Martin Welker
104
230,310
John Deere 5220 5320 5420 5520 Tractors Operators Manual OMRE199128
Format: HTML
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 5220 5320 5420 5520 Tractors
Parts Number: OMRE199128
Foreword
Identification Views
Section : 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prevent Machine Runaway
Use Seat Belt and Foldable ROPS Properly-Straddle Mount and IOOS
Operate Tractor Safely
Use Caution on Hillsides
Shift to Low Gear on Hills
Avoid Tipping
Freeing a Mired Machine
Work In Ventilated Area
Park Tractor Safely
Keep Riders Off Machine
Handle Fuel Safely-Avoid Fires
Prepare for Emergencies
Do Not Use Starting Fluid
Wear Protective Clothing
Protect Against Noise
Avoid Contact with Pesticides
Stay Clear of Rotating Drivelines
Use Safety Lights and Devices
Use a Safety Chain
Safely Transporting the Tractor
Tow Loads Safely
Keep ROPS Installed Properly
Practice Safe Maintenance
Service Tractor Safely
Support Machine Properly
Avoid High-Pressure Fluids
Service Cooling System Safely
Store Attachments Safely
Prevent Acid Burns
Service Tires Safely
Dispose of Waste Properly
Section : 10 - Safety Signs
Warning Labels
Section : 15 - Controls and Instruments
Tractor Controls (Straddle Mount and Hi-Crop)
Tractor Controls (Isolated Open Operator Station and Cab)
Instrument (Dash) Panel-Early Model Tractor
Instrument (Dash) Panel-Late Model Tractor
Overhead Control Panel (Cab)
Section : 20 - Lights
Light Switch Positions
Using Headlights
High Beam Indicator
Using Tail Lights
Using Fender Lights (Isolated Open Operator Station, 5520 Straddle Mount and Hi-Crop)
Using Rear Flood Light (Straddle Mount, Isolated Open Operator Station and Hi-Crop)
Adjusting Rear Flood Light (Straddle Mount, Isolated Open Operator Station and Hi-Crop)
Using Flood Lights (Cab)
Using Warning Lights
Using Turn Signals (Straddle Mount and Hi-Crop)
Using Turn Signals (Isolated Open Operator Station and Cab)
Seven-Terminal Outlet
Section : 25 - Hi-Crop and Straddle Mount Operator Station
Operating Foldable ROPS
Using Seat Belt
Adjusting Seat
Adjusting Steering Wheel Tilt-If Equipped
Section : 30 - Cab and Isolated Open Operator Station
Using Seat Belt
Adjusting Seat-Air Suspension Seat (Cab) (Optional)
Adjusting Seat (Deluxe Adjustable Seat)-Early Model Tractor
Adjusting Seat-Mechanical Suspension Seat-Later Model Tractor
Adjusting Seat Arm Rest-Air and Mechanical Suspension Seat
Adjusting Blower Speed (Cab)
Controlling Temperature (Cab)
Optimizing A/C and Heater Performance
Operating Wiper(s) (Cab)
Accessory Electrical Outlet
Operating the Radio (Cab-If Equipped)
Operating the Radio with Optional Cassette Tape Player (Cab-If Equipped)
Operating the Radio with Optional Compact Disc Player (Cab-If Equipped)
Operating the Optional Cassette Tape Player (Cab-If Equipped)
Operating the Optional Compact Disc Player (Cab-If Equipped)
Setting the Clock (Cab-If Equipped)
Using Dome Light (Cab)
Section : 35 - Break-In Period
Observe Engine Operation Closely
Break-In Service
Section : 40 - Prestarting Checks
Service Daily Before Start-Up
Section : 45 - Operating the Engine
Before Starting the Engine
Starting the Engine
Check Instruments After Starting
Oil Pressure Indicator
Charging System Indicator
Air Restriction Indicator
Coolant Temperature Gauge
Watch Fuel Level
Changing Engine Speeds (Straddle Mount and Hi-Crop)
Changing Engine Speeds (Cab and Isolated Open Operator Station)
Warming Up the Engine
Restart Stalled Engine
Avoid Idling the Engine
Observe Engine Work and Idle Speeds
Working with Speed/Hour Meter
Stopping the Engine
Using Booster Battery
Section : 50 - Driving the Tractor
Operator Training Required
Driving on Public Roads
Operating CollarShift or SyncShuttle™ Transmissions
Shifting CollarShift Transmission
Shifting SyncShuttle™ Transmission
Operating PowrReverser™ Transmission
Shifting PowrReverser™ Transmission
Selecting a Gear
Creeper Gear Operation (If Equipped)
Using Brakes
Using Differential Lock
Operating Mechanical Front Wheel Drive (If Equipped)
Stopping Tractor with CollarShift or SyncShuttle™ Transmission
Stopping Tractor with PowrReverser™ Transmission
Section : 55 - Rockshaft and 3-Point Hitch
Match Tractor Power to Implement
3-Point Hitch Components
Rockshaft Control Levers
Using Rockshaft Position Control
Setting Position Control Lever Stop
Using Draft Control
Adjusting Rockshaft Rate-of-Drop
Preparing Implement
Converting Category II Hitch to Category I
Positioning Center Link
Attaching Implements to 3-Point Hitch
Adjusting Hitch Side Sway
Leveling the Hitch
Adjusting Lateral Float
Adjusting Rockshaft Control Lever Friction
Warming Hydraulic System Oil
Section : 60 - Remote Hydraulic Cylinders
Use Correct Hose Tips
SCV Control Lever and Coupler Identification (If Equipped)
Installing Remote Outlet Oil Manifolds (Optional)
Connecting Cylinder Hoses
Connecting Hose Under Pressure
Connecting Single-Acting Cylinder
Correcting Reversed Cylinder Response
Operating SCV Controls
Adjusting Cylinder Stop
Neutral Lever Position
Loader Joystick Functions
Disconnecting Cylinder Hoses
Section : 65 - Drawbar and PTO
Observe Drawbar Load Limitations
Selecting Drawbar Position
Adjusting Drawbar Length
Attaching PTO-Driven Implement
Selecting Correct PTO Speeds (SyncShuttle™ Transmission Only)-If Equipped
Operating Tractor PTO
Adjust PTO Clutch Operating Rod (Straddle Mount and Hi-Crop)
Adjust PTO Clutch Operating Linkage (Cab and Isolated Open Operator Station)
Section : 70 - Ballast
Planning for Maximum Productivity
Selecting Ballast Carefully
Matching Ballast to Work Load
Checking for Correct Ballast
Measuring Wheel Slip-Manually
Ballast Limitations
Ballasting Front End for Transport
Ballasting Two-Wheel Drive Tractors
Ballasting MFWD-Equipped Tractors
Determining Maximum Rear Ballast
Determining Maximum Front Ballast
Using Cast Iron Weights
Installing Rear Cast Iron Weights
Using Liquid Weight
Using Implement Codes
Section : 75 - Wheels, Tires and Treads
Check Implement-to-Tire Clearance
Check Tire Inflation Pressure
Tire Inflation Pressure Chart-Early Model Tractor
Tire Inflation Pressure Chart-Late Model Tractor
Selecting Front Tire Rolling Direction
Tighten Wheel/Axle Hardware Correctly
Tighten Bolts-Adjustable Front Axle
Tighten Bolts-MFWD Axle
Tighten Bolts-Rear Axle
Observe Rear Wheel Tread Width Limitations
Tread Settings-Two-Position Rear Wheels-Early Model Tractor
Tread Settings-Two-Position Rear Wheels-Late Model Tractor
Tread Settings-Multi-Position Rear Wheels-Early Model Tractor
Tread Settings-Multi-Position Rear Wheels-Late Model Tractor
Tread Settings-Multi-Position MFWD Wheels-Early Model Tractor
Tread Settings-Multi-Position MFWD Wheels-Late Model Tractor
Tread Settings-Adjustable Front Axle-Early Model Tractor
Tread Settings-Adjustable Front Axle-Late Model Tractor
Adjust Front Axle Tread Width-Early Model Tractor
Adjust Front Axle Tread Width-Late Model Tractor
Checking Toe-In-Adjustable Front Axle
Adjusting Toe-In-Adjustable Front Axle-Early Model Tractor
Adjusting Toe-In-Adjustable Front Axle-Late Model Tractor
Checking Toe-In-MFWD
Adjusting Toe-In-MFWD
Set MFWD Steering Stops Turning Radius
Use Correct Tire Combinations
Tire Compatibility Chart-5220 and 5320-Early Model Tractor
Tire Compatibility Chart-5420 and 5520-Early Model Tractor
Tire Compatibility Chart-Late Model Tractor
Section : 80 - Transporting
Use a Safety Chain
Driving Tractor on Roads
Transport on Carrier
Towing Tractor
Section : 85 - Fuels, Lubricants, and Coolant
Handle Fluids Safely-Avoid Fires
Fuel Storage
Cold Weather Operation
Diesel Fuel
Fill Fuel Tank
Lubricant Storage
Diesel Engine Oil
Diesel Engine Coolant
Oil Filters
Liquid Coolant Conditioner
Anti-Chatter Transmission-Hydraulic Oil
Use Correct Hydraulic-Transmission Filter Element
Gear Oil
Grease
Section : 90 - Lubrication and Maintenance
Clean Vehicle of Hazardous Pesticides
Observe Service Intervals
Use Correct Lubricant
Break-In Service
Service Intervals
Section : 95 - Service-10 Hours
Check Engine Oil Level
Check Coolant Level
Drain Water and Sediment from Fuel Tank and Fuel Filter
Lubricate as Necessary
Section : 100 - Service-50 Hours
Check Transmission-Hydraulic System Oil Level
Check MFWD Axle Oil Level
Clean and Check Battery
Inspect All Tires
Lubricate Front Axle Pivot Pin(s)
Lubricate Steering Spindles (Adjustable Front Axle)
Lubricate Steering King Pins (MFWD)
Inspect Tractor for Loose Hardware
Section : 105 - Service-100 Hours
Change Engine Oil and Filter
Replace Transmission-Hydraulic Filter
Check and Adjust Clutch Pedal Free Play (CollarShift and SyncShuttle™)
Clutch Pedal Linkage Adjustment (PowrReverser™)
Section : 110 - Service-250 Hours
Service Air Cleaner
Inspect and Adjust Alternator/Fan Belt (5220 and 5320)
Inspect and Adjust A/C Compressor Belt -Cab (5220 and 5320)
Inspect and Adjust Alternator/Fan Belt (5420 and 5520)
Lubricate 3-Point Hitch
Check Neutral Start System
Clean Cab Air Filters
Section : 115 - Service-500 Hours
Replace Fuel Filter
Section : 120 - Service-600 Hours
Change Oil in MFWD Axle-If Equipped
Clean Engine Crankcase Vent Tube
Pack Front Wheel Bearings-Adjustable Front Axle
Check Hoses and Hose Clamps for Tightness
Lubricate Rear Axle Bearings
Check Engine Idle Speeds
Check Front Axle Pivot Pin
Adjust Engine Valve Clearance
Section : 125 - Service-1200 Hours
Change Transmission-Hydraulic Oil and Filter
Clean Transmission-Hydraulic Pickup Screen
Section : 130 - Service-Annually
Replace Air Cleaner Elements
Inspecting Seat Belt
Section : 135 - Service-2 Years/2000 Hours
Flush Cooling System
Section : 140 - Service-As Required
Service Air Cleaner
Adjust Hand Throttle Friction (Straddle Mount and Hi-Crop)
Adjust Hand Throttle Friction (Isolated Open Operator Station and Cab)
Adjust 540E PTO Throttle Limiter (Straddle Mount and Hi-Crop)
Adjust 540E PTO Throttle Limiter (Isolated Open Operator Station and Cab)
Section : 145 - Service
Engine Break-In Oil
Using High-Pressure Washers
Additional Service Information
Opening Hood
Removing Hood
Removing Side Screens
Air Intake System Components
Service Air Cleaner at Regular Intervals
Checking Air Intake System
Removing Air Cleaner Elements
Inspecting Element
Cleaning Primary Element
Washing Primary Element
Storing Element
Replacing Alternator/Fan Belt (5220 and 5320)
Replacing Fan/Alternator/AC Compressor Belt (5420 and 5520)
Replacing A/C Compressor Belt (5220 and 5320-Cab)
Fuel System Components
Bleeding Fuel System
Do Not Modify Fuel System
Engine Cooling System Components
Cleaning Grille, Screens, Radiator and Oil Cooler
Winterize Cooling System
Prevent Battery Explosions
Observe Electrical Service Precautions
Battery Access-Straddle Mount and Hi-Crop
Battery Access-Cab Machines
Removing Battery
Servicing Battery
Battery Replacement Specifications
Charging Battery
Checking Battery Condition
Connecting Starter Wiring
Connecting Alternator Wiring
Servicing Air Conditioner (Cab)
Locating Fusible Link
Locating Fuses
Fuse Size and Function-Early Model Tractor
Fuse Size and Function-Late Model Tractor
Aiming Headlights
Adjusting Headlights
Replace Headlight Bulb-Early Model Tractor
Replace Headlight Bulb-Late Model Tractor
Replace Warning Light Bulb (Straddle Mount, Hi-Crop and Isolated Open Operator Station)
Replace Warning Light Bulb (Cab)
Replace Tail Light Bulb (Cab and Isolated Open Operator Station)
Replace Tail Light Bulb (Straddle Mount and Hi-Crop)
Replace Flood Light Bulb-Early Model Tractor (Straddle Mount, Hi-Crop and Isolated Open Operator Station)
Replace Flood Light Bulb-Late Model Tractor (Straddle Mount, Hi-Crop and Isolated Open Operator Station)
Replace Flood Light Bulb (Cab)
Replace Fender Light Bulb-Early Model Tractor (Isolated Open Operator Station)
Replace Fender Light Bulb-Late Model Tractor (Isolated Open Operator Station)
Replace Dome Light Bulb (Cab)
Checking Tires
Tubeless Tire Repair
Keep ROPS Installed Properly (Straddle Mount, Hi-Crop and Isolated Open Operator Station)
Keep Cab Protection System Installed Properly
Section : 150 - Troubleshooting
Engine Troubleshooting
Transmission Troubleshooting
Hydraulic System Troubleshooting
Brakes Troubleshooting
Rockshaft and Quick-Coupler 3-Point Hitch Troubleshooting
Remote Hydraulic Cylinders Troubleshooting
Electrical System Troubleshooting
Heater and A/C System Troubleshooting (Cab)
Wipers, Flood Lights, Dome Light and Radio Troubleshooting (Cab)
Section : 155 - Storage
Storing Tractor
Removing Tractor From Storage
Section : 160 - Specifications
Machine Specifications
Drain and Refill Capacities
Machine Dimensions-Straddle Mount
Machine Dimensions-Isolated Open Operator Station
Machine Dimensions (Cab)
Machine Dimensions (Hi-Crop)
Permissible Load Specifications
CollarShift and SyncShuttle™ Transmission Ground Speed Estimates
CollarShift and SyncShuttle™ Creeper Transmission Ground Speed Estimates
PowrReverser™ Transmission Ground Speed Estimates
PowrReverser™ Creeper Transmission Ground Speed Estimates
Correction Factors for Other Tire Sizes
Metric Bolt and Cap Screw Torque Values
Unified Inch Bolt and Cap Screw Torque Values
Emissions Control System Certification Label
U.S. Emissions Control Warranty Statement (United States Only)
Limited Battery Warranty
Section : 165 - Identification Numbers
Identification Plates
Record Tractor Serial Number
Record Front Axle (2-WD) Serial Number
Record Mechanical Front Wheel Drive (MFWD) Serial Number
Record Engine Serial Number
Record Transmission Serial Number
Section : 170 - Lubrication and Maintenance Record Charts
50, 250, 500 Hour Service Chart
600 Hour Service Chart
1200 Hour Service Chart
Annual Service Chart
2000 Hour Service Chart
As Required Service Chart
Section : 175 - Crime Prevention Tips
Help Prevent Crime
Record Ag Identification Numbers
Keep Proof of Ownership
Park Indoors Out of Sight
When Parking Outdoors
Reduce Vandalism
Report Thefts Immediately
Section : SLIT - John Deere Service Literature Available
Parts Catalog
Operator's Manual
Fundamentals of Service Manuals
Technical and Service Manuals
Know-How Booklets
Common Questions Booklet
Section : IBC - John Deere Service Keeps You on the Job
John Deere Quality
