John Deere 5085E 5095E 5100E Tractor Repair Technical Manual TM128319
Brand: John Deere
Model: John Deere 5085E 5095E 5100E Tractor
Part Number: TM128319
Publication Date: 2013
Number of Pages: 1030 Pages
FOREWORD
Section 10 - GENERAL INFORMATION
Group 05 - Safety
Prevent Battery Explosions
Prevent Acid Burns
Service and Operate Chemical Sprayers Safely
Protect Against High Pressure Spray
Work In Ventilated Area
Recognize Safety Information
Avoid Backover Accidents
Prevent Machine Runaway
Avoid Contact with Agricultural Chemicals
Clean Vehicle of Hazardous Pesticides
Use a Safety Chain
Work in Clean Area
Dispose of Waste Properly
Avoid Harmful Asbestos Dust
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Handle Fuel Safely—Avoid Fires
Prepare for Emergencies
Avoid High-Pressure Fluids
Install All Guards
Use Proper Lifting Equipment
Illuminate Work Area Safely
Live With Safety
Service Machines Safely
Support Machine Properly
Park Machine Safely
Stay Clear of Rotating Drivelines
Follow Safety Instructions
Use Proper Tools
Service Tires Safely
Keep ROPS Installed Properly
Practice Safe Maintenance
Understand Signal Words
Replace Safety Signs
Wear Protective Clothing
Handling Batteries Safely
Service Cooling System Safely
Transport Tractor Safely
Servicing Electronic Control Units
Welding Near Electronic Control Units
Keep Electronic Control Unit Connectors Clean
Group 10 - General Specifications
Features and Accessories
Machine General Specifications
Drain and Refill Capacities
Service Recommendations for O-Ring Boss Fittings
Service Recommendations For Flat Face O-Ring Seal Fittings
Glossary of Terms
Group 15 - Fuel and Lubricants
Diesel Fuel
Lubricity of Diesel Fuel
Testing Diesel Fuel
BioDiesel Fuel
Do Not Use Galvanized Containers
Fill Fuel Tank
Diesel Engine Break-In Oil — Non-Emissions Certified and Certified Tier 1, Tier 2, Tier 3, Stage I, Stage II, and Stage III
Diesel Engine Oil — Interim Tier 4, Final Tier 4, Stage IIIB, and Stage IV
Oil Filters
Diesel Engine Coolant (engine with wet sleeve cylinder liners)
Operating in Warm Temperature Climates
Testing Diesel Engine Coolant
Transmission and Hydraulic Oil
Additional Information About Diesel Engine Coolants and John Deere LIQUID COOLANT CONDITIONER
Use Correct Transmission/Hydraulic Filter Element
MFWD Axle Housing and Wheel Hub Oil
Grease
Mixing of Lubricants
Lubricant Storage
Group 20 - Serial Number Locations
Serial Numbers
Product Identification Number
Engine Serial Number
Alternator Identification Number Location
Power Steering Valve Serial Number Location
Starter Serial Number Location
Transmission Serial Number
Mechanical Front Wheel Drive (MFWD) Serial Number Location
Air Conditioner Compressor Serial Number Location
Cab Serial Number
Section 20 - ENGINE
Group 05 - Engine
Service Equipment and Tools
Specifications
Other Material
John Deere Engine Repair—Use Component Technical Manual
Remove Engine
Install Engine
Group 10 - Cooling System
Engine Water Pump Repair—Use Component Technical Manual
Drain Coolant
Remove and Install Coolant Recovery Tank
Remove and Inspect Radiator
Install Radiator
Remove and Install Thermostat
Replace Belt Tensioner
Remove and Install Viscous Clutch
Section 30 - FUEL, AIR INTAKE AND EXHAUST SYSTEMS
Group 05 - Fuel System
Specifications
Injection Pump, Nozzle and Governor Repair
Replace Fuel Level Sender—Cab
Remove, Inspect and Install Fuel Tank—Cab
Replace Fuel Level Sender—Open Operator Station
Remove, Inspect and Install Fuel Tank—Open Operator Station
Replace Fuel Filters
Remove and Install Fuel Primer Pump Assembly
Remove, Inspect and Install Fuel Cooler
Replace Fuel Strainer and In-Line Check Valve
Inspect and Replace Fuel System Lines—Cab
Inspect and Replace Fuel System Lines—Open Operator Station
Group 15 - Air Intake System
Specifications
Other Material
Turbocharger Repair
Remove, Inspect and Install Air Cleaner Elements—Axial Type
Remove and Install Air Cleaner—Axial Type
Remove Turbocharger
Install Turbocharger
Remove, Inspect and Install Charge Air Cooler (CAC)
Group 20 - Air Exhaust System
Specifications
Remove and Install Exhaust Pipe
Remove and Install Aftertreatment Device
Section 40 - ELECTRICAL REPAIR
Group 05 - Battery, Starter and Alternator
Starter Repair—Use Component Technical Manual
Remove and Install Battery
Remove and Install Starter
Remove and Install Alternator
Group 10 - Electrical System Components
Other Material
Specifications
Remove and Install Electrical Shifter Pod
Replace Key Switch
Replace Light Switch
Replace Speakers
Replace Antenna
Replace Turn Signal Switch
Replace Instrument Cluster
Program Instrument Cluster
Replace Rear PTO Switch—Open Operator Station
Replace Rear PTO Switch—Cab
Replace Wiper Control Switch
Replace Wiper Motor
Replace Hand Throttle Position Sensor (OOS)
Replace Hand Throttle Position Sensor (Cab)
Replace Foot Throttle Position Sensor
Replace Park Switch
Replace Speed Lever Neutral Switch—PR Transmission with Creeper
Replace Creeper Lever Position Sensor
Replace Blower Control Switch
Replace A/C Deicing Switch
Replace A/C On/Off Switch
Replace HVAC Resistor
Replace A/C High/Low Pressure Switch
Replace Dome Light
Replace Left Door Switch
Replace Seat Switch—Open Operator Station
Replace Seat Switch—Cab
Replace Load Center—Open Operator Station
Replace Load Center—Cab
Replace Electrohydraulic Control Unit (EHC)—OOS
Replace Electrohydraulic Control Unit (EHC)—Cab
Replace Engine Control Unit (ECU)
Replace Start Relay
Replace Neutral Relay
Replace Top Shaft Speed Sensor
Replace Wheel Speed Sensor
Replace Enable Pressure Sensor
Replace Hydraulic Oil Temperature Sensor
Replace Clutch Pedal Position Sensor
Replace Clutch Disengage Switch
Replace Rear PTO Speed Sensor
Replace Forward Neutral Reverse (FNR) Switch
Replace Brake Pedal Switch
Replace High/Low Shifter Switch—PowrReverser Transmission
Replace Mid-Mount SCV 3rd Function Switch
Replace Multi-Function Control Lever Switch
Replace Mid-Mount SCV Solenoid—If Equipped
Replace Clutch Enable Solenoid
Replace Transmission Forward (Low) Solenoid Valve
Replace Transmission Forward (High) Solenoid Valve (with License and Clearance Lights)
Replace Transmission Reverse Solenoid Valve
Replace PTO Solenoid Valve
Replace EH MFWD Solenoid
Replace EH MFWD Switch
Replace MFWD (Mechanical) Lever Position Switch
Replace Seat Height Control Switch
Replace Headlight Bulb
Replace Warning Light Bulb—Cab
Replace Turn/Warning Light and/or Clearance Light Bulb—Cab
Replace Tail/Brake Light and/or Turn/Warning Light Bulb—Cab
Replace Tail Light and/or Warning Light Bulb—Open Operator Station
Replace Work Light Bulb—OOS
Replace Work Light Bulb—Cab
Replace Fender Light Bulb—OOS
Replace Loader Light Bulb—If Equipped
Replace Loader Light Bulb (with License and Clearance Lights)—If Equipped
Replace Dome Light Bulb—Cab
Replace Controls Illumination Light Bulb—Cab
Replace Rotary Beacon Light Bulb—If Equipped
Group 15 - Wiring Harnesses
Essential Tools
Replace Connector Body—Blade Terminals
Replace WEATHER PACK™ Connector
Install WEATHER PACK™ Contact
Repair (Pull Type) METRI-PACK™ Connectors
Repair (Push Type) METRI-PACK™ Connectors
Exploded View—CINCH Flexbox Connectors
CINCH™ Flexbox Connectors
Repair DEUTSCH™ Connectors
Replace W005 Convenience Outlet Harness (Convenience Outlet with Square Terminals)
Replace W006 Convenience Outlet Harness (Convenience Outlet with Round Terminals)
Replace W007 Engine Power Cable
Replace W008 Positive Battery Cable
Replace W009 Negative Battery Cable
Replace W013 Front Windshield Wiper Harness
Replace W016 Auxiliary Power Strip
Replace W017 Roof License Plate Lighting Harness
Replace W022 Clutch Assembly Harness
Replace W100 Hood Harness
Replace W101 Left Loader Light Harness
Replace W102 Right Loader Light Harness
Replace W103 Loader Light Switch Harness
Replace W104 Right Beacon Light Harness
Replace W105 Left Beacon Light Harness
Replace W106 Left Rear Work Light Harness
Replace W107 Right Rear Work Light Harness
Replace W110 Brake Light Harness
Replace W111 Right Work Light Fender Extension Harness
Replace W112 Left Work Light Fender Extension Harness
Replace W118 Right-Hand Handrail Light Harness
Replace W119 Left-Hand Handrail Light Harness
Replace W120 Right Beacon Light Harness
Replace W121 Left Beacon Light Harness
Replace W307 Engine Harness
Replace W308 Chassis Harness (OOS, PR)
Replace W506 Cab Harness (PR)
Replace W507 Cab Power Harness
Replace W508 Cab Harness (PR, Secondary Brake)
Replace W575 Transmission Harness (PR)
Replace W576 Transmission Harness (PR, Secondary Brake)
Replace W701 Mid-Mount SCV Harness (Cab)
Replace W702 Mid-Mount SCV Harness (OOS)
Replace W703 Multi-Function Control Lever Harness (with Hi/Lo)
Replace W704 Multi-Function Control Lever Harness (without Hi/Lo)
Replace W705 Multi-Function Control Lever Switch Harness
Replace W706 Multi-Coupler Harness
Replace W904 Front Console Harness (PR)
Replace W905 Front Console Harness (PR, Secondary Brake)
Replace W923 Roof Harness (Cab)
Replace W924 Roof Harness (Cab, Secondary Brake)
Replace W931 Air Seat Harness
Replace Exhaust Filter Harness
Replace Injector Harness
Section 50 - POWER TRAIN REPAIR
Group 05 - Clutch Housing
Other Material
Specifications
John Deere Transmission Repair—Use Component Technical Manual
Separate Engine from Clutch Housing
Install Engine to Clutch Housing
Clutch Housing Repair
Inspect and Repair Clutch Pedal and Linkage—(PowrReverser™ Transmissions)
Group 11 - Clutch Assembly
Specifications
John Deere PR Clutch Repair—Use Component Technical Manual
Remove and Install Clutch Assembly
PowrReverser™ Clutch Assembly Repair
Group 15 - PowrReverser™ Transmission
John Deere PowrReverser™ Transmission Repair—Use Component Technical Manual
Section 56 - DRIVE SYSTEM
Group 05 - Differential
Differential Repair
Group 10 - Final Drives
Final Drives Repair
Group 15 - Rear PTO Drive Shaft
Rear PTO Drive Shaft Repair
Inspect and Repair PTO Shift Lever and Linkage—Open Station
Inspect and Repair PTO Shift Lever and Linkage—Cab
Group 20 - Mechanical Front Wheel Drive
Specifications
Other Material
Electrohydraulic Front Wheel Drive Repair
Mechanical Front Wheel Drive Repair
Remove, Inspect and Install MFWD Lever and Linkage
Remove, Inspect and Install MFWD Drive Shaft
Remove and Install MFWD Axle Housing Assembly
Section 60 - STEERING AND BRAKE REPAIR
Group 05 - Steering Repair
Other Material
Specifications
Service Parts Kits
Remove and Install Tilt/Telescoping Steering Column
Remove and Install Steering Valve—Tilt/Telescoping Steering Column
Disassemble and Inspect Steering Valve
Assemble Steering Valve
Remove and Install Steering Cylinder—MFWD Axle
Disassemble, Inspect, and Assemble Steering Cylinder—MFWD Axle
Remove, Inspect, and Install Tie Rod Assembly—MFWD Axle
Inspect and Replace Steering Hydraulic Lines
Group 10 - Brake Repair
Other Material
Specifications
Remove and Install Brake Valve and Pedals
Disassemble and Inspect Brake Pedals and Valve
Brake Valve Cross Section
Assemble Brake Valve
Remove and Inspect Brakes
Install Brakes
Inspect and Replace Brake Hydraulic Lines
Brake Pedal Adjustment
Secondary Brake Repair
Adjust Secondary Brake
Bleed Brakes
Section 70 - HYDRAULIC REPAIR
Group 05 - Hydraulic Pump and Filter
Specifications
Prime Hydraulic Pump
Remove, Inspect, and Install Hydraulic Oil Pick-Up Screen
Remove and Install Hydraulic Pump
Remove Hydraulic Pump External Components
Disassemble and Inspect Hydraulic Pump
Assemble Hydraulic Pump
Install Hydraulic Pump External Components
Remove and Install Hydraulic Oil Filter/Manifold
Group 10 - Hydraulic Oil Cooler
Remove, Inspect, and Install Hydraulic Oil Cooler
Group 15 - Rockshaft
Other Material
Specifications
Service Parts Kits
Inspect and Repair Rockshaft Control Assembly
Inspect and Repair Control Lever—OOS
Inspect and Repair Control Lever and Cables—Mechanical Hitch (Cab)
Inspect and Repair Rockshaft Control Linkage
Remove and Install Rockshaft Control Valve
Replace Main Relief Valve
Replace Rockshaft Hitch Surge Relief Valve
Remove, Inspect, and Install Rate-of-Drop Valve
Remove and Install Rockshaft Case
Remove, Inspect, and Install Rockshaft Lift Arms
Remove, Inspect, and Install Rockshaft Piston and Cylinder
Inspect and Repair Draft Sensing Support Assembly
Rockshaft Lever Friction Adjustment
Draft Control and Position Control Cable Adjustment
Group 20 - Rear Selective Control Valve
Other Material
Specifications
Inspect and Repair SCV Levers and Linkage—Cab
Inspect and Repair SCV Levers and Linkage—OOS
Remove and Install Dual or Triple Selective Control Valve (SCV)
Disassemble, Inspect, and Assemble Dual Selective Control Valve (SCV)
Triple Selective Control Valve (SCV) Cross-Sectional View
Disassemble, Inspect, and Assemble Triple Selective Control Valve (SCV)
Rear SCV Control Cable Adjustment
Rear Triple Deluxe SCV Kick-Out Relief Valve Adjustment
Group 25 - Mid-Mount Selective Control Valve
Other Material
Specifications
Inspect and Repair Joystick and Linkage
Inspect and Repair Multi-Function Control Lever and Linkage (with Secondary Brake)
Remove and Install Mid-Mount Selective Control Valve (SCV)
Remove and Install Mid-Mount Selective Control Valve (SCV) (with Secondary Brake)
Disassemble, Inspect, and Assemble Dual Mid-Mount Selective Control Valve (SCV)
Disassemble, Inspect, and Assemble Triple Mid-Mount Selective Control Valve (SCV)
Mid-Mount SCV Control Cable Adjustment
Mid-Mount SCV Multi-Function Control Cable Adjustment (with Secondary Brake)
Group 30 - Hydraulic Lines
Specifications
Inspect and Replace Hydraulic Lines
Inspect and Replace Implement Pump Hydraulic Lines
Inspect and Replace Steering Lines and Hoses
Inspect and Replace Hydraulic Trailer Brake (HTB) Valve Lines
Group 35 - Hydraulic Trailer Brake Valve
Other Material
Specifications
Remove, Inspect and Install Hydraulic Trailer Brake (HTB) Valve
Disassemble, Inspect and Assemble Hydraulic Trailer Brake (HTB) Valve
Section 80 - MISCELLANEOUS REPAIR
Group 15 - 3-Point Hitch
Specifications
Inspect and Repair Telescoping Draft Links
Inspect and Repair Standard Lift Link
Inspect and Repair Adjustable Lift Link
Inspect and Repair Center Link
Inspect and Repair Hammerstrap Drawbar
Remove and Install Standard Drawbar and Support
Remove and Install Weldment Drawbar Support
Remove and Install Trailer Hitch
Checking the Manually Operated Trailer Hitch for Wear
Checking the Drawbar for Wear
Proper Use of Drawbar
Group 20 - Fenders
Other Material
Specifications
Remove and Install Fenders—Cab
Remove and Install Fenders—Open Operator Station
Group 25 - Hood
Remove and Install Hood
Section 90 - OPERATOR STATION REPAIR—CAB AND OPEN OPERATOR STATION
Group 05 - Seat and Support
Remove and Install Seat and Support—Cab
Remove and Install Seat and Support—Open Operator Station
Group 06 - Roll-Gard
Specifications
Remove and Install Roll-Gard
Group 10 - Control Console and Panel
Specifications
Remove and Install Right-Side Control Console—Cab
Remove and Install Right-Side Control Console—Open Operator Station
Remove and Install Left-Side Control Console—Cab
Remove and Install Left-Side Control Console—Open Operator Station
Remove and Install Center Control Console
Group 20 - Cab Components
Essential Tools
Other Material
Specifications
Remove, Inspect, and Install Cab Interior Recirculating Air Filters
Remove, Inspect, and Install Exterior Cab Intake Air Filter
Remove and Install Headliner
Remove and Install Instructional Seat
Remove and Install Left-Side Upholstery
Remove and Install Right-Side Upholstery
Remove and Install Windshield
Remove and Install Front Lower Windows
Remove and Install Rear Lower Window
Remove and Install Rear Upper Window
Remove and Install Side Windows
Remove and Install Cab Doors
Remove and Install Inner Roof for Air Conditioning Housing Repair
Remove Cab
Install Cab
Park Position Indicator Installation (If Equipped)
Group 30 - Air Conditioning System
Essential Tools
Other Material
Specifications
Adjust A/C Deicing Switch
Recover/Recycle Air Conditioning Refrigerant
Replace Air Conditioning Receiver-Dryer
Remove, Inspect, and Install Air Conditioning Condenser
Remove, Inspect, and Install Air Conditioning Compressor
Test Volumetric Efficiency of Compressor
Test Compressor Shaft Seal Leakage
Disassemble and Assemble Compressor Clutch
Disassemble, Inspect, and Assemble Compressor
Check Compressor Clutch Hub Clearance
Inspect Compressor Manifold
Remove and Install HVAC Housing Cover
Remove Blower Motors
Remove Evaporator-Heater Core
Leak Test Evaporator/Heater Core
Install Evaporator-Heater Core
Service Expansion Valve
Expansion Valve Bench Test
Refrigerant Oil Information
Check Compressor Oil Charge
Determine Correct Refrigerant Oil Charge
Add Refrigerant Oil to System
System Information
Flush Air Conditioning System
Evacuate Air Conditioning System
Charge Air Conditioning System
Group 35 - Heating System
Adjust Heater Temperature Control Cable
Replace Heater Temperature Control Cable
Remove Heater Control Valve
Leak Test Heater Control Valve
Install Heater Control Valve
Section 99 - SPECIAL TOOLS
Group 05 - Dealer Fabricated Tools
DFLV1A—Final Drive Turning Tool
DFRW20—Compressor Holding Fixture
DFT1162—Snap Ring Removal Tool
Group 10 - Service Tools
Essential and Recommended Tools
Brand: John Deere
FOREWORD
Group 05 - Safety
Prevent Acid Burns
Use a Safety Chain
Work in Clean Area
Avoid Hot Exhaust
Install All Guards
Live With Safety
Park Machine Safely
Use Proper Tools
Glossary of Terms
Diesel Fuel
Testing Diesel Fuel
BioDiesel Fuel
Fill Fuel Tank
Oil Filters
Grease
Lubricant Storage
Serial Numbers
Cab Serial Number
Section 20 - ENGINE
Group 05 - Engine
Specifications
Other Material
Remove Engine
Install Engine
Drain Coolant
Install Radiator
Specifications
Specifications
Other Material
Turbocharger Repair
Remove Turbocharger
Specifications
Other Material
Specifications
Replace Key Switch
Replace Speakers
Replace Antenna
Replace Wiper Motor
Replace Park Switch
Replace Dome Light
Replace Start Relay
Essential Tools
Other Material
Specifications
Specifications
Differential Repair
Final Drives Repair
Specifications
Other Material
Other Material
Specifications
Service Parts Kits
Other Material
Specifications
Install Brakes
Bleed Brakes
Specifications
Other Material
Specifications
Service Parts Kits
Other Material
Specifications
Other Material
Specifications
Specifications
Other Material
Specifications
Specifications
Group 20 - Fenders
Other Material
Specifications
Group 25 - Hood
Specifications
Specifications
Essential Tools
Other Material
Specifications
Remove Cab
Install Cab
Essential Tools
Other Material
Specifications
System Information
- JOHN DEERE CODE DTC LIST
