John Deere 5076E 5076EL 5082E 5090E 5090EL 5090EH Tractors Operators Manual OMSU57587
- Download this document, you need 300 Gallons
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 5076E 5076EL 5082E 5090E 5090EL 5090EH Tractors
Part Number: OMSU57587
Number of Pages: 252 Pages
Introduction
Foreword
Emissions Performance and Tampering
Product View
Trademarks
Glossary of Terms
Regions and Country Versions
Machine Overview
Safety Precautions
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Handle Starting Fluid Safely
Fire Prevention
In Case of Fire
Avoid Static Electricity Risk When Refueling
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operators’s Manuals for ISOBUS Controllers
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Transport Towed Equipment at Safe Speeds
Use Caution on Slopes, Uneven Terrain, and Rough Ground
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Safety Signs
Replace Safety Signs
Operators's Manual Safety Sign
Use Seat Belt Safety Sign
Passenger Seat Safety Sign
Riders Safety Sign
ROPS Safety Sign
Hearing Protection Safety Sign
Controls and Instruments
Front Console Controls
Right-Hand Console Controls
Left-Hand Console Controls
Instrument Cluster (Gauges and Indicator Lights) — SS
Instrument Cluster (Gauges and Indicator Lights) — PR
Information Display — PR
AutoTrac™ Universal Controls
Engine Operation
Before Starting the Engine
Operate Key Switch
Start the Engine
Check Engine Indicators and Gauges
Change Engine Speeds
Recommended Engine Speeds and Operating Procedures
Stop the Engine
Cold-Weather Start Aid
Engine Coolant Heater
Air Intake, Fuel, Coolant, and Exhaust Operation
Fill Fuel Tank
Electrical and Lighting Operation
Use a Booster Battery or Charger
Light Switch
Use Headlights
High Beam Indicator
Use Tail Lights
Use Work Lights
Adjust Work Lights — OOS
Adjust Work Lamps — Cab
Use Warning Lights
Use Turn Signals
Use Clearance Lights
Operate Beacon Light
Use Dome Light
Use Control Illumination Light
Seven-Terminal Outlet
Accessory Electrical Outlet
Drivetrain Operation
Observe Maximum Travel Speeds
Select a Gear
Transmission Operation
Operate Transmission — SS
Operate Transmission—PR
Electrohydraulic Transmission System Indicator — PR
PR Modulation (If Equipped)
Stop Tractor
Creeper Operation
MFWD and Front Axle Operation
Operate MFWD
Operate EH MFWD with Auto Engage and Brake Assist
Differential and Rear Axle Operation
Differential Lock
Power Take Off (PTO) Operation
Attach PTO-Driven Implement
Select Correct PTO Speeds
Operate Mechanical PTO
Operate EH PTO
Steering and Brake Operation
Operate Brakes
Adjust Steering Wheel
Set MFWD Steering Stops Turning Radius
AutoTrac™ Universal Steering
Hydraulics Operation
Warm Hydraulic System Oil
Hitch and Drawbar Operation
3-Point Hitch Components
Prepare Implement
Rockshaft Control Levers
Use Rockshaft Position Control
Set Position Control Lever Stop
Use Draft Control
Adjust Rockshaft Speed-of-Drop
Convert Category II Hitch to Category I
Position Center Link
Attach Implements to 3-Point Hitch
Adjust Hitch Side Sway
Level Hitch
Adjust Lateral Float
Adjust Rockshaft Control Lever Friction
Observe Drawbar Load Limitations
Select Drawbar Position
Adjust Drawbar Length
Use Swinging Drawbar
Use a Safety Chain
Selective Control Valve Operation
Connect Cylinder Hoses
Connect Cylinder Hoses—Mid-Mount Valve
Disconnect Cylinder Hoses
Correct Reversed Cylinder Response
Use Correct Hose Tips
Control Lever and Coupler Identification
Operate SCV Control Lever
Install Remote Outlet Oil Manifold
Adjust Cylinder Stop
Power Beyond Connections
Power Beyond Attached
Mid-Mount SCV Control Lever and Coupler Identification
Operate Multi-Function Lever
Match Tractor Power to Implement
Wheels and Tires Operation
Check Implement-to-Tire Clearance
Tire Sidewall Information
Select Tire Inflation Pressure
Tire Inflation Pressure Guidelines
Check Tire Inflation Pressure
Changing to a Different Tire Size
Select Front Tire Rolling Direction
Tighten Wheel/Axle Hardware Correctly
Tighten Bolts—Adjustable Front Axle
Tighten Bolts—MFWD Axle
Tighten Bolts—Rear Axle
Observe Rear Wheel Tread Width Limitations
Tread Settings—Multi-Position Rear Wheels
Tread Settings—Multi-Position MFWD Wheels
Tread Settings—Adjustable Front Axle
Adjust Front Axle Tread Width — 2WD
Adjust Front Axle Tread Width (2WD) — High Clearance
Checking Toe-In—Adjustable Front Axle
Adjusting Toe-In—Adjustable Front Axle
Adjusting Toe-In—Adjustable Front Axle (High Clearance)
Checking Toe-In—MFWD
Adjusting Toe-In—MFWD
Use Correct Tire Combinations
Calculate Tire Combinations (Graphic)
Ballasting
Planning for Maximum Productivity
Selecting Ballast Carefully
Ballast Limitations
Ballasting Two-Wheel Drive Tractors
Ballasting MFWD-Equipped Tractors
Determining Maximum Rear Ballast
Determining Maximum Front Ballast
Using Cast Iron Weights
Using Liquid Weight
Using Implement Codes
Additional Equipment
Front Loader Mounting Bracket Installation
Additional Equipment Operation
Operators’s Cab Operation
Avoid Contact with Pesticides
Operating Foldable ROPS
Wear Seat Belt
Selecting Seat Position
Adjusting Ride Comfort
Using Seat Belt
Adjusting Seat (Mechanical Suspension)
Instructional Seat
Adjusting Seat Arm Rests
Adjusting Steering Wheel Tilt
Using Emergency Exit
Opening Windows
Opening Door
Right-Hand Emergency Exit
Inner Mirror and Sun Visor
Adjusting Blower Speed
Controlling Temperature
Deicing, Demisting, or Defrosting Windshield
Optimizing A/C and Heater Performance
Operating Windshield Wiper and Washer
Installing a Monitor
Routing the Cables
Operating Radio
Setting Clock
Operating Cassette Tape or Compact Disc Player
Fixed ROPS Crossbar
Transport and Storage
Transport on Carrier
Driving Tractor on Roads
Towing Tractor
Operators Training Required
Use Caution on Hillsides
Storing Tractor
Removing Tractor from Storage
Using High Pressure Washers
Maintenance Intervals
Maintenance Interval Chart
Service Daily Before Start-Up
Break-In Service
Additional Service Information
Service Tractor Safely
Observe Service Intervals
Fuels, Lubricants, and Coolants
Diesel Engine Coolant (engine with wet sleeve cylinder liners)
Operating in Warm Temperature Climates
John Deere COOL-GARD™ II Coolant Extender
Water Quality for Mixing with Coolant Concentrate
Testing Coolant Freeze Point
Diesel Engine Oil — Non-Emissions Certified and Certified Tier 1 and Stage I
Diesel Engine Break-In Oil — Non-Emissions Certified and Certified Tier 1, Tier 2, Tier 3, Stage I, Stage II, and Stage III
Extended Diesel Engine Oil Service Intervals — Non-Emissions Certified and Certified Tier 1 and Stage I
Diesel Engine Oil — Tier 2 and Stage II
Engine Oil and Filter Service Intervals — Tier 2 and Stage II Engines
Oil Filters
Fuel Filters
Diesel Fuel
Testing Diesel Fuel
Minimizing the Effect of Cold Weather on Diesel Engines
Supplemental Diesel Fuel Additives
Oilscan™ and CoolScan™
Lubricity of Diesel Fuel
Multipurpose Extreme Pressure (EP) Grease
Mixing of Lubricants
Lubricant Storage
Transmission, Steering, Brake, Hydraulic, and Gear Case Oil
As Required Maintenance
Controls and Instruments Maintenance
Check and Adjust Clutch Pedal Free Play
Check Hoses and Hose Clamps
Check and Adjust Handbrake Lever
Engine Maintenance
Opening Hood
Observe Engine Operation Closely
Check Engine Oil Level
Change Engine Oil and Filter
Clean Engine Crankcase Vent Tube
Adjust Engine Valve Clearance and Fuel Injectors
Check Engine Idle Speeds
Air Intake, Fuel, Coolant, and Exhaust Maintenance
Engine Cooling System Components
Winterize Cooling System
Fuel System Components
Do Not Modify Fuel System
Check Coolant Level
Fuel System Water Separator
Drain Water and Sediment from Fuel Tank
Replacing Fuel Filter—OOS
Replacing Fuel Filter—Cab
Cleaning Water Separator
Replace Primary Fuel Filter
Checking Air Filter Restriction Indicator Performance
Replace Primary and Secondary Air Filter Elements
Check Unloader Valve Condition
Flush Cooling System and Replace Thermostat
Bleeding Fuel System
Clean Primary Air Filter Element
Cleaning Grille Screens, Radiator, Oil Cooler or A/C Condenser
Electrical and Lighting Maintenance
Prevent Battery Explosions
Clean and Check Battery
Inspecting and Replacing Alternator/Fan Belt
Observe Electrical Service Precautions
Removing Battery
Servicing Battery
Battery Replacement Specifications
Charging Battery
Checking Battery Condition
Connecting Starter Wiring
Connecting Alternator Wiring
Locating Fusible Link
Load Center Fuses and Relays – OOS
Load Center Fuses and Relays – Cab
Handling Halogen Light Bulbs Safely
Adjusting Headlights
Replacing Headlight Bulb
Replace Hazard Light Bulbs—OOS
Replacing Warning Light Bulb—Cab
Replacing Taillight Bulb—IOOS and Cab
Replace Worklight Bulb
Replacing Worklight Bulb—Cab
Replacing Dome Light Bulb—Cab
Replacing Controls Illumination Light Bulb—Cab
Replacing Rotary Beacon Light Bulb
Removing Beacon Light Assembly
Drive Train Maintenance
Check Neutral Start System — Mechanical PTO
Checking Neutral Start System — EH PTO
Transmission Maintenance
Check Transmission-Hydraulic System Oil Level
Change Transmission-Hydraulic Oil and Filter
Change Transmission-Hydraulic Oil and Secondary PR Transmission Filter
Clean Transmission Hydraulic Pickup Screen
MFWD and Front Axle Maintenance
Lubricate 2WD Front Axle
Lubricate 2WD Front Axle — High Clearance
Lubricate MFWD Axle
Check Planetary Drive Oil Level
Check MFWD Axle Oil Level
Change Planetary Drive Oil
Change MFWD Axle Oil
Check Front Axle End Play — 2WD
Differential and Rear Axle Maintenance
Lubricate Rear Axle Bearings
Change High Crop Rear Axle Oil
Power Take Off (PTO) Maintenance
Adjust 540E PTO Throttle Limiter — SS
Adjust Mechanical 540E PTO Lever
Adjust PTO Clutch Operating Rod — OOS
Adjust PTO Clutch Operating Rod — Cab
Steering and Brake Maintenance
Lubricate Front Axle Wheel Bearings — 2WD
Hydraulics Maintenance
Warming Hydraulic System Oil
Hydraulic Maintenance
Hitch and Drawbar Maintenance
Lubricate 3-Point Hitch
Adjust Rockshaft
Selective Control Valve Maintenance
Check Selective Control Valve
Wheels and Tires Maintenance
Checking Tires
Inspect All Tires
Change Tires Safely
Inspect Tractor for Loose Hardware
Pack Front Wheel Bearings (Adjustable Front Axle)
Tubeless Tire Repair
Ballasting Maintenance
Matching Ballast to Work Load
Checking for Correct Ballast
Measuring Wheel Slip—Manually
Ballasting Front-End for Transport
Installing Rear Cast Iron Weights
Additional Equipment Maintenance
Check Front Loader Mounting Bracket Installation Cap Screws Tensions
Operators Station Maintenance
Keep Cab Protection System Installed Properly
Inspect ROPS for Loose Hardware
Clean or Replace Cab Air Filters
Servicing Air Conditioner (Cab)
Adjust Throttle Friction
Troubleshooting
Wash Machine After Unloading
Engine Troubleshooting
Transmission Troubleshooting
Hydraulic System Troubleshooting
Brakes Troubleshooting
Rockshaft and quick-Coupler 3-Point Hitch Troubleshooting
Remote Hydraulic Cylinders Troubleshooting
Electrical System Troubleshooting
Heater and A/C System Troubleshooting (Cab)
Wipers, Work Lights, Dome Light, and Radio Troubleshooting (Cab)
On-Board Diagnostics
STOP, Service Alert, and Information Indicators
On-Board Diagnostic Tool
Diagnostic Trouble Code Mode
Diagnostic Address Mode
Specifications
Machine Specifications — Engine
Machine Specifications — Fuel System
Machine Specifications — Electrical System
Machine Specifications — Transmission
Machine Specifications — PTO
Machine Specifications — Hydraulic System
Machine Specifications — Three-Point Hitch
Machine Specifications — Capacities
Machine Dimensions — OOS
Machine Dimensions — Cab
Permissible Load Specifications
Estimated Vehicle Speed, SS (PY), 9 Forward/3 Reverse
Estimated Vehicle Speed, PR, 12 Forward/12 Reverse
Estimated Vehicle Speed, PR with Creeper
Identifications Numbers
Serial Numbers
Product Identification Number
Engine Serial Number Location
Fuel Injection Pump Serial Number Location
Alternator Identification Number Location
Transmission Serial Number Location
Front Axle (2WD) Serial Number Location
Mechanical Front Wheel Drive (MFWD) Serial Number Location
Air Conditioning Compressor Serial Number Location
Cab Serial Number Location
Certification and Warranty
ROPS Certificate - OOS
ROPS Certificate - Cab
Carbon Dioxide Emissions (CO₂)
Service Records
As Required Service Chart
Every 10 Hour Service
Every 50 Hour Service
First 100 Hour Service
Every 125 Hour Service
Every 250 Hour Service
Every 500 Hour Service
Every 1000 Hour Service
Every 1200 Hour Service
Every 2000 Hour Service
John Deere Service Keeps You On The Job
John Deere Parts
The Right Tools
Well-Trained Technicians
Prompt Service
Brand: John Deere
Introduction
Foreword
Product View
Trademarks
Glossary of Terms
Machine Overview
Safety Precautions
Fire Prevention
In Case of Fire
Instructional Seat
Avoid Hot Exhaust
Park Machine Safely
Safety Signs
Riders Safety Sign
ROPS Safety Sign
Engine Operation
Operate Key Switch
Start the Engine
Stop the Engine
Fill Fuel Tank
Light Switch
Use Headlights
High Beam Indicator
Use Tail Lights
Use Work Lights
Use Warning Lights
Use Turn Signals
Use Dome Light
Select a Gear
Stop Tractor
Creeper Operation
Operate MFWD
Differential Lock
Operate EH PTO
Operate Brakes
Prepare Implement
Use Draft Control
Level Hitch
Use a Safety Chain
Ballasting
Ballast Limitations
Using Liquid Weight
Wear Seat Belt
Using Seat Belt
Instructional Seat
Opening Windows
Opening Door
Routing the Cables
Operating Radio
Setting Clock
Fixed ROPS Crossbar
Towing Tractor
Storing Tractor
Break-In Service
Oil Filters
Fuel Filters
Diesel Fuel
Testing Diesel Fuel
Lubricant Storage
Engine Maintenance
Opening Hood
Check Coolant Level
Removing Battery
Servicing Battery
Charging Battery
Lubricate MFWD Axle
Adjust Rockshaft
Checking Tires
Inspect All Tires
Change Tires Safely
Troubleshooting
Specifications
Serial Numbers
Service Records
John Deere Parts
The Right Tools
Prompt Service
- JOHN DEERE CODE DTC LIST
