John Deere 5303 5103 5203 5204 5403 Tractor Technical Manual TM900019
Brand: John Deere
Type of Manual: Technical Manual
Model: John Deere 5303 5103 5203 5204 5403 Tractor
Serial Number: 2013
Part Number: TM900019
Publication Date: 2013
Number of Pages: 2365 Pages
FOREWORD
Section 10 - GENERAL INFORMATION
Group 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Service Cooling System Safely
Avoid High-Pressure Fluids
Park Machine Safely
Support Machine Properly
Wear Protective Clothing
Work in Clean Area
Service Machines Safely
Work In Ventilated Area
Illuminate Work Area Safely
Replace Safety Signs
Use Proper Lifting Equipment
Service Tires Safely
Avoid Harmful Asbestos Dust
Use Proper Tools
Dispose of Waste Properly
Live With Safety
Group 10 - General Specifications
Machine Specifications (For USA and Australia Tractors)
Machine Specifications (For USA Tractors)
Machine Specifications (For Latin America Tractors)
Machine Specifications (Mexico Tractors)
Repair Specifications
Ground Speed Estimates
Service Recommendations for O-Ring Boss Fittings
Service Recommendations for Flat Face O-Ring Seal Fittings
Metric Bolt and Cap Screw Torque Values
Unified Inch Bolt and Cap Screw Torque Values
Group 15 - Fuel and Lubricants
Diesel Fuel
Biodiesel Fuel
Fuel Storage
Do Not Use Galvanized Containers
Fill Fuel Tank
Diesel Engine Oil
Heavy Duty Diesel Engine Coolant
Transmission and Hydraulic Oil
Grease (Specific Application)
Grease
Lubricant Storage
Group 20 - Serial Number Locations
Serial Numbers
Product Identification Number Location
Engine Serial Number Location
Fuel Injection Pump Serial Number Location
Alternator Serial Number Location
Power Steering Valve Serial Number Location
Starter Serial Number Location
Transmission Serial Number Location
Front Axle Serial Number Location (2WD)
Front Axle Serial Number Location (MFWD)
Group 25 - Features and Accessories
Standard Features
Factory Installed Optional Equipment
Field Installed Optional Kits and Accessories
Section 20 - ENGINE REPAIR
Group 05 - Engine
Service Equipment and Tools
Specifications
John Deere Engine Repair—Use CTM8
Remove Engine
Install Engine
Engine Disassembly Sequence
Sealant Application Guidelines
Engine Re-Assembly Sequence
Engine Break-In Guidelines
Perform Engine Break-In
Diesel Engine Break-In Oil
Group 10 - Cylinder Head and Valves
Special or Essential Tools
Specifications
Torques for Hardware
Cylinder Head - Exploded View
Check Valve Lift
Remove Cylinder Head
Clean Injection Nozzle Bores
Valve Actuating Parts
Remove Valves and Valve Springs
Checking Cylinder Head Flatness
Clean Valve Guides
Measure Valve Guides
Knurl Valve Guides
Clean and Inspect Valve Seats
Lapping Valve Seats
Check Valve Recess
Remove Valve Seat Inserts
Valve Seat Insert Installation
Check Valves
Grind Valves
Check Valve Spring Compression
Inspect Valve Rotators
Install Valves
Install Cylinder Head
Torque Turn Tightening Method
Disassembling and Checking Rocker Arm Shaft
Reassembling Rocker Arm Shaft
Install Rocker Arm Assembly
Valve Clearance
Valve Adjustment Sequence
Install Rocker Arm Cover
Final Work
Group 15 - Cyl. Block, Liners, Pistons & Rods
Specifications
Exploded View
Connecting Rods - General Information
Remove Pistons and Connecting Rods
Measure Cylinder Liner Bore
Remove Cylinder Liners
Cylinder Liner Deglazing
Cylinder Block Cleaning
Check Piston Cooling Jets
Cam Follower Bore Measure
Measure Camshaft Bore
Remove Camshaft Bushing
Install Camshaft Bushing
Measure Crankshaft Bore
Replace Crankshaft Bearing Caps
Cylinder Block Top Desk Flatness
Measure Cylinder Liner Protrusion
Liner Packing Installation
Liner O-Ring Installation
Install Cylinder Liners
Measure Connecting Rod Bearing
Rod Bearing Clearance
Measure Connecting Rod Bushing
Replace Connecting Rod Bushing (3029D)
Replace Connecting Rod Bushing (3029T)
Measure Piston Pin
Clean and Inspect Pistons
Measure Piston Pin Bore
Piston Top Ring Groove
Second and Third Piston Ring Grooves
Piston Head and Skirt Checking
Install Piston Rings
Piston Rings Staggering
Piston/Liner Set Information
Assemble Piston and Connecting Rod
Install Piston and Connecting Rod
Measure Piston Protrusion
Complete Final Assembly
Group 20 - Crankshaft, Main Bearings and Flywheel
Specifications
Torques For Hardware
Remove Crankshaft Pulley
Install Crankshaft Pulley
Flywheel Removal
Flywheel Ring Gear Replacement
Install Ball Bearing
Install Flywheel
Remove Crankshaft Rear Oil Seal
Flywheel Housing Replacement (′S′ Transmission)
Flywheel Housing Replacement (′AA′ Transmission)
Install Oil Seal/Wear Sleeve
Crankshaft End Play Measure
Remove Crankshaft
Crankshaft Inspection
Check Crankshaft Journal Diameter
Determine Crankshaft Main Bearing Clearance Using PLASTIGAGE PLASTIGAGE is a trademark of DANA Corp.
Regrind Crankshaft
Crankshaft Regrinding Guidelines
Micro-Finishing Specifications
Replace Crankshaft Gear
Install Main Bearing Inserts
Install 2-Piece Thrust Bearing
Crankshaft Installation
Group 25 - Camshaft and Timing Gear Train
Specifications
Remove Crankshaft Front Oil Seal
Remove Timing Gear Cover
Measure Timing Gear Backlash
Camshaft End Play Measure
Remove Camshaft
Measure Camshaft Journal
Measure Height of Cam Lobe
Replace Camshaft Gear
Install Camshaft
Check Cam Follower
Idler Gear End Play Measure
Remove Front Plate
Idler Gear Bushing and Shaft Measure
Idler Gear Bushing Replacement
Remove Idler Shaft
Install Idler Shaft Spring Pin
Install Idler Shafts
Install Front Plate
Install Upper Timing Gear Train
Install Lower Timing Gear Train
Install Oil Deflector
Timing Gear Cover Identification
Install Timing Gear Cover
Install Crankshaft Front Oil Seal
Install Wear Ring
Install Auxiliary Equipment
Group 30 - Lubrication System
Specifications
Oil Cooler Identification
Remove Oil Cooler
Replace Oil Cooler Nipple
Install Oil Cooler
Replace Oil Cooler/Filter Bracket on Engine with Auxiliary Drive
Remove Oil Pressure Regulating Valve
Replace Oil Pressure Regulating Valve Seat
Install Oil Pressure Regulating Valve
Replace Oil Dipstick Guide
Replace Oil By-Pass Valve
Replace Oil Pump Strainer
Remove Oil Pump
Oil Pump Gear Axial Clearance
Oil Pump Gear Radial Clearance
Oil Pump Specifications
Oil Pump Installation
Install Oil Pan
Group 35 - Cooling System
Specifications
Remove and Inspect Radiator
Remove and Inspect Radiator(5045D, 5045E, 5055D, 5055E, 5065E and 5075E Tractors)
Water Pump — Exploded View
Remove Water Pump
Disassemble Water Pump
Assemble Water Pump
Install Water Pump
Inspect Thermostat
Cooling System Deaeration
Check Fan/Alternator Belt Tension
Install Fan
Install Radiator
Install Radiator(5045D, 5045E, 5055D, 5055E, 5065E and 5075E Tractors)
Replace Thermostat
Section 30 - FUEL AND AIR REPAIR
Group 05 - Fuel System
Injection Pump, Nozzle and Governor Repair—Use CTM8
Remove, Inspect and Install Fuel Tank
Replace Fuel Filter
Replace Fuel Filter/Primer Pump Assembly
Remove Fuel Injection Pump
Repairs to Fuel Injection Pump
Replace Throttle Lever
Install Fuel Injection Pump
Remove Fuel Injection Nozzle
Clean Fuel Injection Nozzle
Fuel Injection Nozzle Disassembly
Install Fuel Injection Nozzle
Group 10 - Air Intake and Exhaust System
Remove, Inspect, and Install Air Cleaner Elements
Check Air Inlet Pipe
Check Air Inlet Pipe with Turbocharger (If Equipped)
Exhaust Manifold Inspection (If Equipped)
Remove Turbocharger (If Equipped)
Turbocharger Cut-Away View (Borge Warner) - (If Equipped)
Check Radial Clearance
Check Axial Clearance
Repair Turbocharger (If Equipped)
Prelube Turbocharger (If Equipped)
Install Turbocharger (If Equipped)
Turbocharger Break-In (If Equipped)
Recommendations for Turbocharger Use (If Equipped)
Group 15 - Speed Control Linkage
Inspect and Repair Speed Control Linkage
Section 40 - ELECTRICAL REPAIR
Group 05 - Battery, Starter and Alternator
Starter Repair—Use CTM77
Remove and Install Battery
Remove and Install Starter
Replace Alternator/Regulator
Group 10 - Electrical System Components
Other Material
Replace Air Filter Restriction Sensor
Replace Coolant Temperature Sender
Replace Engine Speed Sensor
Replace Engine Oil Pressure Sensor
Replace Key Switch
Replace Light Switch
Replace Turn Signal Controller
Replace Instrument Panel
Replace Rear PTO Switch (If Equipped)
Remove and Install Rear PTO Switch-For 5045E, 5055E, 5065E and 5075E Tracators
Replace Park Position Start Switch
Replace Seat Switch (If Equipped)
Replace Fuel Level Sender
Group 15 - Wiring Harness
Service Parts Kits
Remove Connector Body from Blade Terminals
Replace WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Connector
Install WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Contact
Replace Tractor Wiring Harness
Replace Tractor Wiring Harness (5204 Mexico Tractor)
Section 50 - POWER TRAIN REPAIR
Group 05 - Clutch Housing
Other Material
Specifications
Separate Engine from Clutch Housing
Install Engine to Clutch Housing
Replace Clutch Housing Seal (′S′ Transmission)
Inspect and Repair Clutch Pedal and Linkage (′S′ Transmission)
Inspect and Repair Clutch Pedal and Linkage (′AA′ Transmission)
Group 10 - Clutch Assembly
Essential Tools
Other Material
Specifications
Remove and Install Clutch Assembly
Disassemble and Inspect Clutch Assembly
Assemble Clutch Assembly
Traction Clutch Finger Adjustment
PTO Clutch Finger Adjustment
Remove and Inspect Clutch Release Mechanism and Shafts
Install Clutch Release Mechanism and Shafts
Group 15 - ′S′ Transmission
Specifications
Separate Clutch Housing From Transmission
Install Clutch Housing to Transmission
Inspect and Repair Gear Shift Levers
Inspect and Repair Gear Shift Lever (For 5045E, 5055E, 5065E and 5075E Tractors)
Inspect and Repair Range Shift Lever
Inspect and Repair Range Shift Lever (For 5045E, 5055E, 5065E and 5075E Tractors)
Remove Transmission
Disassemble and Inspect Transmission— Collarshift
Assemble Transmission — Collarshift
Disassemble and Inspect Transmission — SyncShuttle™
Assemble Transmission — SyncShuttle™
Install Transmission
Disassemble, Inspect and Assemble Gear Shift Shaft Assemblies
Disassemble, Inspect, and Assemble CollarShift Transmission Top Shaft
Disassemble, Inspect, and Assemble SyncShuttle™ Transmission Top Shaft— For Australia Tractors
Disassemble, Inspect, and Assemble SyncShuttle™ Transmission Top Shaft—For USA Tractors
Disassemble, Inspect, and Assemble Transmission Top Shaft—Partial SyncShuttle™ Transmission
Disassemble, Inspect, and Assemble Range Reduction Shaft
Disassemble, Inspect and Assemble Driven Shaft
Remove, Inspect, and Install Range Gears
Remove, Inspect, and Install Reverse Idler Shaft
Group 20 - ′AA′ Transmission
Other Material
Specifications
Remove, Inspect and Repair Gear Shift Lever And Cover
Remove, Inspect and Repair Gear Shift Lever And Cover (For 5045D and 5055D Tractors)
Remove, Inspect and Install Range and Reverse Shift Lever
Remove, Inspect and Install Range and Reverse Shift Lever (For 5045D and 5055D Tractors)
Remove Transmission
Disassemble, Inspect and Assemble Shift Shaft Assemblies
Disassemble, Inspect, and Assemble Transmission Main Shaft
Disassemble, Inspect and Assemble Range Reduction Shaft
Disassemble, Inspect and Assemble Traction Clutch Driven Shaft
Group 21 - Rear PTO (′S′ Transmission)
Other Material
Specifications
Remove, Inspect and Install Rear PTO Lever and Linkage
Remove, Inspect and Install Rear PTO Lever and Linkage - Cable Linkage
Remove, Inspect and Install Rear PTO Lever and Linkage - Cable Linkage - For 5045E, 5055E, 5065E and 5075E Tractors
Remove and Install Standard Rear PTO Drive Shaft Assembly
Disassemble, Inspect and Assemble Standard Rear PTO Drive Shaft Assembly
Group 25 - Rear PTO (′AA′ Transmission)
Other Material
Specifications
Remove, Inspect and Install Rear PTO Lever and Linkage - For 5045D and 5055D Tractors
Remove and Install Rear PTO Drive Shaft Assembly
Disassemble, Inspect and Assemble Rear PTO Drive Shaft Assembly
Group 26 - Differential
Essential Tools
Other Material
Specifications
Service Parts Kits
Remove and Install Differential Assembly
Disassemble, Inspect, and Assemble Differential Assembly (′S′ Transmission)
Disassemble, Inspect and Assemble Differential Assembly (′AA′ Transmission)
Remove and Inspect Differential Drive Shaft (′S′ Transmission)
Install Differential Drive Shaft (′S′ Transmission)
Remove and Inspect Differential Drive Shaft (′AA′ Transmission)
Install Differential Drive Shaft (′AA′ Transmission)
Remove, Inspect, and Install Differential Lock Assembly (′S′ Transmission)
Remove, Inspect and Install Differential Lock Assembly (′AA′ Transmission)
Differential Cone Point Adjustment
Differential Backlash Adjustment
Group 30 - Final Drives
Other Material
Specifications
Remove and Install Final Drive Assembly
Remove and Inspect Planetary Drive Assembly
Install Planetary Drive Assembly
Remove, Inspect, and Install Axle Shaft Assembly (′S′ Transmission)
Remove, Inspect, and Install Axle Shaft Assembly (′AA′ Transmission)
Group 35 - Mechanical Front Wheel Drive
Essential Tools
Other Material
Specifications
MFWD Axle Repair—Use CTM4870 and CTM4820
Inspect and Repair MFWD Lever and Linkage
Remove and Install MFWD Drop Gearbox
Disassemble and Inspect MFWD Drop Gearbox
MFWD Drop Gearbox Cross Section
Assemble MFWD Drop Gearbox
Remove, Inspect and Install MFWD Drive Shaft
Remove and Install MFWD Axle Housing Assembly
Remove, Inspect and Install Axle Supports (Without Paddy Seal)
Remove, Inspect and Install Axle Supports (With Paddy Seal)
Section 60 - STEERING AND BRAKE REPAIR
Group 05 - Steering Repair
Other Material
Specifications
Service Parts Kits
Remove and Install Steering Column and Valve
Remove and Install Steering Column and Valve - For 5045E, 5055E, 5065E and 5075E Tractors
Remove and Install Steering Column and Valve - For 5045D and 5055D Tractors
Disassemble and Inspect Steering Valve - Sauer Danfoss
Assemble Steering Valve - Sauer Danfoss
Disassemble and Inspect Steering Valve - Eaton
Assemble Steering Valve - Eaton
Remove and Install Steering Cylinder (Global Front Axle)
Disassemble, Inspect and Assemble Steering Cylinder (Global Front Axle)
Remove and Install Steering Cylinder (Fixed Front Axle)
Disassemble, Inspect and Assemble Steering Cylinder (Fixed Front Axle)
Remove, Inspect and Install Tie Rod Assembly
Group 10 - Brake Repair (′S′ Transmission)
Other Material
Specifications
Remove and Install Brake Valve and Pedals
Disassemble and Inspect Brake Pedals and Valve
Brake Valve Cross Section
Assemble Brake Valve
Remove and Inspect Brakes
Install Brakes
Inspect and Replace Brake Hydraulic Lines
Group 15 - Brake Repair (′AA′ Transmission)
Other Material
Specifications
Remove and Install Brake Pedals and Linkage
Remove and Install Park Brake Lever and Linkage—For 5045D and 5055D Tractors (From Tractor Serial Number xxxxx)
Install Brakes
Section 70 - HYDRAULIC REPAIR
Group 05 - Hydraulic Pump and Filter
Essential Tools
Specifications
Service Parts Kits
Remove, Inspect, and Install Hydraulic Oil Pick-Up Screen
Remove and Install Hydraulic Pump
Remove Hydraulic Pump External Components
Disassemble and Inspect Hydraulic Pump
Assemble Hydraulic Pump
Install Hydraulic Pump External Components
Remove and Install Hydraulic Oil Filter/Manifold
Inspect and Replace Hydraulic Supply and Suction/Return Lines
Group 10 - MITA Rockshaft
Other Material
Specifications
Remove, Inspect, and Install Rockshaft Control Lever Assembly
Remove, Inspect, and Install Rockshaft Control Lever Support Assembly
Remove, Inspect and Install Rockshaft Control Linkage
Replace Main Relief Valve(MITA Rockshaft)
Remove, Inspect and Install Rate-of-Drop Valve
Replace Rockshaft Control Valve
Remove and Install Rockshaft Case(MITA Rockshaft)
Remove, Inspect and Install Rockshaft Lift Arms
Remove, Inspect and Install Rockshaft Piston and Cylinder
Group 15 - JD Rockshaft
Other Material
Specifications
Inspect and Repair Rockshaft Control Lever Assembly
Inspect and Repair Rockshaft Control Linkage
Inspect and Repair Draft Sensing Support Assembly (′S′ Rockshaft)
Inspect and Repair Draft Sensing Support Assembly (′AA′ Rockshaft)
Replace Main Relief Valve(JD Rockshaft)
Replace Rockshaft Surge Relief Valve(′S′ Rockshaft)
Replace Rockshaft Surge Relief Valve(′AA′ Rockshaft)
Replace Rockshaft Control Valve(JD Rockshaft)
Remove and Install Rockshaft Case(JD Rockshaft)
Remove, Inspect, and Install Rockshaft Lift Arms (′S′ Transmission)
Remove, Inspect, and Install Rockshaft Piston and Cylinder (′S′ Transmission)
Remove, Inspect, and Install Rockshaft Lift Arms (′AA′ Transmission)
Remove, Inspect, and Install Rockshaft Piston and Cylinder (′AA′ Transmission)
Group 20 - MITA Selective Control Valve (SCV)
Install Single Selective Control Valve (SCV)
Install Rear Coupler Bracket
Install Hydraulic Hoses
Install Second Selective Control Valve (SCV)
Assemble Rear Quick Coupler
Group 25 - EATON Selective Control Valve (SCV)
Group 30 - Mid Mount Selective Control Valve (SCV)
Service Parts Kit
Other Material
Specifications
Remove and Install Mid Mount Control Valve
Remove, Inspect and Install Joystick and Cables—Mid Mount Valve
Disassemble, Inspect, and Assemble Joystick—Mid Mount Coupler
Disassemble, Inspect and Assemble Mid Mount Control Valve
Inspect and Replace Hydraulic Hoses—Mid Mount Coupler
Section 80 - MISCELLANEOUS REPAIR
Group 05 - Front Axle - 2WD
Specifications
Remove and Install Front Axle
Inspect and Replace Pivot Pin and Bushings
Remove and Install Spindle Assembly
Inspect and Replace Spindle Shaft Bushing (Adjustable Front Axle)
Inspect and Replace Spindle Shaft Bushings (Fixed Front Axle)
Group 10 - Wheels
Specifications
Inspect and Replace Front Wheel Bearings
Tighten Bolts—Rear Axle (M-20 Stud)
Group 15 - 3-Point Hitch
Specifications
Inspect and Repair Fixed Draft Links (′S′ Transmission)
Inspect and Repair Fixed Draft Links (′AA′ Transmission)
Inspect and Repair Telescoping Draft Links (If Equipped)
Inspect and Repair Lift Link (If Equipped)
Inspect and Repair Adjustable Lift Link (If Equipped)
Inspect and Repair Center Link
Group 25 - Hood
Remove and Install Hood
Section 90 - OPERATOR STATION REPAIR
Group 05 - Seat and Support
Remove and Install Seat and Support(For 5103, 5203, 5303 and 5403 Australia Tractors)
Remove and Install Seat and Support(For 5103, 5203, 5303, 5403, 5045E, 5055E, 5065E and 5075E Tractors)
Remove and Install Seat and Support(For 5045D and 5055D Tractors)
Disassemble, Inspect and Assemble Seat and Seat Switch (For 5045D, 5045E, 5055D, 5055E, 5065E and 5075E ractors)
Remove and Install Seat and Support(For 5303 and 5403 Latin America Tractors)
Remove and Install Seat and Support(For 5204 and 5303 Mexico Tractor)
Group 06 - Center Console
Remove Center Console Assembly
Install Center Console Assembly
Group 10 - Roll-GardRoll-Gard is a trademark of Deere & Company
Specifications
Remove and Install Roll-Gard Roll-Gard is a trademark of Deere & Company
Group 15 - Operator Platform
Specifications
Remove and Install Right-Side Platform and Step - Old
Remove and Install Left-Side Platform and Step - Old
Remove and Install Right-Side Platform and Step - New
Remove and Install Left-Side Platform and Step - New
Remove and Install Right-Side Platform and Step - 5045E, 5055E, 5065E and 5075E Tractors
Remove and Install Left-Side Platform and Handrail - 5045E, 5055E, 5065E and 5075E Tractors
Remove and Install Right-Side Platform and Step - 5045D and 5055D Tractors
Remove and Install Left-Side Platform and Handrail - 5045D and 5055D Tractors
Group 20 - Fenders
Remove and Install Fenders - Old
Group 25 - Canopy (If Equipped)
Specifications
Remove and Install Canopy
Section 210 - OPERATIONAL CHECKOUT PROCEDURES
Group 10 - Operational Checkout Procedures
Operational Checkout Procedure Information
Engine Oil Level and Condition Check
Coolant Level and Condition Check
Transmission and Hydraulic Oil Check
Fan and Belt Check
Fuel System Check
Air Intake System Check
Electrical System Check
Hydraulic System Check
Indicator Lamps Check
Engine Start Check
Transmission Park Position Start Check
Engine Fast and Slow Idle Operation
Power Steering Check
Differential Lock Check
Clutch Check
Transmission Shift Check
Range Lever Shift Check
Brake Check
Rockshaft Check
Selective Control Valve Check
Miscellaneous Checks
Section 220 - ENGINE OPERATION, TESTS AND ADJUSTMENTS
Group 05 - Component Location
Component Location Information
Engine External Components—Left-Hand Side
Engine External Components—Right-Hand Side
Group 10 - Theory of Operation
Theory of Operation Information
Engine Lubrication System
Engine Cooling System Operation
Group 15 - Diagnosis, Tests and Adjustments
Specifications
Essential Tools
Diagnostic Information
Engine Turns Over But Will Not Start or Starts Hard
Engine Runs Irregularly or Stalls Frequently
Engine Runs Rough
Engine Has Low Power
Engine Smokes—Black or Grey
Engine Smokes Excessively—White
Engine Uses Excess Fuel
Engine Has Excess Noise or Vibration
Engine Uses Excess Oil or Smokes Blue
Engine Has Low Oil Pressure
Engine Coolant Operating Temperature Incorrect
Oil In Coolant or Coolant in Oil
Radiator Bubble Test
Cooling System Test
Radiator Cap Pressure Test
Engine Oil Pressure Test
Cylinder Compression Pressure Test
Fuel Shut-Off Solenoid Check (If Equipped)
Throttle Lever Adjustment
Slow Idle Adjustment (Rotary Pump)
Fast Idle Adjustment (Rotary Pump)
Idle Speed Adjustment (In-Line Pump)
Injection Pump Timing Adjustment(Rotary Pump)
Injection Pump Timing Adjustment(In-Line Pump)
Valve Clearance Adjustment
Fan/Alternator Drive Belt Adjustment
Bleed Fuel System(For USA and Australia Tractors)
Bleed Fuel System(For Latin America and Mexico Tractors)
Bleed Fuel System At Fuel Injection Nozzles(For Latin America and Mexico Tractors)
Section 230 - FUEL/AIR OPERATION, TEST AND ADJUSTMENTS
Fuel System Components
Fuel System Components- 5045E, 5055E, 5065E and 5075E Tractors
Fuel System Components - 5045D and 5055D Tractors
Air Intake System Components
Fuel System Operation (′S′ Transmission)
Fuel System Operation - For 5045E, 5055E, 5065E and 5075E Tractors
Fuel System Operation (′AA′ Transmission)
Fuel System Operation - For 5045D and 5055D Tractors
Fuel Filter Pump Operation
Fuel Injection Pump Operation (Rotary Pump)
Fuel Transfer (Feed) Pump Operation(In-Line Pump)
Fuel Injection Pump Operation(In-Line Pump)
In-Line Pump Governor Operation
Fuel Injection Nozzle Operation
Air Intake System Operation
Turbocharger Operation
Check Turbocharger Boost Pressure
Diagnosing Turbocharger Malfunctions
Fuel/Air Diagnosis, Tests and Adjustments
Section 240 - ELECTRICAL SYSTEM OPERATION, TESTS & ADJUST
Engine Electrical Components—Right Hand Side
Engine Electrical Components—Left Hand Side
Dash And Center Control Console Electrical Components—Latin America, Mexico, USA and Australia (5103, 5203, 5303, 5403) Tractors
Dash And Center Control Console Electrical Components—(5103, 5203, 5303 and 5403) USA and Australia Tractors
Dash And Center Control Console Electrical Components—5045E, 5055E, 5065E and 5075E Tractors
Dash And Center Control Console Electrical Components—5045D and 5055D Tractors
Tractor Electrical Components
Tractor Electrical Components—5045E, 5055E, 5065E and 5075E Tractors
Tractor Electrical Components—5045D and 5055D Tractors
Group 10 - Theory of Operation—Latin America, Mexico, USA and Australia (5103, 5203, 5303, 5403) Tractors
Fuse Block and Fuses
Fuse Block and Fuses (Mexico 5204 Tractors)
Relays
Starting System Operation—Normal
Starting System Operation—Bypass Attempt
Charging System Operation
Lighting System Operation—Left Turn Signals And Warn Lights
Lighting System Operation—Right Turn Signals And Warn Lights
Lighting System Operation—Warning Lights
Lighting System Operation—Tail Lights
Lighting System Operation—Headlights and Instrument Lights
Instrument Panel System Operation—Tachometer/Hour Meter
PTO Warning System Operation (If Equipped)
Instrument Panel System Operation—Fuel Gauge
Instrument Panel System Operation—Temperature Gauge
Air Filter Restriction Indicator Operation
7-Pin Trailer Outlet Connector Operation (If Equipped)
Horn Operation - (Optional)
Rear Work Light - (If Equipped)
Group 15 - Theory of Operation—USA and Australia Tractors
Theory of Operation Information—For USA and Australia Tractors
Fuse Block and Fuses—Type I
Fuse Block and Fuses—Type II
Relays
Starting System Operation—Normal—Type I
Starting System Operation—Normal—Type II
Starting System Operation—Bypass Attempt—Type I
Starting System Operation—Bypass Protection—Type II
Starting System Operation—For 5045E, 5055E, 5065E, and 5075E Tractors (From Serial number XXXX)
Charging System Operation—Type I
Charging System Operation—Type II
Lighting System Operation—Left Turn Signals And Warn Lights—Type I
Lighting System Operation—Left Turn Signals And Warn Lights—Type II (with MARCUREX Flasher)
Lighting System Operation—Right Turn Signals And Warn Lights—Type I
Lighting System Operation—Right Turn Signals And Warn Lights—Type II (with MARCUREX Flasher)
Lighting System Operation—Left Turn Signals And Warn Lights—Type II (with Hella Flasher)
Lighting System Operation—Right Turn Signals And Warn Lights—Type II (with Hella Flasher)
Lighting System Operation—Left Turn Signals And Warn Lights—Type II (with MARCUREX/Hella Flasher)
Lighting System Operation—Right Turn Signals And Warn Lights—Type II (with MARCUREX/Hella Flasher)
Lighting System Operation—Warning Lights—Type I
Lighting System Operation—Warning Lights—Type II (with MARCUREX Flasher)
Lighting System Operation—Warning Lights—Type II (with Hella Flasher)
Lighting System Operation—Headlights and Instrument Lights—Type I
Lighting System Operation—Headlights and Instrument Lights—Type II
Lighting System Operation—Tail Lights—Type I
Instrument Panel System Operation—Tachometer/Hour Meter—Type I
Instrument Panel System Operation—Tachometer—Type II
PTO Warning System Operation—Type I (Optional)
PTO Warning System Operation—Type II
Instrument Panel System Operation—Fuel Gauge—Type I
Instrument Panel System Operation—Fuel Gauge—Type II
Instrument Panel System Operation—Temperature Gauge—Type I
Instrument Panel System Operation—Temperature Gauge—Type II
Air Filter Restriction Indicator Operation—Type I
Air Filter Restriction Indicator Operation—Type II
7-Pin Trailer Outlet Connector Operation—Type I (Optional)
7-Pin Trailer Outlet Connector Operation—Type II
Horn Operation
Rear Work Light—Type I (Optional)
Rear Work Light—Type II (with Jumper Cable)
Rear Work Light—Type II (without Jumper Cable)
Group 20 - Diagnosis, Test and Adjust—Latin America, Mexico (5303), USA and Australia (5103, 5203, 5303, 5403) Tractors
Wire Color Chart
Starting System Test Points—Normal Operation
Starting System Test Points—Bypass Attempt
Charging System Test Points
Lighting System Test Points—Turn Signals And Enhanced Tail Lights
Lighting System Test Points—Warning Lights
Lighting System Test Points—Rear Flood Light
Lighting System Test Points—Headlights and Instrument Lights
Instrument Panel System Test Points—Tachometer/Hourmeter
Instrument Panel System Test Points—Fuel Gauge
Instrument Panel System Test Points—Temperature Gauge
Instrument Panel System Test Points—Oil Pressure
Air Filter Restriction Test Points
Optional Horn Test Points
Accessory Relay and Trailer Connector Test Points
Battery Voltage and Specific Gravity Tests
Charge Battery
Battery Load Test
Starter AMP Draw/RPM Test
Starter No-Load AMP Draw/RPM Test
Alternator/Regulator Test
Starter Solenoid Test
Starter Relay Test
Key Switch Test
Plug-In Relay Test
Mini Plug-In Relay
Diode Pack Test
Fuse Test
Park Position Start Switch Test
PTO Switch Test
PTO Seat Switch Test
Light Switch Test
Turn Signal Controller Test
Fuel Shut-Off Solenoid Test
Group 25 - Diagnosis, Test and Adjust—USA and Australia Tractors
Wire Color Chart
Starting System Test Points—Normal Operation—Type I
Starting System Test Points—Normal Operation—Type II
Starting System Test Points—For 5045E, 5055E, 5065E, and 5075E Tractors (From Serial number XXXX)
Starting System Test Points—Bypass Attempt—Type I
Charging System Test Points—Type I
Charging System Test Points—Type II
Lighting System Test Points—Turn Signals And Enhanced Tail Lights—Type I
Lighting System Test Points—Turn Signals And Enhanced Tail Lights—Type II (with Hella Flasher)
Lighting System Test Points—Turn Signals And Enhanced Tail Lights—Type II (with MARCUREX Flasher)
Lighting System Test Points—Warning Lights—Type I
Lighting System Test Points—Warning Lights—Type II (with Hella Flasher)
Lighting System Test Points—Warning Lights—Type II (with MARCUREX Flasher)
Lighting System Test Points—Rear Flood Light—Type I
Lighting System Test Points—Flood Lights—Type II (with Jumper Cable)
Lighting System Test Points—Flood Lights—Type II (without Jumper Cable)
Lighting System Test Points—Headlights and Instrument Lights—Type I
Lighting System Test Points—Headlights and Instrument Lights—Type II
Instrument Panel System Test Points—Manifold Heater—Type II
Instrument Panel System Test Points—PTO Light—Type II
Instrument Panel System Test Points—Tachometer/Hourmeter—Type I
Instrument Panel System Test Points—Tachometer—Type II
Instrument Panel System Test Points—Fuel Gauge—Type I
Instrument Panel System Test Points—Fuel Gauge—Type II
Instrument Panel System Test Points—Temperature Gauge—Type I
Instrument Panel System Test Points—Temperature Gauge—Type II
Instrument Panel System Test Points—Oil Pressure—Type I
Instrument Panel System Test Points—Oil Pressure—Type II
Air Filter Restriction Test Points—Type I
Air Filter Restriction Test Points—Type II
Horn Test Points—Type I (Optional)
Horn Test Points—Type II
Accessory Relay and Trailer Connector Test Points—Type I
Accessory Relay and Trailer Connector Test Points—Type II
Charge Battery
Battery Load Test
Starter Relay Test
Key Switch Test
Plug-In Relay Test
Mini Plug-In Relay
Diode Pack Test
Fuse Test
PTO Switch Test
Light Switch Test
Group 30 - Diagnosis, Test and Adjust (Mexico 5204 Tractors)
Lighting System Test Points—Turn Signals and Warning Lights
Horn Test Points
Charge Battery
Battery Load Test
Starter Relay Test
Plug-In Relay Test
Diode Pack Test
Fuse Test
Neutral Start Switch Test
Turn Signal Controller (Flasher) Test
Group 35 - Wiring Schematics—Latin America, Mexico (5303), USA and Australia (5103, 5203, 5303, 5403) Tractors
Schematic Information
Component Identification Table
Electrical Schematic Legend
Group 40 - Wiring Schematics—For USA and Australia Tractors
Schematic Information—For USA and Australia Tractors
Quick Reference Table—Type II
Electrical Schematic Legend—Type I
Electrical Schematic—Type II
Electrical Schematic—(Starting Circuit) For 5045E, 5055E, 5065E, and 5075E Tractors (From Serial number XXXX)
Group 45 - Wiring Schematics (Mexico 5204 Tractors)
Electrical Circuits
Group 50 - Component Information—Connectors(For USA and Australia Tractors)
Component Location - Connectors (Summary of Information)
X1 - 1-Pin Connector for Ground
X2 - 16-Pin Connector for Instrument Panel
X3 - 1-Pin Connector for Body Ground
X4 and X5 - 6-Pin Connectors for Front to Rear Wiring Harness
X6 and X7 - 6-Pin Connectors for Front to Rear Wiring Harness
X8 - 1-Pin Connector for Ground
X9 - 1-Pin Connector for Ground
X10 and X11 - 3-Pin Connectors for Hood Wiring Harness
X12 - 6-Pin Connector for Trailer Connection - 2 andX13 - 2-Pin Connector for Trailer Connection - 1
X14 and X15 - 16-Pin Connectors for Front to Rear Wiring Harness (For 5045D and 5055D Tractors)
XA1 - 9-Pin Connector for Controller
XB1 - 2-Pin Connector for Air Restriction Sensor
XB2 I- 1-Pin Connector for Fuel Level Sender
XB2 II1-Pin Connector for Fuel Level Sender
XB3 - 1-Pin Connector for Engine Oil Pressure Switch
XB4 - 1-Pin Connector for Coolant Temperature Sensor
XB5 - 2-Pin Connector for Engine Speed Magnetic Pickup
XB6 I - 1-Pin Connector for Horn
XB6 II - 1-Pin Connector for Horn
XB7 - 2-Pin Connector for Horn Timer
XE1 - 3-Pin Connector for Left Head Light
XE3 - 3-Pin Connector for Right Head Light
XE5 I - 1-Pin Connector for Rear Flood Light
XE5 II - 1-Pin Connector for Rear Flood Light
XE8 I - 1-Pin Connector for Left Warn Light
XE8 II - 1-Pin Connector for Left Warn Light
XE9 I - 1-Pin Connector for Left Tail Turn Light
XE9 II - 1-Pin Connector for Left Tail Turn Light
XE9 III - 1-Pin Connector for Left Tail Turn Light
XE10 I - 1-Pin Connector for Right Tail Turn Light
XE10 II - 1-Pin Connector for Right Tail Turn Light
XE10 III - 1-Pin Connector for Right Tail Turn Light
XE11 I - 1-Pin Connector for Right Warn Light
XE11 II - 1-Pin Connector for Right Warn Light
XF00 - 1-Pin Connector for Junction Box
XF1 - 60-Pin Connector for Fuse Box
XG2 I - 2-Pin Connector for Alternator
XG2 II - 1-Pin Connector for Alternator
XH1 I - 1-Pin Connector for Reverse Alarm Kit
XH1 II - 1-Pin Connector for Reverse Alarm Kit
XK7 - 9-Pin Connector for Flasher Relay
XK8 - 9-Pin Connector for Latch Relay
XK9 - 9-Pin Connector for OTP Accessory Relay
XK10 - 9-Pin Connector for Flood Lamp Relay
XK11 I - 1-Pin Connector for Manifold Heater Relay
XK11 II - 1-Pin Connector for Manifold Heater Relay
XK12 I - 2-Pin Connector for Start Relay
XK12 II - 1-Pin Connector for Start Relay
XK12 III - 1-Pin Connector for Start Relay
XK13 - 6-Pin Connector for Hella Flasher
XK14 - 9-Pin Connector MARCUREX Flasher
XM1 I - 1-Pin Connector for Starter Motor Sol.
XM1 II - 1-Pin Connector for Starter Motor Sol.
XS1 - 8-Pin Connector for Key Switch
XS2 - 6-Pin Connector for Rear PTO Switch
XS3 - 2-Pin Connector for Seat Switch
XS4 - 2-Pin Connector for Neutral Start Switch
XS5 - 3-Pin Connector for Turn Signal Switch
XS6 - 1-Pin Connectors for Light Switch
XS7 I - 1-Pin Connector for Horn Switch
XS7 II - 1-Pin Connector for Horn Switch
XV2 - 9-Pin Connector for Diode Module - 2
XV3 - 9-Pin Connector for Diode Module - 1
XY1 - 1-Pin Connector for Fuel Shut-off Solenoid
Section 250 - POWER TRAIN OPERATION, TESTS AND ADJUSTMENTS
Group 05 - Component Location—Transmission
Power Train Components (′S′ Transmission)
Power Train Components - For 5045E, 5055E, 5065E and 5075E Tractors
Power Train Components (′AA′ Transmission)
Power Train Components - For 5045D and 5055D Tractors
Clutch Components—Dual
CollarShift Transmission Components (′S′ Transmission)
SyncShuttle™ Transmission Components (For Australia Tractors)
SyncShuttle™ Transmission Components (For USA Tractors)
Partial SyncShuttle™ Transmission Components
Collarshift Transmission Components (′AA′ Transmission)
′AA′ Transmission Components (5045D and 5055D Tractors)
Park Brake Components (If Equipped)
Final Drive Components (′S′ Transmission)
Final Drive Components (′AA′ Transmission)
Rear PTO Components
Group 10 - Theory of Operation—Transmission
Clutch Operation—Dual Clutch
′S′ Transmission Lubrication System
′AA′ Transmission Lubrication System
CollarShift ′S′ Transmission - Gear Shift Power Flow
CollarShift ′S′ Transmission - Range Shift Power Flow
Collarshift ′AA′ Transmission - Gear Shift Power Flow
′AA′ Transmission - Gear Shift Power Flow (5045D and 5055D Tractors)
Collarshift ′AA′ Transmission - Range Shift and Reverse Drive Power Flow
′AA′ Transmission - Range Shift and Reverse Drive Power Flow (5045D and 5055D Tractors)
SyncShuttle™ Transmission - Gear Shift Power Flow ( For Australia )
SyncShuttle™ Transmission - Gear Shift Power Flow ( For USA )
Partial SyncShuttle™ Transmission - Gear Shift Power Flow ( For USA )
SyncShuttle™ Transmission - Range Shift Power Flow ( For Australia )
SyncShuttle™ Transmission - Range Shift Power Flow ( For USA )
SyncShuttle™ Transmission Synchronizer Operation - Reverse and 2nd Gear (Disk-and-Plate Type Synchronizer)
SyncShuttle™ Transmission Synchronizer Operation - 1st and 3rd Gear (Pin Type Cone Synchronizer)
SyncShuttle™ Transmission Synchronizer Operation - 1st and 3rd Gear (Strut-Type Cone Synchronizer)
Mechanical Front Wheel Drive (MFWD) Operation (If Equipped)
Rear PTO Operation
Differential Power Flow (′S′ Transmission)
Differential Power Flow (′AA′ Transmission)
Differential Lock Operation (′S′ Transmission)
Differential Lock Operation (′AA′ Transmission)
Final Drive Operation (′S′ Transmission)
Final Drive Operation (′AA′ Transmission)
Group 15 - Diagnosis, Tests, and Adjustments-Transmission
Isolate the Problem Area
Traction Clutch Slips
Traction Clutch Dragging
Traction Clutch Does Not Engage
Traction Clutch Grabs
Traction Clutch Squeaks
Traction Clutch Does Not Release
Traction Clutch Chatters
Traction Clutch Rattles
Traction Clutch Engagement Is Noisy
Excessive Vibration in Traction Clutch
Clutch Pedal Does Not Return
Clutch Pedal Loose
Clutch Pedal Pulsates
Jerky or Rough Transmission of Power
Low Transmission Oil Level (Excessive Oil Leakage)
Gears Clash, Shift Hard, or Will Not Engage
Two Speeds Engage Together
Transmission Will Not Stay in Gear
Transmission Noisy
PTO Noisy
PTO Hard to Engage
PTO Will Not Operate
PTO Will Not Stay Engaged
Excessive Differential Noise
Differential Does Not Work
No Differential Lock
Differential Chatters
Axle Noise
Axle Shaft Will Not Turn
Check and Adjust Clutch Pedal Free Play (′S′ Transmission)
Clutch Pedal Free Play Adjustment (′AA′ Transmission)
Adjust PTO Clutch Operating Rod
Adjust PTO Clutch Operating Cable
Section 260 - STEERING AND BRAKE OPERATION, TEST & ADJUSTMENTS
Steering System Components
Hydraulic Brake System Components
Mechanical Brake System Components
Steering System Operation
Steering Valve Operation—Park Position and Manual Turning
Steering Valve Operation—Power Turning
Hydraulic Brake System Operation
Brake Valve Operation
Mechanical Brake System Operation
Isolate the Problem—Steering System
Steering Sluggish or Loss of Steering
Isolate the Problem—Brakes
Excessive Brake Pedal Leak-Down
Excessive Brake Chatter
Steering Pump Flow Test
Steering Valve Relief Test
Steering Cylinder Leakage Test
Steering Valve Leakage Test
Checking Toe-In (Two Wheel Drive Tractor)
Checking Toe - In (MFWD Tractor)
Adjusting Toe-In (Two-Wheel Drive Tractor)
Adjusting Toe-In (MFWD Tractor)
Brake Pedal Adjustment (′S′ Transmission)
Bleed Brake System
Brake Pedal Adjustment (′AA′ Transmission)
Section 270 - HYDRAULIC SYSTEM OPERATION, TEST AND ADJUSTMENTS
Hydraulic System Components
Hydraulic System Operation
Hydraulic Filter Operation
Hydraulic Pump Operation
MITA Selective Control Valve—Neutral Position
MITA Selective Control Valve—Retract Position
MITA Selective Control Valve—Extend Position
MITA Selective Control Valve—Float Position
EATON Selective Control Valve—Neutral Position
EATON Selective Control Valve—Retract Position
EATON Selective Control Valve—Extend Position
EATON Selective Control Valve—Float Position
MITA Rockshaft Control Valve Operation—Park Position
MITA Rockshaft Control Valve Operation—Raise Position
MITA Rockshaft Control Valve Operation—Lower Position
MITA Rockshaft Draft - Sensing Operation
MITA Surge (Safety) Relief Valve Operation
MITA Rate-of-Drop Valve (Implement Lock) Operation
JD Rockshaft Control Valve Operation—Neutral Phase
JD Rockshaft Control Valve Operation—Delivery Phase
JD Rockshaft Control Valve Operation—Discharge Phase
JD Rockshaft Rate-of-Drop Valve (Implement Lock) Operation
JD Rockshaft Draft-Sensing Operation
JD Rockshaft Surge Relief Valve Operation
JD Rockshaft Main Relief Valve Operation
Functioning of Position Control
Functioning of Draft Control
Combined Functioning of Position and Draft Control
Preliminary Hydraulic System Inspection
Entire Hydraulic System Fails to Function/No Hydraulic Pump Output
Insufficient Pump Delivery
Hydraulic Functions Too Slow
Excessive Pump Pressure
Slow Hydraulic Pump Response
Excessive Pump Noise During Operation
Rockshaft Does Not Lift or Lifts Slowly
Rockshaft Does Not Lower or Lowers Slowly
Park Position Unstable, Rockshaft Drops after Engine Shut Down
Group 20 - Hydraulic Tests - Without SCV
Hydraulic System Tests
Pump Flow Test
MITA Rockshaft Main Relief Valve Test
JD Rockshaft Main Relief Valve Test
Group 25 - Hydraulic Tests—With SCV
Hydraulic System Tests—With SCV
Pump Flow Test—With SCV
Main Relief Valve Test—With SCV
SCV Leakage Test
Group 18 - Hydraulic Tests—With Mid Mount Control Valve
Hydraulic System Tests—With Mid Mount Control Valve
Pump Flow Test—With Mid Mount Control Valve
Main Relief Valve Test—With Mid Mount Control Valve
Mid Mount Control Valve Leakage Test
Group 30 - Hydraulic Tests - All
MITA Rockshaft Leakage Test
JD Rockshaft Leakage Test
Rockshaft Lift Cycle Test
Group 40 - Adjustments
Rockshaft Sensing Lever Friction Adjustment - MITA Rockshaft
Control of Assembly of Reaction Spring- MITA Rockshaft
Measurement Control of Push rod- MITA Rockshaft
Adjustment of Position Control Lever- MITA Rockshaft
Adjustment Of Draft Control Lever- MITA Rockshaft
Rockshaft Lever Friction Adjustment- JD Rockshaft
Rockshaft Position-Sensing Feedback Linkage Adjustment- JD Rockshaft
Rockshaft Draft-Sensing Feedback Linkage Adjustment- JD Rockshaft
Mid Mount Control Valve Joystick Cable Adjustment
Group 45 - Hydraulic Schematics
Hydraulic Circuit Symbols
Hydraulic System—Standard Tractor with First and Second Rear SCV
Brand: John Deere
Serial Number: 2013
FOREWORD
Group 05 - Safety
Prevent Acid Burns
Park Machine Safely
Work in Clean Area
Use Proper Tools
Live With Safety
Diesel Fuel
Biodiesel Fuel
Fuel Storage
Fill Fuel Tank
Diesel Engine Oil
Grease
Lubricant Storage
Serial Numbers
Standard Features
Group 05 - Engine
Specifications
Remove Engine
Install Engine
Specifications
Check Valve Lift
Clean Valve Guides
Knurl Valve Guides
Lapping Valve Seats
Check Valve Recess
Check Valves
Grind Valves
Install Valves
Valve Clearance
Final Work
Specifications
Exploded View
Measure Piston Pin
Specifications
Flywheel Removal
Install Flywheel
Remove Crankshaft
Regrind Crankshaft
Specifications
Remove Camshaft
Install Camshaft
Check Cam Follower
Remove Front Plate
Remove Idler Shaft
Install Front Plate
Install Wear Ring
Specifications
Remove Oil Cooler
Install Oil Cooler
Remove Oil Pump
Install Oil Pan
Specifications
Remove Water Pump
Assemble Water Pump
Install Water Pump
Inspect Thermostat
Install Fan
Install Radiator
Replace Thermostat
Replace Fuel Filter
Other Material
Replace Key Switch
Service Parts Kits
Other Material
Specifications
Essential Tools
Other Material
Specifications
Specifications
Remove Transmission
Other Material
Specifications
Remove Transmission
Other Material
Specifications
Other Material
Specifications
Essential Tools
Other Material
Specifications
Service Parts Kits
Other Material
Specifications
Essential Tools
Other Material
Specifications
Other Material
Specifications
Service Parts Kits
Other Material
Specifications
Install Brakes
Other Material
Specifications
Install Brakes
Essential Tools
Specifications
Service Parts Kits
Other Material
Specifications
Other Material
Specifications
Service Parts Kit
Other Material
Specifications
Specifications
Group 10 - Wheels
Specifications
Specifications
Group 25 - Hood
Specifications
Specifications
Group 20 - Fenders
Specifications
Fan and Belt Check
Fuel System Check
Engine Start Check
Clutch Check
Brake Check
Rockshaft Check
Specifications
Essential Tools
Engine Runs Rough
Cooling System Test
Relays
Relays
Horn Operation
Wire Color Chart
Charge Battery
Battery Load Test
Starter Relay Test
Key Switch Test
Plug-In Relay Test
Mini Plug-In Relay
Diode Pack Test
Fuse Test
PTO Switch Test
Light Switch Test
Wire Color Chart
Charge Battery
Battery Load Test
Starter Relay Test
Key Switch Test
Plug-In Relay Test
Mini Plug-In Relay
Diode Pack Test
Fuse Test
PTO Switch Test
Light Switch Test
Horn Test Points
Charge Battery
Battery Load Test
Starter Relay Test
Plug-In Relay Test
Diode Pack Test
Fuse Test
Electrical Circuits
Rear PTO Components
Rear PTO Operation
Clutch Pedal Loose
Transmission Noisy
PTO Noisy
PTO Hard to Engage
Axle Noise
Bleed Brake System
Pump Flow Test
SCV Leakage Test
- JOHN DEERE CODE DTC LIST
