Martin Welker
104
230,310
John Deere 570 580 590 Round Balers Operators Manual OMCC41367
Brand: John Deere
Type of Machine: Round Balers
Model: John Deere 570 580 590 Round Balers
Part Number: OMCC41367
Number of Pages: 232 Pages
Identification Views
Safety
Safety Decals
Preparing the Tractor
Adjusting drawbar
Adjusting front tread
Adjusting rear tire spacing
Checking ballast
PTO speed
Setting selective control valves
Installing monitors
Installing monitor support
Connecting monitors
Using drawbar shield
Preparing the Baler
Selecting twine
Loading twine boxes
Tying sheet bend knot
Tying modified square knot
Routing twine
Selecting net roll
Care of net roll
Loading net boxes
Routing net
Tire inflation
Attaching and Detaching
Attaching to 540 rpm PTO
Attaching to drawbar
Attaching to trailer hitch
Storing jackstand
Using jackstand
Connecting/disconnecting hookup
Attaching to hydraulic system
Connecting wiring harness
Storing hookup
Page
Transporting
Warning lights
Preparing for transport
Storing jackstand
Operating the Baler
Break-in period
Rotating baler by hand
How the net wrapping works
How the soft core works
Crop preparation
Feeding the material
Basic baler settings
Manual Twine Control
Electronic Wrapping Control Monitor
BaleMaster Control Monitor
LCD screen description
BaleMaster keyboard description
BaleMaster key functions
BaleMaster initial settings
Switching ON BaleMaster
Selecting BaleMaster wrapping mode
Operating BaleMaster
BaleMaster special display
BaleMaster diagnostic mode
Forming a bale with BaleMaster
Forming a bale without BaleMaster
Wrapping a bale with BaleMaster
Wrapping a bale with Electronic Wrapping
Control
Wrapping a bale with Manual Twine
Control Switch
Discharging bale with BaleMaster
Discharging bale without BaleMaster
Gate lock valve (590 only)
Gate lock device (570-580 only)
Unplugging baler (590 only)
Unplugging baler (570-580 only)
Adjusting bale size without BaleMaster
Adjusting twine spacing
Bale density gauge (590 only)
Adjusting bale density
Adjusting soft core diameter
Adjusting twine guide
Adjusting pickup height
Setting wide pickup feeder forks
Adjusting compressor rack
Adjusting converging wheel height
Adjusting wheel spindles
Adjusting wide pickup gauge wheels
Adjusting starter roll scraper
Adjusting pickup float springs
Resetting bale counter
Operating bale push bar
Setting baler for 1000 rpm PTO
Converging wheels
Hydraulic pickup lift
Standard belt stapler
Goro belt stapler
Road light kit
Flax bundle
Bale discharging ramp
Gate deflectors
Silage bundle
Hemp bundle
Pickup gauge wheel
Wide pickup
High floatation tires
Upper roll drive
55 bar soft core kit
0 bar soft core kit
Net wrapping
Bale push bar
Rubber covered shells
Low drive belt speed bundle
Lubrication and Maintenance
Draining and refilling gear case
Checking belt wires
Every 10 hours
Every 30 hours
Every 50 hours
Annually
Troubleshooting
Twine wrapping
Feeding
Pickup
Page
Bale quality
General baler difficulties
Silage equipment
Net wrapping
Service
Torques for hardware
Baler roll numbering
Adjusting drive chains
Adjusting upper drive roll chain
Adjusting upper arm spring
Adjusting gate latch (590 only)
Adjusting gate latch stop
Adjusting gate locking hooks
Adjusting belt tracking
Adjusting bale size indicator
Adjusting twine cutter anvil
Adjusting gate latch switch
Adjusting oversize bale switch
Adjusting bale shape senders
Adjusting pulley sensors
Adjusting lower drive roll sensor
Adjusting bale size potentiometer
Adjusting bale size switch
Adjusting soft core switch
Adjusting net switch
Adjusting pickup auger scrapers
Adjusting twine arm travel
Adjusting twine arm timing
Resetting twine arm actuator rod
Adjusting net feed roll pressure
Checking net feed roll drive belt
Removing net feed roll drive belt
Installing net feed roll drive belt
Access to net knife
Removing and installing net knife
Removing rear net guide
Installing rear net guide
Removing front net guide
Installing front net guide
Checking front net guide rubber band
Adjusting net knife arm stop
Checking net feed roll brake
Removing net wrapped around feed roll
Checking lower front gate roll guide
Replacing powerline shear bolt
Replacing pickup drive shear bolt
Removing the belts
Installing belts
Routing belts through the baler
Hook belt ends
Repairing belts
Installing standard belt hooks
Installing Goro belt hooks
Adjusting slip clutch
Checking slip clutch
Storage
At end of season
Preparing for beginning of season
Specifications
570 baler
580 baler
590 baler
Serial Numbers
Serial number plates
Baler serial number plate
Product identification number
Net wrapping serial number
Index
