Martin Welker
104
230,310
John Deere 5090E 5100E Tractors Operators Manual OMSU59242
Download this document, you need 200 Gallons
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 5090E 5100E Tractors
Part Number: OMSU59242
Number of Pages: 168 Pages
Introduction
Foreword
Product View
Trademarks
Glossary of Terms
Regions and Country Versions
Machine Overview
Safety Precautions
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Handle Starting Fluid Safely
Fire Prevention
In Case of Fire
Avoid Static Electricity Risk When Refueling
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operators’s Manuals for ISOBUS Controllers
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Transport Towed Equipment at Safe Speeds
Use Caution on Slopes, Uneven Terrain, and Rough Ground
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Emergency Measures
Safety Signs
Replace Safety Signs
Operators's Manual Safety Sign
Use Seat Belt Safety Sign
Never Step on PTO Shield
Riders Safety Sign
Keep Away from High Temperature Coolant
Controls and Instruments
Tractor Controls - Front Console
Tractor Controls - Right-Hand Side
Tractor Controls - Left-Hand Side
Instrument Cluster
Information Display
Engine Operation
Before Starting the Engine
Operate Key Switch
Start the Engine
Check Indicators and Gauges
Change Engine Speeds
Recommended Engine Speeds and Operational Procedures
Stop the Engine
Air Intake, Fuel, Coolant, and Exhaust Operation
Fill Fuel Tank
Electrical and Lighting Operation
Light Switch
Use Headlights and Worklights (OOS)
Use Headlights and Worklights (CAB)
High Beam Headlights Indicator
Use Tail Lights and Warning Lights
Use Turn-Signal Lights
Use Dome Light (CAB)
Seven-Pin Outlet
Accessory Electrical Outlet
Cigarette Lighter
Drivetrain Operation
Gear Selection
Transmission Operation
Operate Transmission
Shift Transmission
Stop Tractor
MFWD and Front Axle Operation
Operate Mechanical Front-Wheel Drive (MFWD)
Differential and Rear Axle Operation
Differential Lock
Power Take-off (PTO) Operation
Attach PTO-Driven Implement
Operate Tractor PTO
Steering and Brake Operation
Steering Stop Adjustment
Operate Brakes
Hydraulics Operation
Open Center Hydraulic System
Warm Hydraulic System Oil
Hitch and Drawbar Operation
Rear Hitch Components
Prepare Implement
Rockshaft Control Lever
Use Rockshaft Position Control
Set Position Control Lever Stop
Use Draft Control
Remote Command of Hydraulic Hitch
Adjust Rockshaft Rate-of-Drop
Attach Implements to 3-Point Hitch
Adjust Sway Chains
Level Hitch
Adjust Lateral Float
Wagon Hitch
Selective Control Valve Operation
SCV Control Lever and Coupler Identification
Connect Cylinder Hoses
Reconnect Hoses Under Pressure
Use Correct Hose Tips
Operate SCV Control Levers
Match Tractor Power to Implement
Wheels and Tires Operation
Check Implement-to-Tire Clearance
Check Tire Inflation Pressure
Tire Inflation Pressure Chart
Tighten Wheel/Axle Hardware Correctly
Tighten Bolts—Rear Axle
Tighten Bolts—Front Axle
Tread Settings — Front Wheels
Tread Settings—Multi-Position Rear Wheels
Check Toe-In
Adjust Toe-In
Ballast
Plan for Maximum Productivity
Select Ballast Carefully
Determine Maximum Rear Ballast
Determine Maximum Front Ballast
Use Cast Iron Weights
Additional Equipment
Additional Equipment Operation
Operators’s Station
Operate ROPS
Use Seat Belt
Adjust Seat
Use Emergency Exit
Open Windows
Open Door
Front Sun Shade
Adjust Fan and Temperature (with HVAC)
Operate Windshield Wiper
Adjust Steering Wheel
Toolbox Location
Transport and Storage
Operators Training Required
Observe Maximum Travel Speeds
Drive Tractor on Roads
Transport on Carrier
Tow Tractor
Tractor Storage
Remove Tractor from Storage
Maintenance Intervals
Maintenance Interval Chart
Service Tractor Safely
Observe Service Intervals
Service Daily Before Start-Up
Additional Service Information
Fuels, Lubricants, and Coolants
Cold-Weather Operation
Hot-Weather Operation
Diesel Fuel
Lubricity of Diesel Fuel
Testing Diesel Fuel
Lubricant Storage
Diesel Engine Break-In Oil — Non-Emissions Certified and Certified Tier 1, Tier 2, Tier 3, Stage I, Stage II, and Stage III
Diesel Engine Oil — Tier 2 and Stage II
Oil Filters
Fuel Filters
Heavy Duty Diesel Engine Coolant
John Deere COOL-GARD™ II Coolant Extender
Transmission and Hydraulic Oil
MFWD Front Axle Housing Oil
MFWD Wheel Hub Oil
Multipurpose Extreme Pressure (EP) Grease
Mixing of Lubricants
As Required Maintenance
Wash Machine After Unloading
Controls and Instruments Maintenance
Engine Maintenance
Engine Operation—Break-In Check
Open Hood
Check Engine Oil Level
Use Correct Lubricant
Change Engine Oil and Filter
Adjust Hand Throttle Friction
Check Engine Idle Speed
Break-In Service
Break-In Service
Air Intake, Fuel, Coolant, and Exhaust Maintenance
Service Air Cleaner
Replace Air Cleaner Elements
Check Air Intake System
Check Hoses and Hose Clamps for Tightness
Clean Engine Crankcase Vent Tube
Do Not Modify Fuel System
Drain Water and Sediment from Fuel Filters
Drain Water and Sediment from Fuel Tank
Replace Primary Fuel Filter
Replace Secondary Fuel Filter
Check Coolant Level
Check Cooling System for Leaks
Flush Cooling System
Bleed Fuel System
Front Grille, Side Screens, Radiator, and Oil Cooler Cleaning
Electrical and Lighting Maintenance
Electrical Service Precautions
Use Booster Battery
Clean Battery
Replace Fan Belt
Remove Battery
Service Battery
Battery Replacement Specifications
Charge Battery
Check Battery Condition
Access Fuses
Starter Wiring Connections
Fuse Size and Function
Adjust Headlights
Aim Headlights
Replace Headlight Bulbs
Replace Front Turn Signal/Warning Light Bulbs
Replace Tail Light/Rear Warning Light Bulbs
Replace Worklight Bulb
Drivetrain Maintenance
Use Correct Transmission/Hydraulic Filter Element
Check Neutral Start System
Transmission Maintenance
Check Transmission/Hydraulic System Oil Level
Change Transmission/Hydraulic System Oil
Replace Transmission/Hydraulic Oil Filter
MFWD and Front Axle Maintenance
Lubricate MFWD Front Axle Steering Spindles
Lubricate Front Axle Pivot
Check MFWD Wheel Hub Oil Level
Check MFWD Axle Housing Oil Level
Change MFWD Wheel Hub Oil
Change MFWD Front Axle Housing Oil
Differential and Rear Axle Maintenance
Lubricate Rear Axle Bearings
Power Take Off (PTO) Maintenance
Adjust PTO Clutch Operating Lever
Adjust PTO Control Rod
Steering and Brake Maintenance
Adjust Clutch Pedal Free Travel
Check Brake Pedal
Hydraulics Maintenance
Warm Transmission/Hydraulic System Oil
Hitch and Drawbar Maintenance
Lubricate 3-Point Hitch Components
Selective Control Valve Maintenance
Check Selective Control Valve
Wheels and Tires Maintenance
Inspect Tractor for Loose Hardware
Inspect Tires
Ballasting Maintenance
Measure Rear Wheel Slip—Manually
Ballast Front End for Transport
Install Rear Cast Iron Weights
Additional Equipment Maintenance
Operators’s Station Maintenance
Keep Cab Protection System Installed Properly
Inspect Seat Belt
Troubleshooting
Engine Troubleshooting
Transmission Troubleshooting
Hydraulic System Troubleshooting
Braking System Troubleshooting
Rockshaft and 3-Point Hitch Troubleshooting
Hydraulic Cylinders Troubleshooting
Electrical System Troubleshooting
Worklights Troubleshooting
Clutch Troubleshooting
Ground Driving System Troubleshooting
Steering System Troubleshooting
Front / Rear Axle Troubleshooting
Specifications
Machine Dimensions and Weights
Machine Specifications
Ground Speeds
Identification Numbers
Identification Plates
Record Tractor Serial Number
Record MFWD Front Axle Serial Number
Record Engine Serial Number
Record Transmission Serial Number
Service Records
As Required, Daily or 10 Hour, and Every 50 Hour Service Chart
Every 250 Hour Service Chart
Every 500 Hour, 1000 Hour or Annual, Every Two Year or 2000 Hour Service Chart
John Deere Service Literature Available
Technical Information
John Deere Service Keeps You On The Job
John Deere Parts
The Right Tools
Well-Trained Technicians
John Deere Is At Your Service
