John Deere 600 Series Rigid and Flex Cutting Platforms Operators Manual OMSKD600MY23T
- Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Rigid and Flex Cutting Platforms
Model: John Deere 600 Series Rigid and Flex Cutting Platforms
Serial Number: 140100-
Part Number: OMSKD600MY23T
Number of Pages: 100 Pages
Introduction
Foreword
A Message to Our Customers
Intended Use
Trademarks
Identification View
Identification View
Safety Features
Header Safety Features
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
French and Spanish Safety Signs and Operators's Manual
Replace Safety Signs
Operators Ability
Ballasting for Safe Ground Contact
Parking and Leaving the Machine
Prepare for Emergencies
Wear Protective Clothing
Stay Clear of Harvesting Units
Keep Hands Away From Knives
Use Safety Lights and Devices
Transport Combine with Front-End Equipment Attached Safely
Road Transport Disconnect Switch
Practice Safe Maintenance
Avoid Contact With Moving Parts
Stay Clear of Cutterbar When Rotating Auger
Stay Clear of Rotating Drivelines
Guards and Shields
Avoid High-Pressure Fluids
Service Machines Safely
Service Belts and Chains Safely
Protect Against High Pressure Spray
Support Machine Properly
Store Attachments Safely
Safety Signs-Except North America
Pictorial Safety Signs
Operators’s Manual
Hydraulic Oil and Gas Under Pressure
Rotating Driveline
Reel Safety Stops
Side Shield
Cutterbar Movement
Header Entanglement
Safety Signs-North America Only
Safety Signs Location—Flex Platforms Only
Attaching and Detaching
Location of the Rear Auger Stripper Extension
Identification of Coupling Type
Coupling Header to Combine—Multicoupler
Coupling Header to Combine—Multi-Point
Removing Header from Feeder House—Multicoupler
Removing Header from Feeder House—Multi-Point
Unlocking Feeder House Manually
Location of Locking Cable Shear Screws
Transporting
Transporting on Trailer
Transporting on Combine
Operating the Platform
Choice of Harvesting Time
Cutting Platform Operation
Description of Automatic Header Height Control Systems
Operating Flex Platforms—HYDRAFLEX™ System Pressure
Header Height Sensing—HYDRAFLEX™ Heads with Auxiliary Sensors
Wiring Harness Information—Only for Headers Equipped with Height Sensor
Operating Flex Platform in Rigid Mode
Auxiliary Sensor Arm Operating Positions
Flex System Lock for Rigid Mode Operation–Only for Headers Equipped with Height Sensor
Operating and Servicing Requirements—Only for Headers Equipped with Height Sensor
Checking Platform Speeds
Reel Operation
Cutting Platform Controls
Position Warning Lights for Field Operation
Combining Oats, Sorghum, Wheat, and Sunflowers in Dry Ground Conditions
Combining Oats, Sorghum, and Wheat in Damp or Wet Ground Conditions
Combining Oats, Sorghum, Barley, and Wheat in Short, Thin Crops—Rigid Platforms
Combining Rice—Rigid Platforms
Combining Soybeans—Flex Platforms
Attachments and Options
Auger Flight Extensions (Attachment)—Flex Platforms
Auger Speeds (Attachment)
Stubble Lights (Optional)—Flex Platforms
Fine Serrated Knife (Optional)
Knife Assemblies with Long-Short Sections (Optional)
Knife Drive Sheaves (Attachment)
Heavy-Duty Wear Plates—Rigid Platforms
Reel Position Resume (Attachment)—S Series Combines
Short Dividers (Optional)—Flex Platforms
Spare Knife Storage (Attachment)
Raised Height Skid Shoes (Optional)
Low Stone Dam (Attachment or Option)
High Stone Dam (Attachment or Option)
Calibration and Settings
When to Calibrate
Calibration Error Codes
Calibration Procedures
Adjustments — Flex Platform
Adjust Platform Cutterbar/Skid Plate Tilt
Adjusting Head Drop Rate
Standard PERMA-GLIDE™ Divider Points
Adjusting Standard PERMA-GLIDE™ Divider Point Height
Side-to-Side Adjustment of Front Section of Standard PERMA-GLIDE™ Point
Adjustments — Rigid Platform
Cutterbar Positions
Adjusting Cutterbar Fore/Aft
Adjusting Platform Cutterbar/Skid Plate Tilt
Adjustments — Auger and Stripper
Auger Configuration Information Sign
Remove Knife Drive Belt from Drive Sheave
Adjusting Auger Position
Adjusting Auger Height
Adjusting Auger Fore/Aft
Adjusting Center Auger Finger Timing
Adjusting Rear Stripper
Adjusting Floor Stripper
Adjusting Auger Chain
Adjustments — Reel
Adjust Reel Fingers
Adjusting Minimum Reel Height and Leveling Reel
Adjusting Width Between Reel Arms
Adjusting Reel Fore/Aft and Lift Cylinders
Rephase Hydraulic Reel Fore/Aft
Rephasing Reel Lift Cylinders
Bleeding the Reel Lift Cylinder System
Adjusting Reel Speed Ratio Sensor
Adjusting Reel Drive Gear
Adjusting Platform Height Restoring System
Lubricants
Gear Oil
Mixing of Lubricants
Lubricant Storage
Multipurpose Grease
Lubrication and Service
Lubrication Intervals Information Sign
Lubrication Symbols
Care and Maintenance of Belts
Every 50 Hours of Operation
Every 200 Hours of Operation
Every 400 Hours of Operation
Troubleshooting
Cutterbar Difficulties
Down and Tangled Crops Difficulties
Feeder House Difficulties
Auger Difficulties
Cutting Difficulties
Reel Difficulties
Hydraulic System Difficulties
ACTIVE HEADER CONTROL™
Servicing
Safe Cutting Platform Operation
Reel Safety Stops
Opening and Closing Right and Left-Hand Shields
Remove and Install Knife Drive Belt
Adjusting Knife Drive Belt Tension
Replacing Cutterbar Knife
Knife and Knife Drive Alignment
Knife Hold-Down Clearance
Replacing Knife Sections
Replacing Auger Fingers and Retainers
Stubble Light Bulb Replacement
Header Warning Light Bulb Replacement
Bleeding HydraFlex™ System—Flex Headers
Storage
End of Season Service
Beginning of Season Service
Prepare Machine for Storage
Specifications
Specifications—Rigid Platforms
Dimensions/Weights—Rigid Cutting Platforms
Specifications—Flex Platforms
Dimensions/Weights—Flex Cutting Platforms
Machine Design Life
Serial Number
Identification Numbers
Identification Plate
Keep Proof of Ownership
Interpreting Machine Serial Number
Product Identification Number
Index
John Deere Service Literature Available
Technical Information
John Deere Service—Keeps You on the Job
John Deere Parts
The Right Tools
Well-Trained Technicians
Prompt Service
Brand: John Deere
Introduction
Foreword
Intended Use
Trademarks
Identification View
Identification View
Safety Features
Safety
Operators Ability
Guards and Shields
Operators’s Manual
Rotating Driveline
Reel Safety Stops
Side Shield
Cutterbar Movement
Header Entanglement
Transporting
Reel Operation
When to Calibrate
Cutterbar Positions
Adjustments — Reel
Adjust Reel Fingers
Lubricants
Gear Oil
Lubricant Storage
Multipurpose Grease
Lubrication Symbols
Troubleshooting
Auger Difficulties
Reel Difficulties
Servicing
Reel Safety Stops
Storage
Specifications
Machine Design Life
Serial Number
Index
John Deere Parts
The Right Tools
Prompt Service
- JOHN DEERE CODE DTC LIST
