Martin Welker
104
230,310
John Deere 4720 Pull-Type Forage Harvester Parts Catalog PC1964
Brand: John Deere
Type of Machine: Pull-Type Forage Harvester
Model: John Deere 4720 Pull-Type Forage Harvester
Part Number: PC1964
Number of Pages: 191 Pages
ALPHABETICAL INDEX
A
Actuator Arm, Row-Trak (Row-Crops and Corn Heads)
Actuator, Row-Trak Switch
Adjusting Bolt, Knife, Stationary
Alarms, Slip Clutch Alert; Row-Trak; Iron-Gard
Angle, Spout-Trak Controls Shield
Angles, Filler, Corn-Head Frame
Arm, Actuator, Row-Trak (Row-Crops and Corn Heads)
Armature, Electric Clutch
Auger
Auger Door
Auger Door Seal
Auger Door, Upper
Auger Drive
Auger Drive Sprockets
Auger End Supports
Auger Panels
Auger Stripper
Axle Guard, Tractor (Corn Heads)
B
Bands, Fan
Bar, Nut, Knife, Cutterhead
Base Module (Electrohydraulic Valves)
Base, Console
Bearings, Stationary Knife
Bevel Gear Case (Input Shaft)
Bevel Gear Case (Output Shaft)
Blade, Fan
Bold, Adjusting, Knife, Stationary
Brace, Diagonal
Brace, Discharge Spout
Bracket, Knife, Cutterhead
C
Cable, Feed Roll Gear Case Shift
Cable, Spout Cap Tilt
Cap, Spout
Case, Gear, Feed Roll (L.H. Half)
Chain Coupler, Tongue Front Powershaft
Chain Coupler, Tongue Rear Powershaft
Channel, Spout-Trak (Tongue Section)
Chromed Recutter Screens
Circuit Breaker, Power Harness
Clamp, Knife, Cutterhead
Clean-Out Cover, Discharge Spout
Cleanout Cover, Vertical Discharge Spout
Cleanout Door, Fan Housing
Clevis (7-Ft. Hay Pickup)
Clutch Alert, Slip
Connectors, Electrical, Weatherpack
Console
Console and Power Harness
Console Harness Extension Harness (4-W.D. Tractors
Console SUports (Tractors with or without Sound-Gard Body)
Control Valve Module (Spout Rotation, Spout Cap Tilt, Tongue Positioning)
Corn Head Drive (343)
Corn Heda Drive (449)
Corn Head Mounting Frame
Coupler, Cutterhead
Coupler, Feed Roll Drive
Couplers, level, Hydraulic Outlet
Cover, Auger Door
Cover, Clean-Out, Discharge Spout
Cover, Knife Sharpener
Cover, Toolbox
Covers, Tongue Hydraulic Hoses
Covers, Tongue Wiring Harness
Crank, Knife Sharpener
Cutterhead
Cutterhead Bearings
Cutterhead Coupler
Cutterhead Door
Cutterhead Drive Idler
Cutterhead Drive Shaft
Cutterhead Drive Shield
Cutterhead Housing
Cutterhead Housing Filler Door
Cutterhead Housing Liners
Cutterhead Lift Cylinders
Cutterhead Lift Float Springs
Cutterhead Lift Hydraulic Cylinders Pins, Hoses, and Fittings
Cutterhead LIft Lockout Valve, Hose, and Fittings
Cutterhead Pivot Block
Cutterhead Unit (Less Iron-Gard)
Cutterhead Unit (With Iron-Gard)
Cutterhead Unit Downstop Control
Cylinder, Discharge Spout Cap Tilt, Hydraulic
Cylinder, Feed Roll Gear Case Shift, Hydraulic
Cylinder, Wagon Hitch Disconnect
Cylinders, Cutterhead LIft
Decal Kit (English)
Decal Kit (French-Canadian)
Deflector, Power
Deutsch Terminals and Connectors
Diagonal Brace
Discharge Spout
Discharge Spout Brace
Discharge Spout Cap Tilt Hydraulic Cylinder
Discharge Spout EXtensions, Vertical
Discharge Spout Wear Plates
Door, Auger
Door, Cutterhead
Door, Filler, Cutterhead Housing
Door, Knife Sharpener
Door, Knife, L.H.
Door, Knife, R.H.
Door, Spout-Trak Control Shield
Door, Upper Auger
Double Piloted Module, Electrohydraulic Valves (Standard)
Downstop Control Harness
Downstop Control, Cutterhead Unit
Drive Shaft, Cutterhead
Drive Shaft, Harvesting Unit
Drive Sprocket, Harvesting Unit
Drive, Auger
Drive, Corn Head (343)
Drive, Corn Head (443)
E
Electric Clutch Harness (With Iron-Gard)
Electric Clutch Harness (Without Iron-Gard)
Electric Clutch, Feed Roll Drive
Electric Clutch Pin Bracket
Electrical Connector Service Kit
Electrical Connectors, Deutsch
Electrical Terminals, Deutsch
Electrohydraulic Valve (Harvesting Unit LIft)
Electrohydraulic Valves (Double Piloted Module)
Electrohydraulic Valves (Feed Roll Gear Case Shift)
Electrohydraulic Valves, Double Piloted Module (Standard
Electrohydraulic Valves Hydraulic Hoses and Fittings
Electrohydraulic Valves Main Wiring Harness
Electrohydraulic Valves Unload Module
Electronic Module, Spout-Trak
End Supports, Auger
Equal Angle Hitch (5-1/2-Inch)
Extension Harness, Console Harness (4-W.D. Tractors)
Extension, Wagon Hitch
Extensions, Horizontal, Discharge Spout
Extensions, Vertical Discharge Spout
F
Fan
Fan and Fan Shaft
Fan Bands
Fan Bands and Front Fan Panel
Fan Blades Hardware
Fan Drive
Fan Drive Idler
Fan Drive Shields
Fan Panel, Rear
Feed Roll Arms
Feed Roll Drive Coupler
Feed Roll Drive Electric Clutch
Feed Roll Drive Lower Slip Clutch (With Iron-Gard)
Feed Roll Drive Lower Slip Clutch (Without Iron-Gard)
Feed Roll Drive Shield
Feed Roll Drive Upper Slip Clutch (With Iron-Gard)
Feed Roll Drive Upper Slip Clutch (Without Iron-Gard)
Feed Roll Drive, Lower
Feed Roll Drive, Upper
Feed Roll Gear Case (L.H. Half)
Feed Roll Gear Case Gears
Feed Roll Gear Case Shift Cable
Feed Roll Gear Case Shift Cylinders Hoses and Fittings
Feed Roll Gear Case Shift Hydraulic Cylinder
Feed Roll Gear Case Wiring Harness
Feed Roll Pan, Lower
Feed Roll Stop Riser (Corn Head)
Feed Roll Stop System (With Iron-Gard)
Feed Roll, Lower Front (With Iron-Gard)
Feed Rolls Gear Case and Support, Lower (With Iron-Gard)
Feed Rolls, Lower (Without Iron-Gard)
Feed Rolls, Upper
Fittings, Hydraulic Motor, Sput Rotation
Fittinsg, Spout Cap Tilt Hydraulic Cylinder
Flexible Drive Shaft, Spout-Trak (Spout Section)
Flexible Drive Shaft, Spout-Trak (Tongue Section)
Float Springs, Cutterhead Lift
Flow Divider Valves (Electrohydraulic Valves)
Frame, Front, Cutterhead Mounting
Frame, Main
Frame, Mounting, Corn Head
Frame, Recutter Screen
Front Fan Panel
Front Frames, Cutterhead Supporting
Front PTO Driveline
G
Gatherer Points Suspension with Row-Trak (3-RRC and 4-RRC)
Gatherer Points Suspension with Row-Trak (343 and 443 Corn Heads)
Gear Case and Support, Lower Feed Rolls (With Iron-Gard)
Gear Case Shift Hydraulic Cylinder, Feed Roll
Gear Case, Bevel (Input Shaft)
Gear Case, Bevel (Output Shaft)
Gear Case, Feed Roll (L.H. Half)
Gear Case, Feed Roll (R.H. Half)
Gear Case, Reverse Grind
Gears, Feed Roll Gear Case
Gears, Spur, Spout Rotation
Guard, Axle, Tractor (Corn Heads)
Guide, Actuator Arm Tube, Row-Trak (Row-Crops and Corn Heads)
Handle, Knife Sharpener
Harness, Clutch, Electric (Without Iron-Gard)
Harness, Console
Harness, Electric Clutch (With Iron-Gard)
Harness, Main Wiring
Harness, Power
Harness, Power (John Deere Tractors with Sound-Gard Body other than 50 Series)
Harness, Wiring (With Potentiometer) (Spout-Trak)
Harness, Wiring, Row-Trak, Downstop Control, Slip Clutch Shaft
Harness, Wiring, Spout-Trak (Tongue Section)
Harnesses, Row-Trak Wiring (Corn Heads)
Harnesses, Row-Trak Wiring (Row-Crops)
Harvesting Unit Idler and Support
Hinge, Auger Door
Hinge, Cutterhead Drive Shield
Hitch Bar, Tongue
Hitch bar, Equal Angle (5-1/2 Inch)
Hitch, Wagon Transport
Hookup, Tractor
Horizontal Extensions, Discharge Spout
Hose and Fittings, Lockout Valve
Hoses and Fittings, Cutterhead Lift Hydraulic Cylinders
Hoses and Fittings, Feed Roll Gear Case Shift Cyliders
Hoses and Fittings, Tongue Positioning Hydraulic Cylinder
Hoses, Hydraulic Motor, Spout Rotation
Housing, Cutterhead
Hub, Auger Drive Shear
Hub, Fan Shaft Sheave
Hub, Input Shaft Sheave
Hub, Wheel
Hubs, Lower Front Feed Roll (With Iron-Gard)
Hydraulic Cylinder, Tongue Positioning
Hydraulic Hoses, Electrohydraulic Valves
Hydraulic Hoses, Spout Cap Tilt Hydraulic Cylinder
Hydraulic Hoses, Tongue Positioning Hydraulic Cylinder
Hydraulic Motor Hoses and Fittings, Spout Rotation
Hydraulic Outlet Lever Couplers
Hydraulic Spout Motor
Hydraulic Wagon Hitch
Hydraulic Wagon Hitch Disconnect
I
Idler, Cutterhead Drive
Idler, Drive, Power Deflector
Idler, Fan Drive
Idler, Harvesting Unit
Idler, Slip Clutch
ID VIEW
Implement Safety Chain
Input Shaft, Bevel Gear Case
Instruction Plate, Console
Internal Half Coupler, Hydraulic Hoses, Electrohydraulic Valves
Iron-Gard Instruction Plate, Console
Iron-Gard Relay Wiring Harness
J
Jackstand (Cutterhead Unit)
Jackstand (Tongue)
K
Kit, Decal (English)
Kit, Decal (French-Canadian)
Kit, Electrical Connector Service
Knife Sharpener Cover
Knife Sharpener Door
Knife Sharpener Stone
Knife Sharpener Supports
Knife, Cutterhead
Knife, Stationary
L
Latch, Rear Powerline Shield
Latch, Toolbox
Lever Couplers, Hydraulic Outlet
Lift Cylinders, Cutterhead
Liners, Cutterhead Housing
Lockout Valve, Cutterhead Lift
Lockout, Cylinder, Tongue
Lower Feed Roll Drive
Lower Feed Roll Drive U-Joints
Lower Feed Roll Pan
Lower Feed Rolls (Without Iron-Gard)
Lower Feed Rolls Gear case and Support (With Iron-Gard)
M
Magnet, Lower Front Feed Roll (With Iron-Gard)
Magnetic Pickup, Spout-Trak
Main Frame
Main Wiring Harness
Micro-Switch Actuator, Row-Trak (Row-Crops and Corn Heads)
Micro-Switch, Row-Trak (Row-Crops and Corn Heads)
Motor, Spout, Hydraulic
N
Neutral Stop Switch
O
Outlet Socket, Power Harness to Console Harness
Output Shaft, Bevel Gear Case
P
Paddles, Power Deflector
Pan, Feed Roll, Lower
Panel, Front Fan
Pins and Brackets, Hydraulic Cylinder, Cutterhead Lift
Pins, Jackstand Mounting (Tongue)
Pins, Mounting, Tongue Cylinder
Pivot Block, Cutterhead
Pivot, Stationary Knife
Plate, Slip (5-1/2 Inch)
Points, Suspension, Gatherer (With Row-Trak) (3-RRC and 4-RRC)
Points, Suspension, Gatherer (With Row-Trak) (343 and 443 Corn Heads)
Potentiometer Wiring Harness, Spout-Trak (Spout Section)
Potentiometer Wiring Harness, Spout-Trak (Tongue Section)
Power Deflector
Power Deflector Drive Idler
Power Deflector Drive Sprocket
Power Harness (John Deere Tractors with Sound-Gard Body Other than 50 Series)
Powershaft, Tongue Front
Powershaft, Tongue Rear
R
Rear Fan Panel
Recutter Screen Frame
Recutter Screen Supports
Recutter Screens
Relay Module, Iron-Gard
Relay Switch, Power Harness
Remote Lubrication Hoses, Cutterhead Bearings
Reset Switch, Iron-Gard
Reverse Grind Gear Case
Roll Fillers (Corn Head)
Row-Trak Actuator Arm (Row-Crops and Corn Heads)
Row-Trak Micro-Switch Actuator, Spring, and Supports (Row-Cropss and Corn Heads)
Row-Trak Micro-Switch, Support and Shield (Row-Crops and Corn Heads)
Row-Trak Wiring Harness
Row-Trak Wiring Harnesses (Corn Heads)
Row-Trak Wiring Harnesses (Row-Crops)
S
Safety Chain, Implement
Screens, Recutter
Service Kit, Electrical Connectors
Sharpener Supports, Knife
Sheave, Bevel Gear Case Input Shaft
Sheave, Drive, Cutterhead
Sheave, Driven, Cutterhead
Sheave, Fan Driven
Sheet, Rear Fan
Shield, Bevel Gear Case and Rear Powerline
Shield, Control Valves
Shield, Downstop Control Valve
Shield, Electronic Modules
Shield, Cutterhead Drive
Shield, Feed Roll Drive
Shield, Row-Trak Micro-Switch (Row-Crops and Corn Heads)
Shield, Slip Clutch
Shield, Spout-Trak Controls
Shields, Fan Drive
Shields, Tractor Hookup and Reverse Gear Case
Shift Cable, Feed Roll Gear Case
Shifting Fork, Feed Roll Gear Case
Shifting Lever, Feed Roll Gear Case
Shock Absorber, Idler, Cutterhead Drive
Slip Clutch Alert
Slip Clutch Alert Harness
Slip Clutch Idler and Support
Slip Clutch Shield
Slip Clutch, Feed Roll Drive, Lower (With Iron-Gard)
Slip Clutch, Feed Roll Drive, Lower (Without Iron-Gard)
Slip Plate (5-1/2 Inch)
Smooth Roll Scraper (Without Iron-Gard)
Solenoid, Feed Roll Stop System (With Iron-Gard)
Spindle, Wheel
Stpout Cable Support
Spout Cap
Spout Cap Tilt Cable
Spout Cap Tilt Hydraulic Cylinder Fittings
Spout Cap Tilt Hydraulic Cylinder Hoses
Spout Extensions, Vertical Discharge
Spout Motor, Hydraulic
Spout Rotation Hydraulic Motor Hoses and Fittings
Spout Rotation Hydraulic Motor Support
Spout Transition
Spout-Trak Electronic Module
Spout-Trak Shields
Spout-Trak Transport Bracket
Spout, Discharge
Spring, Row-Trak Actuator (Row-Crops and Corn Heads)
Spring, Upper Feed Roll
Springs, Float, Cutterhead Lift
Sprocket, Power Deflector Drive
Stationary Knife
Stone, Knife Sharpener
Stripper, Auger
Strippers, Auger, Corn Head Frame
Support, Fan Drive Idler
Support, Hydraulic Motor, Spout Rotation
Support, Idler, Harvesting Unit
Support, Row-Trak Micro-Switch (Row-Crops and Corn Heads)
Support, Tractor Hookup
Supports, Console
Supports, Feed Roll Gear Case Shift Cylinders
Supports, Recutter Screen
Supports, Row-Trak Actuator (Row-Crops and Corn Heads)
Supports, Sharpener, Knife
Switch, Neutral Stop
T
Terminals, Electrical, Weatherpack
Test Module, Iron-Gard
Test Switch, Iron-Gard
Toggle Switches, Electrohydraulic Functions
Toggle Switches, Spout-Trak and Row-Trak
Tongue
Tongue Chain Coupler
Tongue Cylinder Lockout
Tongue Pedestal Shields
Tongue Positioning Hydraulic Cylinder Hoses and Fittings
Tongue Positioning Limit Harness
Tongue Rear Chain Coupler
Tongue Rear Universal Joint Hookup
Tongue Wiring Harness Covers
Toolbox
Tractor Axle Guard (Corn Heads)
Tractor Hookup
Tractor Hookup Support
Transition, Spout
Transitions, Power Deflector
U
U-Joints, Lower Feed Roll Drive
U-Joints, Upper Feed Roll Drive
Unbalanced Load Module (Harvesting Unit Lift)
Unit, Cutterhead (Less Iron-Gard)
Unit, Cutterhead (With Iron-Gard)
Universal Joint Hookup, Tongue Rear
Unload Module (Electrohydraulic Valves)
Upper Feed Roll Drive U-Joints
Upper Feed Rolls
V
Valve, Control Module (Additional Function)
Valve, Electrohydraulic (Harvesting Unit LIft)
Valve, Flow Divider (Electrohydraulic Valves)
Valves, Electrohydraulic
Valves, Electrohydraulic (Feed Roll Gear Case Shift)
Valves, Electrohydraulic (Unload Module)
Valves, Flow Divider (Electrohydraulic Valves)
Vertical Discharge Spout Extensions
W
Wagon Hitch Disconnect, Hydraulic
Wagon Hitch Extension
Wagon Hitch, Hydraulic
Wagon Transport Hitch
Wear Plates, Discharge Spout
Weatherpack Connectors
Weatherpack Terminals
Weatherpack Terminals and Connectors
Wheel Hubs
Wheel Spindles
Wiring Harness (With Potentiometer) (Spout-Trak)
Wiring Harness, Feed Roll Gear Case, Iron-Gard
Wiring Harness, Main, Spout-Trak
Wiring Harness, Relay, Iron-Gard
Wiring Harness, Tongue Positioning
Wiring Harnesses, Row-Trak (Corn Heads)
Wiring Harnesses, Row-Trak (Row-Crops)
Worm Gear, Spout Rotation Hydraulic Motor
Y
Yokes, Lower Feed Roll Drive
Yokes, Upper Feed Roll Drive
