Martin Welker
104
230,310
John Deere 5085E And 5100E (FT4) Tractors Operators Manual OMSU41692
Format: HTML
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 5085E And 5100E (FT4) Tractors
Publication Date: 2015
Parts Number: OMSU41692
Foreword
Identification Views
Section 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Handle Starting Fluid Safely
Fire Prevention
In Case of Fire
Avoid Static Electricity Risk When Refueling
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operator Manuals for ISOBUS Implements
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Use a Safety Chain
Transport Towed Equipment at Safe Speeds
Use Caution On Slopes and Uneven Terrain
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Dispose of Waste Properly
Section 10 - Safety Signs
Replace Safety Signs
PTO Shield
Starter
Engine Coolant Heater—If Equipped
Tow Implement Properly
Use Seat Belt Properly (Cab)
Use Seat Belt Properly (OOS)
Operators Manual
Instructional Seat—If Equipped
Front End Loader—If Equipped
ROPS
Section 15 - Controls and Instruments
Front Console Switches and Controls
Foot-Operated Controls
Tractor Controls—Cab
Tractor Controls—OOS
Gauges and Indicator Lights
Aftertreatment Indicators Overview
Information Display (Roll Mode Switch)
Heater and Air Conditioning Controls (Cab Only)
Section 20 - Lights
Light Location
Road, Work, and Warning Lights
Turn Signal, High, and Low Beam Lights
Brake Light
Loader Auxiliary Driving Lights—If Equipped
Implement/Trailer Outlet
Rotating Beacon Light—If Equipped
Section 25 - Operator Station—OOS
Operate Foldable ROPS
ROPS—Certification
Adjusting Operator Seat
Seat Belt
Adjust Steering Wheel Tilt and Height
Section 30 - Operator Station—Cab
Door and Windows
Adjusting Seat
Adjusting Steering Wheel Tilt and Height
HVAC Blower Speed
HVAC Temperature
Defrost Windshield
Air Conditioner and Heater Performance
Windshield Wiper and Washer
Rear Window Wiper and Washer—If Equipped
Use Dome Light
Using Control Illumination Light
Installing a Monitor
Accessory Electrical Outlet
Coat Hook
Section 35 - Break-In Period
Observe Engine Operation
Break-In Service
Section 40 - Prestarting Checks
Service Daily Before Start-Up
Section 50 - Operate Engine
Before Starting the Engine
Operate Key Switch
Start Engine
Cold Weather Start Aid
Using Engine Coolant Heater—If Equipped
Check Engine Indicators and Gauges
Changing Engine Speeds
Recommended Engine Speeds and Operational Procedures
Stopping the Engine
Use Booster Battery or Charger
DEF (Diesel Exhaust Fluid) Level Gauge
Selective Catalytic Reduction (SCR) System Overview
Required Machine Stop Warning
Exhaust Filter System Overview
Automatic (AUTO) Exhaust Filter Cleaning
Disabled Exhaust Filter Cleaning
Parked Exhaust Filter Cleaning
Service Exhaust Filter Cleaning
Section 55 - Operating the Tractor
Operating PowrReverser Transmission
Ground Speed Estimates—PowrReverser Transmission
Operate PowrReverser Plus Transmission
Ground Speed Estimates—PowrReverser Plus Transmission
Correction Factors for Other Tire Sizes
Electrohydraulic Transmission System Indicator
Select a Gear
Using Differential Lock
Mechanical Front-Wheel Drive—Electrohydraulic Control—If Equipped
Mechanical Front-Wheel Drive—With Brake Assist—If Equipped
Operating Brakes
Stop Tractor
Driving on Public Roads
Section 60 - Rear Hitch Controls
Operate Mechanical Position Control
Operate Mechanical Draft Control
Operate Mechanical Rate-of-Drop
Section 65 - 3-Point Hitch
Match Tractor Power to Implement
3-Point Hitch Components
Preparing Implement
Convert Category II Hitch to Category I
Position Center Link
Attach Implements to 3-Point Hitch
Adjust Hitch Side Sway
Level Hitch
Adjust Lateral Float
Section 70 - Hydraulic System Controls and Operations
Rear SCV Control Lever and Coupler Identification
Mid-Mount SCV Multi-function Lever and Coupler Identification—If Equipped
Use Correct Hose Tips
Connecting or Disconnecting High-Pressure Hoses
Connect Cylinder Hoses to Rear SCV
Connect Cylinder Hoses to Mid SCV—If Equipped
Connect and Operate Single-Acting Cylinder
Operate Rear SCV Control Levers
Set Rear SCV Detents
Use Deluxe Rear SCV to Operate Hydraulic Motor
Use Rear SCV to Provide Power Beyond Oil
Use Rear SCV to Operate Loader
Operate Mid SCV Multi-function Lever—If Equipped
Adjust Flow Control—Rear SCV and Mid SCV—If Equipped
Correcting Reversed Cylinder Response
Warm Transmission-Hydraulic System Oil
Use Hydraulic Power Beyond Coupler—If Equipped
Section 75 - Drawbar and PTO
Observing Drawbar Load Limitations
Selecting Drawbar Position
Adjusting Drawbar Length and Offset
Attaching PTO-Driven Implement
Selecting Correct PTO Speeds
Operating Tractor PTO
Section 80 - Performance Ballast
Planning for Maximum Productivity
Select Ballast Carefully
Using Cast Iron Weights
Installing Rear Cast Iron Weights
Filling Tires With Liquid Ballast
Draining Tires
Using Implement Codes
Section 85 - Wheels, Tires and Treads
Check Implement-to-Tire Clearance
Check Tire Inflation Pressure
Tire Inflation Pressure Charts
Selecting Front Tire Rolling Direction
Tighten Wheel/Axle Hardware Correctly
Tighten Wheel Bolts—MFWD Axle
Tighten Wheel Bolts—Rear Axle
Observe Rear Wheel Tread Width Limitations
Jacking Up Tractor—Lifting Points
Tread Settings—Multi-Position Rear Wheels
Tread Settings—Multi-Position MFWD Wheels
Checking Toe-In—MFWD Axle
Adjust Toe-In—MFWD Axle
Set MFWD Steering Stops Turn Radius
Use Correct Tire Combinations
Section 86 - Additional Equipment
Front Loader Installation - Front Loader Brackets
Section 90 - Transporting
Ballasting Front End for Transport
Using Safety Chain
Deliver Safely
Towing Tractor
Section 95 - Fuel, Lubricants, and Coolant
Filling Fuel Tank
Filling Diesel Exhaust Fluid (DEF) Tank
Diesel Engine Coolant (engine with wet sleeve cylinder liners)
Operating in Warm Temperature Climates
John Deere COOL-GARD™ II Coolant Extender
Water Quality for Mixing with Coolant Concentrate
Diesel Exhaust Fluid (DEF) — Use in Selective Catalytic Reduction (SCR) Equipped Engines
Disposal of Diesel Exhaust Fluid (DEF)
Refilling Diesel Exhaust Fluid (DEF) Tank
Storing Diesel Exhaust Fluid (DEF)
Testing Diesel Exhaust Fluid (DEF)
Testing Coolant Freeze Point
Extended Diesel Engine Oil Service Intervals
Diesel Engine Oil — Interim Tier 4, Final Tier 4, Stage IIIB, and Stage IV
Engine Oil and Filter Service Intervals — Interim Tier 4, Final Tier 4, Stage IIIB, and Stage IV Engines
John Deere Break-In Plus™ Engine Oil — Interim Tier 4, Final Tier 4, Stage IIIB, and Stage IV
Oil Filters
Fuel Filters
Diesel Fuel
Lubricity of Diesel Fuel
Testing Diesel Fuel
BioDiesel Fuel
Minimizing the Effect of Cold Weather on Diesel Engines
Supplemental Diesel Fuel Additives
Grease
Mixing of Lubricants
Lubricant Storage
Transmission, Steering, Brake, Hydraulic, and Gear Case Oil
Oilscan™ and CoolScan™
Section 100 - Maintenance and Service Intervals
Service Interval Chart
Service—As Required
Section 105 - Maintenance—As Required/Per Condition
Service Engine Air Cleaner
Required Emission-Related Information
Cleaning Diesel Exhaust Fluid (DEF) Tank
Adjust PTO Speed Shift Lever—Open Operator's Station
Adjust PTO Speed Shift Lever—Cab
Adjust Hand Throttle Friction Linkage
Adjust Rear Fender—Open Operator's Station
Service Air Conditioner—If Equipped
Clean and Check Battery Condition
Clean Cab Air Filters—If Equipped
Clean Grille Screens, Radiator, Oil Cooler, Air Conditioning Screen (If Equipped), and Air Conditioning Condenser (Cab)
Lubricate Rear Axle Bearings
Drain and Flush Fuel Tank
Keep Cab Protection System Installed Properly
Bleed Fuel System
Replace Battery
Locate Fusible Link
Locating Fuses
Fuse and Relay Size and Function
Handling Halogen Light Bulbs Safely
Replace Headlight Bulb
Replacing Warning Light Bulb—Cab
Replacing Taillight Bulb—Cab
Replace Tail Light and/or Warning Light Bulb—Open Operator's Station
Replace Work Light Bulb—Open Operator's Station
Replacing Work Light Bulb
Replacing Loader Light Bulb—If Equipped
Replacing Dome Light Bulb
Replacing Controls Illumination Light Bulb
Replacing Rotary Beacon Light Bulb—If Equipped
Section 110 - Maintenance—Every 10 Hours or Daily
Checking Engine Oil Level
Drain Water and Sediment from Fuel Tank and Fuel Filter
Cleaning Air Filter Dust Unloading Valve
Section 115 - Maintenance—Every Week or 50 Hours
Inspecting Tires
Checking Coolant Level
Checking Transmission-Hydraulic System Oil Level
Check MFWD for Oil Leaks
Checking MFWD Axle Housing Oil Level
Checking MFWD Axle Wheel Hub Oil Level
Lubricate MFWD Axle Trunnion
Lubricating 3-Point Hitch
Inspecting Tractor for Loose Hardware
Section 120 - Maintenance—First 100 Hours
Changing Engine Oil and Filter
Replacing Transmission-Hydraulic Filter
Inspect Hose Clamps on Air Intake System and Engine Cooling System
Section 125 - Maintenance—Every 300 Hours
Section 130 - Maintenance—Every 500 Hours
Replacing Fuel Filter
Section 135 - Maintenance—Every 600 Hours
Check Neutral Start System
Changing MFWD Axle Wheel Hub Oil
Changing MFWD Axle Housing Oil
Clean Open Crankcase Vent (OCV) Tube
Lubricating Rear Axle Bearings
Check Front Axle Pivot Pin End Play
Tighten Air Intake System and Engine Cooling System Hose Clamps
Section 140 - Maintenance—Every 1200 Hours
Inspecting Fan Belt Tensioner
Replace Fan Belt
Changing Transmission-Hydraulic Oil and Filter
Service Air Cleaner Elements
Clean Fuel Tank Vent Filter
Section 145 - Maintenance—Annually
Cleaning Cab Air Filters
Inspecting Seat Belt
Check Engine Coolant Properties
Section 155 - Maintenance—First Three Years or 3000 Hours
Flush Cooling System and Replace Thermostat
Adjust Engine Valve Clearance
Section 160 - Maintenance—First Five Years or 5000 Hours
Changing Diesel Exhaust Fluid (DEF) Dosing Unit Filter
Section 165 - Troubleshooting
Brakes
3-Point Hitch
Remote Hydraulic Cylinder
Selective Control Valves (SCV)
Heater and A/C System (Cab)
Wipers, Work Lights, Dome Light and Radio (Cab)
Section 170 - Storage
Tractor Storage
Remove Tractor from Storage
Section 175 - Specifications
Machine Specifications
Drain and Refill Capacities
Permissible Load Specifications
Limited Battery Warranty
Emissions Control System Certification Label
CARB Non-road Emissions Control Warranty Statement—Compression Ignition
EPA Non-road Emissions Control Warranty Statement—Compression Ignition
Section 180 - Identification Numbers
Record Product Identification Number
Record Front Axle Serial Number
Record Engine Serial Number
Record Transmission Serial Number
Record Cab Serial Number
Keep Proof of Ownership
Keep Machines Secure
Section 185 - Service and Maintenance Record
Daily or 10 Hour Service
Weekly or 50 Hour Service
First 100 Hour Service
300 Hour Service
500 Hour Service
600 Hour Service
1200 Hour Service
Annual Service
First 3 Years or 3000 Hours Service
First 5 Years or 4500 Hours Service
Change of Ownership
Change of Ownership
Change of Ownership
Section JDS - John Deere Service
Technical Information
John Deere Is At Your Service
