John Deere 55H Hillside Self-Propelled Combine Parts Catalog PC0470
Brand: John Deere
Type of Machine: Self-Propelled Combine
Model: John Deere 55H Hillside Self-Propelled Combine
Part Number: PC0470
Number of Pages: 350 Pages
ALPHABETICAL INDEX
A
Air Cleaner and Intake Pipe
Ammeter
Angle, Guard (Knife)
Angles, Frame, Separator Side Sheets
Arm, Reel
Arm, Reel Support
Auger and Knife Drive
Auger, Clean Grain, and Housing
Auger Drive, Clean Grain
Auger Drive, Grain Tank Loading
Auger Drive, Lower Tailings
Auger Drive Shaft at Rear of Platform
Auger Drive, Upper Tailings
Auger, Grain Tank Loading
Auger, Grain Tank Unloading
Auger, Lower Tailings, and Housing
Auger, Platform
Auger Shafts and Fingers, Platform
Auger, Upper Tailings, and Housing
Auger, Weed Seed (ScourKleen)
Axle and Wheel, Rear
Axle Brace, Front and Rear
Axle, Drive
Axle Housing
Axle Pivot Shaft and Platform Hydraulic Cylinder Mounting
Axle, Rear (Spindle)
B
Bar, Rasp
Bar, Weed
Battery Box and Cables
Beam, Leveling
Bearings, Camshaft (Engine)
Bearings, Connecting Rod (Engine)
Bearings, Main (Engine)
Bearings, Straw Walker
Beater
Bell Housing, Crankshaft and Flywheel
Blade Assembly, Cooling Fan
Blades, Cleaning Fan
Blades, Straw Chopper
Blades, Straw Spreader
Block, Cylinder
Bottom, Grain Conveyor
Box, Switch, and Wires
Box, Tool
Brace, Front and Rear Axle
Brake Controls, Foot
Brake Controls, Parking
Brake Pedal
Brake, Transmission
Brakes, Individual Wheel
Breather Tube
C
Cables, Starter and Ground
Camshaft and Bearings
Cap, Radiator
Carburetor
Cartridge, Oil Filter
Cell-Type Concave Extensions
Chaffer, Sieves and Finger Bar
Choke and Throttle Controls
Chopper, Straw
Chopper, Straw, Drive
Chopper, Straw, Reverse Drive
Chute, Sack, and Supports
Clean Grain Auger and Housing
Clean Grain Auger Drive
Clean Grain Elevator
Cleaner, Air, and Intake Pipe
Cleaning Fan, Housing, and Shields
Clutch Controls
Clutch, Drive Wheel
Clutch, Electromagnetic
Clutch Pedal
Coil and Spark Plug Wires
Concave Adjusting Controls
Concave and Grain Grate
Concave Cover Plates
Concaves, Spike-Tooth
Connecting Rod and Piston (Engine)
Control, Leveling, Reservoir and Line
Control, Selective Ground Speed
Control, Solenoid, for Leveling Valve
Controls, Clutch
Controls, Concave Adjusting
Controls, Foot Brake
Controls, Gearshift
Controls, Grain Tank Unloading Auger
Controls, Hydraulic Unit
Controls, Hydraulic Valve
Controls, Parking Brake
Controls, Separator Throw-Out
Controls, Steering
Controls, Throttle and Choke
Conveyor Bottoms, Grain
Conveyor Chain, Feeder House
Conveyor Chain, Grain, with Shafts
Conveyor Drive, Feeder
Conveyor Drive, Grain
Cooling Fan
Cooling Fan, Generator, Hydraulic Unit, and Grain Tank Unloading Auger Rear Drive
Cover, Valve, and Valves
Crankshaft, Bell Housing, and Flywheel
Crankshaft, Shoe
Crankshafts, Straw Walker, and Bearings
Cross Tie, Separator
Cutter Bar Extensions
Cylinder Block and Head
Cylinder Drive
Cylinder, Hydraulic, Leveling
Cylinder, Hydraulic, Platform Lift
Cylinder, Hydraulic, Reel Lift
Cylinder, Hydraulic, Selective Ground Speed Control
Cylinder, Hydraulic, Steering
Cylinder, Rasp-Bar
Cylinder, Spike-Tooth
Decalcomania Sets
Differential Gears and Housing
Differential Shaft and Drive Shaft
Discharge Spout, ScourKleen
Distributor
Dividers, Extension
Drive Axle
Drive Shaft, Hydraulic Unit
Drive Shaft, Platform and Feeder Beater, Through Front of Feeder House
Drive Shaft, Reel, at Rear of Platform
Drive Shield for Cylinder, Fan, Shoe, and Straw Walker
Drive Wheel
Drive Wheel Axle Housing Support
Drive Wheel Clutch
Drive Wheel Reduction Gears
Drive, Clean Grain Auger
Drive, Cooling Fan
Drive, Cylinder
Drive, Feeder Beater
Drive, Feeder Conveyor
Drive, Generator
Drive, Grain Conveyor
Drive, Grain Tank Loading Auger
Drive, Grain Tank Loading Auger (ScourKleen)
Drive, Grain Tank Unloading Auger Front
Drive, Grain Tank Unloading Auger Rear
Drive, Hydraulic Unit
Drive, Knife and Auger, on Feeder House
Drive, Lower Tailings Auger
Drive, Platform Auger
Drive, Propulsion
Drive, Reel Front
Drive, Reel Front (With Hydraulic Lift Reel)
Drive, Reel Rear
Drive, Rotor for ScourKleen
Drive, Separator, and Tightener
Drive, Straw Chopper
Drive, Straw Chopper Reverse
Drive, Straw Spreader
Drive, Straw Walker, Shoe, and Fan
Drive, Upper Tailings Auger
Drive, Weed Seed Auger (ScourKleen)
E
Electromagnetic Throw-Out Clutch
Elevator, Clean Grain
Elevator, Tailings
End Sheets, Platform
End Shields, Reel
Engine, Hercules
Engine Powershaft
Engine Shields (Sacker)
Engine Support and Handrail
Exhaust Pipe and Mnaifold
Extension, Cell-Type Concave
Extension, Cutter Bar
Extension Dividers
Extension for Ladder
Extension, Grain Tank
Extension, Muffler Guard
Extension, Rear Hood
F
Fan, Cooling
Fan Housing, Cleaning
Fan Shaft and Bearings
Fan, Straw Walker, and Shoe Drive
Feeder Beater Drive
Feeder Conveyor Chain Shield
Feeder Conveyor Drive
Feeder Drum in Feeder House
Feeder House Bottom Sheets
Feeder House Conveyor Chain
Feeder House Feeder Drum
Feeder House Side Sheets
Feeder House Top Sheets
Filter and Fuel Pump
Finger Bar, Sieves and Chaffer
Fingers, Platform Auger
Floorboard, Sacking Platform
Flywheel, Crankshaft, and Bell Housing
Foot Brake Controls
Fork, Shifter
Frame Angles, Separator
Front and Rear Axle Brace
Fuel Pump and Filter
Fuel Tank and Supports
G
Gauge, Oil Pressure, Ammeter, and Temperature
Gear Cover
Gear, Steering
Gears, Bevel and Pinion, Differential and Transmission
Gears, Drive Wheel Reduction
Gears, Transmission
Gearshift Controls
Generator
Generator Drive
Governor
Governor Oil Tube
Grain Conveyor Bottoms
Grain Conveyor Chain with Shafts
Grain Conveyor Drive
Grain Grate and Concave
Grain Tank
Grain Tank Extension
Grain Tank Loading Auger Drive
Grain Tank Loading Auger Drive (ScourKleen)
Grain Tank Unloading Auger Controls
Grain Tank Unloading Auger Drive Sheave
Grain Tank Unloading Auger Front Drive
Guard, Muffler (Sacker)
Guard, Straw Spreader
Guards and Knifes
Guards, Lifting
Hand Rails (Operator's Platform)
Hand Rails (Sacking Platform)
Head and Cylinder Block
Holders, Sacking, and Spout
Hood, Rear
Housing, Axle
Housing, Clean Grain Auger
Housing, Cleaning Fan
Housing, Differential
Housing, Grain Tank Unloading Auger
Housing, Spindle, Rear Axle
Housing, Straw Chopper
Housing, Transmission Brake and Reduction Gear
Housing, Transmission Shifter
Housing, Upper Tailings Auger
Hydraulic Cylinder, Leveling
Hydraulic Cylinder, Platform Lift
Hydraulic Cylinder, Reel
Hydraulic Cylinder, Selective Ground Speed Control
Hydraulic Cylinder, Steering
Hydraulic Cylinder Mounting, Platform
Hydraulic Lift Reel
Hydraulic Lift Reel Selector Valve and Control Lever
Hydraulic Oil Lines
Hydraulic Oil Reservoir
Hydraulic Unit Controls
Hydraulic Unit Drive
Hydraulic Unit Drive Shaft and Throw-Out
Hydraulic Valve, Leveling
Hydraulic Valve, Platform Lift
Hydraulic Valve, Reel Lift
Hydrauilc Valve, Selective Ground Speed
Hydraulic Valve, Steering
I
ID VIEW
Indicator, Selective Ground Speed
Individual Wheel Brakes
Instrument Panel, Switch Box, and Wires
Intake Pipe and Air Cleaner
K
Knife and Auger Drive on Feeder House
Knife and Auger Drive Shaft at Rear of Platform
Knife Drive Oscillating Pipe
Knifes and Guards
L
Ladder Extension
Ladder on Operator's Platform
Ladder on Separator
Leveling Beam
Leveling Control Reservoir and Line
Leveling Control Switch
Leveling Cylinder
Leveling Cylinder Oil Lines
Leveling Links, Platform
Leveling Valve
Lifting Guards
Limit Switch
Lines, Water, Radiator, and Screen
Low-Cut Cutter Bar Extension
Lower Tailings Auger and Housing
Lower Tailings Auger Drive
M
Main Bearings
Maize Cutter Bar Extension
Manifold and Exhaust Pipe
Manual Lever for Leveling Valve
Manual, Operator's
Motor, Starting
Muffler Guard Extension (Sacker)
O
Oil Filter
Oil Lines, Leveling Cylinders
Oil Lines, Platform Lift
Oil Lines, Selective Ground Speed Control
Oil Lines, Steering, and Relief Valve
Oil Pan
Oil Gauge
Oil Pump
Oil Reservoir, Hydraluic
Operator's Manual
Operator's Platform
Operator's Platform Ladder
Operator's Seat
Oscillating Pipe and Knife Drive
P
Paddles, Elevator
Pan, Oil
Parking Brake Controls
Pedal, Brake
Pedal, Clutch
Pinion Gear
Pipe, Intake Air Cleaner
Pipe, Knife Drive Oscillating
Pipe, Muffler Extension
Pipe, Reel
Piston and Connecting Rod
Pitman, Shoe, and Crank
Pivot Rings and Braces, Platform
Plates, Concave Cover
Platform and Feeder Beater Drive Shaft through Front of Feeder House
Platform Angles and Braces
Platform Auger
Platform Auger Drive
Platform Auger Shafts and Fingers
Platform Bottom Sheets
Platform Bottom Shields
Platform End Sheets
Platform Floorboard, Sacking
Platform Hydraulic CYlinder Mounting
Platform Leveling Links on Feeder House Side
Platform Lift Cylinders
Platform Lift Oil Lines
Platform, Operator's
Platform Pivot Rings and Braces
Platform Side Sheets, Sacking
Platform Support Angles, Sacking
Powershaft on Engine
Propulsion Drive
Pump, Hydraulic
Pump, Oil
Pump, Water
R
Radiator, Screen, and Water Lines
Rasp-Bar Cylinder
Rear Axle and Spindle Housing
Rear Hood
Rear Hood Extension
Rear Wheel and Spindle
Rear Wheel Supports
Reciprocating Shoe
Reduction Gears, Drive Wheel
Reel Drive Shaft at Rear of Platform
Reel, End Shield, Slats, Support Arms, and Pipe
Reel Front Drive
Reel Front Drive (With Hydraulic Lift Reel)
Reel, Hydraulic Lift
Reel Rear Drive
Regular Shoe
Regulator, Voltage (Hercules Engine)
Relief Valve
Reservoir, Hydraulic Oil
Reservoir, Leveling Control
Rings, Piston (Engine)
Rocker Arms
Rods, Connecting
Rotor Drive (ScourKleen)
S
Sack Chute and Supports
Sack Holder and Sacking Spout
Sack Shelf
Sacker (ScourKleen)
Sacking Platform Floorboard
Sacking Platform Side Sheets and Engine Shields
Sacking Platform Support Angles
Sacking Spout
ScourKleen Discharge Spout
ScourKleen, Hart
Screen, Radiator, and Water Lines
Seat, Operator's
Section, Knife
Selective Ground Speed Control Hydraulic Cylinder
Selective Ground Speed Control Oil Lines
Selective Ground Speed Indicator
Selector Valve and Control Lever (Hydraulic Lift Reel)
Separator Cross Tie
Separator Drive and Tightener
Separator Front End Sheets
Separator Ladder
Separator Throw-Out Controls
Separator Side Sheets and Frame Angles
Separator Top Sheets and SUpports
Shaft, Differential
Sheets, Bottom, Feeder House
Sheets, Platform Bottom
Sheets, Platform End
Sheets, Separator Front End
Sheets, Separator Side, and Frame Angles
Sheets, Separator Top
Sheets, Side, Feeder House
Sheets, Top, Feeder House
Shelf, Sack
Shield, Feeder Conveyor Chain
Shield for Cylinder, Fan, Shoe, and Straw Walker Drives
Shields, End, Reel
Shields, Engine (Sacker)
Shields, Fan
Shields, Platform Bottom
Shifter Fork
Shoe Pitman and Crank
Shoe, Reciprocating
Shoe, Regular
Shoe, Straw Walker, and Fan Drive
Sieves, Chaffer, and Finger Bar
Slats, Reel
Solenoid Control for Leveling Valve
Spark Plug Wires and Coil
Spike-Tooth Concaves
Spike-Tooth Cylinder
Spindle Housing, Rear Wheel
Spindle, Rear Wheel
Spout, Discharge (ScourKleen)
Spout, Sacking
Spout, Weed Seed (ScourKleen)
Spreader, Straw
Spreader, Straw, Drive
Starting Magnetic Switch
Starting Motor
Steering Arms and Tie Rods
Steering Controls on Operator's Platform
Steering Gear, Arm, and Housing
Steering Oil Lines and Relief Valve
Stone Trap (Rod-Type)
Stone Trap (Trough-Type)
Straw Chopper
Straw Chopper Drive
Straw Chopper Housing
Straw Chopper Reverse Drive
Straw Spreader
Straw Spreader Drive
Straw Spreader Guard
Straw Walker Crankshaft and Bearings
Straw Walker, Shoe, and Fan Drive
Straw Walkers
Support Arms, Reel
Support, Clean Grain Elevator (Sacker)
Support, Drive Wheel Axle Housing
Support, Engine, and Hand Rail
Support, Rear Wheel
Support Tubes, Wheel
Supports, Fuel Tank
Supports, Sack Chute
Switch Box, Wires, Instrument Panel, and Operator's Seat
Switch, Leveling Control
Switch, Limit
Switch, Starting Magnetic
T
Tailings Auger Drive, Lower
Tailings Auger Drive, Upper
Tailings Elevator
Tank, Fuel, and Supports
Tank, Grain
Temperature Gauge
Throttle and Choke Controls
Throw-Out Clutch, Electromagnetic
Throw-Out, Grain Tank Unloading Auger Drive Sheave
Tie Rods and Steering Arms
Tie, Separator Cross
Tire and Tube, Drive Wheel
Tire and Tube, Rear Wheel
Tool Box
Transmission Brake, Reduction Gears, and Housing
Transmission Gears and Case
Transmission Shifters and Housing
Trap, Stone (Rod-Type)
Trap, Stone (Trough-Type)
U
Upper Tailings Auger and Housing
Upper Tailings Auger Drive
V
Valve, Relief
Valves and Valve Cover (Engine)
Valves, Hydraulic, Leveling
Valves, Hydraulic, Platform Lift
Valves, Hydraulic, Reel Lift
Valves, Hydraulic, Selective Ground Speed
Valves, Steering
Voltage Regulator (Hercules Engine)
Voltage Regulator (217 and 232 Engines)
W
Walkers, Straw
Water Lines, Radiator and Screen
Weed Bar
Weed Seed Auger and Housing (ScourKleen)
Weed Seed Auger Drive (ScourKleen)
Weed Seed Spout (ScourKleen)
Wheels, Drive
Wheels, Rear
Wheels, Steering
Wheel Support Tubes
Wires, Electromagnetic Throw-Out Clutch
Wires, Spark Plug
Wiring, Switch Box and Instrument Panel
Brand: John Deere
Part Number: PC0470
ALPHABETICAL INDEX
A
Ammeter
Arm, Reel
Arm, Reel Support
Auger, Platform
Axle, Drive
Axle Housing
B
Bar, Rasp
Bar, Weed
Beam, Leveling
Beater
Block, Cylinder
Box, Tool
Brake Pedal
Brake, Transmission
Breather Tube
C
Cap, Radiator
Carburetor
Chopper, Straw
Clutch Controls
Clutch, Drive Wheel
Clutch Pedal
Controls, Clutch
Controls, Gearshift
Controls, Steering
Cooling Fan
Crankshaft, Shoe
Cylinder Drive
Cylinder, Rasp-Bar
Decalcomania Sets
Distributor
Dividers, Extension
Drive Axle
Drive Wheel
Drive Wheel Clutch
Drive, Cooling Fan
Drive, Cylinder
Drive, Generator
Drive, Propulsion
Drive, Reel Front
Drive, Reel Rear
E
Elevator, Tailings
End Shields, Reel
Engine, Hercules
Engine Powershaft
Extension Dividers
F
Fan, Cooling
Feeder Beater Drive
Foot Brake Controls
Fork, Shifter
G
Gear Cover
Gear, Steering
Gears, Transmission
Gearshift Controls
Generator
Generator Drive
Governor
Governor Oil Tube
Grain Tank
Guards and Knifes
Guards, Lifting
Hood, Rear
Housing, Axle
Hydraulic Lift Reel
Hydraulic Oil Lines
I
ID VIEW
K
Knifes and Guards
L
Ladder Extension
Ladder on Separator
Leveling Beam
Leveling Cylinder
Leveling Valve
Lifting Guards
Limit Switch
M
Main Bearings
Manual, Operator's
Motor, Starting
O
Oil Filter
Oil Pan
Oil Gauge
Oil Pump
Operator's Manual
Operator's Platform
Operator's Seat
P
Paddles, Elevator
Pan, Oil
Pedal, Brake
Pedal, Clutch
Pinion Gear
Pipe, Reel
Platform Auger
Platform End Sheets
Propulsion Drive
Pump, Hydraulic
Pump, Oil
Pump, Water
R
Rasp-Bar Cylinder
Rear Hood
Rear Hood Extension
Rear Wheel Supports
Reciprocating Shoe
Reel Front Drive
Reel Rear Drive
Regular Shoe
Relief Valve
Rocker Arms
Rods, Connecting
S
Sack Shelf
Sacker (ScourKleen)
Sacking Spout
ScourKleen, Hart
Seat, Operator's
Section, Knife
Separator Cross Tie
Separator Ladder
Shaft, Differential
Shelf, Sack
Shields, End, Reel
Shields, Fan
Shifter Fork
Shoe, Reciprocating
Shoe, Regular
Slats, Reel
Spindle, Rear Wheel
Spout, Sacking
Spreader, Straw
Starting Motor
Straw Chopper
Straw Chopper Drive
Straw Spreader
Straw Walkers
Support Arms, Reel
Support, Rear Wheel
Supports, Fuel Tank
Switch, Limit
T
Tailings Elevator
Tank, Grain
Temperature Gauge
Tool Box
U
V
Valve, Relief
Valves, Steering
W
Walkers, Straw
Weed Bar
Wheels, Drive
Wheels, Rear
Wheels, Steering
Wheel Support Tubes
Wires, Spark Plug
- JOHN DEERE CODE DTC LIST
