John Deere 570 580 590 Round Balers Operators Manual OMCC45009
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Round Balers
Model: John Deere 570 580 590 Round Balers
Serial Number: 315565
Part Number: OMCC45009
Number of Pages: 301 Pages
Identification Views
Safety
Safety Decals
Preparing the Tractor
Adjusting drawbar
Adjusting front tread
Adjusting rear tire spacing
Checking ballast
PTO speed
Setting selective control valves
Preparing tractor for monitor installation
Installing monitor support
Connecting monitors
Using drawbar shield
Preparing the Baler
Selecting twine
Loading twine boxes
Tying sheet bend knot
Tying modified square knot
Routing twine
Selecting net roll
Care of net roll
Care of net wrapping device
Loading net boxes
Routing net
Setting baler for 1000 rpm PTO
Tractors with low hydraulic flow
Tire inflation
Attaching and Detaching
Attaching to 540 rpm PTO
Tractor electrical connection
Attaching to drawbar
Attaching to trailer hitch
Connecting safety chain
Storing jackstand
Page
Using jackstand
Connecting telescoping hook-up
Attaching to hydraulic system
Connecting wiring harness
Detaching telescoping hook-up
Storing hook-up
Transporting
Warning lights
Preparing for transport
Storing jackstand
Operating the Baler-General Purposes
Break-in period
Rotating baler by hand
How the net wrapping works
How the soft core works
Crop preparation
Feeding the material
Basic baler settings
Gate lock valve (590 only)
Gate lock device (570-580 only)
Unplugging baler with precutter device
Unplugging baler without precutter device
Adjusting twine spacing
Bale density gauge
Adjusting bale density
Adjusting twine guide
Adjusting lower net guide panel side
wedges
Setting wide pickup feeder forks
Adjusting compressor rack
Adjusting converging wheel height
Adjusting wheel spindles
Adjusting wide pickup gauge wheels
Adjusting starter roll scraper
Adjusting bottom roll scraper
Adjusting pickup auger scrapers
Adjusting pickup float springs
Adjusting pickup height
Positioning precutter front sheet
Changing precutter knife support position
Resetting bale counter
Operating bale push bar
Operating Manual Twine Control
Adjusting bale size
Adjusting soft core diameter
Forming a bale
Wrapping a bale
Discharging bale
Operating Electronic Wrapping Control
Electronic Wrapping Control Monitor
Adjusting bale size
Forming a bale
Wrapping a bale
Discharging bale
Operating BaleMaster Control
General description
BaleMaster component locations
LCD screen description
Keyboard description
Operating BaleMaster monitor
BaleMaster setup values and initial
settings
Switching ON control monitor
BaleMaster malfunctions check-up
Changing measurements units
Resetting control monitor to initial settings
Selecting wrapping mode
Selecting flax wrapping mode
Adjusting bale size
Fine tuning bale size
Adjusting twine density
Adjusting net wrap density
Adjusting bale start wrap position
Adjusting bale end wrap position
Adjusting bale side wrap
Adjusting twine arm re-extension
Reducing l
Using bale counter
Displaying software versions
Selecting baler model
Page
Selecting precutter operating modes
Diagnostic mode
Forming a bale
Wrapping a bale with twine
Wrapping a bale with net
Discharging bale
Converging wheels
Hydraulic pickup lift
Standard belt stapler
Goro belt stapler
Mato belt stapler
Road light kit
Flax bundle
Bale discharging ramp
Gate deflectors
Silage bundle
Hemp bundle
Pickup gauge wheel
Wide pickup
High floatation tires
Upper roll drive
55 bar soft core kit
0 bar soft core kit
Net wrapping
Bale push bar
Rubber covered shells
Low drive belt speed bundle
Twine pulley sensors
BaleMaster control monitor battery
harness
Monitor mounting bracket
Hydraulic pressure accumulator
Front twine/net box
Knife slot filler kit
Special knife kit
Lubrication and Maintenance
Observe service intervals
Grease
Gear oil
Alternative lubricants
Lubricant storage
Mixing of lubricants
Draining and refilling gear case
Checking precutter knives
Checking belt wires
Every 10 hours
Every 30 hours
Every 50 hours
Annually
Troubleshooting
BaleMaster Control Monitor
Twine wrapping
Feeding
Pickup
Bale quality
General baler difficulties
Silage equipment
Net wrapping
Push bar
Service
Torques for hardware
Baler roll numbering
Adjusting main drive chain
Adjusting bottom roll drive chain
Adjusting upper drive roll chain
Adjusting precutter drive chain
Adjusting pickup drive chains
Replacing precutter knives
Adjusting upper arm spring
Adjusting upper arm cylinder
Adjusting gate latch (590 only)
Adjusting gate latch stop
Adjusting gate locking hooks
Adjusting belt tracking
Adjusting bale size indicator
Adjusting twine cutter anvil
Adjusting twine arm travel
Adjusting twine arm timing
Replacing controller fuse
Diagnosing right gate latch switch
Diagnosing left gate latch switch
Adjusting gate latch switches
Diagnosing oversize switch
Adjusting oversize bale switch
Diagnosing bale formation potentiometers
Adjusting bale shape senders
Diagnosing twine pulleys
Adjusting pulley sensors
Diagnosing lower drive roll sensor
Adjusting lower drive roll sensor
Diagnosing precutter knife sensor
Adjusting precutter knife sensor
Diagnosing precutter reverse sensor
Adjusting precutter reverse sensor
Diagnosing bale size potentiometer
Page
Adjusting bale size potentiometer
Diagnosing twine arm potentiometer
Resetting twine arm actuator rod
Diagnosing net cut switch (baler with
adjustable net cut switch)
Adjusting net cut switch (baler with
non-adjustable net cut switch)
Checking net cut switch (baler with
Adjusting bale size switch
Adjusting soft core switch
Adjusting gear case hydraulic cylinder
stroke
Adjusting slip clutch
Checking slip clutch
Adjusting net feed roll pressure
Checking net feed roll drive belt
Removing net feed roll drive belt
Installing net feed roll drive belt
Access to net knife or net guides
Removing and installing net knife
Sharpening net knife
Removing rear net guide
Installing rear net guide
Removing front net guide (baler with
Installing front net guide (baler with
Checking front net guide rubber band
Adjusting net knife arm stop
Adjusting net feed roll brake (baler with
upper net brake)
Checking net feed roll brake (baler with
lower net brake)
Checking lower net guide panel (net
guide panel with side wedges only)
Checking lower net guide panel (panel
without side wedges only)
Checking lower net guide crossbar
Checking lower net guide channels
Removing net wrapped around feed roll
Replacing powerline shear bolt
Replacing pickup drive shear bolt
Removing the belts
Repairing belts
Preparing damaged belts
Installing standard belt hooks
Installing Goro belt hooks
Installing Mato belt hooks
Installing belts
Routing belts through the baler
Hook belt ends
Storage
At end of season
Preparing for beginning of season
Specifications
570 baler
580 baler
590 baler
Serial Numbers
Serial number plates
Baler serial number plate
Net wrapping serial number
Precutter device serial number
Index
Brand: John Deere
Safety
Safety Decals
Adjusting drawbar
Checking ballast
PTO speed
Connecting monitors
Preparing the Baler
Selecting twine
Loading twine boxes
Routing twine
Selecting net roll
Care of net roll
Loading net boxes
Routing net
Tire inflation
Storing jackstand
Page
Using jackstand
Storing hook-up
Transporting
Warning lights
Storing jackstand
Break-in period
Crop preparation
Bale density gauge
wedges
Adjusting bale size
Forming a bale
Wrapping a bale
Discharging bale
Adjusting bale size
Forming a bale
Wrapping a bale
Discharging bale
General description
settings
Adjusting bale size
Reducing l
Using bale counter
Page
Diagnostic mode
Forming a bale
Discharging bale
Converging wheels
Goro belt stapler
Mato belt stapler
Road light kit
Flax bundle
Gate deflectors
Silage bundle
Hemp bundle
Pickup gauge wheel
Wide pickup
Upper roll drive
0 bar soft core kit
Net wrapping
Bale push bar
harness
Front twine/net box
Special knife kit
Grease
Gear oil
Lubricant storage
Checking belt wires
Every 10 hours
Every 30 hours
Every 50 hours
Annually
Troubleshooting
Twine wrapping
Feeding
Pickup
Bale quality
Silage equipment
Net wrapping
Push bar
Service
Page
stroke
upper net brake)
lower net brake)
Removing the belts
Repairing belts
Installing belts
Hook belt ends
Storage
At end of season
Specifications
570 baler
580 baler
590 baler
Serial Numbers
Index
- JOHN DEERE CODE DTC LIST
