John Deere 6020 to 6920S and SE Tractor Operation and Tests Manual TM4741
Brand: John Deere
Type of Manual: Operation and Tests Manual
Model: John Deere 6020, 6120, 6220, 6320, 6420, 6420S, 6520, 6620, 6820, 6920 and 6920S
6020SE, 6120SE, 6220SE, 6320SE, 6420SE and 6520SE Tractor
Part Number: TM4741
Publication Date: 2002
Number of Pages: 3476 Pages
GENERAL INFORMATION
Safety Measures
Recognize Safety Information
"Important" - Information
"Note" - Information
Prevent Machine Runaway
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Avoid High-Pressure Fluids
Service Cooling System Safely
Work In Ventilated Area
Wear Protective Clothing
Practice Safe Maintenance
Park Machine Safely
Use Proper Lifting Equipment
Support Machine Properly
Work in Clean Area
Illuminate Work Area Safely
Service Machines Safely
Use Proper Tools
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Safety Information - Air Brake System
Avoid Eye Contact With Radar
Keep ROPS Installed Properly
Replace Safety Signs
Dispose of Waste Properly
Live With Safety
Safety Measures on Electronic Control Units
General References
210-15-001, General References—Summary
Reference 210-15-010, Unified Inch Bolt and Cap Screw Torque Values
Reference 210-15-015, Metric Bolt and Cap Screw Torque Values
210-15-020, Hydraulic System Inch Fitting Torques
210-15-025, Hydraulic System Metric Fitting Torques
210-15-030, Component Identification Table
Reference 210-15-035, How to Read a Functional Schematic
210-15-040, How to Read a Diagnostic Schematic
210-15-042, Wire Numbers and Color Codes
210-15-045, Schematic, Wiring and Harness Symbols
210-15-050, Visual Check of the Electrical System
Reference 210-15-055, Electrical Circuit Malfunctions
Types of fault
Reference 210-15-060, Seven Step Electrical Test Procedure
210-15-065, Hydraulic System — Circuit Symbols
ENGINE
Operational Check-Out
Reference 220-10-010, Safety
220-10-020, Preliminary Engine Tests
Tests and Adjustments
220-15-010, Dynamometer Test
FUEL, AIR INTAKE AND COOLING SYSTEMS
Reference 230-15-001, Tests and Adjustments—Summary of References
Reference 230-15-010, General Information
Reference 230-15-020, Explanation of Checks
Reference 230-15-030, Safety
Reference 230-15-040, Special Tools
Reference 230-15-050, Specifications
Reference 230-15-060, Testing Air Intake System
Reference 230-15-070, Checking the Cooling System for Leaks
Reference 230-15-080, Testing the Temperature at which the Thermostat opens
Reference 230-15-090, Checking the Viscous Fan Drive
Reference 230-15-100, Checking the Fuel Transfer Pump
Reference 230-15-110, Hand Throttle Lever and Accelerator Pedal Adjustment
Reference 230-15-120, Accelerator Pedal Adjustment
Descriptions
Reference 230-20-001, Component Description - Summary of References
Reference 230-20-010, Fuel System - Description
Reference 230-20-020, Air Intake System - Theory of Operation
Reference 230-20-030, Coolant Circuit - Description
Reference 230-20-040, Cooling System Radiator - Description
Reference 230-20-050, Intercooler - Description
Reference 230-20-060, Ring-Shaped (Transmission Oil) Cooler - Description
Reference 230-20-070, Viscous Fan Drive - Theory of Operation
Reference 230-20-080, Automatic Drive Belt Tensioner - Theory of Operation
Reference 230-20-020, Cold Weather Starting Aids - Theory of Operation
ELECTRICAL SYSTEM
Sub-System Diagnostics (Cab)
Reference 240-10-001, Sub-System Diagnostics (Cab) — Summary of References
Reference 240-10-002, Special Tools
Reference 240-10-050, SE1 — Starter Motor and Charging Circuit
Reference 240-10-004, SE2 — Basic Informator
Reference 240-10-005, SE3 — Horn
Reference 240-10-006, SE4 — Cigarette Lighter and Operator's Seat
Reference 240-10-007, SE6 — Lights
Reference 240-10-008, SE7— Worklights
Reference 240-10-009, SE8 — Front Loader Plug
Reference 240-10-010, SE9 — Radio, Digital Clock, Dome, Console and Access Step Lights
Reference 240-10-011, SE10 — Fan and Air Conditioner
Reference 240-10-012, SE11—Windshield Wiper and Washer
Reference 240-10-013, SE12 — Rear Window Wiper and Washer
Reference 240-10-014, SE13 — Beacon Light
Reference 240-10-015, SE14 — Power Outlet Sockets, 3- and 7-Terminal
Reference 240-10-016, SE15 — Electronic Hitch Control
Reference 240-10-017, SE16A — Basic Control Unit (BCU) (Rear PTO and External Control)
Reference 240-10-018, SE16B — Basic Control Unit (BCU) (Front PTO)
Reference 240-10-019, SE16C — Basic Control Unit (BCU) (Front-Wheel Drive)
Reference 240-10-020, SE16D — Basic Control Unit (BCU) (Differential Lock)
Reference 240-10-021, SE16E — BCU (Hazard Warning and Turn Signal Lights)
Reference 240-10A-051, SE16F — Basic Control Unit (BCU) (Speed Sensor and Radar) (PowrQuad Plus or AutoQuad Transmissions)
Reference 240-10-022, SE16F — Basic Control Unit (BCU) (Speed Sensor and Radar) (AutoPowr/IVT Transmission)
Reference 240-10-023, SE16G — Basic Control Unit (BCU) (Headland Management System II)
Reference 240-10-024, SE16H — Basic Control Unit (BCU) (Power Supply, Acoustic Alarm)
Reference 240-10-025, SE16I — BCU (Intercooler)
Reference 240-10-026, SE16J — Basic Control Unit (BCU) (Braking System and Handbrake Monitor Unit)
Reference 240-10-027, SE17 — Signal Socket
Reference 240-10-028, SE18 — Performance Monitor
Reference 240-10-029, SE20 — Front-Wheel Drive Axle with TLS and CSC Cab Suspension
Reference 240-10-030, SE21 — Electronic Actuation of SCVs
Reference 240-10-031, SE21A — Stepper Motor Driver for Electronic Independent Control Valves (E-ICV)
Reference 240-10-032, SE21B — Stepper Motor Driver for Electronic Selective Control Valves (E-SCV)
Reference 240-10-033, SE22 — BUS Terminator and Terminating Resistor
Reference 240-10A-052, SE23A — Electronic Engine Control (PowrQuad Plus and AutoQuad Transmissions)
Reference 240-10-034, SE23B — Electronic Engine Control (PowrQuad Plus, AutoQuad and AutoPowr/IVT transmissions)
Reference 240-10-035, SE26 — Transmission Control Unit (AutoPowr/IVT Transmissions)
Reference 240-10A-053, SE26A — Transmission Control (PowrQuad Plus & AutoQuad Transm.)
Reference 240-10A-054, SE26C — Electrical Reverser Control (PowrQuad Plus and AutoQuad Transmissions)
Reference 240-10-036, SE27 — Transmission Shift (AutoPowr/IVT transmission)
Reference 240-10-037, SE28 — Electronic Park Lock (AutoPowr/IVT Transmission)
Reference 240-10-040, SE29 — Electrical Rear-View Mirror
Reference 240-10-038, SE30 — JDLink Control Unit
Reference 240-10-039, SE31 — Heated Rear Window
Reference 240-10-041, SE32 — 60-amp GreenStar Socket (with and without TEC)
Reference 240-10-042, SE33 — GreenStar
Sub-System Diagnsotics (Open Operator's Station)
Reference 240-10A-001, Sub-System Diagnostics (Open Operator's Station) — Summary of References
Reference 240-10A-003, SE1—Starter Motor and Charging Circuit
Reference 240-10A-004, SE2—Basic Informator
Reference 240-10A-005, SE3 — Horn
Reference 240-10A-006, SE4 — Operator's Seat
Reference 240-10A-007, SE6—Lights
Reference 240-10A-008, SE7— Worklights
Reference 240-10A-009, SE14—3- and 7-Terminal Power Outlet Sockets
Reference 240-10A-010, SE15—Electronic Hitch Control
Reference 240-10A-011, SE16A—Basic Control Unit (BCU) (Rear PTO)
Reference 240-10A-012, SE16B—Basic Control Unit (BCU) (Front PTO)
Reference 240-10A-013, SE16C—Basic Control Unit (BCU) (Front-Wheel Drive)
Reference 240-10A-014, SE16D—Basic Control Unit (BCU) (Differential Lock)
Reference 240-10A-015, SE16E—Basic Control Unit (BCU) (Hazard Flasher and Turn Signal Unit)
Reference 240-10A-016, SE16F—Basic Control Unit (BCU) (Speed Sending Units)
Reference 240-10A-017, SE16H—Basic Control Unit (BCU) (Power Supply, Acoustic Alarm)
Reference 240-10A-018, SE16J—Basic Control Unit (BCU) (Braking System and BUS Connection)
Reference 240-10A-019, SE17—Signal Socket
Reference 240-10A-020, SE22 — BUS Terminator and Terminating Resistor
Reference 240-10A-021, SE23 — Electronic Engine Control
Sub-System Diagnostics (SE Tractor)
Reference 240-10B-001, Sub-System Diagnostics (SE Tractors) — Summary of References
Reference 240-10B-003, SE1 — Starter Motor and Charging Circuit
Reference 240-10B-004, SE2 — Basic Informator
Reference 240-10B-005, SE3 — Horn
Reference 240-10B-006, SE4 — Operator's Seat
Reference 240-10B-007, SE6 — Lights
Reference 240-10B-008, SE7 — Worklights
Reference 240-10B-009, SE9 — Radio, Dome Light and Console Light
Reference 240-10B-010, SE10 — Fan and Air-Conditioning System
Reference 240-10B-011, SE11 — Windshield Wiper and Washer
Reference 240-10B-012, SE13 — Beacon Light
Reference 240-10B-013, SE14 — 3- and 7-Terminal Power Outlet Sockets
Reference 240-10B-014, SE15 — Electronic Hitch Control
Reference 240-10B-015, SE16A — Basic Control Unit (BCU) (Rear PTO and External Control)
Reference 240-10B-016, SE16B — Basic Control Unit (BCU) (Front PTO)
Reference 240-10B-017, SE16C — Basic Control Unit (BCU) (Front-Wheel Drive)
Reference 240-10B-018, SE16D — Basic Control Unit (BCU) (Differential Lock)
Reference 240-10B-019, SE16E — Basic Control Unit (BCU) (Hazard Flasher and Turn Signal Unit)
Reference 240-10B-020, SE16F — Basic Control Unit (BCU) (Speed Sender and Radar)
Reference 240-10B-021, SE16H — Basic Control Unit (BCU) (Power Supply, Acoustic Alarm and CAN-BUS Connection)
Reference 240-10B-022, SE16J — Basic Control Unit (BCU) (Control Unit for Brakes and Handbrake)
Reference 240-10B-023, SE17 — Signal Socket
Reference 240-10B-024, SE22 — BUS Terminator and Terminating Resistor
Reference 240-10B-025, SE23 — Electronic Engine Control
Component Testing
Reference 240-15-001, SE01 — Starter Motor and Charging Circuit
Starter Checks (M01)
Alternator Checks (G02)
Battery Checks (G01)
Component Tests
Reference 240-15-002, SE02 — Basic Informator
Component checks
Reference 240-15-003, SE03 — Horn
Reference 240-15-004, SE04 — Cigarette Lighter and Operator's Seat
Reference 240-15-005, SE06 — Lighting Circuits
Reference 240-15-006, SE07-Worklights
Reference 240-15-007, SE09 — Radio, Dome Light and Console Light
Reference 240-15-008, SE10 — Blower and Air Conditioner
Reference 240-15-009, SE11 and SE12 — Wiper and Washer System
Reference 240-15-010, SE13 — Beacon Light
Reference 240-15-011, SE14 — Sockets, 3- and 7-Terminal
Reference 240-15-012, SE15 — Electronic Hitch Control
Reference 240-15-013, SE16A — Basic Control Unit (BCU) (Rear PTO and External Control)
Reference 240-15-014, SE16B — BCU (Front PTO)
Reference 240-15-015, SE16C — BCU (FWD)
Reference 240-15-016, SE16D — BCU (Differential Lock)
Reference 240-15-017, SE16E - Basic Control Unit (BCU) (Hazard Flasher and Turn Signal Unit)
Reference 240-15-018, SE16G — Basic Control Unit (BCU) (HMS)
Reference 240-15-019, SE16H — Basic Control Unit (BCU) (Power Supply, Acoustic Alarm)
Reference 240-15-020, SE16I — BCU (Intercooler)
Reference 240-15-021, SE16J — Basic Control Unit (BCU) (Braking System and Handbrake Monitor Unit)
Reference 240-15-022, SE20 — FWD Axle with TLS and Cab Suspension
Reference 240-15-023, SE21 — Electronic Actuation of SCVs
Reference 240-15-024, SE22 — CAN BUS Terminating Resistor
Reference 240-15-025, SE23 — Electronic Engine Control
Reference 240-15-026, SE26A — Transmission Control (PowrQuad Plus and AutoQuad Transmission)
Reference 240-15-027, SE26C — Electrical Reverser Control (PowrQuad Plus and AutoQuad Transmissions)
Reference 240-15-028, SE27 — Transmission Shift (AutoPowr/IVT Transmissions)
Reference 240-15-029, SE28 — Electronic Park Lock (AutoPowr/IVT Transmissions)
Reference 240-15-030, SE29 — Electrically-Adjustable Outside Mirrors
Reference 240-15-031, SE31 — Heated Rear Window
Reference 240-15-032, SE32 — 60-amp GreenStar Socket (with and without TEC)
Functional Schematics (AutoPowr/IVT Transmission)
Reference 240-25-001, Functional Schematic and Fuses (AutoPowr/IVT Transmission) — Summary of References
Reference 240-25-002, Fuses
Reference 240-25-003, Designation of Parts Shown in Functional Schematic and Harness Diagram
Reference 240-25-004, Designation of Sections Shown in Functional Schematic
Reference 240-25-005, Wiring Harness Designations
Reference 240-25-006, Functional Schematic (Complete Tractor)
Functional Schematics (PowrQuad Plus & AutoQuad Transm.)
Reference 240-25A-001, Functional Schematic and Wiring Harnesses (PowrQuad Plus and AutoQuad Transmissions ) — Summary of References
Reference 240-25A-010, Fuses
Reference 240-25A-011, Designation of Parts Shown in Functional Schematic and Harness Diagram
Reference 240-25A-012, Designation of Sections Shown in Functional Schematic
Reference 240-25A-013, Wiring Harness Designations
Reference 240-25A-014, Functional Schematic (Complete Tractor)
Functional Schematics (Open Operator's Station)
Reference 240-25B-001, Functional Schematic and Wiring Harnesses (Open Operator's Station) — Summary of References
Reference 240-25B-002, Fuses and Relays
Reference 240-25B-003, Designation of Parts Shown in Functional Schematic and Harness Diagram
Reference 240-25B-004, Designation of Sections Shown in Functional Schematic
Reference 240-25B-005, Wiring Harness Designations
Reference 240-25B-006, Functional Schematic (Complete Tractor)
Functional Schematics (SE Tractor)
Reference 240-25C-001, Functional Schematic and Wiring Harnesses (SE Tractor) — Summary of References
Reference 240-25C-010, Fuses and Relays
Reference 240-25C-011, Designation of Parts Shown in Functional Schematic and Harness Diagram
Reference 240-25C-012, Designation of Sections Shown in Functional Schematic
Reference 240-25C-013, Wiring Harness Designations
Reference 240-25C-014, Functional Schematic (Complete Tractor)
Wiring Harnesses
Reference 240-26-004, Wiring Harnesses for 6120, 6220, 6320, 6420 and 6520 Tractors with PowrQuad Plus Transmission and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-005, Wiring Harnesses for 6320, 6420 and 6520 Tractors with AutoQuad Transmission and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-002, Wiring Harnesses for 6420S, 6620, 6820, 6920 and 6920S Tractors with PowrQuad Plus or AutoQuad Transmissions and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-501, Wiring Harnesses for Tractors with PowrQuad Plus or AutoQuad Transmissions and Stage II Engine to 97/68/EC — Summary of References
Reference 240-26-003, Wiring Harnesses for Tractors with AutoPowr/IVT Transmission and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-502, Wiring Harnesses for Tractors with AutoPowr/IVT Transmission and Stage II Engine to 97/68/EC — Summary of References
Reference 240-26-006, Wiring Harnesses for Tractors with Open Operator's Station and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-503, Wiring Harnesses for Tractors with Open Operator's Station and Stage II Engine to 97/68/EC — Summary of References
Reference 240-26-007, Wiring Harnesses for SE Tractors with Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-504, Wiring Harnesses for SE Tractors with Stage II Engine to 97/68/EC — Summary of References
Reference 240-26-011, W01 — Wiring Harness - Power Supply
Reference 240-26-013, W01 — Wiring Harness - Power Supply (Open Operator's Station)
Reference 240-26-015, W01 — Wiring Harness - Power Supply (SE Tractors)
Reference 240-26-021, W02 — Engine Wiring Harness for Stage I Engine to 97/68/EC (without Engine Control or with Level 1 ECU)
Reference 240-26-023, W02 — Engine Wiring Harness for Stage I Engines to 97/68/EC (Level 4 ECU)
Reference 240-26-521, W02 — Engine Wiring Harness for Stage II Engines to 97/68/EC (Level 11 ECU)
Reference 240-26-025, W02 — Engine Wiring Harness for Stage I Engines to 97/68/EC (Open Operator's Station)
Reference 240-26-524, W02 — Engine Wiring Harness for Stage II Engines to 97/68/EC (Level 12 ECU) (Open Operator's Station)
Reference 240-26-027, W02 — Engine Wiring Harness for Stage I Engines to 97/68/EC (SE Tractors)
Reference 240-26-526, W02 — Engine Wiring Harness for Stage II Engines to 97/68/EC (Level 12 ECU) (SE Tractors)
Reference 240-26-031, W03 — Wiring Harness - Starting Aid for Stage I and II Engines to 97/68/EC (without Engine Control or with Level 1 or 12 ECUs)
Reference 240-26-032, W03 — Wiring Harness - Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs)
Reference 240-26-033, W03 — Wiring Harness - Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs) (AutoPowr/IVT transmission)
Reference 240-26-042, W04 — Wiring Harness - Headlights
Reference 240-26-061, W06 — Wiring Harness - Front-Wheel Drive Axle with TLS
Reference 240-26-071, W07 — Wiring Harness - Front PTO
Reference 240-26-081, W08 — Wiring Harness - Cab, with Stage I Engine to 97/68/EC
Reference 240-26-581, W08 — Wiring Harness - Cab, with Stage II Engine to 97/68/EC
Reference 240-26-082, W08 — Wiring Harness - Cab, with Stage I Engine to 97/68/EC (AutoPowr/IVT transmission)
Reference 240-26-582, W08 — Wiring Harness - Cab, with Stage II Engine to 97/68/EC (AutoPowr/IVT transmission)
Reference 240-26-083, W08 — Wiring Harness - Open Operator's Station, with Stage I Engine to 97/68/EC
Reference 240-26-583, W08 — Wiring Harness - Open Operator's Station, with Stage II Engine to 97/68/EC
Reference 240-26-084, W08 — Wiring Harness - Cab, with Stage I Engine to 97/68/EC (SE Tractors)
Reference 240-26-584, W08 — Wiring Harness - Cab, with Stage II Engine to 97/68/EC (SE Tractors)
Reference 240-26-091, W09 — Wiring Harness - Cowl, with Stage I Engine to 97/68/EC
Reference 240-26-591, W09 — Wiring Harness - Cowl, with Stage II Engine to 97/68/EC
Reference 240-26-092, W09 — Wiring Harness - Cowl, with Stage I Engine to 97/68/EC (AutoPowr/IVT transmission)
Reference 240-26-592, W09 — Wiring Harness - Cowl, with Stage II Engine to 97/68/EC (AutoPowr/IVT transmission)
Reference 240-26-094, W09 — Wiring Harness - Cowl, with Stage I Engine to 97/68/EC (Open Operator's Station)
Reference 240-26-593, W09 — Wiring Harness - Cowl, with Stage II Engine to 97/68/EC (Open Operator's Station)
Reference 240-26-095, W09 — Wiring Harness - Cowl, with Stage I Engine to 97/68/EC (SE Tractors)
Reference 240-26-594, W09 — Wiring Harness - Cowl, with Stage II Engine to 97/68/EC (SE Tractors)
Reference 240-26-101, W10 — Wiring Harness - Shift Console
Reference 240-26-111, W11 — Wiring Harness - Transmission Shift and Hand Throttle
Reference 240-26-112, W11 — Wiring Harness - Speed Control Lever and Hand Throttle (AutoPowr/IVT Transmission)
Reference 240-26-122, W12 — Wiring Harness - Command Arm (AutoPowr/IVT Transmission)
Reference 240-26-131, W13 — Wiring Harness - Clutch Sender
Reference 240-26-144, W14 — Wiring Harness - 3-Terminal Power Outlet Socket
Reference 240-26-141, W14 — Wiring Harness - 3-Terminal Power Outlet Socket (Open Operator's Station and SE Tractor)
Reference 240-26-153, W15 — ECU Wiring Harness for Stage I Engines to 97/68/EC (without Engine Control)
Reference 240-26-151, W15 — ECU Wiring Harness for Stage I Engines to 97/68/EC (Level 1 ECU)
Reference 240-26-152, W15 — ECU Wiring Harness for Stage I Engines to 97/68/EC (Level 4 ECU)
Reference 240-26-651, W15 — ECU Wiring Harness for Stage II Engines to 97/68/EC (Level 11 ECU)
Reference 240-26-161, W16 — SIC Wiring Harness for Stage I Engines to 97/68/EC
Reference 240-26-561, W16 — SIC Wiring Harness for Stage II Engines to 97/68/EC
Reference 240-26-171, W17 — Wiring Harness - Multifunction Unit
Reference 240-26-181, W18 — Wiring Harness - Windshield Wiper Switch (without Intermittent Wipe)
Reference 240-26-182, W18 — Wiring Harness - Windshield Wiper Switch (with Intermittent Wipe)
Reference 240-26-191, W19 — Wiring Harness - Cab Roof, with Stage I Engines to 97/68/EC
Reference 240-26-691, W19 — Wiring Harness - Cab Roof, with Stage II Engines to 97/68/EC
Reference 240-26-193, W19 — Cab Roof Wiring Harness (SE Tractors)
Reference 240-26-201, W20 — Wiring Harness - Turn Signal and Clearance Lights
240-26-211, W21 — Wiring Harness - Worklights on Front of Cab Roof
240-26-221, W22 — Wiring Harness - Worklights on Rear of Cab Roof
Reference 240-26-222, W22 — Wiring Harness - Xenon Worklights on Rear of Cab Roof
Reference 240-26-231, W23 — Wiring Harness - Windshield Wiper (Without Switch for Windshield)
Reference 240-26-232, W23 — Wiring Harness - Windshield Wiper (With Switch for Windshield)
Reference 240-26-241, W24 — Wiring Harness - Rear Window Wiper
Reference 240-26-251, W25 — Wiring Harness - Rear Window Wiper Switch
Reference 240-26-261, W26 — Wiring Harness - Blower and Air Conditioner
Reference 240-26-263, W26 — Wiring Harness - Fan and Air Conditioner (SE Tractors)
Reference 240-26-281, W28 — Wiring Harness - Front End of Transmission
Reference 240-26-285, W28 — Wiring Harness - Front Part of Transmission (AutoPowr/IVT Transmission)
Reference 240-26-284, W28 — Wiring Harness - Front End of Transmission (Open Operator's Station)
Reference 240-26-288, W28 — Wiring Harness - Front Part of Transmission (SE Tractors)
Reference 240-26-291, W29 — Wiring Harness - Valve Block (AutoPowr/IVT Transmission)
Reference 240-26-303, W30 — Wiring Harness - Rear Part of Transmission (6120-6620 Tractors)
Reference 240-26-304, W30 — Wiring Harness - Rear Part of Transmission (6820-6920 Tractors)
Reference 240-26-306, W30 — Wiring Harness - Rear End of Transmission (Open Operator's Station)
Reference 240-26-307, W30 — Wiring Harness - Rear Part of Transmission (SE Tractors)
Reference 240-26-311, W31 — Wiring Harness - 7-Terminal Power Outlet Socket
Reference 240-26-321, W32 — Wiring Harness - Stepper Motors, with Stage I Engines to 9/68/EC
Reference 240-26-821, W32 — Wiring Harness - Stepper Motors, with Stage II Engines to 97/68/EC
Reference 240-26-331, W33 — Wiring Harness - Service
Reference 240-26-341, W34 — Wiring Harness - Electric Rear-View Mirrors
Reference 240-26-351, W35 — Wiring Harness - Access-Step Light and Battery Cut-Off Switch
Reference 240-26-361, W36 — Wiring Harness - 60 A GreenStar Socket
Reference 240-26-371, W37 — Wiring Harness - GreenStar Port
Reference 240-26-391, W39 — Wiring Harness - GreenStar (Cab)
Reference 240-26-392, W39 — Wiring Harness - GreenStar (Cab) with TEC
Reference 240-26-401, W40 — Wiring Harness - GreenStar (Cab Roof)
Reference 240-26-411, W41 — Wiring Harness - JDLink
Reference 240-26-421, W42 — Wiring Harness - Battery Cut-Off Switch
ELECTRONIC CONTROL UNITS
Operation and General Information on Diagnostics
Special or Essential Tools
Reference 245-05-001, General Operating Instructions and Entering Program Mode
Customer Level
Dealer/Service Level
Reference 245-05-002, Accessing Addresses and Diagnostic Trouble Codes
Accessing the Diagnostic Trouble Codes of all the Control Units (ALL Mode)
Accessing and Confirming a Control Unit
Accessing Diagnostic Trouble Codes of the Individual Control Units
Accessing Addresses
Aborting or Completing the Program Mode
Reference 245-05-005, Driving in the Diagnostic Mode
Reference 245-05-003, Description of Diagnostic Trouble Codes
Reference 245-05-004, Electronic Control Units — Summary of Addresses
Reference 245-05-006, Approved Software for Control Units
Data BUS Systems, Diagnosis
Reference 245-10-001, 29-bit CAN BUS - Check
Checking the circuit
Reference 245-10-002, 11-bit CAN BUS - Check
Reference 245-10-003, 29-bit CAN BUS - Check (Tractors with Open Operator's Station and SE-Tractors with Stage II Engines according to 97/68/EC; Level 12)
Data BUS Systems, Theory of Operation
Reference 245-20-001, Data BUS Systems — Summary of References
Reference 245-20-002, Data-BUS Systems
Reference 245-20-003, CAN BUS System
Reference 245-20-011, CAN BUS Systems on Tractors without Engine Control Unit (ECU)
Reference 245-20-012, CAN BUS Systems on Tractors with Engine Control Unit (ECU) Level 1
Reference 245-20-013, CAN BUS Systems on Tractors with Engine Control Unit (ECU) Level 4
Reference 245-20-014, CAN BUS Systems on Tractors with AutoPowr/IVT Transmission
BCU - Basic Control Unit
Reference 245-BCU-001, Calibration and Input Addresses of Basic Functions
Entering program mode
Address BCU020 - Basic functions, engine speed sending unit/impulses per rev.
Address BCU021 - Basic functions, rear PTO speed sending unit/impulses per rev.
Address BCU022 - Basic functions, FWD control function
Address BCU023 - Basic functions, front PTO speed sending unit/impulses per rev.
Address BCU024 - Basic functions, units of measurement used in display
Address BCU025 — Basic functions, selection of region
Address BCU026 - Basic functions, audible indication of turn signal
Address BCU027 — Basic functions, front PTO control function
Address BCU028 — Basic functions, rear PTO control function
Address BCU029 - Basic functions, air brake system control function
Address BCU030 - Basic functions, sensor control function
Address BCU031 — Basic functions, reverse drive lever control function
Address BCU034 - Basic functions, LTC coolant pump control function
Address BCU035 — Basic functions, service interval setting
Address BCU037 - Basic functions, configuration of control displays
Address BCU038 - Basic functions, indicator light test
Address BCU039 - Basic functions, rear PTO remote control switch
Address BCU043 - Basic functions, number of engine operating hours
Address BCU044 - Basic functions, diagnostic trouble code display
Address BCU056 - Basic functions, rolling radius
Address BCU058 - Basic functions, wheel speed sending unit/impulses per rev.
Address BCU060 - Basic functions, calibration factor for travel speed (radar)
Address BCU066 - Basic functions, mode for HMS II
Address BCU077 — Basic functions, tractor configuration
Address BCU078 - Basic functions, engine control function
Address BCU247 - Tractor model designation
Address BCU248 - Tractor serial number
Reference 245-BCU-002, Calibration and Input Addresses of Hitch Control
Address BCU 118 — Input address for "quick withdrawal" and "hitch dampening"
Address BCU 122 — Calibration of rockshaft control
Address BCU 165 — Input address for rate of rise
Address BCU 167 — Input address for rockshaft components
Address BCU 174 — Input address for load control index
Address BCU 185 — Input address for volume of lift cylinder
Reference 245-BCU-100, Pre-Test of BCU Electrical Circuit
Reference 245-BCU-101, Circuit Test for Rear PTO Remote Control Switch (S44)
Operational check of rear PTO remote control (left)
Circuit/harness test for rear PTO remote control
Reference 245-BCU-102, Circuit Test for Rear PTO Switch S21 (with Command Arm)
Operational test on rear PTO switch (S21)
Circuit/harness test for rear PTO switch (S21)
Reference 245-BCU-103, Circuit Test for Rear PTO Switch (S21)
Reference 245-BCU-104, Circuit Test for PTO Preselector Switch (S45)
Operational check for rear PTO preselector switch (S45)
Circuit/harness test for rear PTO preselector switch (S45).
Reference 245-BCU-105, Circuit Test for Front PTO Switch (S06) (with Command Arm)
Operational check for front PTO switch (S06)
Circuit/harness test for front PTO switch S06 (with Command Arm)
Reference 245-BCU-106, Circuit Test for Front PTO Switch (S06)
Circuit/harness test for front PTO switch (S06)
Reference 245-BCU-107, Circuit Test for Front-Wheel Drive Switch (S63) (without HMS II)
Operational test on front-wheel drive switch (S63)
Circuit/harness test for front-wheel drive switch (S63) (without HMS II)
Reference 245-BCU-108, Circuit Test for Front-Wheel Drive Switch (S05) (with HMS II)
Operational test on front-wheel drive switch (S05)
Circuit test for front-wheel drive switch (S05) (with HMS II).
Reference 245-BCU-109, Circuit Test for Differential Lock Switch (S22)
Operational test for differential lock switch (S22)
Circuit/harness test for differential lock switch (S22)
Reference 245-BCU-110, Circuit Test for Hazard Warning Switch (S62)
Operational test for hazard warning switch (S62)
Circuit/harness test for hazard warning switch (S62) ECE
Reference 245-BCU-111, Circuit Test for Hazard Warning Switch (S66)
Operational test for hazard warning switch (S66)
Circuit/harness test for hazard warning switch (S66)
Reference 245-BCU-112, Circuit Test for Turn Signal Switch (S08)
Operational test on turn signal switch (S08)
Circuit/harness test for turn signal switch (S08)
Reference 245-BCU-113, Circuit Test for Wheel Speed Sender (B09) (on 6120-6620)
Operational test on wheel speed sending unit (B09)
Circuit/harness test for wheel speed sending unit (B09)
Reference 245-BCU-114, Circuit Test for Wheel Speed Sender (B09) (on 6820-6920)
Reference 245-BCU-115, Circuit Test for Wheel Speed Sender (B35) (on 6120-6620)
Operational test on wheel speed sending unit (B35) (on 6120-6620)
Circuit/harness test for wheel speed sending unit (B35)
Reference 245-BCU-116, Circuit Test for Wheel Speed Sender (B35) (on 6820-6920)
Reference 245-BCU-117, Circuit Test for Record/Save Switch (S95)
Operational test for record/save switch (S95)
Circuit/harness test for record/save switch
Reference 245-BCU-118, Circuit Test for HMS Program Switch (S100)
Operational test for HMS program switch (S100)
Circuit/harness test for HMS program switch (S100).
Reference 245-BCU-119, Circuit Test for Handbrake Switch (B37)
Operational test for handbrake switch (B37)
Circuit/harness test for handbrake switch (B37)
Reference 245-BCU-120, Circuit Test for Engine Speed Sender (B01)
Operational test on engine speed sender (B01)
Circuit/harness test for engine speed sender (B01)
Reference 245-BCU-121, Circuit Test for PTO Speed Sender (B06)
Operational test on PTO speed sender (B06)
Circuit/harness test for PTO speed sender (B06)
Reference 245-BCU-122, Circuit Test for Front PTO Speed Sender (B58)
Operational test on front PTO speed sender (B58)
Circuit/harness test for front PTO speed sender (B58)
Reference 245-BCU-123, Circuit Test on Sensitivity Potentiometer (B26)
Operational test on sensitivity potentiometer (B26)
Circuit/harness test for sensitivity potentiometer.
Reference 245-BCU-124, Circuit Test on Sensitivity Potentiometer (B97)
Operational test on sensitivity potentiometer (B97)
Reference 245-BCU-125, Circuit Test for Depth-Setting Potentiometer (B98)
Operational test on depth-setting potentiometer (B98)
Circuit/harness test for depth-setting potentiometer.
Reference 245-BCU-126, Circuit Test for Depth-Setting Potentiometer (B27)
Operational test on depth-setting potentiometer (B27)
Reference 245-BCU-127, Circuit Test for Position Sensor (B21)
Operational test for position sensor (B21)
Circuit/harness test for position sensor.
Reference 245-BCU-128, Circuit Test on Rate-of-Drop Potentiometer (B27)
Operational test on rate-of-drop potentiometer (B27)
Circuit/harness test for rate-of-drop potentiometer.
Reference 245-BCU-129, Circuit Test on Rate-of-Drop Potentiometer (B97)
Operational test on rate-of-drop potentiometer (B97)
Circuit/harness test for rate-of-drop potentiometer (B97)
Reference 245-BCU-130, Circuit Test on Raise-Limit Potentiometer (B27)
Operational test on raise-limit potentiometer (B27)
Circuit/harness test for raise-limit potentiometer (B27)
Reference 245-BCU-131, Circuit Test on Raise-Limit Potentiometer (B97)
Operational test on raise-limit potentiometer (B97)
Circuit/harness test for raise-limit potentiometer (B97)
Reference 245-BCU-132, Circuit Test for Rapid-Raise Switch (S24)
Operational check for rapid-raise switch (S24)
Circuit/harness test, potentiometer for rapid-raise switch (S24)
Reference 245-BCU-133, Circuit Test for Rapid-Raise Switch (S24_A)
Operational check for rapid-raise switch (S24_A)
Circuit/harness test, potentiometer for rapid-raise switch (S24_A)
Reference 245-BCU-134, Circuit Test for Rear PTO Solenoid Valve (Y04)
Circuit/harness test for rear PTO solenoid valve (Y04)
Reference 245-BCU-135, Circuit Test for Front-Wheel Drive Solenoid Valve (Y03)
Circuit/harness test for front-wheel drive solenoid valve (Y03)
Reference 245-BCU-136, Circuit Test for Differential Lock Solenoid Valve (Y05)
Circuit/harness test for differential lock solenoid valve (Y05)
Reference 245-BCU-137, Circuit Test for Front PTO Solenoid Valve (Y01)
Circuit/harness test for front PTO solenoid valve (Y01)
Reference 245-BCU-138, Circuit Test on R.h. Draft Sensor (B19)
Operational test on r.h. draft sensor (B19)
Circuit/harness test for the draft sensor.
Reference 245-BCU-139, Circuit Test for L.h. Draft Sensor (B20)
Operational test on l.h. draft sensor (B20)
Reference 245-BCU-140, Circuit Test for Draft Potentiometer (B41)
Operational test for draft potentiometer (B41)
Circuit/harness test for the draft potentiometer.
Reference 245-BCU-141, Circuit Test for Right Remote Control Switch (S23)
Operational check for right remote control switch (S23)
Circuit/harness test for right remote control switch
Reference 245-BCU-142, Circuit Test for Left Remote Control Switch (S68)
Operational check for left remote control switch (S68)
Circuit/harness test for left remote control switch
Reference 245-BCU-143, Circuit Test for Rockshaft Control Stepper Motor (M08)
Circuit/harness test for rockshaft control stepper motor (M08)
Reference 245-BCU-144, Circuit Test on Relay for LTC Coolant Pump K02/3
Circuit/harness test on relay for LTC coolant pump K02/3
Reference 245-BCU-145, Circuit Test for HMS Switch (S43)
Operational test for HMS switch (S43)
Circuit/harness test for HMS switch (S43)
Reference 245-BCU-146, Circuit Test for Air Brake Solenoid Valve (Y31)
Circuit/harness test for air brake solenoid valve (Y31)
Reference 245-BCU-147, Circuit Test for Alternator Relay (K02/2)
Circuit/harness test for alternator relay (K02/2)
Reference 245-BCU-148, Circuit Test for Rear PTO Switch (S21) - Open Operator's Station
Reference 245-BCU-149, Circuit Test for Front PTO Switch (S06) - Open Operator's Station
Reference 245-BCU-150, Circuit Test for Front-Wheel Drive Switch (S63) - Open Operator's Station
Reference 245-BCU-151, Circuit Test for Differential Lock Switch (S22) - Open Operator's Station
Reference 245-BCU-152, Circuit Test for Turn Signal Switch (S08) - Open Operator's Station
Reference 245-BCU-153, Circuit Test for Wheel Speed Sender (B35) - Open Operator's Station
Reference 245-BCU-154, Circuit Test for Engine Speed Sender (B01) - Open Operator's Station
Reference 245-BCU-155, Circuit Test for PTO Speed Sender (B06) - Open Operator's Station
Reference 245-BCU-156, Circuit Test for Front PTO Speed Sender (B58) - Open Operator's Station
Reference 245-BCU-157, Circuit Test on Sensitivity Potentiometer (B26) - Open Operator's Station
Reference 245-BCU-158, Circuit Test on Depth-Setting Potentiometer - Open Operator's Station
Reference 245-BCU-159, Circuit Test for Position Sensor (B21) - Open Operator's Station
Reference 245-BCU-160, Circuit Test on Rate-of-Drop Potentiometer - Open Operator's Station
Reference 245-BCU-161, Circuit Test on Raise-Limit Potentiometer - Open Operator's Station
Reference 245-BCU-162, Circuit Test for Rapid-Raise Switch (S24) - Open Operator's Station
Reference 245-BCU-163, Circuit Test for Rear PTO Solenoid Valve (Y04) - Open Operator's Station
Reference 245-BCU-164, Circuit Test for Front-Wheel Drive Solenoid Valve (Y03) - Open Operator's Station
Reference 245-BCU-165, Circuit Test for Differential Lock Solenoid Valve (Y05) - Open Operator's Station
Reference 245-BCU-166, Circuit Test on R.h. Draft Sensor (B19) - Open Operator's Station
Reference 245-BCU-167, Circuit Test on L.h. Draft Sensor (B20) - Open Operator's Station
Reference 245-BCU-168, Circuit Test for Left Remote Control Switch (S68) - Open Operator's Station
Reference 245-BCU-169, Circuit Test for Rockshaft Control Stepper Motor (M08) - Open Operator's Station
Reference 245-BCU-170, Circuit Test for Rear PTO Switch (S21) - SE Tractors
Circuit/harness test for rear PTO switch - SE tractors
Reference 245-BCU-171, Circuit Test for Front PTO Switch (S06) - SE Tractors
Circuit/harness test for front PTO switch (S06) - SE tractors
Reference 245-BCU-172, Circuit Test for Front-Wheel Drive Switch (S63) - SE Tractors
Circuit/harness test for front-wheel drive switch (S63) - SE tractors
Reference 245-BCU-173, Circuit Test for Differential Lock Switch (S22) - SE Tractors
Circuit/harness test for differential lock switch (S22) - SE tractors
Reference 245-BCU-174, Circuit Test for Hazard Warning Switch (S106) - SE Tractors
Operational test for hazard warning switch (S106)
Circuit/harness test for hazard warning switch (S106) - SE tractors
Reference 245-BCU-175, Circuit Test for Turn Signal Switch (S08) - SE Tractors
Circuit/harness test for turn signal switch (S08) - SE tractors
Reference 245-BCU-176, Circuit Test for Wheel Speed Sender (B35) - SE Tractors
Circuit/harness test for wheel speed sending unit (B35) - SE tractors
Reference 245-BCU-177, Circuit Test for Engine Speed Sender (B01) - SE Tractors
Circuit/Harness test for engine speed sender (B01) - SE tractors
Reference 245-BCU-178, Circuit Test for PTO Speed Sender (B06) - SE Tractors
Circuit/Harness test for PTO speed sender (B06) - SE tractors
Reference 245-BCU-179, Circuit Test for Front PTO Speed Sender (B58) - SE Tractors
Circuit/harness test for front PTO speed sending unit (B58) - SE tractors
Reference 245-BCU-180, Circuit Test on Sensitivity Potentiometer (B26) - SE Tractors
Circuit/harness test for sensitivity potentiometer - SE tractors
Reference 245-BCU-181, Circuit Test on Depth-Setting Potentiometer (B27) - SE Tractors
Circuit/harness test for depth-setting potentiometer - SE tractors
Reference 245-BCU-182, Circuit Test for Position Sensor (B21) - SE Tractors
Circuit/harness test for position sensor - SE tractors
Reference 245-BCU-183, Circuit Test on Rate-of-Drop Potentiometer (B27) - SE Tractors
Circuit/harness test for rate-of-drop potentiometer - SE tractors
Reference 245-BCU-184, Circuit Test on Raise-Limit Potentiometer (B27) - SE Tractors
Circuit/harness test for raise limit potentiometer (B27) - SE tractors
Reference 245-BCU-185, Circuit Test for Rapid-Raise Switch (S24) - SE Tractors
Circuit/harness test for potentiometer for rapid-raise switch (S24) - SE tractors
Reference 245-BCU-186, Circuit Test for Rear PTO Solenoid Valve (Y04) - SE Tractors
Reference 245-BCU-187, Circuit Test for Front-Wheel Drive Solenoid Valve (Y03) - SE Tractors
Reference 245-BCU-188, Circuit Test for Differential Lock Solenoid Valve (Y05) - SE Tractors
Reference 245-BCU-189, Circuit Test for Front PTO Solenoid Valve (Y01) - SE Tractors
Reference 245-BCU-190, Circuit Test on R.h. Draft Sensor (B19) - SE Tractors
Circuit/harness test for draft sensor - SE tractors
Reference 245-BCU-191, Circuit Test on L.h. Draft Sensor (B20) - SE Tractors
Reference 245-BCU-192, Circuit Test for Left Remote Control Switch (S68) - SE Tractors
Circuit/harness test for left remote control switch - SE tractors
Reference 245-BCU-193, Circuit Test for Rockshaft Control Stepper Motor (M08) - SE Tractors
Reference 245-BCU-200, Theory of Operation (Basic Functions)
Reference 245-BCU-201, Theory of Operation (Hitch Control)
BIF - Basic Informator
Reference 245-BIF-001, Calibration and Input Addresses
Address BIF022 - Gear indicator in display
Address BIF023 - Worklight alarm
Address BIF024 - Units of measurement used in displays
Address BIF027 - Indicator light test
Address BIF028 - Clock operation
Address BIF029 - Electrical starting aid
Address BIF035 - Instrument lighting brightness
Address BIF036 — Selecting the information source for engine oil pressure and coolant temperature
Address BIF037 - Ground speed sending unit
Address BIF038 - Language selection
Address BIF039 - Rear PTO speed indication
Address BIF060 - Front PTO control function
Address BIF066 - Data Bus control function
Address BIF247 - Tractor model designation
Address BIF248 - Tractor serial number
Reference 245-BIF-101, Circuit Test for Fuel Gauge Sender (B03)
Operational test for fuel gauge sender (B03)
Circuit/harness test for fuel gauge sender (B03)
Reference 245-BIF-102, Circuit Test for Coolant Temperature Sender (B08)
Operational test for coolant temperature sender (B08)
Circuit/Harness test for Coolant Temperature Sender (B08)
Reference 245-BIF-103, Circuit Test for Hydraulic Oil Temperature Sender (B60)
Operational test for hydraulic oil temperature sender (B60)
Circuit/Harness test for Hydraulic Oil Temperature Sender (B60)
Reference 245-BIF-104, Circuit Test for Engine Oil Pressure Sender (B04)
Operational test for engine oil pressure sender (B04)
Circuit/Harness test for Engine Oil Pressure Sender (B04)
Reference 245-BIF-105, Circuit Test for Transmission Oil Pressure Sender (B31)
Operational test for transmission oil pressure sender (B31)
Circuit/harness test for transmission oil pressure sender (B31)
Reference 245-BIF-106, Circuit Test for Sender (B02; Air Cleaner Restriction Indicator Light)
Operational test for sender (B02; air cleaner restriction indicator light)
Circuit/harness test for sender (B02; air cleaner restriction indicator light)
Reference 245-BIF-107, Circuit Test for Alternator D+ Voltage
Operational test for alternator D+ voltage
Circuit/harness test for alternator D+ voltage
Reference 245-BIF-108, Circuit Test for Sender (B07; Oil Filter Restriction Indicator Light)
Operational test for sender (B07; oil filter restriction indicator light)
Circuit/harness test for sender (B07; oil filter restriction indicator light)
Reference 245-BIF-109, Circuit Test for Restriction Warning Switch at Hydraulic Oil Filter (B111) (AutoPowr/IVT Transmission)
Operational test for restriction warning switch at hydraulic oil filter (B111) (AutoPowr/IVT transmission)
Circuit/harness test for restriction warning switch at hydraulic oil filter (B111)
Reference 245-BIF-110, Circuit Test for Restriction Warning Switch at Hydraulic Oil Filter (B111)
Operational test for restriction switch in hydraulic oil filter (B111)
Reference 245-BIF-200, Theory of Operation
ECU - Engine Control Unit
Reference 245-ECU-001, Calibration and Input Addresses
Reference 245-ECU-100, Diagnosis of Electrical Circuits for Level 1 and Level 4 Engine Control Unit (ECU)
Reference 245-ECU-101, Diagnosis of Electrical Circuits for Level 11 and Level 12 Engine Control Unit (ECU)
Reference 245-ECU-200, Theory of Operation (Level 1)
Reference 245-ECU-201, Theory of Operation (Level 4)
Reference 245-ECU-202, Theory of Operation (Stage II Engines to 97/68/EC; Level 11 with AutoQuad Transmission)
Reference 245-ECU-203, Theory of Operation (Stage II Engines to 97/68/EC; Level 11 with AutoPowr/IVT Transmission)
Reference 245-ECU-204, Theory of Operation (Stage II Engines to 97/68/EC; Level 12)
EPC - Control Unit for PowrQuad Plus and AutoQuad Transmissions
Reference 245-EPC-001, Calibration and Input Addresses
Address EPC 028 - Input address, tractor model
Address EPC 030 — Input address, impulses per engine revolution
Address EPC 033 - Input address, system pressure
Address EPC 035 - Input address, temperature difference where other types of hydraulic oil are used instead of J20C
Address EPC 037 - Input address, for hydraulic oils used as an alternative to J20C
Address EPC 038 - Calibration address, transmission calibration
Address EPC 047 - Input address, automatic deletion of diagnostic trouble codes
Address EPC 134 - Input address, impulses at sending unit for transmission speed (B104)
Address EPC 135 - Input address, transmission function activation
Address EPC 156 - Input address, automatic shifting in reverse travel
Address EPC 157 - Input address, parameters for automatic speed matching
Address EPC 158 - Input address, value for automatic shifting, power mode
Address EPC 160 - Input address, value for automatic shifting, power mode
Address EPC 162 - Input address, value for automatic shifting, ECO mode
Address EPC 164 - Input address, value for automatic shifting, ECO mode
Address EPC 247 - Input address for tractor model designation
Address EPC 248 - Input address for tractor serial number
Reference 245-EPC-100, Pre-Test of EPC Electrical Circuit
Reference 245-EPC-101, Circuit Test for Enable Proportional Solenoid Valve (Y38)
Operational test for enable proportional solenoid valve (Y38)
Circuit/harness test for proportional enable solenoid valve (Y38)
Reference 245-EPC-102, Circuit Test for Forward Solenoid Valve (Y33)
Operational test for circuit of forward solenoid valve (Y33)
Circuit/harness test for forward solenoid valve (Y33)
Reference 245-EPC-103, Circuit Test for Reverse Solenoid Valve (Y36)
Operational test for circuit of reverse solenoid valve (Y36)
Circuit/harness test for reverse solenoid valve (Y36)
Reference 245-EPC-104, Circuit Test for K1 Solenoid Valve (Y40)
Operational test for circuit of K1 solenoid valve (Y40)
Circuit/harness test for K1 solenoid valve (Y40)
Reference 245-EPC-105, Circuit Test for K2 Solenoid Valve (Y39)
Operational test for circuit of K2 solenoid valve (Y39)
Circuit/harness test for K2 solenoid valve (Y39)
Reference 245-EPC-106, Circuit Test for K3 Solenoid Valve (Y32)
Operational test for circuit of K3 solenoid valve (Y32)
Circuit/harness test for K3 solenoid valve (Y32)
Reference 245-EPC-107, Circuit Test for Transmission Speed Sender (B104/1) for 6820 and 6920 Tractors
Operational test for transmission speed sender (B104/1)
Circuit/harness test for transmission speed sender (B104/1)
Reference 245-EPC-108, Circuit Test for Transmission Speed Sender (B104/2) for 6120 - 6620 Tractors
Operational test for transmission speed sender (B104/2)
Circuit/harness test for transmission speed sender (B104/2)
Reference 245-EPC-109, Circuit Test for Enable Pressure Sender (B105)
Operational test for enable pressure sender (B105)
Circuit/harness test for enable pressure sender (B105)
Reference 245-EPC-110, Circuit Test for Clutch Pedal Switch (S72)
Operational test for clutch pedal switch (S72)
Circuit/harness test for clutch pedal switch
Reference 245-EPC-111, Circuit Test for Clutch Pedal Potentiometer (B65)
Operational test for clutch pedal potentiometer (B65)
Circuit/harness test for clutch pedal potentiometer (B65)
Reference 245-EPC-112, Circuit Test for Power/Eco Mode Switch (S85)
Operational test for Power/Eco mode switch (S85)
Circuit/harness test for Power/Eco Mode switch (S85)
Reference 245-EPC-113, Circuit Test for Upshift and Downshift Switches (S48, S49 and S81)
Operational test for upshift and downshift switches (S48 and S49)
Operational test of the rocker switch for upshift/downshift (S81)
Circuit/harness test for upshift and downshift switches (S48, S49 and S81)
Reference 245-EPC-114, Circuit Test for Transmission Enable Relay (K09/5)
Operational test for transmission enable relay (K09/5)
Circuit/harness test for transmission enable relay (K09/5)
Reference 245-EPC-115, Circuit Test for Come-Home Plug (K10/4)
Circuit test for Come-Home plug (K10/4)
Reference 245-EPC-116, Circuit Test for Reverse Drive Lever (A47)
Operational test for reverse drive lever (A47)
Circuit/harness test for forward switch
Circuit/harness test for reverse switch
Circuit/harness test for not-neutral switch
Circuit/harness test for detent coil in reverse drive lever
Reference 245-EPC-117, Circuit Test for Park Switch (S116)
Operational test for park switch (S116)
Circuit/harness test for park switch (S116)
Reference 245-EPC-118, Circuit Test for Power Mode and Eco Mode Indicator Lights
Operational test for Power mode and Eco mode indicator lights (H68 and H75)
Circuit/harness test for Power mode and Eco mode indicator lights (H68 and H75)
Reference 245-EPC-200, Theory of Operation
JDL - Control Unit for JDLink
Reference 245-JDL-001, JDLink Input Addresses
Reference 245-JDL-200 , JDLink - Theory of Operation
JDLink ł Connector Locations
JDLink ł Electrical Schematic
PLC - Park Lock Controller
Reference 245-PLC-001, Calibration and Input Addresses
Address PLC 247 — Input address for tractor model designation
Address PLC 248 — Input address for tractor serial number
Reference 245-PLC-100, Preliminary Check of PLC Circuit
Reference 245-PLC-101, Circuit Test for Park Lock Solenoid Valve (Y15-2)
Operational test for park lock solenoid valve (Y15-2)
Circuit/harness test for park lock solenoid valve (Y15-2)
Reference 245-PLC-102, Circuit Test for Transmission Output Speed Sender (B84)
Operational test for transmission output speed sender (B84)
Circuit/harness test for transmission output speed sender (B84)
Reference 245-PLC-103, Circuit Test for Park Lock Pressure Sender (B90)
Operational test for park lock pressure sender (B90)
Circuit/harness test for park lock pressure sender (B90)
Reference 245-PLC-104, Circuit Test for Acoustic Alarm (K10/2)
Operational test for acoustic alarm (K10/2)
Circuit/harness test for acoustic alarm (K10/2)
Reference 245-PLC-105, Circuit Test for Reverse Drive Lever (S80)
Operational test for reverse drive lever (S80)
Circuit/harness test for neutral, corner park and center park switches
Reference 245-PLC-200, Theory of Operation
PRF - Performance Monitor
Reference 245-PRF-001, Calibration and Input Addresses
Address PRF020 — Data Bus control function
Address PRF022 - Brightness of lighting
Address PRF023 - Setting the implement control arrow
Address PRF060 - Ground speed sensor
Address PRF070 - Diagnostic trouble code control function
Address PRF102 - Parameter for Engine Control Unit (ECU)
Reference 245-PRF-011, Calibration of Ground Speed Sensor (Radar)
Reference 245-PRF-021, Setting Wheel Slip Back to Zero
Reference 245-PRF-101, Circuit Test for Keypad Operation
Operational test of performance monitor
Reference 245-PRF-200, Theory of Operation
SFA - Control Unit for Front-Wheel Drive Axle and Cab Suspension
Reference 245-SFA-001, Calibration and Input Addresses (Front Wheel Drive Axle with TLS)
Address SFA 020 — Calibration address for FWD axle with TLS
Address SFA 033 — Input address, instrument panel (BIF)
Address SFA 035 — Input address, activate/de-activate FWD axle with TLS and cab suspension
Reference 245-SFA-100, Pre-Test of SFA Electrical Circuit
Reference 245-SFA-101, Circuit Test for Front-Wheel Drive Axle Solenoid Valves Y10 and Y11
Operational test for solenoid valves Y10 and Y11
Circuit/harness test for TLS solenoid valve (Y10)
Circuit/harness test for TLS solenoid valve (Y11)
Reference 245-SFA-102, Circuit Test for Cab Suspension Solenoid Valves Y42 and Y43
Operational test for solenoid valves Y42 and Y43
Circuit/harness test for cab solenoid valve (Y42)
Circuit/harness test for cab solenoid valve (Y43)
Reference 245-SFA-103, Circuit Test for TLS Position Sensor (B53)
Operational test for circuit of TLS position sensor (B53)
Circuit/harness test for TLS position sensor (B53)
Reference 245-SFA-104, Circuit Test for Cab Position Sensor (B110)
Operational test for circuit of cab position sensor (B110)
Circuit/harness test for cab position sensor (B110)
Reference 245-SFA-200, Theory of Operation
SIC - E-SCV/E-ICV Controller
Reference 245-SIC-001, Calibration and Input Addresses
Address SIC 020 - Calibration of selective control valves (E-SCV and E-ICV)
Address SIC 033 - Input address for instrument unit
Address SIC 036 - Activate input address for functions 1 to 3, Independent Selective Control Valve (E-ICV)
Address SIC 037 - Activate input address for functions 4 to 6, Selective Control Valves (E-ICV) No. 1 to 3
Address SIC 038 - Activate input address for function 7, Selective Control Valve (E-SCV) No. 4
Address SIC 039 - Input address for vibrator function of front loader bucket (E-ICV)
Address SIC 040 - Calibration for stepper motor identification
Address SIC 045 - Input address, automatic deletion of diagnostic trouble codes
Address SIC 247 - Input address for tractor model designation
Address SIC 248 - Input address for tractor serial number
Reference 245-SIC-100, Preliminary Check of SIC Circuit
Reference 245-SIC-101, Circuit Test for Multi-Function Lever (S64)
Operational test for multi-function lever (S64)
Circuit/harness test for function 1 (E-ICV)
Circuit/harness test for function 2 (E-ICV)
Circuit/harness test for function 3 (E-ICV)
Reference 245-SIC-102, Circuit Test for E-ICV Transport Lock Switch (S65)
Operational test for E-ICV transport lock switch (S65)
Circuit/harness test for E-ICV transport lock (S65)
Reference 245-SIC-103, Circuit Test for E-ICV Safety Switch (Integrated into S64)
Operational test for E-ICV safety switch (interlock switch actuator)
Circuit/harness test for E-ICV safety switch
Reference 245-SIC-104, Circuit Test for E-ICV no.1 Stepper Motor (M12)
Circuit/harness test for E-ICV no.1 stepper motor (M12), power supply
Circuit/harness test for CAN bus lines for no.1 stepper motor E-ICV (M12)
Reference 245-SIC-105, Circuit Test for E-ICV no.2 Stepper Motor (M13)
Circuit/harness test for E-ICV no.2 stepper motor (M13), power supply
Circuit/harness test for CAN bus lines for no.2 stepper motor E-ICV (M13)
Reference 245-SIC-106, Circuit Test for E-ICV no.3 Stepper Motor (M14)
Circuit/harness test for E-ICV no.3 stepper motor (M14), power supply
Circuit/harness test for CAN bus lines for no.3 stepper motor E-ICV (M14)
Reference 245-SIC-107, Circuit Test for E-SCV no.1, Potentiometer or Switch at Control Lever is Faulty
Operational test for E- SCV no.1, control lever's switch/potentiometer
Circuit/harness test for E-SCV no.1 (control lever's switch/potentiometer)
Reference 245-SIC-108, Circuit Test for E-SCV no.2, Potentiometer or Switch at Control Lever is Faulty
Operational test for E- SCV no.2, control lever's switch/potentiometer
Circuit/harness test for E-SCV no.2 (control lever's switch/potentiometer)
Reference 245-SIC-109, Circuit Test for E-SCV no.3, Potentiometer or Switch at Control Lever is Faulty
Operational test for E- SCV no.3, control lever's switch/potentiometer
Circuit/harness test for E-SCV no.3 (control lever's switch/potentiometer)
Reference 245-SIC-110, Circuit Test for E-SCV no.4, Potentiometer or Switch at Control Lever is Faulty
Operational test for E- SCV no.4, control lever's switch/potentiometer
Circuit/harness test for E-SCV no.4 (control lever's switch/potentiometer)
Reference 245-SIC-111, Circuit Test for E-SCV Transport Lock Switch (S110)
Operational test for E-SCV transport lock switch (S110)
Circuit/harness test for E-SCV transport lock (S110)
Reference 245-SIC-112, Circuit Test for E-SCV Function Adjustment Knob (B115)
Operational test for E-SCV function adjustment knob (B115)
Circuit/harness test for E-SCV function adjustment knob (B115)
Reference 245-SIC-113, Circuit Test for E-SCV no.1 Stepper Motor (M36)
Circuit/harness test for E-SCV no.1 stepper motor (M36), power supply
Circuit/harness test for CAN bus lines for no.1 stepper motor E-SCV (M36)
Reference 245-SIC-114, Circuit Test for E-SCV no.2 Stepper Motor (M37)
Circuit/harness test for E-SCV no.2 stepper motor (M37), power supply.
Circuit/harness test for CAN bus lines for no.2 stepper motor E-SCV (M37)
Reference 245-SIC-115, Circuit Test for E-SCV no.3 Stepper Motor (M38)
Circuit/harness test for E-SCV no.3 stepper motor (M38), power supply
Circuit/harness test for CAN bus lines for no.3 stepper motor E-SCV (M38)
Reference 245-SIC-116, Circuit Test for E-SCV no.4 Stepper Motor (M39)
Circuit/harness test for E-SCV no.4 stepper motor (M39), power supply
Circuit/harness test for CAN bus lines for no.4 stepper motor E-SCV (M39)
245-SIC-200, Theory of Operation
TCU - Control Unit for AutoPowr/IVT Transmission
Reference 245-TCU-001, Calibration and Input Addresses
Address TCU 20 — Transmission Calibration
Address TCU 25 — Vacant Input Address
Address TCU 26 — Vacant Input Address
Address TCU 44 — Input Address for Tractor Type
Address TCU 49 — Input addresses for output test mode
Reference 245-TCU-001A, Output Test Mode Chart
Reference 245-TCU-100, Preliminary Check of TCU Circuit
Reference 245-TCU-101, Circuit Test for Transmission Enable Signal from Relay K02/1 and Clutch Pedal Switch (S72)
Operational test for transmission enable signal from relay K02/1
Circuit/harness test for transmission enable signal from relay K02/1 and clutch pedal switch S72
Reference 245-TCU-102, Circuit Test for Oil Temperature Sender
Operational test for oil temperature sender
Circuit/harness test for oil temperature sender
Reference 245-TCU-103, Circuit Test for Transmission Oil Filter Switch (S73)
Operational test for transmission oil filter switch (S73)
Circuit/harness test for transmission oil filter switch (S73)
Reference 245-TCU-104, Circuit Test for Transmission Oil Pressure Switch (S74)
Operational test for transmission oil pressure switch (S74)
Circuit/harness test for transmission oil pressure switch (S74)
Reference 245-TCU-105, Circuit Test for Switch (B87) of Filter By-Pass Valve (Cold-Weather Starting)
Operational test for switch (B87) of filter by-pass valve (cold-weather starting)
Circuit/harness test for switch (B87) of filter by-pass valve (cold-weather starting).
Reference 245-TCU-106, Circuit Test for Transmission Input Speed Sender (B61)
Operational test for transmission input speed sender (B61)
Circuit/harness test for transmission input speed sender (B61)
Reference 245-TCU-107, Circuit Test for Transmission Output Speed Sender (B63)
Operational test for transmission output speed sender (B63)
Circuit/harness test for transmission output speed sender (B63)
Reference 245-TCU-108, Circuit Test for Hydrostatic Speed Sender (B62)
Operational test for hydrostatic speed sender (B62)
Circuit/harness test for hydrostatic speed sender (B62)
Reference 245-TCU-109, Circuit Test for Park Lock Solenoid Valve (Y15-1)
Operational test for park lock solenoid valve (Y15-1)
Circuit/harness test for park lock solenoid valve (Y15-1)
Reference 245-TCU-110, Circuit Test for C1 Solenoid Valve
Operational test for C1 solenoid valve
Circuit/harness test for C1 solenoid valve
Reference 245-TCU-111, Circuit Test for C2 Solenoid Valve
Operational test for C2 solenoid valve
Circuit/harness test for C2 solenoid valve
Reference 245-TCU-112, Circuit Test for C3 Solenoid Valve
Operational test for C3 solenoid valve
Circuit/harness test for C3 solenoid valve
Reference 245-TCU-113, Circuit Test for C4 Solenoid Valve
Operational test for C4 solenoid valve
Circuit/harness test for C4 solenoid valve
Reference 245-TCU-114, Circuit Test for BG Solenoid Valve
Operational test for BG solenoid valve
Circuit/harness test for BG solenoid valve
Reference 245-TCU-115, Circuit Test for Hydrostatic Unit Proportional Solenoid Valve (Y1)
Operational test for hydrostatic unit proportional solenoid valve (Y1)
Circuit/harness test for hydrostatic unit proportional solenoid valve (Y1)
Reference 245-TCU-116, Circuit Test for Hydrostatic Unit Proportional Solenoid Valve (Y2)
Operational test for hydrostatic unit proportional solenoid valve (Y2)
Circuit/harness test for hydrostatic unit proportional solenoid valve (Y2)
Reference 245-TCU-117, Circuit Test for CF Proportional Solenoid Valve of the Forward Clutch
Operational test for CF proportional solenoid valve of the forward clutch
Circuit/harness test for CF proportional solenoid valve of the forward clutch.
Reference 245-TCU-118, Circuit Test for CR Proportional Solenoid Valve of the Reverse Clutch
Operational test for CR proportional solenoid valve of the reverse clutch
Circuit/harness test for CR proportional solenoid valve of the reverse clutch
Reference 245-TCU-200, Theory of Operation
UIC - User Interface Controller
Reference 245-UIC-001, Calibration and Input Addresses
Address UIC 32 — Input address for anti-jack-knife control and front axle brake
Address UIC 33 — Input address for engine type (only with Stage II engine to 97/68/EC)
Address UIC 34 — Input address for speed displayed in km/h or mph
Address UIC 35 — Input address for automatic deletion of diagnostic trouble codes (Auto Purge)
Address UIC 36 — Input address for tractor type
Address UIC 42 — Input addresses for tire size (rolling radius)
Address UIC 43 — Input address for transmission ratio of front-wheel drive axle
Address UIC 49 — Input address for output test mode (enable relay)
Address UIC 247 — Input address for tractor model designation
Address UIC 248 — Input address for tractor serial number
Reference 245-UIC-100, Preliminary Check of UIC Circuit
Reference 245-UIC-101, Circuit Test for Reverse Drive Lever (S80)
Circuit/harness test, switches for forward travel, tractor movement and Power Zero
Circuit/harness test, switches for reverse travel, tractor movement and Power Zero
Reference 245-UIC-102, Circuit Test for Cruise Control Potentiometer (A19)
Operational test for cruise control potentiometer (A19)
Circuit/harness test for cruise control potentiometer (A19)
Reference 245-UIC-103, Circuit Test for AutoPowr Selector (B83)
Operational test for AutoPowr selector (B83)
Circuit/harness test for AutoPowr selector (B83)
Reference 245-UIC-104, Circuit Test for Speed Wheel on Speed Control Lever (S108)
Operational test for speed wheel
Circuit/harness test for speed wheel
Reference 245-UIC-105, Circuit Test for Speed Control Lever (S108 and B67)
Operational test for speed control lever (set speeds 1 and 2)
Circuit/harness test for Hall-type switch for speed control lever (S108)
Circuit/harness test for Hall-type potentiometer for speed control lever (B67)
Reference 245-UIC-106, Circuit Test for Hand Throttle Potentiometer (B78)
Operational test for hand throttle potentiometer (B78)
Circuit/harness test for hand throttle potentiometer (B78)
Reference 245-UIC-107, Circuit Test for Accelerator Pedal Potentiometer (B79)
Operational test for accelerator pedal potentiometer (B79)
Circuit/harness test for accelerator pedal potentiometer (B79)
Reference 245-UIC-108, Circuit Test for Brake Pedal Sensors (B88)
Operational test for brake pedal sensors (B88)
Circuit/harness test for brake pedal switches (B88)
Circuit/harness test for brake pedal potentiometers (B88)
Reference 245-UIC-109, Circuit Test for Clutch Pedal Potentiometer (B65)
Operational test for clutch pedal sensors (B65 and S72)
Reference 245-UIC-110, Circuit Test for Front-Wheel Drive Axle Speed Sender (B89)
Operational test for front-wheel drive axle speed sender (B89)
Circuit/harness test for front-wheel drive axle speed sender (B89)
Reference 245-UIC-111, Circuit Test for Air Brake Solenoid Valve (Y31)
Operational test for air brake solenoid valve (Y31)
Reference 245-UIC-112, Circuit Test for Seat Switch (S40)
Operational test for seat switch (S40)
Circuit/harness test for seat switch (S40)
Reference 245-UIC-113, Circuit Test for Come-Home Plug (K10/4)
Operational test for Come-Home plug (K10/4)
Reference 245-UIC-200, Theory of Operation
SYNCROPLUS TRANSMISSION
Introductory Checks
Reference 250-05-001, Introductory Checks for Transmission and Hydraulic Diagnosis
Introductory Checks
Reference 250-10-001, Syncroplus Transmission—Operational Checkout
Operational Checks
Reference 250-15-001, Syncroplus Transmission—System Check
System Check
Reference 250-15-002, Syncroplus Transmission—Checking System Pressure
Reference 250-15-003, Syncroplus Transmission—Adjusting System Pressure
Reference 250-15-004, Syncroplus Transmission—Checking Components Dependent on System Pressure
Reference 250-15-005, Syncroplus Transmission—Checking the Filter Relief Valve
Reference 250-15-006, Syncroplus Transmission—Checking the Engagement Override Valve and Clutch Pedal Valve
Reference 250-15-007, Syncroplus Transmission—Checking the Modulation of the Clutch Pedal Valve
Reference 250-15-008, Syncroplus Transmission—Checking the Lube Oil Pressure
Reference 250-15-009, Syncroplus Transmission—Checking the Cooling System
Reference 250-15-010, Syncroplus Transmission—Checking the Rate of Flow
Reference 250-15-011, Syncroplus Transmission—Checking the Cooler Relief Valve
Reference 250-15-012, Syncroplus Transmission—Checking the Transmission Oil Filter
Reference 250-15-013, Syncroplus Transmission—Layout of Test Ports and Sending Units
Reference 250-15-014, Syncroplus Transmission—Checking and Adjusting the Shift Units
Reference 250-15-015, Syncroplus Transmission—Adjusting the Park Lock
Reference 250-15-016, Syncroplus Transmission—Checking and Adjusting the Linkage on the Range Transmission
Reference 250-15-017, Syncroplus Transmission—Checking and Adjusting the Linkage on the Gear Transmission
Reference 250-15-018, Syncroplus Transmission—Checking and Adjusting the Neutral Start Switch
Reference 250-15-019, Syncroplus Transmission—Adjusting the Clutch Pedal
Operation
Reference 250-20-001, Syncroplus Transmission—Summary of References
Reference 250-20-010, Syncroplus Transmission—Layout
Reference 250-20-020, Syncroplus Transmission—Lubrication System
Reference 250-20-030, Syncroplus Transmission—Shift Linkage
Reference 250-20-040, Syncroplus Transmission—Synchronization
Reference 250-20-050, Syncroplus Transmission—Operation of Transmission Oil Circuit (including Diagram)
Reference 250-20-100, Perma Clutch II Module—Exploded View
Reference 250-20-110, Perma Clutch II Module—Layout
Reference 250-20-120, Perma Clutch II Module—Powerflow
Reference 250-20-130, Perma Clutch II Module—Transmission Oil Pump
Reference 250-20-140, Perma Clutch II Module—Hydraulic Circuit Diagram
Reference 250-20-150, Perma Clutch II Module—Description of Various Valves and Components
Reference 250-20-160, Perma Clutch II Module—Operation of Pressure Regulating Valve and Filter Relief Valve
Reference 250-20-170, Perma Clutch II Module—Operation of Clutch Pedal Valve and Engagement Override Valve
Reference 250-20-180, Perma Clutch II Module—Operation of Cooling System
Reference 250-20-200, Gear Transmission—Layout
Reference 250-20-210, Gear Transmission— Powerflow
Reference 250-20-220, Gear Transmission— Neutral Start Switch
Reference 250-20-300, Creeper Transmission— Layout and Operation
Reference 250-20-310, Creeper Transmission— Powerflow
POWER REVERSER
Reference 251-10-001, Power Reverser—Operational Checkout
Reference 251-15-001, Power Reverser—System Check
Reference 251-15-002, Power Reverser—Checking System Pressure
Reference 251-15-003, Power Reverser—Adjusting System Pressure
Reference 251-15-004, Power Reverser—Checking Components Dependent on System Pressure
Reference 251-15-005, Power Reverser—Checking the Filter Relief Valve
Reference 251-15-006, Power Reverser—Checking and Adjusting the Engagement Override Valve and Clutch Pedal Valve
Reference 251-15-007, Power Reverser—Checking the Disk Clutch and Disk Brake
Reference 251-15-008, Power Reverser—Checking the Lube Oil Pressure
Reference 251-15-009, Power Reverser—Checking the Cooling System
Reference 251-15-010, Power Reverser—Checking the Rate of Flow
Reference 251-15-011, Power Reverser—Checking the Cooler Relief Valve
Reference 251-15-012, Power Reverser—Checking the Transmission Oil Filter
Reference 251-15-013, Power Reverser—Adjusting the Modulation Time
Reference 251-15-014, Power Reverser—Layout of Test Ports and Sending Units
Reference 251-15-015, Power Reverser—Checking and Adjusting the Shift Units
Reference 251-15-016, Power Reverser—Adjusting the Park Lock
Reference 251-15-017, Power Reverser—Checking and Adjusting the Shift Linkage at the Range Transmission
Reference 251-15-018, Power Reverser—Checking and Adjusting the Shift Linkage at the Gear Transmission
Reference 251-15-019, Power Reverser—Adjusting the Reverse Drive Linkage
Reference 251-15-020, Power Reverser—Adjusting the Reverse Drive Lever
Reference 251-15-021, Power Reverser—Adjusting the Clutch Pedal
Reference 251-20-001, Power Reverser—Summary of References
Reference 251-20-010, Power Reverser—Layout
Reference 251-20-020, Power Reverser—Lubrication System
Reference 251-20-030, Power Reverser—Shift Linkage
Reference 251-20-040, Power Reverser—Synchronization
Reference 251-20-050, Power Reverser—Operation of Transmission Oil Circuit (including Diagram)
Reference 251-20-100, Power Reverser Module—Sectional View
Reference 251-20-110, Power Reverser Module—Components
Reference 251-20-120, Power Reverser Module—Layout and Powerflow
Reference 251-20-130, Power Reverser Module—Transmission Oil Pump
Reference 251-20-140, Power Reverser Module—Valves and Other Hydraulic Components
Reference 251-20-150, Power Reverser Module—Hydraulic Circuit Diagram
Reference 251-20-160, Power Reverser Module—Description of Various Valves and Components
Reference 251-20-170, Power Reverser Module—Operation of Pressure Regulating Valve and Filter Relief Valve
Reference 251-20-180, Power Reverser Module—Operation of Forward/Reverse Modulation
Reference 251-20-190, Power Reverser Module—Operation of Clutch Pedal Valve
Reference 251-20-200, Power Reverser Module—Operation of Engagement Override Valve
Reference 251-20-210, Power Reverser Module—Operation of Cooling System
Reference 251-20-300—Gear Transmission, Layout and Powerflow
AUTOPOWR/IVT TRANSMISSION
Reference 253-10-001, AutoPowr/IVT Transmission—Operational Checkout
Operational Checks
Reference 253-15-001, AutoPowr/IVT Transmission — Test Result Table
Reference 253-15-002, AutoPowr/IVT Transmission — Checking the Transmission Oil Circuit
Reference 253-15-005, AutoPowr/IVT Transmission — Test Ports (6320 to 6620)
Reference 253-15-006, AutoPowr/IVT Transmission — Test Ports (6820 and 6920)
Reference 253-15-010, AutoPowr/IVT Transmission — Checking System Pressure
Reference 253-15-011, AutoPowr/IVT Transmission — Checking Reduced System Pressure (Pressure for Other Consumers)
Reference 253-15-012, AutoPowr/IVT Transmission — Checking Oil Cooler Pressure
Reference 253-15-013, AutoPowr/IVT Transmission — Checking Lube Oil Pressure
Reference 253-15-014, AutoPowr/IVT Transmission — Checking Pressure at the C1 Clutch
Reference 253-15-015, AutoPowr/IVT Transmission — Checking Pressure at the C2 Clutch
Reference 253-15-016, AutoPowr/IVT Transmission — Checking Pressure at the C3 Clutch
Reference 253-15-017, AutoPowr/IVT Transmission — Checking Pressure at the C4 Clutch
Reference 253-15-018, AutoPowr/IVT Transmission — Checking Pressure at the BG Disk Brake
Reference 253-15-019, AutoPowr/IVT Transmission — Checking Pressure at the Forward Clutch (CF)
Reference 253-15-020, AutoPowr/IVT Transmission — Checking Pressure at the Reverse Clutch (CR)
Reference 253-15-021, AutoPowr/IVT Transmission — Checking Park Lock Pressure
Reference 253-20-001, AutoPowr/IVT Transmission — Operation (Summary of References)
Reference 253-20-010, AutoPowr/IVT Transmission — Operation
Reference 253-20-011, AutoPowr/IVT Transmission — Layout of Transmission Sub-Assembly
Reference 253-20-012, AutoPowr/IVT Transmission — Sectional View of Transmission
Reference 253-20-013, AutoPowr/IVT Transmission — Transmission Peripherals
Reference 253-20-014, AutoPowr/IVT Transmission — Transmission Control Components
Reference 253-20-015, AutoPowr/IVT Transmission — Transmission Control
Reference 253-20-016, AutoPowr/IVT Transmission — Description of Transmission Oil Circuit
Reference 253-20-017, AutoPowr/IVT Transmission — Description of System Pressure Control Block
Reference 253-20-018, AutoPowr/IVT Transmission — Description of Clutch Control Block
Reference 253-20-019, AutoPowr/IVT Transmission — Operation of Hydrostatic Unit
Reference 253-20-020, AutoPowr/IVT Transmission — Diagram of Transmission
Reference 253-20-021, AutoPowr/IVT Transmission — Summary of Engaged Elements
Reference 253-20-022, AutoPowr/IVT Transmission — Power Flows
Reference 253-20-023, AutoPowr/IVT Transmission — Oil Flows
Reference 253-20-024, AutoPowr/IVT Transmission — Operation of Park Lock
Reference 253-20-025, AutoPowr/IVT Transmission — Shift Controls
POWRQUAD, POWRQUAD PLUS AND AUTOQUAD TRANSMISSIONS
Reference 255-10-001, PowrQuad Transmission—Operational Checkout
Operational Check
Reference 255-15-001, PowrQuad Transmission—System Check
System check
Reference 255-15-002, PowrQuad Transmission—Test Ports
Reference 255-15-003, PowrQuad Transmission—Checking Rate of Flow at Cooler
Reference 255-15-004, PowrQuad Transmission—Checking System Pressure
Reference 255-15-005, PowrQuad Transmission—Checking Lube Oil Pressure
Reference 255-15-006, PowrQuad Transmission—Checking Cooling Oil Pressure (Forward Clutch)
Reference 255-15-007, PowrQuad Transmission—Checking Cooling Oil Pressure (Reverse Brake)
Reference 255-15-008, PowrQuad Transmission—Checking Pressure at Forward Clutch
Reference 255-15-009, PowrQuad Transmission—Checking Pressure at Reverse Brake
Reference 255-15-010, PowrQuad Transmission—Checking Pressure at B1 Brake
Reference 255-15-011, PowrQuad Transmission—Checking Pressure at B2 Brake
Reference 255-15-012, PowrQuad Transmission—Checking Pressure at B3 Brake
Reference 255-15-013, PowrQuad Transmission—Checking Pressure at C4 Clutch
Reference 255-15-014, PowrQuad Transmission—Adjusting System Pressure
Reference 255-15-015, PowrQuad Transmission—Test Result Table
Reference 255-15-016, PowrQuad Transmission—Adjusting the Reverse Drive Linkage
Reference 255-15-017, PowrQuad Transmission—Shift Linkage and Park Lock
Reference 255-15-018, Adjusting the Reverse Drive Lever (Reverser Control on Steering Column)
Reference 255-15-019, Checking and Adjusting the Shift Mechanisms/Linkages (PowrQuad Plus & AutoQuad Transm.)
Reference 255-20-001, PowrQuad, PowrQuad Plus and AutoQuad Transmissions—Summary of References
Reference 255-20-050, PowrQuad Transmission—Layout
Reference 255-20-100, PowrQuad Module—Layout
Reference 255-20-280, PowrQuad Module—Sectional and 3D View
Reference 255-20-290, PowrQuad Module—Location of Valves, Sensors and Switches
Reference 255-20-110, PowrQuad Module—Element Engagement Chart
Reference 255-20-120, PowrQuad Module—Pneumatic Pump
Reference 255-20-130, PowrQuad Module—Transmission Oil Pump
Reference 255-20-140, PowrQuad Module—Pressure-Regulating Valve and Filter Relief Valve
Reference 255-20-150, PowrQuad Module—Overspeed Relief Valve and Anti-Cavitation Check Valve
Reference 255-20-160, PowrQuad Module—Clutch Cooling Components
Reference 255-20-170, PowrQuad Module—Clutch Cooling Valve (Forward/Reverse)
Reference 255-20-180, PowrQuad Module—System 1 Oil and System 2 Oil
Reference 255-20-190, PowrQuad Module—Hydraulic Schematic, Mechanically Actuated PowrQuad Module
255-20-200, PowrQuad Module—Operation of Forward/Reverse Modulation, Mechanically Actuated PowrQuad Module
Reference 255-20-210, PowrQuad Module—Neutral Start Circuit, Mechanically Actuated PowrQuad Module
Reference 255-20-220, PowrQuad Module—Operation of Gear-to-Gear Modulation, Mechanically Actuated PowrQuad Module
Reference 255-20-230, PowrQuad Module—Hydraulic Schematic, Electrically Actuated PowrQuad Module
Reference 255-20-240, PowrQuad Module—Operation of Forward/Reverse Modulation, Electrically Actuated PowrQuad Module
Reference 255-20-250, PowrQuad Module—Operation of Gear-to-Gear Modulation, Electrically Actuated PowrQuad Module
Reference 255-20-260, PowrQuad Module—Reverse Drive Lever and Gear Shift Lever, Mechanically Actuated PowrQuad Module
Reference 255-20-270, PowrQuad Module—Reverse Drive Lever and Range Shift Lever with Gearshift Switches, Electrically Actuated PowrQuad Module
Reference 255-20-400, PowrQuad Plus and AutoQuad Transmissions—Summary of Transmission Versions
Reference 255-20-410, PowrQuad Plus and AutoQuad Transmissions—Sub-Assemblies
Reference 255-20-420, PowrQuad Plus Transmission—Description of Shift Functions
Reference 255-20-430, AutoQuad Transmission—Description of Shift Functions
Reference 255-20-440, PowrQuad Plus and AutoQuad Transmissions—Description of Clutch Actuation
Reference 255-20-500—Range Transmission (6020-6620 Tractors), Layout
Reference 255-20-510—Range Transmission (6020-6620 Tractors), Power-Flows
Reference 255-20-520—Range Transmission, Park Lock (6020-6620 Tractors)
Reference 255-20-530, Range Transmission (6820 and 6920 Tractors)—Layout
Reference 255-20-700, Creeper Transmission (6020-6620 Tractors)—Operation
Reference 255-20-710, Creeper Transmission (6020-6620 Tractors)—Powerflow
Reference 255-20-720, Creeper Transmission (6820 and 6920 Tractors)—Operation
DRIVE SYSTEMS
Reference 256-10-001, Drive Systems—Operational Check
Operational check
Reference 256-15-001, Drive Systems—System Check
Reference 256-15-002, Checking Pressure at the Front-Wheel Drive Clutch
Reference 256-15-003, Checking Pressure at the Hydraulic Differential Lock
Reference 256-15-004, Checking Pressure at the Rear PTO
Reference 256-15-005, Checking Pressure at the Front PTO
Reference 256-15-006, Drive Systems—Test Result Table
Reference 256-15-007, Front PTO—Adjusting System Pressure
Reference 256-20-001, Drive Systems—Summary of References
Reference 256-20-100, Front-Wheel Drive Clutch (6020 to 6620 Tractors)—Layout
Reference 256-20-110, Front-Wheel Drive Clutch (6020 to 6620 Tractors)—Oil-Flow and Power-Flow
Reference 256-20-120, Front-Wheel Drive Clutch (6020 to 6620 Tractors)—Cooling and Lubrication
Reference 256-20-130, Front-Wheel Drive Clutch (6820 and 6920 Tractors)—Layout
Reference 256-20-140, Front-Wheel Drive Clutch (6820 and 6920 Tractors)—Oil-Flow and Power-Flow
Reference 256-20-200, Differential (6020 to 6620 Tractors)—Layout
Reference 256-20-210, Differential (6820 and 6920 Tractors)—Layout
Reference 256-20-220, Differential—Power-Flows
Reference 256-20-230, Differential—Oil-Flows
Reference 256-20-300, Final Drives (6020 to 6620 Tractors)—Operation and Layout
Reference 256-20-310, Final Drives (6820 and 6920 Tractors)—Operation and Layout
Reference 256-20-400, Rear PTO Options—Description
Reference 256-20-410, Rear PTO Options—PTO Modulating Valve and Solenoid Valve
Reference 256-20-420, Rear PTO Options—PTO Clutch and PTO Brake
Reference 256-20-430, Rear PTO Options (6820 and 6920 Tractors)—Lube Cut-Off Valve
Reference 256-20-440, Rear PTO Options—Power-Flows
Reference 256-20-500, Front PTO Options—Operation
Reference 256-20-510, Front PTO Options—Description, Hydraulic Circuit
Reference 256-20-520, Front PTO Options—PTO Modulating Valve and Solenoid Valve
Reference 256-20-530, Front PTO Options—Hydraulic Pump
Reference 256-20-540, Front PTO Options—Oil Cooler
STEERING AND BRAKES
Reference 260-10-001, Safety Information
Reference 260-10-010, Steering Check
Reference 260-10-010, Brake Check
Reference 260-15-001, Tests and Adjustments—Summary of References
Reference 260-15-010, Special Tools
Reference 260-15-020, Connecting SensoControl Test Equipment
Reference 260-15-030, Specifications
Reference 260-15-040, Checking the Steering Valve
Reference 260-15-050, Checking the Brake System
Reference 260-15-060, Bleeding the Brakes (Brake Valve, Power-Fill Brakes and MFWD and Disk Brake)
Reference 260-15-070, Adjusting the Brake Pedals and Switches
Reference 260-15-080, Handbrake Checks
Reference 260-15-090, Checking the Trailer Brake Valve
Reference 260-15-100, Adjusting the Trailer Brake Valve
Reference 260-15-110, Checking the Air Brake (Visual Inspection)
Reference 260-15-120, Checking the System for Leaks
Reference 260-15-130, Checking the "Supply" Coupling End
Reference 260-15-140, Checking the Pressure Limiting Valve (Tractors with MFWD and Disk Brake)
Reference 260-15-150, Checking the Dual-Line Brake Valve
Reference 260-15-160, Checking the Single-Line Brake Valve
Reference 260-15-170, Adjusting the Handbrake and Air Brakes
Reference 260-20-001, Operation — Summary of References
Reference 260-20-010, Description of Steering Valves, Operation
Reference 260-20-020, Brake Valve (with Power Fill), Operation
Reference 260-20-030, Brake Valve (with MFWD and Disk Brakes), Operation
Reference 260-20-040, Rear Wheel Brakes, Operation
Reference 260-20-050, Handbrake, Description
Reference 260-20-060, Trailer Brake Valve, Description
260-20-080, Description of Air Brake System
HYDRAULIC SYSTEM
270-10-010, Hydraulic System Load Check
Reference 270-10-020, Hitch Control - Operational Checkout
Reference 270-10-030, External Control of Hitch - Operational Checkout
Reference 270-10-040, Selective Control Valves - Operational Checkout
Reference 270-15-001, Safety Measures for Hydraulic Checks
Reference 270-15-010, Heating Up Hydraulic Oil
Reference 270-15-011, Hydraulic System — Oil Pressure Test Ports
Reference 270-15-012, Checking the PFC Hydraulic System
Reference 270-15-013, PFC Hydraulic System — Test Result Table
Reference 270-15-020, Checking the PC Hydraulic System
Reference 270-15-021, PC Hydraulic System — Test Result Table
Reference 270-15-030, Charge Pump — Checking Lube Oil Pressure
Reference 270-15-031, Charge Pump — Checking the Delivery Rate
Reference 270-15-050, Hydraulic Pump — Testing and Adjusting the System Pressure (PFC Hydraulic System)
Reference 270-15-051, Hydraulic Pump — Checking the Delivery Rate (PFC Hydraulic System)
Reference 270-15-052, Hydraulic Pump—Checking the Delivery Rate (PC Hydraulic System)
Reference 270-15-053, Hydraulic Pump — Checking the Pressure-and-Flow Regulator
Reference 270-15-070, Checking the Pressure Differential Dynamically (PFC Hydraulic System Only)
Reference 270-15-071, Checking the LS (Load-Sensing) Pressure
Reference 270-15-090, Selective Control Valves — Check for Leaks at Valve Spools (PFC Hydraulic System Only)
Reference 270-15-091, Selective Control Valves (SCV) — Checking for Leaks in Couplers
Reference 270-15-092, 300 and 301 Series Selective Control Valves—Adjust Detent Kickout Relief Valve Parts
Reference 270-15-093, Selective Control Valves—Adjusting Left Endplate With Additional LS Port For External Consumers
Reference 270-15-094, Selective Control Valves—Adjusting Right Endplate With Additional Ports For External Consumers
Reference 270-15-110, Checking the Stepper Motor and Rockshaft Valve
Reference 270-15-130, Rockshaft Valve — Checking for Leaks
Reference 270-15-131, Rockshaft Valve — Checking the Pressure-Relief Valve
Reference 270-15-132, Rockshaft Valve — Checking Depth to Which Pressure and Discharge Valves are Screwed In
Reference 270-15-150, Rockshaft Valve — Checking the Position Sensor
Reference 270-15-151, Rockshaft—Testing and Adjusting the Draft Sensors (6020 to 6620)
Reference 270-15-152, Rockshaft — Testing and Adjusting the Draft Potentiometer (6820 to 6920S)
Reference 270-15-170, Adjusting the Power Beyond Valve
Reference 270-20-001, PFC Hydraulic System—Summary of References
Reference 270-20-002, PC Hydraulic System—Summary of References
Reference 270-20-010, PFC Hydraulic System — Description
Reference 270-20-020, PFC Hydraulic System—Operation
Reference 270-20-030, PFC Hydraulic System—Symbolic Representation
Reference 270-20-040, PFC Hydraulic System—Schematic View
Reference 270-20-050, PFC Hydraulic System — Three-Dimensional View
Reference 270-20-060, PC Hydraulic System—Description
Reference 270-20-070, PC Hydraulic System—Operation
Reference 270-20-080, PC Hydraulic System—Symbolic Representation
Reference 270-20-090, PC Hydraulic System—Schematic View
Reference 270-20-100, PC Hydraulic System—Three-Dimensional View
Reference 270-20-110, PFC Hydraulic System — Charge Pump, Description and Operation
Reference 270-20-120, PFC Hydraulic System—Description of Hydraulic Pump
Reference 270-20-130, PFC Hydraulic System—Oil Lines of Hydraulic Pump
Reference 270-20-140, PFC Hydraulic System — Operation of Hydraulic Pump
Reference 270-20-150, PFC Hydraulic System—Hydraulic Pump Operating Modes
Reference 270-20-160, PC Hydraulic System—Description of Hydraulic Pump
Reference 270-20-170, PC Hydraulic System—Oil Lines of Hydraulic Pump
Reference 270-20-180, PC Hydraulic System—Operation of Hydraulic Pump
270-20-190, Primary Hydraulic Oil Filter — Description
Reference 270-20-200, Hydraulic Oil Cooler — Description
Reference 270-20-210, PFC Hydraulic System—Description of Hydraulic Oil Filter
Reference 270-20-220, PC Hydraulic System—Description of Hydraulic Oil Filter
Reference 270-20-230, PC Hydraulic System—Description of Lube Priority Valve
Reference 270-20-240, PFC Hydraulic System—Description and Arrangement of Shuttle Valves
Reference 270-20-250, PFC Hydraulic System — Operation of Shuttle Valves
Reference 270-20-260, PC Hydraulic System—Description and Arrangement of Shuttle Valves
Reference 270-20-270, PFC Hydraulic System—Description of Main Block with Priority Valve
Reference 270-20-280, PFC Hydraulic System — Operation of Priority Valve in Main Block
Reference 270-20-290, PC Hydraulic System—Description of Main Block with Priority Valve and By-Pass Valve
Reference 270-20-300, PC Hydraulic System—Operation of Priority Valve and By-Pass Valve
Reference 270-20-310, Power Beyond Valve — Operation
Reference 270-20-320, Rockshaft — Description
Reference 270-20-330, Rockshaft — Operation of Rockshaft Control
Reference 270-20-340, Rockshaft — Operation of Rockshaft Valve
Reference 270-20-350, Rockshaft — Operation of Position Sensor
Reference 270-20-360, Rockshaft — Operation of Draft Sensor
Reference 270-20-370, Rockshaft — Description of Controls
Reference 270-20-380, Rockshaft — Direct Actuation
Reference 270-20-390, 100, 200 and 300 Series Selective Control Valves (Mechanically Actuated)—Description
Reference 270-20-400, 100 Series Selective Control Valve (Mechanically Actuated) — Operation
Reference 270-20-410, 200 Series Selective Control Valve (Mechanically Actuated) — Operation
Reference 270-20-420, 300 Series Selective Control Valve (Mechanically Actuated) — Operation
Reference 270-20-430, Selective Control Valves (Electrically Actuated)—Description
Reference 270-20-435, Selective Control Valves (Electrically Actuated) — Description of Controls
Reference 270-20-440, Selective Control Valves (Electrically Actuated)—Operation
Reference 270-20-470, 101, 201 and 301 Series Selective Control Valves—Description
Reference 270-20-480, Couplers — Description
Reference 270-20-490, Endplate of Selective Control Valves — Summary
Reference 270-20-500, Independent Control Valve—Description
Reference 270-20-505, Independent Control Valve (Electrically Actuated)—Description of Controls
Reference 270-20-510, Independent Control Valve — Operation
MISCELLANEOUS
Reference 280-10-001, Front-Wheel Drive Axle with TLS—Operational Checkout
Reference 280-15-001, Front-Wheel Drive Axle with TLS—System Check
Reference 280-15-002, Front-Wheel Drive Axle with TLS—Checking and Adjusting the Nitrogen Precharge
Reference 280-15-003, Front-Wheel Drive Axle with TLS—Adjusting the Sensor Rod (Position Sensor to Panhard Link)
Reference 280-15-004, Front-Wheel Drive Axle with TLS—Test Result Table
Reference 280-20-001, Front-Wheel Drive Axle with TLS—Summary of References
Reference 280-20-100, Front-Wheel Drive Axle with TLS—Components
Reference 280-20-110, Front-Wheel Drive Axle with TLS—Operation
Reference 280-20-120, Front-Wheel Drive Axle with TLS—Description, Level Control
Reference 280-20-130, Front-Wheel Drive Axle with TLS—Position Sensor
Reference 280-20-140, Front-Wheel Drive Axle with TLS—Electronic Control Unit (SFA)
Reference 280-20-150, Front-Wheel Drive Axle with TLS—Control Block, Exploded View
Reference 280-20-160, Front-Wheel Drive Axle with TLS—Control Block, Sectional View
Reference 280-20-170, Front-Wheel Drive Axle with TLS—Hydraulic Circuit Diagram, Suspension Function
Reference 280-20-180, Front-Wheel Drive Axle with TLS—Hydraulic Circuit Diagram, Level Control (Up)
Reference 280-20-190, Front-Wheel Drive Axle with TLS—Hydraulic Circuit Diagram, Level Control (Down)
OPERATOR'S CAB
Operational Checkout (Summary of References)
Reference 290-10-002, Air Conditioning System, Heater Unit and Operator's Seat—Test Sequence
Reference 290-10-003, Hydro-pneumatic Cab Suspension—Test Sequence
290-15-001, Tests/Adjustments—Summary of References
Reference 290-15-010, Safety at Work
Reference 290-15-015, Handling Refrigerant
Reference 290-15-020, Safety Equipment
Reference 290-15-025, In an Emergency
Reference 290-15-030, Storage of Refrigerant Containers
Reference 290-15-035, R134a Refrigerant
Reference 290-15-040, Important
Reference 290-15-050, Special Tools
290-15-060, Specifications
290-15-065, Explanation of Checks
Air conditioning system, checks
Reference 290-15-070, Pressure Deviations
Reference 290-15-080, MSG95 Operator's Seat Checks
Weight and height setting not functioning in upward direction
Weight and height setting not functioning in downward direction
Spring collapses after a short interval
Spring can be lowered properly, but does not pump up from the lowest position
Spring can be pumped up to the uppermost position, but does not deflate
Spring can be pumped up and lowered, but returns to its original height
290-15-100, Hydro-Pneumatic Cab Suspension — System Check
290-15-110, Hydro-Pneumatic Cab Suspension — Checking and Adjusting the Nitrogen Precharge
Checking and adjusting the nitrogen precharge
Reference 290-15-120, Hydro-pneumatic Cab Suspension—Adjusting the Sensor Rod
290-15-130, Hydro-Pneumatic Cab Suspension — Test Result Table
Reference 290-20-001, Operation of Air-Conditioner/Heater/Air Vents—Summary of References
Reference 290-20-002, Operation of Hydro-pneumatic Cab Suspension—Summary of References
Reference 290-20-010, Principle of Heat Exchange
Reference 290-20-015, R134a Refrigerant
Reference 290-20-020, Refrigerant Circuit Layout (6120 to 6920S Tractors)
Reference 290-20-025, Refrigerant Circuit Layout (SE-Tractors)
Reference 290-20-030, Refrigerant Circuit Operation
Reference 290-20-035, Component Description
Reference 290-20-040, Heating and Ventilation (6120 to 6920S Tractors)
Reference 290-20-045, Heating and Ventilation (SE-Tractors)
290-20-050, Hydro-Pneumatic Cab Suspension — Components
290-20-055, Hydro-Pneumatic Cab Suspension — Operation
290-20-060, Hydro-Pneumatic Cab Suspension — Description of Level Control
290-20-065, Hydro-Pneumatic Cab Suspension — Position Sensor
290-20-070, Hydro-Pneumatic Cab Suspension — Spherical Bearings
290-20-075, Hydro-Pneumatic Cab Suspension — Hydraulic Cylinders/Accumulators
Reference 290-20-080, Hydro-pneumatic Cab Suspension—Control Unit (SFA)
Reference 290-20-085, Hydro-pneumatic Cab Suspension—Control block, components
Reference 290-20-090, Hydro-Pneumatic Cab Suspension — Hydraulic Diagram "Raising"
290-20-095, Hydro-Pneumatic Cab Suspension — Hydraulic Diagram "Lowering"
290-20-100, Hydro-Pneumatic Cab Suspension — Hydraulic Diagram "Suspension Function"
SPECIAL TOOLS (Dealer-Fabricated)
Special Tools (Dealer-Fabricated)
Reference 299-05-001, Special Tools (Dealer-Fabricated) — Summary
Reference 299-05-010, Holding Tool
Reference 299-05-011, Adjusting Tool
Reference 299-05-012, DFRW2—Needle Valve Test Hose Assembly
Reference 299-05-013, DFRW85—Reverse Brake Test Plate
Reference 299-05-014, DFLX10 and DFLX11—Test Harnesses
Reference 299-05-015, DFLX12—Special Tool for 11-BIT and 29-BIT CAN BUS
Reference 299-05-016, DFLX14—Solenoid Test Harness
Page Numbers
Brand: John Deere
Type of Manual: Operation and Tests Manual
Model: John Deere 6020, 6120, 6220, 6320, 6420, 6420S, 6520, 6620, 6820, 6920 and 6920S
6020SE, 6120SE, 6220SE, 6320SE, 6420SE and 6520SE Tractor
Part Number: TM4741
Publication Date: 2002
Number of Pages: 3476 Pages
GENERAL INFORMATION
Safety Measures
Recognize Safety Information
"Important" - Information
"Note" - Information
Prevent Machine Runaway
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Avoid High-Pressure Fluids
Service Cooling System Safely
Work In Ventilated Area
Wear Protective Clothing
Practice Safe Maintenance
Park Machine Safely
Use Proper Lifting Equipment
Support Machine Properly
Work in Clean Area
Illuminate Work Area Safely
Service Machines Safely
Use Proper Tools
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Safety Information - Air Brake System
Avoid Eye Contact With Radar
Keep ROPS Installed Properly
Replace Safety Signs
Dispose of Waste Properly
Live With Safety
Safety Measures on Electronic Control Units
General References
210-15-001, General References—Summary
Reference 210-15-010, Unified Inch Bolt and Cap Screw Torque Values
Reference 210-15-015, Metric Bolt and Cap Screw Torque Values
210-15-020, Hydraulic System Inch Fitting Torques
210-15-025, Hydraulic System Metric Fitting Torques
210-15-030, Component Identification Table
Reference 210-15-035, How to Read a Functional Schematic
210-15-040, How to Read a Diagnostic Schematic
210-15-042, Wire Numbers and Color Codes
210-15-045, Schematic, Wiring and Harness Symbols
210-15-050, Visual Check of the Electrical System
Reference 210-15-055, Electrical Circuit Malfunctions
Types of fault
Reference 210-15-060, Seven Step Electrical Test Procedure
210-15-065, Hydraulic System — Circuit Symbols
ENGINE
Operational Check-Out
Reference 220-10-010, Safety
220-10-020, Preliminary Engine Tests
220-15-010, Dynamometer Test
FUEL, AIR INTAKE AND COOLING SYSTEMS
Reference 230-15-001, Tests and Adjustments—Summary of References
Reference 230-15-010, General Information
Reference 230-15-020, Explanation of Checks
Reference 230-15-030, Safety
Reference 230-15-040, Special Tools
Reference 230-15-050, Specifications
Reference 230-15-060, Testing Air Intake System
Reference 230-15-070, Checking the Cooling System for Leaks
Reference 230-15-080, Testing the Temperature at which the Thermostat opens
Reference 230-15-090, Checking the Viscous Fan Drive
Reference 230-15-100, Checking the Fuel Transfer Pump
Reference 230-15-110, Hand Throttle Lever and Accelerator Pedal Adjustment
Reference 230-15-120, Accelerator Pedal Adjustment
Descriptions
Reference 230-20-001, Component Description - Summary of References
Reference 230-20-010, Fuel System - Description
Reference 230-20-020, Air Intake System - Theory of Operation
Reference 230-20-030, Coolant Circuit - Description
Reference 230-20-040, Cooling System Radiator - Description
Reference 230-20-050, Intercooler - Description
Reference 230-20-060, Ring-Shaped (Transmission Oil) Cooler - Description
Reference 230-20-070, Viscous Fan Drive - Theory of Operation
Reference 230-20-080, Automatic Drive Belt Tensioner - Theory of Operation
Reference 230-20-020, Cold Weather Starting Aids - Theory of Operation
ELECTRICAL SYSTEM
Sub-System Diagnostics (Cab)
Reference 240-10-001, Sub-System Diagnostics (Cab) — Summary of References
Reference 240-10-002, Special Tools
Reference 240-10-050, SE1 — Starter Motor and Charging Circuit
Reference 240-10-004, SE2 — Basic Informator
Reference 240-10-005, SE3 — Horn
Reference 240-10-006, SE4 — Cigarette Lighter and Operator's Seat
Reference 240-10-007, SE6 — Lights
Reference 240-10-008, SE7— Worklights
Reference 240-10-009, SE8 — Front Loader Plug
Reference 240-10-010, SE9 — Radio, Digital Clock, Dome, Console and Access Step Lights
Reference 240-10-011, SE10 — Fan and Air Conditioner
Reference 240-10-012, SE11—Windshield Wiper and Washer
Reference 240-10-013, SE12 — Rear Window Wiper and Washer
Reference 240-10-014, SE13 — Beacon Light
Reference 240-10-015, SE14 — Power Outlet Sockets, 3- and 7-Terminal
Reference 240-10-016, SE15 — Electronic Hitch Control
Reference 240-10-017, SE16A — Basic Control Unit (BCU) (Rear PTO and External Control)
Reference 240-10-018, SE16B — Basic Control Unit (BCU) (Front PTO)
Reference 240-10-019, SE16C — Basic Control Unit (BCU) (Front-Wheel Drive)
Reference 240-10-020, SE16D — Basic Control Unit (BCU) (Differential Lock)
Reference 240-10-021, SE16E — BCU (Hazard Warning and Turn Signal Lights)
Reference 240-10A-051, SE16F — Basic Control Unit (BCU) (Speed Sensor and Radar) (PowrQuad Plus or AutoQuad Transmissions)
Reference 240-10-022, SE16F — Basic Control Unit (BCU) (Speed Sensor and Radar) (AutoPowr/IVT Transmission)
Reference 240-10-023, SE16G — Basic Control Unit (BCU) (Headland Management System II)
Reference 240-10-024, SE16H — Basic Control Unit (BCU) (Power Supply, Acoustic Alarm)
Reference 240-10-025, SE16I — BCU (Intercooler)
Reference 240-10-026, SE16J — Basic Control Unit (BCU) (Braking System and Handbrake Monitor Unit)
Reference 240-10-027, SE17 — Signal Socket
Reference 240-10-028, SE18 — Performance Monitor
Reference 240-10-029, SE20 — Front-Wheel Drive Axle with TLS and CSC Cab Suspension
Reference 240-10-030, SE21 — Electronic Actuation of SCVs
Reference 240-10-031, SE21A — Stepper Motor Driver for Electronic Independent Control Valves (E-ICV)
Reference 240-10-032, SE21B — Stepper Motor Driver for Electronic Selective Control Valves (E-SCV)
Reference 240-10-033, SE22 — BUS Terminator and Terminating Resistor
Reference 240-10A-052, SE23A — Electronic Engine Control (PowrQuad Plus and AutoQuad Transmissions)
Reference 240-10-034, SE23B — Electronic Engine Control (PowrQuad Plus, AutoQuad and AutoPowr/IVT transmissions)
Reference 240-10-035, SE26 — Transmission Control Unit (AutoPowr/IVT Transmissions)
Reference 240-10A-053, SE26A — Transmission Control (PowrQuad Plus & AutoQuad Transm.)
Reference 240-10A-054, SE26C — Electrical Reverser Control (PowrQuad Plus and AutoQuad Transmissions)
Reference 240-10-036, SE27 — Transmission Shift (AutoPowr/IVT transmission)
Reference 240-10-037, SE28 — Electronic Park Lock (AutoPowr/IVT Transmission)
Reference 240-10-040, SE29 — Electrical Rear-View Mirror
Reference 240-10-038, SE30 — JDLink Control Unit
Reference 240-10-039, SE31 — Heated Rear Window
Reference 240-10-041, SE32 — 60-amp GreenStar Socket (with and without TEC)
Reference 240-10-042, SE33 — GreenStar
Sub-System Diagnsotics (Open Operator's Station)
Reference 240-10A-001, Sub-System Diagnostics (Open Operator's Station) — Summary of References
Reference 240-10A-003, SE1—Starter Motor and Charging Circuit
Reference 240-10A-004, SE2—Basic Informator
Reference 240-10A-005, SE3 — Horn
Reference 240-10A-006, SE4 — Operator's Seat
Reference 240-10A-007, SE6—Lights
Reference 240-10A-008, SE7— Worklights
Reference 240-10A-009, SE14—3- and 7-Terminal Power Outlet Sockets
Reference 240-10A-010, SE15—Electronic Hitch Control
Reference 240-10A-011, SE16A—Basic Control Unit (BCU) (Rear PTO)
Reference 240-10A-012, SE16B—Basic Control Unit (BCU) (Front PTO)
Reference 240-10A-013, SE16C—Basic Control Unit (BCU) (Front-Wheel Drive)
Reference 240-10A-014, SE16D—Basic Control Unit (BCU) (Differential Lock)
Reference 240-10A-015, SE16E—Basic Control Unit (BCU) (Hazard Flasher and Turn Signal Unit)
Reference 240-10A-016, SE16F—Basic Control Unit (BCU) (Speed Sending Units)
Reference 240-10A-017, SE16H—Basic Control Unit (BCU) (Power Supply, Acoustic Alarm)
Reference 240-10A-018, SE16J—Basic Control Unit (BCU) (Braking System and BUS Connection)
Reference 240-10A-019, SE17—Signal Socket
Reference 240-10A-020, SE22 — BUS Terminator and Terminating Resistor
Reference 240-10A-021, SE23 — Electronic Engine Control
Sub-System Diagnostics (SE Tractor)
Reference 240-10B-001, Sub-System Diagnostics (SE Tractors) — Summary of References
Reference 240-10B-003, SE1 — Starter Motor and Charging Circuit
Reference 240-10B-004, SE2 — Basic Informator
Reference 240-10B-005, SE3 — Horn
Reference 240-10B-006, SE4 — Operator's Seat
Reference 240-10B-007, SE6 — Lights
Reference 240-10B-008, SE7 — Worklights
Reference 240-10B-009, SE9 — Radio, Dome Light and Console Light
Reference 240-10B-010, SE10 — Fan and Air-Conditioning System
Reference 240-10B-011, SE11 — Windshield Wiper and Washer
Reference 240-10B-012, SE13 — Beacon Light
Reference 240-10B-013, SE14 — 3- and 7-Terminal Power Outlet Sockets
Reference 240-10B-014, SE15 — Electronic Hitch Control
Reference 240-10B-015, SE16A — Basic Control Unit (BCU) (Rear PTO and External Control)
Reference 240-10B-016, SE16B — Basic Control Unit (BCU) (Front PTO)
Reference 240-10B-017, SE16C — Basic Control Unit (BCU) (Front-Wheel Drive)
Reference 240-10B-018, SE16D — Basic Control Unit (BCU) (Differential Lock)
Reference 240-10B-019, SE16E — Basic Control Unit (BCU) (Hazard Flasher and Turn Signal Unit)
Reference 240-10B-020, SE16F — Basic Control Unit (BCU) (Speed Sender and Radar)
Reference 240-10B-021, SE16H — Basic Control Unit (BCU) (Power Supply, Acoustic Alarm and CAN-BUS Connection)
Reference 240-10B-022, SE16J — Basic Control Unit (BCU) (Control Unit for Brakes and Handbrake)
Reference 240-10B-023, SE17 — Signal Socket
Reference 240-10B-024, SE22 — BUS Terminator and Terminating Resistor
Reference 240-10B-025, SE23 — Electronic Engine Control
Component Testing
Reference 240-15-001, SE01 — Starter Motor and Charging Circuit
Starter Checks (M01)
Alternator Checks (G02)
Battery Checks (G01)
Component Tests
Reference 240-15-002, SE02 — Basic Informator
Component checks
Reference 240-15-003, SE03 — Horn
Reference 240-15-004, SE04 — Cigarette Lighter and Operator's Seat
Reference 240-15-005, SE06 — Lighting Circuits
Reference 240-15-006, SE07-Worklights
Reference 240-15-007, SE09 — Radio, Dome Light and Console Light
Reference 240-15-008, SE10 — Blower and Air Conditioner
Reference 240-15-009, SE11 and SE12 — Wiper and Washer System
Reference 240-15-010, SE13 — Beacon Light
Reference 240-15-011, SE14 — Sockets, 3- and 7-Terminal
Reference 240-15-012, SE15 — Electronic Hitch Control
Reference 240-15-013, SE16A — Basic Control Unit (BCU) (Rear PTO and External Control)
Reference 240-15-014, SE16B — BCU (Front PTO)
Reference 240-15-015, SE16C — BCU (FWD)
Reference 240-15-016, SE16D — BCU (Differential Lock)
Reference 240-15-017, SE16E - Basic Control Unit (BCU) (Hazard Flasher and Turn Signal Unit)
Reference 240-15-018, SE16G — Basic Control Unit (BCU) (HMS)
Reference 240-15-019, SE16H — Basic Control Unit (BCU) (Power Supply, Acoustic Alarm)
Reference 240-15-020, SE16I — BCU (Intercooler)
Reference 240-15-021, SE16J — Basic Control Unit (BCU) (Braking System and Handbrake Monitor Unit)
Reference 240-15-022, SE20 — FWD Axle with TLS and Cab Suspension
Reference 240-15-023, SE21 — Electronic Actuation of SCVs
Reference 240-15-024, SE22 — CAN BUS Terminating Resistor
Reference 240-15-025, SE23 — Electronic Engine Control
Reference 240-15-026, SE26A — Transmission Control (PowrQuad Plus and AutoQuad Transmission)
Reference 240-15-027, SE26C — Electrical Reverser Control (PowrQuad Plus and AutoQuad Transmissions)
Reference 240-15-028, SE27 — Transmission Shift (AutoPowr/IVT Transmissions)
Reference 240-15-029, SE28 — Electronic Park Lock (AutoPowr/IVT Transmissions)
Reference 240-15-030, SE29 — Electrically-Adjustable Outside Mirrors
Reference 240-15-031, SE31 — Heated Rear Window
Reference 240-15-032, SE32 — 60-amp GreenStar Socket (with and without TEC)
Functional Schematics (AutoPowr/IVT Transmission)
Reference 240-25-001, Functional Schematic and Fuses (AutoPowr/IVT Transmission) — Summary of References
Reference 240-25-002, Fuses
Reference 240-25-003, Designation of Parts Shown in Functional Schematic and Harness Diagram
Reference 240-25-004, Designation of Sections Shown in Functional Schematic
Reference 240-25-005, Wiring Harness Designations
Reference 240-25-006, Functional Schematic (Complete Tractor)
Functional Schematics (PowrQuad Plus & AutoQuad Transm.)
Reference 240-25A-001, Functional Schematic and Wiring Harnesses (PowrQuad Plus and AutoQuad Transmissions ) — Summary of References
Reference 240-25A-010, Fuses
Reference 240-25A-011, Designation of Parts Shown in Functional Schematic and Harness Diagram
Reference 240-25A-012, Designation of Sections Shown in Functional Schematic
Reference 240-25A-013, Wiring Harness Designations
Reference 240-25A-014, Functional Schematic (Complete Tractor)
Functional Schematics (Open Operator's Station)
Reference 240-25B-001, Functional Schematic and Wiring Harnesses (Open Operator's Station) — Summary of References
Reference 240-25B-002, Fuses and Relays
Reference 240-25B-003, Designation of Parts Shown in Functional Schematic and Harness Diagram
Reference 240-25B-004, Designation of Sections Shown in Functional Schematic
Reference 240-25B-005, Wiring Harness Designations
Reference 240-25B-006, Functional Schematic (Complete Tractor)
Functional Schematics (SE Tractor)
Reference 240-25C-001, Functional Schematic and Wiring Harnesses (SE Tractor) — Summary of References
Reference 240-25C-010, Fuses and Relays
Reference 240-25C-011, Designation of Parts Shown in Functional Schematic and Harness Diagram
Reference 240-25C-012, Designation of Sections Shown in Functional Schematic
Reference 240-25C-013, Wiring Harness Designations
Reference 240-25C-014, Functional Schematic (Complete Tractor)
Wiring Harnesses
Reference 240-26-004, Wiring Harnesses for 6120, 6220, 6320, 6420 and 6520 Tractors with PowrQuad Plus Transmission and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-005, Wiring Harnesses for 6320, 6420 and 6520 Tractors with AutoQuad Transmission and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-002, Wiring Harnesses for 6420S, 6620, 6820, 6920 and 6920S Tractors with PowrQuad Plus or AutoQuad Transmissions and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-501, Wiring Harnesses for Tractors with PowrQuad Plus or AutoQuad Transmissions and Stage II Engine to 97/68/EC — Summary of References
Reference 240-26-003, Wiring Harnesses for Tractors with AutoPowr/IVT Transmission and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-502, Wiring Harnesses for Tractors with AutoPowr/IVT Transmission and Stage II Engine to 97/68/EC — Summary of References
Reference 240-26-006, Wiring Harnesses for Tractors with Open Operator's Station and Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-503, Wiring Harnesses for Tractors with Open Operator's Station and Stage II Engine to 97/68/EC — Summary of References
Reference 240-26-007, Wiring Harnesses for SE Tractors with Stage I Engine to 97/68/EC — Summary of References
Reference 240-26-504, Wiring Harnesses for SE Tractors with Stage II Engine to 97/68/EC — Summary of References
Reference 240-26-011, W01 — Wiring Harness - Power Supply
Reference 240-26-013, W01 — Wiring Harness - Power Supply (Open Operator's Station)
Reference 240-26-015, W01 — Wiring Harness - Power Supply (SE Tractors)
Reference 240-26-021, W02 — Engine Wiring Harness for Stage I Engine to 97/68/EC (without Engine Control or with Level 1 ECU)
Reference 240-26-023, W02 — Engine Wiring Harness for Stage I Engines to 97/68/EC (Level 4 ECU)
Reference 240-26-521, W02 — Engine Wiring Harness for Stage II Engines to 97/68/EC (Level 11 ECU)
Reference 240-26-025, W02 — Engine Wiring Harness for Stage I Engines to 97/68/EC (Open Operator's Station)
Reference 240-26-524, W02 — Engine Wiring Harness for Stage II Engines to 97/68/EC (Level 12 ECU) (Open Operator's Station)
Reference 240-26-027, W02 — Engine Wiring Harness for Stage I Engines to 97/68/EC (SE Tractors)
Reference 240-26-526, W02 — Engine Wiring Harness for Stage II Engines to 97/68/EC (Level 12 ECU) (SE Tractors)
Reference 240-26-031, W03 — Wiring Harness - Starting Aid for Stage I and II Engines to 97/68/EC (without Engine Control or with Level 1 or 12 ECUs)
Reference 240-26-032, W03 — Wiring Harness - Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs)
Reference 240-26-033, W03 — Wiring Harness - Starting Aid for Stage I and II Engines to 97/68/EC (Level 4 or 11 ECUs) (AutoPowr/IVT transmission)
Reference 240-26-042, W04 — Wiring Harness - Headlights
Reference 240-26-061, W06 — Wiring Harness - Front-Wheel Drive Axle with TLS
Reference 240-26-071, W07 — Wiring Harness - Front PTO
Reference 240-26-081, W08 — Wiring Harness - Cab, with Stage I Engine to 97/68/EC
Reference 240-26-581, W08 — Wiring Harness - Cab, with Stage II Engine to 97/68/EC
Reference 240-26-082, W08 — Wiring Harness - Cab, with Stage I Engine to 97/68/EC (AutoPowr/IVT transmission)
Reference 240-26-582, W08 — Wiring Harness - Cab, with Stage II Engine to 97/68/EC (AutoPowr/IVT transmission)
Reference 240-26-083, W08 — Wiring Harness - Open Operator's Station, with Stage I Engine to 97/68/EC
Reference 240-26-583, W08 — Wiring Harness - Open Operator's Station, with Stage II Engine to 97/68/EC
Reference 240-26-084, W08 — Wiring Harness - Cab, with Stage I Engine to 97/68/EC (SE Tractors)
Reference 240-26-584, W08 — Wiring Harness - Cab, with Stage II Engine to 97/68/EC (SE Tractors)
Reference 240-26-091, W09 — Wiring Harness - Cowl, with Stage I Engine to 97/68/EC
Reference 240-26-591, W09 — Wiring Harness - Cowl, with Stage II Engine to 97/68/EC
Reference 240-26-092, W09 — Wiring Harness - Cowl, with Stage I Engine to 97/68/EC (AutoPowr/IVT transmission)
Reference 240-26-592, W09 — Wiring Harness - Cowl, with Stage II Engine to 97/68/EC (AutoPowr/IVT transmission)
Reference 240-26-094, W09 — Wiring Harness - Cowl, with Stage I Engine to 97/68/EC (Open Operator's Station)
Reference 240-26-593, W09 — Wiring Harness - Cowl, with Stage II Engine to 97/68/EC (Open Operator's Station)
Reference 240-26-095, W09 — Wiring Harness - Cowl, with Stage I Engine to 97/68/EC (SE Tractors)
Reference 240-26-594, W09 — Wiring Harness - Cowl, with Stage II Engine to 97/68/EC (SE Tractors)
Reference 240-26-101, W10 — Wiring Harness - Shift Console
Reference 240-26-111, W11 — Wiring Harness - Transmission Shift and Hand Throttle
Reference 240-26-112, W11 — Wiring Harness - Speed Control Lever and Hand Throttle (AutoPowr/IVT Transmission)
Reference 240-26-122, W12 — Wiring Harness - Command Arm (AutoPowr/IVT Transmission)
Reference 240-26-131, W13 — Wiring Harness - Clutch Sender
Reference 240-26-144, W14 — Wiring Harness - 3-Terminal Power Outlet Socket
Reference 240-26-141, W14 — Wiring Harness - 3-Terminal Power Outlet Socket (Open Operator's Station and SE Tractor)
Reference 240-26-153, W15 — ECU Wiring Harness for Stage I Engines to 97/68/EC (without Engine Control)
Reference 240-26-151, W15 — ECU Wiring Harness for Stage I Engines to 97/68/EC (Level 1 ECU)
Reference 240-26-152, W15 — ECU Wiring Harness for Stage I Engines to 97/68/EC (Level 4 ECU)
Reference 240-26-651, W15 — ECU Wiring Harness for Stage II Engines to 97/68/EC (Level 11 ECU)
Reference 240-26-161, W16 — SIC Wiring Harness for Stage I Engines to 97/68/EC
Reference 240-26-561, W16 — SIC Wiring Harness for Stage II Engines to 97/68/EC
Reference 240-26-171, W17 — Wiring Harness - Multifunction Unit
Reference 240-26-181, W18 — Wiring Harness - Windshield Wiper Switch (without Intermittent Wipe)
Reference 240-26-182, W18 — Wiring Harness - Windshield Wiper Switch (with Intermittent Wipe)
Reference 240-26-191, W19 — Wiring Harness - Cab Roof, with Stage I Engines to 97/68/EC
Reference 240-26-691, W19 — Wiring Harness - Cab Roof, with Stage II Engines to 97/68/EC
Reference 240-26-193, W19 — Cab Roof Wiring Harness (SE Tractors)
Reference 240-26-201, W20 — Wiring Harness - Turn Signal and Clearance Lights
240-26-211, W21 — Wiring Harness - Worklights on Front of Cab Roof
240-26-221, W22 — Wiring Harness - Worklights on Rear of Cab Roof
Reference 240-26-222, W22 — Wiring Harness - Xenon Worklights on Rear of Cab Roof
Reference 240-26-231, W23 — Wiring Harness - Windshield Wiper (Without Switch for Windshield)
Reference 240-26-232, W23 — Wiring Harness - Windshield Wiper (With Switch for Windshield)
Reference 240-26-241, W24 — Wiring Harness - Rear Window Wiper
Reference 240-26-251, W25 — Wiring Harness - Rear Window Wiper Switch
Reference 240-26-261, W26 — Wiring Harness - Blower and Air Conditioner
Reference 240-26-263, W26 — Wiring Harness - Fan and Air Conditioner (SE Tractors)
Reference 240-26-281, W28 — Wiring Harness - Front End of Transmission
Reference 240-26-285, W28 — Wiring Harness - Front Part of Transmission (AutoPowr/IVT Transmission)
Reference 240-26-284, W28 — Wiring Harness - Front End of Transmission (Open Operator's Station)
Reference 240-26-288, W28 — Wiring Harness - Front Part of Transmission (SE Tractors)
Reference 240-26-291, W29 — Wiring Harness - Valve Block (AutoPowr/IVT Transmission)
Reference 240-26-303, W30 — Wiring Harness - Rear Part of Transmission (6120-6620 Tractors)
Reference 240-26-304, W30 — Wiring Harness - Rear Part of Transmission (6820-6920 Tractors)
Reference 240-26-306, W30 — Wiring Harness - Rear End of Transmission (Open Operator's Station)
Reference 240-26-307, W30 — Wiring Harness - Rear Part of Transmission (SE Tractors)
Reference 240-26-311, W31 — Wiring Harness - 7-Terminal Power Outlet Socket
Reference 240-26-321, W32 — Wiring Harness - Stepper Motors, with Stage I Engines to 9/68/EC
Reference 240-26-821, W32 — Wiring Harness - Stepper Motors, with Stage II Engines to 97/68/EC
Reference 240-26-331, W33 — Wiring Harness - Service
Reference 240-26-341, W34 — Wiring Harness - Electric Rear-View Mirrors
Reference 240-26-351, W35 — Wiring Harness - Access-Step Light and Battery Cut-Off Switch
Reference 240-26-361, W36 — Wiring Harness - 60 A GreenStar Socket
Reference 240-26-371, W37 — Wiring Harness - GreenStar Port
Reference 240-26-391, W39 — Wiring Harness - GreenStar (Cab)
Reference 240-26-392, W39 — Wiring Harness - GreenStar (Cab) with TEC
Reference 240-26-401, W40 — Wiring Harness - GreenStar (Cab Roof)
Reference 240-26-411, W41 — Wiring Harness - JDLink
Reference 240-26-421, W42 — Wiring Harness - Battery Cut-Off Switch
ELECTRONIC CONTROL UNITS
Operation and General Information on Diagnostics
Special or Essential Tools
Reference 245-05-001, General Operating Instructions and Entering Program Mode
Customer Level
Dealer/Service Level
Reference 245-05-002, Accessing Addresses and Diagnostic Trouble Codes
Accessing the Diagnostic Trouble Codes of all the Control Units (ALL Mode)
Accessing and Confirming a Control Unit
Accessing Diagnostic Trouble Codes of the Individual Control Units
Accessing Addresses
Aborting or Completing the Program Mode
Reference 245-05-005, Driving in the Diagnostic Mode
Reference 245-05-003, Description of Diagnostic Trouble Codes
Reference 245-05-004, Electronic Control Units — Summary of Addresses
Reference 245-05-006, Approved Software for Control Units
Data BUS Systems, Diagnosis
Reference 245-10-001, 29-bit CAN BUS - Check
Checking the circuit
Reference 245-10-002, 11-bit CAN BUS - Check
Reference 245-10-003, 29-bit CAN BUS - Check (Tractors with Open Operator's Station and SE-Tractors with Stage II Engines according to 97/68/EC; Level 12)
Data BUS Systems, Theory of Operation
Reference 245-20-001, Data BUS Systems — Summary of References
Reference 245-20-002, Data-BUS Systems
Reference 245-20-003, CAN BUS System
Reference 245-20-011, CAN BUS Systems on Tractors without Engine Control Unit (ECU)
Reference 245-20-012, CAN BUS Systems on Tractors with Engine Control Unit (ECU) Level 1
Reference 245-20-013, CAN BUS Systems on Tractors with Engine Control Unit (ECU) Level 4
Reference 245-20-014, CAN BUS Systems on Tractors with AutoPowr/IVT Transmission
BCU - Basic Control Unit
Reference 245-BCU-001, Calibration and Input Addresses of Basic Functions
Entering program mode
Address BCU020 - Basic functions, engine speed sending unit/impulses per rev.
Address BCU021 - Basic functions, rear PTO speed sending unit/impulses per rev.
Address BCU022 - Basic functions, FWD control function
Address BCU023 - Basic functions, front PTO speed sending unit/impulses per rev.
Address BCU024 - Basic functions, units of measurement used in display
Address BCU025 — Basic functions, selection of region
Address BCU026 - Basic functions, audible indication of turn signal
Address BCU027 — Basic functions, front PTO control function
Address BCU028 — Basic functions, rear PTO control function
Address BCU029 - Basic functions, air brake system control function
Address BCU030 - Basic functions, sensor control function
Address BCU031 — Basic functions, reverse drive lever control function
Address BCU034 - Basic functions, LTC coolant pump control function
Address BCU035 — Basic functions, service interval setting
Address BCU037 - Basic functions, configuration of control displays
Address BCU038 - Basic functions, indicator light test
Address BCU039 - Basic functions, rear PTO remote control switch
Address BCU043 - Basic functions, number of engine operating hours
Address BCU044 - Basic functions, diagnostic trouble code display
Address BCU056 - Basic functions, rolling radius
Address BCU058 - Basic functions, wheel speed sending unit/impulses per rev.
Address BCU060 - Basic functions, calibration factor for travel speed (radar)
Address BCU066 - Basic functions, mode for HMS II
Address BCU077 — Basic functions, tractor configuration
Address BCU078 - Basic functions, engine control function
Address BCU247 - Tractor model designation
Address BCU248 - Tractor serial number
Reference 245-BCU-002, Calibration and Input Addresses of Hitch Control
Address BCU 118 — Input address for "quick withdrawal" and "hitch dampening"
Address BCU 122 — Calibration of rockshaft control
Address BCU 165 — Input address for rate of rise
Address BCU 167 — Input address for rockshaft components
Address BCU 174 — Input address for load control index
Address BCU 185 — Input address for volume of lift cylinder
Reference 245-BCU-100, Pre-Test of BCU Electrical Circuit
Reference 245-BCU-101, Circuit Test for Rear PTO Remote Control Switch (S44)
Operational check of rear PTO remote control (left)
Circuit/harness test for rear PTO remote control
Reference 245-BCU-102, Circuit Test for Rear PTO Switch S21 (with Command Arm)
Operational test on rear PTO switch (S21)
Circuit/harness test for rear PTO switch (S21)
Reference 245-BCU-103, Circuit Test for Rear PTO Switch (S21)
Reference 245-BCU-104, Circuit Test for PTO Preselector Switch (S45)
Operational check for rear PTO preselector switch (S45)
Circuit/harness test for rear PTO preselector switch (S45).
Reference 245-BCU-105, Circuit Test for Front PTO Switch (S06) (with Command Arm)
Operational check for front PTO switch (S06)
Circuit/harness test for front PTO switch S06 (with Command Arm)
Reference 245-BCU-106, Circuit Test for Front PTO Switch (S06)
Circuit/harness test for front PTO switch (S06)
Reference 245-BCU-107, Circuit Test for Front-Wheel Drive Switch (S63) (without HMS II)
Operational test on front-wheel drive switch (S63)
Circuit/harness test for front-wheel drive switch (S63) (without HMS II)
Reference 245-BCU-108, Circuit Test for Front-Wheel Drive Switch (S05) (with HMS II)
Operational test on front-wheel drive switch (S05)
Circuit test for front-wheel drive switch (S05) (with HMS II).
Reference 245-BCU-109, Circuit Test for Differential Lock Switch (S22)
Operational test for differential lock switch (S22)
Circuit/harness test for differential lock switch (S22)
Reference 245-BCU-110, Circuit Test for Hazard Warning Switch (S62)
Operational test for hazard warning switch (S62)
Circuit/harness test for hazard warning switch (S62) ECE
Reference 245-BCU-111, Circuit Test for Hazard Warning Switch (S66)
Operational test for hazard warning switch (S66)
Circuit/harness test for hazard warning switch (S66)
Reference 245-BCU-112, Circuit Test for Turn Signal Switch (S08)
Operational test on turn signal switch (S08)
Circuit/harness test for turn signal switch (S08)
Reference 245-BCU-113, Circuit Test for Wheel Speed Sender (B09) (on 6120-6620)
Operational test on wheel speed sending unit (B09)
Circuit/harness test for wheel speed sending unit (B09)
Reference 245-BCU-114, Circuit Test for Wheel Speed Sender (B09) (on 6820-6920)
Reference 245-BCU-115, Circuit Test for Wheel Speed Sender (B35) (on 6120-6620)
Operational test on wheel speed sending unit (B35) (on 6120-6620)
Circuit/harness test for wheel speed sending unit (B35)
Reference 245-BCU-116, Circuit Test for Wheel Speed Sender (B35) (on 6820-6920)
Reference 245-BCU-117, Circuit Test for Record/Save Switch (S95)
Operational test for record/save switch (S95)
Circuit/harness test for record/save switch
Reference 245-BCU-118, Circuit Test for HMS Program Switch (S100)
Operational test for HMS program switch (S100)
Circuit/harness test for HMS program switch (S100).
Reference 245-BCU-119, Circuit Test for Handbrake Switch (B37)
Operational test for handbrake switch (B37)
Circuit/harness test for handbrake switch (B37)
Reference 245-BCU-120, Circuit Test for Engine Speed Sender (B01)
Operational test on engine speed sender (B01)
Circuit/harness test for engine speed sender (B01)
Reference 245-BCU-121, Circuit Test for PTO Speed Sender (B06)
Operational test on PTO speed sender (B06)
Circuit/harness test for PTO speed sender (B06)
Reference 245-BCU-122, Circuit Test for Front PTO Speed Sender (B58)
Operational test on front PTO speed sender (B58)
Circuit/harness test for front PTO speed sender (B58)
Reference 245-BCU-123, Circuit Test on Sensitivity Potentiometer (B26)
Operational test on sensitivity potentiometer (B26)
Circuit/harness test for sensitivity potentiometer.
Reference 245-BCU-124, Circuit Test on Sensitivity Potentiometer (B97)
Operational test on sensitivity potentiometer (B97)
Reference 245-BCU-125, Circuit Test for Depth-Setting Potentiometer (B98)
Operational test on depth-setting potentiometer (B98)
Circuit/harness test for depth-setting potentiometer.
Reference 245-BCU-126, Circuit Test for Depth-Setting Potentiometer (B27)
Operational test on depth-setting potentiometer (B27)
Reference 245-BCU-127, Circuit Test for Position Sensor (B21)
Operational test for position sensor (B21)
Circuit/harness test for position sensor.
Reference 245-BCU-128, Circuit Test on Rate-of-Drop Potentiometer (B27)
Operational test on rate-of-drop potentiometer (B27)
Circuit/harness test for rate-of-drop potentiometer.
Reference 245-BCU-129, Circuit Test on Rate-of-Drop Potentiometer (B97)
Operational test on rate-of-drop potentiometer (B97)
Circuit/harness test for rate-of-drop potentiometer (B97)
Reference 245-BCU-130, Circuit Test on Raise-Limit Potentiometer (B27)
Operational test on raise-limit potentiometer (B27)
Circuit/harness test for raise-limit potentiometer (B27)
Reference 245-BCU-131, Circuit Test on Raise-Limit Potentiometer (B97)
Operational test on raise-limit potentiometer (B97)
Circuit/harness test for raise-limit potentiometer (B97)
Reference 245-BCU-132, Circuit Test for Rapid-Raise Switch (S24)
Operational check for rapid-raise switch (S24)
Circuit/harness test, potentiometer for rapid-raise switch (S24)
Reference 245-BCU-133, Circuit Test for Rapid-Raise Switch (S24_A)
Operational check for rapid-raise switch (S24_A)
Circuit/harness test, potentiometer for rapid-raise switch (S24_A)
Reference 245-BCU-134, Circuit Test for Rear PTO Solenoid Valve (Y04)
Circuit/harness test for rear PTO solenoid valve (Y04)
Reference 245-BCU-135, Circuit Test for Front-Wheel Drive Solenoid Valve (Y03)
Circuit/harness test for front-wheel drive solenoid valve (Y03)
Reference 245-BCU-136, Circuit Test for Differential Lock Solenoid Valve (Y05)
Circuit/harness test for differential lock solenoid valve (Y05)
Reference 245-BCU-137, Circuit Test for Front PTO Solenoid Valve (Y01)
Circuit/harness test for front PTO solenoid valve (Y01)
Reference 245-BCU-138, Circuit Test on R.h. Draft Sensor (B19)
Operational test on r.h. draft sensor (B19)
Circuit/harness test for the draft sensor.
Reference 245-BCU-139, Circuit Test for L.h. Draft Sensor (B20)
Operational test on l.h. draft sensor (B20)
Reference 245-BCU-140, Circuit Test for Draft Potentiometer (B41)
Operational test for draft potentiometer (B41)
Circuit/harness test for the draft potentiometer.
Reference 245-BCU-141, Circuit Test for Right Remote Control Switch (S23)
Operational check for right remote control switch (S23)
Circuit/harness test for right remote control switch
Reference 245-BCU-142, Circuit Test for Left Remote Control Switch (S68)
Operational check for left remote control switch (S68)
Circuit/harness test for left remote control switch
Reference 245-BCU-143, Circuit Test for Rockshaft Control Stepper Motor (M08)
Circuit/harness test for rockshaft control stepper motor (M08)
Reference 245-BCU-144, Circuit Test on Relay for LTC Coolant Pump K02/3
Circuit/harness test on relay for LTC coolant pump K02/3
Reference 245-BCU-145, Circuit Test for HMS Switch (S43)
Operational test for HMS switch (S43)
Circuit/harness test for HMS switch (S43)
Reference 245-BCU-146, Circuit Test for Air Brake Solenoid Valve (Y31)
Circuit/harness test for air brake solenoid valve (Y31)
Reference 245-BCU-147, Circuit Test for Alternator Relay (K02/2)
Circuit/harness test for alternator relay (K02/2)
Reference 245-BCU-148, Circuit Test for Rear PTO Switch (S21) - Open Operator's Station
Reference 245-BCU-149, Circuit Test for Front PTO Switch (S06) - Open Operator's Station
Reference 245-BCU-150, Circuit Test for Front-Wheel Drive Switch (S63) - Open Operator's Station
Reference 245-BCU-151, Circuit Test for Differential Lock Switch (S22) - Open Operator's Station
Reference 245-BCU-152, Circuit Test for Turn Signal Switch (S08) - Open Operator's Station
Reference 245-BCU-153, Circuit Test for Wheel Speed Sender (B35) - Open Operator's Station
Reference 245-BCU-154, Circuit Test for Engine Speed Sender (B01) - Open Operator's Station
Reference 245-BCU-155, Circuit Test for PTO Speed Sender (B06) - Open Operator's Station
Reference 245-BCU-156, Circuit Test for Front PTO Speed Sender (B58) - Open Operator's Station
Reference 245-BCU-157, Circuit Test on Sensitivity Potentiometer (B26) - Open Operator's Station
Reference 245-BCU-158, Circuit Test on Depth-Setting Potentiometer - Open Operator's Station
Reference 245-BCU-159, Circuit Test for Position Sensor (B21) - Open Operator's Station
Reference 245-BCU-160, Circuit Test on Rate-of-Drop Potentiometer - Open Operator's Station
Reference 245-BCU-161, Circuit Test on Raise-Limit Potentiometer - Open Operator's Station
Reference 245-BCU-162, Circuit Test for Rapid-Raise Switch (S24) - Open Operator's Station
Reference 245-BCU-163, Circuit Test for Rear PTO Solenoid Valve (Y04) - Open Operator's Station
Reference 245-BCU-164, Circuit Test for Front-Wheel Drive Solenoid Valve (Y03) - Open Operator's Station
Reference 245-BCU-165, Circuit Test for Differential Lock Solenoid Valve (Y05) - Open Operator's Station
Reference 245-BCU-166, Circuit Test on R.h. Draft Sensor (B19) - Open Operator's Station
Reference 245-BCU-167, Circuit Test on L.h. Draft Sensor (B20) - Open Operator's Station
Reference 245-BCU-168, Circuit Test for Left Remote Control Switch (S68) - Open Operator's Station
Reference 245-BCU-169, Circuit Test for Rockshaft Control Stepper Motor (M08) - Open Operator's Station
Reference 245-BCU-170, Circuit Test for Rear PTO Switch (S21) - SE Tractors
Circuit/harness test for rear PTO switch - SE tractors
Reference 245-BCU-171, Circuit Test for Front PTO Switch (S06) - SE Tractors
Circuit/harness test for front PTO switch (S06) - SE tractors
Reference 245-BCU-172, Circuit Test for Front-Wheel Drive Switch (S63) - SE Tractors
Circuit/harness test for front-wheel drive switch (S63) - SE tractors
Reference 245-BCU-173, Circuit Test for Differential Lock Switch (S22) - SE Tractors
Circuit/harness test for differential lock switch (S22) - SE tractors
Reference 245-BCU-174, Circuit Test for Hazard Warning Switch (S106) - SE Tractors
Operational test for hazard warning switch (S106)
Circuit/harness test for hazard warning switch (S106) - SE tractors
Reference 245-BCU-175, Circuit Test for Turn Signal Switch (S08) - SE Tractors
Circuit/harness test for turn signal switch (S08) - SE tractors
Reference 245-BCU-176, Circuit Test for Wheel Speed Sender (B35) - SE Tractors
Circuit/harness test for wheel speed sending unit (B35) - SE tractors
Reference 245-BCU-177, Circuit Test for Engine Speed Sender (B01) - SE Tractors
Circuit/Harness test for engine speed sender (B01) - SE tractors
Reference 245-BCU-178, Circuit Test for PTO Speed Sender (B06) - SE Tractors
Circuit/Harness test for PTO speed sender (B06) - SE tractors
Reference 245-BCU-179, Circuit Test for Front PTO Speed Sender (B58) - SE Tractors
Circuit/harness test for front PTO speed sending unit (B58) - SE tractors
Reference 245-BCU-180, Circuit Test on Sensitivity Potentiometer (B26) - SE Tractors
Circuit/harness test for sensitivity potentiometer - SE tractors
Reference 245-BCU-181, Circuit Test on Depth-Setting Potentiometer (B27) - SE Tractors
Circuit/harness test for depth-setting potentiometer - SE tractors
Reference 245-BCU-182, Circuit Test for Position Sensor (B21) - SE Tractors
Circuit/harness test for position sensor - SE tractors
Reference 245-BCU-183, Circuit Test on Rate-of-Drop Potentiometer (B27) - SE Tractors
Circuit/harness test for rate-of-drop potentiometer - SE tractors
Reference 245-BCU-184, Circuit Test on Raise-Limit Potentiometer (B27) - SE Tractors
Circuit/harness test for raise limit potentiometer (B27) - SE tractors
Reference 245-BCU-185, Circuit Test for Rapid-Raise Switch (S24) - SE Tractors
Circuit/harness test for potentiometer for rapid-raise switch (S24) - SE tractors
Reference 245-BCU-186, Circuit Test for Rear PTO Solenoid Valve (Y04) - SE Tractors
Reference 245-BCU-187, Circuit Test for Front-Wheel Drive Solenoid Valve (Y03) - SE Tractors
Reference 245-BCU-188, Circuit Test for Differential Lock Solenoid Valve (Y05) - SE Tractors
Reference 245-BCU-189, Circuit Test for Front PTO Solenoid Valve (Y01) - SE Tractors
Reference 245-BCU-190, Circuit Test on R.h. Draft Sensor (B19) - SE Tractors
Circuit/harness test for draft sensor - SE tractors
Reference 245-BCU-191, Circuit Test on L.h. Draft Sensor (B20) - SE Tractors
Reference 245-BCU-192, Circuit Test for Left Remote Control Switch (S68) - SE Tractors
Circuit/harness test for left remote control switch - SE tractors
Reference 245-BCU-193, Circuit Test for Rockshaft Control Stepper Motor (M08) - SE Tractors
Reference 245-BCU-200, Theory of Operation (Basic Functions)
Reference 245-BCU-201, Theory of Operation (Hitch Control)
BIF - Basic Informator
Reference 245-BIF-001, Calibration and Input Addresses
Address BIF022 - Gear indicator in display
Address BIF023 - Worklight alarm
Address BIF024 - Units of measurement used in displays
Address BIF027 - Indicator light test
Address BIF028 - Clock operation
Address BIF029 - Electrical starting aid
Address BIF035 - Instrument lighting brightness
Address BIF036 — Selecting the information source for engine oil pressure and coolant temperature
Address BIF037 - Ground speed sending unit
Address BIF038 - Language selection
Address BIF039 - Rear PTO speed indication
Address BIF060 - Front PTO control function
Address BIF066 - Data Bus control function
Address BIF247 - Tractor model designation
Address BIF248 - Tractor serial number
Reference 245-BIF-101, Circuit Test for Fuel Gauge Sender (B03)
Operational test for fuel gauge sender (B03)
Circuit/harness test for fuel gauge sender (B03)
Reference 245-BIF-102, Circuit Test for Coolant Temperature Sender (B08)
Operational test for coolant temperature sender (B08)
Circuit/Harness test for Coolant Temperature Sender (B08)
Reference 245-BIF-103, Circuit Test for Hydraulic Oil Temperature Sender (B60)
Operational test for hydraulic oil temperature sender (B60)
Circuit/Harness test for Hydraulic Oil Temperature Sender (B60)
Reference 245-BIF-104, Circuit Test for Engine Oil Pressure Sender (B04)
Operational test for engine oil pressure sender (B04)
Circuit/Harness test for Engine Oil Pressure Sender (B04)
Reference 245-BIF-105, Circuit Test for Transmission Oil Pressure Sender (B31)
Operational test for transmission oil pressure sender (B31)
Circuit/harness test for transmission oil pressure sender (B31)
Reference 245-BIF-106, Circuit Test for Sender (B02; Air Cleaner Restriction Indicator Light)
Operational test for sender (B02; air cleaner restriction indicator light)
Circuit/harness test for sender (B02; air cleaner restriction indicator light)
Reference 245-BIF-107, Circuit Test for Alternator D+ Voltage
Operational test for alternator D+ voltage
Circuit/harness test for alternator D+ voltage
Reference 245-BIF-108, Circuit Test for Sender (B07; Oil Filter Restriction Indicator Light)
Operational test for sender (B07; oil filter restriction indicator light)
Circuit/harness test for sender (B07; oil filter restriction indicator light)
Reference 245-BIF-109, Circuit Test for Restriction Warning Switch at Hydraulic Oil Filter (B111) (AutoPowr/IVT Transmission)
Operational test for restriction warning switch at hydraulic oil filter (B111) (AutoPowr/IVT transmission)
Circuit/harness test for restriction warning switch at hydraulic oil filter (B111)
Reference 245-BIF-110, Circuit Test for Restriction Warning Switch at Hydraulic Oil Filter (B111)
Operational test for restriction switch in hydraulic oil filter (B111)
Reference 245-BIF-200, Theory of Operation
ECU - Engine Control Unit
Reference 245-ECU-001, Calibration and Input Addresses
Reference 245-ECU-100, Diagnosis of Electrical Circuits for Level 1 and Level 4 Engine Control Unit (ECU)
Reference 245-ECU-101, Diagnosis of Electrical Circuits for Level 11 and Level 12 Engine Control Unit (ECU)
Reference 245-ECU-200, Theory of Operation (Level 1)
Reference 245-ECU-201, Theory of Operation (Level 4)
Reference 245-ECU-202, Theory of Operation (Stage II Engines to 97/68/EC; Level 11 with AutoQuad Transmission)
Reference 245-ECU-203, Theory of Operation (Stage II Engines to 97/68/EC; Level 11 with AutoPowr/IVT Transmission)
Reference 245-ECU-204, Theory of Operation (Stage II Engines to 97/68/EC; Level 12)
EPC - Control Unit for PowrQuad Plus and AutoQuad Transmissions
Reference 245-EPC-001, Calibration and Input Addresses
Address EPC 028 - Input address, tractor model
Address EPC 030 — Input address, impulses per engine revolution
Address EPC 033 - Input address, system pressure
Address EPC 035 - Input address, temperature difference where other types of hydraulic oil are used instead of J20C
Address EPC 037 - Input address, for hydraulic oils used as an alternative to J20C
Address EPC 038 - Calibration address, transmission calibration
Address EPC 047 - Input address, automatic deletion of diagnostic trouble codes
Address EPC 134 - Input address, impulses at sending unit for transmission speed (B104)
Address EPC 135 - Input address, transmission function activation
Address EPC 156 - Input address, automatic shifting in reverse travel
Address EPC 157 - Input address, parameters for automatic speed matching
Address EPC 158 - Input address, value for automatic shifting, power mode
Address EPC 160 - Input address, value for automatic shifting, power mode
Address EPC 162 - Input address, value for automatic shifting, ECO mode
Address EPC 164 - Input address, value for automatic shifting, ECO mode
Address EPC 247 - Input address for tractor model designation
Address EPC 248 - Input address for tractor serial number
Reference 245-EPC-100, Pre-Test of EPC Electrical Circuit
Reference 245-EPC-101, Circuit Test for Enable Proportional Solenoid Valve (Y38)
Operational test for enable proportional solenoid valve (Y38)
Circuit/harness test for proportional enable solenoid valve (Y38)
Reference 245-EPC-102, Circuit Test for Forward Solenoid Valve (Y33)
Operational test for circuit of forward solenoid valve (Y33)
Circuit/harness test for forward solenoid valve (Y33)
Reference 245-EPC-103, Circuit Test for Reverse Solenoid Valve (Y36)
Operational test for circuit of reverse solenoid valve (Y36)
Circuit/harness test for reverse solenoid valve (Y36)
Reference 245-EPC-104, Circuit Test for K1 Solenoid Valve (Y40)
Operational test for circuit of K1 solenoid valve (Y40)
Circuit/harness test for K1 solenoid valve (Y40)
Reference 245-EPC-105, Circuit Test for K2 Solenoid Valve (Y39)
Operational test for circuit of K2 solenoid valve (Y39)
Circuit/harness test for K2 solenoid valve (Y39)
Reference 245-EPC-106, Circuit Test for K3 Solenoid Valve (Y32)
Operational test for circuit of K3 solenoid valve (Y32)
Circuit/harness test for K3 solenoid valve (Y32)
Reference 245-EPC-107, Circuit Test for Transmission Speed Sender (B104/1) for 6820 and 6920 Tractors
Operational test for transmission speed sender (B104/1)
Circuit/harness test for transmission speed sender (B104/1)
Reference 245-EPC-108, Circuit Test for Transmission Speed Sender (B104/2) for 6120 - 6620 Tractors
Operational test for transmission speed sender (B104/2)
Circuit/harness test for transmission speed sender (B104/2)
Reference 245-EPC-109, Circuit Test for Enable Pressure Sender (B105)
Operational test for enable pressure sender (B105)
Circuit/harness test for enable pressure sender (B105)
Reference 245-EPC-110, Circuit Test for Clutch Pedal Switch (S72)
Operational test for clutch pedal switch (S72)
Circuit/harness test for clutch pedal switch
Reference 245-EPC-111, Circuit Test for Clutch Pedal Potentiometer (B65)
Operational test for clutch pedal potentiometer (B65)
Circuit/harness test for clutch pedal potentiometer (B65)
Reference 245-EPC-112, Circuit Test for Power/Eco Mode Switch (S85)
Operational test for Power/Eco mode switch (S85)
Circuit/harness test for Power/Eco Mode switch (S85)
Reference 245-EPC-113, Circuit Test for Upshift and Downshift Switches (S48, S49 and S81)
Operational test for upshift and downshift switches (S48 and S49)
Operational test of the rocker switch for upshift/downshift (S81)
Circuit/harness test for upshift and downshift switches (S48, S49 and S81)
Reference 245-EPC-114, Circuit Test for Transmission Enable Relay (K09/5)
Operational test for transmission enable relay (K09/5)
Circuit/harness test for transmission enable relay (K09/5)
Reference 245-EPC-115, Circuit Test for Come-Home Plug (K10/4)
Circuit test for Come-Home plug (K10/4)
Reference 245-EPC-116, Circuit Test for Reverse Drive Lever (A47)
Operational test for reverse drive lever (A47)
Circuit/harness test for forward switch
Circuit/harness test for reverse switch
Circuit/harness test for not-neutral switch
Circuit/harness test for detent coil in reverse drive lever
Reference 245-EPC-117, Circuit Test for Park Switch (S116)
Operational test for park switch (S116)
Circuit/harness test for park switch (S116)
Reference 245-EPC-118, Circuit Test for Power Mode and Eco Mode Indicator Lights
Operational test for Power mode and Eco mode indicator lights (H68 and H75)
Circuit/harness test for Power mode and Eco mode indicator lights (H68 and H75)
Reference 245-EPC-200, Theory of Operation
JDL - Control Unit for JDLink
Reference 245-JDL-001, JDLink Input Addresses
Reference 245-JDL-200 , JDLink - Theory of Operation
JDLink ł Connector Locations
JDLink ł Electrical Schematic
PLC - Park Lock Controller
Reference 245-PLC-001, Calibration and Input Addresses
Address PLC 247 — Input address for tractor model designation
Address PLC 248 — Input address for tractor serial number
Reference 245-PLC-100, Preliminary Check of PLC Circuit
Reference 245-PLC-101, Circuit Test for Park Lock Solenoid Valve (Y15-2)
Operational test for park lock solenoid valve (Y15-2)
Circuit/harness test for park lock solenoid valve (Y15-2)
Reference 245-PLC-102, Circuit Test for Transmission Output Speed Sender (B84)
Operational test for transmission output speed sender (B84)
Circuit/harness test for transmission output speed sender (B84)
Reference 245-PLC-103, Circuit Test for Park Lock Pressure Sender (B90)
Operational test for park lock pressure sender (B90)
Circuit/harness test for park lock pressure sender (B90)
Reference 245-PLC-104, Circuit Test for Acoustic Alarm (K10/2)
Operational test for acoustic alarm (K10/2)
Circuit/harness test for acoustic alarm (K10/2)
Reference 245-PLC-105, Circuit Test for Reverse Drive Lever (S80)
Operational test for reverse drive lever (S80)
Circuit/harness test for neutral, corner park and center park switches
Reference 245-PLC-200, Theory of Operation
PRF - Performance Monitor
Reference 245-PRF-001, Calibration and Input Addresses
Address PRF020 — Data Bus control function
Address PRF022 - Brightness of lighting
Address PRF023 - Setting the implement control arrow
Address PRF060 - Ground speed sensor
Address PRF070 - Diagnostic trouble code control function
Address PRF102 - Parameter for Engine Control Unit (ECU)
Reference 245-PRF-011, Calibration of Ground Speed Sensor (Radar)
Reference 245-PRF-021, Setting Wheel Slip Back to Zero
Reference 245-PRF-101, Circuit Test for Keypad Operation
Operational test of performance monitor
Reference 245-PRF-200, Theory of Operation
SFA - Control Unit for Front-Wheel Drive Axle and Cab Suspension
Reference 245-SFA-001, Calibration and Input Addresses (Front Wheel Drive Axle with TLS)
Address SFA 020 — Calibration address for FWD axle with TLS
Address SFA 033 — Input address, instrument panel (BIF)
Address SFA 035 — Input address, activate/de-activate FWD axle with TLS and cab suspension
Reference 245-SFA-100, Pre-Test of SFA Electrical Circuit
Reference 245-SFA-101, Circuit Test for Front-Wheel Drive Axle Solenoid Valves Y10 and Y11
Operational test for solenoid valves Y10 and Y11
Circuit/harness test for TLS solenoid valve (Y10)
Circuit/harness test for TLS solenoid valve (Y11)
Reference 245-SFA-102, Circuit Test for Cab Suspension Solenoid Valves Y42 and Y43
Operational test for solenoid valves Y42 and Y43
Circuit/harness test for cab solenoid valve (Y42)
Circuit/harness test for cab solenoid valve (Y43)
Reference 245-SFA-103, Circuit Test for TLS Position Sensor (B53)
Operational test for circuit of TLS position sensor (B53)
Circuit/harness test for TLS position sensor (B53)
Reference 245-SFA-104, Circuit Test for Cab Position Sensor (B110)
Operational test for circuit of cab position sensor (B110)
Circuit/harness test for cab position sensor (B110)
Reference 245-SFA-200, Theory of Operation
SIC - E-SCV/E-ICV Controller
Reference 245-SIC-001, Calibration and Input Addresses
Address SIC 020 - Calibration of selective control valves (E-SCV and E-ICV)
Address SIC 033 - Input address for instrument unit
Address SIC 036 - Activate input address for functions 1 to 3, Independent Selective Control Valve (E-ICV)
Address SIC 037 - Activate input address for functions 4 to 6, Selective Control Valves (E-ICV) No. 1 to 3
Address SIC 038 - Activate input address for function 7, Selective Control Valve (E-SCV) No. 4
Address SIC 039 - Input address for vibrator function of front loader bucket (E-ICV)
Address SIC 040 - Calibration for stepper motor identification
Address SIC 045 - Input address, automatic deletion of diagnostic trouble codes
Address SIC 247 - Input address for tractor model designation
Address SIC 248 - Input address for tractor serial number
Reference 245-SIC-100, Preliminary Check of SIC Circuit
Reference 245-SIC-101, Circuit Test for Multi-Function Lever (S64)
Operational test for multi-function lever (S64)
Circuit/harness test for function 1 (E-ICV)
Circuit/harness test for function 2 (E-ICV)
Circuit/harness test for function 3 (E-ICV)
Reference 245-SIC-102, Circuit Test for E-ICV Transport Lock Switch (S65)
Operational test for E-ICV transport lock switch (S65)
Circuit/harness test for E-ICV transport lock (S65)
Reference 245-SIC-103, Circuit Test for E-ICV Safety Switch (Integrated into S64)
Operational test for E-ICV safety switch (interlock switch actuator)
Circuit/harness test for E-ICV safety switch
Reference 245-SIC-104, Circuit Test for E-ICV no.1 Stepper Motor (M12)
Circuit/harness test for E-ICV no.1 stepper motor (M12), power supply
Circuit/harness test for CAN bus lines for no.1 stepper motor E-ICV (M12)
Reference 245-SIC-105, Circuit Test for E-ICV no.2 Stepper Motor (M13)
Circuit/harness test for E-ICV no.2 stepper motor (M13), power supply
Circuit/harness test for CAN bus lines for no.2 stepper motor E-ICV (M13)
Reference 245-SIC-106, Circuit Test for E-ICV no.3 Stepper Motor (M14)
Circuit/harness test for E-ICV no.3 stepper motor (M14), power supply
Circuit/harness test for CAN bus lines for no.3 stepper motor E-ICV (M14)
Reference 245-SIC-107, Circuit Test for E-SCV no.1, Potentiometer or Switch at Control Lever is Faulty
Operational test for E- SCV no.1, control lever's switch/potentiometer
Circuit/harness test for E-SCV no.1 (control lever's switch/potentiometer)
Reference 245-SIC-108, Circuit Test for E-SCV no.2, Potentiometer or Switch at Control Lever is Faulty
Operational test for E- SCV no.2, control lever's switch/potentiometer
Circuit/harness test for E-SCV no.2 (control lever's switch/potentiometer)
Reference 245-SIC-109, Circuit Test for E-SCV no.3, Potentiometer or Switch at Control Lever is Faulty
Operational test for E- SCV no.3, control lever's switch/potentiometer
Circuit/harness test for E-SCV no.3 (control lever's switch/potentiometer)
Reference 245-SIC-110, Circuit Test for E-SCV no.4, Potentiometer or Switch at Control Lever is Faulty
Operational test for E- SCV no.4, control lever's switch/potentiometer
Circuit/harness test for E-SCV no.4 (control lever's switch/potentiometer)
Reference 245-SIC-111, Circuit Test for E-SCV Transport Lock Switch (S110)
Operational test for E-SCV transport lock switch (S110)
Circuit/harness test for E-SCV transport lock (S110)
Reference 245-SIC-112, Circuit Test for E-SCV Function Adjustment Knob (B115)
Operational test for E-SCV function adjustment knob (B115)
Circuit/harness test for E-SCV function adjustment knob (B115)
Reference 245-SIC-113, Circuit Test for E-SCV no.1 Stepper Motor (M36)
Circuit/harness test for E-SCV no.1 stepper motor (M36), power supply
Circuit/harness test for CAN bus lines for no.1 stepper motor E-SCV (M36)
Reference 245-SIC-114, Circuit Test for E-SCV no.2 Stepper Motor (M37)
Circuit/harness test for E-SCV no.2 stepper motor (M37), power supply.
Circuit/harness test for CAN bus lines for no.2 stepper motor E-SCV (M37)
Reference 245-SIC-115, Circuit Test for E-SCV no.3 Stepper Motor (M38)
Circuit/harness test for E-SCV no.3 stepper motor (M38), power supply
Circuit/harness test for CAN bus lines for no.3 stepper motor E-SCV (M38)
Reference 245-SIC-116, Circuit Test for E-SCV no.4 Stepper Motor (M39)
Circuit/harness test for E-SCV no.4 stepper motor (M39), power supply
Circuit/harness test for CAN bus lines for no.4 stepper motor E-SCV (M39)
245-SIC-200, Theory of Operation
TCU - Control Unit for AutoPowr/IVT Transmission
Reference 245-TCU-001, Calibration and Input Addresses
Address TCU 20 — Transmission Calibration
Address TCU 25 — Vacant Input Address
Address TCU 26 — Vacant Input Address
Address TCU 44 — Input Address for Tractor Type
Address TCU 49 — Input addresses for output test mode
Reference 245-TCU-001A, Output Test Mode Chart
Reference 245-TCU-100, Preliminary Check of TCU Circuit
Reference 245-TCU-101, Circuit Test for Transmission Enable Signal from Relay K02/1 and Clutch Pedal Switch (S72)
Operational test for transmission enable signal from relay K02/1
Circuit/harness test for transmission enable signal from relay K02/1 and clutch pedal switch S72
Reference 245-TCU-102, Circuit Test for Oil Temperature Sender
Operational test for oil temperature sender
Circuit/harness test for oil temperature sender
Reference 245-TCU-103, Circuit Test for Transmission Oil Filter Switch (S73)
Operational test for transmission oil filter switch (S73)
Circuit/harness test for transmission oil filter switch (S73)
Reference 245-TCU-104, Circuit Test for Transmission Oil Pressure Switch (S74)
Operational test for transmission oil pressure switch (S74)
Circuit/harness test for transmission oil pressure switch (S74)
Reference 245-TCU-105, Circuit Test for Switch (B87) of Filter By-Pass Valve (Cold-Weather Starting)
Operational test for switch (B87) of filter by-pass valve (cold-weather starting)
Circuit/harness test for switch (B87) of filter by-pass valve (cold-weather starting).
Reference 245-TCU-106, Circuit Test for Transmission Input Speed Sender (B61)
Operational test for transmission input speed sender (B61)
Circuit/harness test for transmission input speed sender (B61)
Reference 245-TCU-107, Circuit Test for Transmission Output Speed Sender (B63)
Operational test for transmission output speed sender (B63)
Circuit/harness test for transmission output speed sender (B63)
Reference 245-TCU-108, Circuit Test for Hydrostatic Speed Sender (B62)
Operational test for hydrostatic speed sender (B62)
Circuit/harness test for hydrostatic speed sender (B62)
Reference 245-TCU-109, Circuit Test for Park Lock Solenoid Valve (Y15-1)
Operational test for park lock solenoid valve (Y15-1)
Circuit/harness test for park lock solenoid valve (Y15-1)
Reference 245-TCU-110, Circuit Test for C1 Solenoid Valve
Operational test for C1 solenoid valve
Circuit/harness test for C1 solenoid valve
Reference 245-TCU-111, Circuit Test for C2 Solenoid Valve
Operational test for C2 solenoid valve
Circuit/harness test for C2 solenoid valve
Reference 245-TCU-112, Circuit Test for C3 Solenoid Valve
Operational test for C3 solenoid valve
Circuit/harness test for C3 solenoid valve
Reference 245-TCU-113, Circuit Test for C4 Solenoid Valve
Operational test for C4 solenoid valve
Circuit/harness test for C4 solenoid valve
Reference 245-TCU-114, Circuit Test for BG Solenoid Valve
Operational test for BG solenoid valve
Circuit/harness test for BG solenoid valve
Reference 245-TCU-115, Circuit Test for Hydrostatic Unit Proportional Solenoid Valve (Y1)
Operational test for hydrostatic unit proportional solenoid valve (Y1)
Circuit/harness test for hydrostatic unit proportional solenoid valve (Y1)
Reference 245-TCU-116, Circuit Test for Hydrostatic Unit Proportional Solenoid Valve (Y2)
Operational test for hydrostatic unit proportional solenoid valve (Y2)
Circuit/harness test for hydrostatic unit proportional solenoid valve (Y2)
Reference 245-TCU-117, Circuit Test for CF Proportional Solenoid Valve of the Forward Clutch
Operational test for CF proportional solenoid valve of the forward clutch
Circuit/harness test for CF proportional solenoid valve of the forward clutch.
Reference 245-TCU-118, Circuit Test for CR Proportional Solenoid Valve of the Reverse Clutch
Operational test for CR proportional solenoid valve of the reverse clutch
Circuit/harness test for CR proportional solenoid valve of the reverse clutch
Reference 245-TCU-200, Theory of Operation
UIC - User Interface Controller
Reference 245-UIC-001, Calibration and Input Addresses
Address UIC 32 — Input address for anti-jack-knife control and front axle brake
Address UIC 33 — Input address for engine type (only with Stage II engine to 97/68/EC)
Address UIC 34 — Input address for speed displayed in km/h or mph
Address UIC 35 — Input address for automatic deletion of diagnostic trouble codes (Auto Purge)
Address UIC 36 — Input address for tractor type
Address UIC 42 — Input addresses for tire size (rolling radius)
Address UIC 43 — Input address for transmission ratio of front-wheel drive axle
Address UIC 49 — Input address for output test mode (enable relay)
Address UIC 247 — Input address for tractor model designation
Address UIC 248 — Input address for tractor serial number
Reference 245-UIC-100, Preliminary Check of UIC Circuit
Reference 245-UIC-101, Circuit Test for Reverse Drive Lever (S80)
Circuit/harness test, switches for forward travel, tractor movement and Power Zero
Circuit/harness test, switches for reverse travel, tractor movement and Power Zero
Reference 245-UIC-102, Circuit Test for Cruise Control Potentiometer (A19)
Operational test for cruise control potentiometer (A19)
Circuit/harness test for cruise control potentiometer (A19)
Reference 245-UIC-103, Circuit Test for AutoPowr Selector (B83)
Operational test for AutoPowr selector (B83)
Circuit/harness test for AutoPowr selector (B83)
Reference 245-UIC-104, Circuit Test for Speed Wheel on Speed Control Lever (S108)
Operational test for speed wheel
Circuit/harness test for speed wheel
Reference 245-UIC-105, Circuit Test for Speed Control Lever (S108 and B67)
Operational test for speed control lever (set speeds 1 and 2)
Circuit/harness test for Hall-type switch for speed control lever (S108)
Circuit/harness test for Hall-type potentiometer for speed control lever (B67)
Reference 245-UIC-106, Circuit Test for Hand Throttle Potentiometer (B78)
Operational test for hand throttle potentiometer (B78)
Circuit/harness test for hand throttle potentiometer (B78)
Reference 245-UIC-107, Circuit Test for Accelerator Pedal Potentiometer (B79)
Operational test for accelerator pedal potentiometer (B79)
Circuit/harness test for accelerator pedal potentiometer (B79)
Reference 245-UIC-108, Circuit Test for Brake Pedal Sensors (B88)
Operational test for brake pedal sensors (B88)
Circuit/harness test for brake pedal switches (B88)
Circuit/harness test for brake pedal potentiometers (B88)
Reference 245-UIC-109, Circuit Test for Clutch Pedal Potentiometer (B65)
Operational test for clutch pedal sensors (B65 and S72)
Reference 245-UIC-110, Circuit Test for Front-Wheel Drive Axle Speed Sender (B89)
Operational test for front-wheel drive axle speed sender (B89)
Circuit/harness test for front-wheel drive axle speed sender (B89)
Reference 245-UIC-111, Circuit Test for Air Brake Solenoid Valve (Y31)
Operational test for air brake solenoid valve (Y31)
Reference 245-UIC-112, Circuit Test for Seat Switch (S40)
Operational test for seat switch (S40)
Circuit/harness test for seat switch (S40)
Reference 245-UIC-113, Circuit Test for Come-Home Plug (K10/4)
Operational test for Come-Home plug (K10/4)
Reference 245-UIC-200, Theory of Operation
SYNCROPLUS TRANSMISSION
Introductory Checks
Reference 250-05-001, Introductory Checks for Transmission and Hydraulic Diagnosis
Introductory Checks
Reference 250-10-001, Syncroplus Transmission—Operational Checkout
Operational Checks
Reference 250-15-001, Syncroplus Transmission—System Check
System Check
Reference 250-15-002, Syncroplus Transmission—Checking System Pressure
Reference 250-15-003, Syncroplus Transmission—Adjusting System Pressure
Reference 250-15-004, Syncroplus Transmission—Checking Components Dependent on System Pressure
Reference 250-15-005, Syncroplus Transmission—Checking the Filter Relief Valve
Reference 250-15-006, Syncroplus Transmission—Checking the Engagement Override Valve and Clutch Pedal Valve
Reference 250-15-007, Syncroplus Transmission—Checking the Modulation of the Clutch Pedal Valve
Reference 250-15-008, Syncroplus Transmission—Checking the Lube Oil Pressure
Reference 250-15-009, Syncroplus Transmission—Checking the Cooling System
Reference 250-15-010, Syncroplus Transmission—Checking the Rate of Flow
Reference 250-15-011, Syncroplus Transmission—Checking the Cooler Relief Valve
Reference 250-15-012, Syncroplus Transmission—Checking the Transmission Oil Filter
Reference 250-15-013, Syncroplus Transmission—Layout of Test Ports and Sending Units
Reference 250-15-014, Syncroplus Transmission—Checking and Adjusting the Shift Units
Reference 250-15-015, Syncroplus Transmission—Adjusting the Park Lock
Reference 250-15-016, Syncroplus Transmission—Checking and Adjusting the Linkage on the Range Transmission
Reference 250-15-017, Syncroplus Transmission—Checking and Adjusting the Linkage on the Gear Transmission
Reference 250-15-018, Syncroplus Transmission—Checking and Adjusting the Neutral Start Switch
Reference 250-15-019, Syncroplus Transmission—Adjusting the Clutch Pedal
Operation
Reference 250-20-001, Syncroplus Transmission—Summary of References
Reference 250-20-010, Syncroplus Transmission—Layout
Reference 250-20-020, Syncroplus Transmission—Lubrication System
Reference 250-20-030, Syncroplus Transmission—Shift Linkage
Reference 250-20-040, Syncroplus Transmission—Synchronization
Reference 250-20-050, Syncroplus Transmission—Operation of Transmission Oil Circuit (including Diagram)
Reference 250-20-100, Perma Clutch II Module—Exploded View
Reference 250-20-110, Perma Clutch II Module—Layout
Reference 250-20-120, Perma Clutch II Module—Powerflow
Reference 250-20-130, Perma Clutch II Module—Transmission Oil Pump
Reference 250-20-140, Perma Clutch II Module—Hydraulic Circuit Diagram
Reference 250-20-150, Perma Clutch II Module—Description of Various Valves and Components
Reference 250-20-160, Perma Clutch II Module—Operation of Pressure Regulating Valve and Filter Relief Valve
Reference 250-20-170, Perma Clutch II Module—Operation of Clutch Pedal Valve and Engagement Override Valve
Reference 250-20-180, Perma Clutch II Module—Operation of Cooling System
Reference 250-20-200, Gear Transmission—Layout
Reference 250-20-210, Gear Transmission— Powerflow
Reference 250-20-220, Gear Transmission— Neutral Start Switch
Reference 250-20-300, Creeper Transmission— Layout and Operation
Reference 250-20-310, Creeper Transmission— Powerflow
POWER REVERSER
Reference 251-10-001, Power Reverser—Operational Checkout
Reference 251-15-001, Power Reverser—System Check
Reference 251-15-002, Power Reverser—Checking System Pressure
Reference 251-15-003, Power Reverser—Adjusting System Pressure
Reference 251-15-004, Power Reverser—Checking Components Dependent on System Pressure
Reference 251-15-005, Power Reverser—Checking the Filter Relief Valve
Reference 251-15-006, Power Reverser—Checking and Adjusting the Engagement Override Valve and Clutch Pedal Valve
Reference 251-15-007, Power Reverser—Checking the Disk Clutch and Disk Brake
Reference 251-15-008, Power Reverser—Checking the Lube Oil Pressure
Reference 251-15-009, Power Reverser—Checking the Cooling System
Reference 251-15-010, Power Reverser—Checking the Rate of Flow
Reference 251-15-011, Power Reverser—Checking the Cooler Relief Valve
Reference 251-15-012, Power Reverser—Checking the Transmission Oil Filter
Reference 251-15-013, Power Reverser—Adjusting the Modulation Time
Reference 251-15-014, Power Reverser—Layout of Test Ports and Sending Units
Reference 251-15-015, Power Reverser—Checking and Adjusting the Shift Units
Reference 251-15-016, Power Reverser—Adjusting the Park Lock
Reference 251-15-017, Power Reverser—Checking and Adjusting the Shift Linkage at the Range Transmission
Reference 251-15-018, Power Reverser—Checking and Adjusting the Shift Linkage at the Gear Transmission
Reference 251-15-019, Power Reverser—Adjusting the Reverse Drive Linkage
Reference 251-15-020, Power Reverser—Adjusting the Reverse Drive Lever
Reference 251-15-021, Power Reverser—Adjusting the Clutch Pedal
Reference 251-20-001, Power Reverser—Summary of References
Reference 251-20-010, Power Reverser—Layout
Reference 251-20-020, Power Reverser—Lubrication System
Reference 251-20-030, Power Reverser—Shift Linkage
Reference 251-20-040, Power Reverser—Synchronization
Reference 251-20-050, Power Reverser—Operation of Transmission Oil Circuit (including Diagram)
Reference 251-20-100, Power Reverser Module—Sectional View
Reference 251-20-110, Power Reverser Module—Components
Reference 251-20-120, Power Reverser Module—Layout and Powerflow
Reference 251-20-130, Power Reverser Module—Transmission Oil Pump
Reference 251-20-140, Power Reverser Module—Valves and Other Hydraulic Components
Reference 251-20-150, Power Reverser Module—Hydraulic Circuit Diagram
Reference 251-20-160, Power Reverser Module—Description of Various Valves and Components
Reference 251-20-170, Power Reverser Module—Operation of Pressure Regulating Valve and Filter Relief Valve
Reference 251-20-180, Power Reverser Module—Operation of Forward/Reverse Modulation
Reference 251-20-190, Power Reverser Module—Operation of Clutch Pedal Valve
Reference 251-20-200, Power Reverser Module—Operation of Engagement Override Valve
Reference 251-20-210, Power Reverser Module—Operation of Cooling System
Reference 251-20-300—Gear Transmission, Layout and Powerflow
AUTOPOWR/IVT TRANSMISSION
Reference 253-10-001, AutoPowr/IVT Transmission—Operational Checkout
Operational Checks
Reference 253-15-001, AutoPowr/IVT Transmission — Test Result Table
Reference 253-15-002, AutoPowr/IVT Transmission — Checking the Transmission Oil Circuit
Reference 253-15-005, AutoPowr/IVT Transmission — Test Ports (6320 to 6620)
Reference 253-15-006, AutoPowr/IVT Transmission — Test Ports (6820 and 6920)
Reference 253-15-010, AutoPowr/IVT Transmission — Checking System Pressure
Reference 253-15-011, AutoPowr/IVT Transmission — Checking Reduced System Pressure (Pressure for Other Consumers)
Reference 253-15-012, AutoPowr/IVT Transmission — Checking Oil Cooler Pressure
Reference 253-15-013, AutoPowr/IVT Transmission — Checking Lube Oil Pressure
Reference 253-15-014, AutoPowr/IVT Transmission — Checking Pressure at the C1 Clutch
Reference 253-15-015, AutoPowr/IVT Transmission — Checking Pressure at the C2 Clutch
Reference 253-15-016, AutoPowr/IVT Transmission — Checking Pressure at the C3 Clutch
Reference 253-15-017, AutoPowr/IVT Transmission — Checking Pressure at the C4 Clutch
Reference 253-15-018, AutoPowr/IVT Transmission — Checking Pressure at the BG Disk Brake
Reference 253-15-019, AutoPowr/IVT Transmission — Checking Pressure at the Forward Clutch (CF)
Reference 253-15-020, AutoPowr/IVT Transmission — Checking Pressure at the Reverse Clutch (CR)
Reference 253-15-021, AutoPowr/IVT Transmission — Checking Park Lock Pressure
Reference 253-20-001, AutoPowr/IVT Transmission — Operation (Summary of References)
Reference 253-20-010, AutoPowr/IVT Transmission — Operation
Reference 253-20-011, AutoPowr/IVT Transmission — Layout of Transmission Sub-Assembly
Reference 253-20-012, AutoPowr/IVT Transmission — Sectional View of Transmission
Reference 253-20-013, AutoPowr/IVT Transmission — Transmission Peripherals
Reference 253-20-014, AutoPowr/IVT Transmission — Transmission Control Components
Reference 253-20-015, AutoPowr/IVT Transmission — Transmission Control
Reference 253-20-016, AutoPowr/IVT Transmission — Description of Transmission Oil Circuit
Reference 253-20-017, AutoPowr/IVT Transmission — Description of System Pressure Control Block
Reference 253-20-018, AutoPowr/IVT Transmission — Description of Clutch Control Block
Reference 253-20-019, AutoPowr/IVT Transmission — Operation of Hydrostatic Unit
Reference 253-20-020, AutoPowr/IVT Transmission — Diagram of Transmission
Reference 253-20-021, AutoPowr/IVT Transmission — Summary of Engaged Elements
Reference 253-20-022, AutoPowr/IVT Transmission — Power Flows
Reference 253-20-023, AutoPowr/IVT Transmission — Oil Flows
Reference 253-20-024, AutoPowr/IVT Transmission — Operation of Park Lock
Reference 253-20-025, AutoPowr/IVT Transmission — Shift Controls
POWRQUAD, POWRQUAD PLUS AND AUTOQUAD TRANSMISSIONS
Reference 255-10-001, PowrQuad Transmission—Operational Checkout
Operational Check
Reference 255-15-001, PowrQuad Transmission—System Check
System check
Reference 255-15-002, PowrQuad Transmission—Test Ports
Reference 255-15-003, PowrQuad Transmission—Checking Rate of Flow at Cooler
Reference 255-15-004, PowrQuad Transmission—Checking System Pressure
Reference 255-15-005, PowrQuad Transmission—Checking Lube Oil Pressure
Reference 255-15-006, PowrQuad Transmission—Checking Cooling Oil Pressure (Forward Clutch)
Reference 255-15-007, PowrQuad Transmission—Checking Cooling Oil Pressure (Reverse Brake)
Reference 255-15-008, PowrQuad Transmission—Checking Pressure at Forward Clutch
Reference 255-15-009, PowrQuad Transmission—Checking Pressure at Reverse Brake
Reference 255-15-010, PowrQuad Transmission—Checking Pressure at B1 Brake
Reference 255-15-011, PowrQuad Transmission—Checking Pressure at B2 Brake
Reference 255-15-012, PowrQuad Transmission—Checking Pressure at B3 Brake
Reference 255-15-013, PowrQuad Transmission—Checking Pressure at C4 Clutch
Reference 255-15-014, PowrQuad Transmission—Adjusting System Pressure
Reference 255-15-015, PowrQuad Transmission—Test Result Table
Reference 255-15-016, PowrQuad Transmission—Adjusting the Reverse Drive Linkage
Reference 255-15-017, PowrQuad Transmission—Shift Linkage and Park Lock
Reference 255-15-018, Adjusting the Reverse Drive Lever (Reverser Control on Steering Column)
Reference 255-15-019, Checking and Adjusting the Shift Mechanisms/Linkages (PowrQuad Plus & AutoQuad Transm.)
Reference 255-20-001, PowrQuad, PowrQuad Plus and AutoQuad Transmissions—Summary of References
Reference 255-20-050, PowrQuad Transmission—Layout
Reference 255-20-100, PowrQuad Module—Layout
Reference 255-20-280, PowrQuad Module—Sectional and 3D View
Reference 255-20-290, PowrQuad Module—Location of Valves, Sensors and Switches
Reference 255-20-110, PowrQuad Module—Element Engagement Chart
Reference 255-20-120, PowrQuad Module—Pneumatic Pump
Reference 255-20-130, PowrQuad Module—Transmission Oil Pump
Reference 255-20-140, PowrQuad Module—Pressure-Regulating Valve and Filter Relief Valve
Reference 255-20-150, PowrQuad Module—Overspeed Relief Valve and Anti-Cavitation Check Valve
Reference 255-20-160, PowrQuad Module—Clutch Cooling Components
Reference 255-20-170, PowrQuad Module—Clutch Cooling Valve (Forward/Reverse)
Reference 255-20-180, PowrQuad Module—System 1 Oil and System 2 Oil
Reference 255-20-190, PowrQuad Module—Hydraulic Schematic, Mechanically Actuated PowrQuad Module
255-20-200, PowrQuad Module—Operation of Forward/Reverse Modulation, Mechanically Actuated PowrQuad Module
Reference 255-20-210, PowrQuad Module—Neutral Start Circuit, Mechanically Actuated PowrQuad Module
Reference 255-20-220, PowrQuad Module—Operation of Gear-to-Gear Modulation, Mechanically Actuated PowrQuad Module
Reference 255-20-230, PowrQuad Module—Hydraulic Schematic, Electrically Actuated PowrQuad Module
Reference 255-20-240, PowrQuad Module—Operation of Forward/Reverse Modulation, Electrically Actuated PowrQuad Module
Reference 255-20-250, PowrQuad Module—Operation of Gear-to-Gear Modulation, Electrically Actuated PowrQuad Module
Reference 255-20-260, PowrQuad Module—Reverse Drive Lever and Gear Shift Lever, Mechanically Actuated PowrQuad Module
Reference 255-20-270, PowrQuad Module—Reverse Drive Lever and Range Shift Lever with Gearshift Switches, Electrically Actuated PowrQuad Module
Reference 255-20-400, PowrQuad Plus and AutoQuad Transmissions—Summary of Transmission Versions
Reference 255-20-410, PowrQuad Plus and AutoQuad Transmissions—Sub-Assemblies
Reference 255-20-420, PowrQuad Plus Transmission—Description of Shift Functions
Reference 255-20-430, AutoQuad Transmission—Description of Shift Functions
Reference 255-20-440, PowrQuad Plus and AutoQuad Transmissions—Description of Clutch Actuation
Reference 255-20-500—Range Transmission (6020-6620 Tractors), Layout
Reference 255-20-510—Range Transmission (6020-6620 Tractors), Power-Flows
Reference 255-20-520—Range Transmission, Park Lock (6020-6620 Tractors)
Reference 255-20-530, Range Transmission (6820 and 6920 Tractors)—Layout
Reference 255-20-700, Creeper Transmission (6020-6620 Tractors)—Operation
Reference 255-20-710, Creeper Transmission (6020-6620 Tractors)—Powerflow
Reference 255-20-720, Creeper Transmission (6820 and 6920 Tractors)—Operation
DRIVE SYSTEMS
Reference 256-10-001, Drive Systems—Operational Check
Operational check
Reference 256-15-001, Drive Systems—System Check
Reference 256-15-002, Checking Pressure at the Front-Wheel Drive Clutch
Reference 256-15-003, Checking Pressure at the Hydraulic Differential Lock
Reference 256-15-004, Checking Pressure at the Rear PTO
Reference 256-15-005, Checking Pressure at the Front PTO
Reference 256-15-006, Drive Systems—Test Result Table
Reference 256-15-007, Front PTO—Adjusting System Pressure
Reference 256-20-001, Drive Systems—Summary of References
Reference 256-20-100, Front-Wheel Drive Clutch (6020 to 6620 Tractors)—Layout
Reference 256-20-110, Front-Wheel Drive Clutch (6020 to 6620 Tractors)—Oil-Flow and Power-Flow
Reference 256-20-120, Front-Wheel Drive Clutch (6020 to 6620 Tractors)—Cooling and Lubrication
Reference 256-20-130, Front-Wheel Drive Clutch (6820 and 6920 Tractors)—Layout
Reference 256-20-140, Front-Wheel Drive Clutch (6820 and 6920 Tractors)—Oil-Flow and Power-Flow
Reference 256-20-200, Differential (6020 to 6620 Tractors)—Layout
Reference 256-20-210, Differential (6820 and 6920 Tractors)—Layout
Reference 256-20-220, Differential—Power-Flows
Reference 256-20-230, Differential—Oil-Flows
Reference 256-20-300, Final Drives (6020 to 6620 Tractors)—Operation and Layout
Reference 256-20-310, Final Drives (6820 and 6920 Tractors)—Operation and Layout
Reference 256-20-400, Rear PTO Options—Description
Reference 256-20-410, Rear PTO Options—PTO Modulating Valve and Solenoid Valve
Reference 256-20-420, Rear PTO Options—PTO Clutch and PTO Brake
Reference 256-20-430, Rear PTO Options (6820 and 6920 Tractors)—Lube Cut-Off Valve
Reference 256-20-440, Rear PTO Options—Power-Flows
Reference 256-20-500, Front PTO Options—Operation
Reference 256-20-510, Front PTO Options—Description, Hydraulic Circuit
Reference 256-20-520, Front PTO Options—PTO Modulating Valve and Solenoid Valve
Reference 256-20-530, Front PTO Options—Hydraulic Pump
Reference 256-20-540, Front PTO Options—Oil Cooler
STEERING AND BRAKES
Reference 260-10-001, Safety Information
Reference 260-10-010, Steering Check
Reference 260-10-010, Brake Check
Reference 260-15-001, Tests and Adjustments—Summary of References
Reference 260-15-010, Special Tools
Reference 260-15-020, Connecting SensoControl Test Equipment
Reference 260-15-030, Specifications
Reference 260-15-040, Checking the Steering Valve
Reference 260-15-050, Checking the Brake System
Reference 260-15-060, Bleeding the Brakes (Brake Valve, Power-Fill Brakes and MFWD and Disk Brake)
Reference 260-15-070, Adjusting the Brake Pedals and Switches
Reference 260-15-080, Handbrake Checks
Reference 260-15-090, Checking the Trailer Brake Valve
Reference 260-15-100, Adjusting the Trailer Brake Valve
Reference 260-15-110, Checking the Air Brake (Visual Inspection)
Reference 260-15-120, Checking the System for Leaks
Reference 260-15-130, Checking the "Supply" Coupling End
Reference 260-15-140, Checking the Pressure Limiting Valve (Tractors with MFWD and Disk Brake)
Reference 260-15-150, Checking the Dual-Line Brake Valve
Reference 260-15-160, Checking the Single-Line Brake Valve
Reference 260-15-170, Adjusting the Handbrake and Air Brakes
Reference 260-20-001, Operation — Summary of References
Reference 260-20-010, Description of Steering Valves, Operation
Reference 260-20-020, Brake Valve (with Power Fill), Operation
Reference 260-20-030, Brake Valve (with MFWD and Disk Brakes), Operation
Reference 260-20-040, Rear Wheel Brakes, Operation
Reference 260-20-050, Handbrake, Description
Reference 260-20-060, Trailer Brake Valve, Description
260-20-080, Description of Air Brake System
HYDRAULIC SYSTEM
270-10-010, Hydraulic System Load Check
Reference 270-10-020, Hitch Control - Operational Checkout
Reference 270-10-030, External Control of Hitch - Operational Checkout
Reference 270-10-040, Selective Control Valves - Operational Checkout
Reference 270-15-001, Safety Measures for Hydraulic Checks
Reference 270-15-010, Heating Up Hydraulic Oil
Reference 270-15-011, Hydraulic System — Oil Pressure Test Ports
Reference 270-15-012, Checking the PFC Hydraulic System
Reference 270-15-013, PFC Hydraulic System — Test Result Table
Reference 270-15-020, Checking the PC Hydraulic System
Reference 270-15-021, PC Hydraulic System — Test Result Table
Reference 270-15-030, Charge Pump — Checking Lube Oil Pressure
Reference 270-15-031, Charge Pump — Checking the Delivery Rate
Reference 270-15-050, Hydraulic Pump — Testing and Adjusting the System Pressure (PFC Hydraulic System)
Reference 270-15-051, Hydraulic Pump — Checking the Delivery Rate (PFC Hydraulic System)
Reference 270-15-052, Hydraulic Pump—Checking the Delivery Rate (PC Hydraulic System)
Reference 270-15-053, Hydraulic Pump — Checking the Pressure-and-Flow Regulator
Reference 270-15-070, Checking the Pressure Differential Dynamically (PFC Hydraulic System Only)
Reference 270-15-071, Checking the LS (Load-Sensing) Pressure
Reference 270-15-090, Selective Control Valves — Check for Leaks at Valve Spools (PFC Hydraulic System Only)
Reference 270-15-091, Selective Control Valves (SCV) — Checking for Leaks in Couplers
Reference 270-15-092, 300 and 301 Series Selective Control Valves—Adjust Detent Kickout Relief Valve Parts
Reference 270-15-093, Selective Control Valves—Adjusting Left Endplate With Additional LS Port For External Consumers
Reference 270-15-094, Selective Control Valves—Adjusting Right Endplate With Additional Ports For External Consumers
Reference 270-15-110, Checking the Stepper Motor and Rockshaft Valve
Reference 270-15-130, Rockshaft Valve — Checking for Leaks
Reference 270-15-131, Rockshaft Valve — Checking the Pressure-Relief Valve
Reference 270-15-132, Rockshaft Valve — Checking Depth to Which Pressure and Discharge Valves are Screwed In
Reference 270-15-150, Rockshaft Valve — Checking the Position Sensor
Reference 270-15-151, Rockshaft—Testing and Adjusting the Draft Sensors (6020 to 6620)
Reference 270-15-152, Rockshaft — Testing and Adjusting the Draft Potentiometer (6820 to 6920S)
Reference 270-15-170, Adjusting the Power Beyond Valve
Reference 270-20-001, PFC Hydraulic System—Summary of References
Reference 270-20-002, PC Hydraulic System—Summary of References
Reference 270-20-010, PFC Hydraulic System — Description
Reference 270-20-020, PFC Hydraulic System—Operation
Reference 270-20-030, PFC Hydraulic System—Symbolic Representation
Reference 270-20-040, PFC Hydraulic System—Schematic View
Reference 270-20-050, PFC Hydraulic System — Three-Dimensional View
Reference 270-20-060, PC Hydraulic System—Description
Reference 270-20-070, PC Hydraulic System—Operation
Reference 270-20-080, PC Hydraulic System—Symbolic Representation
Reference 270-20-090, PC Hydraulic System—Schematic View
Reference 270-20-100, PC Hydraulic System—Three-Dimensional View
Reference 270-20-110, PFC Hydraulic System — Charge Pump, Description and Operation
Reference 270-20-120, PFC Hydraulic System—Description of Hydraulic Pump
Reference 270-20-130, PFC Hydraulic System—Oil Lines of Hydraulic Pump
Reference 270-20-140, PFC Hydraulic System — Operation of Hydraulic Pump
Reference 270-20-150, PFC Hydraulic System—Hydraulic Pump Operating Modes
Reference 270-20-160, PC Hydraulic System—Description of Hydraulic Pump
Reference 270-20-170, PC Hydraulic System—Oil Lines of Hydraulic Pump
Reference 270-20-180, PC Hydraulic System—Operation of Hydraulic Pump
270-20-190, Primary Hydraulic Oil Filter — Description
Reference 270-20-200, Hydraulic Oil Cooler — Description
Reference 270-20-210, PFC Hydraulic System—Description of Hydraulic Oil Filter
Reference 270-20-220, PC Hydraulic System—Description of Hydraulic Oil Filter
Reference 270-20-230, PC Hydraulic System—Description of Lube Priority Valve
Reference 270-20-240, PFC Hydraulic System—Description and Arrangement of Shuttle Valves
Reference 270-20-250, PFC Hydraulic System — Operation of Shuttle Valves
Reference 270-20-260, PC Hydraulic System—Description and Arrangement of Shuttle Valves
Reference 270-20-270, PFC Hydraulic System—Description of Main Block with Priority Valve
Reference 270-20-280, PFC Hydraulic System — Operation of Priority Valve in Main Block
Reference 270-20-290, PC Hydraulic System—Description of Main Block with Priority Valve and By-Pass Valve
Reference 270-20-300, PC Hydraulic System—Operation of Priority Valve and By-Pass Valve
Reference 270-20-310, Power Beyond Valve — Operation
Reference 270-20-320, Rockshaft — Description
Reference 270-20-330, Rockshaft — Operation of Rockshaft Control
Reference 270-20-340, Rockshaft — Operation of Rockshaft Valve
Reference 270-20-350, Rockshaft — Operation of Position Sensor
Reference 270-20-360, Rockshaft — Operation of Draft Sensor
Reference 270-20-370, Rockshaft — Description of Controls
Reference 270-20-380, Rockshaft — Direct Actuation
Reference 270-20-390, 100, 200 and 300 Series Selective Control Valves (Mechanically Actuated)—Description
Reference 270-20-400, 100 Series Selective Control Valve (Mechanically Actuated) — Operation
Reference 270-20-410, 200 Series Selective Control Valve (Mechanically Actuated) — Operation
Reference 270-20-420, 300 Series Selective Control Valve (Mechanically Actuated) — Operation
Reference 270-20-430, Selective Control Valves (Electrically Actuated)—Description
Reference 270-20-435, Selective Control Valves (Electrically Actuated) — Description of Controls
Reference 270-20-440, Selective Control Valves (Electrically Actuated)—Operation
Reference 270-20-470, 101, 201 and 301 Series Selective Control Valves—Description
Reference 270-20-480, Couplers — Description
Reference 270-20-490, Endplate of Selective Control Valves — Summary
Reference 270-20-500, Independent Control Valve—Description
Reference 270-20-505, Independent Control Valve (Electrically Actuated)—Description of Controls
Reference 270-20-510, Independent Control Valve — Operation
MISCELLANEOUS
Reference 280-10-001, Front-Wheel Drive Axle with TLS—Operational Checkout
Reference 280-15-001, Front-Wheel Drive Axle with TLS—System Check
Reference 280-15-002, Front-Wheel Drive Axle with TLS—Checking and Adjusting the Nitrogen Precharge
Reference 280-15-003, Front-Wheel Drive Axle with TLS—Adjusting the Sensor Rod (Position Sensor to Panhard Link)
Reference 280-15-004, Front-Wheel Drive Axle with TLS—Test Result Table
Reference 280-20-001, Front-Wheel Drive Axle with TLS—Summary of References
Reference 280-20-100, Front-Wheel Drive Axle with TLS—Components
Reference 280-20-110, Front-Wheel Drive Axle with TLS—Operation
Reference 280-20-120, Front-Wheel Drive Axle with TLS—Description, Level Control
Reference 280-20-130, Front-Wheel Drive Axle with TLS—Position Sensor
Reference 280-20-140, Front-Wheel Drive Axle with TLS—Electronic Control Unit (SFA)
Reference 280-20-150, Front-Wheel Drive Axle with TLS—Control Block, Exploded View
Reference 280-20-160, Front-Wheel Drive Axle with TLS—Control Block, Sectional View
Reference 280-20-170, Front-Wheel Drive Axle with TLS—Hydraulic Circuit Diagram, Suspension Function
Reference 280-20-180, Front-Wheel Drive Axle with TLS—Hydraulic Circuit Diagram, Level Control (Up)
Reference 280-20-190, Front-Wheel Drive Axle with TLS—Hydraulic Circuit Diagram, Level Control (Down)
OPERATOR'S CAB
Operational Checkout (Summary of References)
Reference 290-10-002, Air Conditioning System, Heater Unit and Operator's Seat—Test Sequence
Reference 290-10-003, Hydro-pneumatic Cab Suspension—Test Sequence
290-15-001, Tests/Adjustments—Summary of References
Reference 290-15-010, Safety at Work
Reference 290-15-015, Handling Refrigerant
Reference 290-15-020, Safety Equipment
Reference 290-15-025, In an Emergency
Reference 290-15-030, Storage of Refrigerant Containers
Reference 290-15-035, R134a Refrigerant
Reference 290-15-040, Important
Reference 290-15-050, Special Tools
290-15-060, Specifications
290-15-065, Explanation of Checks
Air conditioning system, checks
Reference 290-15-070, Pressure Deviations
Reference 290-15-080, MSG95 Operator's Seat Checks
Weight and height setting not functioning in upward direction
Weight and height setting not functioning in downward direction
Spring collapses after a short interval
Spring can be lowered properly, but does not pump up from the lowest position
Spring can be pumped up to the uppermost position, but does not deflate
Spring can be pumped up and lowered, but returns to its original height
290-15-100, Hydro-Pneumatic Cab Suspension — System Check
290-15-110, Hydro-Pneumatic Cab Suspension — Checking and Adjusting the Nitrogen Precharge
Checking and adjusting the nitrogen precharge
Reference 290-15-120, Hydro-pneumatic Cab Suspension—Adjusting the Sensor Rod
290-15-130, Hydro-Pneumatic Cab Suspension — Test Result Table
Reference 290-20-001, Operation of Air-Conditioner/Heater/Air Vents—Summary of References
Reference 290-20-002, Operation of Hydro-pneumatic Cab Suspension—Summary of References
Reference 290-20-010, Principle of Heat Exchange
Reference 290-20-015, R134a Refrigerant
Reference 290-20-020, Refrigerant Circuit Layout (6120 to 6920S Tractors)
Reference 290-20-025, Refrigerant Circuit Layout (SE-Tractors)
Reference 290-20-030, Refrigerant Circuit Operation
Reference 290-20-035, Component Description
Reference 290-20-040, Heating and Ventilation (6120 to 6920S Tractors)
Reference 290-20-045, Heating and Ventilation (SE-Tractors)
290-20-050, Hydro-Pneumatic Cab Suspension — Components
290-20-055, Hydro-Pneumatic Cab Suspension — Operation
290-20-060, Hydro-Pneumatic Cab Suspension — Description of Level Control
290-20-065, Hydro-Pneumatic Cab Suspension — Position Sensor
290-20-070, Hydro-Pneumatic Cab Suspension — Spherical Bearings
290-20-075, Hydro-Pneumatic Cab Suspension — Hydraulic Cylinders/Accumulators
Reference 290-20-080, Hydro-pneumatic Cab Suspension—Control Unit (SFA)
Reference 290-20-085, Hydro-pneumatic Cab Suspension—Control block, components
Reference 290-20-090, Hydro-Pneumatic Cab Suspension — Hydraulic Diagram "Raising"
290-20-095, Hydro-Pneumatic Cab Suspension — Hydraulic Diagram "Lowering"
290-20-100, Hydro-Pneumatic Cab Suspension — Hydraulic Diagram "Suspension Function"
SPECIAL TOOLS (Dealer-Fabricated)
Special Tools (Dealer-Fabricated)
Reference 299-05-001, Special Tools (Dealer-Fabricated) — Summary
Reference 299-05-010, Holding Tool
Reference 299-05-011, Adjusting Tool
Reference 299-05-012, DFRW2—Needle Valve Test Hose Assembly
Reference 299-05-013, DFRW85—Reverse Brake Test Plate
Reference 299-05-014, DFLX10 and DFLX11—Test Harnesses
Reference 299-05-015, DFLX12—Special Tool for 11-BIT and 29-BIT CAN BUS
Reference 299-05-016, DFLX14—Solenoid Test Harness
Page Numbers
- JOHN DEERE CODE DTC LIST
