Martin Welker
104
230,310
John Deere 4990 Self-Propelled Windrower Diagnostic Technical Manual TM1820
Brand: John Deere
Type of Machine: Self-Propelled Windrower
Type of Manual: Diagnostic Technical Manual
Model: John Deere 4990 Self-Propelled Windrower
Part Number: TM1820
Publication Date: 2002
Number of Pages: 964 Pages
Introduction
Foreword
Service Technician Response
Contents
Safety Information
Safety
Diagnostic Information
Fuel/Air Systems
Electrical System Diagnosis and Test (Serial No. -163100)
Theory of Operation
System Information
Electrical Diagrams
Diagnosing Electrical System Malfunctions
Power Supply Circuits Tests
Starting System Tests
Charging System Tests (120 Amp)
Ground Speed Control System Diagnostics
Lighting System Tests
Platform Control Systems Tests
Machine Monitor System Tests
Fuel Control Tests
Heating and Air Conditioning Tests
Cab Accessories Circuits Tests
Air Seat Systems Tests
Miscellaneous Tests
Electrical System Diagnosis and Test (Serial Number 163101 - )
How To Use This Diagnostic Information
Test And Adjustments
Air Condition and Heat Diagnostics
Armrest - Float Pressure Diagnostics
Armrest - Field/Road Shift (Running Lights) Diagnostics
Armrest - Platform Engage Diagnostics
Armrest - Throttle Control Diagnostics
Auxiliary Power Diagnostics
Charging Diagnostics
COMFORT COMMAND Seat Diagnostics
Gauges - Engine Temperature and Fuel Level Diagnostics
Horn Diagnostics
Hydro Handle - Raise/Lower Diagnostics
Hydro Handle - Reel/Platform Speed Diagnostic
Hydro Handle - Platform Tilt Diagnostics
Lighting System - Dome and Console Light Diagnostics
Lighting System - Field Lights Diagnostics
Lighting System - Hazard Lights Diagnostics
Lighting System - Overall Diagnostic
Lighting System - Road/Running Lights Diagnostics
Lighting System - Turn Signal Diagnostics
Lighting System - Work Lights Diagnostics
Park Brake Diagnostics
Power Distribution Diagnostics
Radio Diagnostics
Rotating Wand Diagnostics
Starting System Diagnostics
Tachometer - Engine Speed and Hourmeter Diagnostics
Tachometer - Float Pressure Diagnostics
Tachometer - Ground Speed/Park Brake Diagnostics
Tachometer - Overall Diagnostics
Tachometer - Platform Speed and Hourmeter Diagnostics
Warning Display Panel - Alternator Diagnostics
Warning Display Panel - Engine Air Filter Diagnostics
Warning Display Panel - Engine Oil Pressure Diagnostics
Warning Display Panel - Engine Temperature Diagnostics
Warning Display Panel - Float Pressure Warning Diagnostics
Warning Display Panel - Hydraulic Oil Filter Diagnostics
Warning Display Panel - Hydrostatic Charge Pressure Low Diagnostics
Warning Display Panel - Hydrostatic Oil Temperature Diagnostics
Warning Display Panel - Low Fuel Diagnostics
Warning Display Panel - Operator Presence
Warning Display Panel - Overall Diagnostics
Warning Display Panel - Park Brake Diagnostics
Warning Display Panel - Road Shift Engage Light Diagnostics
Wiper Diagnostics
Connector Information (end views, numbers, location photos)
Power Train Diagnosis and Test
Tests and Adjustments
Power Train Diagnostics
Range Shift Diagnostics
Steering and Brake Release Diagnostics
Final Drive Diagnostics
Component Location
Steering and Brakes Diagnosis and Test
General
Steering System/Ground Speed Diagnostics
Hydraulic System Diagnosis and Test
General Hydraulic System Diagnostics
Priority Valve Diagnostics
Open Center Circuit Diagnostics
Platform Raise/Lower Diagnostics
Platform Float System Diagnostics
Platform Drive Diagnostics
Auxiliary-Charge Pump Diagnostics
Component Location
Operator Station (Serial No. -163100)
System Operational Checks
Diagnostics
Adjustments
Theory of Operation
Operator Station Diagnosis and Test (Serial No. 163101-)
Air Conditioning General Information
Air Conditioning and Heater Diagnostics
Component Location
Page Number
