditioning the Charge Pump
Charge Pump - Checking the Lube Oil Valve
Hydraulic Oil Reservoir — Restrictor
Hydraulic Pump — Removing and Installing the Pressure-and-Flow Controller
Hydraulic Pump — Reconditioning the Pressure-and-Flow Controller
Removing and Installing the Hydraulic Pump
Hydraulikpumpe (PC-Hydrauliksystem)
Other Material
Specifications
Removing the Hydraulic Pump
Hydraulic Pump - Removing the Installation Plate
Replacing the Lube Priority Valve
Hydraulic Pump - Installing the Installation Plate
Valves
Reconditioning the Valves (PFC Hydraulic System — Summary of References
Reconditioning the Valves (PC Hydraulic System — Summary of References
Special Tools (Dealer Fabricated)
Specifications
Hydraulic System — General Instructions on Safety and Repair
Direct Control of Rockshaft
Removing the Rockshaft Valve
Reconditioning the Rockshaft Valve
Rockshaft Valve — Depth to Which Raising and Lowering Valves are Screwed In
Rockshaft Valve — Removing and Installing the Stepper Motor
Rockshaft Valve — Centering the Stepper Motor
Installing the Rockshaft Valve
Removing Main Block (PFC Hydraulic System)
Reconditioning the Main Block (PFC Hydraulic System)
Installing the Main Block (PFC Hydraulic System)
Removing Main Block (PC Hydraulic System)
Reconditioning the Main Block (PC Hydraulic System)
Installing the Main Block (PC Hydraulic System)
Reconditioning the Hydraulic Oil Filter (PFC Hydraulic System)
Reconditioning the Hydraulic Oil Filter (PC Hydraulic System)
Power Beyond Valve—Exploded View
Connecting the Power Beyond Valve
Converting the Power Beyond Valve
Rockshaft
Self-Manufactured Special Tools
Other Material
Specifications
Rockshaft — Removing and Installing the Electronic Control Unit
Rockshaft — Removing and Installing the Position Sensor and Toothed Segment
Rockshaft — Removing and Installing the Rockshaft
Rockshaft — Removing the Rockshaft Cylinders
Rockshaft — Reconditioning the Rockshaft Cylinders
Rockshaft — Installing the Rockshaft Cylinders
Rockshaft — Removing and Installing the Draft Sensors and Draft Link Bearing Pins
Selective Control Valves and Couplers
Reconditioning the Selective Control Valves and Couplers — Summary of References
Special Tools
Other Material
Specifications
Reconditioning the Selective Control Valves and Couplers — General Instructions on Safety and Reconditioning
SCV Identification
Installing the Shuttle Valves
Series 300 Selective Control Valves (Electrically Actuated) — Removing and Installing the Stepper Motors
Removing the Selective Control Valves
Series 100/101 Selective Control Valves — Reconditioning
Series 200 to 301 Selective Control Valves — Replacing the Control Knobs
Series 200 to 301 Selective Control Valves — Inspecting the Check Valves
Series 200 to 301 Selective Control Valves — Inspecting the Inlet Check Valve and Metering Valve
Series 200/201 Selective Control Valves — Reconditioning
Series 300/301 Selective Control Valves — Inspecting the Pressure Compensator Valve
Series 300/301 Selective Control Valves — Reconditioning
Series 300 Selective Control Valves (Electrically Actuated) — Inspecting the Check Valves
Series 300 Selective Control Valves (Electrically Actuated) — Inspecting the Inlet Check Valve
Series 300 Selective Control Valves (Electrically Actuated) — Inspecting the Pressure Compensator Valve
Series 300 Selective Control Valves (Electrically Actuated) — Reconditioning
Installing the Selective Control Valves
Selective Control Valves — Installing the Endplate
Selective Control Valves — Reconditioning the Couplers
Reconditioning Independent Control Valves — Summary of References
Other Material
Specifications
Removing the Independent Control Valve (M-ICV)
Reconditioning the Independent Control Valve (M-ICV)
Independent Control Valves — Reconditioning the Inlet Plate
Assembling the Independent Control Valve (M-ICV)
Installing the Independent Control Valve (M-ICV)
Independent Control Valve (E-ICV) — Removing and Installing the Stepper Motors
Removing the Independent Control Valve (E-ICV)
Reconditioning the Independent Control Valve (E-ICV)
Assembling the Independent Control Valve (E-ICV)
Installing the Independent Control Valve (E-ICV)
MISCELLANEOUS
Specifications
Removing and Installing the Main Frame (Summary of References)
Removing the Main Frame
Removing and Installing the Front Axle or Front-Wheel Drive Axle (Summary of References)
Removing the Front Axle
Removing the Front Wheel Drive Axle
Installing the Front-Wheel Drive Axle
Removing the Front Wheel Drive Axle With TLS
Installing the Front Wheel Drive Axle With TLS
Removing and Installing the Front Axle Support (Summary of References)
Removing the Front Axle Support
Main Frame
Specifications
Reconditioning the Main Frame (with or without TLS FWD axle)
Front Axle
Specifications
Front Axle — Reconditioning (Summary of References)
Reconditioning the Front Axle
Checking and Adjusting Toe-In
Specifications
Front and Rear Wheels — Reconditioning (Summary of References)
Removing the Front and Rear Wheels
Reconditioning the Front and Rear Wheels
Installing the Front and Rear Wheels
Trailer Mounting and Swinging Drawbar
Trailer Mounting and Swinging Drawbar — Reconditioning (Summary of References)
Specifications
Installing Rigid Trailer Mounting
Installing the Guide Rails
Repairing the Automatic Trailer Hitch (Two-Lever Operation)
Repairing the Automatic Trailer Hitch (One-Lever Operation)
Remote Control for Automatic Trailer Hitch
Reconditioning the height-adjustable trailer hitch (Italy and Spain only)
Swinging Drawbar
Swinging Drawbar with Pick-Up Hitch
Adjusting the Retaining Strap
Triple Link Suspension (TLS) of Front-Wheel Drive Axle
Triple Link Suspension (TLS) of FWD Axle—Summary of References
Other Material
Specifications
Relieving Pressure in the Hydraulic System
Removing/Installing the Oscillation Limiter
Removing the Panhard Link
Installing the Panhard Link
Removing and Installing the Sensor Rod
Removing the Position Sensor
Reconditioning the Position Sensor
Removing the Hydraulic Cylinder
Reconditioning the Hydraulic Cylinder
Installing the Hydraulic Cylinder
Removing the Control Valve Block
Reconditioning the Valves in the Control Valve Block
Installing the Control Valve Block
Removing the Accumulator
Installing the Accumulator
Removing and Reconditioning the Bearing Support
Installing the bearing support
Pick-Up Hitch
Pick-Up Hitch — Summary of References
Specifications
Other Material
Installing the Upper Frame
Frame Assembly - Exploded View
Control Lever and Lift Links - Exploded View
Hydraulic Parts
Repairing the Retainer Spring
Repairing the Latch Housing
Repairing the Hydraulic Cylinder
Adjusting the Lift Links
Adjusting the Guide Stop
Adjusting the Locking Pin
Operational Check
OPERATOR'S CAB
Special Tools
Specifications
Operator's Cab / Open Station, Tilting or Removing and Installing
Tilting the Operator's Cab Upward
Tilting the Operator's Cab Downward
Removing the Operator's Cab
Installing the Operator's Cab
Tilting Flat-Floor Cabs on SE Tractors Upward and Downward
Removing the Operator's Cab from SE Tractors
Installing the Operator's Cab on SE Tractors
Removing the Open Operator's Station
Installing the Open Operator's Station
Controls and Instruments
Controls and Instruments (Summary of References)
Replacing Bulbs on the Instrument Unit
Removing Control Unit
Removing Control Unit for the Lighting System
Replace Control Unit (BCU)
Replace Control Unit (BCU) on SE Tractors
Replace Control Unit (SFA)
Replace Control Unit (SIC)
Replace Control Unit (ECU)
Replace Control Unit (UIC/PLC)
Replacing the Bus Resistors
Replacing the Performance Monitor (PRF)
Replacing Instrument Unit (BIF)
Replacing Instrument Unit (Tractors without Cab)
Replace Operation Unit
Air-Conditioning System (Summary of References)
Special Tools
Specifications
Torques for Tightening Refrigerant Hoses
Safety At Work
Handling Refrigerant
In an Emergency
Safety Equipment
Storage of Refrigerant Containers
R134A Refrigerant
Important Note
Discharging the System
Evacuating the System
Filling with Refrigerant Oil
Instructions for Starting Up the DENSO Air-Conditioning Compressor
Filling the System
Topping Up a Partly Discharged System
Leak Test
Removing the Compressor
Checking Level in the Compressor
Disassembling the Compressor Clutch
Checking Clutch Hub Clearance
Checking the Compressor Manifold
Installing the Compressor
Removing and Installing the Condenser
Removing and Installing the Receiver-Drier
Removing and Installing the Evaporator and Expansion Valve1
Replacing the Expansion Valve
SE-Tractors: Removing and Installing the Evaporator and Expansion Valve
Installing Condensation Water Drain Hoses
SE-Tractors: Arrangement of Condensation Water Drain Hoses
Removing the Heater/Evaporator Housing From SE Tractors
Removing and Installing the Thermostat Switch
Adjusting Thermostat Switch Bowden Cables
SE-Tractors: Removing and Installing the Thermostat Switch
Removing and Installing the High/Low Pressure Switch
Heating System
6020 to 6620 Tractors
SE-Tractors
Seats
Specifications
Super Comfort Seat MSG83
Comfort Seat MSG85
Air Comfort Seat MSG95A-00, Lower Section
Passenger Seat, Exploded View
Command Arm Repair
Operator's Cab
Operator's Cab (Summary of References)
Removing Cab Frame
Torques for Hardware on Platform Mounting (2-Post ROPS, Standard Version)
Cab Mounting Torques
Removing the Outer Roof
Removing and Installing the Windshield
Removing and Installing the Rear Window
Removing and Installing the Roof Hatch
Installing Door Lock
Adjusting Window Contact Pressure
Operator's Cab Door Removal and Installation
Roller Sun-Visor Removal and Installation
Removing Inner Roof Trim
Cab Suspension
Cab Suspension - Summary of References
Important Instructions
Specifications
Relieving Hydraulic System Pressure
Adjusting the Sensor Rod
Removing Hydraulic Cylinder
Installing Hydraulic Cylinder
Panhard Link Removal and Installation
Bleeding Cab Suspension Hydraulic Cylinders
SPECIAL TOOLS (DEALER-FABRICATED)
Special Tools (Dealer-Fabricated)
Suspension Device
Lifting Device
Holding Device
Suspension Eyes for Operator's Cab
Holding device
Holding Tool
Wooden Block
DFRW79 - Piston Holding Tool
Socket Wrench Insert
Seal Installer
Driver
Assembly and Guide Mandrels
Turning Device
Bushing
Seal Installer
Special Wrench
Page Numbers
Brand: John Deere
Part Number: TM4750
SAFETY
Safety Measures
Prevent Acid Burns
Park Machine Safely
Work in Clean Area
Use Proper Tools
Live With Safety
GENERAL INFORMATION
Specifications
Air Intake System
Clutch
Power Reverser
Rear PTO
Front PTO
Differential lock
Final drives
Front-Wheel Drive
FWD axle with TLS
Hydraulic Brakes
Handbrake
Parking Lock
Rockshaft
Front Hitch
Ground Speeds
Capacities
Diesel Fuel
Diesel Engine Oil
Grease
Oil Filters
Lubricant Storage
Tune-Up
Specifications
Tractor Tune-Up
Final Engine Check
ENGINE
Specifications
Removing the Engine
Specifications
Fuel System
Air Intake System
Specifications
Fuel Preheater
Coolant Heater
Exhaust System
Specifications
ELECTRICAL SYSTEM
Connectors
Special Tools
General
Stripping Wire Ends
Connectors
KOSTAL connectors
DEUTSCH Connectors
Changing terminals
Wiring Harnesses
Charging Circuit
Special Tools
Specifications
Specifications
Note
Special Tools
Specifications
Rockshaft control
Monitoring Systems
Note
Note
Note
Note
Note
Special Tools
Specifications
Specifications
Specifications
Specifications
Removing the Clutch
Gear Transmission
Specifications
Specifications
Specifications
Specifications
Gear Transmission
Specifications
Specifications
Input Housing
Specifications
Output Housing
Specifications
Specifications
Specifications
Specifications
PowrQuad Module
Specifications
Specifications
Option Transmission
Specifications
Range Transmission
Specifications
DRIVE SYSTEMS
Specifications
Specifications
Other Material
Specifications
Specifications
Specifications
Final Drives
Specifications
Rear PTO Options
Other Material
Specifications
Front PTO
Other Material
Specifications
Specifications
Summary of Torques
Preliminary Work
STEERING AND BRAKES
Special Tools
Specifications
Preliminary Work
Specifications
Brake Valve
Special Tools
Specifications
Rear Brakes
Specifications
Final assembly
Handbrake
Specifications
Preliminary Work
Final Assembly
Handbrake Test
Special Tools
Specifications
Repair Instructions
Cleaning the Screen
Air Brakes
Specifications
Test sequence
HYDRAULIC SYSTEM
Controls
Specifications
Other Material
Specifications
Other Material
Specifications
Valves
Specifications
Rockshaft
Other Material
Specifications
Special Tools
Other Material
Specifications
SCV Identification
Other Material
Specifications
MISCELLANEOUS
Specifications
Main Frame
Specifications
Front Axle
Specifications
Specifications
Specifications
Swinging Drawbar
Other Material
Specifications
Pick-Up Hitch
Specifications
Other Material
Hydraulic Parts
Operational Check
OPERATOR'S CAB
Special Tools
Specifications
Special Tools
Specifications
Safety At Work
In an Emergency
Safety Equipment
R134A Refrigerant
Important Note
Filling the System
Leak Test
Heating System
SE-Tractors
Seats
Specifications
Comfort Seat MSG85
Command Arm Repair
Operator's Cab
Removing Cab Frame
Cab Suspension
Specifications
Suspension Device
Lifting Device
Holding Device
Holding device
Holding Tool
Wooden Block
Seal Installer
Driver
Turning Device
Bushing
Seal Installer
Special Wrench
Page Numbers
- JOHN DEERE CODE DTC LIST
