John Deere 4730 4830 Self-Propelled Sprayers Repair Technical Manual TM2368
Brand: John Deere
Type of Machine: Self-Propelled Sprayers
Model: John Deere 4730 4830 Self-Propelled Sprayers
Part Number: TM2368
Publication Date: 2014
Number of Pages: 866 Pages
FOREWORD
Section 10 - GENERAL INFORMATION
Group 05 - Safety
Recognize Safety Information
Understand Signal Words
Perform Service Safely
Wait Before Opening High-Pressure Fuel System
Park Machine Safely
Servicing Electronic Control Units
Welding Near Electronic Control Units
Keep Electronic Control Unit Connectors Clean
Prevent Battery Explosions
Prepare for Emergencies
Protect Against High Pressure Spray
Prevent Acid Burns
Wear Protective Clothing
Avoid Contact with Agricultural Chemicals
Clean Vehicle of Hazardous Pesticides
Support Machine Properly
Service Machines Safely
Practice Safe Maintenance
Avoid Harmful Asbestos Dust
Work In Ventilated Area
Work in Clean Area
Avoid High-Pressure Fluids
Service Tires Safely
Service Cooling System Safely
Illuminate Work Area Safely
Replace Safety Signs
Use Proper Lifting Equipment
Use Proper Tools
Dispose of Waste Properly
Handle Electronic Components and Brackets Safely
Live With Safety
Group 10 - General Information
Machine Specification
Dimensions
Dimensions—All Machines
Identification Numbers
Sealants and Adhesives Cross-Reference Chart
Face Seal Fittings Assembly and Installation—All Pressure Applications
Metric Face Seal and O-Ring Stud End Fitting Torque Chart—Standard Pressures
Metric Face Seal and O-Ring Stud End Fitting Torque Chart—High Pressure Applications
SAE Face Seal and O-Ring Stud End Fitting Torque Chart—Standard Pressures
SAE Face Seal and O-Ring Stud End Fitting Torque Chart—High Pressure Applications
Four Bolt Flange Fittings Assembly and Installation—All Pressure Applications
SAE Four Bolt Flange Cap Screw Torque Values—Standard Pressure Applications
SAE Four Bolt Flange Cap Screw Torque Values—High Pressure Applications
External Hexagon Port Plug Torque Chart
Identifying Zinc-Flake Coated Fasteners
Glossary of Terms
Preparing and Painting Sprayer Components
Group 15 - Fuels and Lubricants
Diesel Fuel
Testing Diesel Fuel
Lubricity of Diesel Fuel
Diesel Engine Coolant (engine with wet sleeve cylinder liners)
Testing Diesel Engine Coolant
Supplemental Coolant Additives
Operating in Warm Temperature Climates
Additional Information About Diesel Engine Coolants and John Deere LIQUID COOLANT CONDITIONER
Diesel Engine Break-In Oil — Non-Emissions Certified and Certified Tier 1, Tier 2, Tier 3, Stage I, Stage II, and Stage III
Diesel Engine Oil — Non-Emissions Certified and Certified Tier 1 and Stage I
Extended Diesel Engine Oil Service Intervals — Non-Emissions Certified and Certified Tier 1 and Stage I
Hydrostatic/Hydraulic Drive Oil
Planetary Hub Oil
Grease
Suspension and Steering Grease
Lubricant Storage
Section 20 - ENGINE
Group 00 - Component Removal and Installation
Essential or Recommended Tools
Other Material
Specifications
John Deere Engine Repair—Use CTM
Remove and Install Engine
Remove and Install Hood
Repair Hood Screens
Remove and Install Exhaust System
Section 30 - FUEL, AIR INTAKE, AND COOLING SYSTEMS
Group 10 - Diesel Fuel System
Specifications
Remove Fuel Tank
Clean and Inspect Fuel Tank
Replace Fuel Filter, Fuel Pump, and Bleed Fuel System
Group 15 - Air Intake System
Specifications
Inspect and Service Air Intake System
Group 20 - Engine Cooling System
Specifications
Test Radiator and Coolant Tank Cap
Remove and Install Radiator
Remove and Install Charge Air Cooler
Inspect Belt Tensioner
Remove and Install Fan Drive
Remove, Install, and Repair Engine Accessory Drive
Fan Belt Routing
Group 25 - Hydraulic Oil Cooler and Air Conditioning Condenser/Fuel Cooler
Specifications
Other Material
Remove Air Conditioning Condenser/Fuel Cooler
Install Air Conditioning Condenser/Fuel Cooler
Remove and Install Hydraulic Oil Cooler
Leak Test Hydraulic Oil Cooler
Section 40 - ELECTRICAL
Group 05 - Batteries
Battery Safety
Prevent Damage to Electrical Systems
Checking Electrolyte Specific Gravity
Battery Replacement
Charging Batteries
Connecting Battery Cables
Group 10 - Connector Repair
Using High-Pressure Washers
Connector Information
Repair Procedure R-A
Repair Procedure R-B
Repair Procedure R-C
Repair Procedure R-D
Repair Procedure R-E
Repair Procedure R-F
Repair Procedure R-G
Repair Procedure R-I
Repair Procedure R-J
Repair Procedure R-K
Repair Procedure R-M
Repair Procedure R-N
Repair Procedure R-AE
Repair Procedure R-AF
Repair Procedure R-AG
Repair Procedure R-AH
Repair Procedure R-AI
Repair Procedure R-AJ
Repair Procedure R-AK
Group 15 - Charging Circuit
Repair Alternator—Use CTM77
Exploded View—Alternator
Remove and Install Alternator
Group 20 - Starting Circuit
Specifications
Repair Starter—Use CTM77
Remove and Install Starter Motor
Group 25 - Switches and Relays
Disconnect Electrical Circuit
Replace Side Console Switches
Replace A/C High/Low Pressure Switch
Replace Dome Light Switch
Replace Cab Door Light Switch
Replace Ignition Switch
Replace A/C Deicing Switch and Blower Motor Resistor
Replace Boom Fold/Level Switch
Load Center Fuses (S.N. —13 000)
Load Center Fuses (S.N. 13 001—)
Load Center Relays and Diodes
Replace Battery Box Fuses
Replace Remote Solution Pump Switch
Group 30 - Monitoring Systems and Sensors
Other Material
Specifications
Replace Turn Signal Indicator Bulbs
Replace Steering Column Mini-Pod
Replace Chassis Computer Unit/Spray Rate Control Unit (CCU/SRC)
Replace Radar Sensor
Replace Boom Height Control Unit (BHC)
Replace Hydraulic Oil Temperature Sensor
Replace Boom Height Sensor
Replace Boom Fold Cylinder Switch
Replace Wheel Speed Sensor
Replace Fuel Level Sender
Replace Solution Pressure Sensor
Remove and Install Flowmeter Sensor (Stainless Steel)
Remove and Install Flowmeter Sensor (Plastic)
Group 32 - Engine Control System
Other Material
Specifications
Replace Engine Control Unit (ECU)
Replace Engine Oil Pressure Sensor
Replace Engine Crank Speed Sensor
Replace Engine Coolant Temperature Sensor
Replace Air Filter Restriction Indicator Sensor
Group 35 - Lights
Replace and Adjust Field Lights
Safety Rules When Replacing Halogen Bulbs
Hood Headlight Bulb Replacement and Adjustment
Remove and Install Headlight Assembly
Group 40 - Convenience and Accessory Components
Replace Three-Pin Accessory Outlets
Replace Circulation Blower Motor
Remove Air Quality (AQS) Pressurizer Blower Motor
Replace Wiper Motor
Replace Windshield Washer Pump
Replace Seat Air Compressor Motor
Remove Radio and Speakers
Group 45 - Wiring Harness Routing
Engine Harness Routing
Chassis Harness Routing (S.N. —2000)
Chassis Harness Routing (S.N. 2001—)
Group 50 - Boom Trac Pro System
Decontaminate Spray Equipment
Remove and Install Boom Trac ProTM Breakaway Sensor
Remove and Install Boom Trac ProTM Inner Boom Sensor
Remove and Install Boom Trac ProTM Center Section Sensor
Remove and Install Boom Trac ProTM Roll Sensor
Section 50 - POWER TRAIN REPAIR
Group 05 - Remove and Install Hydrostatic Components
Service Equipment and Tools
Other Material
Specifications
Emergency Tow Procedure
Start-Up Procedure After Hydrostatic Repair
Flushing Hydrostatic Drive System
Tightening Wheel Hardware
Remove Hydrostatic Drive Pump
Install Hydrostatic Drive Pump
Replace Hydrostatic Drive Pump Isolators
Remove, Install, and Adjust Hydrostatic Control Cable
Remove and Install Hydrostatic Drive Motor
Remove and Install Drive Shaft
Inspect Drive Shaft
Remove Planetary Hub
Install Planetary Hub
Group 10 - Hydrostatic Drive Repair
Other Material
Specifications
Remove and Install Hydrostatic Pump Shaft Seal
Replace Hydrostatic Pump Cartridge Valves
Replace Hydrostatic Pump Charge Pressure Relief Valve
Repair Charge Pump
Remove and Install Hydrostatic Pump Control Valve
Remove and Install Control Valve Neutral Start Switch
Adjust Neutral Start Switch
Adjust Control Valve Eccentric Plug
Disassemble Hydrostatic Drive Pump
Inspect and Repair Hydrostatic Drive Pump
Assemble Hydrostatic Drive Pump
Disassemble and Assemble Hydrostatic Drive Motor—Style A
Disassemble and Assemble Hydrostatic Drive Motor—Style B
Disassemble and Assemble Hydrostatic Drive Motor Port Plate
Group 15 - Planetary Hub Repair
Other Material
Specifications
Disassemble Planetary Hub—4730 (Front and Rear); 4830 (Front)
Assemble Planetary Hub—4730 (Front and Rear); 4830 (Front)
Disassemble Planetary Hub—4830 (Rear)
Assemble Planetary Hub—4830 (Rear)
Section 60 - STEERING AND BRAKES
Group 05 - Steering Column
Specifications
Repair Steering Column (Standard and AutoTrac Equipped)
Bleed Steering System
Group 10 - Steering Valve
Other Material
Specifications
Service Parts Kit
Remove and Install Steering Valve
Repair Steering Valve
Remove and Install Toe-Control Valves
Group 12 - AutoTrac™ Steering System
Specifications
Remove and Install AutoTrac™ Controller
Remove and Install AutoTrac™ Steering Control Valve
Repair AutoTrac™ Steering Control Valve Assembly
Remove and Install AutoTrac™ Wheel Angle Sensor
Group 15 - Steering Cylinder
Specifications
Service Parts Kit
Remove and Install Steering Cylinder
Repair Steering Cylinder
Check Front Axle Toe-In
Adjust Front Axle Toe-In
Group 20 - Service Brakes
Other Material
Specifications
Service Parts Kit
Inspect Service Brake System Components
Remove and Install Service Brake Valve
Remove and Install Service Brake Caliper
Disassemble and Assemble Service Brake Caliper
Start-Up Procedure After Brake System Repair
Group 25 - Park Brakes
Other Material
Specifications
Remove and Install Park Brake Valve
Park Brake Check
Section 61 - SUSPENSION AND TREAD ADJUST REPAIR
Group 05 - Suspension
Other Material
Specifications
Replace Suspension Bushings and Seals
Adjust Front and Rear Air Spring Assemblies
Remove and Install Air Spring Leveling System Control Valve
Air Spring Leveling System Linkage
Group 10 - Tread Adjust Valves
Specifications
Service Parts Kit
Tread Adjust Valve Block
Remove and Install Tread Adjust Valve Block
Replace Vickers Control Valve Coil(s)
Replace Tread Adjust Valve
Remove, Inspect and Install Manifold Check Valve and Pilot Piston
Group 15 - Tread Adjust Cylinders
Other Material
Specifications
Service Parts Kit
Remove and Install Hydraulic Tread Adjust Cylinders
Tread Adjust Cylinder Identification
Disassemble and Assemble Tread Adjust Cylinders—Style A
Disassemble and Assemble Tread Adjust Cylinder—Style B
Group 20 - Tread Adjust Shim Pads
Other Material
Replacing Top Tread Adjust Shim Pads
Replacing Bottom Tread Adjust Shim Pads
Section 70 - HYDRAULIC SYSTEM
Group 05 - Hydraulic Pump
Specifications
Service Parts Kit
Relieve Hydraulic System Pressure
Remove and Install Hydraulic Pump
Disassemble and Assemble Hydraulic Pump
Remove and Install Hydraulic Pump Compensator
Repair Hydraulic Pump Compensator
Group 10 - Hydraulic Valves
Other Material
Specifications
Service Parts Kit
Boom Valve Assembly
Roll Bias Boom Valve (Optional)
Disassemble, Inspect and Assemble Roll Bias Boom Valve
Remove and Install Boom Control Valve
Boom Control Valve General Information
Disassemble, Inspect and Assemble Boom Control Valve
Replace Priority Valve
Disassemble, Inspect and Assemble Priority Valve
Replace Load Sense Shuttle Valve
Remove and Install Combination Valve
Repair Combination Valve
Remove and Install Traction Control Valve
Repair Traction Control Valve
Remove and Install Reverse Boost Valve
Group 15 - Boom Hydraulic Cylinders
Other Material
Specifications
Service Parts Kit
Hydraulic Cylinder and Boom Control Valve Fitting Torques
Remove and Install Boom Lift Cylinders
Remove and Install Boom Leveling Cylinder
Adjusting Boom Leveling Cylinders
Remove and Install Boom Inner Fold Cylinder
Adjusting Inner Fold Cylinder
Remove and Install Boom Outer Fold Cylinder
Adjusting Outer Fold Cylinder
Adjusting Stop Bolt
Remove and Install Roll Bias Cylinder
Outer Folding Cylinder and Leveling Cylinder Identification
Leveling Cylinder One Way Orifice Identification
Disassemble and Assemble Boom Lift Cylinder
Disassemble and Assemble Boom Leveling Cylinder—Style A
Disassemble and Assemble Boom Leveling Cylinder—Style B
Disassemble and Assemble Boom Inner Fold Cylinder
Disassemble and Assemble Outer Folding Cylinder—Style A
Disassemble and Assemble Outer Folding Cylinder—Style B
Disassemble and Assemble Roll Bias Cylinder
Group 20 - Hydraulic Oil Cooler
Group 25 - Hydraulic Reservoir
Specifications
Remove Hydraulic Reservoir
Install Hydraulic Reservoir
Clean Hydraulic Reservoir Strainers
Group 30 - Accumulator
Specifications
Remove and Install Accumulator
Charge Accumulator
Group 35 - Retractable Ladder
Service Parts Kit
Remove and Install Ladder Cylinder
Remove and Install Ladder Control Valve
Section 80 - SOLUTION SPRAY SYSTEM
Group 05 - Nozzle Repair
Cleaning SprayMaster™ 5-Position Nozzle Bodies—Standard Flow
Cleaning SprayMater™ 5-Position Nozzle Bodies—High Flow
Group 10 - Solution Tank
Other Material
Specifications
Flush Solution Tank and Spray System
Remove and Install Solution Tank
Remove and Install Agitation Nozzles
Group 15 - Solution Pump
Other Material
Specifications
Remove Solution Pump and Motor
Solution Pump Exploded View
Repair Solution Pump
Repair Solution Pump Hydraulic Motor
Install Solution Pump and Motor
Group 20 - Solution Control Valves
Other Material
Specifications
Disassemble and Assemble Fittings
Repair Check Valves and Strainers
Replace Solution Control Valves
Remove and Install Boom Section Shut-Off Valves
Replace Boom Section Shut-Off Valve Actuator
Remove and Install Boom Section Shut-Off Valve Actuator Terminals
Group 25 - Rinse Tank
Specifications
Remove and Install Rinse Tank Assembly
Repair Polyethylene Plastic
Group 30 - Eductor
Eductor Assembly
Remove and Install Eductor System Venturi
Group 35 - Flowmeter
Specifications
Remove and Install Flowmeter Assembly
Replace Flowmeter Insert
Recondition Flowmeter
Calibrate Flowmeter
Section 81 - FOAM MARKER SYSTEM
Group 05 - Foam Marker System Repair
Other Material
On Board Air Foam Marker Schematic
Repair Foam Marker Tubes
Foam Control Box Relay Identification (S.N. —13 000)
Foam Control Box Relay Identification (S.N. 13 001—)
Repair Tank
Remove and Install Foam Tank (S.N. —13 000)
Repair Foam Collectors
Repair Foam Marker Quick Fill (S.N. —13 000)
Fittings
Disassemble, Inspect, and Assemble Foam Mixing Head (S.N. —13 000)
Remove and Install Foam Mixing Chamber (S.N. 13 001—)
Group 10 - On Board Air System
Specifications
Remove and Install On Board Air Compressor
Remove and Install On Board Air Dryer
Repair On Board Air Dryer
Section 90 - OPERATOR STATION
Group 05 - Component Removal and Installation
Specifications
Remove and Install Cab
Group 10 - Controls
Other Material
Specifications
Service Parts Kit
Remove and Install Armrest
Remove and Install Armrest Control Cover
Remove and Install Multifunction Control Handle
Remove and Install Throttle Control
Remove and Install Throttle Sensor
Remove, Install, and Adjust Temperature Control Cable
Group 15 - Air Conditioning System
Other Material
Service Parts Kits
Specifications
Hose and Tubing O-Ring Connection Torques
System Information
Diagram - Air Conditioning System
Air Conditioning System Fittings—Reference Chart
Discharge Air Conditioning System
Flush Compressor
Flush Evaporator
Flush Evaporator (Through Expansion Valve)
Flush Condenser
Purge Air Conditioning System
Evacuate Air Conditioning System
Charge Air Conditioning System
Refrigerant Oil Information
Check Refrigerant Oil Charge
Determine Correct Refrigerant Oil Charge
Add Refrigerant Oil to System
Add Oil to Pressurized System
Remove and Install Compressor
Test Volumetric Efficiency
Test Shaft Seal Leakage
Disassemble and Assemble Compressor Clutch
Check Clutch Hub Clearance
Inspect Compressor Manifold
Disassemble, Inspect and Assemble Compressor
Remove and Install Compressor Relief Valve
Remove and Install Expansion Valve
Replace Receiver-Dryer
Leak Test Hydraulic Oil Cooler/Air Conditioning Condenser
Remove Air Quality System Module
Remove and Install Heater Core or Evaporator
Leak Test Air Quality System Module
Install Air Quality System Module
Group 20 - Heating System
Remove Heater Control Valve
Leak Test Heater Control Valve
Install Heater Control Valve
Group 25 - Air Suspension Seat
Other Material
Service Parts Kit
Remove Seat from Suspension
Operator Seat—Exploded View
Remove Air Seat Suspension System
Operator Seat Air Suspension Assembly—Exploded View
Disassemble and Assemble Operator′s Seat Air Suspension Assembly
Group 30 - Cab Door and Windshield
Specifications
Repair Cab Door Latch Assembly
Cab Door Adjustment—Step 1
Cab Door Adjustment—Step 2
Cab Door Adjustment—Step 3
Cab Door Adjustment—Step 4
Cab Door Adjustment—Step 5
Replace Windshield Glass or Seal
Remove and Install Door Cylinder
Section 100 - BOOM REPAIR
Group 05 - Boom Repair
Other Material
Specifications
Remove and Install Boom Center Roll Bearing
Remove and Install Boom Shock Absorbers and Rubber Stops
Remove and Install Boom Roll Suspension Springs
Remove and Install Boom Rear Anti-Yaw Link
Replace Boom Anti-Yaw Link Washers
Remove and Install Yaw Rocker Cushions
Section 199 - DEALER FABRICATED TOOLS
Group 05 - Dealer Fabricated Tools
DFN20 Solution Pump Seal Driver
DFN21 Pump Support Fixture
DFN22 Bearing Seat Driver
DFN23 Hydrostatic Motor Seal Driver
DFNX65-A1 Eccentric Plug Adjustment Tool
DFNX65-A2 Sizing Arbor
DFNXT1—High Pressure Flange Wrench
DFNXT2—Agitation Nozzle Tool
DFRW151—Radiator Cap Adapter
DFNXT13—Rear Planetary Assembly Spacer
Brand: John Deere
Part Number: TM2368
FOREWORD
Group 05 - Safety
Park Machine Safely
Prevent Acid Burns
Work in Clean Area
Use Proper Tools
Live With Safety
Dimensions
Glossary of Terms
Diesel Fuel
Testing Diesel Fuel
Planetary Hub Oil
Grease
Lubricant Storage
Section 20 - ENGINE
Other Material
Specifications
Repair Hood Screens
Specifications
Remove Fuel Tank
Specifications
Specifications
Fan Belt Routing
Specifications
Other Material
Battery Safety
Battery Replacement
Charging Batteries
Specifications
Other Material
Specifications
Other Material
Specifications
Group 35 - Lights
Replace Wiper Motor
Other Material
Specifications
Inspect Drive Shaft
Other Material
Specifications
Repair Charge Pump
Other Material
Specifications
Specifications
Other Material
Specifications
Service Parts Kit
Specifications
Specifications
Service Parts Kit
Other Material
Specifications
Service Parts Kit
Other Material
Specifications
Park Brake Check
Other Material
Specifications
Specifications
Service Parts Kit
Other Material
Specifications
Service Parts Kit
Other Material
Specifications
Service Parts Kit
Other Material
Specifications
Service Parts Kit
Boom Valve Assembly
Other Material
Specifications
Service Parts Kit
Adjusting Stop Bolt
Specifications
Specifications
Charge Accumulator
Service Parts Kit
Other Material
Specifications
Other Material
Specifications
Other Material
Specifications
Specifications
Group 30 - Eductor
Eductor Assembly
Specifications
Calibrate Flowmeter
Other Material
Repair Tank
Fittings
Specifications
Specifications
Group 10 - Controls
Other Material
Specifications
Service Parts Kit
Other Material
Service Parts Kits
Specifications
System Information
Flush Compressor
Flush Evaporator
Flush Condenser
Other Material
Service Parts Kit
Specifications
Other Material
Specifications
- JOHN DEERE CODE DTC LIST
