Martin Welker
104
230,310
John Deere 5055E 5065E 5075E Tractor Repair Technical Manual TM900919
Brand: John Deere
Type of Machine: Tractor
Model: John Deere 5055E 5065E 5075E Tractor
Part Number: TM900919
Publication Date: 2013
Number of Pages: 790 Pages
FOREWORD
Section 10 - GENERAL INFORMATION
Group 05 - Safety
Recognize Safety Information
Understand Signal Words
Follow Safety Instructions
Handle Fluids Safely—Avoid Fires
Prevent Battery Explosions
Prepare for Emergencies
Prevent Acid Burns
Service Cooling System Safely
Avoid High-Pressure Fluids
Park Machine Safely
Support Machine Properly
Wear Protective Clothing
Work in Clean Area
Service Machines Safely
Work In Ventilated Area
Illuminate Work Area Safely
Replace Safety Signs
Use Proper Lifting Equipment
Service Tires Safely
Avoid Harmful Asbestos Dust
Avoid Heating Near Pressurized Fluid Lines
Remove Paint Before Welding or Heating
Use Proper Tools
Dispose of Waste Properly
Live With Safety
Group 10 - General Specifications (9x3 TSS Transmission)
Machine Specifications
Repair Specifications
Ground Speed Estimates — Sync Shuttle Transmission
Service Recommendations for O-Ring Boss Fittings
Service Recommendations for Flat Face O-Ring Seal Fittings
Metric Bolt and Cap Screw Torque Values
Unified Inch Bolt and Cap Screw Torque Values
Glossary of Terms
Group 11 - General Specifications (12x12 PR Transmission)
Ground Speed Estimates — PowrReverser PowrReverser is a trademark of Deere & Company Transmission
Glossary of Terms
Group 15 - Fuel and Lubricants
Diesel Fuel
Handling and Storing Diesel Fuel
Lubricity of Diesel Fuel
Testing Diesel Fuel
Biodiesel Fuel
Do Not Use Galvanized Containers
Fill Fuel Tank
Diesel Engine Break-In Oil
Diesel Engine Oil
Oil Filters
Heavy Duty Diesel Engine Coolant
Operating in Warm Temperature Climates
Testing Diesel Engine Coolant
Transmission and Hydraulic Oil
Additional Information About Diesel Engine Coolants and John Deere LIQUID COOLANT CONDITIONER
Use Correct Transmission/Hydraulic Filter Element
MFWD Axle Housing and Wheel Hub Oil
Grease
Mixing of Lubricants
Alternative and Synthetic Lubricants
Lubricant Storage
Group 20 - Serial Number Locations
Serial Numbers
Product Identification Number
Record Engine Serial Number
Fuel Injection Pump Serial Number
Alternator Serial Number Location
Power Steering Valve Serial Number Location
Starter Serial Number Location
Transaxle Serial Number Location (12x12 PR Transmission)
Record Mechanical Front Wheel Drive (MFWD) Serial Number
Group 25 - Features and Accessories
Standard Features
Factory Installed Optional Equipment
Field Installed Optional Kits and Accessories
Section 20 - ENGINE REPAIR
Group 05 - Engine
Service Equipment and Tools
Specifications
John Deere Engine Repair—Use CTM
Remove Engine — Cab
Remove Engine — OOS
Install Engine — Cab
Install Engine — OOS
Group 30 - Cooling System
Special or Essential Tools
Specifications
Torques for Hardware
Remove and Inspect Radiator (OOS)
Remove and Inspect Radiator (Cab)
Water Pump — Exploded View
Install Radiator
Replace Thermostat
Section 30 - FUEL, AIR INTAKE AND EXHAUST SYSTEMS
Group 05 - Fuel System
Injection Pump, Nozzle and Governor Repair—Use CTM
Remove, Inspect and Install Fuel Tank (OOS)
Remove, Inspect and Install Fuel Tank (Cab)
Group 10 - Air Intake and Exhaust System
Remove, Inspect, and Install Air Cleaner Elements
Check Air Inlet Pipe with Turbocharger
Exhaust Manifold Inspection
Remove Turbocharger
Install Turbocharger
Group 15 - Speed Control Linkage
Inspect and Repair Speed Control Linkage (OOS)
Inspect and Repair Speed Control Linkage (Cab)
Section 40 - ELECTRICAL REPAIR
Group 05 - Battery, Starter and Alternator
Starter Repair—Use CTM
Remove and Install Battery (OOS)
Remove and Install Battery (Cab)
Remove and Install Starter
Replace Alternator/Regulator
Group 10 - Electrical System Components
Other Material
Replace Air Filter Restriction Sensor
Replace Coolant Temperature Sender
Replace Engine Speed Sensor
Replace Engine Oil Pressure Sensor
Replace Key Switch (OOS)
Replace Key Switch (CAB)
Replace Light Switch
Replace Turn Signal Controller
Replace Instrument Panel (OOS)
Replace Instrument Panel (CAB)
Replace Rear PTO Switch (PR Transmission)
Replace Clutch Pedal Position Sensor (PR Transmission)
Remove and Install Rear PTO Switch (TSS Transmission)
Replace Park Position Start Switch
Replace Seat Switch (OOS)
Replace Fuel Level Sender (OOS)
Replace Fuel Level Sender (CAB)
Group 15 - Wiring Harness
Service Parts Kits
Remove Connector Body from Blade Terminals
Replace WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Connector
Install WEATHER PACK WEATHER PACK is a trademark of Packard Electric. Contact
Replace Battery Positive Cable (OOS)
Replace Battery Positive Cable (Cab)
Replace Hood Wiring Harness
Replace Beacon Lamp Wiring Harness
Replace Engine Wiring Harness (OOS)
Replace Engine Wiring Harness (Cab)
Replace Console Wiring Harness (9x3 TSS Transmission)
Replace Console Wiring Harness (12x12 PR Transmission)
Replace Rear Wiring Harness (9x3 TSS Transmission)
Replace Rear Wiring Harness (12x12 PR Transmisssion)
Replace 7 Pin Connector Wiring Harness
Section 50 - POWER TRAIN REPAIR (12X12 PR TRANSMISSION)
Group 05 - Clutch Housing
John Deere Transmission Repair — Use CTM
Specifications
Separate Engine from Clutch Housing (PR)
Install Engine to Clutch Housing (PR)
Remove, Inspect, and Repair Clutch Pedal and Linkage (PR)
Group 10 - Clutch Assembly
Specifications
Group 15 - Transmission
Other Material
Specifications
Inspect and Repair Gear Shift Lever
Inspect and Repair Range Shift Lever
Group 21 - Rear PTO
Other Material
Specifications
Group 26 - Differential
Essential Tools
Other Material
Specifications
Service Parts Kits
Group 30 - Final Drives
Other Material
Specifications
Group 35 - Mechanical Front Wheel Drive
Mechanical Front Wheel Drive – If Equipped—Summary of References
Essential Tools
Other Material
Specifications
MFWD Axle Repair — Use CTM
MFWD Dropbox Repair—Use CTM
Remove, Inspect and Install MFWD Drive Shaft(PR)
Remove and Install MFWD Axle Housing Assembly(PR)
Remove, Inspect and Install MFWD Axle Supports (Without Paddy Seal)(PR)
Section 51 - POWER TRAIN REPAIR (9X3 TSS TRANSMISSION)
Other Material
Essential Tools
Specification
Separate Engine from Clutch Housing (TSS)
Install Engine to Clutch Housing (TSS)
Inspect and Repair Clutch Pedal and Linkage (TSS)
Specification
Specifications
Group 21 - Rear PTO
Other Material
Specifications
Remove, Inspect and Install Rear PTO Lever and Linkage
Other Material
Specifications
Remove and Install Final Drive Assembly
Remove and Inspect Planetary Drive Assembly
Install Planetary Drive Assembly
Remove, Inspect, and Install Axle Shaft Assembly
Essential Tools
Other Material
Specifications
MFWD Axle Repair—Use CTM
Inspect and Repair MFWD Lever and Linkage
Remove and Install MFWD Drop Gearbox
Disassemble and Inspect MFWD Drop Gear box
MFWD Drop Gearbox Cross Section
Assemble MFWD Drop Gearbox
Section 60 - STEERING AND BRAKE REPAIR
Group 05 - Steering Repair
Other Material
Specifications
Service Parts Kits
Remove and Install Steering Column and Valve
Disassemble and Inspect Steering Valve - Sauer Danfoss
Assemble Steering Valve - Sauer Danfoss
Disassemble and Inspect Steering Valve - Eaton
Assemble Steering Valve - Eaton
Remove and Install Steering Cylinder (Global Front Axle)
Disassemble, Inspect and Assemble Steering Cylinder (Global Front Axle)
Remove and Install Steering Cylinder (Fixed Front Axle)
Disassemble, Inspect and Assemble Steering Cylinder (Fixed Front Axle)
Remove, Inspect and Install Tie Rod Assembly
Group 10 - Brake Repair
Other Material
Specifications
Remove and Install Brake Valve and Pedals
Disassemble and Inspect Brake Pedals and Valve
Brake Valve Cross Section
Assemble Brake Valve
Remove and Inspect Brakes
Install Brakes
Bleed Brakes
Adjust Brake Retractors
Inspect and Replace Brake Hydraulic Lines
Section 70 - HYDRAULIC REPAIR
Group 05 - Hydraulic Pump and Filter
Essential Tools
Specifications
Service Parts Kits
Remove, Inspect, and Install Hydraulic Oil Pick-Up Screen
Remove and Install Hydraulic Pump
Remove Hydraulic Pump External Components
Disassemble and Inspect Hydraulic Pump
Assemble Hydraulic Pump
Install Hydraulic Pump External Components
Remove and Install Hydraulic Oil Filter/Manifold
Inspect and Replace Hydraulic Supply and Suction/Return Lines
Group 15 - JD Rockshaft
Other Material
Specifications
Inspect and Repair Rockshaft Control Lever Assembly
Inspect and Repair Rockshaft Control Linkage
Inspect and Repair Draft Sensing Support Assembly
Replace Main Relief Valve
Replace Rockshaft Surge Relief Valve
Replace Rockshaft Control Valve
Remove and Install Rockshaft Case
Remove, Inspect, and Install Rockshaft Piston and Cylinder
Group 25 - EATON Selective Control Valve (SCV)
Install Single Selective Control Valve (SCV)
Install Rear Coupler Bracket
Install Hydraulic Hoses
Install Second Selective Control Valve (SCV)
Assemble Rear Quick Coupler
Group 30 - Mid Mount Selective Control Valve (SCV)
Service Parts Kit
Other Material
Specifications
Remove and Install Mid Mount Control Valve
Remove, Inspect and Install Joystick and Cables—Mid Mount Valve
Disassemble, Inspect, and Assemble Joystick—Mid Mount Coupler
Disassemble, Inspect and Assemble Mid Mount Control Valve
Inspect and Replace Hydraulic Hoses—Mid Mount Coupler
Section 80 - MISCELLANEOUS REPAIR
Group 05 - Front Axle
Specification
Remove and Install Front Axle — MFWD
Group 10 - Wheels
Specifications
Inspect and Replace Front Wheel Bearings
Tighten Bolts—Rear Axle (M-20 Stud)
Group 15 - 3-Point Hitch
Specifications
Inspect and Repair Fixed Draft Links
Inspect and Repair Lift Link (If Equipped)
Inspect and Repair Adjustable Lift Link (If Equipped)
Inspect and Repair Center Link
Group 25 - Hood
Remove and Install Hood
Section 90 - OPERATOR STATION REPAIR (OOS)
Group 05 - Seat and Support
Remove and Install Seat and Support (OOS)
Disassemble, Inspect and Assemble Seat and Seat Switch
Group 06 - Center Console
Remove Center Console Assembly
Install Center Console Assembly
Group 10 - Roll-GardROLL-GARD is a trademark of Deere & Company.
Specifications
Remove and Install Roll-Gard Roll-Gard is a trademark of Deere & Company
Group 15 - Operator Platform
Specifications
Remove and Install Right-Side Platform and Step
Remove and Install Left-Side Platform and Handrail
Group 20 - Fenders
Remove and Install Fenders
Group 25 - Canopy (If Equipped)
Specifications
Remove and Install Canopy
Section 91 - OPERATOR STATION REPAIR (CAB)
Remove and Install Seat and Support (Cab)
Group 10 - Control Console and Panel
Specifications
Remove and Install Right-Side Control Console
Remove and Install Left-Side Control Console
Remove and Install Center Control Console (TSS Transmission)
Remove and Install Center Control Console (PR Transmission)
Group 20 - Cab Components
Essential Tools
Other Material
Specifications
Remove, Inspect, and Install Cab Interior Recirculating Air Filters
Remove, Inspect, and Install Exterior Cab Intake Air Filter
Remove and Install Headliner
Remove and Install Left-Side Upholstery
Remove and Install Right-Side Upholstery
Remove and Install Windshield
Remove and Install Front Lower Windows
Remove and Install Rear Lower Window
Remove and Install Rear Upper Window
Remove and Install Side Windows
Remove and Install Cab Doors
Remove and Install Inner Roof for Air Conditioning Housing Repair
Remove Cab
Install Cab
Group 30 - Air Conditioning System
Essential Tools
Other Material
Specifications
Adjust A/C Temperature Control Switch
Recover/Recycle Air Conditioning Refrigerant
Replace Air Conditioning Receiver/Dryer
Remove, Inspect, and Install Air Conditioning Condenser
Remove, Inspect, and Install Air Conditioning Compressor
Test Volumetric Efficiency of Compressor
Test Compressor Shaft Seal Leakage
Disassemble and Assemble Compressor Clutch
Disassemble, Inspect, and Assemble Compressor
Check Compressor Clutch Hub Clearance
Inspect Compressor Manifold
Remove, Inspect, and Install Compressor Relief Valve
Remove and Install HVAC Housing Cover
Remove Blower Motors
Remove Evaporator/Heater Core
Leak Test Evaporator/Heater Core
Install Evaporator/Heater Core
Service Expansion Valve
Expansion Valve Bench Test
Refrigerant Oil Information
Check Compressor Oil Charge
Determine Correct Refrigerant Oil Charge
Add Refrigerant Oil to System
System Information
Flush Air Conditioning System
Evacuate Air Conditioning System
Charge Air Conditioning System
Group 35 - Heating System
Adjust Heater Temperature Control Cable
Replace Heater Temperature Control Cable
Remove Heater Control Valve
Leak Test Heater Control Valve
Install Heater Control Valve
