John Deere 520 530 Series Tractors Parts Catalog PC0527
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 520 530 Series Tractors
Part Number: PC0527
Number of Pages: 254 Pages
ALPHABETICAL INDEX
A
Air Cleaner
Air Stack
Arms, Rockshaft Lift
Axle, Front, Double Front Wheel Spindle Extensions
Axle, Front, Double Front Wheel Hubs
Axle, Front, Housing (38-Inch Fixed Tread)
Axle, Front, Housing (48- to 80-Inch Tread)
Axle, Front, Knee (38-Inch Fixed Tread)
Axle, Front, Knee (48- to 80-Inch Tread)
Axle, Front, Roll-O-Matic
Axle, Front, Single Front Wheel
Axle, Rear, Housing
Axle, Rear, Housing Cover (Tractors Less Powershaft and Rockshaft)
Axle, Rear, Shaft
B
Battery Box
Battery Cables
Bearings, Main
Bearings, Main and Crankshaft Gasket Set
Bearings, Main and Oil Pipes
Belt Pulley
Belt Pulley Brake
Belt Pulley Dust Shield
Block, Cylinder
Box, Tool
Brakes
Breakaway Coupler
Bulk Flexible Oil Lines
Button, Cranking Motor (520)
C
Cable, Spark Plug, and Lead Wire Kit
Cable, Speed-Hour Meter
Cam Followers
Camshaft
Cap, Radiator
Carburetor
Carburetor Air Intake
Case, Engine and Transmission
Choke Rod
Cigarette Lighter
Clamp, Hose, Worm-Driven
Cleaner, Air
Clutch, Adjusting Disk
Clutch and Pulley
Cluth and Pulley Brake
Clutch, Collar
Clutch, Disk, Sliding and Fixed
Clutch, Drive Disk
Clutch, Facings
Clutch, Forks
Clutch, Lever and Linkage
Clutch, Powershaft
Clutch, Powershaft, Cover
Clutch, Powershaft, Linkage
Clutch, Powershaft, Pedal
Coil, Ignition
Connecting Rods
Control, Hitch Load
Control, Starting Motor
Countershaft, Transmission
Coupler, Breakaway
Cover, Crankcase
Cover, First Reduction Gear
Cover, Flywheel
Cover, Fourth and Sixth Speed Gear
Cover, Powershaft Clutch
Cover, Rear Axle Housing (Tractors Less Rockshaft and Powershaft)
Cover, Transmission Case
Convertor, Fuel (LP-gas)
Crankshaft and Bearing Gasket Set
Cranking Motor
Cranking Motor Starter Button and Rod
Cylinder and Piston Ring Gasket Set
Cylinder, Block
Cylinder, Head
Cylinder, Remote, Single or Dual
Cylinder, Water Inlet Housing
Cylinder, Water Outlet Housing
Dash Pot
Dash Lamps
Decalcomania Sets
Disk, Clutch Adjusting, Sliding and Fixed
Disk, Clutch Drive
Distributor (Delco-Remy)
Distributor (Wico)
Double Front Wheels
Draft Link
Draft Link Support
Drawbar
E
Electrical Outlet Plug
Element, Oil Filter
Engine Case and Covers
Engine Replacement Assemblies
Exhaust Pipe
Exhaust Trail Pipe, Rear
F
Fan (Manual Steering)
Fan (Poser Steering)
Fan Drive (Power Steering)
Fan Pump (Power Steering)
Fan Shaft (Manual Steering)
Fan Shaft (Power Steering)
Fan Shaft Support (Manual Steering)
Fan Shaft Support (Power Steering)
Fan Shroud
Fenders
Filter, Fuel (All-Fuel)
Filter, Fuel (Gasoline)
Filter, Oil
Final Drive
First Reduction Gear Cover
Flasher, Warning Lamp
Float-Ride Seat
Flywheel
Flywheel Cover
Frame
Frame Weight
Front Axle, Housing (38-Inch Fixed Tread)
Front Axle, Housing (48- to 80-Inch Tread)
Front Axle, Knee (38-Inch Fixed Tread)
Front Axle, Knee (48- to 80-Inch Tread)
Front End Support
Front End Weights
Front Mounted Rockshaft
Front Wheel, Single
Front Wheel, Double
Fuel Convertor (LP-Gas)
Fuel Convertor Parts (LP-Gas)
Fuel Convertor Water Pipes
Fuel Convertor Fuel Pipes
Fuel Filter (All-Fuel)
Fuel Filter (Gasoline)
Fuel Gauge
Fuel Gauge Sender
Fuel Strainer (LP-Gas)
Fuel Strainer Parts (LP-Gas)
Fuel Strainer Fuel Pipes
Fuel Tank and Valves (LP-Gas)
Fuel Tank (All-Fuel)
Fuel Tank (Gasoline)
G
Gasket Sets, Crankshaft and Bearing
Gasket Sets, Governor Overhaul
Gasket Sets, Intake and Exhaust Valves
Gasket Sets, Piston Ring and Cylinder
Gasket Sets, Transmission and Rear End Overhaul
Gauge, Ammeter
Gauge, Fuel
Gauge, Heat Indicator
Gauge, Oil Pressure
Gear, Camshaft
Gear, Countershaft Idler, Transmission
Gear, Cover, First Reduction
Gear, Differential
Gear, Final Drive
Gear, Governor Drive
Gear, Powershaft Clutch
Gear, Powershaft Drive
Gear, Powershaft Idler
Gear, Pulley
Gear, Steering
Gear, Transmission Drive and Frist Reduction
Gearshift
Gearshift Forks
Generator and Mounting Bracket
Generator, Ignition and Starting Motor
Generator, Parts
Governor
Grille
Heat Indicator
Heat Shield, Fuel Tank
Hitch, Dash Pot
Hitch, Draft Links
Hitch, Draft Link Support
Hitch, Drawbar
Hitch, Lift Links
Hitch, Load Control
Hitch, Upper Links
Hood
Hose, Clamp, Worm-Driven
Hose, Remote Cylinder
Housing, Dual Remote Cylinder Vavle
Housing, Rear Axle Shaft
Housing, Rockshaft and Powershaft
Housing, Rockshaft Valve
Housing, Single Remote Cylinder Valve
Hubs, Double Front Wheels
I
ID VIEW
Ignition and Starter Wiring
Implement Warning Lamp
Instrument Panel and Gauges
Instrument Panel Wiring
K
Kit, Carburetor Choke
Kit, Carburetor Gasket
Kit, Carburetor Service
Kit, Front Fan Bearing
Kit, Fuel Convertor
Kit, Powershaft Clutch Conversion Assembly
Kit, Power Steering Adjustable Helix Service
Kit, Seat Cushion
Kit, Spark Plug Cable and Lead Wire
Kit, Remote Cylinder Overhaul
Kit, Wire Replacement
Knee, Front Axle
L
Lamp and Wiring
Lamp, Combination Rear and Warning
Lamp, Dash
Lamp, Front and Rear (Parts)
Lamp, Warning
Lamp, Wiring (Tw0-Head)
Lamp, Wiring (Four-Head)
Lever, Clutch
Lever, Remote Cylinder, L.H.
Lever, Remote Clylinder, R.H.
Lever, Rockshaft, L.H.
Lever, Rockshaft, R.H.
Lever, Throttle
Lever, Transmission Gear Shift
Lift Arm, Rockshaft
Lighter, Cigarette
Link, Draft
Link, Lift
Link, Support, Draft
Link, Upper
Linkage, Clutch
Linkage, Powershaft Clutch
Linkage, Remote Cylinder, L.H.
Linkage, Remote, Cylinder, R.H.
Linkage, Rockshaft Control
Linkage, Rockshaft, L.H.
Linkage, Rockshaft, R.H.
Load Control
M
Main Bearings
Main Bearings and Oil Pipes
Manifold
Meter, Speed-Hour
Mirror, Rear View
Motor, Cranking
Muffler
Muffler, Rear Echaust
O
Oil Filter
Oil Filter Oil Pipes
Oil Pipes - See Pipes, Oil
Oil Pressure Gauge
Oil Power Steering
Oil Pump
Oil Pump, Drive Gear
Oil Pump, Oil Pipes
P
Pedal, Brake
Pedal, Powershaft Clutch
Pedestal (Manual Steering)
Pedestal (Power Steering)
Pipe, Exhaust
Pipe, Exhuast Tail, Rear
Pipe, Fuel Convertor Water
Pipe, Fuel Strainer
Pipe, Ventilator Inlet
Pipe, Ventilator Outlet
Pipes, Oil, Cam Follower
Pipes, Oil, Camshaft
Pipes, Oil, Governor
Pipes, Oil, Main Bearings
Pipes, Oil, Oil Pressure Gauge
Pipes, Oil Pressure Relief
Pipes, Oil, Oil Pump
Pipes, Oil, Power Steering
Pipes, Oil, Powr-trol
Pipes, Oil, Tappet Lever
Piston Rings
Piston, Rockshaft
Pistons
Platform
Powershaft
Powershaft, Clutch Cover
Powershaft, Clutch Linkage
Powershaft, Clutch Pedal
Powershaft, Cover
Powershaft, Drive Gear
Powershaft, Housing
Powershaft, Master Shield
Powershaft, Valves
Pow-trol Oil Pipes
Powr-trol Pump
Pre-Cleaner
Pre-Screener
Pulley, Belt, Brake
Pulley, Belt, Dust Shield
Pulley, Generator
Pulley, Water Pump
Pump, Oil
Pump, Powershaft
Pump, Power Steering
Pump, Pow-trol
Pump, Ventilator
Pump, Water
R
Radiator, Lower Connections
Radiator, Upper Connections
Rear Axle Shaft
Rear View Mirror
Regulator, Voltage
Remote Cylinder
Remote Cylinder, Breakaway Coupler
Remote Cylinder, Dual Vavle Housing
Remote Cylinder, Hoses
Remote Cylinder, Levers, L.H.
Remote Cylinder, Levers, R.H.
Remote Cylinder, Linkage, L.H.
Remote Cylinder, Linkage, R.H
Remote Cylinder, Single Valve Housing
Replacement Assemblies, Engine
Reusable couplings
Rim, Demountable
Rings, Piston
Rings and Cylinder Gasket Set
Rockshaft
Rockshaft, Control Shaft
Rockshaft, Cover
Rockshaft, Front Mounted
Rockshaft, Housing
Rockshaft, Levers, L.H.
Rockshaft, Levers, R.H.
Rockshaft, Lift Arms
Rockshaft, Linkage, Control
Rockshaft, Linkage, L.H.
Rockshaft, Linkage, R.H.
Rockshaft, Load Control Shaft
Rockshaft, Piston
Rockshaft, Valve Housing
Rockshaft, Valves
Rod, Choke
Rod, Cranking Motor
Rods, Connecting
Rods, Tappet
Roll-O-Matic
S
Seat, Foat-Ride
Seat, Float-Ride Frame and Cushions
Seat, Regular
Shield, Master, Powershaft
Shifter Shafts, Transmission
Shoes, Brakes
Single Front Wheel
Sliding Gear Shaft
Socket, Electrical Outlet
Solenoid Switch (530)
Spark Plug Cable and Lead Wire Kit
Spark Plugs
Speed Control Lever
Speed-Hour Meter
Starter (Cranking Motor)
Starter Switch (530)
Steering, Oil Pipes, Power
Steering, Oil, Power
Steering, Pump, Power
Steering, Spindle (Manual)
Steering, Spindle (Power)
Steering, Spindle Extension
Steering, Valve, Power
Steering, Wheel
Steering, Wheel Shaft (520)
Steering, Wheel Shaft (530)
Steering, Wheel Shaft Support (520)
Steering, Wheel Shaft Support (530)
Steering, Wheel Shaft Support (LP-Gas) (520)
Steering, Wheel Shaft Support (LP-Gas) (530)
Steering, Worm and Housing (Manual)
Steering, Worm, Shaft, and Housing (Power)
Step, Tractor
Strainer, Fuel (LP-Gas)
Support, Draft Link
Support, Front End
Switch, Ignition
Switch, Solenoid (530)
Switch, Starter (530)
T
Tail Pipe, Rear Exhaust
Tank, Fuel and Valves (LP-Gas)
Tank, Fuel (All-Fuel)
Tank, Fuel (Gasoline)
Tappet Cover
Tappet Rods
Tappets
Thermostat
Throttle Lever and Linkage
Tool Box
Tools
Tractor Step
Transmission, Case and Cover
Transmission, Countershaft
Transmission, Cover, Gear Shift Case
Transmission, Cover, Fourth and Sixth Speed Gear
Transmission, Gear Shift Lever
Transmission, Gears and Shafts
Transmission, Oil Baffle
Transmission, Shift Forks, Gear
Transmission, Shifter Shafts
U
Upper Link
V
Valve, Housing, Dual Remote Cylinder
Valve, Housing, Rockshaft
Valve, Housing, Single Remote Cylinder
Valve, Power Steering
Valves, Fuel Tank (LP-Gas)
Valves, Gasket Set, Intake and Exhaust
Valves, Intake and Exhaust
Ventilator, Inlet Pipe
Ventilator, Outlet Pipe
Ventilator, Pump (Manual Steering)
Ventilator, Pump (Power Steering)
Voltage Regulator
W
Warning Lamp
Warning Lamp, Flasher
Warning Lamp, Flashing, for Towed Implement
Weathershield
Weight, Front end Support
Weights, Frame
Wiring, Ignition (520)
Wiring, Ignition and Starter (530)
Wiring, Instrument Panel
Wiring, Lamp (520)
Wiring, Lamp, Four-Head (530)
Wiring, Lamp, Two-Head (530)
Wheel, Front (Except Sinle Front Wheel)
Wheel, Single Front
Wheel, Steering
Wheels, Rear
Wheels, Rear, Power Adjusted
Worm-Driven Hose Clamps
Brand: John Deere
Part Number: PC0527
ALPHABETICAL INDEX
A
Air Cleaner
Air Stack
Axle, Rear, Housing
Axle, Rear, Shaft
B
Battery Box
Battery Cables
Bearings, Main
Belt Pulley
Belt Pulley Brake
Block, Cylinder
Box, Tool
Brakes
Breakaway Coupler
C
Cam Followers
Camshaft
Cap, Radiator
Carburetor
Choke Rod
Cigarette Lighter
Cleaner, Air
Clutch and Pulley
Clutch, Collar
Clutch, Drive Disk
Clutch, Facings
Clutch, Forks
Clutch, Powershaft
Coil, Ignition
Connecting Rods
Control, Hitch Load
Coupler, Breakaway
Cover, Crankcase
Cover, Flywheel
Cranking Motor
Cylinder, Block
Cylinder, Head
Dash Pot
Dash Lamps
Decalcomania Sets
Disk, Clutch Drive
Distributor (Wico)
Double Front Wheels
Draft Link
Draft Link Support
Drawbar
E
Element, Oil Filter
Exhaust Pipe
F
Fan Shroud
Fenders
Filter, Oil
Final Drive
Float-Ride Seat
Flywheel
Flywheel Cover
Frame
Frame Weight
Front End Support
Front End Weights
Front Wheel, Single
Front Wheel, Double
Fuel Gauge
Fuel Gauge Sender
G
Gauge, Ammeter
Gauge, Fuel
Gauge, Oil Pressure
Gear, Camshaft
Gear, Differential
Gear, Final Drive
Gear, Pulley
Gear, Steering
Gearshift
Gearshift Forks
Generator, Parts
Governor
Grille
Heat Indicator
Hitch, Dash Pot
Hitch, Draft Links
Hitch, Drawbar
Hitch, Lift Links
Hitch, Load Control
Hitch, Upper Links
Hood
I
ID VIEW
K
Kit, Fuel Convertor
Kit, Seat Cushion
Knee, Front Axle
L
Lamp and Wiring
Lamp, Dash
Lamp, Warning
Lever, Clutch
Lever, Throttle
Lift Arm, Rockshaft
Lighter, Cigarette
Link, Draft
Link, Lift
Link, Upper
Linkage, Clutch
Load Control
M
Main Bearings
Manifold
Meter, Speed-Hour
Mirror, Rear View
Motor, Cranking
Muffler
O
Oil Filter
Oil Pressure Gauge
Oil Power Steering
Oil Pump
Oil Pump, Oil Pipes
P
Pedal, Brake
Pipe, Exhaust
Pipe, Fuel Strainer
Piston Rings
Piston, Rockshaft
Pistons
Platform
Powershaft
Powershaft, Cover
Powershaft, Housing
Powershaft, Valves
Pow-trol Oil Pipes
Powr-trol Pump
Pre-Cleaner
Pre-Screener
Pulley, Belt, Brake
Pulley, Generator
Pulley, Water Pump
Pump, Oil
Pump, Powershaft
Pump, Pow-trol
Pump, Ventilator
Pump, Water
R
Rear Axle Shaft
Rear View Mirror
Regulator, Voltage
Remote Cylinder
Reusable couplings
Rim, Demountable
Rings, Piston
Rockshaft
Rockshaft, Cover
Rockshaft, Housing
Rockshaft, Piston
Rockshaft, Valves
Rod, Choke
Rod, Cranking Motor
Rods, Connecting
Rods, Tappet
Roll-O-Matic
S
Seat, Foat-Ride
Seat, Regular
Shoes, Brakes
Single Front Wheel
Sliding Gear Shaft
Spark Plugs
Speed Control Lever
Speed-Hour Meter
Steering, Wheel
Step, Tractor
Support, Draft Link
Support, Front End
Switch, Ignition
T
Tappet Cover
Tappet Rods
Tappets
Thermostat
Tool Box
Tools
Tractor Step
U
Upper Link
V
Voltage Regulator
W
Warning Lamp
Weathershield
Weights, Frame
Wiring, Lamp (520)
Wheel, Single Front
Wheel, Steering
Wheels, Rear
- JOHN DEERE CODE DTC LIST
