Martin Welker
104
230,310
John Deere 5730 5830 Self Propelled Forage Harvester Technical Manual TM1352
Brand: John Deere
Type of Machine: Self Propelled Forage Harvester
Type of Manual: Technical Manual
Model: John Deere 5730 5830 Self Propelled Forage Harvester
Part Number: TM1352
Number of Pages: 1474 Pages
SECTION 10—GENERAL
Group 05—Safety
Group 10—Specifications, Torques, and Special Tools
Group 15—Tune-Up
Group 20—Engine Removal
SECTION 20—ENGINE REPAIR (6466A)
SECTION 25—ENGINE REPAIR (6619A)
Group 00—Specifications and Special Tools
Group 05—Cylinder Head, Valves and Camshaft
Group 10—Cylinder Block, Liners Pistons, and Rod
Group 15—Crankshaft, Main Bearings, and Flywheel
Group 20—Lubrication System
Group 25—Cooling System
SECTION 30—FUEL AND AIR REPAIR
Group 05—Air Intake System
Group 10—Diesel Fuel System
SECTION 40—ELECTRICAL REPAIR
Group 05—Battery Repair
Group 10—Charging Circuit Repair
Group 15—Starting Circuit Repair
Group 20—Electrical Component Repair
Group 25—Harness Repair
Group 30—Metal Detector Repair
Group 35—Rotary Screen Motor Repair
Group 40—SPOUT-TRAKTM Repair
SECTION 50—POWER TRAIN
Group 05—Hydrostatic Fitting Torques
Group 10—Flushing Hydrostatic System
Group 15—Hydrostatic Drive Repair
Group 20—Transmission Repair
Group 25—Differential Repair
Group 30—Final Drive Repair
Group 35—Cam Lobe Motor Repair
Group 40—Power Rear Wheel Control Valve
SECTION 60-STEERING AND BRAKES REPAIR
Group 05—Steering Unit Repair
Group 10—Steering Cylinder and Tie Rod Repair
Group 15—Brake Repair
Group 20—Master Cylinder Repair
Group 25—Slave Cylinder Repair
SECTION 70—HYDRAULIC REPAIR
Group OS—Torque Hydraulic Fittings
Group 10—Flushing the Hydraulic System
Group 15—Hydraulic Reservoir
Group 20—Knife Sharpener Motor Repair
Group 25—Knife Sharpener Selector Valve Repair
Group 30—Gear Case Cooling Pump Repair
Group 35—Main Hydraulic Pump Repair
Group 40—Priority and Relief Valves
Group 45—Hydraulic Outlet
Group 50—Harvesting Unit Lift Cylinder
Group 55—Belt Tightener Cylinder
Group 60—Spout Control Motor Repair
Group 65—Electrohydraulic Valves
SECTION 80—MACHINE FUNCTIONS
Group 05—DIagnosing malfunctions
Group 10—Feed Roll Repair
Group 15—Stationary Knife Adjuster Repair
Group 20—Remove Roll Arm Repair
Group 25—Cutter head Knife Bracket
Group 20—Cutter head Repair
Group 35—Knife Sharpener Repair
Group 40——-Feed Roll Gear Case Repair
Group 45—Auger Repair
Group 50—Fan and Spout Repair
Group 55—Main Clutch Repair
Group 60—-Main Gear Case Repair
SECTION 90—OPERATOR'S STATION REPAIR
Group 05—Pressurizer System
Group 10—Air Conditioning System
Group 15—Cab Removal
Group 20—Heating System
Group 25—Personal PostureTM Seat
