Martin Welker
104
230,310
John Deere 5083E 5093E 5101E Limited Tractor Repair Technical Manual TM112519
Brand: John Deere
Model: John Deere 5083E Limited, 5093E Limited, 5101E Limited, 5083E, 5093E, and 5101E Tractor
Part Number: TM112519
Publication Date: 2012
Number of Pages: 1525 Pages
FOREWORD
Section 10 - GENERAL INFORMATION
Group 05 - Safety
Recognize Safety Information
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Service and Operate Chemical Sprayers Safely
Avoid High-Pressure Fluids
Park Machine Safely
Support Machine Properly
Wear Protective Clothing
Work in Clean Area
Service Machines Safely
Work In Ventilated Area
Illuminate Work Area Safely
Replace Safety Signs
Use Proper Lifting Equipment
Keep ROPS Installed Properly
Service Tires Safely
Avoid Harmful Asbestos Dust
Practice Safe Maintenance
Use Proper Tools
Dispose of Waste Properly
Prevent Machine Runaway
Handle Starting Fluid Safely
Service Cooling System Safely
Stay Clear of Rotating Drivelines
Protect Against High Pressure Spray
Clean Vehicle of Hazardous Pesticides
Live With Safety
Group 10 - General Specifications
Machine Specifications 5083E Limited, 5093E Limited, 5101E Limited, 5083E, 5093E, and 5101E
Machine Dimensions
Repair Specifications
Service Recommendations for O-Ring Boss Fittings
Service Recommendations For Flat Face O-Ring Seal Fittings
Metric Cap Screw Torque Values—Grade 7
Glossary of Terms
Group 20 - Fuel and Lubricants
Diesel Fuel
Do Not Use Galvanized Containers
Lubricity of Diesel Fuel
Testing Diesel Fuel
Biodiesel Fuel
Filling Fuel Tank
Diesel Engine Break-In Oil
Diesel Engine Oil
Oil Filters
Heavy Duty Diesel Engine Coolant
Operating in Warm Temperature Climates
Additional Information About Diesel Engine Coolants and John Deere LIQUID COOLANT CONDITIONER
Testing Diesel Engine Coolant
Transmission and Hydraulic Oil
Use Correct Transmission/Hydraulic Filter Element
MFWD Axle Housing and Wheel Hub Oil
Grease
Grease (Specific Application)
Mixing of Lubricants
Lubricant Storage
Group 25 - Serial Number Locations
Serial Numbers
Product Identification Number Location
Engine Serial Number Location
Fuel Injection Pump Serial Number Location
Alternator Identification Number Location
Power Steering Valve Serial Number Location
Starter Serial Number Location
Transmission Serial Number Location
Mechanical Front Wheel Drive (MFWD) Serial Number Location
Air Conditioning Compressor Serial Number Location
Cab Serial Number Location
Group 30 - Features and Accessories
Standard Features
Factory Installed Optional Equipment
Field Installed Optional Kits and Accessories
Section 20 - ENGINE REPAIR
Group 05 - Engine
Service Equipment and Tools
Specifications
John Deere Engine Repair—Use Component Technical Manual
Remove Engine (Tier 2)
Remove Engine ( -Aug 2012)
Remove Engine (Aug 2012- )
Install Engine (Tier 2)
Install Engine ( -Aug 2012)
Install Engine (Aug 2012- )
Group 10 - Cooling System
Specifications
Engine Coolant Pump Repair—Use Component Technical Manual
Remove and Install Coolant Recovery Tank (Tier 2)
Remove and Install Coolant Recovery Tank (Tier 3)
Remove and Inspect Radiator (Tier 2)
Remove and Inspect Radiator (Tier 3)
Install Radiator (Tier 2)
Install Radiator (Tier 3)
Remove and Install Thermostat
Inspect and Replace Belt Tensioner
Section 30 - FUEL AND AIR REPAIR
Group 05 - Fuel System
Specifications
Injection Pump, Nozzle and Governor Repair
Remove, Inspect and Install Fuel Tank—Cab
Remove, Inspect and Install Fuel Tank—Open Operator Station
Replace Fuel Filter/Water Separator
Remove and Install Fuel Filter/Primer Pump Assembly
Replace Fuel Transfer Pump (Tier 2)
Remove and Install Fuel Transfer Pump (Tier 3)
Remove, Inspect and Install Fuel Cooler (Tier 3)
Replace In-Line Fuel Filter (Tier 3)
Group 10 - Air Intake System
Specifications
Turbocharger Repair
Remove, Inspect and Install Air Cleaner Elements (Tier 2)
Remove, Inspect and Install Air Cleaner Elements (Tier 3)
Remove and Install Air Cleaner (Tier 2)
Remove and Install Air Cleaner (Tier 3)
Remove Turbocharger ( -Aug 2012)
Install Turbocharger ( -Aug 2012)
Remove and Install Turbocharger (Aug 2012- )
Turbocharger Break-In
Remove, Inspect and Install Charge Air Cooler (CAC) (Tier 3)
Group 15 - Speed Control Linkage
Inspect and Repair Speed Control Linkage ( -Aug 2012)
Inspect and Repair Speed Control Linkage (Aug 2012- )
Inspect and Repair Speed Control Linkage—PTO
Section 40 - ELECTRICAL REPAIR
Group 05 - Battery, Starter and Alternator
Starter Repair—Use Component Technical Manual
Remove and Install Battery (Tier 2)
Remove and Install Battery (Tier 3)
Remove and Install Starter
Replace Alternator/Regulator (Tier 2)
Replace Alternator/Regulator (Tier 3)
Group 10 - Electrical System Components
Essential Tools
Other Material
Specifications
Replace Air Filter Restriction Switch
Replace Cold Start Advance Switch
Replace Coolant Temperature Sender
Replace Engine Speed Sensor (Tier 2)
Replace Engine Speed Sensor (Tier 3)
Replace Engine Oil Pressure Switch
Replace Key Switch—Cab
Replace Key Switch—Open Operator Station
Replace Light Switch—Cab
Replace Light Switch—Open Operator Station
Replace Speakers
Replace Antenna
Replace Turn Signal Switch—Cab
Replace Turn Signal Switch—Open Operator Station
Replace Instrument Cluster—Cab
Replace Instrument Cluster—Open Operator Station
Program Instrument Cluster
Replace Rear PTO Switch—Cab
Replace Rear PTO Switch—Open Operator Station
Replace Fuel Level Sender—Cab
Replace Fuel Level Sender—Open Operator Station
Replace Wiper Control Switch
Replace Wiper Motor
Replace Blower Control Switch
Replace A/C On/Off Switch
Replace A/C Temperature Control Switch
Replace Blower Motor Resistor
Replace Air Conditioning High/Low Pressure Switch
Replace Dome Light
Replace Door Switch
Replace Seat Switch—Cab
Replace Seat Switch—Open Operator Station
Replace Vehicle Electrical Center (VEC)
Replace Load Center—Cab
Replace Load Center—Open Operator Station
Replace Electro-Hydraulic Controller—Cab
Replace Electro-Hydraulic Controller—Open Operator Station
Replace Start Relay—VEC
Replace Start Relay—Load Center
Replace Countershaft Speed Sensor
Replace Wheel Speed Sensor
Replace Enable Pressure Sensor
Replace Hydraulic Oil Temperature Sensor
Replace Clutch Pedal Position Sensor
Replace Clutch Disengage Switch
Replace Rear PTO Sensor
Replace Electro-Hydraulic Directional Reverser
Replace Park Switch
Replace Brake Pedal Switch
Replace Mid-Mount Solenoid Switch
Replace Clutch Enable Solenoid
Replace Trans Forward Solenoid
Replace Trans Reverse Solenoid
Group 15 - Wiring Harness
Essential Tools
Replace Connector Body—Blade Terminals
Replace WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Connector
Install WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Contact
Repair (Pull Type) Metri-Pack® Connectors
Repair (Push Type) Metri-Pack® Connectors
Replace Headlight Wiring Harness (Tier 2)
Replace Headlight Wiring Harness (Tier 3)
Replace Fused Power Wiring Harness
Replace Engine Wiring Harness (Tier 2)
Replace Engine Wiring Harness (Tier 3)
Replace Console Wiring Harness
Replace Rear Wiring Harness
Replace Cab Roof Wiring Harness
Replace Open Operator Station Chassis Wiring Harness
Section 50 - POWER TRAIN REPAIR
Group 05 - Clutch Housing
Other Material
Specifications
Separate Engine from Clutch Housing
Install Engine to Clutch Housing
Inspect and Repair Clutch Pedal and Linkage—(PowrReverser™ Transmissions)
Group 11 - Clutch Assembly
Essential Tools
Other Material
Specifications
Service Parts Kits
Remove and Install Clutch Assembly
Disassemble and Inspect Clutch Assembly
Assemble Clutch Assembly
PTO Clutch Finger Adjustment
Remove and Inspect Clutch Release Mechanism and Shafts
Install Clutch Release Mechanism and Shafts
Remove, Inspect, and Repair Transmission Pump
Group 12 - PowrReverser Clutch Assembly
PowrReverser™ Transmission Identification
Essential Tools
Other Material
Specifications
Remove and Install PowrReverser™ Control Valve
Disassemble, Inspect, and Repair PowrReverser™ Control Valve
Remove and Install PowrReverser™—Transmissions
Disassemble, Inspect, and Repair Reverse Idle Gear
Disassemble, Inspect, and Repair Clutch Gear
Disassemble, Inspect, and Repair Driven Shaft
Group 16 - PowrReverser™ Transmission
Essential Tools
Other Material
Specifications
Separate Clutch Housing from Transmission
Install Clutch Housing to Transmission
Remove Transmission
Disassemble and Inspect Transmission
Assemble Transmission
Install Transmission
Disassemble, Inspect, and Assemble Gearshift Shaft Assemblies
Disassemble, Inspect, and Assemble Transmission Bottom Shaft
Disassemble, Inspect, and Assemble Range Reduction Shaft
Disassemble, Inspect, and Assemble Top Shaft
Remove, Inspect, and Install MFWD and Range Gears
Section 56 - DRIVE SYSTEM
Group 05 - Differential
Essential Tools
Other Material
Specifications
Service Parts Kits
Remove and Install Differential Assembly
Disassemble, Inspect, and Assemble Differential Assembly
Remove and Inspect Differential Drive Shaft
Install Differential Drive Shaft
Remove, Inspect, and Install Differential Lock Assembly
Differential Cone Point Adjustment
Differential Backlash Adjustment
Group 10 - Final Drives
Other Material
Specifications
Remove and Install Final Drive Assembly
Remove and Inspect Planetary Drive Assembly
Install Planetary Drive Assembly
Remove, Inspect, and Install Axle Shaft Assembly
Group 15 - Rear PTO Drive Shaft
Other Material
Specifications
Remove, Inspect and Install Rear PTO Lever and Linkage
Inspect and Repair PTO Shift Lever and Linkage
Remove and Install Rear PTO Drive Shaft Assembly
Disassemble, Inspect, and Assemble Rear PTO Drive Shaft Assembly
Remove and Install Rear 540/540E Electro-Hydraulic PTO Shaft Assembly
Disassemble, Inspect, and Assemble Rear 540/540E Electro-Hydraulic Pinion Shaft
Disassemble, Inspect, and Assemble Rear 540/540E Electro-Hydraulic PTO Output Shaft Assembly
Remove, Inspect and Install Electro-Hydraulic PTO Valve
Group 20 - Mechanical Front Wheel Drive
Other Material
Specifications
MFWD Axle Repair—Use Component Technical Manual
Remove, Inspect and Install MFWD Lever and Linkage
Remove, Inspect and Install MFWD Lever and Linkage—OOS
Remove and Install MFWD Drop Gearbox
Disassemble and Inspect MFWD Drop Gearbox
MFWD Drop Gearbox Cross Section
Assemble MFWD Drop Gearbox
Remove, Inspect and Install MFWD Drive Shaft
Remove and Install MFWD Axle Housing Assembly
Group 25 - Creeper Assembly
Other Material
Specifications
Remove and Install Creeper Assembly
Disassemble, Inspect, and Assemble Creeper Assembly
Section 60 - STEERING AND BRAKE REPAIR
Group 05 - Steering Repair
Other Material
Specifications
Service Parts Kits
Remove and Install Straight Steering Column and Valve
Remove and Install Tilt/Telescoping Steering Column
Remove and Install Steering Valve—Tilt/Telescoping Steering Column
Disassemble and Inspect Steering Valve
Assemble Steering Valve
Remove and Install Steering Cylinder—MFWD Axle
Disassemble, Inspect, and Assemble Steering Cylinder—MFWD Axle—Use Component Technical Manual
Remove, Inspect and Install Tie Rod Assembly—MFWD Axle
Inspect and Replace Steering Hydraulic Lines
Group 10 - Brake Repair
Other Material
Specifications
Remove and Install Brake Valve and Pedals
Disassemble and Inspect Brake Pedals and Valve
Brake Valve Cross Section
Assemble Brake Valve
Remove and Inspect Brakes
Install Brakes
Inspect and Replace Brake Hydraulic Lines
Section 70 - HYDRAULIC REPAIR
Group 05 - Hydraulic Pump and Filter
Specifications
Prime Hydraulic Pump
Remove, Inspect, and Install Hydraulic Oil Pick-Up Screen
Remove and Install Hydraulic Pump
Remove Hydraulic Pump External Components
Disassemble and Inspect Hydraulic Pump
Assemble Hydraulic Pump
Install Hydraulic Pump External Components
Remove and Install Hydraulic Oil Filter/Manifold—Later Version
Inspect and Replace Hydraulic Supply/Return Lines
Group 06 - Hydraulic Oil Cooler
Remove, Inspect, and Install Hydraulic Oil Cooler (Tier 2)
Remove, Inspect, and Install Hydraulic Oil Cooler (Tier 3)
Group 10 - Rockshaft
Service Parts Kits
Other Material
Specifications
Inspect and Repair Rockshaft Control Assembly—Earlier Version
Inspect and Repair Rockshaft Control Assembly—Later Version
Inspect and Repair Rockshaft Control Levers and Cables
Inspect and Repair Control Lever and Cables—Mechanical Hitch (Cab) (NEW CAB)
Replace Hitch Control Module—Electro-Hydraulic Hitch (NEW CAB)
Inspect and Repair Rockshaft Control Linkage
Remove and Install Rockshaft Control Valve—Earlier Version
Remove and Install Rockshaft Control Valve—Later Version
Replace Main Relief Valve—Earlier Version
Replace Main Relief Valve—Later Version
Replace Rockshaft Surge Relief Valve
Remove, Inspect, and Install Rate-of-Drop Valve—Earlier Version
Remove, Inspect, and Install Rate-of-Drop Valve—Later Version
Remove and Install Rockshaft Case—Earlier Version
Remove and Install Rockshaft Case—Later Version
Remove, Inspect, and Install Rockshaft Lift Arms
Remove, Inspect, and Install Rockshaft Piston and Cylinder
Inspect and Repair Draft Sensing Support Assembly—Earlier Version
Inspect and Repair Draft Sensing Support Assembly—Later Version
Group 15 - Selective Control Valve
Other Material
Specifications
Inspect and Repair SCV Levers and Linkage—Earlier Version
Inspect and Repair SCV Levers and Linkage—Later Version
Inspect and Repair SCV Levers and Linkage—OOS
Remove and Install Selective Control Valve (SCV)—Earlier Version
Remove and Install Dual or Triple Selective Control Valve (SCV)—Later Version
Disassemble, Inspect, and Assemble Dual Selective Control Valve (SCV)—Later Version
Triple Selective Control Valve (SCV) Cross-Sectional View—Later Version
Disassemble, Inspect, and Assemble Selective Control Valve (SCV)—Earlier Version
Disassemble, Inspect, and Assemble Triple Selective Control Valve (SCV)—Later Version
Inspect and Replace Hydraulic Lines Single, Dual, or Triple Selective Control Valve (SCV)—Earlier Version
Inspect and Replace Hydraulic Lines Single, Dual, or Triple Selective Control Valve (SCV)—Later Version
Inspect and Replace Hydraulic Lines Single, Dual, or Triple Selective Control Valve (SCV) With Mid-Mount Valve—Later Version
Group 20 - Hydraulic Mid-Mount Control Valve
Other Material
Specifications
Inspect and Repair Joystick and Linkage
Remove and Install Mid-Mount Control Valve
Disassemble, Inspect, and Assemble Dual Mid-Mount Control Valve
Disassemble, Inspect and Assemble Triple Mid-Mount Selective Control Valve (SCV)
Inspect and Replace Hydraulic Lines on Dual or Triple Mid-Mount Control Valve With Rear SCV—Early Version
Section 80 - MISCELLANEOUS REPAIR
Group 15 - 3-Point Hitch
Specifications
Inspect and Repair Fixed Draft Links
Inspect and Repair Telescoping Draft Links-Cab (S.N. -439999)
Inspect and Repair Telescoping Draft Links—Cab (S.N. 73000- ) and Open Operator Station
Inspect and Repair Standard Lift Link
Inspect and Repair Adjustable Lift Link
Inspect and Repair Center Link
Remove and Install Draw Bar and Support
Group 20 - Fenders
Other Material
Specifications
Remove and Install Fenders—Cab (S.N. -439999)
Remove and Install Fenders—Cab (S.N. 73000- )
Remove and Install Fenders—Open Operator Station
Group 25 - Hood
Remove and Install Hood
Section 90 - OPERATOR STATION REPAIR—CAB (S.N. -439999)
Group 05 - Seat and Support
Specifications
Remove and Install Seat and Support—With Mechanical Seat (Tier 2)
Remove and Install Seat and Support—Tier 2 (Later Models) and Tier 3
Group 06 - Control Console and Panel
Remove and Install Right-Side Control Console
Remove and Install Left-Side Control Console
Remove and Install Center Control Console
Group 15 - Cab Components
Essential Tools
Other Material
Specifications
Remove, Inspect, and Install Cab Interior Recirculating Air Filters
Remove, Inspect, and Install Exterior Cab Intake Air Filter
Remove and Install Headliner
Remove and Install Instructional Seat
Remove and Install Left-Side Upholstery
Remove and Install Right-Side Upholstery
Remove and Install Windshield
Remove and Install Front Lower Windows
Remove and Install Rear Lower Window
Remove and Install Rear Upper Window
Remove and Install Side Windows
Remove and Install Cab Doors
Remove and Install A/C Housing Inner Roof
Remove Cab
Install Cab
Group 20 - Air Conditioning System
Essential Tools
Other Material
Specifications
Service Parts Kits
Recover/Recycle Air Conditioning Refrigerant
Replace Air Conditioning Receiver/Dryer
Remove, Inspect, and Install Air Conditioning Condenser (Tier 2)
Remove, Inspect, and Install Air Conditioning Condenser (Tier 3)
Remove, Inspect, and Install Air Conditioning Compressor (Tier 2)
Remove, Inspect, and Install Air Conditioning Compressor (Tier 3)
Test Volumetric Efficiency of Compressor
Test Compressor Shaft Seal Leakage
Disassemble and Assemble Compressor Clutch
Disassemble, Inspect, and Assemble Compressor
Check Compressor Clutch Hub Clearance
Inspect Compressor Manifold
Remove and Install Compressor Relief Valve
Remove and Install HVAC Housing Cover
Remove Blower Motors
Remove Evaporator/Heater Core
Leak Test Evaporator/Heater Core
Install Evaporator/Heater Core
Service Expansion Valve
Expansion Valve Bench Test
Refrigerant Oil Information
Check Compressor Oil Charge
Determine Correct Refrigerant Oil Charge
Add Refrigerant Oil to System
System Information
Flush Air Conditioning System
Evacuate Air Conditioning System
Charge Air Conditioning System
Group 25 - Heating System
Replace Heater Temperature Control Cable
Remove Heater Control Valve
Leak Test Heater Control Valve
Install Heater Control Valve
Section 91 - OPERATOR STATION REPAIR—CAB (S.N.73000- ) AND OPEN OPERATOR STATION
Remove and Install Seat and Support—Cab
Remove and Install Seat and Support—Open Operator Station
Group 06 - ROLL-GARD
Remove and Install ROLL-GARD ROLL-GARD is a trademark of Deere & Company —Open Operator Station
Group 10 - Control Console and Panel
Specifications
Remove and Install Right-Side Control Console—Cab
Remove and Install Right-Side Control Console—Open Operator Station
Remove and Install Left-Side Control Console—Cab
Remove and Install Left-Side Control Console—Open Operator Station
Remove and Install Center Control Console—Cab
Remove and Install Cowl Cover—Open Operator Station
Group 20 - Cab Components
Essential Tools
Other Material
Specifications
Remove and Install Inner Roof for Air Conditioning Housing Repair
Remove Cab
Install Cab
Park Position Indicator Installation and Adjustment Procedure—Cab (—Dec. 2011)
Group 30 - Air Conditioning System
Essential Tools
Other Material
Specifications
Adjust A/C Temperature Control Switch
Remove, Inspect, and Install Compressor Relief Valve
System Information
Group 35 - Heating System
Adjust Heater Temperature Control Cable
Section 99 - DEALER FABRICATED TOOLS
Group 05 - Dealer Fabricated Tools
DFLV1A—Final Drive Turning Tool
DFRW20—Compressor Holding Fixture
DFT1162—Snap Ring Removal Tool
