John Deere 5055E 5065E 5075E 5078E 5085E 5090E Tractors Repair Technical Manual TM801719
Brand: John Deere
Type of Machine: Tractors
Type of Manual: Technical Manual
Model: John Deere 5055E 5065E 5075E 5078E 5085E 5090E Tractors
Part Number: TM801719
Number of Pages: 450 Pages
Adjust Control Valve Sensitivity 1
Adjusting Differential Cone End 1
Inspecting And Repairing Draft Sensor Support Assembly 1
Inspecting And Repairing Engine Speed Control Linkage - Cab Tractors 1
Inspecting And Repairing Engine Speed Control Linkage - Open Operator Station 1
Inspecting And Replacing Hydraulic Return Supply Lines - A-Type 1
Inspecting And Replacing Hydraulic Return Supply Lines - B-Type 1
Inspecting And Replacing Steering Hydraulic Lines (With Oil Cooler) 1
Inspecting And Replacing Steering Hydraulic Lines (Without Oil Cooler) 1
Installation of Differential Drive Shaft 1
Installing Brakes 1
Parking Brake Components FIG 1
Removing And Installing Steering Column - Cab Tractors 1
Removing And Installing Steering Valve (With Oil Cooler) 1
Removing, Inspecting And Installing Differential Lock Assembly - Open Operator's Station 1
Removing, Inspecting And Installing Driven Shaft 1
Removing, Inspecting And Installing MFWD And Range Gears 1
Removing, Inspecting And Installing PTO Drive Shaft Assembly 1
Removing, Inspecting And Installing Shaft Assembly 1
Adjust Control Valve Sensitivity 2
Adjusting Differential Cone End 2
Disassemble, Inspect, And Assemble Dual Selective Control Valve (SCV) C FIG 2
Inspecting And Repairing Draft Sensor Support Assembly 2
Inspecting And Repairing Engine Speed Control Linkage - Cab Tractors 2
Inspecting And Repairing Pick-Up Hitch Control Lever Mechanism FIG 2
Inspecting And Replacing Hydraulic Return Supply Lines - A-Type 2
Inspecting And Replacing Hydraulic Return Supply Lines - B-Type 2
Inspecting And Replacing Steering Hydraulic Lines (With Oil Cooler) 2
Inspecting And Replacing Steering Hydraulic Lines (Without Oil Cooler) 2
Installation of Differential Drive Shaft 2
Installing Planetary Drive Assembly 2
Removing And Installing Steering Column - Cab Tractors 2
Removing And Installing Steering Valve (With Oil Cooler) 2
Removing, Inspecting And Installing Hydraulic Oil Collector Mesh 2
Removing, Inspecting And Installing MFWD And Range Gears 2
Removing, Inspecting And Installing PTO Drive Shaft Assembly 2
Removing, Inspecting And Installing PTO Drive Shaft Assembly (540 540E) 2
Removing, Inspecting And Installing Pick-Up Hitch Rate-of-Drop Control Valve 2
Removing, Inspecting And Installing Pick-up Hitch Cylinder And Piston 2
Removing, Inspecting And Installing Shaft Assembly 2
Removing, Inspecting And Installing Shifter Shaft Assemblies FIG 2
Removing, Inspecting And Installing of Reverse Shaft 2
Inspecting And Repairing Draft Sensor Support Assembly 3
Removing, Inspecting And Installing Pick-Up Hitch Rate-of-Drop Control Valve 3
Adjusting Differential Play
Adjusting Drive Clutch Fingers
Adjusting PTO Clutch Fingers
Assemble Transmission — Collarshift
Assembling Bosch Hydraulic Pump
Assembling Clutch
Assembling Range Box And MFWD Gears
Assembling Steering Valve
Assembling the Brake Valve
Assembling the Transmission
Bleeding Brakes
Checking Compressor Clutch Hub Distance
Compressor Volumetric Efficiency Test
Disassemble And Inspect Transmission— Collarshift
Disassembling And Inspecting Clutch Assembly
Disassembling And Inspecting Steering Valve
Disassembling And Inspecting Transmission
Disassembling Hydraulic Pump
Disassembling, Inspecting And Assembling Dual Selective Control Valve (SCV) D
Evacuating Air Conditioning System
Inspecting And Repairing MFWD Lever And Linkage - Cab Tractors
Inspecting And Repairing PTO Lever And Linkage - Cab Tractors
Inspecting And Repairing Pick-Up Hitch Control Lever Assembly
Inspecting And Repairing Pick-Up Hitch Control Lever Assembly B
Inspecting Compressor Manifold
Installing Brakes
Installing Cab
Installing Clutch Housing to Transmission - Cab Tractors
Installing Clutch Housing to Transmission - Open Operator's Station
Installing Drive to Center Housing
Installing Engine
Installing Engine to Clutch Housing - Open Operator's Station
Installing Heater Control Valve
Installing Heater Evaporator Core
Installing MFWD Creeper Gear Box
Installing Parking Brake Components
Installing Turbocharger
Installing Upper Shaft
Installing WEATHER PACK ™ Contact
Installing the Transmission
Machine Specifications - 5075E, 5078E, 5085E And 5090E Tractors
Mounted Upper Shaft
Remove And Inspect Brakes
Remove And Inspect Planetary Drive Assembly
Remove And Install Dual Selective Control Valve (SCV) C
Remove And Install Front Lower Windows
Remove And Install Rear Upper Window
Remove And Install Thermostat
Removing And Inspecting Differential Drive Shaft
Removing And Inspecting Radiator - 5078E, 5085E And 5090E Tractors
Removing And Installing Brake Valve And Pedals
Removing And Installing Cab Door
Removing And Installing Clutch Assembly
Removing And Installing Console And Left-HAnd Instrument Panel - Open Operator's Station
Removing And Installing Console And Right-HAnd Instrument Panel - Open Operator's Station
Removing And Installing Coolant Recovery Tank
Removing And Installing Creeper Transmission
Removing And Installing Differential Assembly
Removing And Installing Final Drive Assembly
Removing And Installing Front Windshield
Removing And Installing Hydraulic Filter Tubing
Removing And Installing Hydraulic Pump
Removing And Installing Inner Roof of AC Housing
Removing And Installing Panel Guard - 5078E, 5085E And 5090E Tractors
Removing And Installing Selective Control Valve (SCV) B
Removing And Installing Side Windows
Removing And Installing Single Selective Control Valve (SCV)
Removing And Installing StAndard Rear PTO Drive Shaft Assembly (StAndard And 540-540E)
Removing And Installing Steering Column And Valve (Without Oil Cooler)
Removing And Installing Third Selective Control Valve
Removing And Installing the Battery
Removing Cab
Removing Engine
Removing Fan Guards
Removing Fan Motors
Removing Heater Control Valve
Removing Heater Evaporator Core
Removing Transmission
Removing Turbocharger
Removing, Inspecting And Installing Differential Lock Assembly - Cab Tractors
Removing, Inspecting And Installing PTO (540 540E) Lever And Linkage - Cab Tractors
Removing, Inspecting And Installing Pick-Up Hitch Rate-of-Drop Control Valve D
Removing, Inspecting And Repairing PTO (540 540E) Lever And Linkage - Open Operator's Station
Replace Fan Control Switch
Replacing AC On Off Switch
Replacing AC Temperature Control Switch
Replacing Air Conditioning High Low Pressure Switch
Replacing Clutch Housing Retainer
Replacing Door Switch
Replacing Fan Motor Resistor
Replacing Heater Control Cable
Replacing Main Relief Valve
Replacing Pick-Up Hitch Control Valve
Replacing Pick-Up Hitch Pressure Relief Valve
Replacing Rear PTO Switch
Replacing Starter Relay
Replacing the Dome Light
Replacing the WEATHER PACK ™ Connector
Separating Clutch Housing from Transmission - Open Operator's Station
Separating Engine from Clutch Housing - Open Operator's Station
Brand: John Deere
Installing Brakes 1
Assembling Clutch
Bleeding Brakes
Installing Brakes
Installing Cab
Installing Engine
Mounted Upper Shaft
Removing Cab
Removing Engine
Removing Fan Guards
Removing Fan Motors
- JOHN DEERE CODE DTC LIST
