Martin Welker
104
230,310
John Deere 5090E 5090EL 5100E FT4 Tractors Operators Manual OMSU54538
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 5090E 5090EL 5100E FT4 Tractors
Part Number: OMSU54538
Publication Date: 2018
Number of Pages: 300 Pages
Introduction
Foreword
Emissions Performance and Tampering
Product View
Trademarks
Glossary of Terms
Regions and Country Versions
Machine Overview
Safety Precautions
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Handle Starting Fluid Safely
Fire Prevention
In Case of Fire
Avoid Static Electricity Risk When Refueling
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operators’s Manuals for ISOBUS Controllers
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Use a Safety Chain
Transport Towed Equipment at Safe Speeds
Use Caution on Slopes, Uneven Terrain, and Rough Ground
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Safety Signs
Replace Safety Signs
Operators Manual (Cab)
Operators Manual (OOS and Low-Profile)
Use Seat Belt Properly (Cab)
Use Seat Belt Properly (OOS and Low-Profile)
Instructional Seat
Starter
PTO Shield
Tow Implement Properly
Front End Loader
Engine Coolant Heater
ROPS
Controls and Instruments
Front Console Controls
Foot Operated Controls
Side Console Controls
Transmission Controls
Multi-Function Lever/Mid-SCV Controls
Rear SCV Controls
Rear Hitch Controls
Rear PTO Controls
Heat and Air Conditioning Controls
Engine Operation
Required Machine Stop Warning
Engine Fuel System and Power Rating
Check Engine Indicators and Gauges
Operate Key Switch
Start Engine
Cold Weather Start
Run Engine
Engine Speeds and Operational Procedures
Stop Engine
Restart Engine That Has Run Out of Fuel
Air Intake, Fuel, Coolant, and Exhaust Operation
Aftertreatment Indicators Overview
Selective Catalytic Reduction (SCR) System Overview
US EPA Qualified Emergency Use — SCR Derate Override Option
Fuel and Diesel Exhaust Fluid (DEF) Level Gauge
Fill Fuel Tank
Fill Diesel Exhaust Fluid (DEF) Tank
Reduce Fuel Consumption
Exhaust Filter Cleaning
Exhaust Filter System Overview
Automatic (AUTO) Exhaust Filter Cleaning
Disabled Exhaust Filter Cleaning
Parked Exhaust Filter Cleaning
Service Exhaust Filter Cleaning
Electrical and Lighting Operation
Light Switch
Headlights (Cab)
Headlights (OOS and Low-Profile)
Loader Lights
Bucket Lights
Tail and Brake Lights (Cab)
Brake Lights (OOS)
Turn Signals
Warning Lights
Beacon Light
Front Work Lights
Rear Work Lights
Dome Light
Right-Hand Console Light
Horn
Backup Alarm
Front Wiper and Washer
Rear Wiper and Washer
Radio
Radio Antenna
Implement Connector
Power Outlet
Convenience Outlet
Auxiliary Power Strip
Service ADVISOR™ Connector
Operators Presence
Displays, Software, and Electronics Operation
Primary Display
Information Display (Roll-Mode Switch)
Drivetrain Operation
Drivetrain Information
Off Level Operation
Transmission Operation
Electrohydraulic Transmission System Indicator
12/12 Transmission
24/12 Transmission
Reverser Modulation
Downhill Operation in Slippery Conditions
12/12 Transmission Ground Speed Chart
24/12 Transmission Ground Speed Chart
Correction Factors for Other Tire Sizes
MFWD and Front Axle Operation
Mechanical Front-Wheel Drive (MFWD On/Off)
Mechanical Front-Wheel Drive (MFWD On/Brake Assist)
Differential and Rear Axle Operation
Differential Lock
Power Take-Off (PTO) Operation
Match Machine Power to Implement
PTO Guard
PTO Shield
PTO Drive Shaft Shield
Select PTO Drawbar Position
Exchangeable 540/1000 rpm PTO Shaft
Attach PTO Driven Implement
Select Correct PTO Speed
Operate Rear PTO
Steering and Brake Operation
Service Brakes
Hydraulics Operation
Warm Transmission/Hydraulic Oil
Open Center Hydraulics
Hitch and Drawbar Operation
Rear Hitch Controls
Rear Hitch Components
Operate Mechanical Position Control
Operate Mechanical Draft Control
Operate Mechanical Rate-of-Drop Control
Prepare Implement
Hitch Conversion - Category II to I
Position Center Link
Adjust Lateral Float
Attach Implement to Rear Hitch
Level Hitch
Adjust Hitch Side Sway
Quick Coupler
Drawbar Settings
Clevis Drawbar
Drawn Implement Connection
Selective Control Valve Operation
Rear SCV Controls and Components
Mid-SCV Controls and Components
Connect Hydraulic Hoses
Connect to Rear SCVs
Connect to Mid-SCVs
Correct Reversed Cylinder Response
Single-Acting Cylinders
Implements Requiring Large Volumes of Oil
Set SCV Detents
Operate Hydraulic Motor with Rear SCV
Operate Power Beyond with Rear SCV
Operate Loader with Rear SCV
Adjust Flow Control
Power Beyond
Wheels and Tires Operation
Wheels and Tires Information
Ballasting
Ballasting Information
Additional Equipment
Tool Box
Front Loader
Lockable Fuel Fill Cap
Hood Latch
Operators’s Station Operation
Doors
Grab Handles
Windows
Mirrors
Foldable Roll-Over Protective Structure (ROPS)
Cab Seats
OOS and Low Profile Seats
Adjust Seat Armrests
Instructional Seat
Steering Wheel
Heat, Defrost, and Air Conditioning
General Storage
Field Office™
Monitor Mounts
Rear Window Cable Routing
Coat Hook
Ash Tray and Cigarette Lighter
Transport and Storage
Keep Machines Secure
Deliver Safely
Road Transportation
Towing Loads
Come Home Mode - PowrReverser Transmission
Tow Machine
Front Tow Points
Rear Tow Points
Machine Storage
Remove Machine from Storage
Maintenance Intervals
Maintain Daily Before Start-Up
Maintenance Interval Chart
Fuels, Lubricants, and Coolants
Diesel Engine Coolant (engine with wet sleeve cylinder liners)
Operating in Warm Temperature Climates
John Deere COOL-GARD™ II Coolant Extender
Water Quality for Mixing with Coolant Concentrate
Testing Coolant Freeze Point
Diesel Exhaust Fluid (DEF) — Use in Selective Catalytic Reduction (SCR) Equipped Engines
Disposal of Diesel Exhaust Fluid (DEF)
Refilling Diesel Exhaust Fluid (DEF) Tank
Storing Diesel Exhaust Fluid (DEF)
Testing Diesel Exhaust Fluid (DEF)
Diesel Engine Oil Service Interval for Operation at High Altitude
Diesel Engine Oil — Interim Tier 4, Final Tier 4, Stage IIIB, Stage IV, and Stage V
Engine Oil and Filter Service Intervals — Interim Tier 4, Final Tier 4, Stage IIIB, Stage IV, and Stage V Engines
John Deere Break-In Plus™ Engine Oil — Interim Tier 4, Final Tier 4, Stage IIIB, Stage IV, and Stage V
Oil Filters
Fuel Filters
Diesel Fuel
Lubricity of Diesel Fuel
Testing Diesel Fuel
Biodiesel Fuel
Minimizing the Effect of Cold Weather on Diesel Engines
Supplemental Diesel Fuel Additives
Multipurpose Extreme Pressure (EP) Grease
Mixing of Lubricants
Lubricant Storage
Oilscan™ and CoolScan™
Transmission, Steering, Brake, Hydraulic, and Gear Case Oil
As Required Maintenance
Maintain as Required
Paint and Finish Care
Wash Machine
Controls and Instruments Maintenance
General Controls and Instruments Maintenance
Engine Maintenance
Break-In Maintenance
Break-In Checks
Check Engine Oil Level
Change Engine Oil and Filter
Clean Open Crankcase Vent (OCV) Tube
Change Open Crankcase Vent (OCV) Filter
Check Fan Belt Tensioner
Replace Fan Belt
Adjust Engine Valve Clearance
Air, Fuel, Coolant, and Exhaust Maintenance
Required Emission-Related Information
Recommended Dealer Performed Service
Check Engine and Exhaust Compartments for Debris
Clean Diesel Particulate Filter (DPF)
Change Diesel Exhaust Fluid (DEF) In-Line Filter
Change Diesel Exhaust Fluid (DEF) Dosing Unit Filter
Replace Diesel Exhaust Fluid (DEF) Tank Header Suction Screen
Clean Diesel Exhaust Fluid (DEF) Tank
Drain Diesel Exhaust Fluid (DEF) Tank
Service Air Cleaner Elements
Tighten Air Intake and Engine Cooling Hose Clamps
Clean Air Filter Dust Unloading Valve
Clean Grille Screens and Cooling Package
Do Not Modify Fuel System
Drain Water and Sediment from Fuel Tank and Fuel Filter
Bleed Fuel System
Replace Fuel Filters
Clean Fuel Tank Vent Filter
Check Coolant Level
Electrical and Lighting Maintenance
Use Booster Battery or Charger
Battery Maintenance
Replace Battery
Replace Fusible Link
Replace Cab Fuses
Replace OOS and Low Profile Fuses
Handle Halogen Light Bulbs Safely
Replace Halogen Headlight Bulb
Replace LED Headlight
Headlight Adjustment
Replace Loader Light Bulb
Replace Bucket Light
Replace Cab Tail/Turn/Brake Light Bulb
Replace OOS Tail/Turn/Warning Light Bulb
Replace Low-Profile Tail/Turn/Warning Light Bulb
Replace OOS Brake Light Bulb
Replace Cab Warning Light Bulb
Replace Canopy Warning Light Bulb
Replace Cab Halogen Work Light Bulb
Replace Cab LED Work Light
Replace OOS and Low Profile Rear Work Light Bulb
Replace OOS and Low Profile Fender Light Bulb
Replace Beacon Light Bulb
Replace Dome Light Bulb
Replace Right-Hand Console Light Bulb
Drivetrain Maintenance
Transmission Maintenance
Change Transmission/Hydraulic Oil and Filter
Check Neutral Start System
Check Transmission Park System
Replace Transmission Dampener
MFWD and Front Axle Maintenance
Check Axle Pivot Pin End Play
Check MFWD Axle for Oil Leaks
Lubricate MFWD Axle Trunnion
Check MFWD Axle Housing and Wheel Hub Oil Levels
Change MFWD Axle Wheel Hub Oil
Change MFWD Axle Housing Oil
Differential and Rear Axle Maintenance
Lubricate Rear Axle Bearings
Power Take-Off (PTO) Maintenance
Adjust PTO Speed Shift Lever
Lubricate Exchangeable 540/1000 rpm PTO Shaft
Steering and Brake Maintenance
Check Manual Brakes
Hydraulics Maintenance
Check Transmission/Hydraulic System Oil Level
Change Transmission/Hydraulic Filter
Hitch and Drawbar Maintenance
Lubricate Rear Hitch
Inspect Hitch and Drawbar for Excessive Wear
Selective Control Valve Maintenance
Adjust Mechanical SCV Cables
Wheels and Tires Maintenance
Inspect Tires
Adjust and Check Clearance
Check Tire Inflation Pressure
Tire Pressures
Tire Inflation Pressure Guidelines
Tire Sidewall Information
Use Correct Tire Combinations
Correct Tire Selection
Changing Tire Sizes
Select Front Tire Rolling Direction
Rear Wheel Tread Width Limitations
Set Tread—Two-Position MFWD Wheels
Set Tread—Multi-Position MFWD Wheels
Set Tread—Multi-Position Rear Wheels
Tighten Wheel Bolts Correctly
Install Wheel Spacer
Tighten Wheel Bolts—MFWD Axle
Tighten Wheel Bolts—Rear Axle
Jacking Up Machine
Check Toe-In—MFWD Axle
Adjust Toe-In—MFWD Axle
Set Steering Stops
Ballasting Maintenance
General Ballast Information
Select Ballast Carefully
Front-End Ballast
Rear Wheel Ballast
Control Power Hop - MFWD
Add Liquid Ballast to Tires
Remove Liquid Ballast from Tires
Measure Wheel Slip
Additional Equipment Maintenance
Front Loader Bracket Installation
Set Pivoting Fender Brackets
Set Fender Position
Operators’s Station Maintenance
Clean Cab Air Filters
Check Air Conditioning System
Replace Wiper Blade
Inspect Seat Belts
Adjust OOS and Low Profile Rear Fender
Keep Roll-Over Protective Structure (ROPS) Installed Properly
Keep Cab Protection System Installed Properly
Troubleshooting
Electrical
Display
Brakes
Hydraulics
Hitch
Selective Control Valves (SCV)
On-Board Diagnostics
STOP, Service, Information Alert Indicators, and Alarms
On-Board Diagnostic Tool
Specifications
Fluid Capacities
Machine Dimensions
Machine Weight
Engine and PTO Power
Engine Specifications
Electrical Specifications
PTO Engine Speeds
Hydraulic Specifications
Rear Hitch Lift Capacities
Drawbar Capacities
Weight Distribution
Permissible Load
Ballast Capacities
Sound Level
Identification Numbers
Record Product Identification Number
Record Engine Serial Number
Record Transmission Serial Number
Record Front Axle Serial Number
Record Cab Serial Number
Record ROPS Serial Number
Keep Proof of Ownership
Certification and Warranty
Cab ROPS Certificate
OOS ROPS Certificate
Low Profile ROPS Certificate
Limited Battery Warranty
Emissions Control System Certification Label
Carbon Dioxide Emissions (CO₂)
CARB Non-road Emissions Control Warranty Statement—Compression Ignition
EPA Non-road Emissions Control Warranty Statement—Compression Ignition
Maintenance Records
Daily or 10 Hours
Weekly or 50 Hours
First 100 Hours
Every 250 Hours
Every 300 Hours
Every 500 Hours
Every 600 Hours
Every 1200 Hours
Annual Maintenance
Every 3000 Hours
Every 4500 Hours
Change of Ownership
Change of Ownership
Change of Ownership
Index
John Deere Service
Technical Information
John Deere Is At Your Service
