Martin Welker
104
230,310
John Deere 568 578 Round Baler Repair Technical Manual TM3300
Brand: John Deere
Type of Machine: Round Baler
Model: John Deere 568 578 Round Baler
Part Number: TM3300
Number of Pages: 314 Pages
Adjust Brake Lever fig 1
Adjust Brake Shoes fig 1
Adjust Double Arm Twine Tying Starting Point fig 1
Adjust Twine Guide fig 1
Adjusting Full-Size Bale Switch S1 (Baler With ELC Monitor) S3 (Baler With BaleTrak Control Monitor) FIG 1
Adjusting Net Cut Switch S2 (Baler With ELC Monitor) S1 (Baler With BaleTrak Control Monitor) FIG 1
Air Brake Description And Diagram fig 1
Air Brake Connection Lines Exploded View fig 1
Check for Leaks at Brake Circuit fig 1
Check the Braking Pressure 1
Checking And Adjusting Sprocket Alignment fig 1
Description And Diagram (Baler with BaleTrak Control Monitor) GIG 1
Description And Diagram (Baler without BaleTrak Control Monitor) FIG 1
Disassemble Cam-Type Cut Out Clutch 1
Exploded View of Precutter Gear Case fig 1
Exploded View of Twine Tying System fig 1
Exploded View of Wheel Hub (with Brake) fig 1
Exploded-view of Powerline FIG 1
Hydraulic Brake Description And Diagram fig 1
Hydraulic Symbols (As Defined by ISO 1219) fig 1
Installing Front Net Guide fig 1
Lubrication System Pump fig 1
MAXICUT Precutter Rotor And Bearing - Cross-Sectional View fig 1
Net Tying Operation fig 1
Remove Brake Cylinder fig 1
Remove Brake Cylinder hydraulic fig 1
Removing Roll No.12 And its Bearings fig 1
Adjust Bale Shape Indicator Strap fig 2
Description And Diagram (Baler with BaleTrak Control Monitor) FIG 2
Disassemble And Assemble Pump fig 2
Disassemble-Assemble Twine Actuator M1 And Net Actuator M2 FIG 2
Installing Front Net Guide fig 2
Removing Roll No. 2 to 9 And their Bearings
Removing Roll No. 2 to 9 And their Bearings fig 1
Removing Roll No. 2 to 9 And their Bearings fig 2
Removing Roll No.12 And its Bearings fig 2
Wiring Diagram of Main Wiring Harness W 2
Wiring Diagram of Main Wiring Harness W 2 component locations
Wiring Diagram of Main Wiring Harness W 2 identification
Description And Diagram (Baler with BaleTrak Control Monitor) FIG 3
Component Location for 2.00 m (6 ft 7 in.) Pickup fig 1
E003 Tension Over or Equal to 16 V
Removing Roll No.13, 15, 16 And their Bearings
Removing Roll No.13, 15, 16 And their Bearings 1
Removing Roll No.13, 15, 16 And their Bearings fig 2
Removing Roll No.11, 14, 17 And their Bearings
Replacing Metri Pack Connectors [For Metri Pack connectors, 150 series]
2.00 m (6 ft 6.7 in.) Pickup Identification And Diagram
Adjust 2.00 m (6 ft. 6.7 in.) Precutter And MAXICUT Precutter Main Drive Chain
Adjust Arm Twine Tying Starting Point (Baler with BaleTrak Control)
Adjust Brake Lever
Adjust Brake Shoes
Adjust Drive Chains for 2.00 m (6 ft. 6.7 in.) Pickup with Precutter or MAXICUT Precutter
Adjust Lubrication Pump Flow
Adjust Oil Flow
Adjust Twine Arm Travel (Except With BaleTrak Control Monitor)
Adjust Twine Guide
Adjusting 2.00 m (6 ft 6.7 in.) Pickup Drive Chains (Without Precutter Device
Adjusting Bale Density Control Valve
Adjusting Baler Speed Sensor S6 (Baler With BaleTrak Control Monitor)
Adjusting Flaps
Adjusting Precutter And MAXICUT Precutter Reverse Sensor S9 (578 With Precutter)
Adjusting Roll Drive Chains
Adjusting Twine Cutter Anvil
Adjusting Twine Pulley Sensors S7 And S8 (Baler With BaleTrak Control Monitor And Double Arm Twine Tying)
Adjusting Twine Pulley Sensors S7 And S8 (Baler With BaleTrak Control Monitor And Single Arm Twine Tying)
Assemble Bale Density Control Valve
Assemble Gear Case
Assemble Net Tying System
Assemble Tongue
Assemble Wheel Hub (with Brake)
Assemble Wheel Hub (without Brake)
Assembling Cam-Type Cut Out Clutch
Avoid High-Pressure Fluids
BaleTrak Monitor
Baler Identification Number
Bleeding Chain Oiling System Pump
Bleeding the Circuit
Check Bale Density Adjustable Relief Valve And Check Valve
Check Bale Density Density Gauge
Check Bale Density Hydraulic System
Check Gate Locking Valve for Leakage
Check Gate Operation Hydraulic System
Check Gear Case Reverser Function (Baler with Precutter And MAXICUT Precutter)
Check Hydraulic Cylinder for Leakage
Check Knife Function (Baler with Precutter And MAXICUT Precutter)
Check Pickup Lift Function (Baler with Precutter And MAXICUT Precutter)
Check Pilot Line Pressure
Check Safety Relief Valve
Check Valve Pilot Piston Check
Check circuit condition.
Check if E001 is still active.
Check minimum voltage during a tying cycle
Checking Condition of Valve Seats And Poppets
Component Identification ACTUATORS
Component Identification Table electrical system
Component Identification Wiring
Component Identifications Main Wiring Harness
Component Location of Main Wiring Harness
Component Location of Main Wiring Harness W2
Component Location of Precutter Wiring Harness W3
Diagnosing Hydraulic Functions
Diagnosing Malfunctions lubrication
Disassemble Gear Case
Disassemble Wheel Hub (with Brake)
Disassembling Bale Density Control Valve
Disassembling Net Tying System
E001 Erratic Supply Voltage
E002 Tension Below or Equal to 11.2 V
Electrical Connector HAndling
Exploded View of Cam-Type Cut Out Clutch
Exploded View of Wheel Hub (without Brake)
Functional Schematic (Part 1)
Functional Schematic (Part 2)
Functional Schematic of Twine Net Tying Function
Functional Schematic of Twine Net Tying Function identification
Functional Schematic of Twine Tying Function
Functional Schematic of Twine Tying Function identification
Gear Oil
Grease
Harness Repair Splice Connector
Install DEUTSCH Contact
Install Gear Case
Install Inline Orifice
Install Net Feed Roll Drive Belt
Install Relay Emergency Valve air brakes
Manual Twine Control Switch
Metric Bolt And Screw Torque Values
Multiluber Chain Oil
Net Tying Operation
Net Tying Operation Troubleshooting
Pickup Attachment (Baler with Precutter And MAXICUT Precutter)
Precutter And MAXICUT Precutter Knife Switches S10 And S11
Precutter Gear Case Install Gear Case
Precutter Removing Gear Case
Prepare for Emergencies
Remove And Install Bale Density Control Valve
Remove And Install Metering Valve
Remove And Install Twine Arm Actuator M1
Remove Front Net Guide
Removing And Installing Gate Cylinder
Removing And Installing Hoses
Removing And Installing Net Knife
Removing And Installing Rear Net Guide
Removing Net Feed Roll Drive Belt
Removing Net Wrapped Around Feed Rolls
Removing Roll No.10 And its Bearings
Repair Powerline
Replace CPC, Large MATE-N-LOK And METRIMATE™ Pin Type Connectors
Replace WEATHER PACK Connector
Replacing Bearings in Roll
Road lights Wiring Diagram
Road lights component locations
Road lights identifications
Service Rolls Safely
Sharpening Net Knife
Sheer bolt repair
Specifications SENSORS And SWITCHES
Support Machine Properly
Test Sequence lubrication
Troubleshooting
Weather Pack Male And Female Terminal
Wiring Diagram battery
Wiring Diagram for ELS (Manual Twine Control)
Wiring Diagram for ELS (Manual Twine Control) component location
Wiring Diagram of Main Wiring Harness W2
Wiring Diagram of Precutter Wiring Harness W3
