Martin Welker
104
230,310
John Deere 6010 6110 6210 6310 6410 Tractors Operators Manual OMAL116289
Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 6010 6110 6210 6310 6410 Tractors
Part Number: OMAL116289
Number of Pages: 257 Pages
Identification Views
Safety
Safety Decals
Controls and Instruments
Vehicle controls
PTO and creeper controls
Attachment controls
Heater and air conditioning controls
Operating the digital display
Indicator lights
Fuel gauge
Coolant temperature gauge
Digital display
Travel speed
Engine speed
PTO speed
Time of day (clock)
Operating hours
Gear
Performance monitor
Data entry
Operating
Calibration
Wheel slip
Vehicle speed
Service
Backlight brightness
Lights
H4 farm headlights
Light switch
Hazard warning lights
Turn signals and horn
Work lights
Operator’s Platform and Cab
Roll-over protective structure
Page
Seat belt
Operator’s seat
Windshield wiper
Blower and air louvers
Heater
Air-conditioning system
Cooling cans of drink
Storage rack
Dome and console lights
Adjusting the steering wheel
Beacon light
Adjusting the access step
Cool box
Monitor installation
Cigarette lighter and ashtray
Roof hatch
Break-In Period
After the first 4 and 8 hours of operation
Within the first 100 hours of operation
After the first 100 hours of operation
Prestarting Checks
Operating the Engine
Starting the engine
Electrical starting aid
Coolant heater
Booster battery
Fuel preheater
Towing the tractor
Parking the tractor
Stopping the engine
Operating the Tractor
Reduce fuel consumption
Correct ground travel speed
Travel speeds, SyncroPlus transmission
Shifting SyncroPlus transmission
Travel speeds, PowrQuad transmission
Shifting PowrQuad transmission
Shift positions, PowrQuad transmission
Shifting PowrQuad Plus transmission
Shifting AutoQuad transmission
Engaging creeper transmission
Engaging front-wheel drive
Differential lock
Foot brakes
Rockshaft and Three-Point Hitch
Operating the rockshaft
With Headland Management System
(HMS)
Remote control
Depth adjustment
Three-point hitch
Draft links
Attaching implements
Center link
Lift links
Sway blocks
Power Take-Off
PTO guard
Operating the PTOs
Changing speed of shiftable rear PTO
Attaching PTO-driven equipment
Ballast
Ballast
Measuring rear wheel slip
Rear wheel weights
Filling tires with liquid ballast
Pre-assembling the pick-up weight
Attaching to three-point hitch (rear-end
attachment)
Attaching to basic weight
Attaching to three-point hitch (front-end
attachment)
Front weights
Wheel Tread, Tires
Front wheel tread adjustment
Adjusting the fenders
Rear wheel tread adjustment
Tires
Page
Tire combinations with front-wheel drive
Additional Equipment
Selective control valves
Control lever
Couplers
Maximum permissible oil withdrawal
Additional oil reservoir
Power Beyond valve
Remote hydaulic cylinder
Swinging drawbar
Trailer hitches
Pick-up hitch
Transport
Fuel, Lubricants, Hydraulic Oil and Coolant
Fuel
Engine oil
Transmission/hydraulic oil
FWD axle oil
Grease
Coolant
Lubrication and Periodic Service
Opening hood
Removing grille screens
Access to battery
Access to fuses
Service chart
Service intervals
Service / Daily or Every 10 Hours
Engine crankcase oil level
Checking the lights
Other service jobs
Service / Every 250 Hours
Changing engine oil
Changing engine crankcase filter element
Checking transmission oil level
Battery service
Lubricating front axle
Checking oil level in FWD axle
Three-point hitch
Trailer hitches
Checking neutral start circuit
Service / Every 500 Hours
Changing the fuel filter
Lubricating rear axle
Air intake hoses
Service / Every 750 Hours
Checking engine speeds
Changing transmission oil filters
Service / Every 1500 Hours or 2 Years
Changing coolant
Changing oil in FWD axle
Service / As Required
Engine air cleaner
Secondary (safety) element
Cab air filters
Service - air conditioning system
Adjusting the handbrake
Bleeding the hydraulic brakes
Fuel filter
Bleeding the fuel system
Operator’s seat
Starting motor
Fuses
Troubleshooting
Hydraulic system
Electrical system
Diagnostic Codes
Storage
Storage for a lengthy period
Taking tractor out of storage
Specifications
PTO power output
Axle loads and weights
Electrical system
Capacities
Sound level
Tire loading limits
Safety note regarding electrical
appliances
Page
Serial Numbers
Index
