Martin Welker
104
230,310
John Deere 5065E And 5075E Tractors Operators Manual OMSU37534
Format: HTML
Brand: John Deere
Type of Machine: Tractors
Model: John Deere 5065E And 5075E Tractors
Parts Number: OMSU37534
Foreword
Section 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Prepare for Emergencies
Wear Protective Clothing
Protect Against Noise
Handle Fuel Safely—Avoid Fires
Handle Starting Fluid Safely
Fire Prevention
In Case of Fire
Avoid Static Electricity Risk When Refueling
Keep ROPS Installed Properly
Use Foldable ROPS and Seat Belt Properly
Stay Clear of Rotating Drivelines
Read Operator’s Manuals for ISOBUS Controllers
Use Seat Belt Properly
Operating the Tractor Safely
Avoid Backover Accidents
Limited Use in Forestry Operation
Operating the Loader Tractor Safely
Keep Riders Off Machine
Instructional Seat
Use Safety Lights and Devices
Transport Towed Equipment at Safe Speeds
Use Caution on Slopes, Uneven Terrain, and Rough Ground
Freeing a Mired Machine
Avoid Contact with Agricultural Chemicals
Handling Batteries Safely
Handle Electronic Components and Brackets Safely
Practice Safe Maintenance
Avoid Hot Exhaust
Clean Exhaust Filter Safely
Work In Ventilated Area
Support Machine Properly
Prevent Machine Runaway
Park Machine Safely
Transport Tractor Safely
Service Cooling System Safely
Service Tires Safely
Service Front-Wheel Drive Tractor Safely
Tightening Wheel Retaining Bolts/Nuts
Avoid High-Pressure Fluids
Do Not Open High-Pressure Fuel System
Store Attachments Safely
Section 10 - Safety Signs
Pictorial Safety Signs
Operator’s Manual
Riders
ROPS in Normal Position
Use Seat Belt
Section 15 - Controls and Instruments
Tractor Controls
Instrument Panel
Section 20 - Lights
Light Switch Positions
Use Headlights
Use High Beam Indicator
Use Tail Lights
Use Turn Signals
Use Hazard Lights
Use Flood Lamp
SevenTerminal Outlet
Section 25 - Operator's Platform
Operate Foldable ROPS
Select Seat Position—Standard Seat
Adjust Ride Comfort
Section 30 - Break-In Period
Observe Engine Operation Closely
Break-In Service
Section 35 - Prestarting Checks
Daily Service Before Starting Engine
Section 40 - Operating the Engine
Before Starting the Engine
Start the Engine
Check Engine Indicators and Gauges
Change Engine Speeds
Recommended Engine Speeds and Operating Procedures
Working With Speed/Hour Meter
Engines with Turbocharger
Stop the Engine
Use Booster Battery
Section 50 - Driving the Tractor
Operator Training Required
Reduce Fuel Consumption
Driving on Public Roads
Operate Transmission
Shifting Transmission
Select a Gear
Use Brakes
Use Differential Lock
Operate Mechanical Front Wheel Drive
Stopping Tractor (With Park Brake)
Stop the Tractor (With Park Pawl)
Loader Fixation Points (If Equipped)
Section 55 - Rockshaft and 3-Point Hitch
Match Tractor Power to Implement
3-Point Hitch Components
Rockshaft Control Levers
Set Position Control Lever Stop
Using Rockshaft Position Control
Use Draft Control
Adjust Rockshaft Rate-of-Drop/ Implement lock
Prepare Implement
Position Center Link
Attach Implements to 3-Point Hitch
Adjust Hitch Side Sway Chain
Leveling the Hitch
Adjust Lateral Float
Adjust Rockshaft Lever Friction - JD Rockshaft
Warm Hydraulic System Oil
Section 60 - Remote Hydraulic Cylinders
Use Correct Hose Tips
Control Lever and Coupler Identification—If Equipped
Connect Hoses
Connect Single-Acting Cylinder
Correct Reversed Cylinder Response
Neutral Lever Position
Extend/Retract Cylinder
Disconnect Hoses
Section 65 - Drawbar and PTO
Observe Drawbar / Wagon Hitch Load Limitations
Use Swinging Drawbar
Adjustable Drawbar
Proper Use of Drawbar
Attach PTO-Driven Implement
Operate Tractor PTO
Operate Tractor Dual PTO (If equipped)
Adjust PTO Clutch Operating Rod
Section 70 - Ballast
Plan for Maximum Productivity
Use Proper Ballast
Select Ballast Carefully
Match Ballast to Load Work
Check for Correct Ballast
Measure Wheel Slip (Manually)
Ballast Limitations
Ballast Front End for Transport
Ballast Two-Wheel Drive Tractors
Ballast MFWD-Equipped Tractors
Determine Maximum Rear Ballast
Determine Maximum Front Ballast
Use Cast Iron Weights
Install Rear Cast Iron Weights
Use Liquid Weight
Draining the Tires
Use Implement Codes
Section 75 - Wheels, Tires and Treads
Check Implement-to-Tire Clearance
Check Tire Inflation Pressure
Tire Inflation Pressure Chart
Tighten Wheel/Axle Hardware Correctly
Tighten Bolts—Adjustable Front Axle
Tighten Nuts—MFWD Axle
Tighten Bolts—Rear Axle
Observe Rear Wheel Tread Width Limitations
Tread Settings—Multi-Position Rear Wheels
Tread Settings—Adjustable Front Axle
Tread Setting—Multi-Position MFWD Wheels
Adjust Front Axle Tread Width
Check Toe-In
Adjust Toe-In—Two-Wheel Drive Tractor
Check Toe-In (MFWD Tractor)
Adjust Toe-In (MFWD Tractor)
Set MFWD Steering Stops Turning Radius
Mount Tires
Use Correct Tire Combinations
Tire Compatibility Chart
Section 80 - Transporting
Use a Safety Chain
Driving Tractor on Roads
Transport on Carrier
Tow Tractor
Section 85 - Fuels, Lubricants, and Coolant
Fuel Storage
Cold Weather Operation
Diesel Fuel
Handle and Storing Diesel Fuel
Bio-Diesel Fuel
Fill Fuel Tank
Lubricant Storage
Diesel Engine Oil
Oil Filters
Diesel Engine Coolant
Liquid Coolant Conditioner
Anti-Chatter Transmission/Hydraulic Oil
Use Correct Hydraulic-Transmission Filter Element
Gear Oil
Grease
Section 90 - Lubrication and Maintenance
Clean Vehicle of Hazardous Pesticides
Observe Service Intervals
Use Correct Lubricant
Break-In Service
Service Intervals
Section 95 - Service—10 Hours
Check Engine Oil Level
Check Coolant Level
Drain Water and Sediment From Fuel Tank and Fuel Filter
Lubricate as Necessary
Section 100 - Service—50 Hours
Check Transmission-Hydraulic System Oil Level
Check MFWD Axle Oil Level
Clean and Check Battery
Inspect All Tires
Lubricate Front Axle Pivot Pin(s)
Lubricate Steering Spindles
Inspect Tractor for Loose Hardware
Section 105 - Service—100 Hours
Change Engine Oil and Filter
Section 110 - Service—250 Hours
Service Air Cleaner
Inspect and Adjust Alternator/Fan Belt
Lubricate 3-Point Hitch
Check Neutral Start System
Check and Adjust Clutch Pedal Free Play
Section 115 - Service—500 Hours
Replace Fuel Filter
Section 120 - Service—600 Hours
Change Oil in MFWD Axle (If Equipped)
Clean Engine Crankcase Vent Tube
Pack Front Wheel Bearings (Adjustable Front Axle)
Check Hoses and Hose Clamps for Tightness
Lubricate Rear Axle Bearings
Check Engine Idle Speeds
Check Front Axle Pivot Pin
Section 125 - Service—1000 Hours
Change Transmission-Hydraulic Oil and Filter
Clean Transmission-Hydraulic Pickup Screen
Section 121 - Service—1100 Hours
Check and Replace Water Separator Bowl
Section 130 - Service—Annually
Replace Air Cleaner Elements
Section 135 - Service—2 Years/2000 Hours
Flush Cooling System
Section 140 - Service—As Required
Service Air Cleaner
Adjust Throttle Friction
Section 145 - Service
Service Tractor Safely
Engine Break-In Oil
Use High-Pressure Washers
Additional Service Information
Open Hood
Remove Hood
Air Intake System Components
Service Air Cleaner at Regular Intervals
Check Air Intake System
Remove Primary Air Cleaner Element
Clean Primary Element
Wash Primary Element
Inspect Element
Store Element
Replace Alternator/Fan Belt
Fuel System Components - Inline Pump
Fuel System Components - Rotary Pump
Do Not Modify Fuel System
Bleeding Fuel System - Inline Pump
Bleeding Fuel System - Rotary Pump
Bleed Fuel System At Fuel Injection Nozzles
Engine Cooling System Components
Cleaning Grille, Screens, Radiator and Oil Cooler
Winterize Cooling System
Prevent Battery Explosions
Observe Electrical Service Precautions
Battery Access
Remove Battery
Service Battery
Charge Battery
Battery Replacement Specifications
Connect Starter Wiring
Connect Alternator Wiring
Locate Fusible Link
Locate Fuses
Fuse Size and Function
Aim Headlights
Adjust Headlights
Replace Headlight Bulb
Replace Tail Light and Warning Light Bulbs
Replace Flood Lamp Bulb
Check Tires
Tubeless Tire Repair
Section 150 - Troubleshooting
Engine Troubleshooting
Transmission Troubleshooting
Hydraulic System Troubleshooting
Brakes Troubleshooting
Rockshaft and Quick-Coupler 3-Point Hitch Troubleshooting
Remote Hydraulic Cylinders Troubleshooting
Electrical System Troubleshooting
Section 155 - Tractor Storage
Tractor Storage
Removing Tractor From Storage
Section 160 - Specifications
John Deere 5065E Tractor
John Deere 5075E Tractor
Ground Speeds
Section 165 - Identification Numbers
Identification Plates
Record Tractor Serial Number
Record Front Axle (2-WD) Serial Number
Record Mechanical Front Wheel Drive (MFWD) Serial Number - If Equipped
ROPS Serial Number
Record Engine Serial Number
Record Transmission Serial Number
Keep Proof of Ownership
Keep Machines Secure
Section 170 - Lubrication Maintenance Record Charts
50, 250, 500 Hour Service Chart
600 Hour Service Chart
1000, 1200 Hour Service Chart
Annual Service Chart
2000 Hour Service Chart
As Required Service Chart
Section 180 - John Deere Service
John Deere Parts
The Right Tools
Well Trained Technician
Prompt Service
