John Deere 55 Series Self-Propelled Combine Parts Catalog PC0337
Brand: John Deere
Type of Machine: Self-Propelled Combine
Model: John Deere 55 Series Self-Propelled Combine
Part Number: PC0337
Number of Pages: 614 Pages
ALPHABETICAL INDEX
A
Air Cleaner
Angles, Frame, Separator Side Sheets, L.H.
Angles, Frame, Separator Side Sheets, R.H.
Angle, Guard (Sickle)
Arm, Reel
Arms, Reel Support, R.H. and L.H.
Auger, Clean Grain, and Housing
Auger, Grain Tank, Hinged Unloading
Auger, Grain Tank Loading
Auger, Grain Tank, Rigid Unloading
Auger, Lower Tailings
Auger, Platform
Auger, Weed Seed, and Housing for Hart ScourKleen Models "N" and "S-35" (Grain Tank)
Axle, Rear
Axle Shaft and Differential Gears, Main Wheel
Axle Support
B
Bar, Cylinder Stripper
Bar, Rasp
Bar, Weed
Battery Box and Cables
Bearings, Connecting Rod (Engine)
Bearings, Main (Engine)
Bearings, Wood (For Straw Walker Crankshaft)
Beater Behind Cylinder
Bell Housing (Engine)
Blade, Assembly, Cooling Fan
Blade, Fan (For Straw Spreader)
Blade, Straw Chopper
Blades, Cleaning Fan
Block, Cylinder and Head (Engine)
Brace Channels on Front of Separator
Brace, Operator's Platform to Axle
Brace Rods for Main Wheel Axle Housing Support
Brake and Clutch Controls on Operator's Platform
Brake Cylinder for Main Wheel Hydraulic Brake
Brake, Hydrualic, Individual Wheel
Brake, Main Wheel, and Linings
Brake, Parking, Controls ( - 39349)
Brake, Parking, Controls (39350 - )
Brake, Transmission
C
Cables, Starter and Ground (For Battery)
Camshaft and Bearings (Engine)
Cap, Radiator
Carburetor
Cartridge, Oil Filter
Chaffers and Finger Bar
Choke and Throttle Controls
Chopper, Straw
Chute, Sack
Clean Grain Auger
Clean Grain Elevator
Clutch and Brake Controls on Operator's Platform
Clutch, Electro-Magnetic Throw-Out, for Platform
Clutch, Main Wheel ( - 39349)
Clutch, Main Wheel (39350 - )
Coil (Engine)
Concave Plates, Rasp-Bar Cylinder
Concaves and Grate, Rasp-Bar Cylinder
Concaves, Spike-Tooth
Concave Tooth
Connecting Rod and Piston (Engine)
Connection, Hose, Radiator
Control Rod, Separator Belt Tightener Lever
Controls, Gearshift
Controls, Hydraulic for Platform Lift
Controls, Hydraulic, for Selective Ground Speed
Controls, Steering, on Operator's Platform
Conveyor Bottom, Grain
Conveyor in Feeder House
Crank, Shoe Pitman
Crankshaft (Engine)
Crankshaft and Bearings, Straw Walker
Crawler Tracks
Cutter Bar Extension (Special)
Cutting Platform Support Stand (Special)
Cylinder Block and Head
Cylinder, Brake, Hydraulic, Main Wheel
Cylinder, Brake, Hydraulic, Selective Ground Speed Control
Cylinder, Rasp-Bar
Cylinder, Spike-Tooth
Cylinder Sprockets
Cylinder, Stripper Bar
Cylinder Tooth
Decalcomania Set
Differential Gears (39350 - )
Differential Gears and Axle Shaft Main Wheel ( - 39349)
Differential Housing, Main Wheel ( - 39349)
Distributor
Divider, Platform End Sheet
Drives for Clean Grain Auger
Drives for Conveyor Behind the Cylinder
Drives for Cooling Fan and Generator
Drives for Cylinder
Drives for Feed Rolls
Drives for Feed Rolls Lower Roll
Drives for Feed Rolls Upper Roll
Drives for Feeder Conveyor Chain
Drives for Feeder Drum in Feeder House
Drives for Grain Tank Loading Auger
Drives for Grain Tank Unloading Auger, Front
Drives for Grian Tank Unloading Auger, Rear
Drives for Hydrualic Unit
Drives for Main Wheels
Drives for Platform Auger
Drives for Reel, Front
Drives for Reel, Rear
Drives for Rotor, Hart ScourKleen Model "N"
Drives for Rotor, Hart ScourKleen Model "S-35"
Drives for ScourKleen, Hart, Models "N" and "S-35"
Drives for Separator Drive Belt and Tightener
Drives for Sickle and Auger on L.H. Side Feeder House
Drives for Straw Chopper
Drives for Straw Chopper, Reverse
Drives for Straw Spreader
Drives for Straw Walker, Shoe and Fan
Drives for Tailings Auger, Lower
Drives for Tailings Auger, Upper
Drives for Weed Seed Auger, Hart ScourKleen Model "N"
Drives for Weed Seed Auger, Hart ScourKleen Model "S-35"
Drive Gears and Housing, Main Wheel final
Drive Parts at L.H. End of Platform Auger
Drive Shaft on Rear of Platform for Sickle and Auger
E
Electro-Magnetic Throw-Out Clutch for Platform
Elevator, Clean Grain
Elevator, Tailings
End Sheet, Platform
Engine, Hercules QXD-3, Bearings, Connecting Rod
Engine, Hercules QXD-3, Bearings, Main
Engine, Hercules QXD-3, Bell Housing
Engine, Hercules QXD-3, Camshaft and Bearings
Engine, Hercules QXD-3, Crankshaft
Engine, Hercules QXD-3, Cylinder Block and Head
Engine, Hercules QXD-3, Flywheel
Engine, Hercules QXD-3, Fuel Pump and Filter
Engine, Hercules QXD-3, Fuel Tank and Supports
Engine, Hercules QXD-3, Gasoline Tank and Supports
Engine, Hercules QXD-3, Gear Cover, Breather Tube and Governor Oil Tube
Engine, Hercules QXD-3, Generator
Engine, Hercules QXD-3, Governor
Engine, Hercules QXD-3, Oil Filter
Engine, Hercules QXD-3, Oil Pan
Engine, Hercules QXD-3, Oil Pump
Engine, Hercules QXD-3, Piston and Connecting Rod
Engine, Hercules QXD-3, Piston Rings
Engine, Hercules QXD-3, Powershaft
Engine, Hercules QXD-3, Radiator Screen
Engine, Hercules QXD-3, Spark Plug
Engine, Hercules QXD-3, Starting Motor
Engine, Hercules QXD-3, Step-Voltage Control on Generator
Engine, Hercules QXD-3, Valves and Valve Cover
Engine, Hercules QXD-3, Voltage Regulator on Generator
Engine, Hercules QXD-3, Water Pump
Engine Shield, Sacking Platform
Engine Support and Hand Rail
Exhaust Pipe and Manifold
Extension, Cutter Bar (Special)
Extension Divider
Extension for Rear Hood, Straw Chopper
Extension, Grain Tank
Extension, Ladder on Separator
Extension, Platform Auger
Extension, Rear Hood
F
Fan, Cooling (Engine)
Fan Housing (Cleaning) and Shields
Fan Shaft (Cleaning) and Bearings
Feed Rolls and Housing
Feeder Conveyor Chain Shields
Feeder House Bottom, Side and Top Sheets
Feeder House Conveyor Chain
Feeder House Feeder Drum
Filter, Oil (Purolator)
Final Drive
Fingers, Grain Grate
Fingers, Platform Auger
Floorboard, Sacking Platform
Flywheel (Engine)
Frame Angles, Separator Side Sheets, L.H.
Frame Angles, Separator Side Sheets, R.H.
G
Gaskets for Bell Housing (Engine)
Gaskets for Carburetor
Gaskets for Cooling Fan
Gaskets for Cylinder Block and Head (Engine)
Gaskets for Distributor
Gaskets for Exhaust Pipe and Manifold
Gaskets for Fuel Pump and Filter
Gaskets for Gasoline Tank and Fuel Filter
Gear Cover (Engine)
Gear Cover, Generator
Gear Cover, Governor
Gear Cover, Hydraulic Pump
Gear Cover, Oil Filter
Gear Cover, Oil Pan (Engine)
Gear Cover, Oil Pump
Gear Cover, Radiator Pump
Gear Cover, Valve Cover (Engine)
Gear Cover, Voltage Regulator
Gear Cover, Water Outlet (Radiator)
Gear Cover, Water Pump
Gear Cover, Water Pump Inlet (Radiator)
Gear Cover, Breather Tube and Governor Oil Tube (Engine)
Gearshift Controls
Gear, Steering
Generator
Governor
Grain Conveyor Bottom
Grain Conveyor Chain with Shafts
Grain Grate and Concaves
Grain Grate Fingers
Grain Tank
Grain Tank Extension
Grain Tank Hinged Unloading Auger
Grain Tank Rigid Unloading Auger
Grain Tank Unloading Auger Clutch
Grain Tank Unloading Auger Control Rod
Grain Tank Unloading Auger Drive Sheave Throw-Out
Grate and Concaves
Guard and Extension, for Muffler
Guard for Transmission Sheave ( - 39349)
Guard for Transmission Sheave (39350 - )
Guards and Sickle
Handrails, Sacking Platform
Hillside Attachment for Shoe
Holders, Sack, and Sacking Spout
Hood, Rear
Hose Connection, Radiator
Housing for Clean Grain Auger
Housing for Clean Grain Hinged Unloading Auger
Housing for Fan (Cleaning)
Housing for Grain Tank Loading Auger
Housing for Grain Tank Riding Unloading Auger
Housing for Lower Tailings Auger
Housing for Upper Tailings Auger
Hydraulic Controls for Platform Lift
Hydraulic Controls for Selective Ground Speed
Hydraulic Cylinders, Brake Cylinder Main Wheel
Hydraulic Cylinders, Hydraulic Steering
Hydraulic Cylinders, Platform Lift
Hydraulic Cylinders, Selective Ground Speed Control
Hydraulic Hoses, Hydraulic Oil Reservoir
Hydraulic Hoses, Platform Lift
Hydraulic Hoses, Steering Oil Lines
Hydraulic Oil Line, Hydraulic Brake
Hydraulic Oil Line, Hydraulic Steering
Hydraulic Oil Line, Platform Lift ( - 3000)
Hydraulic Oil Line, Platform Lift (3001 - 12050)
Hydraulic Oil Line, Platform Lift (24949 - 46800)
Hydraulic Oil Line, Platform Lift (46801 - )
Hydraulic Oil Line, Platform Lift (Vickers) (12051 - 32430)
Hydraulic Oil Line, Selective Ground Speed Control (12051 - 46800)
Hydraulic Oil Line, Selective Ground Speed Control (46801 - )
Hydraulic Oil Pump, Valve, and Reservoir with Connections
Hydraulic Pumps, Cessna (Power Steering) (46801 - )
Hydraulic Pumps, Hydreco (24949 - )
Hydraulic Pumps, Hydreco (Power Steering) (34949 - 46800)
Hydraulic Pumps, Pesco ( - 12051)
Hydraulic Pumps, Pesco (24949 - 546800)
Hydraulic Unit Drive
Hydraulic Unit Drive Shaft and Throw-Out
Hydrualic Unit Drive (Vickers) (12051 - 32430)
Hydraulic Valves, Hydraulic Steering
Hydraulic Valves, Hydraulic Steering Relief
Hydraulic Valves, Cessna ( - 12050)
Hydraulic Valves, John Deere (24949 - )
Hydraulic Valves, Parker (4757 - 12050)
Hydraulic Valves, Pesco ( - 4756)
I
ID VIEW
Intake Pipe, Air Cleaner
K
Knife Head
Knife Sections (For Straw Chopper)
L
Ladder on Separator
Ladder, Operator's Platform
Lever, Gearshift
Lever, Grain Tank Unloading
Lever, Platform Hydraulic
Lever, Selective Ground Speed Control
Lever, Separator Belt Tightener
Lifting Guards (For Sickle)
Lighting Attachment
Lines, Oil, Selective Ground Speed Control (12051 - 46800)
Lines, Oil, Selective Ground Speed Control (46801 - )
Lining, Brake, Main Wheel ( - 39349)
Lining, Brake, Main Wheel (39350 - )
Lining, Brake, Parking
Lower Tailing Auger and Housing
M
Main Bearings (Engine)
Main Wheel
Main Wheel Brake and Linings
Main Wheel Clutch ( - 39349)
Main Wheel Clutch (39350 - )
Main Wheel Differential Gears and Axle Shaft
Main Wheel Differential Housing
Main Wheel Hydraulic Brake Cylinder and Oil Lines
Main Wheel Reduction Gears and Housing
Main Wheel Transmission Brake and Reduction Gear Housing
Main Wheel Transmission Gears and Case ( - 39349)
Main Wheel Transmission Gears and Case (39350 - )
Main Wheel Transmission Shifter and Housing ( - 39349)
Main Wheel Transmission Shifter and Housing (39350 - )
Manifold and Exhuast Pipe
Motor, Starting
Muffler Guard and Extension Pipe
O
Oil Filter (Purolator)
Oil Lines for Main Wheel Hydraulic Brakes
Oil Lines for Selective Ground Speed Control (12051 - 46800)
Oil Lines for Selective Ground Speed Control (46801 - )
Oil Pan
Oil Pump
Oil Reservoir, Hydraulic
Oil Tube, Governor
Operator's Platform
Operator's Platform Ladder
Operator's Platform Seat
Operator's, Seat, Sacking Platform
P
Paddles, Clean Grain Elevator
Pan, Oil
Pipe Intake, Air Cleaner
Pipe, Muffler Extension
Pipe, Reel
Pipe, Sickle Drive Oscillating
Plates, Concave
Platform Angles and Braces
Platform Auger
Platform Auger Drive Parts at L.H. End
Platform Auger Extension
Platform Bottom Sheets
Platform Bottom Shields
Platform End Sheet, and Divider
Platform Extension Divider
Platform, Operator's
Paddles, Tailings Elevator
Platform, Sacking, Support Angles, and Handrails
Plug, Spark
Powershaft on Engine
Pre-Cleaner (Engine)
Pulley, Separator Drive on Engine
Pump, Fuel, and Filter
Pump, Oil
Pump, Water
R
Radiator, Radiator Screen and Water Line
Rasp Bar
Rear Axle
Rear Beater, Behind Cylinder
Rear Hood
Rear Hood Extension (for Straw Chopper)
Rear Wheel and Stub Axle
Rear Wheel Supports
Reduction Gears and Housing, Main Wheel
Reel
Reel Arm
Reel Drive Shaft at Rear of Platform
Reel Pipe
Reel Slat
Reel Slats End Shield
Reel Support Arms, L.H. and R.H.
Reflective Tape, Safety
Regulator, Voltage
Reverse Drive, Straw Chopper
Rings, Piston Compression (Engine)
Rod, Control, Separator Belt Tightener
Rods, Brace, for Main Wheel Axle Housing Support
Rods, Connecting (Engine)
Rods, Control, Selective Ground Speed and Platform Lift
Rotor Drive, Hart ScourKleen, Model "N"
Rotor Drive, Hart ScourKleen, Model "S-35"
S
Sack Chute and Supports
Sack Holders
Sack Shelf and Clean Grain Elevator Support
Sacking Platform Floorboard and Operator's Seat
Sacking Platform Side Sheets and Engine Shields
Sacking Platform, Support Angle, and Handrails
Sacking Spout
ScourKleen, Hart, Model "N"
ScourKleen, Hart, Model "S-35"
ScourKleen, Hart, Model "S-35" Upright and Sill Angles
ScourKleen, Hart, Weed Seed Auger and Housing for Models "N" and "S-35"
ScourKleen, Hart, Weed Seed Spout and Box
Screen Radiator
Screens, Hart, ScourKleen, Model "N"
Screens, Hart, ScourKleen, Model "S-35"
Seat, Operator's Platform
Seat, Operator's Sacking Platform
Section, Sickle
Separator Belt Tightener Control Rod
Separator Belt Tightener Control Lever
Separator Brace Channels
Separator Front End Sheets
Separator Side Sheets, L.H. and Frame Angles
Separator Side Sheets, R.H. and Frame Angles
Separator Top Sheets and Supports
Shelf, Sack and Clean Grain Elevator Support
Shield, End, Reel Slats
Shield for Cylinder, Fan Shoe, and Straw Walker Drives
Shield for Fan Housing (Special)
Shield for Variable Drive
Shields, Cleaning Fan Housing
Shields, Platform Bottom
Shifters and Housing, Transmission ( - 39349)
Shifters and Housing, Transmission (39350 - )
Shoe
Shoe, Hillsdie Attachment
Shoe Pitman and Crank
Sickle
Sickle and Auger Drive Shaft on Rear of Platform
Side Sheets, Sacking Platform
Sieves, Chaffer and Finger Bar
Slat, Reel
Spark Plug
Spark Plug Wires and Coil
Speed Indicator, Variable Drive Relative (Special)
Spike-Tooth Concaves
Spike-Tooth Cylinder
Spout, Hinged Unloading Auger
Spout, Rigid Unloading Auger
Spout, Sacking
Spout, Weed Seed (Sacker)
Spouts, ScourKleen Discharge (Sacker)
Spreader, Straw
Stand, Support, Cutting Platform (Special)
Starting Motor
Starting Switch
Steering Arms and Tie Rods
Steering Cable
Steering Controls on Operator's Platform
Steering Gear
Straw Chopper
Straw Chopper Extensions for Rear Hood
Straw Chopper Housing, with Fins and Shields
Straw Spreader
Straw Walker
Straw Walker Crankshafts and Bearings
Support, Axle
Supports, Rear Wheel
Supports, Separator Top Sheets
Switch Box, Wire, and Cables
Switch, Starting
T
Tailings Auger Drive, Lower
Tailings Auger Drive, Upper
Tailings Elevator
Tank, Fuel, and Supports
Tank, Grain
Tape, Reflective, Safety
Tappets (Engine)
Throttle and Choke Controls
Throw-Out, Grain Tank Unloading Auger Drive Sheave
Tie Rods and Steering Arms
Tire and Tube, Main Wheel
Tooth, Concave
Tooth, Cylinder
Tracks, Crawler
Transmission Sheave Guard ( - 39349)
Transmission Sheave Guard (39350 - )
Transmission Shifters and Housings, Main Wheel ( - 39349)
Transmission Shifters and Housings, Main Wheel (39350 - )
Tube, Breather
Tube, Oil, Governor
U
Upper Tailings Auger and Housing
Upright and Sill Angles for Hart ScourKleen, Model "S-35"
V
Valves and Valve Cover (Engine)
Variable Drive Relative Speed Indicator (Special)
Voltage Regulator
W
Walkers, Straw
Warming Lighting
Weed Bar
Weed Seed Auger and Housing for Hart ScourKleen, Models "N" and "S-35"
Weed Seed Spout (Sacker)
Wheel Brake, Individual Hydraulic
Wheel, Main
Wheel, Rear
Wiper Reel Slat
Wires, Cable and Switch Box
Wires, for Electromagnetic Throw-Out clutch for Platform
Wires, Spark Plug
Wrench, Wheel
Brand: John Deere
Part Number: PC0337
ALPHABETICAL INDEX
A
Air Cleaner
Arm, Reel
Auger, Platform
Axle, Rear
Axle Support
B
Bar, Rasp
Bar, Weed
Brake, Transmission
C
Cap, Radiator
Carburetor
Chopper, Straw
Chute, Sack
Clean Grain Auger
Coil (Engine)
Concave Tooth
Controls, Gearshift
Crank, Shoe Pitman
Crankshaft (Engine)
Crawler Tracks
Cylinder, Rasp-Bar
Cylinder Sprockets
Cylinder Tooth
Decalcomania Set
Distributor
Drives for Cylinder
E
Elevator, Tailings
End Sheet, Platform
Extension Divider
F
Final Drive
Flywheel (Engine)
G
Gear Cover (Engine)
Gearshift Controls
Gear, Steering
Generator
Governor
Grain Grate Fingers
Grain Tank
Grate and Concaves
Guards and Sickle
Hood, Rear
I
ID VIEW
K
Knife Head
L
Ladder on Separator
Lever, Gearshift
Lighting Attachment
M
Main Wheel
Motor, Starting
O
Oil Pan
Oil Pump
Oil Tube, Governor
Operator's Platform
P
Pan, Oil
Pipe, Reel
Plates, Concave
Platform Auger
Plug, Spark
Pump, Oil
Pump, Water
R
Rasp Bar
Rear Axle
Rear Hood
Rear Wheel Supports
Reel
Reel Arm
Reel Pipe
Reel Slat
Regulator, Voltage
S
Sack Holders
Sacking Spout
Screen Radiator
Section, Sickle
Shoe
Sickle
Slat, Reel
Spark Plug
Spout, Sacking
Spreader, Straw
Starting Motor
Starting Switch
Steering Cable
Steering Gear
Straw Chopper
Straw Spreader
Straw Walker
Support, Axle
Switch, Starting
T
Tailings Elevator
Tank, Grain
Tappets (Engine)
Tooth, Concave
Tooth, Cylinder
Tracks, Crawler
Tube, Breather
Tube, Oil, Governor
U
V
Voltage Regulator
W
Walkers, Straw
Warming Lighting
Weed Bar
Wheel, Main
Wheel, Rear
Wiper Reel Slat
Wires, Spark Plug
Wrench, Wheel
- JOHN DEERE CODE DTC LIST
