John Deere 600 Series Rigid and Flex Cutting Platforms Operators Manual OMCQ100210
- Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Rigid and Flex Cutting Platforms
Model: John Deere 600 Series Rigid and Flex Cutting Platforms
Serial Number: -140099
Part Number: OMCQ100210
Number of Pages: 76 Pages
Introduction
Foreword
Identification View
Identification View
Safety Features
Safety Features Rigid and Flexible 600
Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Replace Safety Signs
Operators Ability
Ballasting for Safe Ground Contact
Parking and Leaving the Machine
Prepare for Emergencies
Wear Protective Clothing
Stay Clear of Harvesting Units
Keep Hands Away From Knives
Use Safety Lights and Devices
Transporting Combine with Header Safely
Comply with Road Traffic Regulations
Practice Safe Maintenance
Avoid Entanglement
Avoid Contact With Moving Parts
Stay Clear of Cutterbar When Rotating Auger
Stay Clear of Rotating Drivelines
Guards and Shields
Avoid High-Pressure Fluids
Service Machines Safely
Service Belts Safely
Support Machine Properly
Store Attachments Safely
Safety Sign
Pictorial Safety Signs
Operators's Manual
Hydraulic Pressure
Telescopic Driveshaft
Reel Safety Stops
Reel Drive
Cutterbar Movement
Header Entanglement
Attaching and Detaching
Checking Auger Stripper Location
Identification of Type
Coupling Header to Combine—A-Type
Coupling Header to Combine—B-Type
Coupling Header to Combine—C-Type
Removing Header from Feeder House—A-Type
Removing Header from Feeder House—B-Type
Removing Header from Feeder House—C-Type
Unlocking Feeder House Manually— A-Type
Unlocking Feeder House Manually— B-Type
Unlocking Feeder House Manually— C-Type
Latching Cable Shear Screw Location
Haulage
Transport
Operating the Header
Choice of Harvesting Time
Cutting Platform Operation
Operating Flex Headers — HYDRAFLEX™ System Pressure
Checking Platform Speeds
Reel Operation
Cutting Platform Controls
Combining Oats, Sorghum, Wheat and Sunflowers in Dry Ground Conditions
Combining Oats, Sorghum and Wheat in Damp or Wet Ground Conditions
Combining Oats, Sorghum, Barley and Wheat in Short, Thin Crops—Rigid Platforms
Combining Rice—Rigid Platforms
Combining Soybeans—Flex Platforms
Accessories and Optional Equipment
Auger Flight Extensions (Attachment)—Flex Platforms
Auger Speeds (Attachment)
Heavy Duty Wear Plates (Optional)—Rigid Platforms
Reel Position Resume (Attachment)—STS Combines
Short Dividers, Flex Header
Calibration Procedures
Flex Header Adjustments
Adjust Platform Cutterbar/Skid Plate Tilt (Flex)
Operating Flex Header In Rigid Mode
Adjusting Head Drop Rate
Standard PERMA-GLIDE™ Divider Points
Adjusting Standard PERMA-GLIDE™ Divider Point Height
Side-to-Side Adjustment of Front Section of Standard PERMA-GLIDE™ Point
Rigid Header Adjustments
Cutterbar Positions
Adjusting Cutterbar Fore/Aft
Adjusting Platform Cutterbar/Skid Plate Tilt (Rigid)
Auger and Stripper Adjustments
Setting Reel Safety Stops
Adjusting Auger Clearance
Adjusting auger height
Adjusting Auger Fore/Aft
Adjusting Auger Center Finger Synchronization
Adjusting Rear Auger Stripper
Adjusting Lower Stripper
Adjusting Auger Chain
Adjusting Reel
Adjusting Reel Fingers
Adjusting Reel Position
Adjusting Width Between Reel Arms
Adjusting Reel Fore/Aft and Lift Cylinders
Rephase Hydraulic Reel Fore/Aft
Rephasing Reel Lift Cylinders
Bleeding the Reel Lift Cylinder System
Adjusting Reel Speed Ratio Sensor
Adjusting Platform Height Restoring System
Lubricants
Gear Oil
Grease
Mixing of Lubricants
Lubricant Storage
Lubrication and Service
Lubrication Symbols
Care and Maintenance of Belts
Troubleshooting
Cutterbar Difficulties
Down and Tangled Crops Difficulties
Feeder House Difficulties
Auger Difficulties
Cutting Difficulties
Reel Difficulties
Hydraulic System Difficulties
ACTIVE HEADER CONTROL™
Servicing
Safe Cutting Platform Operation
Removing and Installing Knife Drive Belt
Replacing Cutterbar Knife
Aligning Knife Head / Knife Drive
Knife Hold-Down Clearance
Replacing Knife Sections
Replacing Auger Fingers and Retainers
Bleeding HYDRAFLEX System—Flex Headers
Storage
End of Season Service
Beginning of Season Service
Specifications
Specifications—Rigid Platforms
Dimensions/Weights—Rigid Cutting Platforms
Specifications—Flex Platforms
Dimensions/Weights—Flex Cutting Platforms
Product Identification Number
Index
John Deere Service Literature Available
Technical Information
John Deere Service—Keeps You on the Job
John Deere Parts
The Right Tools
Well-Trained Technicians
Prompt Service
Brand: John Deere
Introduction
Foreword
Identification View
Identification View
Safety Features
Safety
Operators Ability
Avoid Entanglement
Guards and Shields
Safety Sign
Operators's Manual
Hydraulic Pressure
Reel Safety Stops
Reel Drive
Cutterbar Movement
Header Entanglement
Haulage
Transport
Reel Operation
Cutterbar Positions
Adjusting Reel
Lubricants
Gear Oil
Grease
Lubricant Storage
Lubrication Symbols
Troubleshooting
Auger Difficulties
Reel Difficulties
Servicing
Storage
Specifications
Index
John Deere Parts
The Right Tools
Prompt Service
- JOHN DEERE CODE DTC LIST
